  4. Node-Red
  5. Payload String zerlegen
    6.4k
77 Beiträge 7 Kommentatoren 19.6k Aufrufe 7 Beobachtet
  • R rieders
    Hallo
    Ich versuche gerade mein Stromzähler String zu zerlegen.
    Eine Verbindung zum mqtt-Broker besteht, die Daten werden auch im Debug angezeigt.
    Ich habe schon einiges Versuch, ich bekomme einfach nicht die Werte einzeln angezeigt.
    Smartmeter_Garten/tele/SENSOR : msg.payload : string[643]
    "{"Time":"2023-01-13T12:54:35","SDM630":{"1":178,"Voltage_P1":231.88,"Voltage_P2":231.5,"Voltage_P3":232.49,"Current_P1":0,"Current_P2":0.1,"Current_P3":0,"Power_P1":0,"Power_P2":22.35,"Power_P3":0,"Frequenz":50.01,"Total":534.694,"phase_angle":-9.73,"Import_nres":186.145,"Export_nres":348.549,"Export_P1":13.568,"Export_P2":334.981,"Export_P3":0,"Import_P1":19.409,"Import_P2":131.003,"Import_P3":35.733,"L1_total_kwh":32.977,"L2_total_kwh":465.984,"L3_total_kwh":35.733,"Blindleistung_L1":0,"Blindleistung_L2":-7.734,"Blindleistung_L3":0,"Scheinleistung_L1":0,"Scheinleistung_L2":22.627,"Scheinleistung_L3":0,"VAh_since_last_reset":565.815}}"
    Ich hoffe jemand kann mir weiter helfen.
    "id": "553525487db580b5",
    "type": "mqtt in",
    "z": "eb71b4cddc9da37a",
    "name": "Smartmeter_Garten/tele/SENSOR",
    "topic": "Smartmeter_Garten/tele/SENSOR",
    "qos": "2",
    "datatype": "auto-detect",
    "broker": "e7e1e2255e66e588",
    "nl": false,
    "rap": true,
    "rh": "2",
    "inputs": 0,
    "x": 180,
    "y": 260,
    "wires": [
    "04a7ba72539a5cb1",
    "df378652670347e0"
    "id": "b0fcb45d6d8ab9f4",
    "type": "ui_gauge",
    "name": "Test",
    "group": "67140eec2a9994a9",
    "order": 0,
    "width": 0,
    "height": 0,
    "gtype": "gage",
    "title": "Voltage_P1",
    "label": "",
    "format": "{{Value}}",
    "min": "1",
    "max": "260",
    "colors": [
    "#b30000",
    "#e6e600",
    "#00b815"
    "seg1": "",
    "seg2": "",
    "x": 890,
    "y": 260,
    "wires": []
    "id": "9faaac80e56b9d83",
    "type": "ui_chart",
    "name": "",
    "order": 0,
    "width": 0,
    "height": 0,
    "label": "chart",
    "chartType": "line",
    "legend": "false",
    "xformat": "HH:mm:ss",
    "interpolate": "linear",
    "nodata": "",
    "dot": false,
    "ymin": "0",
    "ymax": "260",
    "removeOlder": 1,
    "removeOlderPoints": "",
    "removeOlderUnit": "3600",
    "cutout": 0,
    "useOneColor": false,
    "useUTC": false,
    "colors": [
    "#1f77b4",
    "#aec7e8",
    "#ff7f0e",
    "#2ca02c",
    "#98df8a",
    "#d62728",
    "#ff9896",
    "#9467bd",
    "#c5b0d5"
    "outputs": 1,
    "useDifferentColor": false,
    "x": 890,
    "y": 320,
    "wires": [
    "id": "04a7ba72539a5cb1",
    "type": "json",
    "name": "V1",
    "property": "payload",
    "action": "",
    "pretty": false,
    "x": 450,
    "y": 200,
    "wires": [
    "35354018b6c6c095",
    "639599639f78788c"
    "id": "6f72cb37f4aa2278",
    "type": "debug",
    "name": "debug 1",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "targetType": "msg",
    "statusVal": "",
    "statusType": "auto",
    "x": 900,
    "y": 200,
    "wires": []
    "id": "35354018b6c6c095",
    "type": "debug",
    "name": "debug 2",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 620,
    "y": 120,
    "wires": []
    "id": "639599639f78788c",
    "type": "change",
    "name": "",
    "rules": [
    "t": "set",
    "p": "payload",
    "pt": "msg",
    "to": "payload["SDM630"].Voltage_P1",
    "tot": "msg"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 670,
    "y": 200,
    "wires": [
    "6f72cb37f4aa2278",
    "b0fcb45d6d8ab9f4",
    "9faaac80e56b9d83"
    "id": "a5192d83b6ce2f1c",
    "type": "mqtt out",
    "name": "V1",
    "topic": "Testzähler",
    "qos": "",
    "retain": "",
    "respTopic": "",
    "contentType": "",
    "userProps": "",
    "correl": "",
    "expiry": "",
    "broker": "d19896c9b4e98e28",
    "x": 750,
    "y": 340,
    "wires": []
    "id": "df378652670347e0",
    "type": "function",
    "name": "function 2",
    "func": "\nreturn msg;payload["SDM630"].Voltage_P1",
    "outputs": 1,
    "noerr": 0,
    "initialize": "",
    "finalize": "",
    "libs": [],
    "x": 560,
    "y": 340,
    "wires": [
    "a5192d83b6ce2f1c"
    "id": "e7e1e2255e66e588",
    "type": "mqtt-broker",
    "name": "mqtt-broker",
    "broker": "192.168.1.146",
    "port": "1885",
    "clientid": "",
    "autoConnect": true,
    "usetls": false,
    "protocolVersion": "4",
    "keepalive": "60",
    "cleansession": true,
    "birthTopic": "",
    "birthQos": "0",
    "birthPayload": "",
    "birthMsg": {},
    "closeTopic": "",
    "closeQos": "0",
    "closePayload": "",
    "closeMsg": {},
    "willTopic": "",
    "willQos": "0",
    "willPayload": "",
    "willMsg": {},
    "userProps": "",
    "sessionExpiry": ""
    "id": "67140eec2a9994a9",
    "type": "ui_group",
    "name": "Test",
    "tab": "71f6d060a354b8d9",
    "order": 1,
    "disp": true,
    "width": "6",
    "collapse": false
    "id": "d19896c9b4e98e28",
    "name": "Venus OS",
    "broker": "192.168.1.37",
    "port": "1883",
    "clientid": "test-client",
    "usetls": false,
    "keepalive": "60",
    "birthTopic": "",
    "birthQos": "0",
    "birthPayload": "",
    "birthMsg": {},
    "closeTopic": "",
    "closeQos": "0",
    "closePayload": "",
    "closeMsg": {},
    "willTopic": "",
    "willQos": "0",
    "willPayload": "",
    "willMsg": {},
    "userProps": "",
    "sessionExpiry": ""
    "id": "71f6d060a354b8d9",
    "type": "ui_tab",
    "name": "Home",
    "icon": "dashboard",
    "disabled": false,
    "hidden": false
    Grüße André
    1 Offline
    1 Offline
    1984chris
    @rieders @rieders Hallo Ich habe das gleiche Problem wie du
    ![0_1684256284880_ausgabe.jpg](Uploading 100%)
    konntest du das wie in Debug2 darstellen?
    DANKE im Voraus
    LG Christoph
    1 1 Antwort Letzte Antwort
    • 1 1984chris
      DANKE im Voraus
      LG Christoph
      1 Offline
      1 Offline
      1984chris
      1 mickymM 2 Antworten Letzte Antwort
      • 1 1984chris
        1 Offline
        1 Offline
        1984chris
        @1984chris ich will die einzelnen Werte L1,L2,L3 Ströme A_L1,A_l2 usw an die influxDB übertragen
        • 1 1984chris
          mickymM Offline
          mickymM Offline
          mickym
          @1984chris Wenn ich Dir helfen soll, dann solltest Du den Wert in die Zwischenablage kopieren und hier in Codetags einbetten.
          Dann woher hast Du das - kommt das aus einer iobroker IN Node oder aus einer mqtt Node?
          Willst Du alle Werte in einzelne Datenpunkte zerlegen oder nur einzelne Werte extrahieren und weiter verarbeiten?
          Einzelne Werte kopierst Du in die Zwischenablage in dem Du mit der Maul im Debug Fenster neben den Wert fährst.
          Wenn Du es in der Zwischenablage hast, dann kopierst Du es bitte in Code-Tags wie hier dargestellt:
          Und wie gesagt - wer es nett, wenn Du ein paar Zeilen dazu schreiben möchtest, was Du möchtest
          • 1 1984chris
            mickymM Offline
            mickymM Offline
            mickym
            @1984chris sagte in Payload String zerlegen:
            Dann wäre es wohl sinnvoll einzelne Werte zu erstellen, dann empfehle ich Dir meinen Flow - der den ganzen JSON in einzelne Datenpunkte schreibt:
            https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
            Dann brauchst Du nur diesen Flow zu importieren.
            Im 1. Post ist eigentlich alles beschrieben und welche Einstellungen Du machen willst. Falls Du noch Fragen hast, dann gerne. Also hängt davon ab, ob Du nur ein paar Werte haben willst oder alle Werte einzeln haben möchtest.
            • mickymM mickym
              1 Offline
              1 Offline
              1984chris
              @mickym ```
              {"Time":"2023-05-16T19:45:29","Tagstrom":{"V_L1":233,"V_L3":236,"V_L3":236,"A_L1":0.63,"A_L2":2.33,"A_L3":0.32,"W_IN":590,"W_OUT":0,"kWh_total_IN":19147.756,"kWh_total_OUT":776.383},"WäPu":{"V_L1":232,"V_L3":236,"V_L3":235,"A_L1":0.48,"A_L2":0.00,"A_L3":0.02,"W_IN":112,"W_OUT":0,"kWh_total_IN":21698.535,"kWh_total_OUT":0.000}}
              die Daten kommen von einenm Nodred in mqtt ich bekomme das auf der Debugseite nicht so angezeigt wie du im Beispiel. Will die einzelnen Werte dan in eine influxDB und weiter mit GRAFANA....
              • 1 1984chris
                @mickym ```
                mickymM Offline
                mickymM Offline
                mickym
                @1984chris Wie gesagt wenn Du alle Werte haben willst, hast Du meinen Flow importiert und das Erstellen von Objekten zugelassen?
                • 1 1984chris
                  @mickym ```
                  mickymM Offline
                  mickymM Offline
                  mickym
                  In dem Tagstrom ist ein komisches Zeichen - hast Du den String über Wert kopieren reinkopiert oder mit der Maus?
                      "Time": "2023-05-16T19:45:29",
                      "Tagstrom": {
                          "V_L1": 233,
                          "V_L3": 236,
                          "A_L1": 0.63,
                          "A_L2": 2.33,
                          "A_L3": 0.32,
                          "W_IN": 590,
                          "W_OUT": 0,
                          "kWh_total_IN": 19147.756,
                          "kWh_total_OUT": 776.383
                      "WäPu": {
                          "V_L1": 232,
                          "V_L3": 235,
                          "A_L1": 0.48,
                          "A_L2": 0,
                          "A_L3": 0.02,
                          "W_IN": 112,
                          "W_OUT": 0,
                          "kWh_total_IN": 21698.535,
                          "kWh_total_OUT": 0
                  So funktioniert es.
                  • mickymM mickym
                        "Tagstrom": {
                            "V_L1": 233,
                            "V_L3": 236,
                            "A_L1": 0.63,
                            "A_L2": 2.33,
                            "A_L3": 0.32,
                            "W_IN": 590,
                            "W_OUT": 0,
                        "WäPu": {
                            "V_L1": 232,
                            "V_L3": 235,
                            "A_L1": 0.48,
                            "A_L2": 0,
                            "A_L3": 0.02,
                            "W_IN": 112,
                            "W_OUT": 0,
                            "kWh_total_OUT": 0
                    So funktioniert es.
                    1 Offline
                    1 Offline
                    1984chris
                    @mickym
                    Mit der Maus, wenn ich über Wert kopieren reinkopiere kommt
                    [123,34,84,105,109,101,34,58,34,50,48,50,51,45,48,53,45,49,54,84,49,57,58,52,53,58,50,57,34,44,34,84,97,103,115,116,114,111,109,1,34,58,123,34,86,95,76,49,34,58,50,51,51,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,54,44,34,65,95,76,49,34,58,48,46,54,51,44,34,65,95,76,50,34,58,50,46,51,51,44,34,65,95,76,51,34,58,48,46,51,50,44,34,87,95,73,78,34,58,53,57,48,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,49,57,49,52,55,46,55,53,54,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,55,55,54,46,51,56,51,125,44,34,87,195,164,80,117,34,58,123,34,86,95,76,49,34,58,50,51,50,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,53,44,34,65,95,76,49,34,58,48,46,52,56,44,34,65,95,76,50,34,58,48,46,48,48,44,34,65,95,76,51,34,58,48,46,48,50,44,34,87,95,73,78,34,58,49,49,50,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,50,49,54,57,56,46,53,51,53,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,48,46,48,48,48,125,125]
                    • 1 1984chris
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @1984chris Na OK - ich weiss nicht was Du da genau gemacht hast.
                      Wie gesagt wenn Du meinen Flow importierst - habe ich gerade gemacht - dann erhälst Du folgende Struktur
                      Wenn Du mein Flow hast - dann brauchst Du nur die neue Node und eine iobroker-Out Node:
                      wie gesagt die Fremdobjekte erstellen zulassen und in der Node angeben unter welchem Datenpunkt die Datenpunkte angelegt werden sollen:
                      Hier zum Import:
                             "id": "6e802f1553b18149",
                             "type": "subflow",
                             "name": "JSON or Obj to IOBroker",
                             "info": "# Creates an IOBroker tree\n\nThis node creates an IOBroker tree out of an Java-Object or JSON String.\n\nThe object tree will be created under 0_userdata.0\nIn addition to the JSON-String or Java Object as `msg.payload` it is necessary to specify a `msg.top` properity in addition to the msg-Object.\n\nThe object tree will be created under 0_userdata.0\n\nExisting `msg.topic` entries will be deleted.\nAn iobroker-out node has to be appended to this subflow node. It is not part of the subflow itself. No topic should be specified in the iobroker out node.\n\nIs `msg.top` property isn't defined, the `top` property of the subflow-node is used. \n\nIn the properties of the subflow node a new property `keepTopic` has been added. Default is _false_ to keep the current behaviour. If set to _true_ then the originial topic will be placed between the `top` property of the subflow node and the property of the analyzed JSON object.\n\n**Attention:**\nIf msg.top and top is empty, all msg.topics (msg.topic) will be directly prefixed with 0_userdata.0. . \n\n**Update 13.09.2022:**\nSpaces in topics of objects are no longer replaced with underscores in objects. No differences between all data types.\n\n# Erstellt einen Objektbaum im ioBroker\n\nDiese Node erstellt einen Objektbaum im ioBroker aus einem JAVA Objekt bzw. einem JSON String. \n\nDer Baum wird in jedem Fall unter 0_userdata.0 erstellt und zwar unter dem Topic der in` msg.top` mitgegeben wurde. In der `msg.payload` befindet sich dann der JSON String oder das entsprechende Objekt.\n\nExistierende `msg.topic `Einträge werden gelöscht.\nEin entsprechende iobroker-out Node muss an den Flow angehängt werden. Sie ist nicht Bestandteil des Subflows. In dieser iobroker-out Node darf kein Topic angegeben werden. \n\nFalls msg.top nicht definiert wurde, wird der `top`-Wert der Subflow-Node verwendet.\n\nIn den Eigenschaften der Subflow-Node wurde ein neuer Parameter `keepTopic` hinzugefügt. Standardwert ist _false_, um das bisherige Verhalten beizubehalten. Setzt man die Eigenschaft auf _true_, dann wird das originale Topic zwischen der `top` Eigenschaft der Subflow-Node und Eigenschaft des analysierten JSON Objektes eingefügt.\n\n**Achtung:**\nWenn top und msg.top leer ist, werden alle msg.topics (msg.topic) direkt unter dem Präfix 0_userdata.0., angelegt bzw. ausgegeben. \n\n**Update 13.09.2022:**\nLeerzeichen werden in Topics von Objekten nicht mehr durch Unterstriche ersetzt. Es gibt keine Unterschiede mehr zwischen den Datentypen.",
                             "category": "",
                             "in": [
                                     "x": 60,
                                     "y": 160,
                                     "wires": [
                                             "id": "554b8c663bcb46c2"
                             "out": [
                                     "x": 2620,
                                     "y": 280,
                                     "wires": [
                                             "id": "0962842ebd23e0d7",
                                             "port": 0
                             "env": [
                                     "name": "top",
                                     "type": "str",
                                     "value": "objRoot"
                                     "name": "keepTopic",
                                     "type": "bool",
                                     "value": "false"
                             "meta": {},
                             "color": "#E2D96E",
                             "icon": "node-red/batch.svg"
                             "id": "3e11e8338f694832",
                             "type": "split",
                             "z": "6e802f1553b18149",
                             "name": "split object",
                             "splt": "\\n",
                             "spltType": "str",
                             "arraySplt": 1,
                             "arraySpltType": "len",
                             "stream": false,
                             "addname": "key",
                             "x": 1370,
                             "y": 160,
                             "wires": [
                                     "0562a4249c8b856b"
                             "id": "0562a4249c8b856b",
                             "type": "change",
                             "name": "add key to topic",
                             "rules": [
                                     "t": "set",
                                     "p": "stateName",
                                     "pt": "msg",
                                     "to": "key",
                                     "tot": "msg"
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "topic  & '.' & key",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1560,
                             "y": 160,
                             "wires": [
                                     "ddc90985bef0fafa"
                             "id": "ddc90985bef0fafa",
                             "type": "switch",
                             "name": "is type?",
                             "propertyType": "msg",
                             "rules": [
                                     "t": "istype",
                                     "v": "array",
                                     "vt": "array"
                                     "t": "istype",
                                     "v": "object",
                                     "vt": "object"
                                     "t": "else"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 1740,
                             "y": 160,
                             "wires": [
                                     "bfce19b206660fbe"
                                     "3e11e8338f694832"
                                     "1a8c03d866b85b12"
                             "id": "bfce19b206660fbe",
                             "type": "split",
                             "name": "split array",
                             "splt": "\\n",
                             "spltType": "str",
                             "arraySplt": 1,
                             "stream": false,
                             "addname": "",
                             "x": 780,
                             "y": 280,
                             "wires": [
                                     "e89927810c6d75ec"
                             "id": "e89927810c6d75ec",
                             "type": "change",
                             "name": "add index to topic",
                             "rules": [
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "topic  & '.' & parts.index",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 970,
                             "y": 280,
                             "wires": [
                                     "a4d1a5d04564dc77"
                             "id": "f5d52c6a57d08904",
                             "type": "change",
                             "name": "finalize msg.topic",
                             "rules": [
                                     "t": "set",
                                     "p": "top",
                                     "pt": "msg",
                                     "to": "'0_userdata.0.' & top",
                                     "tot": "jsonata"
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "top & '.' & topic",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 2170,
                             "y": 240,
                             "wires": [
                                     "0962842ebd23e0d7"
                             "id": "1a8c03d866b85b12",
                             "type": "switch",
                             "name": "is msg.top != null",
                             "property": "top",
                             "rules": [
                                     "t": "nnull"
                                     "t": "null"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 1950,
                             "y": 280,
                             "wires": [
                                     "f5d52c6a57d08904"
                                     "74c895ce724750de"
                             "id": "e023fe88445ce43e",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "delete",
                                     "p": "topic",
                                     "pt": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 350,
                             "y": 200,
                             "wires": [
                                     "3649300b4c233b10"
                             "id": "3649300b4c233b10",
                             "type": "switch",
                             "name": "is type?",
                             "rules": [
                                     "t": "istype",
                                     "v": "json",
                                     "vt": "json"
                                     "t": "istype",
                                     "v": "array",
                                     "vt": "array"
                                     "t": "istype",
                                     "v": "object",
                                     "vt": "object"
                                     "t": "else"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 4,
                             "x": 600,
                             "y": 160,
                             "wires": [
                                     "fc7913a8524badb7"
                                     "bfce19b206660fbe"
                                     "3e11e8338f694832"
                                     "9ac3cc3681e8b6c6"
                             "id": "1b8480cd2df7ba3f",
                             "type": "comment",
                             "name": "Array",
                             "info": "",
                             "x": 600,
                             "y": 280,
                             "wires": []
                             "id": "b3541807672be040",
                             "type": "comment",
                             "name": "object",
                             "info": "",
                             "x": 1340,
                             "y": 100,
                             "wires": []
                             "id": "a4d1a5d04564dc77",
                             "type": "switch",
                             "name": "is type?",
                             "rules": [
                                     "t": "istype",
                                     "v": "object",
                                     "vt": "object"
                                     "t": "istype",
                                     "v": "array",
                                     "vt": "array"
                                     "t": "else"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 1160,
                             "y": 280,
                             "wires": [
                                     "3e11e8338f694832"
                                     "bfce19b206660fbe"
                                     "a096a93bb82b7a93"
                             "id": "74c895ce724750de",
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "top",
                                     "pt": "msg",
                                     "to": "top",
                                     "tot": "env"
                                     "t": "set",
                                     "p": "top",
                                     "pt": "msg",
                                     "tot": "jsonata"
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 2170,
                             "y": 320,
                             "wires": [
                                     "0962842ebd23e0d7"
                             "id": "554b8c663bcb46c2",
                             "type": "switch",
                             "name": "",
                             "property": "keepTopic",
                             "propertyType": "env",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 170,
                             "y": 160,
                             "wires": [
                                     "e30ba9f0483285e4"
                                     "e023fe88445ce43e"
                             "id": "e30ba9f0483285e4",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "change",
                                     "p": "topic",
                                     "pt": "msg",
                                     "from": "/",
                                     "fromt": "str",
                                     "to": ".",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 350,
                             "y": 120,
                             "wires": [
                                     "3649300b4c233b10"
                             "type": "change",
                             "name": "translate invalid chars in topic",
                             "rules": [
                                     "t": "change",
                                     "p": "topic",
                                     "pt": "msg",
                                     "from": "..",
                                     "fromt": "str",
                                     "to": ".",
                                     "tot": "str"
                                     "t": "change",
                                     "p": "topic",
                                     "pt": "msg",
                                     "from": "€",
                                     "fromt": "str",
                                     "to": "EUR",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 2430,
                             "y": 280,
                             "wires": [
                             "id": "9ac3cc3681e8b6c6",
                             "type": "change",
                             "name": "set topic, if empty",
                             "rules": [
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "topic ? topic : $type(payload)\t",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 950,
                             "y": 200,
                             "wires": [
                                     "a096a93bb82b7a93"
                             "id": "fc7913a8524badb7",
                             "type": "json",
                             "name": "",
                             "action": "obj",
                             "pretty": false,
                             "x": 750,
                             "y": 100,
                             "wires": [
                                     "d9e7bdd4c48a8aa1"
                             "id": "d9e7bdd4c48a8aa1",
                             "type": "switch",
                             "name": "is type?",
                             "rules": [
                                     "t": "istype",
                                     "v": "array",
                                     "vt": "array"
                                     "t": "istype",
                                     "v": "object",
                                     "vt": "object"
                                     "t": "else"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 900,
                             "y": 100,
                             "wires": [
                                     "1520be42bcc2145e"
                                     "1520be42bcc2145e"
                                     "9ac3cc3681e8b6c6"
                             "id": "a096a93bb82b7a93",
                             "type": "junction",
                             "x": 1380,
                             "y": 280,
                             "wires": [
                                     "1a8c03d866b85b12"
                             "id": "1520be42bcc2145e",
                             "type": "junction",
                             "x": 480,
                             "y": 20,
                             "wires": [
                                     "3649300b4c233b10"
                             "id": "ef7643b826aed308",
                             "type": "subflow:6e802f1553b18149",
                             "z": "1983aa28392732ca",
                             "name": "",
                             "env": [
                                     "name": "top",
                                     "value": "Sensor_903788",
                                     "type": "str"
                             "x": 550,
                             "y": 2960,
                             "wires": [
                                     "2b9df08b75d20726"
                             "id": "2b9df08b75d20726",
                             "type": "ioBroker out",
                             "name": "",
                             "topic": "",
                             "ack": "true",
                             "autoCreate": "true",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "true",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 780,
                             "y": 2960,
                             "wires": []
                      In der NodeRed Adapter konfig schauen, dass Fremdobjekte erstellt werden dürfen und die Konvertierung ausgeschaltet ist.
                      • mickymM mickym
                        Hier zum Import:
                               "type": "subflow",
                               "category": "",
                               "in": [
                                       "x": 60,
                                       "y": 160,
                                       "wires": [
                               "out": [
                                       "x": 2620,
                                       "y": 280,
                                       "wires": [
                                               "port": 0
                               "env": [
                                       "name": "top",
                                       "type": "str",
                                       "value": "objRoot"
                                       "type": "bool",
                                       "value": "false"
                               "meta": {},
                               "color": "#E2D96E",
                               "type": "split",
                               "splt": "\\n",
                               "spltType": "str",
                               "arraySplt": 1,
                               "stream": false,
                               "addname": "key",
                               "x": 1370,
                               "y": 160,
                               "wires": [
                                       "0562a4249c8b856b"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "stateName",
                                       "pt": "msg",
                                       "to": "key",
                                       "tot": "msg"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1560,
                               "y": 160,
                               "wires": [
                                       "ddc90985bef0fafa"
                               "type": "switch",
                               "name": "is type?",
                               "rules": [
                                       "t": "istype",
                                       "v": "array",
                                       "vt": "array"
                                       "t": "istype",
                                       "v": "object",
                                       "vt": "object"
                                       "t": "else"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 1740,
                               "y": 160,
                               "wires": [
                                       "bfce19b206660fbe"
                                       "3e11e8338f694832"
                                       "1a8c03d866b85b12"
                               "type": "split",
                               "splt": "\\n",
                               "spltType": "str",
                               "arraySplt": 1,
                               "stream": false,
                               "addname": "",
                               "x": 780,
                               "y": 280,
                               "wires": [
                                       "e89927810c6d75ec"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 970,
                               "y": 280,
                               "wires": [
                                       "a4d1a5d04564dc77"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "top",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2170,
                               "y": 240,
                               "wires": [
                                       "0962842ebd23e0d7"
                               "type": "switch",
                               "property": "top",
                               "rules": [
                                       "t": "nnull"
                                       "t": "null"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 1950,
                               "y": 280,
                               "wires": [
                                       "f5d52c6a57d08904"
                                       "74c895ce724750de"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "delete",
                                       "p": "topic",
                                       "pt": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 350,
                               "y": 200,
                               "wires": [
                                       "3649300b4c233b10"
                               "type": "switch",
                               "name": "is type?",
                               "rules": [
                                       "t": "istype",
                                       "v": "json",
                                       "vt": "json"
                                       "t": "istype",
                                       "v": "array",
                                       "vt": "array"
                                       "t": "istype",
                                       "v": "object",
                                       "vt": "object"
                                       "t": "else"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 4,
                               "x": 600,
                               "y": 160,
                               "wires": [
                                       "fc7913a8524badb7"
                                       "bfce19b206660fbe"
                                       "3e11e8338f694832"
                                       "9ac3cc3681e8b6c6"
                               "type": "comment",
                               "name": "Array",
                               "info": "",
                               "x": 600,
                               "y": 280,
                               "wires": []
                               "type": "comment",
                               "name": "object",
                               "info": "",
                               "x": 1340,
                               "y": 100,
                               "wires": []
                               "type": "switch",
                               "name": "is type?",
                               "rules": [
                                       "t": "istype",
                                       "v": "object",
                                       "vt": "object"
                                       "t": "istype",
                                       "v": "array",
                                       "vt": "array"
                                       "t": "else"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 1160,
                               "y": 280,
                               "wires": [
                                       "3e11e8338f694832"
                                       "bfce19b206660fbe"
                                       "a096a93bb82b7a93"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "top",
                                       "pt": "msg",
                                       "to": "top",
                                       "tot": "env"
                                       "t": "set",
                                       "p": "top",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2170,
                               "y": 320,
                               "wires": [
                                       "0962842ebd23e0d7"
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 170,
                               "y": 160,
                               "wires": [
                                       "e30ba9f0483285e4"
                                       "e023fe88445ce43e"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "change",
                                       "p": "topic",
                                       "pt": "msg",
                                       "from": "/",
                                       "fromt": "str",
                                       "to": ".",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 350,
                               "y": 120,
                               "wires": [
                                       "3649300b4c233b10"
                               "type": "change",
                               "rules": [
                                       "t": "change",
                                       "p": "topic",
                                       "pt": "msg",
                                       "from": "..",
                                       "fromt": "str",
                                       "to": ".",
                                       "tot": "str"
                                       "t": "change",
                                       "p": "topic",
                                       "pt": "msg",
                                       "from": "€",
                                       "fromt": "str",
                                       "to": "EUR",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2430,
                               "y": 280,
                               "wires": [
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 950,
                               "y": 200,
                               "wires": [
                                       "a096a93bb82b7a93"
                               "type": "json",
                               "name": "",
                               "action": "obj",
                               "pretty": false,
                               "x": 750,
                               "y": 100,
                               "wires": [
                                       "d9e7bdd4c48a8aa1"
                               "type": "switch",
                               "name": "is type?",
                               "rules": [
                                       "t": "istype",
                                       "v": "array",
                                       "vt": "array"
                                       "t": "istype",
                                       "v": "object",
                                       "vt": "object"
                                       "t": "else"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 900,
                               "y": 100,
                               "wires": [
                                       "1520be42bcc2145e"
                                       "1520be42bcc2145e"
                                       "9ac3cc3681e8b6c6"
                               "type": "junction",
                               "x": 1380,
                               "y": 280,
                               "wires": [
                                       "1a8c03d866b85b12"
                               "type": "junction",
                               "x": 480,
                               "y": 20,
                               "wires": [
                                       "3649300b4c233b10"
                               "name": "",
                               "env": [
                                       "name": "top",
                                       "type": "str"
                               "x": 550,
                               "y": 2960,
                               "wires": [
                                       "2b9df08b75d20726"
                               "name": "",
                               "topic": "",
                               "ack": "true",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "true",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 780,
                               "y": 2960,
                               "wires": []
                        1 Offline
                        1 Offline
                        1984chris
                        @mickym
                        Bin blutiger Anfänger in NodeRed und habe keine Programierkenntnisse,hab mir gedacht das geht so einfach.
                        • 1 1984chris
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @1984chris Geht dich auch einfach. Also Schritt für Schritt:
                          1. Hast Du die Einstellungen in der Adapterkonfiguration gemacht?
                          2. Weißt Du wie man einen Flow importiert?
                          • mickymM mickym
                            1 Offline
                            1 Offline
                            1984chris
                            @mickym
                            Ich habe noch kein iobrocker.
                            habe via Docker MQTT NODERED InfluxDB und GRAFANA laufen
                            • 1 1984chris
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @1984chris Ah OK - gut das ändert natürlich einiges. ;)
                              Gut kannst Du mal einen Screenshot von Deinem Flow machen und dann stelle bitte in deinen mqtt-Nodes ein, dass das Objekt komplett analysiert werden soll.
                              Dann solltest du nun in dem Debug Fenster keinen String sondern ein Objekt bekommen. Wenn Du das hast - dann mach da mal ein Screenshot von Deinem Debug Fenster.
                              Welche Influx DB Version nutzt Du denn?
                              • mickymM mickym
                                1 Offline
                                1 Offline
                                1984chris
                                @mickym
                                so?
                                • 1 1984chris
                                  @mickym
                                  so?
                                  1 Offline
                                  1 Offline
                                  1984chris
                                  @mickym
                                  influxDB1.8
                                  • 1 1984chris
                                    @mickym
                                    so?
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym
                                    so?
                                    Ja dann sollte auch das Objekt in der Debug Node anders aussehen, Wenn Du das so einstellst.
                                    • 1 1984chris
                                      @mickym
                                      influxDB1.8
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @mickym
                                      influxDB1.8
                                      Hast Du die neu installiert und warum die alte Version?
                                      • mickymM mickym
                                        @mickym
                                        so?
                                        1 Offline
                                        1 Offline
                                        1984chris
                                        @mickym
                                        aber das ist ja die Debug Node
                                        • 1 1984chris
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @1984chris Ja aber wenn Du in der mqtt- Node umgestellt hast, dann sollte das Objekt auch anders aussehen.
