  4. Node-Red
  5. Payload String zerlegen
    6.4k
77 Beiträge 7 Kommentatoren 19.7k Aufrufe 7 Beobachtet
  • 1 1984chris
    @mickym
    Mit der Maus, wenn ich über Wert kopieren reinkopiere kommt
    [123,34,84,105,109,101,34,58,34,50,48,50,51,45,48,53,45,49,54,84,49,57,58,52,53,58,50,57,34,44,34,84,97,103,115,116,114,111,109,1,34,58,123,34,86,95,76,49,34,58,50,51,51,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,54,44,34,65,95,76,49,34,58,48,46,54,51,44,34,65,95,76,50,34,58,50,46,51,51,44,34,65,95,76,51,34,58,48,46,51,50,44,34,87,95,73,78,34,58,53,57,48,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,49,57,49,52,55,46,55,53,54,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,55,55,54,46,51,56,51,125,44,34,87,195,164,80,117,34,58,123,34,86,95,76,49,34,58,50,51,50,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,53,44,34,65,95,76,49,34,58,48,46,52,56,44,34,65,95,76,50,34,58,48,46,48,48,44,34,65,95,76,51,34,58,48,46,48,50,44,34,87,95,73,78,34,58,49,49,50,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,50,49,54,57,56,46,53,51,53,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,48,46,48,48,48,125,125]
    mickymM Offline
    mickymM Offline
    mickym
    @1984chris Na OK - ich weiss nicht was Du da genau gemacht hast.
    Wie gesagt wenn Du meinen Flow importierst - habe ich gerade gemacht - dann erhälst Du folgende Struktur
    Wenn Du mein Flow hast - dann brauchst Du nur die neue Node und eine iobroker-Out Node:
    wie gesagt die Fremdobjekte erstellen zulassen und in der Node angeben unter welchem Datenpunkt die Datenpunkte angelegt werden sollen:
    Hier zum Import:
           "id": "6e802f1553b18149",
           "type": "subflow",
           "name": "JSON or Obj to IOBroker",
           "info": "# Creates an IOBroker tree\n\nThis node creates an IOBroker tree out of an Java-Object or JSON String.\n\nThe object tree will be created under 0_userdata.0\nIn addition to the JSON-String or Java Object as `msg.payload` it is necessary to specify a `msg.top` properity in addition to the msg-Object.\n\nThe object tree will be created under 0_userdata.0\n\nExisting `msg.topic` entries will be deleted.\nAn iobroker-out node has to be appended to this subflow node. It is not part of the subflow itself. No topic should be specified in the iobroker out node.\n\nIs `msg.top` property isn't defined, the `top` property of the subflow-node is used. \n\nIn the properties of the subflow node a new property `keepTopic` has been added. Default is _false_ to keep the current behaviour. If set to _true_ then the originial topic will be placed between the `top` property of the subflow node and the property of the analyzed JSON object.\n\n**Attention:**\nIf msg.top and top is empty, all msg.topics (msg.topic) will be directly prefixed with 0_userdata.0. . \n\n**Update 13.09.2022:**\nSpaces in topics of objects are no longer replaced with underscores in objects. No differences between all data types.\n\n# Erstellt einen Objektbaum im ioBroker\n\nDiese Node erstellt einen Objektbaum im ioBroker aus einem JAVA Objekt bzw. einem JSON String. \n\nDer Baum wird in jedem Fall unter 0_userdata.0 erstellt und zwar unter dem Topic der in` msg.top` mitgegeben wurde. In der `msg.payload` befindet sich dann der JSON String oder das entsprechende Objekt.\n\nExistierende `msg.topic `Einträge werden gelöscht.\nEin entsprechende iobroker-out Node muss an den Flow angehängt werden. Sie ist nicht Bestandteil des Subflows. In dieser iobroker-out Node darf kein Topic angegeben werden. \n\nFalls msg.top nicht definiert wurde, wird der `top`-Wert der Subflow-Node verwendet.\n\nIn den Eigenschaften der Subflow-Node wurde ein neuer Parameter `keepTopic` hinzugefügt. Standardwert ist _false_, um das bisherige Verhalten beizubehalten. Setzt man die Eigenschaft auf _true_, dann wird das originale Topic zwischen der `top` Eigenschaft der Subflow-Node und Eigenschaft des analysierten JSON Objektes eingefügt.\n\n**Achtung:**\nWenn top und msg.top leer ist, werden alle msg.topics (msg.topic) direkt unter dem Präfix 0_userdata.0., angelegt bzw. ausgegeben. \n\n**Update 13.09.2022:**\nLeerzeichen werden in Topics von Objekten nicht mehr durch Unterstriche ersetzt. Es gibt keine Unterschiede mehr zwischen den Datentypen.",
           "category": "",
           "in": [
                   "x": 60,
                   "y": 160,
                   "wires": [
                           "id": "554b8c663bcb46c2"
           "out": [
                   "x": 2620,
                   "y": 280,
                   "wires": [
                           "id": "0962842ebd23e0d7",
                           "port": 0
           "env": [
                   "name": "top",
                   "type": "str",
                   "value": "objRoot"
                   "name": "keepTopic",
                   "type": "bool",
                   "value": "false"
           "meta": {},
           "color": "#E2D96E",
           "icon": "node-red/batch.svg"
           "id": "3e11e8338f694832",
           "type": "split",
           "z": "6e802f1553b18149",
           "name": "split object",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "arraySpltType": "len",
           "stream": false,
           "addname": "key",
           "x": 1370,
           "y": 160,
           "wires": [
                   "0562a4249c8b856b"
           "id": "0562a4249c8b856b",
           "type": "change",
           "name": "add key to topic",
           "rules": [
                   "t": "set",
                   "p": "stateName",
                   "pt": "msg",
                   "to": "key",
                   "tot": "msg"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic  & '.' & key",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1560,
           "y": 160,
           "wires": [
                   "ddc90985bef0fafa"
           "id": "ddc90985bef0fafa",
           "type": "switch",
           "name": "is type?",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1740,
           "y": 160,
           "wires": [
                   "bfce19b206660fbe"
                   "3e11e8338f694832"
                   "1a8c03d866b85b12"
           "id": "bfce19b206660fbe",
           "type": "split",
           "name": "split array",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "stream": false,
           "addname": "",
           "x": 780,
           "y": 280,
           "wires": [
                   "e89927810c6d75ec"
           "id": "e89927810c6d75ec",
           "type": "change",
           "name": "add index to topic",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic  & '.' & parts.index",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 970,
           "y": 280,
           "wires": [
                   "a4d1a5d04564dc77"
           "id": "f5d52c6a57d08904",
           "type": "change",
           "name": "finalize msg.topic",
           "rules": [
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "'0_userdata.0.' & top",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "top & '.' & topic",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2170,
           "y": 240,
           "wires": [
                   "0962842ebd23e0d7"
           "id": "1a8c03d866b85b12",
           "type": "switch",
           "name": "is msg.top != null",
           "property": "top",
           "rules": [
                   "t": "nnull"
                   "t": "null"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 1950,
           "y": 280,
           "wires": [
                   "f5d52c6a57d08904"
                   "74c895ce724750de"
           "id": "e023fe88445ce43e",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "delete",
                   "p": "topic",
                   "pt": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 200,
           "wires": [
                   "3649300b4c233b10"
           "id": "3649300b4c233b10",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "json",
                   "vt": "json"
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 4,
           "x": 600,
           "y": 160,
           "wires": [
                   "fc7913a8524badb7"
                   "bfce19b206660fbe"
                   "3e11e8338f694832"
                   "9ac3cc3681e8b6c6"
           "id": "1b8480cd2df7ba3f",
           "type": "comment",
           "name": "Array",
           "info": "",
           "x": 600,
           "y": 280,
           "wires": []
           "id": "b3541807672be040",
           "type": "comment",
           "name": "object",
           "info": "",
           "x": 1340,
           "y": 100,
           "wires": []
           "id": "a4d1a5d04564dc77",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1160,
           "y": 280,
           "wires": [
                   "3e11e8338f694832"
                   "bfce19b206660fbe"
                   "a096a93bb82b7a93"
           "id": "74c895ce724750de",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "top",
                   "tot": "env"
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2170,
           "y": 320,
           "wires": [
                   "0962842ebd23e0d7"
           "id": "554b8c663bcb46c2",
           "type": "switch",
           "name": "",
           "property": "keepTopic",
           "propertyType": "env",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 170,
           "y": 160,
           "wires": [
                   "e30ba9f0483285e4"
                   "e023fe88445ce43e"
           "id": "e30ba9f0483285e4",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "/",
                   "fromt": "str",
                   "to": ".",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 120,
           "wires": [
                   "3649300b4c233b10"
           "type": "change",
           "name": "translate invalid chars in topic",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "..",
                   "fromt": "str",
                   "to": ".",
                   "tot": "str"
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "€",
                   "fromt": "str",
                   "to": "EUR",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2430,
           "y": 280,
           "wires": [
           "id": "9ac3cc3681e8b6c6",
           "type": "change",
           "name": "set topic, if empty",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic ? topic : $type(payload)\t",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 950,
           "y": 200,
           "wires": [
                   "a096a93bb82b7a93"
           "id": "fc7913a8524badb7",
           "type": "json",
           "name": "",
           "action": "obj",
           "pretty": false,
           "x": 750,
           "y": 100,
           "wires": [
                   "d9e7bdd4c48a8aa1"
           "id": "d9e7bdd4c48a8aa1",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 900,
           "y": 100,
           "wires": [
                   "1520be42bcc2145e"
                   "1520be42bcc2145e"
                   "9ac3cc3681e8b6c6"
           "id": "a096a93bb82b7a93",
           "type": "junction",
           "x": 1380,
           "y": 280,
           "wires": [
                   "1a8c03d866b85b12"
           "id": "1520be42bcc2145e",
           "type": "junction",
           "x": 480,
           "y": 20,
           "wires": [
                   "3649300b4c233b10"
           "id": "ef7643b826aed308",
           "type": "subflow:6e802f1553b18149",
           "z": "1983aa28392732ca",
           "name": "",
           "env": [
                   "name": "top",
                   "value": "Sensor_903788",
                   "type": "str"
           "x": 550,
           "y": 2960,
           "wires": [
                   "2b9df08b75d20726"
           "id": "2b9df08b75d20726",
           "type": "ioBroker out",
           "name": "",
           "topic": "",
           "ack": "true",
           "autoCreate": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "true",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 780,
           "y": 2960,
           "wires": []
    In der NodeRed Adapter konfig schauen, dass Fremdobjekte erstellt werden dürfen und die Konvertierung ausgeschaltet ist.
    1 1 Antwort Letzte Antwort
    • mickymM mickym
      Hier zum Import:
             "type": "subflow",
             "category": "",
             "in": [
                     "x": 60,
                     "y": 160,
                     "wires": [
             "out": [
                     "x": 2620,
                     "y": 280,
                     "wires": [
                             "port": 0
             "env": [
                     "name": "top",
                     "type": "str",
                     "value": "objRoot"
                     "type": "bool",
                     "value": "false"
             "meta": {},
             "color": "#E2D96E",
             "type": "split",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "stream": false,
             "addname": "key",
             "x": 1370,
             "y": 160,
             "wires": [
                     "0562a4249c8b856b"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "stateName",
                     "pt": "msg",
                     "to": "key",
                     "tot": "msg"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1560,
             "y": 160,
             "wires": [
                     "ddc90985bef0fafa"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 1740,
             "y": 160,
             "wires": [
                     "bfce19b206660fbe"
                     "3e11e8338f694832"
                     "1a8c03d866b85b12"
             "type": "split",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "stream": false,
             "addname": "",
             "x": 780,
             "y": 280,
             "wires": [
                     "e89927810c6d75ec"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 970,
             "y": 280,
             "wires": [
                     "a4d1a5d04564dc77"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2170,
             "y": 240,
             "wires": [
                     "0962842ebd23e0d7"
             "type": "switch",
             "property": "top",
             "rules": [
                     "t": "nnull"
                     "t": "null"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 1950,
             "y": 280,
             "wires": [
                     "f5d52c6a57d08904"
                     "74c895ce724750de"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "delete",
                     "p": "topic",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 350,
             "y": 200,
             "wires": [
                     "3649300b4c233b10"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "json",
                     "vt": "json"
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 600,
             "y": 160,
             "wires": [
                     "fc7913a8524badb7"
                     "bfce19b206660fbe"
                     "3e11e8338f694832"
                     "9ac3cc3681e8b6c6"
             "type": "comment",
             "name": "Array",
             "info": "",
             "x": 600,
             "y": 280,
             "wires": []
             "type": "comment",
             "name": "object",
             "info": "",
             "x": 1340,
             "y": 100,
             "wires": []
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 1160,
             "y": 280,
             "wires": [
                     "3e11e8338f694832"
                     "bfce19b206660fbe"
                     "a096a93bb82b7a93"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "to": "top",
                     "tot": "env"
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2170,
             "y": 320,
             "wires": [
                     "0962842ebd23e0d7"
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 170,
             "y": 160,
             "wires": [
                     "e30ba9f0483285e4"
                     "e023fe88445ce43e"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "/",
                     "fromt": "str",
                     "to": ".",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 350,
             "y": 120,
             "wires": [
                     "3649300b4c233b10"
             "type": "change",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "..",
                     "fromt": "str",
                     "to": ".",
                     "tot": "str"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "€",
                     "fromt": "str",
                     "to": "EUR",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2430,
             "y": 280,
             "wires": [
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 950,
             "y": 200,
             "wires": [
                     "a096a93bb82b7a93"
             "type": "json",
             "name": "",
             "action": "obj",
             "pretty": false,
             "x": 750,
             "y": 100,
             "wires": [
                     "d9e7bdd4c48a8aa1"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 900,
             "y": 100,
             "wires": [
                     "1520be42bcc2145e"
                     "1520be42bcc2145e"
                     "9ac3cc3681e8b6c6"
             "type": "junction",
             "x": 1380,
             "y": 280,
             "wires": [
                     "1a8c03d866b85b12"
             "type": "junction",
             "x": 480,
             "y": 20,
             "wires": [
                     "3649300b4c233b10"
             "name": "",
             "env": [
                     "name": "top",
                     "type": "str"
             "x": 550,
             "y": 2960,
             "wires": [
                     "2b9df08b75d20726"
             "name": "",
             "topic": "",
             "ack": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "true",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 780,
             "y": 2960,
             "wires": []
      1 Offline
      1 Offline
      1984chris
      @mickym
      Bin blutiger Anfänger in NodeRed und habe keine Programierkenntnisse,hab mir gedacht das geht so einfach.
      • 1 1984chris
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @1984chris Geht dich auch einfach. Also Schritt für Schritt:
        1. Hast Du die Einstellungen in der Adapterkonfiguration gemacht?
        2. Weißt Du wie man einen Flow importiert?
        • mickymM mickym
          1 Offline
          1 Offline
          1984chris
          @mickym
          Ich habe noch kein iobrocker.
          habe via Docker MQTT NODERED InfluxDB und GRAFANA laufen
          • 1 1984chris
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @1984chris Ah OK - gut das ändert natürlich einiges. ;)
            Gut kannst Du mal einen Screenshot von Deinem Flow machen und dann stelle bitte in deinen mqtt-Nodes ein, dass das Objekt komplett analysiert werden soll.
            Dann solltest du nun in dem Debug Fenster keinen String sondern ein Objekt bekommen. Wenn Du das hast - dann mach da mal ein Screenshot von Deinem Debug Fenster.
            Welche Influx DB Version nutzt Du denn?
            • mickymM mickym
              1 Offline
              1 Offline
              1984chris
              @mickym
              so?
              1 mickymM 2 Antworten Letzte Antwort
              • 1 1984chris
                @mickym
                so?
                1 Offline
                1 Offline
                1984chris
                @mickym
                influxDB1.8
                • 1 1984chris
                  @mickym
                  so?
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @1984chris sagte in Payload String zerlegen:
                  @mickym
                  so?
                  Ja dann sollte auch das Objekt in der Debug Node anders aussehen, Wenn Du das so einstellst.
                  • 1 1984chris
                    @mickym
                    influxDB1.8
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @mickym
                    influxDB1.8
                    Hast Du die neu installiert und warum die alte Version?
                    • mickymM mickym
                      @mickym
                      so?
                      1 Offline
                      1 Offline
                      1984chris
                      @mickym
                      aber das ist ja die Debug Node
                      • 1 1984chris
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @1984chris Ja aber wenn Du in der mqtt- Node umgestellt hast, dann sollte das Objekt auch anders aussehen.
                        • mickymM mickym
                          1 Offline
                          1 Offline
                          1984chris
                          @mickym
                          das Foto ist schon als ich die Umstellung gemacht habe.
                          • 1 1984chris
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @mickym
                            Wenn Du die mqtt Node bereits umgestellt hättest, dann sollte die Ausgabe Deiner Debug Node so aussehen:
                            Du hattest vorher
                            eingestellt.
                            • mickymM mickym
                              @mickym
                              Du hattest vorher
                              eingestellt.
                              1 Offline
                              1 Offline
                              1984chris
                              • 1 1984chris
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @1984chris Ja das ist ein Buffer
                                Schau mal in der mqtt Node - dass das drin steht:
                                Das müsste auch so voreingestellt gewesen sein - das hast Du sonst nachträglich umgestellt.
                                Welche NodeRed Version nutzt du denn?
                                • mickymM mickym
                                  1 Offline
                                  1 Offline
                                  1984chris
                                  @mickym
                                  das ist meine Einstellung
                                  NodeRed V3.0.2
                                  • 1 1984chris
                                    @mickym
                                    NodeRed V3.0.2
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @1984chris Zieh bitte nochmal eine neue Mqtt-In Node raus - lass den QoS auf 2 - ändere gar nichts und trage nur das Topic ein.
                                    Bei mir kommen auch Objekte raus. Hast Du Deinen Broker auf Version 3.1.1 eingestellt?
                                    Und ich habe es auch den tele/SENSOR topic bei mir eingestellt.
                                    Das Intervall wie oft der tele Ast sendet stellst Du über die TelePeriod in der Tasmota Konsole ein:
                                    • mickymM mickym
                                      1 Offline
                                      1 Offline
                                      1984chris
                                      @mickym
                                      entweder bin ich zu blöd oda keine Ahnung warum das nicht geht
                                      • 1 1984chris
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @1984chris Was nutzt Du für ein mqtt-Broker? mosquitto?
                                        • 1 1984chris
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @1984chris Ok - dann machen wir das anders. Stellst Du mal
                                          um und zeig dann mal die Debug Ausgabe.
