  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.7k
1.2k Beiträge 100 Kommentatoren 505.2k Aufrufe 82 Beobachtet
  • Damrak2022D Damrak2022
    @bahnuhr Irgendwas stimmt hier noch nicht:
    Zuerst die Fehlermeldung im Log:
    host.homebridge
    2023-04-16 08:31:32.738	error	Caught by controller[7]: 8: 0x15865ac [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.738	error	Caught by controller[6]: 7: 0xd38518 v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.738	error	Caught by controller[5]: 6: 0xd374a4 [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.738	error	Caught by controller[4]: 5: 0x7f9d2ff170 [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
    host.homebridge
    2023-04-16 08:31:32.737	error	Caught by controller[3]: 4: 0x7f9d30df30 Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
    host.homebridge
    2023-04-16 08:31:32.737	error	Caught by controller[3]: 3: 0xccf858 v8::Utils::ReportApiFailure(char const*, char const*) [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.737	error	Caught by controller[2]: 2: 0xa214d4 node::FatalError(char const*, char const*) [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.737	error	Caught by controller[1]: 1: 0xb00584 node::Abort() [io.mihome-vacuum.0]
    host.homebridge
    2023-04-16 08:31:32.737	error	Caught by controller[0]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
    Und jetzt während der Staubsauger läuft sieht es so aus:
    mihome-vacuum.0
    411025	2023-04-16 08:32:09.641	info	create state for carpet_mode
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.524	info	create states for dust collecting
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.520	info	create states for dock status
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.516	info	create states for mop mode
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.395	info	create states for water box mode
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.385	info	create states for water box
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.383	info	change states from State control.fan_power
    mihome-vacuum.0
    411025	2023-04-16 08:32:08.313	info	create states for mop
    mihome-vacuum.0
    411025	2023-04-16 08:32:07.572	info	settest next timer: not available
    mihome-vacuum.0
    411025	2023-04-16 08:32:06.869	info	select standard vacuum protocol....
    mihome-vacuum.0
    411025	2023-04-16 08:32:06.706	info	IOT enabled, create state
    mihome-vacuum.0
    411025	2023-04-16 08:32:06.485	info	starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.1, js-controller: 4.0.24
    Und in der VIS sieht es so aus:
    obwohl es im Adapter so eingestellt ist:
    Bildschirmfoto 2023-04-16 um 08.40.19.png Bildschirmfoto 2023-04-16 um 08.40.07.png
    In der App wird die Karte angezeigt und auch die Bewegung des Saugers
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #1074
    @damrak2022
    Ich weiß nicht was du wie installiert hast.
    Habe auch den thread nicht verfolgt.
    für mich sieht das: "Caught by controller" nach einem generellen Problem aus.
    Aber wenns doch läuft; dann ist doch alles gut.
    Danke.
    • haselchenH haselchen
      @christian-wöhrle
      Gleiche Spiel von vorne .
      Bekommst du im Adapter einen Token , sprich , wird dein Gerät gefunden ?
      Was sagt das Debug Log beim Adapterstart.
      Christian WöhrleC Offline
      Christian Wöhrle
      #1075
      @haselchen ganz komisch: habe Sauger komplett aus meinem mi home account gelöscht und neu integriert. Adapter ebenfalls de und wieder installiert. Läuft jetzt wieder. Warum auch immer
      • Christian WöhrleC Christian Wöhrle
        haselchenH Offline
        haselchenH Offline
        haselchen
        #1076
        @christian-wöhrle
        Backup machen und freuen, dass es geht :)
        Christian WöhrleC 1 Antwort Letzte Antwort
          @christian-wöhrle
          Christian Wöhrle
          #1077
          @haselchen said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
          @christian-wöhrle
          Läuft jede Nacht 👍
          G 1 Antwort Letzte Antwort
            @christian-wöhrle
            Läuft jede Nacht 👍
            g1zm0
            #1078
            Ich nutze den Adapter nun schon eine ganze Weile mit meinem Roborock S7 Pro Ultra.
            Seit ein paar Tagen will das Ganze aber nicht mehr so recht.
            Der Adapter ist grün und bekommt auch den Status mit, allerdings kann ich nicht mehr steuern.
            Über die App geht alles.
            Habt ihr eine Idee, wo und wie ich anfangen könnte nach dem Fehler zu suchen?
            Noch einen schönen Abend!
            Viele Grüße,
            Ingo
            • G g1zm0
              Viele Grüße,
              Ingo
              dirkhe
              #1079
              @g1zm0 erstmal adapter auf debug stellen und schauen, was er uns so mitzuteilen hat. ggf das log mal hier einstellen
              • D dirkhe
                g1zm0
                #1080
                @dirkhe
                Hallöchen!
                Ich hab den Adapter mal auf Debug gestellt.
                Aber wie das dann immer so ist - dann läufts.
                Falls es nochmal dazu kommen sollte melde ich mich wieder mit einem Debug Log.
                Noch einen schönen Tag und schonmal ein schönes, langes Wochenende.
                Viele Grüße,
                Ingo
                • J Offline
                  jojo182
                  #1081
                  ich frag mich warum das Thema hier noch nicht aufgeschlagen ist, aber bei Verwendung von dem Adapter wird bei mir irgendwann keine Karte mehr angezeigt. Weder über den Adapter, noch über die Mihome App. Es gibt wohl ein API Limit auf Xiaomi Server Seite, siehe zB hier: https://github.com/PiotrMachowski/Home-Assistant-custom-components-Xiaomi-Cloud-Map-Extractor/issues/422
                  Ich konnte das Ganze reproduzieren. Läuft die Adapterinstanz kann im Laufe des Tages keine Karte mehr geladen werden. Irgendwann wird der temporäre Bann dann wieder reseted und dann gehts wieder für eine gewisse Zeit. Deaktiviere ich die Adapterinstanz, läuft alles über mehrere Tage stabil, also in der Mihome App. Steuerbefehle sind wohl nicht betroffen.
                  Leider hat das deaktivieren der Karte in der Instanz nicht geholfen. Auch habe ich versucht die Intervalle hoch zu setzen, aber bisher noch keinen brauchbaren Wert gefunden.
                  • J jojo182
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #1082
                    @jojo182 Ich weiß nicht, ob das jetzt so genau au Deinen Post zutrifft, aber ich habe neuerdings auch folgendes Verhalten. Staubsauger läuft bei mir alle 2 Tage. Karte wird mir am Pc angezeigt - alles gut. Urplötzlich she ich in der App nur noch das Symbol des Staubsaugers auf schwarzem Hintergrund, aber keine Karte mehr. Logischerweise wird Sie dann auch nicht am Pc angezeigt. Gerade ein hatte ich wieder genau das Verhalten: Keine Karte in der App zu sehen - Reinigung aber völlig normal.
                    Mit besten Grüßen
                    Andy
                      #1083
                      @damrak2022
                      @dirkhe
                      Hier auch, am Morgen seh ich in der App die Karte noch, ab nachmittags kommt se dann in der App nicht mehr..
                      hab 5 S5 bei allen gleich, ob die gestartet waren oder nicht ist egal..
                      werde mal den Adapter deaktivieren und nur starten, wenn die Sauger starten sollen, mal sehen ob das erstmal n workaround ist…
                        @damrak2022
                        @dirkhe
                        tombox
                        #1084
                        @ilovegym Hat jemand schon probiert "Status anfordern in Sekunden" hochzudrehen. Die github version zeigt auch mehr debug logs an
                        • T tombox
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #1085
                          @tombox Also ich nicht. Seit meinem letzten Post hier, habe ich meinen Staubsauger komplett in Ruhe an der Ladestation stehengelassen. Eben beim starten des Reinigungsdurchgangs bekomme ich erneut in der App anstelle der Karte nur das angezeigt:
                          Gibt es hier mittlerweile irgendwelche neuen Erkenntnisse?
                          Mit besten Grüßen
                          Andy
                            tombox
                            #1086
                            @damrak2022 Ich vermute das alle 20 Sekunden Zuviel request gesendet werden. Es würde sicher helfen die anfragen zu reduzieren oder von 20 Sekunden auf 1-5minuten zu gehen
                            • T tombox
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #1087
                              @tombox Ich habe den Abfrage Intervall mal auf 60 Sekunden gestellt. Aber hätte er nicht heute morgen beim ersten öffnen der App erstmal die Karte anzeigen müssen?
                              Mit besten Grüßen
                              Andy
                              T 2 Antworten Letzte Antwort
                                tombox
                                #1088
                                @damrak2022 Nein der Adapter hat alle Request für die letzen 24h aufgebraucht
                                • T tombox
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #1089
                                  @tombox
                                  @Damrak2022
                                  Da muss es woanders hängen.
                                  Ich hab 2 Roborocks S50 und noch nie (ausser vielleicht bei Major Updates) ein Problem mit der Steuerung oder Karte gehabt.
                                  Ich hab jetzt kein aussergewöhnliches System.
                                  Meine Node und NPM und Admin Daten stehen in meiner Signatur.
                                  Beim Adapter habe ich Version 3.10.1
                                  Im Adapter selber keine anderen Einstellungen gemacht, als die, die logisch sind.
                                  Server: Germany
                                  Ich benutze die Xiaomi Home App und auch dort ist kartentechnisch alles wunderbar.
                                  Ich will euer Problem nicht kleinreden , sondern einfach mitteilen, dass es bei mir zufriedenstellend und ohne Probleme funktioniert.
                                  Vielleicht können wir ja mal einige Sachen abgleichen.
                                  Die Karte mal als Beispiel
                                    tombox
                                    #1090
                                    @damrak2022 Hass.io issue berichten darüber das roborock kein rate limit hat das wäre dann noch eine alternative auf die roborock app umzuziehen
                                    • ? Offline
                                      #1091
                                      @tombox sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                      ich hab bei meinen 4 Saugern (S5) "Status anfordern" von 10sec auf 120 gesetzt, Wifi auf 180, bei der Map die Werte auf 10000 und 20000ms gesetzt.
                                      Hab ja durch die 4 Sauger auch 4 Instanzen, mein Startscript fuer die Sauger so geaendert, dass die Instanz erst gestartet wird, wenn der Sauger laufen soll (n Timeout von 60sec), und nach dem Saugvorgang wird die Instanz wieder beendet.
                                      Dadurch kann ich auch spaeter nach einem Saugvorgang noch auf die Karte in der App zugreifen.
                                      Dann hab ich gestern ausversehen die Instanzen eingeschaltet gelassen, heute morgen in der App keine Karte bei allen 4 sichtbar.
                                      Ich teste die Tage mit der Git Version mal auf debug um zu sehen, wann da was klemmt...
                                        dirkhe
                                        #1092
                                        ich kann nicht mitreden, weil ich die Karte nicht aktiviert habe, aber die meisten request werden dann ja währen der reinigung abgesetzt. Vlt sollten w8r mal zusammentragen, wie lange und oft die reinigungszeiten sind.
                                        oder ich muss mal ein counter einbauen
                                        • bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #1093
                                          Ich hatte gestern das gleiche Problem wie @Damrak2022 .
                                          Mir wurde nur der Sauger in der Mitte, aber keine Karte angezeigt.
                                          Allerdings wurde mir ein update des Saugers angezeigt.
                                          Dieses gemacht und danach funktionierte die Karte wieder im handy, und auch in der VIS.
                                          Ob dies zusammenhängt kann ich nicht sagen,
                                          aber bei mir läuft alles.
                                          Danke.
                                          D Damrak2022D 2 Antworten Letzte Antwort
