  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. BSB-LAN Adapter Funktioniert nach iobroker update nicht.
    5.1k
40 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
    @fischerjedd
    Irgendwas musst du ja beim Adapter an Einstellungen getätigt haben.
    Das Log schaut man sich am besten so an
    iob logs --watch | uniq
    und startet den Adapter/die Instanz dann neu. Ausgaben im Logfile dann hier, in CodeTags eingebettet, reinkopieren.
    FischerJedd
    2023-05-29 11:42:04.780 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
    2023-05-29 11:42:04.781 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
    at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
    at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
    at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (node:events:513:28)
    at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    at ClientRequest.emit (node:events:525:35)
    at Socket.socketOnData (node:_http_client:551:9)
    at Socket.emit (node:events:513:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Readable.push (node:internal/streams/readable:234:10)
    at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    2023-05-29 11:42:14.802 - info: bsblan.0 (10434) Setup new objects (700) ...
    2023-05-29 11:42:16.913 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
    2023-05-29 11:42:16.914 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
    • F FischerJedd
      @fischerjedd
      In CodeTags, damit man das auch lesen kann.
      F 1 Antwort Letzte Antwort
        @fischerjedd
        FischerJedd
        noch nie gemacht
        so
        29.05.2023 00:00:09.078 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
        29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
        29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
        bei neuem RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
        unter plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
        bei Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
        unter self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
        bei Request.emit (node:events:513:28)
        unter Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
        bei ClientRequest.emit (node:events:525:35)
        bei Socket.socketOnData (node:_http_client:551:9)
        bei Socket.emit (node:events:513:28)
        bei addChunk (node:internal/streams/readable:324:12)
        bei readableAddChunk (node:internal/streams/readable:297:9)
        bei Readable.push (node:internal/streams/readable:234:10)
        bei TCP.onStreamRead (node:internal/stream_base_commons:190:23)
        29.05.2023 00:00:21.344 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
        29.05.2023 00:00:22.374 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
        29.05.2023 00:00:22.375 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
        29.05.2023 00:00:33.392 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
        • F FischerJedd
          noch nie gemacht
          so
          @fischerjedd
          Nein.
          Schau hier rein:
          • F FischerJedd
            @fischerjedd
            In dem Protokoll steht
            RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char bei neuem RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15) bei plumbing.callback (/opt/iobroker/node_modules/ request-promise-core/lib/plumbing.js:87:29) bei Request.RP$callback [als _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) bei self.callback (/opt/iobroker/node_modules/request/request.js:185:22) bei Request.emit (node:events:513:28) bei Request.onRequestError (/opt/iobroker/node_modules/request/request .js:877:8) bei ClientRequest.emit (node:events:525:35) bei Socket.socketOnData (node:_http_client:551:9) bei Socket.emit (node:events:513:28) bei addChunk (node :internal/streams/readable:324:12) bei readableAddChunk (Knoten:internal/streams/readable:297:9) bei Readable.push (Knoten:internal/streams/readable:234:10) bei TCP.onStreamRead (node:internal/stream_base_commons:190:23)
            GlasfaserG Offline
            GlasfaserG Offline
            @fischerjedd sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
            @fischerjedd
            Dazu habe ich ganz am Anfang etwas geschrieben !
            @glasfaser sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
            Stelle in der Instanz die Logstufe auf DEBUG .
            Starte den Adapter und zeige hier die Log Ausgabe davon !
            EDIT :
            Expertenmodus ..... dann auf den Bleistift ... von Info auf Debug ändern .
            • GlasfaserG Glasfaser
              @fischerjedd
              EDIT :
              FischerJedd
              schrieb am zuletzt editiert von FischerJedd
              @glasfaser
              Super erklärt, jetzt habe ich dussel es auch kapiert.
              Thomas BraunT F 2 Antworten Letzte Antwort
              • F FischerJedd
                @glasfaser
                @fischerjedd
                Warum ändert sich die Sprache im logfile von Englisch auf Deutsch?
                Übersetzungsautomatiken im Browser aktiv? Aber das dürfte das LogFile nicht tangieren.
                Vielleicht führt das auch zu den 'invalid header value char' Meldungen...
                • F FischerJedd
                  @glasfaser
                  FischerJedd
                  @fischerjedd
                  Nächstes Problem
                  Ich mache hier gerade eine Fortbildung
                  • F FischerJedd
                    @fischerjedd
                    Nächstes Problem
                    @fischerjedd
                    Nächstes Problem
                    Schau hier rein:
                      @fischerjedd
                      Nächstes Problem
                      Schau hier rein:
                      FischerJedd
                      Ich habe es mal in Firefox gestartet
                      alles das selbe
                      • F FischerJedd
                        alles das selbe
                        GlasfaserG Offline
                        GlasfaserG Offline
                        alles das selbe
                        Was das selbe ... stehn gerade auf dem Schlauch was du meinst !?
                          alles das selbe
                          FischerJedd
                          @glasfaser
                          ich meinte, das Verhalten ist dasselbe, selber Fehler
                          • F FischerJedd
                            @glasfaser
                            FischerJedd
                            @fischerjedd
                            wegen automatische Übersetzung englisch - deutsch
                            • F FischerJedd
                              @fischerjedd
                              FischerJedd
                              @fischerjedd
                              ist bei Firefox nicht eingestellt
                              GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                              • F FischerJedd
                                @fischerjedd
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @fischerjedd
                                dort ausgeschaltet !?
                                • F FischerJedd
                                  @fischerjedd
                                  @fischerjedd
                                  Hol das log direkt aus dem Dateisystem und nicht irgendwie über den Browser.
                                  Im Terminal mit
                                    @fischerjedd
                                    Im Terminal mit
                                    FischerJedd
                                    @thomas-braun said in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                                    login as: pi
                                    pi@192.168.33.23's password:
                                    Linux iobroker-2 6.1.29-v8+ #1652 SMP PREEMPT Wed May 24 14:46:55 BST 2023 aarch        64
                                    permitted by applicable law.
                                    Last login: Mon May 29 11:20:27 2023 from 192.168.33.17
                                    SSH is enabled and the default password for the 'pi' user has not been changed.
                                    This is a security risk - please login as the 'pi' user and type 'passwd' to set        a new password.
                                    pi@iobroker-2:~ $ iob logs --watch | uniq
                                    2023-05-29 12:33:58.226  - error: bsblan.0 (13225) Error: Parse Error: Invalid header value char
                                    2023-05-29 12:33:58.227  - error: bsblan.0 (13225) RequestError: Error: Parse Error: Invalid header value char
                                    2023-05-29 12:33:58.227  - debug: bsblan.0 (13225) Reset Timer
                                    2023-05-29 12:34:00.009  - info: bsblan.0 (13225) Scheduled restart.
                                    2023-05-29 12:34:00.010  - info: bsblan.0 (13225) cleaned everything up...
                                    2023-05-29 12:34:00.056  - info: bsblan.0 (13225) terminating
                                    2023-05-29 12:34:00.058  - info: bsblan.0 (13225) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2023-05-29 12:34:00.597  - info: host.iobroker-2 instance system.adapter.bsblan.0 scheduled normal terminated and will be restarted on schedule.
                                    2023-05-29 12:34:00.597  - info: host.iobroker-2 Restart adapter system.adapter.bsblan.0 because enabled
                                    2023-05-29 12:34:01.628  - info: host.iobroker-2 instance system.adapter.bsblan.0 started with pid 13240
                                    2023-05-29 12:34:03.492  - debug: bsblan.0 (13240) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2023-05-29 12:34:03.532  - debug: bsblan.0 (13240) Objects client ready ... initialize now
                                    2023-05-29 12:34:03.536  - debug: bsblan.0 (13240) Objects create System PubSub Client
                                    2023-05-29 12:34:03.537  - debug: bsblan.0 (13240) Objects create User PubSub Client
                                    2023-05-29 12:34:03.566  - debug: bsblan.0 (13240) Objects client initialize lua scripts
                                    2023-05-29 12:34:03.576  - debug: bsblan.0 (13240) Objects connected to redis: 127.0.0.1:9001
                                    2023-05-29 12:34:03.599  - debug: bsblan.0 (13240) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2023-05-29 12:34:03.610  - debug: bsblan.0 (13240) States create System PubSub Client
                                    2023-05-29 12:34:03.611  - debug: bsblan.0 (13240) States create User PubSub Client
                                    2023-05-29 12:34:03.628  - debug: bsblan.0 (13240) States connected to redis: 127.0.0.1:9000
                                    2023-05-29 12:34:03.752  - info: bsblan.0 (13240) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.bsblan, node: v18.16.0, js-controller: 4.0.24
                                    2023-05-29 12:34:03.825  - debug: bsblan.0 (13240) Schedule restart: */30 * * * * *
                                    2023-05-29 12:34:03.894  - info: bsblan.0 (13240) Values found: 700
                                    2023-05-29 12:34:03.897  - debug: bsblan.0 (13240) Fetch values ...
                                    2023-05-29 12:34:03.984  - info: bsblan.0 (13240) Setup new objects (700) ...
                                    2023-05-29 12:34:05.398  - error: bsblan.0 (13240) Error: Parse Error: Invalid header value char
                                    2023-05-29 12:34:05.399  - error: bsblan.0 (13240) RequestError: Error: Parse Error: Invalid header value char
                                        a
                                    • F FischerJedd
                                      Hallo ich benötige Hilfe bevor ich komplett durchdrehe,
                                      ich habe seit dem 29.12.22 dieses Problem und komme einfach nicht darauf warum,
                                      vor allen hatte ich noch einen alten Raspberry mit iobroker wo es lief, bis zu dem Moment
                                      als ich Dussel Updates für den iobroker installiert habe.
                                      Hier habe ich ein komplett frisches System mit den neusten Updates, die als Stable laufen, installiert
                                      Ich könnte heulen, und ich bin in Linux nicht sehr, eher gar nicht bewandert.
                                      In dem Verzeichnis Instanzen / bsblan.0 wird folgendes Angezeigt:
                                      Verbunden mit Host OK
                                      Lebenszeichen OK
                                      Verbunden mit Gerät oder Dienst FEHLER!
                                      An bsb-lan kann es eigentlich nicht liegen da bis zu dem Moment des Updates alles lief.
                                      Vielleicht kann man damit was anfangen…
                                      root@iobroker-2:~# hostnamectl && node -v && npm -v && cat /sys/firmware/devicetree/base/model && vcgencmd get_config int && vcgencmd version && pstree
                                         Static hostname: iobroker-2
                                               Icon name: computer
                                              Machine ID: 4b39a791a9f5480e8a1268f3aa81f6d2
                                                 Boot ID: 766da368b24a45d2807981cd9649a7a1
                                        Operating System: Debian GNU/Linux 11 (bullseye)
                                                  Kernel: Linux 6.1.29-v8+
                                            Architecture: arm64
                                      v18.16.0
                                      9.6.7
                                      Raspberry Pi 4 Model B Rev 1.4arm_64bit=1
                                      arm_boost=1
                                      arm_freq=1800
                                      audio_pwm_mode=514
                                      camera_auto_detect=1
                                      config_hdmi_boost=5
                                      core_freq=500
                                      core_freq_min=200
                                      disable_commandline_tags=2
                                      disable_l2cache=1
                                      disable_overscan=1
                                      display_auto_detect=1
                                      display_hdmi_rotate=-1
                                      display_lcd_rotate=-1
                                      dvfs=3
                                      enable_gic=1
                                      force_eeprom_read=1
                                      force_pwm_open=1
                                      framebuffer_ignore_alpha=1
                                      framebuffer_swap=1
                                      gpu_freq=500
                                      gpu_freq_min=250
                                      init_uart_clock=0x2dc6c00
                                      lcd_framerate=60
                                      mask_gpu_interrupt0=3072
                                      mask_gpu_interrupt1=25635
                                      max_framebuffers=2
                                      over_voltage_avs=-40000
                                      pause_burst_frames=1
                                      program_serial_random=1
                                      total_mem=8192
                                      hdmi_force_cec_address:0=65535
                                      hdmi_force_cec_address:1=65535
                                      hdmi_pixel_freq_limit:0=0x11e1a300
                                      hdmi_pixel_freq_limit:1=0x11e1a300
                                      Apr 25 2023 18:26:03
                                      Copyright (c) 2012 Broadcom
                                      version d7f9c2b4ef7e4a8c0b04374a879ce89d7a948453 (clean) (release) (start)
                                      systemd-+-ModemManager---2*[{ModemManager}]
                                              |-agetty
                                              |-avahi-daemon---avahi-daemon
                                              |-bluetoothd
                                              |-cron
                                              |-dbus-daemon
                                              |-dhcpcd
                                              |-iobroker.js-con-+-io.admin.0---10*[{io.admin.0}]
                                              |                 |-io.backitup.0---10*[{io.backitup.0}]
                                              |                 |-io.bsblan.0---10*[{io.bsblan.0}]
                                              |                 |-io.discovery.0---10*[{io.discovery.0}]
                                              |                 `-10*[{iobroker.js-con}]
                                              |-polkitd---2*[{polkitd}]
                                              |-rngd---3*[{rngd}]
                                              |-rsyslogd---3*[{rsyslogd}]
                                              |-sshd-+-sshd---sshd---bash
                                              |      `-sshd---sshd---bash---sudo---bash---pstree
                                              |-systemd---(sd-pam)
                                              |-systemd-hostnam
                                              |-systemd-journal
                                              |-systemd-logind
                                              |-systemd-timesyn---{systemd-timesyn}
                                              |-systemd-udevd
                                              |-thd
                                              `-2*[wpa_supplicant]
                                      root@iobroker-2:~#
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Mit welcher Version lief es denn vorher ?
                                      Aktuelle in Stable ist die 0.0.2 ..
                                      Hast du eventuell die Beta genutzt , dort sind einige Änderung enthalten , vielleicht lief es mit der !?
                                        FischerJedd
                                        @glasfaser
                                        Deshalb ja ich dussel, ich kann es nicht mehr nachvollziehen,
                                        es kann sein.
                                        • F FischerJedd
                                          @glasfaser
                                          es kann sein.
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @fischerjedd
                                          Tipp :
                                          Poste hier im Thread :
                                          https://forum.iobroker.net/topic/25406/test-adapter-bsb_lan-v0-0-x
                                          und verlinke dein Problem als Kurzversion hier zum Thread,
                                          damit dir der Adapter Entwickler / andere User dir mehr helfen können .
