  4. Yahka Adapter in iobroker im Docker Container
255 Beiträge 6 Kommentatoren 62.4k Aufrufe 5 Beobachtet
  • T Tomme
    root@iobroker:/opt/iobroker# pkill -u iobroker
    iob fix
    iob start
    iob diag
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        Installing prerequisites (1/5)
    Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
    Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
    Get:3 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
    Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
    Get:5 http://deb.debian.org/debian bullseye/main arm64 Packages [8.071 kB]
    Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
    Get:7 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages [235 kB]
    Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 Packages [12,0 kB]
    Fetched 8.531 kB in 12s (722 kB/s)
    Reading package lists... Done
    Installed gcc-c++
    Docker detected!
    If you have any adapters that need the CAP_NET_ADMIN capability,
    you need to start the docker container with the option --cap-add=NET_ADMIN
    and manually add that capability to node
        Checking ioBroker user and directory permissions (2/5)
    visudo: /etc/sudo.conf is world writable
    sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
    sudo: /usr/lib/sudo/sudoers.so must be only be writable by owner
    sudo: fatal error, unable to load plugins
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    main: line 12: [: -lt: unary operator expected
        Checking autostart (5/5)
    Unsupported init system, cannot enable autostart!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    diag kommt gleich ... nur die zusammenfassung oder auch das davor?
    Tomme
    #170
    root@iobroker:/opt/iobroker# iob start
    iob diag
    • GlasfaserG Offline
      GlasfaserG Offline
      #171
      @tomme sagte in Yahka Adapter in iobroker im Docker Container:
      Alles umsetzten auf Docker
      pkill -u iobroker
      iob fix
      Container neu starten über Portainer ..
      dann
      iob diag
      kein start und stop im Container !
      T 3 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        pkill -u iobroker
        iob fix
        dann
        iob diag
        Tomme
        #172
        @glasfaser aso
          pkill -u iobroker
          iob fix
          dann
          iob diag
          Tomme
          #173
          @glasfaser auch nach neustart container gleiche meldung (ohne iob start)
          ich versuche es in ner minute nochmal vielleicht war ich wieder zu schnell
            pkill -u iobroker
            iob fix
            dann
            iob diag
            Tomme
            #174
            @glasfaser
            root@iobroker:/opt/iobroker# iob diag
            root@iobroker:/opt/iobroker# iobroker diag
            • T Tomme
              iob diag
              GlasfaserG Offline
              GlasfaserG Offline
              #175
              @Thomas-Braun
              ich habe kein Plan , was mit seiner Pi los ist ...
              Kannst du vielleicht helfen !?
              T Thomas BraunT 2 Antworten Letzte Antwort
                @Thomas-Braun
                Tomme
                #176
                @glasfaser ist das jetzt auf dem lokalen rechner? neenee oder?
                • T Tomme
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #177
                  @tomme
                  Keine Ahnung warum im Docker soetwas kommt .
                  ich habe mal eine andere Frage ... warum überhaupt Docker auf der Pi !?
                  DJMarc75D T 2 Antworten Letzte Antwort
                    @tomme
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #178
                    @glasfaser
                    https://forum.iobroker.net/topic/65177/yahka-adapter-in-iobroker-im-docker-container/2
                    So hab ich im Beitrag gleich auch reagiert.
                    Lehrling seit 1975 !!!
                    • DJMarc75D DJMarc75
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #179
                      @djmarc75
                      ja... gerade auch gelesen ... wohl übersehn :)
                      • T Tomme
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #180
                        @tomme
                        Vorschlag , da ich wie gesagt nicht weiterkomme mit deinem Sudo Problem :
                        Installiere doch ioBroker normal auf der Pi
                        und dann Grafana über Docker ... geht doch auch
                          @tomme
                          Tomme
                          #181
                          @glasfaser
                          das ist vielleicht auch quatsch aber ...
                          bei meiner stand alone installation danke nochmal an @thomasBraun hatte ich den iobroker grafana influx homebridge und noch iwas drauf und lief auch eigentlich
                          dann wollte ich trenddaten von meinem loxone aufgehübscht mit grafana an meinen telegram account schicken ... ich weiß ist ne gute idee für n anfänger aber ich hatte zu dem zeitpunkt n paar daten in influx mitgeschrieben und wollte die halt zu telegram ... naja
                          auf jeden fall war dann ich glaube in grafana n plugin zu laden das sich auf dem raspi nicht laden ließ und in irgend einem forum ich weiß nicht mehr wo stand das das nur geht wenn man das über docker löst also grafana im docker
                          und da ich das hier gelernte ja auch in der kammer anwenden will war das mit dem docker eigentlich ne geile sache so dass die lehrlinge und meisterschüler nicht immer das gesamte system platt machen wenn bei einem teil was nicht geht und sie zu fummeln anfangen sondern halt nur einen container versauen der ja schnell mal neu gemacht ist ...
                          ich hab ja nur begrenzte zeit mit denen im unterricht da fand ich das gut und hab das neu gemacht mit docker halt
                            @Thomas-Braun
                            #182
                            @glasfaser
                            Um Docker-Installationen kümmer ich mich nicht. Grundsätzlich nicht.
                              @tomme
                              Tomme
                              #183
                              @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
                              ja das würde für mich privat natürlich auch gehen da hast du recht ist halt nur ein größerer aufwand wenn man den neu machen muss
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #184
                                @thomas-braun sagte in Yahka Adapter in iobroker im Docker Container:
                                es ging nicht um Docker ... etwas stimmt mit seiner Pi nicht !
                                • T Tomme
                                  Hi Marc
                                  ich habe mich für docker entschieden weil ich mit Grafana Trenddaten an Telegram schicken wollte und das unter raspi iwi nicht ging und wenn man bei dem Fehler nachgelesen hat funktioniert das mit raspi wohl nur über den Docker Umweg ...
                                  frag mich bitte jetzt nicht welches Plugin da rum gemeckert hat das weiß ich gerade nicht
                                  im prinzip finde ich das mit den Containern gar nicht so schlecht
                                  alles läuft voneinander unabhängig und wenn eins abschmiert machst halt nur eins neu das klang erstmal ganz gut
                                  die container source ist die aktuelle wenn ich iobroker/iobroker genommen habe hat er trotzdem die andere nachgeladen von daher weiß ich nicht was falsch dran ist
                                  und alle anderen adapter laufen ja gut und kriegen so weit ich das bisher geprüft habe auch daten von den anderen containern ...
                                  probleme macht wirklich nur yahka
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #185
                                  Habe ich auch ;)
                                    #186
                                    @glasfaser
                                    Ist das nicht jetzt ein Docker auf einem Pi?
                                    Warum auch immer man sowas machen will.
                                    Auf jeden Fall ist da an sudo herumgefummelt worden.
                                    sudo apt update
                                    sudo apt install --reinstall sudo
                                    könnte das evtl. wieder einrenken.
                                    Und eigentlich habe ich auch wenig Lust mich durch die permanente Kleinschreibung des TE zu kämpfen.
                                    GlasfaserG T 2 Antworten Letzte Antwort
                                      @glasfaser
                                      sudo apt update
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #187
                                      @glasfaser
                                      Ja .. aber so einen Fehler mit sudo habe ich noch nie gesehn .
                                        @glasfaser
                                        sudo apt update
                                        Tomme
                                        #188
                                        sudo apt update sudo apt install --reinstall sudo
                                        das habe ich jetzt auf dem raspi ausgeführt nicht im container
                                        pi@dockerpi:/opt $ htop
                                        pi@dockerpi:/opt $ sudo apt update
                                        Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                        OK:2 http://deb.debian.org/debian bullseye InRelease
                                        Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:5 https://download.docker.com/linux/debian bullseye InRelease
                                        Es wurden 92,4 kB in 1 s geholt (63,3 kB/s).
                                        Alle Pakete sind aktuell.
                                        0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Es müssen 996 kB an Archiven heruntergeladen werden.
                                        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                        Holen:1 http://deb.debian.org/debian bullseye/main arm64 sudo arm64 1.9.5p2-3+deb11u1 [996 kB]
                                        Es wurden 996 kB in 1 s geholt (1.072 kB/s).
                                        (Lese Datenbank ... 97962 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Vorbereitung zum Entpacken von .../sudo_1.9.5p2-3+deb11u1_arm64.deb ...
                                        Entpacken von sudo (1.9.5p2-3+deb11u1) über (1.9.5p2-3+deb11u1) ...
                                        sudo (1.9.5p2-3+deb11u1) wird eingerichtet ...
                                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                        pi@dockerpi:/opt $
                                        • T Tomme
                                          pi@dockerpi:/opt $
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #189
                                          ist auch richtig so !
