  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. BSB-LAN Adapter Funktioniert nach iobroker update nicht.
    5.1k
40 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • F FischerJedd
    OK werde ich so machen.
    Vielen Dank nochmal für die schnelle Hilfe.
    FischerJedd
    @fischerjedd
    ![0_1685352408168_056ce302-a4bc-45bf-9214-43891f25997b-image.png](Uploading 100%)
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     11:20:51 up 18 min,  3 users,  load average: 0.22, 0.23, 0.21
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=47.2'C
    volt=0.9060V
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-29 11:20:52 CEST
               Universal time: Mon 2023-05-29 09:20:52 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.6G        365M        6.7G        1.0M        540M        7.2G
    Swap:            99M          0B         99M
    Total:          7.7G        365M        6.8G
             7635 M total memory
              365 M used memory
              503 M active memory
              299 M inactive memory
             6729 M free memory
               28 M buffer memory
              512 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      230G  2.8G  217G   2% /
    devtmpfs       devtmpfs  3.5G     0  3.5G   0% /dev
    tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs          tmpfs     1.5G  1.2M  1.5G   1% /run
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     764M     0  764M   0% /run/user/1000
    [Mon May 29 11:01:58 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:C2:4C:1A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=84ea2d7e-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon May 29 11:02:00 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 29 11:02:00 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon May 29 11:02:01 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    513M    /var/
    183M    /var/cache
    178M    /var/cache/apt
    155M    /var/lib
    130M    /var/lib/apt/lists
    Archived and active journals take up 72.0M in the file system.
    /opt/iobroker/backups:
    4.7M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    36M     /opt/iobroker/iobroker-data/
    17M     /opt/iobroker/iobroker-data/backup-objects
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.2M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    1.1M    /opt/iobroker/iobroker-data/backup-objects/2023-05-29_08-57_objects.jsonl.gz
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-2                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-2                               -  enabled
    + system.adapter.bsblan.0                 : bsblan                : iobroker-2                               -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-2                               -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "bsblan"       : 0.2.2    , installed 0.2.2
    Objects and States
    Objects:        156
    States:         118
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12288      507/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15367      507/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12755      541/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15479      591/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12766      541/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12623      398/avahi-daemon: r
    udp        0      0 0.0.0.0:34353           0.0.0.0:*                           108        12625      398/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1707       790/dhcpcd
    udp6       0      0 :::45951                :::*                                108        12626      398/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12624      398/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15415      790/dhcpcd
        at Request.emit (node:events:513:28)
        at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
        at ClientRequest.emit (node:events:525:35)
        at Socket.socketOnData (node:_http_client:551:9)
        at Socket.emit (node:events:513:28)
        at addChunk (node:internal/streams/readable:324:12)
        at readableAddChunk (node:internal/streams/readable:297:9)
        at Readable.push (node:internal/streams/readable:234:10)
        at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    2023-05-29 11:21:37.557  - info: bsblan.0 (4314) Setup new objects (700) ...
    2023-05-29 11:21:38.587  - error: bsblan.0 (4314) Error: Parse Error: Invalid header value char
    2023-05-29 11:21:38.587  - error: bsblan.0 (4314) RequestError: Error: Parse Error: Invalid header value char
        at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
        at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
        at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
        at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.29-v8+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.6G        362M        6.7G        1.0M        541M        7.2G
    Swap:            99M          0B         99M
    Total:          7.7G        362M        6.8G
    Active iob-Instances:   5
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                156
    States:                 118
    Size of iob-Database:
    476K    /opt/iobroker/iobroker-data/states.jsonl
    pi@iobroker-2:~ $
    F 1 Antwort Letzte Antwort
    • F FischerJedd
      @fischerjedd
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=47.2'C
      volt=0.9060V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7635 M total memory
                365 M used memory
                503 M active memory
               6729 M free memory
                 28 M buffer memory
                512 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      513M    /var/
      183M    /var/cache
      178M    /var/cache/apt
      155M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        156
      States:         118
      Pending Updates: 0
                           v.2023-04-16
      Kernel:                 6.1.29-v8+
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
      Swap:            99M          0B         99M
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                156
      States:                 118
      pi@iobroker-2:~ $
      FischerJedd
      @fischerjedd
      Ich mag es ja gar nicht sagen...
      OK der Fehler mit nodejs ist weg, aber bsb-lan, da ist dieselbe Reaktion, auch nach
      dem Deinstall und neu Install mit Neustart.
      • F FischerJedd
        @fischerjedd
        FischerJedd
        @fischerjedd
        In dem Protokoll steht
        RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char bei neuem RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15) bei plumbing.callback (/opt/iobroker/node_modules/ request-promise-core/lib/plumbing.js:87:29) bei Request.RP$callback [als _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) bei self.callback (/opt/iobroker/node_modules/request/request.js:185:22) bei Request.emit (node:events:513:28) bei Request.onRequestError (/opt/iobroker/node_modules/request/request .js:877:8) bei ClientRequest.emit (node:events:525:35) bei Socket.socketOnData (node:_http_client:551:9) bei Socket.emit (node:events:513:28) bei addChunk (node :internal/streams/readable:324:12) bei readableAddChunk (Knoten:internal/streams/readable:297:9) bei Readable.push (Knoten:internal/streams/readable:234:10) bei TCP.onStreamRead (node:internal/stream_base_commons:190:23)
        F GlasfaserG 2 Antworten Letzte Antwort
        • F FischerJedd
          @fischerjedd
          FischerJedd
          @fischerjedd
          Natürlich alles in rot
          in Schwarz
          Neue Objekte einrichten (700) ..
          • F FischerJedd
            @fischerjedd
            in Schwarz
            @fischerjedd
            Dann ist jetzt zumindest die Basis sauber und du kannst dich auf den Adapter konzentrieren.
            Wie sehen die Einstellungen da aus und wie sieht ein Start des Adapters im Logfile aus?
              @fischerjedd
              FischerJedd
              ÄÄÄÄÄh wo, wie, was...
              Ich oute mich als dau
              • F FischerJedd
                @fischerjedd
                Irgendwas musst du ja beim Adapter an Einstellungen getätigt haben.
                Das Log schaut man sich am besten so an
                iob logs --watch | uniq
                und startet den Adapter/die Instanz dann neu. Ausgaben im Logfile dann hier, in CodeTags eingebettet, reinkopieren.
                  @fischerjedd
                  FischerJedd
                  2023-05-29 11:42:04.780 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
                  2023-05-29 11:42:04.781 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
                  2023-05-29 11:42:14.802 - info: bsblan.0 (10434) Setup new objects (700) ...
                  2023-05-29 11:42:16.913 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
                  2023-05-29 11:42:16.914 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
                  • F FischerJedd
                    @fischerjedd
                    In CodeTags, damit man das auch lesen kann.
                      @fischerjedd
                      FischerJedd
                      noch nie gemacht
                      so
                      29.05.2023 00:00:09.078 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                      29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
                      29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
                      unter plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
                      bei Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
                      unter self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                      unter Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
                      bei addChunk (node:internal/streams/readable:324:12)
                      bei readableAddChunk (node:internal/streams/readable:297:9)
                      bei Readable.push (node:internal/streams/readable:234:10)
                      29.05.2023 00:00:21.344 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                      29.05.2023 00:00:22.374 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
                      29.05.2023 00:00:22.375 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
                      29.05.2023 00:00:33.392 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                      • F FischerJedd
                        noch nie gemacht
                        so
                        @fischerjedd
                        Nein.
                        Schau hier rein:
                        • F FischerJedd
                          @fischerjedd
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @fischerjedd sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                          @fischerjedd
                          Dazu habe ich ganz am Anfang etwas geschrieben !
                          @glasfaser sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                          Stelle in der Instanz die Logstufe auf DEBUG .
                          Starte den Adapter und zeige hier die Log Ausgabe davon !
                          EDIT :
                          Expertenmodus ..... dann auf den Bleistift ... von Info auf Debug ändern .
                          • GlasfaserG Glasfaser
                            @fischerjedd
                            EDIT :
                            FischerJedd
                            schrieb am zuletzt editiert von FischerJedd
                            @glasfaser
                            Super erklärt, jetzt habe ich dussel es auch kapiert.
                            Thomas BraunT F 2 Antworten Letzte Antwort
                            • F FischerJedd
                              @glasfaser
                              @fischerjedd
                              Warum ändert sich die Sprache im logfile von Englisch auf Deutsch?
                              Übersetzungsautomatiken im Browser aktiv? Aber das dürfte das LogFile nicht tangieren.
                              Vielleicht führt das auch zu den 'invalid header value char' Meldungen...
                              • F FischerJedd
                                @glasfaser
                                FischerJedd
                                @fischerjedd
                                Nächstes Problem
                                Ich mache hier gerade eine Fortbildung
                                • F FischerJedd
                                  @fischerjedd
                                  Nächstes Problem
                                  @fischerjedd
                                  Nächstes Problem
                                  Schau hier rein:
                                    @fischerjedd
                                    Nächstes Problem
                                    Schau hier rein:
                                    FischerJedd
                                    Ich habe es mal in Firefox gestartet
                                    alles das selbe
                                    • F FischerJedd
                                      alles das selbe
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      alles das selbe
                                      Was das selbe ... stehn gerade auf dem Schlauch was du meinst !?
                                        alles das selbe
                                        FischerJedd
                                        @glasfaser
                                        ich meinte, das Verhalten ist dasselbe, selber Fehler
                                        • F FischerJedd
                                          @glasfaser
                                          FischerJedd
                                          @fischerjedd
                                          wegen automatische Übersetzung englisch - deutsch
