  4. Test Adapter OpenDTU
dtuhoymilesopendtusolar
457 Beiträge 47 Kommentatoren 173.6k Aufrufe 42 Beobachtet
  • L Laser
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:06:49 up 49 min,  1 user,  load average: 2.06, 1.84, 1.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=60.8'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-29 20:06:49 CEST
               Universal time: Mon 2023-05-29 18:06:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    otto
    /home/otto
    otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        1.5G        4.7G        1.0M        1.6G        6.2G
    Swap:            99M          0B         99M
    Total:          7.9G        1.5G        4.8G
             7811 M total memory
             1508 M used memory
             2309 M active memory
              607 M inactive memory
             4671 M free memory
               92 M buffer memory
             1538 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G   11G   96G  10% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Mon May 29 19:17:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=af0e4bd2-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon May 29 19:17:04 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Mon May 29 19:17:04 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Mon May 29 19:17:05 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Mon May 29 19:17:05 2023] EXT4-fs (sda2): 13 orphan inodes deleted
    [Mon May 29 19:17:05 2023] EXT4-fs (sda2): recovery complete
    [Mon May 29 19:17:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 29 19:17:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon May 29 19:17:07 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    6.0G    /var/
    3.6G    /var/log
    3.4G    /var/log/journal/aaa8ad0836ed4822b2dfcde31d4a0fb2
    2.2G    /var/lib
    Archived and active journals take up 3.3G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    980M    /opt/iobroker/iobroker-data/history
    158M    /opt/iobroker/iobroker-data/files
    67M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.i2c.0                    : i2c                   : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.owfs.0                   : owfs                  : raspberrypi                              -  enabled, port: 4304
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.vedirect.0               : vedirect              : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "i2c"          : 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "logparser"    : 2.1.1    , installed 2.1.2
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        3542
    States:         2903
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:7 https://repos.influxdata.com/debian bullseye InRelease
    Hit:8 https://apt.grafana.com stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14432      561/sshd: /usr/sbin
    tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       79357      12606/io.hm-rpc.1
    tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       81026      12591/io.hm-rpc.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       79950      12436/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       79199      12436/iobroker.js-c
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       78802      12636/io.mqtt.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14434      561/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        3830       872/grafana
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       80534      13066/io.simple-api
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14634      748/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       80911      12454/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       80725      13673/io.web.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14445      723/dhcpcd
    udp        0      0 0.0.0.0:50020           0.0.0.0:*                           108        3556       424/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3554       424/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       79510      12767/io.shelly.1
    udp6       0      0 :::57690                :::*                                108        3557       424/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12068      723/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        3555       424/avahi-daemon: r
    2023-05-29 20:07:44.196  - warn: javascript.0 (12524)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:7:15)
    2023-05-29 20:07:44.196  - warn: javascript.0 (12524)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2541:34)
    2023-05-29 20:07:44.196  - warn: javascript.0 (12524)     at listOnTimeout (node:internal/timers:569:17)
    2023-05-29 20:07:44.197  - warn: javascript.0 (12524)     at processTimers (node:internal/timers:512:7)
    2023-05-29 20:07:44.253  - warn: javascript.0 (12524) getState "opendtu.0.total.yieldtotal" not found (3)
    2023-05-29 20:07:44.254  - warn: javascript.0 (12524)     at Object.Solar (script.js.Solar.Ges-kWh-Solarertrag:7:15)
    2023-05-29 20:07:44.255  - warn: javascript.0 (12524)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2541:34)
    2023-05-29 20:07:44.255  - warn: javascript.0 (12524)     at listOnTimeout (node:internal/timers:569:17)
    2023-05-29 20:07:44.255  - warn: javascript.0 (12524)     at processTimers (node:internal/timers:512:7)
    2023-05-29 20:07:44.256  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 0
    2023-05-29 20:07:44.256  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: Laden: 75
    2023-05-29 20:07:44.256  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 75
    2023-05-29 20:07:49.194  - warn: javascript.0 (12524) getState "opendtu.0.total.power" not found (3)
    2023-05-29 20:07:49.196  - warn: javascript.0 (12524)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:7:15)
    2023-05-29 20:07:49.196  - warn: javascript.0 (12524)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2541:34)
    2023-05-29 20:07:49.196  - warn: javascript.0 (12524)     at listOnTimeout (node:internal/timers:569:17)
    2023-05-29 20:07:49.196  - warn: javascript.0 (12524)     at processTimers (node:internal/timers:512:7)
    2023-05-29 20:07:49.255  - warn: javascript.0 (12524) getState "opendtu.0.total.yieldtotal" not found (3)
    2023-05-29 20:07:49.257  - warn: javascript.0 (12524)     at Object.Solar (script.js.Solar.Ges-kWh-Solarertrag:7:15)
    2023-05-29 20:07:49.257  - warn: javascript.0 (12524)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2541:34)
    2023-05-29 20:07:49.257  - warn: javascript.0 (12524)     at listOnTimeout (node:internal/timers:569:17)
    2023-05-29 20:07:49.257  - warn: javascript.0 (12524)     at processTimers (node:internal/timers:512:7)
    2023-05-29 20:07:49.258  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 0
    2023-05-29 20:07:49.258  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: Laden: 75
    2023-05-29 20:07:49.258  - info: javascript.0 (12524) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 75
    iob diag has finished.
    Habe nochmal die letzte NPV Version manuell installiert (aber erst, als opendtu nicht über die Admin- Oberfläche (Katzenfenster) zu finden war). War das ein Fehler?
    https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
    #217
    @laser sagte in Test Adapter OpenDTU:
    War das ein Fehler?
    Wie oft eigentlich noch? JAAAAAAAAAAAAA!
    L 1 Antwort Letzte Antwort
    • L Laser
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=60.8'C
      volt=0.9360V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      otto
      /home/otto
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               1508 M used memory
               4671 M free memory
                 92 M buffer memory
               1538 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      6.0G    /var/
      3.6G    /var/log
      2.2G    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3542
      States:         2903
      Pending Updates: 0
      #218
      Dein Dateisystem macht die Grätsche.
        War das ein Fehler?
        Laser
        schrieb am zuletzt editiert von Laser
        #219
        @thomas-braun OK. Da es vorher schon nicht ging, konnte ja nicht mehr viel passieren. HAbe ich mir gedacht. Jetzt muß ich sehen, wie ich die niedrige Version wieder reinbekomme.
        Dateisystem? Habe einen neuen Raspi eingebaut. Mit alter SSD. Hat die SSD Alterungserscheinungen?
        • L Laser
          #220
          @laser
          /usr/bin/npm            9.6.7
          falsche Version, hier gehört 9.5.1 dazu.
          • L Laser
            #221
            Offenbar. Die vergisst inodes. Und/oder zu fährst die Kiste nicht sauber herunter sondern rupfst die brutal vom Strom.
              Laser
              #222
              @thomas-braun Ich mußte die Stromzufuhr radikal trennen, da vorhin nichts mehr ging (Auch kein Ping auf die Adresse des PI's.)
              • L Laser
                #223
                @laser
                Dann war das Ding auch vorher schon mumpf.
                Installier es neu auf einem neuen Speichermedium.
                  @laser
                  Laser
                  #224
                  @thomas-braun Mache ich. Hole morgen eine neue SSD (die 3. in diesem Jahr).
                  • L Laser
                    #225
                    Würde mir zu denken geben... Besser mit dem System umgehen und schon mal über eine USV nachgedacht?
                      Laser
                      #226
                      @thomas-braun Nachgedacht schon...Stromausfall gibt es hier aber nicht.
                      • L Laser
                        #227
                        Dann reiß halt die Kiste nicht immer vom Strom...
                          Laser
                          #228
                          @thomas-braun Das mache ich ganz bestimmt nur, wenn nichts mehr geht! Nicht aus Spaß.
                          Morgen wird es neu.
                          • L Laser
                            Morgen wird es neu.
                            #229
                            Dann warte ab bis die Vorgänge abgeschlossen sind und die offenen Dateien sicher zurückgeschrieben wurden. Dann erst ausschalten. Übrigens gibt es auch Gehäuse (oder wenigstens Taster) für den Pi, mit dem der per Knopfdruck sauber heruntergefahren wird. Zumindest wird es versucht.
                            Das ArgonOne ist z. B. so ein Gehäuse.
                            Wenn öfter 'nichts mehr geht' stimmt auch was grundsätzliches nicht mit deinem Ding. Mein Pi rennt hier eigentlich immer durch, der hängt sich nicht weg.
                            DuffyD 1 Antwort Letzte Antwort
                            • L Offline
                              Laser
                              #230
                              @thomas-braun Ich habe jetzt einen neuen Pi (8GB). Morgen eine neue SSD und ein neues System. Dann sehe ich weiter. Mit dem Taster werde ich versuchen. Daß der Pi noch etwas tut ist die Voraussetzung.
                                DuffyD Offline
                                DuffyD Offline
                                Duffy
                                #231
                                ... ich kenne das Problem mit dem Abstürzen auch aber nur wenn ich in echarts oder, eher seltener bei Flot, mehrerere Kurven darstellen lassen will. Bei Grafana ist der rp4 noch nie nie abgestürzt.
                                Wo muss man den diesen "soft Resetknopf " anschließen?
                                Gruß Duffy
                                Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                                Node.js: v22.23.2
                                NPM: 10.9.4
                                js-controller 7.1.2
                                Linux: Trixie
                                • DuffyD Duffy
                                  Gruß Duffy
                                  #232
                                  @duffy sagte in Test Adapter OpenDTU:
                                  Sollte in der Anleitung zu dem Ding stehen. Google weiß das aber auch bestimmt, welche Pins man da kurzschließen müsste.
                                    Laser
                                    #233
                                    @thomas-braun , @Duffy
                                    Das Problem vertiefte sich, nachdem ich die Influx- Datenbank installiert habe. Da wird ja sehr oft geschrieben. Wenn dann die Stromzufuhr unterbrochen wird... Zur Zeit startet auch der "sourceanalytix" nicht mehr. Für den Reset- Taster muß die CPU aber noch laufen? Zumindest hatte ich mal so etwas installiert.
                                    Ergänzung: Nach der Neuinstallation (Vis Adapter vor dem Backup einspielen nicht vergessen) funktioniert (fast) Alles wieder. Opendtu ist immer noch nicht auswählbar. Bis zum nächsten Ausfall...
                                    • L Laser
                                      #234
                                      Hier fällt nix aus. Was ballerst du denn alles auf die Kiste drauf?
                                        Laser
                                        #235
                                        @thomas-braun Ich habe eben die Influx- Datenbank und ein minimal- Grafana System mit drauf. Der Open-DTU Adapter ist übrigens immer noch nicht auswählbar. Weder unter normal noch beta- Repostery.
                                        • L Laser
                                          #236
                                          @laser
                                          Hier geht das natürlich. Irgendwas machst du anders als andere...
                                          Beta-Repo mal für die Aktion aktiviert?
