  4. Yahka Adapter in iobroker im Docker Container
255 Beiträge 6 Kommentatoren 62.4k Aufrufe 5 Beobachtet
  • T Tomme
    @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
    iob logs --watch
    ist der schon durch? im moment kommt das weiter nix mehr ... müsste da nicht auch drin stehen das der jetzt die adapter installiert?
    root@iobroker:/opt/iobroker# iob logs --watch
    2023-05-07 19:19:33.517  - info: host.iobroker iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-07 19:19:33.523  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-07 19:19:33.524  - info: host.iobroker hostname: iobroker, node: v18.16.0
    2023-05-07 19:19:33.525  - info: host.iobroker ip addresses: 192.168.7.39 2a01:598:b1ae:5fa:cda9:f7e8:4f52:b0ae fe80::d1ed:ac40:eb70:1818 172.17.0.1 fe80::42:ff:fea8:f9dc 169.254.109.96 fe80::dc28:b3ff:fe26:53e2 169.254.233.119 fe80::6111:bcc0:a1c7:a2b1 169.254.246.52 fe80::88ee:4aff:fed1:1f0e
    2023-05-07 19:19:33.950  - info: host.iobroker connected to Objects and States
    2023-05-07 19:19:33.980  - info: host.iobroker Node.js version has changed from unknown to 18.16.0
    2023-05-07 19:19:34.039  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
    sudo: /etc/sudo.conf is world writable
    sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
    2023-05-07 19:19:34.057  - info: host.iobroker added notifications configuration of host
    2023-05-07 19:19:34.349  - info: host.iobroker 3 instances found
    2023-05-07 19:19:34.360  - info: host.iobroker starting 3 instances
    2023-05-07 19:19:34.428  - info: host.iobroker instance system.adapter.admin.0 started with pid 1828
    2023-05-07 19:19:36.707  - info: admin.0 (1828) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:36.770  - info: admin.0 (1828) requesting all states
    2023-05-07 19:19:36.771  - info: admin.0 (1828) requesting all objects
    2023-05-07 19:19:36.948  - info: admin.0 (1828) received all objects
    2023-05-07 19:19:36.973  - info: admin.0 (1828) Request actual repository...
    2023-05-07 19:19:36.990  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-05-07 19:19:36.995  - info: admin.0 (1828) http server listening on port 8081
    2023-05-07 19:19:36.996  - info: admin.0 (1828) Use link "http://localhost:8081" to configure.
    2023-05-07 19:19:37.006  - info: admin.0 (1828) socket.io server listening on port 8081
    2023-05-07 19:19:37.166  - warn: admin.0 (1828) Repository cannot be read: Active repo - stable
    2023-05-07 19:19:37.169  - warn: admin.0 (1828) Active repository "stable" cannot be read
    2023-05-07 19:19:38.396  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1851
    2023-05-07 19:19:40.681  - info: discovery.0 (1851) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:42.860  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1870
    2023-05-07 19:19:42.944  - info: admin.0 (1828) Repository received successfully.
    2023-05-07 19:19:47.040  - info: backitup.0 (1870) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:47.154  - info: backitup.0 (1870) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-05-07 19:20:12.573  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:20:12.929  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:27:02.612  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:27:02.966  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:31:54.131  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:31:54.216  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:31:59.225  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:32:01.820  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:33:18.830  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:37:01.987  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
    da steht doch garnix davon drin das sind doch die logins von vor dem restore oder? 19:37 ...
    GlasfaserG Offline
    GlasfaserG Offline
    #155
    @tomme sagte in Yahka Adapter in iobroker im Docker Container:
    Da ist nichts passiert !
    Nimm mal zum Test einen anderen Browser ( dann Restore über Backitup ) , eventuell ein Popup Blocker !?
    T 2 Antworten Letzte Antwort
    • T Tomme
      @djmarc75 der ist ruhig läuft deutlich unter 10% CPU Last
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #156
      das meine ich nicht. Du kannst da auch sehen ob Adapter installiert werden. In Deinem Screenshot (Momentaufnahme) ist aber alles durch ;)
      Lehrling seit 1975 !!!
      • GlasfaserG Glasfaser
        Tomme
        #157
        nö das fenster war da hat auch die ersten zeilen gemacht und dann kam das was ich gepostet habe ... ich machs nochmal war gestern auch so ... dachte nur ich habs beeinflusst weil ich ziemlich schnell nachgeschaut hatte
          Tomme
          schrieb am zuletzt editiert von Tomme
          #158
          10218ebd-72db-44ae-8e0b-67d55adc82a0-image.png @glasfaser
          so sieht das zu anfang aus und dann kommt wieder die meldung
          htop sieht jetzt so aus
          ins log schaue ich gleich
          2023-05-07 20:04:36.654  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
          2023-05-07 20:04:38.839  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
          2023-05-07 20:04:41.241  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
          2023-05-07 20:04:44.688  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
          2023-05-07 20:04:48.298  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
          2023-05-07 20:05:12.805  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
          • T Tomme
            GlasfaserG Offline
            GlasfaserG Offline
            #159
            @tomme
            Eine allgemeine Frage von mir ... was ich niergens hier von dir erlese ..
            Hast du Buster oder bullseye
              @tomme
              Tomme
              #160
              @glasfaser das neueste bullseye von vorgestern das image das neue
              • T Tomme
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #161
                zeig mal
                iob diag
                bitte aber in Codetags ;)
                • DJMarc75D DJMarc75
                  zeig mal
                  iob diag
                  Tomme
                  #162
                  @djmarc75
                  root@iobroker:/opt/iobroker# iob diag
                  sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
                  sudo: /usr/lib/sudo/sudoers.so must be only be writable by owner
                  sudo: fatal error, unable to load plugins
                  • T Tomme
                    @djmarc75
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #163
                    @tomme Docker kenn ich mich nicht aus - ob da root sinnvoll ist - kein Plan... aber teste mal
                    iob stop
                    iob fix
                    iob start
                    iob diag
                    T GlasfaserG 2 Antworten Letzte Antwort
                      iob stop
                      iob fix
                      iob start
                      iob diag
                      Tomme
                      #164
                      @djmarc75 iob stop geht nicht da nehme ich das pkill ja
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        #165
                        richtig ... setze es um auf Docker !
                          iob stop
                          iob fix
                          iob start
                          iob diag
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #166
                          @djmarc75 sagte in Yahka Adapter in iobroker im Docker Container:
                          Ist kein root im Sinne .. (Docker)
                          ich habe keine Ahnung was bei Ihm los ist ... ist von anfang an der Fehler mit sudo .
                            Tomme
                            #167
                            @glasfaser wenn ich in portainer ein terminal öffne ist das root bei mir
                            • T Tomme
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #168
                              Alles gut !
                                Alles gut !
                                Tomme
                                #169
                                root@iobroker:/opt/iobroker# pkill -u iobroker
                                iob fix
                                iob start
                                iob diag
                                library: loaded
                                Library version=2022-12-09
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2023-04-02
                                    Installing prerequisites (1/5)
                                Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
                                Get:3 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                Get:5 http://deb.debian.org/debian bullseye/main arm64 Packages [8.071 kB]
                                Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
                                Get:7 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages [235 kB]
                                Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 Packages [12,0 kB]
                                Fetched 8.531 kB in 12s (722 kB/s)
                                Reading package lists... Done
                                Installed gcc-c++
                                Docker detected!
                                If you have any adapters that need the CAP_NET_ADMIN capability,
                                you need to start the docker container with the option --cap-add=NET_ADMIN
                                and manually add that capability to node
                                    Checking ioBroker user and directory permissions (2/5)
                                visudo: /etc/sudo.conf is world writable
                                    Check and cleanup npm temporary directories (3/5)
                                Done.
                                    Database maintenance (4/5)
                                Checking for uncompressed JSONL databases... This might take a while!
                                main: line 12: [: -lt: unary operator expected
                                    Checking autostart (5/5)
                                Unsupported init system, cannot enable autostart!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                diag kommt gleich ... nur die zusammenfassung oder auch das davor?
                                • T Tomme
                                  iob fix
                                  iob start
                                  iob diag
                                  library: loaded
                                  Installed gcc-c++
                                  Docker detected!
                                  Done.
                                  Tomme
                                  #170
                                  root@iobroker:/opt/iobroker# iob start
                                  iob diag
                                    GlasfaserG Offline
                                    #171
                                    Alles umsetzten auf Docker
                                    pkill -u iobroker
                                    iob fix
                                    Container neu starten über Portainer ..
                                    dann
                                    iob diag
                                    kein start und stop im Container !
                                    T 3 Antworten Letzte Antwort
                                      pkill -u iobroker
                                      iob fix
                                      dann
                                      iob diag
                                      Tomme
                                      #172
                                      @glasfaser aso
                                        pkill -u iobroker
                                        iob fix
                                        dann
                                        iob diag
                                        Tomme
                                        #173
                                        @glasfaser auch nach neustart container gleiche meldung (ohne iob start)
                                        ich versuche es in ner minute nochmal vielleicht war ich wieder zu schnell
                                          pkill -u iobroker
                                          iob fix
                                          dann
                                          iob diag
                                          Tomme
                                          #174
                                          @glasfaser
                                          root@iobroker:/opt/iobroker# iobroker diag
