  4. Yahka Adapter in iobroker im Docker Container
255 Beiträge 6 Kommentatoren 62.4k Aufrufe 5 Beobachtet
  • T Tomme
    @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
    iob logs --watch
    ist der schon durch? im moment kommt das weiter nix mehr ... müsste da nicht auch drin stehen das der jetzt die adapter installiert?
    root@iobroker:/opt/iobroker# iob logs --watch
    2023-05-07 19:19:33.517  - info: host.iobroker iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-07 19:19:33.523  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-07 19:19:33.524  - info: host.iobroker hostname: iobroker, node: v18.16.0
    2023-05-07 19:19:33.525  - info: host.iobroker ip addresses: 192.168.7.39 2a01:598:b1ae:5fa:cda9:f7e8:4f52:b0ae fe80::d1ed:ac40:eb70:1818 172.17.0.1 fe80::42:ff:fea8:f9dc 169.254.109.96 fe80::dc28:b3ff:fe26:53e2 169.254.233.119 fe80::6111:bcc0:a1c7:a2b1 169.254.246.52 fe80::88ee:4aff:fed1:1f0e
    2023-05-07 19:19:33.950  - info: host.iobroker connected to Objects and States
    2023-05-07 19:19:33.980  - info: host.iobroker Node.js version has changed from unknown to 18.16.0
    2023-05-07 19:19:34.039  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
    sudo: /etc/sudo.conf is world writable
    sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
    2023-05-07 19:19:34.057  - info: host.iobroker added notifications configuration of host
    2023-05-07 19:19:34.349  - info: host.iobroker 3 instances found
    2023-05-07 19:19:34.360  - info: host.iobroker starting 3 instances
    2023-05-07 19:19:34.428  - info: host.iobroker instance system.adapter.admin.0 started with pid 1828
    2023-05-07 19:19:36.707  - info: admin.0 (1828) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:36.770  - info: admin.0 (1828) requesting all states
    2023-05-07 19:19:36.771  - info: admin.0 (1828) requesting all objects
    2023-05-07 19:19:36.948  - info: admin.0 (1828) received all objects
    2023-05-07 19:19:36.973  - info: admin.0 (1828) Request actual repository...
    2023-05-07 19:19:36.990  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-05-07 19:19:36.995  - info: admin.0 (1828) http server listening on port 8081
    2023-05-07 19:19:36.996  - info: admin.0 (1828) Use link "http://localhost:8081" to configure.
    2023-05-07 19:19:37.006  - info: admin.0 (1828) socket.io server listening on port 8081
    2023-05-07 19:19:37.166  - warn: admin.0 (1828) Repository cannot be read: Active repo - stable
    2023-05-07 19:19:37.169  - warn: admin.0 (1828) Active repository "stable" cannot be read
    2023-05-07 19:19:38.396  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1851
    2023-05-07 19:19:40.681  - info: discovery.0 (1851) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:42.860  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1870
    2023-05-07 19:19:42.944  - info: admin.0 (1828) Repository received successfully.
    2023-05-07 19:19:47.040  - info: backitup.0 (1870) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 19:19:47.154  - info: backitup.0 (1870) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-05-07 19:20:12.573  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:20:12.929  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:27:02.612  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:27:02.966  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:31:54.131  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:31:54.216  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:31:59.225  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
    2023-05-07 19:32:01.820  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:33:18.830  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
    2023-05-07 19:37:01.987  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
    da steht doch garnix davon drin das sind doch die logins von vor dem restore oder? 19:37 ...
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #153
    @tomme schau mal unter
    htop
    nach
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      htop
      nach
      Tomme
      #154
      @djmarc75 der ist ruhig läuft deutlich unter 10% CPU Last
      • T Tomme
        iob logs --watch
        GlasfaserG Offline
        GlasfaserG Offline
        #155
        @tomme sagte in Yahka Adapter in iobroker im Docker Container:
        Da ist nichts passiert !
        Nimm mal zum Test einen anderen Browser ( dann Restore über Backitup ) , eventuell ein Popup Blocker !?
        T 2 Antworten Letzte Antwort
        • T Tomme
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #156
          das meine ich nicht. Du kannst da auch sehen ob Adapter installiert werden. In Deinem Screenshot (Momentaufnahme) ist aber alles durch ;)
          • GlasfaserG Glasfaser
            Tomme
            #157
            nö das fenster war da hat auch die ersten zeilen gemacht und dann kam das was ich gepostet habe ... ich machs nochmal war gestern auch so ... dachte nur ich habs beeinflusst weil ich ziemlich schnell nachgeschaut hatte
              Tomme
              schrieb am zuletzt editiert von Tomme
              #158
              10218ebd-72db-44ae-8e0b-67d55adc82a0-image.png @glasfaser
              so sieht das zu anfang aus und dann kommt wieder die meldung
              htop sieht jetzt so aus
              ins log schaue ich gleich
              2023-05-07 20:04:36.654  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1 admin
              2023-05-07 20:04:38.839  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
              2023-05-07 20:04:41.241  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
              2023-05-07 20:04:44.688  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
              2023-05-07 20:04:48.298  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.7.1
              2023-05-07 20:05:12.805  - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.7.1
              • T Tomme
                GlasfaserG Offline
                GlasfaserG Offline
                #159
                @tomme
                Eine allgemeine Frage von mir ... was ich niergens hier von dir erlese ..
                Hast du Buster oder bullseye
                  @tomme
                  Tomme
                  #160
                  @glasfaser das neueste bullseye von vorgestern das image das neue
                  • T Tomme
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #161
                    zeig mal
                    iob diag
                    bitte aber in Codetags ;)
                      zeig mal
                      iob diag
                      Tomme
                      #162
                      @djmarc75
                      root@iobroker:/opt/iobroker# iob diag
                      sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
                      sudo: /usr/lib/sudo/sudoers.so must be only be writable by owner
                      sudo: fatal error, unable to load plugins
                      • T Tomme
                        @djmarc75
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #163
                        @tomme Docker kenn ich mich nicht aus - ob da root sinnvoll ist - kein Plan... aber teste mal
                        iob stop
                        iob fix
                        iob start
                        iob diag
                        T GlasfaserG 2 Antworten Letzte Antwort
                          iob stop
                          iob fix
                          iob start
                          iob diag
                          Tomme
                          #164
                          @djmarc75 iob stop geht nicht da nehme ich das pkill ja
                          • GlasfaserG Offline
                            GlasfaserG Offline
                            #165
                            richtig ... setze es um auf Docker !
                              iob stop
                              iob fix
                              iob start
                              iob diag
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #166
                              @djmarc75 sagte in Yahka Adapter in iobroker im Docker Container:
                              Ist kein root im Sinne .. (Docker)
                              ich habe keine Ahnung was bei Ihm los ist ... ist von anfang an der Fehler mit sudo .
                                Tomme
                                #167
                                @glasfaser wenn ich in portainer ein terminal öffne ist das root bei mir
                                • T Tomme
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #168
                                  Alles gut !
                                    Alles gut !
                                    Tomme
                                    #169
                                    root@iobroker:/opt/iobroker# pkill -u iobroker
                                    iob fix
                                    iob start
                                    iob diag
                                    library: loaded
                                    Library version=2022-12-09
                                        Welcome to the ioBroker installation fixer!
                                        Script version: 2023-04-02
                                        Installing prerequisites (1/5)
                                    Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                    Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
                                    Get:3 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                    Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                    Get:5 http://deb.debian.org/debian bullseye/main arm64 Packages [8.071 kB]
                                    Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
                                    Get:7 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages [235 kB]
                                    Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 Packages [12,0 kB]
                                    Fetched 8.531 kB in 12s (722 kB/s)
                                    Reading package lists... Done
                                    Installed gcc-c++
                                    Docker detected!
                                    If you have any adapters that need the CAP_NET_ADMIN capability,
                                    you need to start the docker container with the option --cap-add=NET_ADMIN
                                    and manually add that capability to node
                                        Checking ioBroker user and directory permissions (2/5)
                                    visudo: /etc/sudo.conf is world writable
                                        Check and cleanup npm temporary directories (3/5)
                                    Done.
                                        Database maintenance (4/5)
                                    Checking for uncompressed JSONL databases... This might take a while!
                                    main: line 12: [: -lt: unary operator expected
                                        Checking autostart (5/5)
                                    Unsupported init system, cannot enable autostart!
                                        Your installation was fixed successfully
                                        Run iobroker start to start ioBroker again!
                                    diag kommt gleich ... nur die zusammenfassung oder auch das davor?
                                    • T Tomme
                                      iob fix
                                      iob start
                                      iob diag
                                      library: loaded
                                      Installed gcc-c++
                                      Docker detected!
                                      Done.
                                      Tomme
                                      #170
                                      root@iobroker:/opt/iobroker# iob start
                                      iob diag
                                        GlasfaserG Offline
                                        #171
                                        Alles umsetzten auf Docker
                                        pkill -u iobroker
                                        iob fix
                                        Container neu starten über Portainer ..
                                        dann
                                        iob diag
                                        kein start und stop im Container !
                                        T 3 Antworten Letzte Antwort
                                          pkill -u iobroker
                                          iob fix
                                          dann
                                          iob diag
                                          Tomme
                                          #172
                                          @glasfaser aso
