  4. Wunsch: Adapter für Panasonic Viera Smart TV Steuerung
180 Beiträge 49 Kommentatoren 50.2k Aufrufe 18 Beobachtet
  • BluefoxB Offline
    BluefoxB Offline
    @uweklatt:
    es gibt bereits eine Lib, die unter ioBroker mit Javascript genutzt werden kann.
    Quelle: https://github.com/samuelmatis/viera.js
    Dazu muss die Lib auf der Kommandozeile installiert werden:
    Ins Verzeichnis /opt/iobroker/node_modules/iobroker.javascript wechseln und viera.js installieren:````
    cd /opt/iobroker/node_modules/iobroker.javascript
    npm install viera.js
    Ein einfaches Beispiel als Javascript:
    var Viera = require('viera.js');
    var tv = new Viera('IP-ADRESSE-TV');
    tv.sendCommand("menu");
    >! CH_DOWN - channel down
    >! CH_UP - channel up
    >! VOLUP - volume up
    >! VOLDOWN - volume down
    >! POWER - Power off
    >! MUTE - mute
    >! TV - TV
    >! CHG_INPUT - AV
    >! HOME - Home screen
    >! APPS - Apps
    >! GUIDE - Guide
    >! RED - red
    >! GREEN - green
    >! YELLOW - yellow
    >! BLUE - blue
    >! VTOOLS - VIERA tools
    >! CANCEL - Cancel / Exit
    >! SUBMENU - Option
    >! RETURN - Return
    >! ENTER - Control Center click / enter
    >! RIGHT - Control RIGHT
    >! LEFT - Control LEFT
    >! UP - Control UP
    >! DOWN - Control DOWN
    >! 3D - 3D button
    >! SD_CARD - SD-card
    >! DISP_MODE - Display mode / Aspect ratio
    >! MENU - Menu
    >! INTERNET - VIERA connect
    >! VIERA_LINK - VIERA link
    >! EPG - Guide / EPG
    >! TEXT - Text / TTV
    >! STTL - STTL / Subtitles
    >! INFO - info
    >! INDEX - TTV index
    >! HOLD - TTV hold / image freeze
    >! R_TUNE - Last view
    >! REW - rewind
    >! PLAY - play
    >! FF - fast forward
    >! SKIP_PREV - skip previous
    >! PAUSE - pause
    >! SKIP_NEXT - skip next
    >! STOP - stop
    >! REC - record
    >! numeric buttons
    >! D1 D2 D3 D4 D5 D6 D7 D8 D9 D0
    >! P_NR - P-NR (Noise reduction)
    >! OFFTIMER - off timer
    >! R_TUNE - Seems to do the same as INFO
    >! others (depends on type of your TV)
    >! CHG_NETWORK
    >! CC
    >! SAP
    >! RECLIST
    >! DRIVE
    >! DATA
    >! BD
    >! FAVORITE
    >! DIGA_CTL
    >! VOD
    >! ECO
    >! GAME
    >! EZ_SYNC
    >! PICTAI
    >! MPX
    >! SPLIT
    >! SWAP
    >! R_SCREEN
    >! 30S_SKIP
    >! PROG
    >! TV_MUTE_ON
    >! TV_MUTE_OFF
    >! DMS_CH_UP
    >! DMS_CH_DOWN
    Tschau
    Uwe `
    geht das?
    • uweklattU Offline
      uweklattU Offline
      uweklatt
      Hallo Bluefox,@Bluefox:
      geht das? ` was soll daran nicht "gehen"?
      Bei mir funktioniert es.
      Leider kann ich meinen TV auch nicht aus dem Standby einschalten, aber das liegt am Modell.
      Vermutlich muss man die Lib nicht so wie ich es geschrieben habe installieren, sondern nur als zusätzliche Lib im Adapter eintragen.
      Tschau
      Uwe
      Intel i5/Proxmox/LXC/Docker/ioBroker
      • ldittmarL Offline
        ldittmarL Offline
        ldittmar
        Hallo Community,
        ich habe mal den Wunsch umgesetzt und ein Adapter für den Panasonic Smart-TV geschrieben. Leider habe ich kein Panasonic TV. Kann es jemand testen bevor es auf ioBroker zur Verfügung gestellt werden kann? https://github.com/ldittmar81/ioBroker.panasonic-viera
        Danke!
        Grüße,
        ldittmar
          Bongo
          Danke für die Umsetzung.
          Bei mir tut sich aber nichts. Nur connected stimmt.
          Mein Fernseher ist aber nicht ganz aktuell: TX-P46VT20E
          Bongo
          Script - Die sprechende Kaffeemaschine – Home Connect
          Script - JUDO Wasserenthärtung - Connectivity-Modul API
            Bobohne
            Hallo!
            Ich werde es im Laufe der nächsten Woche testen. Ist ein TX-P60ZT60E…
            • ldittmarL Offline
              ldittmarL Offline
              ldittmar
              Also… im FB hat einer geschrieben, dass der Adapter laufen würde. Wäre cool noch ein paar Tests zu haben, bevor ich den Adapter veröffentliche.
              Grüße,
              ldittmar
                matche
                Hallo ldittmar,
                Danke im Vorraus für Deinen Adapter, hat mich sehr gefreut…
                Ich habe einen TX-50DX780.. also relativ Neu...
                Ich habe mal versucht alle Befehle zu testen...
                Leider stürzte der Adapter nach jedem Tastendruck ab...
                ! panasonic-viera.0 2017-09-18 14:10:45.161 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
                ! panasonic-viera.0 2017-09-18 14:10:13.628 info cleaned everything up…
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at emitOne (events.js:77:13)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at Socket.socketOnData (_http_client.js:322:20)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest.emit (events.js:169:7)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest.g (events.js:260:16)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error at IncomingMessage.addListener (events.js:197:11)
                ! panasonic-viera.0 2017-09-18 14:10:13.624 error TypeError: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:10:13.615 error uncaught exception: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:10:05.666 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
                ! panasonic-viera.0 2017-09-18 14:09:34.025 info cleaned everything up…
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at emitOne (events.js:77:13)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at Socket.socketOnData (_http_client.js:322:20)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest.emit (events.js:169:7)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest.g (events.js:260:16)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error at IncomingMessage.addListener (events.js:197:11)
                ! panasonic-viera.0 2017-09-18 14:09:34.022 error TypeError: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:09:34.017 error uncaught exception: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:07:09.350 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
                ! panasonic-viera.0 2017-09-18 14:06:37.737 info cleaned everything up…
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at emitOne (events.js:77:13)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at Socket.socketOnData (_http_client.js:322:20)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest.emit (events.js:169:7)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest.g (events.js:260:16)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error at IncomingMessage.addListener (events.js:197:11)
                ! panasonic-viera.0 2017-09-18 14:06:37.733 error TypeError: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:06:37.724 error uncaught exception: listener must be a function
                ! panasonic-viera.0 2017-09-18 14:06:33.236 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
                Folgende Tastencodes funktionieren….
                ! VOLUP - volume up
                ! POWER - Power off
                ! MUTE - mute
                ! TV - TV
                ! CHG_INPUT - AV
                ! APPS - Apps
                ! GUIDE - Guide
                ! RED - red
                ! GREEN - green
                ! YELLOW - yellow
                ! BLUE – blue
                ! RETURN - Return
                ! UP - Control UP
                ! MENU - Menu
                ! EPG - Guide / EPG
                ! numeric buttons
                ! FAVORITE
                ! DMS_CH_UP
                ! DMS_CH_DOWN
                Die restlichen Tasten teste ich noch, aber durch die Abstürze ist das sehr mühsam….
                Ich hoffe ich konnt Dir ein wenig helfen...
                Mario
                • ldittmarL Offline
                  ldittmarL Offline
                  ldittmar
                  Hi Mario,
                  vielen Dank für die Tests. Ich glaube deine Abstürze daran liegen, dass du Node.js 4.x nutzt. Scheinbar wurde die benutzte Bibliothek für Node ab 6 geschrieben. :(
                  Ich schaue mal nach…
                  Grüße,
                  ldittmar
                    matche
                    Servus ldittmar,
                    habe ich getestet, siehe unten
                    ! panasonic-viera.0 2017-09-18 21:46:59.464 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v6.11.3
                    ! host.HM-Wir 2017-09-18 21:46:57.661 info instance system.adapter.panasonic-viera.0 started with pid 31197
                    ! host.HM-Wir 2017-09-18 21:46:27.606 info Restart adapter system.adapter.panasonic-viera.0 because enabled
                    ! host.HM-Wir 2017-09-18 21:46:27.604 error instance system.adapter.panasonic-viera.0 terminated with code 0 (OK)
                    ! panasonic-viera.0 2017-09-18 21:46:27.526 info cleaned everything up…
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.emit (events.js:169:7)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at emitOne (events.js:77:13)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.socketOnData (_http_client.js:322:20)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.emit (events.js:169:7)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.g (events.js:260:16)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.addListener (events.js:197:11)
                    ! panasonic-viera.0 2017-09-18 21:46:27.521 error TypeError: listener must be a function
                    ! panasonic-viera.0 2017-09-18 21:46:27.510 error uncaught exception: listener must be a function
                    Mario
                    • BluefoxB Offline
                      BluefoxB Offline
                      Ich habe auch versucht zu analysieren und sehe immer noch das Problem nicht. :(
                      • ldittmarL Offline
                        ldittmarL Offline
                        ldittmar
                        Soo… eine neue Version steht zum Testen bereit. Ich hoffe die Abstürze sind jetzt weg ;)
                        Grüße,
                        ldittmar
                          matche
                          Servus ldittmar,
                          jetzt funktionierts enwandfrei…
                          Teste die Tage noch aller Befehle durch...
                          Frage:
                          ist es auch möglich sich Infos anzeigen zu lassen:
                          Ist der Fernseher eingeschaltet?
                          Welcher Eingang ist gewählt?
                          usw.?
                          Danke für Deine tolle Arbeit
                          Mario
                          • ldittmarL Offline
                            ldittmarL Offline
                            ldittmar
                            @matche:
                            Teste die Tage noch aller Befehle durch... `
                            Hi Mario,
                            freut mich! Ich werde noch die einzelnen Tasten ein bisschen gruppieren, damit nicht so viele Funktionen auf einem Schlag auftauchen.
                            @matche:
                            Ist der Fernseher eingeschaltet? `
                            das geht jetzt schon… unter info.connection
                            @matche:
                            usw.? `
                            Leider ist mir kein Weg bekannt. Ich bekomme nur die aktuelle Lautstärke raus.. Sorry
                            Grüße,
                            ldittmar
                            • BluefoxB Offline
                              BluefoxB Offline
                              @Lditmar hast du schon an discovery gedacht?
                              Das soll super einfach gehen. Einfach https://github.com/ioBroker/ioBroker.di … ers/hue.js kopieren und anpassen.
                              • ldittmarL Offline
                                ldittmarL Offline
                                ldittmar
                                Natürlich habe ich schon an Discovery gedacht. Hab ja schon den Worx und Fronius Adapter hinzugefügt. Jetzt kommen Panasonic und Sony 8-)
                                Grüße,
                                ldittmar
                                • ldittmarL Offline
                                  ldittmarL Offline
                                  ldittmar
                                  Die neue Version 0.0.6 ist jetzt online und kann getestet werden. Bitte um Feedback.
                                  Grüße,
                                  ldittmar
                                  • O Offline
                                    O Offline
                                    onkeltom9
                                    hallo
                                    Adapter funktioniert
                                    starten des TV geht über wake on lan
                                    mein TV TX50EXW
                                    tolle Arbeit
                                    gruß
                                      Bobohne
                                      Hallo!
                                      Kann den Adapter zwar installieren, er erscheint dann aber nicht unter Instanzen. Somit kann ich ihn auch nicht konfigurieren. Mach ich was falsch?
                                      LG
                                      Michael
                                      • HomoranH Offline
                                        HomoranH Offline
                                        @Bobohne:
                                        Kann den Adapter zwar installieren `
                                        gut!
                                        @Bobohne:
                                        er erscheint dann aber nicht unter Instanzen `
                                        ist üblicherweise immer so ;.)
                                        hast du denn versucht eine Instanz anzulegen?
                                        http://www.iobroker.net/docu/?page_id=1 … _Instanzen
                                          Bobohne
                                          @Homoran:
                                          @Bobohne:
                                          gut!
                                          @Bobohne:
                                          Rainer `
                                          Jetzt funktionierts! Danke! :D
                                          Wie peinlich :oops:
                                          Mal eine Frage. Ist es möglich mit dem Adapter eine Nachricht auf dem TV einblenden zu lassen? Gibt die API das her?
                                          LG
                                          Michael
