  5. Ich suche jemand der mir beim Scripten hilft
34 Beiträge 4 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • B Bernd 1337
    @mickym ich hab das jetzt so geändert
      <variables>
        <variable id="m%;]I;h}!Z_t1Yxam4uW">Karte</variable>
      </variables>
      <block type="on_ext" id="6ypcIzCMQRF3|OFtCu$H" x="63" y="38">
        <value name="OID0">
          <shadow type="field_oid" id="0$-3/p1BOdqFB?*T/|X*">
            <field name="oid">mqtt.0.ESP_RFID.RFIDREADER.Tag</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="variables_set" id="I.Lo8mCc0E0q@@iGg;|5">
            <field name="VAR" id="m%;]I;h}!Z_t1Yxam4uW">Karte</field>
            <value name="VALUE">
              <block type="logic_boolean" id="~OL_*yAm$_4{(C9A/jXS">
              </block>
            </value>
            <next>
              <block type="controls_if" id="||aVdXtP+JhK=)GbQ9Hf">
                <value name="IF0">
                  <block type="logic_compare" id="hi_LV-~|4b0Yztv7~L|?">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="on_source" id="x+ln-_-0U)Tux:1R7@[0">
                      </block>
                    </value>
                    <value name="B">
                      <block type="text" id="C-9RSDVvHt,*/7i!h+VQ">
                        <field name="TEXT">3336024090</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="telegram" id="$f7szM,?Na{|_@os+_*%">
                    <field name="LOG"></field>
                    <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                    <value name="MESSAGE">
                      <shadow type="text" id=")4:*x|SqSR?8}=RMp3l)">
                        <field name="TEXT">Bitte Karte auflegen ....</field>
                      </shadow>
                    </value>
                    <next>
                      <block type="variables_set" id="c|uI79O:p=`bGD^2cX.@">
                          <block type="logic_boolean" id="Wo`~q2PVe:LE}ygEnFgY">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
        <next>
          <block type="on_ext" id="=+~QO#0ot8=Nw%V3-@.=">
            <value name="OID0">
              <shadow type="field_oid" id="YzzM0f~KBZke?G!c@~Vk">
                <field name="oid">0_userdata.0.Test.RFIDAuthenticated</field>
              </shadow>
            </value>
              <block type="controls_if" id="NL6aL;Ac/(jEx|iJ,-*(">
                <value name="IF0">
                  <block type="variables_get" id=".NvW34##(TntCFkFImX2">
                  </block>
                </value>
                  <block type="controls_if" id="?qpE]9?f#_Oti?duTCH.">
                    <value name="IF0">
                      <block type="logic_compare" id="02qDfU#z[)DZgT{:gDpw">
                        <value name="A">
                          <block type="on_source" id="`6(JWh75dvXQI%Y?J!y{">
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="GFGo=No-j6RTuOrYFU}O">
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="telegram" id="I3,ety?iL=kvB%.XX4Q^">
                          <shadow type="text" id="A,GxGfTJ#*e+z,/btj6J">
                            <field name="TEXT">Aktion autorisiert, bitte bestätigen!</field>
                          </shadow>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="update" id="3WCXv[gbcadX|-(l3nhN">
                        <field name="OID">0_userdata.0.trigger</field>
                          <block type="logic_boolean" id="6kxkk!0(esICbvoRL#ZY">
                          </block>
                        </value>
                        <next>
                          <block type="variables_set" id="3~,*yt=?|ep%=9c6Zi/s">
                              <block type="logic_boolean" id="AV4`m}EJQTZ3J*OXbUMf">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    TT-Tom
    @bernd-1337 bitte in code tag packen und vom Blockly ein Screenshot.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • mickymM mickym
      Jedenfalls würde ich es über 2 Nachrichten lösen#
      Die erste Nachricht wird getriggert von was auch immer.
      Mit der 2. Nachricht bestätigst Du.
       <block type="on_ext" id="C0fI0opS7as77;sjK5e2" x="37" y="138">
         <value name="OID0">
           <shadow type="field_oid" id="OXhs1)[K?nvf./bx|L-x">
             <field name="oid">0_userdata.0.Test.Alarm</field>
           </shadow>
         </value>
           <block type="debug" id="^p00Gns;|_EIh5XE(/mR">
             <value name="TEXT">
               <shadow type="text" id=".LsqS7;;AF+iQ|@!kakC">
                 <field name="TEXT">Alarm schalten, bitte autorisieren</field>
               </shadow>
             </value>
           </block>
         </statement>
         <next>
           <block type="on_ext" id="6ypcIzCMQRF3|OFtCu$H">
             <value name="OID0">
                 <field name="oid">0_userdata.0.Test.RFIDTag</field>
               </shadow>
             </value>
                 <value name="IF0">
                     <value name="A">
                       </block>
                     </value>
                     <value name="B">
                         <field name="TEXT">123456789</field>
                       </block>
                     </value>
                   </block>
                 </value>
                   <block type="debug" id="I/B#NA!y@9/c+*9*Q_n~">
                     <value name="TEXT">
                       <shadow type="text" id="[:MIpn%r$u=]:~%]c+ZY">
                       </shadow>
                     </value>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      Bernd 1337
      @mickym habe das jetzt so gemacht aber er steckt beim anfang fest Screenshot_7.png
      • B Bernd 1337
        TT-Tom
        @bernd-1337
        du nutzt den selben Datenpunkt bei beiden Triggern. @mickym hatte einen separaten für die Bestätigung. Das muss deine Rückmeldung vom Telegram
        Gruß Tom
        Public Transport
        B 2 Antworten Letzte Antwort
        • T TT-Tom
          @bernd-1337
          Bernd 1337
          @tt-tom okay ich schau mal
          • T TT-Tom
            @bernd-1337
            Bernd 1337
            @tt-tom du meinst vom Telegram adapter request ja
            • B Bernd 1337
              TT-Tom
              @bernd-1337
              da ich Telegram nicht nutze kann ich die Datenpunkte nicht nennen, nur wie es funktionieren müsste.
              Hast du schon mal Rückmeldungen von Telegram ausgewertet?
              Gruß Tom
              Public Transport
              • T TT-Tom
                @bernd-1337
                Bernd 1337
                • B Bernd 1337
                  TT-Tom
                  @bernd-1337 sende doch einfachmal etwas über Telegram zurück dann kannst du sehen welcher DP sich ändert und sein Inhalt.
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    Bernd 1337
                    @tt-tom wenn ich ja die karte auflege ändert sich dort garnichts bekomme den text aber im adapter ändert sich nichts nur wenn ich selbst etwas zu dem bot schreib steht bei request etwas
                    • B Bernd 1337
                      TT-Tom
                      @bernd-1337 Wenn du die Meldung "bitte Karte auflegen" bekommst und du darauf antwortest, kommt nix an? verstehe ich das Richtig?
                      Gruß Tom
                      Public Transport
                      B 4 Antworten Letzte Antwort
                      • T TT-Tom
                        Bernd 1337
                        @tt-tom wenn ich etwas rein schreibe doch bei request kommt dan das was ich rein geschrieben habe
                        • T TT-Tom
                          Bernd 1337
                          @tt-tom habe das ausgewählt aber es passiert nichts wenn ich was rein schreibe
                          • T TT-Tom
                            Bernd 1337
                            @tt-tom habe das als leztes rein geschrieben nachdem ich die karte aufgelegt hatte Screenshot_9.png
                            • T TT-Tom
                              Bernd 1337
                              • B Bernd 1337
                                TT-Tom
                                @bernd-1337 okay, dann Haber wir das geklärt.
                                du musst hier jetzt den Datenpunkt "request" einsetzen und hinter "falls -> Wert =" den Vergleich mit dein Text machen den du zurücksendest.
                                Gruß Tom
                                Public Transport
                                • T TT-Tom
                                  Bernd 1337
                                  • B Bernd 1337
                                    TT-Tom
                                    oder das was du zurückschreibst, wobei Tobi immer mitkommt
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      Bernd 1337
                                      • B Bernd 1337
                                        TT-Tom
                                        @bernd-1337 mach mal einen zweiten Durchlauf
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          Bernd 1337
                                          @tt-tom ja hab ich funzt
