  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.2k Aufrufe 40 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    schrieb am zuletzt editiert von Nashra
    #429
    Moin, Proxmox mit lxc
    Skript v.2023-05-28-4
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     09:28:37 up 3 days, 21:22,  1 user,  load average: 0.71, 0.89, 0.98
    CPU threads: 4
    *** Time and Time Zones ***
    Failed to query server: Connection timed out
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             10G        4.8G        4.2G        0.0K        1.2G        5.5G
    Swap:             0B          0B          0B
    Total:           10G        4.8G        4.2G
            10240 M total memory
             4773 M used memory
              352 M active memory
             5373 M inactive memory
             4237 M free memory
                0 M buffer memory
             1229 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       21G  9.3G   11G  48% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G   72K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    931M    /var/
    519M    /var/log
    457M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
    229M    /var/cache
    Archived and active journals take up 456.0M in the file system.
    /opt/iobroker/backups:
    970M    /opt/iobroker/backups/
    3.1M    /opt/iobroker/backups/scripte
    844K    /opt/iobroker/backups/scripte/Allerlei
    472K    /opt/iobroker/backups/scripte/Wetter
    440K    /opt/iobroker/backups/scripte/global
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    677M    /opt/iobroker/iobroker-data/files
    620M    /opt/iobroker/iobroker-data/backup-objects
    203M    /opt/iobroker/iobroker-data/history
    169M    /opt/iobroker/iobroker-data/files/vis.0
    103M    /opt/iobroker/iobroker-data/objects.jsonl
    87M     /opt/iobroker/iobroker-data/states.jsonl
    28M     /opt/iobroker/iobroker-data/objects.json.migrated
    28M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.48682a62.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   8
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
    + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : ioBroker                                 - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
      system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 -  enabled
      system.adapter.meteoalarm.2             : meteoalarm            : ioBroker                                 -  enabled
      system.adapter.meteoalarm.3             : meteoalarm            : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.nut.2                    : nut                   : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.radar-trap2.0            : radar-trap2           : ioBroker                                 -  enabled
    + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
    + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.synology.2               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
      system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    stable-live   : http://iobroker.live/repo/sources-dist.json
    latest-live   : http://iobroker.live/repo/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
    Adapter    "countdown"    : 2.0.0    , installed 2.0.0
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.0.12   , installed 1.5.0
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.1.1    , installed 2.2.0
    Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.6
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "parcel"       : 0.0.27   , installed 0.0.28
    Adapter    "pegelalarm"   : 1.3.0    , installed 1.3.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.5
    Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "snmp"         : 2.4.7    , installed 2.4.7
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "unifi"        : 0.5.10   , installed 0.6.4
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.94.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        37365
    States:         35147
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org bullseye-security InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          39953      317/master
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       40082      121/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       39603      121/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          36854      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35815      190/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       63491160   226443/nc
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          39954      317/master
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       65692      2406/io.rest-api.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       51707      1389/io.simple-api.
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       53340      1404/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63169909   201723/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       39751      332/io.admin.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          36856      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          35817      190/sshd: /usr/sbin
    tcp6       0      0 :::3040                 :::*                    LISTEN      1001       71028      2860/io.radar-trap2
    udp        0      0 0.0.0.0:56801           0.0.0.0:*                           1001       55623      1517/io.upnp.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          36855      1/init
    udp        0      0 0.0.0.0:57552           0.0.0.0:*                           1001       72979      2925/io.snmp.0
    udp        0      0 0.0.0.0:41546           0.0.0.0:*                           1001       72129      2925/io.snmp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       57521      1517/io.upnp.0
    udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       40779      545/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       40673      527/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       41547      575/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       41548      575/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          36857      1/init
    2023-05-29 09:18:00.039  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 215091
    2023-05-29 09:18:01.024  - info: dwd.0 (215091) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 09:18:01.489  - info: dwd.0 (215091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-05-29 09:18:02.014  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-29 09:18:08.620  - info: host.ioBroker stopInstance system.adapter.logparser.0 (force=false, process=true)
    2023-05-29 09:18:08.622  - info: logparser.0 (213911) Got terminate signal TERMINATE_YOURSELF
    2023-05-29 09:18:08.622  - info: logparser.0 (213911) cleaned everything up...
    2023-05-29 09:18:08.622  - info: logparser.0 (213911) terminating
    2023-05-29 09:18:08.623  - info: logparser.0 (213911) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-05-29 09:18:08.712  - info: host.ioBroker stopInstance system.adapter.logparser.0 send kill signal
    2023-05-29 09:18:09.190  - info: host.ioBroker instance system.adapter.logparser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-29 09:18:11.817  - info: host.ioBroker instance system.adapter.logparser.0 started with pid 215124
    2023-05-29 09:18:12.707  - info: logparser.0 (215124) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.logparser, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 09:21:22.532  - info: linux-control.0 (2450) getting data from ioBroker (192.168.1.14:22)
    2023-05-29 09:21:25.600  - info: linux-control.0 (2450) successful received data from ioBroker (192.168.1.14:22)
    2023-05-29 09:24:00.035  - info: host.ioBroker instance system.adapter.weatherunderground.0 started with pid 220093
    2023-05-29 09:24:06.520  - info: host.ioBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-05-29 09:24:33.654  - info: linux-control.0 (2450) getting data from Proxmox (192.168.1.13:22)
    2023-05-29 09:24:35.806  - info: linux-control.0 (2450) successful received data from Proxmox (192.168.1.13:22)
    2023-05-29 09:26:00.038  - info: host.ioBroker instance system.adapter.meteoalarm.1 started with pid 222903
    2023-05-29 09:26:02.198  - info: host.ioBroker instance system.adapter.meteoalarm.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-29 09:27:00.037  - info: host.ioBroker instance system.adapter.meteoalarm.3 started with pid 223605
    2023-05-29 09:27:01.987  - info: host.ioBroker instance system.adapter.meteoalarm.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-29 09:29:00.034  - info: host.ioBroker instance system.adapter.meteoalarm.0 started with pid 225402
    2023-05-29 09:29:01.928  - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                         v.2023-05-28-4
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             10G        4.8G        4.2G        0.0K        1.2G        5.4G
    Swap:             0B          0B          0B
    Active iob-Instances:   44
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                37365
    States:                 35146
    Size of iob-Database:
    0       /opt/iobroker/iobroker-data/objects.json.broken
    103M    /opt/iobroker/iobroker-data/states.jsonl
    17M     /opt/iobroker/iobroker-data/states.json.migrated
    17M     /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Gruß Ralf
    • NashraN Nashra
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:             0B          0B          0B
               4773 M used memory
                352 M active memory
               4237 M free memory
                  0 M buffer memory
               1229 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      931M    /var/
      519M    /var/log
      229M    /var/cache
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        37365
      States:         35147
      Pending Updates: 0
                           v.2023-05-28-4
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
      Swap:             0B          0B          0B
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                37365
      States:                 35146
      #430
      @nashra
      Nanu? Ich dachte proxmox läuft auch über systemd und die entsprechenden Befehle könnte man da verwenden?
      NashraN bahnuhrB 2 Antworten Letzte Antwort
        @nashra
        NashraN Offline
        NashraN Offline
        Nashra
        #431
        @thomas-braun sagte in iob diag - Skript:
        @nashra
        Sorry, kenne ich mich nicht mit aus, aber beim letzten Skript kam das nicht
        Gruß Ralf
        • NashraN Nashra
          @nashra
          #432
          @nashra
          Da war die Abfrage auch anders aufgebaut.
          Am Rande: Spring da nicht als root herum. Auch in LXCs verwendet man natürlich Standard-User.
            @nashra
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #433
            proxmox, iob in vm
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : kvm
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
             10:02:50 up 9 days, 19:38,  1 user,  load average: 3.36, 3.07, 2.38
            CPU threads: 8
                           Local time: Mon 2023-05-29 10:02:50 CEST
                       Universal time: Mon 2023-05-29 08:02:50 UTC
                             RTC time: Mon 2023-05-29 08:02:51
                          NTP service: active
                      RTC in local TZ: no
            dieter
            /home/dieter
            dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            5.9G        4.6G        765M        0.0K        531M        1.1G
            Swap:           974M        862M        112M
            Total:          6.9G        5.5G        878M
                     5940 M total memory
                     4643 M used memory
                     3764 M active memory
                     1119 M inactive memory
                      765 M free memory
                      113 M buffer memory
                      418 M swap cache
                      974 M total swap
                      862 M used swap
                      112 M free swap
            *** FILESYSTEM ***
            udev                      devtmpfs  2.9G     0  2.9G   0% /dev
            tmpfs                     tmpfs     595M  508K  594M   1% /run
            /dev/sda1                 ext4       31G  6.5G   23G  23% /
            tmpfs                     tmpfs     3.0G     0  3.0G   0% /dev/shm
            //192.168.243.100/1_Sound cifs      238G  125G  113G  53% /mnt
            tmpfs                     tmpfs     595M     0  595M   0% /run/user/1000
            [Fri May 19 14:24:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Fri May 19 14:24:53 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            [Sat May 27 00:20:06 2023]  ext4_sync_file+0xd4/0x360 [ext4]
            [Sat May 27 00:20:06 2023]  __ext4_journal_get_write_access+0x77/0x130 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_reserve_inode_write+0x83/0xc0 [ext4]
            [Sat May 27 00:20:06 2023]  __ext4_mark_inode_dirty+0x57/0x220 [ext4]
            [Sat May 27 00:20:06 2023]  ? __ext4_journal_start_sb+0xfb/0x110 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_dirty_inode+0x5f/0x90 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_setattr+0x1fa/0x9b0 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_sync_file+0x73/0x360 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_buffered_write_iter+0x5a/0x170 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_buffered_write_iter+0x3b/0x170 [ext4]
            [Sat May 27 00:20:06 2023]  ext4_sync_file+0x2cc/0x360 [ext4]
            /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
            `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
            /var:
            762M    /var/
            371M    /var/cache
            364M    /var/cache/apt
            296M    /var/cache/apt/archives
            225M    /var/log
            Archived and active journals take up 40.0M in the file system.
            360M    /opt/iobroker/backups/
            1005M   /opt/iobroker/iobroker-data/
            622M    /opt/iobroker/iobroker-data/files
            298M    /opt/iobroker/iobroker-data/files/vis.0
            248M    /opt/iobroker/iobroker-data/files/vis.0/wav
            229M    /opt/iobroker/iobroker-data/sqlite
            229M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
            154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
            34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
            29M     /opt/iobroker/iobroker-data/objects.jsonl
            22M     /opt/iobroker/iobroker-data/states.jsonl
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapters from github:   11
            Adapter State
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
            + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
            + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
            + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
            + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
            + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
            + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
            + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
            + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
            + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
            + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
            + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
            + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
            + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
              system.adapter.sayit.5                  : sayit                 : iobroker                                 - disabled, port: 0
              system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
            + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
              system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
            + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
              system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
              system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
            + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
            + instance is alive
            Active repo(s): stable
            Used repository: stable
            Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
            Adapter    "bmw"          : 2.5.7    , installed 2.5.7
            Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
            Adapter    "cloud"        : 4.3.0    , installed 4.4.1
            Adapter    "doorio"       : 2.1.4    , installed 2.1.4
            Adapter    "flot"         : 1.11.0   , installed 1.12.0
            Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
            Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
            Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
            Adapter    "libre"        : 0.0.4    , installed 0.0.4
            Adapter    "logparser"    : 2.1.1    , installed 2.1.1
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 3.9.5    , installed 3.11.0
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
            Adapter    "musiccast"    : 0.1.5    , installed 1.1.2
            Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
            Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
            Adapter    "parser"       : 1.1.8    , installed 1.1.8
            Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
            Adapter    "socketio"     : 4.2.0    , installed 6.3.5
            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
            Adapter    "viessmann"    : 1.4.3    , installed 1.4.3
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 4.3.0    , installed 6.0.1
            Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
            Adapter    "ws"           : 1.3.0    , installed 2.3.6
            Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Objects and States
            Objects:        23712
            States:         19516
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Pending Updates: 52
            tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        2585       390/asterisk
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2288       1/init
            tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       5541107    339102/io.hm-rpc.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2561       424/sshd: /usr/sbin
            tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       5539786    339091/io.hm-rpc.2
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15484      813/io.mqtt.0
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15298      832/io.mqtt.2
            tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       13166      711/io.hm-rpc.1
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14859      391/iobroker.js-con
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       2604       391/iobroker.js-con
            tcp6       0      0 :::111                  :::*                    LISTEN      0          12538      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2649       580/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19906      1397/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21598      1403/io.ws.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2563       424/sshd: /usr/sbin
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19772      1284/io.simple-api.
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1278       1/init
            udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       23590      1234/io.musiccast.0
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       7503964    434189/io.mihome-va
            udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        2598       390/asterisk
            udp        0      0 0.0.0.0:49696           0.0.0.0:*                           108        13006      390/asterisk
            udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        2599       390/asterisk
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3827070    233728/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3827071    233728/io.tuya.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2556       380/dhclient
            udp6       0      0 :::111                  :::*                                0          10997      1/init
            udp6       0      0 :::33130                :::*                                108        13007      390/asterisk
            2023-05-29 10:01:24.522  - info: javascript.0 (618) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
            2023-05-29 10:01:24.540  - info: javascript.0 (618) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Wind Schwankungsbreite
            2023-05-29 10:01:24.562  - info: javascript.0 (618) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
            2023-05-29 10:01:26.030  - info: ical.0 (458530) Terminated (NO_ERROR): Without reason
            2023-05-29 10:01:26.594  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2023-05-29 10:01:51.191  - info: web.0 (1397) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
            2023-05-29 10:01:51.192  - info: web.0 (1397) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
            2023-05-29 10:01:51.235  - info: web.0 (1397) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
            2023-05-29 10:01:56.354  - info: javascript.0 (618) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
            2023-05-29 10:01:56.369  - info: javascript.0 (618) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
            2023-05-29 10:02:00.115  - info: javascript.0 (618) script.js.Scripte.Geraete.Photovoltaik: Auslöser: Schedule
            2023-05-29 10:02:00.116  - info: javascript.0 (618) script.js.Scripte.Geraete.Photovoltaik: Piko 5.5 auslesen
            2023-05-29 10:02:00.148  - info: javascript.0 (618) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 55903, "mode": 0, "battery": 100, "hours": 888}, "timer": {"status": 2, "next": {"date": "2023-05-30", "time": "10:00:00", "unix": 1685440800}}, "blades": {"quality": 64, "hours": 109, "days": 61}, "wlan": {"signal": -77}, "health": {"temperature": 26, "humidity": 23}, "clock": {"date": "2023-05-29", "time": "10:02:00", "unix": 1685354520}, "successful": true}
            2023-05-29 10:02:04.155  - info: daswetter.0 (458515) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-05-29 10:02:04.714  - info: daswetter.0 (458515) cleaned everything up...
            2023-05-29 10:02:04.745  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-05-29 10:02:41.025  - info: javascript.0 (618) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
            2023-05-29 10:02:52.876  - info: javascript.0 (618) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
            2023-05-29 10:03:55.490  - info: javascript.0 (618) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Wind Schwankungsbreite
            2023-05-29 10:03:55.501  - info: javascript.0 (618) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
            2023-05-29 10:04:00.125  - info: javascript.0 (618) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 56023, "mode": 0, "battery": 100, "hours": 888}, "timer": {"status": 2, "next": {"date": "2023-05-30", "time": "10:00:00", "unix": 1685440800}}, "blades": {"quality": 64, "hours": 109, "days": 61}, "wlan": {"signal": -77}, "health": {"temperature": 26, "humidity": 23}, "clock": {"date": "2023-05-29", "time": "10:03:59", "unix": 1685354639}, "successful": true}
            2023-05-29 10:04:00.978  - info: javascript.0 (618) script.js.Scripte.Geraete.Drucksensor: Heizung: 10336 , 1.81
            2023-05-29 10:04:00.980  - info: javascript.0 (618) script.js.Scripte.Geraete.Drucksensor: FB-Heizung: 7888 , 1.24
            2023-05-29 10:04:00.980  - info: javascript.0 (618) script.js.Scripte.Geraete.Drucksensor: Wasser: 5504 , 1.62
            2023-05-29 10:04:23.011  - info: javascript.0 (618) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 65° / Sonne: Elevation: 29.2° / Mond: Azimut: 68° / Mond: Elevation: -79.6°
            iob diag has finished.
                                 v.2023-04-16
            Operatingsystem:        Debian GNU/Linux 11 (bullseye)
            Kernel:                 5.10.0-21-amd64
            Installation:           kvm
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     52
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Mem:            5.9G        4.6G        725M        0.0K        601M        1.1G
            Swap:           974M        861M        113M
            Total:          6.9G        5.5G        838M
            Active iob-Instances:   52
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                23712
            States:                 19516
            25M     /opt/iobroker/iobroker-data/states.jsonl
            Danke.
            • bahnuhrB bahnuhr
              proxmox, iob in vm
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 8
                            NTP service: active
                        RTC in local TZ: no
              dieter
              /home/dieter
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
                       5940 M total memory
                       4643 M used memory
                        765 M free memory
                        113 M buffer memory
                        418 M swap cache
                        974 M total swap
                        862 M used swap
                        112 M free swap
              *** FILESYSTEM ***
              /var:
              762M    /var/
              371M    /var/cache
              364M    /var/cache/apt
              225M    /var/log
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        23712
              States:         19516
              Pending Updates: 52
                                   v.2023-04-16
              Installation:           kvm
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              MEMORY:
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                23712
              States:                 19516
              #434
              @bahnuhr
              Danke.Aber das ist nicht das Skript das getestet werden soll.
              Da sehe ich aber dennoch gleich Probleme in deinem Setup.
              Das Dateisystem sollte nicht in /mnt sondern in ein Unterverzeichnis gehängt werden. Leg dir /mnt/sounds oder sowas an.
              Vielleicht erledigt sich das mit den vielen Meldungen zu /dev/sda1 dann auch. Da ist nämlich auch was schräg.
              Und wie immer: Updates fahren!
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #435
                wo find ich die?
                Was ist das ?
                Danke.
                • bahnuhrB bahnuhr
                  wo find ich die?
                  Was ist das ?
                  #436
                  @bahnuhr
                  Gehört hier nicht hin. Mach einen eigenen Thread dafür auf.
                    @nashra
                    NashraN Offline
                    NashraN Offline
                    Nashra
                    #437
                    @nashra
                    Bin als User dort unterwegs, root packe ich nicht an
                    Gruß Ralf
                    • NashraN Nashra
                      @nashra
                      #438
                      @nashra
                      Das Skript sagt was anderes...
                      • NashraN Nashra
                        @nashra
                        #439
                        @nashra
                        Was spuckt das Terminal zu
                        systemd-detect-virt
                        aus?
                        T NashraN 2 Antworten Letzte Antwort
                          @nashra
                          systemd-detect-virt
                          aus?
                          tobrog
                          #440
                          @thomas-braun Hab das skript auch mal im lxc container getestet.
                          *** BASE SYSTEM ***
                             Static hostname: iob-test
                                   Icon name: computer-container
                                     Chassis: container
                                  Machine ID: d8caa5b3244e49f2ac681e0f79a122d3
                                     Boot ID: d94366b77fd34be8be8ae7312c47af6a
                              Virtualization: lxc
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.0.19-edge
                                Architecture: x86-64
                          model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                          Kernel          : x86_64
                          Userland        : amd64
                           12:44:23 up 0 min,  2 users,  load average: 1.58, 0.91, 0.65
                          CPU threads: 2
                                         Local time: Mon 2023-05-29 12:44:23 CEST
                                     Universal time: Mon 2023-05-29 10:44:23 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          rog
                          /home/rog
                          rog adm sudo redis iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            8.2G        1.6G        6.3G        2.0M        293M        6.6G
                          Swap:           2.0G          0B        2.0G
                          Total:           10G        1.6G        8.3G
                                   8192 M total memory
                                   1598 M used memory
                                     66 M active memory
                                   1764 M inactive memory
                                   6299 M free memory
                                      0 M buffer memory
                                    293 M swap cache
                                   2048 M total swap
                                      0 M used swap
                                   2048 M free swap
                          *** FILESYSTEM ***
                          /dev/mapper/pve-vm--200--disk--0     ext4    16G  3.9G   11G  27% /
                          /dev/mapper/pve-root                 ext4    66G   12G   51G  18% /dev/ttyACM0
                          tmpfs                                tmpfs  3.1G  160K  3.1G   1% /run
                          //10.10.10.10/Public/backup/iobroker cifs   2.7T  2.1T  627G  78% /media/iobroker
                          tmpfs                                tmpfs  1.6G     0  1.6G   0% /run/user/1000
                          [Sat May 27 18:18:31 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 18:18:32 2023] EXT4-fs (dm-1): re-mounted. Quota mode: none.
                          [Sat May 27 18:18:51 2023] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 18:19:10 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 18:19:29 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 18:19:48 2023] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 18:19:52 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 19:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 19:01:47 2023] EXT4-fs (dm-9): unmounting filesystem.
                          [Sat May 27 19:01:51 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat May 27 19:02:53 2023] EXT4-fs (dm-12): unmounting filesystem.
                          [Sun May 28 07:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun May 28 07:02:15 2023] EXT4-fs (dm-9): unmounting filesystem.
                          [Sun May 28 07:02:20 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun May 28 07:03:23 2023] EXT4-fs (dm-12): unmounting filesystem.
                          [Sun May 28 19:01:23 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun May 28 19:01:48 2023] EXT4-fs (dm-9): unmounting filesystem.
                          [Sun May 28 19:01:53 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun May 28 19:02:57 2023] EXT4-fs (dm-12): unmounting filesystem.
                          [Mon May 29 07:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon May 29 07:01:46 2023] EXT4-fs (dm-9): unmounting filesystem.
                          [Mon May 29 07:01:50 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon May 29 07:02:53 2023] EXT4-fs (dm-12): unmounting filesystem.
                          [Mon May 29 12:38:02 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon May 29 12:43:43 2023] EXT4-fs (dm-12): unmounting filesystem.
                          [Mon May 29 12:43:44 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
                          /                 /dev/mapper/pve-vm--200--disk--0                       ext4   rw,relatime,stripe=16
                          |-/dev/ttyACM0    /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                          `-/media/iobroker //10.10.10.10/Public/backup/iobroker                   cifs   rw,relatime,vers=3.1.1,cache=strict,username=XXX,uid=1001,noforceuid,gid=1001,noforc
                          /var:
                          458M    /var/
                          226M    /var/cache
                          221M    /var/cache/apt
                          161M    /var/lib
                          152M    /var/cache/apt/archives
                          Archived and active journals take up 24.0M in the file system.
                          142M    /opt/iobroker/backups/
                          392M    /opt/iobroker/iobroker-data/
                          305M    /opt/iobroker/iobroker-data/files
                          66M     /opt/iobroker/iobroker-data/backup-objects
                          51M     /opt/iobroker/iobroker-data/files/javascript.admin
                          48M     /opt/iobroker/iobroker-data/files/telegram.admin
                          33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                          17M     /opt/iobroker/iobroker-data/objects.jsonl
                          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                          9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                          8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          Objects:                    jsonl on 127.0.0.1
                          States:                     redis on 127.0.0.1
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapters from github:   2
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iob-test                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.alexa2.0                 : alexa2                : iob-test                                 - disabled
                            system.adapter.alias-manager.0          : alias-manager         : iob-test                                 - disabled
                            system.adapter.apple-find-me.0          : apple-find-me         : iob-test                                 - disabled
                            system.adapter.apple-find-me.1          : apple-find-me         : iob-test                                 - disabled
                            system.adapter.apple-find-me.2          : apple-find-me         : iob-test                                 - disabled
                            system.adapter.apple-find-me.3          : apple-find-me         : iob-test                                 - disabled
                            system.adapter.apple-find-me.4          : apple-find-me         : iob-test                                 - disabled
                          + system.adapter.backitup.0               : backitup              : iob-test                                 -  enabled
                          + system.adapter.device-watcher.0         : device-watcher        : iob-test                                 -  enabled
                            system.adapter.devices.0                : devices               : iob-test                                 - disabled
                          + system.adapter.discovery.0              : discovery             : iob-test                                 -  enabled
                          + system.adapter.echarts.0                : echarts               : iob-test                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iob-test                                 - disabled
                            system.adapter.history.0                : history               : iob-test                                 - disabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test                                 - disabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test                                 - disabled
                          + system.adapter.info.0                   : info                  : iob-test                                 -  enabled
                            system.adapter.jarvis.0                 : jarvis                : iob-test                                 - disabled
                          + system.adapter.javascript.0             : javascript            : iob-test                                 -  enabled
                            system.adapter.nina.0                   : nina                  : iob-test                                 - disabled
                            system.adapter.plex.0                   : plex                  : iob-test                                 - disabled
                          + system.adapter.simple-api.0             : simple-api            : iob-test                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.socketio.0               : socketio              : iob-test                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            system.adapter.switchbot-hub.0          : switchbot-hub         : iob-test                                 - disabled
                            system.adapter.telegram.0               : telegram              : iob-test                                 - disabled, port: 8443, bind: 0.0.0.0
                            system.adapter.tr-064.0                 : tr-064                : iob-test                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test                                 - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test                                 -  enabled
                            system.adapter.vis-map.0                : vis-map               : iob-test                                 - disabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test                                 - disabled
                            system.adapter.vis-owl.0                : vis-owl               : iob-test                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test                                 - disabled
                            system.adapter.vis.0                    : vis                   : iob-test                                 -  enabled
                          + system.adapter.web.0                    : web                   : iob-test                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.1                    : web                   : iob-test                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                          + system.adapter.ws.0                     : ws                    : iob-test                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                            system.adapter.zigbee.0                 : zigbee                : iob-test                                 - disabled, port: /dev/ttyACM0
                          + instance is alive
                          live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                          live-stable   : http://iobroker.live/repo/sources-dist.json
                          Adapter    "apple-find-me": 0.0.14   , installed 0.0.15
                          Adapter    "device-watcher": 2.9.1   , installed 2.9.1
                          Adapter    "devices"      : 1.1.2    , installed 1.1.2
                          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                          Adapter    "plex"         : 0.9.1    , installed 0.9.1
                          Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                          Objects and States
                          Objects:        5543
                          States:         4580
                          Hit:3 http://security.debian.org bullseye-security InRelease
                          Hit:5 https://packages.sury.org/php bullseye InRelease
                          Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        10096841   124/mosquitto
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          10097023   318/master
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10094414   1/init
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          10096944   213/lighttpd
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10097182   129/iobroker.js-con
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        10096812   108/systemd-resolve
                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        10097759   119/redis-server 12
                          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        10096806   108/systemd-resolve
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          10097024   318/master
                          tcp6       0      0 :::1883                 :::*                    LISTEN      110        10096842   124/mosquitto
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          10094545   1/init
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          10094418   1/init
                          tcp6       0      0 :::80                   :::*                    LISTEN      0          10096945   213/lighttpd
                          tcp6       0      0 ::1:6379                :::*                    LISTEN      109        10097760   119/redis-server 12
                          tcp6       0      0 :::8085                 :::*                    LISTEN      1001       10098846   457/io.ws.0
                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       10103907   944/io.socketio.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10100707   758/io.simple-api.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10098182   333/io.admin.0
                          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10104026   987/io.web.1
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10098618   417/io.web.0
                          tcp6       0      0 :::5355                 :::*                    LISTEN      104        10096809   108/systemd-resolve
                          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        10096805   108/systemd-resolve
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        10096811   108/systemd-resolve
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10094415   1/init
                          udp6       0      0 :::5355                 :::*                                104        10096808   108/systemd-resolve
                          udp6       0      0 :::111                  :::*                                0          10094421   1/init
                          2023-05-29 12:44:23.992  - info: host.iob-test instance system.adapter.echarts.0 started with pid 534
                          2023-05-29 12:44:24.222  - info: vis.0 (474) Uploaded. 0
                          2023-05-29 12:44:24.727  - info: vis.0 (474) Terminated (NO_ERROR): Without reason
                          2023-05-29 12:44:25.038  - info: echarts.0 (534) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:25.305  - info: host.iob-test instance system.adapter.vis.0 terminated while should be started once
                          2023-05-29 12:44:28.032  - info: host.iob-test instance system.adapter.info.0 started with pid 562
                          2023-05-29 12:44:30.330  - info: info.0 (562) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:30.462  - info: info.0 (562) Reading/updating systemdata.
                          2023-05-29 12:44:30.975  - info: info.0 (562) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                          2023-05-29 12:44:31.018  - info: info.0 (562) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                          2023-05-29 12:44:31.112  - info: info.0 (562) cpu Temp res = {"main":46,"cores":[46,46,46,45],"max":46,"socket":[45],"chipset":null}
                          2023-05-29 12:44:32.051  - info: host.iob-test instance system.adapter.simple-api.0 started with pid 758
                          2023-05-29 12:44:33.467  - info: simple-api.0 (758) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:33.495  - info: simple-api.0 (758) simpleAPI server listening on port 8087
                          2023-05-29 12:44:33.496  - info: simple-api.0 (758) Allow states only when user is owner: false
                          2023-05-29 12:44:33.505  - info: simple-api.0 (758) http server listening on port 8087
                          2023-05-29 12:44:36.036  - info: host.iob-test instance system.adapter.socketio.0 started with pid 944
                          2023-05-29 12:44:37.130  - info: socketio.0 (944) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:37.268  - info: socketio.0 (944) socket.io server listening on port 8084
                          2023-05-29 12:44:40.035  - info: host.iob-test instance system.adapter.vis-inventwo.0 started with pid 959
                          2023-05-29 12:44:41.086  - info: vis-inventwo.0 (959) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:44.044  - info: host.iob-test instance system.adapter.web.1 started with pid 987
                          2023-05-29 12:44:45.611  - info: web.1 (987) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
                          2023-05-29 12:44:45.770  - info: web.1 (987) socket.io server listening on port 8083
                          2023-05-29 12:44:45.774  - info: web.1 (987) http server listening on port 8083
                                               v.2023-05-28-4
                                     Chassis: container
                              Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          MEMORY:
                          Mem:            8.2G        1.5G        6.2G        2.0M        530M        6.7G
                          Swap:           2.0G          0B        2.0G
                          Total:           10G        1.5G        8.2G
                          Active iob-Instances:   14
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: redis
                          Objects:                5543
                          States:                 4580
                          27M     /opt/iobroker/iobroker-data/objects.jsonl
                          3.8M    /opt/iobroker/iobroker-data/states.jsonl
                          rog@iob-test:~$ systemd-detect-virt
                          lxc
                          • T tobrog
                            *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 2
                                             RTC time: n/a
                                      RTC in local TZ: no
                            rog
                            /home/rog
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           2.0G          0B        2.0G
                                     8192 M total memory
                                     1598 M used memory
                                       66 M active memory
                                     6299 M free memory
                                        0 M buffer memory
                                      293 M swap cache
                                     2048 M total swap
                                        0 M used swap
                                     2048 M free swap
                            *** FILESYSTEM ***
                            /var:
                            458M    /var/
                            226M    /var/cache
                            221M    /var/cache/apt
                            161M    /var/lib
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            admin:          6.3.5
                            javascript:     6.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        5543
                            States:         4580
                            Pending Updates: 0
                                                 v.2023-05-28-4
                                       Chassis: container
                                Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            9.5.1
                                                    /usr/bin/npx            9.5.1
                            MEMORY:
                            Swap:           2.0G          0B        2.0G
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: redis
                            Objects:                5543
                            States:                 4580
                            lxc
                            #441
                            @tobrog
                            Ja, so sollte es in einem LXC aussehen. Warum das bei @Nashra nicht funktioniert kann ich mir gerade nicht erklären. Ist aber offenbar ein individuelles phänomen in seiner Installation.
                              @tobrog
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #442
                              Da sind noch mehr ... bei Ihm :
                                @tobrog
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #443
                                @Nashra
                                Starte deine ... Kiste ... mal neu durch !
                                • GlasfaserG Glasfaser
                                  #444
                                  @glasfaser
                                  Ja, hab ich gesehen. Sind die Stellen, die ich für non-Docker auf systemd-Kommandos umgestellt habe. Bei @tobrog funktioniert es ja auch wie vorgesehen und erwartet.
                                  Vielleicht eine steinalte Basis? Keine Ahnung seit wann Proxmox-LXC auf systemd laufen.
                                    @nashra
                                    systemd-detect-virt
                                    aus?
                                    NashraN Offline
                                    NashraN Offline
                                    Nashra
                                    #445
                                    systemd-detect-virt
                                    jack@ioBroker:~$ systemd-detect-virt
                                    lxc
                                    jack@ioBroker:~$
                                    Starte die Kiste mal neu, ist aktuellste Version drauf
                                    Gruß Ralf
                                    • NashraN Nashra
                                      systemd-detect-virt
                                      lxc
                                      jack@ioBroker:~$
                                      #446
                                      @nashra
                                      Und
                                      timedatectl
                                      hostnamectl
                                      funktionieren nicht? Wundert mich.
                                        @nashra
                                        Und
                                        timedatectl
                                        hostnamectl
                                        NashraN Offline
                                        NashraN Offline
                                        Nashra
                                        #447
                                        timedatectl
                                        Funktionieren beide nicht, Fehlermeldung
                                        und das kommt jetzt nach einem kompletten Neustart
                                        *** BASE SYSTEM ***
                                        Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                                        Kernel          : x86_64
                                        Userland        : amd64
                                         13:30:51 up 5 min,  1 user,  load average: 1.34, 1.23, 0.64
                                        CPU threads: 4
                                        Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                                        jack
                                        /home/jack
                                        jack sudo iobroker
                                        Gruß Ralf
                                        • NashraN Nashra
                                          timedatectl
                                          *** BASE SYSTEM ***
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          CPU threads: 4
                                          jack
                                          /home/jack
                                          jack sudo iobroker
                                          #448
                                          @nashra sagte in iob diag - Skript:
                                          Keine Ahnung warum in deinem System die Services nicht laufen. Sollten sie imho eigentlich.
