  4. Wunsch: Adapter für Panasonic Viera Smart TV Steuerung
180 Beiträge 49 Kommentatoren 50.2k Aufrufe 18 Beobachtet
    matche
    Servus ldittmar,
    habe ich getestet, siehe unten
    ! panasonic-viera.0 2017-09-18 21:46:59.464 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v6.11.3
    ! host.HM-Wir 2017-09-18 21:46:57.661 info instance system.adapter.panasonic-viera.0 started with pid 31197
    ! host.HM-Wir 2017-09-18 21:46:27.606 info Restart adapter system.adapter.panasonic-viera.0 because enabled
    ! host.HM-Wir 2017-09-18 21:46:27.604 error instance system.adapter.panasonic-viera.0 terminated with code 0 (OK)
    ! panasonic-viera.0 2017-09-18 21:46:27.526 info cleaned everything up…
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.emit (events.js:169:7)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at emitOne (events.js:77:13)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.socketOnData (_http_client.js:322:20)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.emit (events.js:169:7)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.g (events.js:260:16)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.addListener (events.js:197:11)
    ! panasonic-viera.0 2017-09-18 21:46:27.521 error TypeError: listener must be a function
    ! panasonic-viera.0 2017-09-18 21:46:27.510 error uncaught exception: listener must be a function
    Mario
    • BluefoxB Offline
      BluefoxB Offline
      Ich habe auch versucht zu analysieren und sehe immer noch das Problem nicht. :(
      • ldittmarL Offline
        ldittmarL Offline
        ldittmar
        Soo… eine neue Version steht zum Testen bereit. Ich hoffe die Abstürze sind jetzt weg ;)
        Grüße,
        ldittmar
          matche
          Servus ldittmar,
          jetzt funktionierts enwandfrei…
          Teste die Tage noch aller Befehle durch...
          Frage:
          ist es auch möglich sich Infos anzeigen zu lassen:
          Ist der Fernseher eingeschaltet?
          Welcher Eingang ist gewählt?
          usw.?
          Danke für Deine tolle Arbeit
          Mario
          • ldittmarL Offline
            ldittmarL Offline
            ldittmar
            @matche:
            Teste die Tage noch aller Befehle durch... `
            Hi Mario,
            freut mich! Ich werde noch die einzelnen Tasten ein bisschen gruppieren, damit nicht so viele Funktionen auf einem Schlag auftauchen.
            @matche:
            Ist der Fernseher eingeschaltet? `
            das geht jetzt schon… unter info.connection
            @matche:
            usw.? `
            Leider ist mir kein Weg bekannt. Ich bekomme nur die aktuelle Lautstärke raus.. Sorry
            Grüße,
            ldittmar
            • BluefoxB Offline
              BluefoxB Offline
              @Lditmar hast du schon an discovery gedacht?
              Das soll super einfach gehen. Einfach https://github.com/ioBroker/ioBroker.di … ers/hue.js kopieren und anpassen.
              • ldittmarL Offline
                ldittmarL Offline
                ldittmar
                Natürlich habe ich schon an Discovery gedacht. Hab ja schon den Worx und Fronius Adapter hinzugefügt. Jetzt kommen Panasonic und Sony 8-)
                Grüße,
                ldittmar
                • ldittmarL Offline
                  ldittmarL Offline
                  ldittmar
                  Die neue Version 0.0.6 ist jetzt online und kann getestet werden. Bitte um Feedback.
                  https://github.com/ldittmar81/ioBroker.panasonic-viera
                  Grüße,
                  ldittmar
                  • O Offline
                    O Offline
                    onkeltom9
                    hallo
                    Adapter funktioniert
                    starten des TV geht über wake on lan
                    mein TV TX50EXW
                    tolle Arbeit
                    gruß
                      Bobohne
                      Hallo!
                      Kann den Adapter zwar installieren, er erscheint dann aber nicht unter Instanzen. Somit kann ich ihn auch nicht konfigurieren. Mach ich was falsch?
                      LG
                      Michael
                      • HomoranH Offline
                        HomoranH Offline
                        @Bobohne:
                        Kann den Adapter zwar installieren `
                        gut!
                        @Bobohne:
                        er erscheint dann aber nicht unter Instanzen `
                        ist üblicherweise immer so ;.)
                        hast du denn versucht eine Instanz anzulegen?
                        http://www.iobroker.net/docu/?page_id=1 … _Instanzen
                          Bobohne
                          @Homoran:
                          @Bobohne:
                          gut!
                          @Bobohne:
                          Rainer `
                          Jetzt funktionierts! Danke! :D
                          Wie peinlich :oops:
                          Mal eine Frage. Ist es möglich mit dem Adapter eine Nachricht auf dem TV einblenden zu lassen? Gibt die API das her?
                          LG
                          Michael
                          • ldittmarL Offline
                            ldittmarL Offline
                            ldittmar
                            @Bobohne:
                            LG
                            Michael `
                            Hi Michael,
                            leider nicht und da ich kein Panasonic TV besitze, wird auch schwierig neue Funktionen einzubauen. Wenn es aber eine Anleitung dazu gibt, baue ich es gerne ein ;-)
                            Grüße,
                            ldittmar
                              schittl
                              Danke, der Adapter funktioniert. Sehr gute Arbeit. Mein TV ist ein TX-P50GT50E. Das Einschalten funktioniert leider nicht. Ist aber kein Adapter-Problem sondern API-Problem. Ich habe gelesen, dass über WOL der TV eingeschaltet werden kann? Kann mir jemand sagen wie im Detail? @onkeltom9
                              Derzeit nutze ich noch den Broadlink-Adapter, denn damit geht sogar das Einschalten zuverlässig :D
                              HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
                              SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
                              • ldittmarL Offline
                                ldittmarL Offline
                                ldittmar
                                @schittl:
                                Derzeit nutze ich noch den Broadlink-Adapter, denn damit geht sogar das Einschalten zuverlässig :D `
                                habe ich gern gemacht… Ich schaue mal ob ich was mit der Einschaltfunktion machen kann. Wird zwar ohne Gerät eher so eine Ratestunde werden, aber das kriegen wir bestimmt hin. ;)
                                Grüße,
                                ldttmar
                                  schittl
                                  Das wäre prima. Würde mich natürlich dann auch zum testen anbieten ;) Ich habe aber leider schon davon gelesen, dass dieses nicht möglich ist. War glaube ich bei fhem bzw. openhab. Das liegt wohl direkt an dem Typ, da man beim Einschalten den Power-Knopf länger halten muss, damit er startet. Wie bereits berichtet, nutze ich Broadlink fürs Einschalten. Damit funktioniert der "längere" Tastendruck. Also schlag Dir nicht deswegen soviel Stunden um die Ohren ;) Finde ich aber echt klasse dein Engagement. TOP!!
                                  Hast Du oder gibt es vielleicht auch schon ne schöne VIS-Ansicht/Steuerung?
                                  mfg
                                  Falk
                                    TimoS.
                                    Vielen Dank, funktioniert bisher einwandfrei. Genau danach habe ich gesucht.
                                    • W Offline
                                      W Offline
                                      wuchti
                                      Ich bin auch neu hier und möchte die Programme meines Panasonic Fernsehers über Alexa aufrufen.
                                      Ich habe die Programme umbenannt (D1 = ARD, D2=ZDF, etc..).
                                      Was muss ich machen, damit die Befehle im Cloud Adapter erscheinen, so dass ich sie über Alexa aufrufen kann?
                                      Der Cloud Adapter ist soweit konfiguriert meine Homematic Aktoren kann ich über steuern.
                                      Danke und Gruß Markus
                                        Schnutexxl
                                        Hallo Idittmar,
                                        auch von mir besten Dank für den tollen Adapter!!! :D
                                        Aber ein kleines Problem scheint es hier zu geben. Das Ein- bzw. Ausschalten funktioniert bei meinem Panasonic über den selben Befehl und nicht über WakeOnLAN, wie bei manch anderen. Somit ist meine LAN Verbindung zum TV immer vorhanden, auch wenn der TV aus ist. Fazit, ich habe keinen korrekten Datenpunkt über den wirklichen Status des TV –> immer an obwohl aus. Ich glaube du hast im Script für den Connection Datenpunkt eine Ping Abfrage genutzt und kein Request from TV.
                                        Somit kommen zusätzlich auch fehlerhafte Abfragen, getVolume, getMute, zustande, wenn der TV aus ist.
                                        Kann man das irgendwie noch einbauen, dass es einen Datenpunkt für den wirklichen Status des TV gibt?
                                        Sollte es dafür keinen Befehl geben, könnte man die zyklische Abfrage von "Mute" oder "Volume" für einen "wirklichen" Status des TV zu nutze machen.
                                        Mit bestem Dank im Voraus und Grüße
                                        • ldittmarL Offline
                                          ldittmarL Offline
                                          ldittmar
                                          Hi Coronaxxl,
                                          mein größtes Problem bei der Sache ist, dass gar kein Panasonic habe. Ich habe den Adapter einfach so blind programmiert. Bei den Fehler könnte ich es vielleicht abfangen und kein Logeintrag senden… bzw... hmm ... Wenn ich keine Daten bekomme, ist dann das Fernsehr aus, oder? Mindestens meistens... (bei Netzwerkfehler auch).
                                          Würde es euch helfen, wenn ich einfach behaupten würde, dass das Fernsehr aus ist, wenn keine Daten kommen?
                                          Grüße,
                                          ldittmar
