  4. [HowTo] ioBroker Restore unter Linux durchführen
    6.7k
restorerestore backupbackituphow-to
527 Beiträge 80 Kommentatoren 198.9k Aufrufe 76 Beobachtet
    Sebi_7_6
    #431
    Hab jetzt VIS & HabPanel als Instanz und Objekt entfernt und auch die Reste in den Ordnern files und node_modules gelöscht. Habe dann VIS neu installiert.
    und wieder...
    Click ich drauf.
    URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/vis/index.html'
        at decodeURIComponent (<anonymous>)
        at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
        at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
        at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
        at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
        at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
        at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
        at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
        at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
        at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
    • S Sebi_7_6
      und wieder...
      Click ich drauf.
      crunchipC Offline
      crunchipC Offline
      #432
      @sebi_7_6 Einstellung deines web Adapters?
      • S Sebi_7_6
        Beides
        Adapter State
          system.adapter.accuweather.0            : accuweather           : raspberrypi                              - disabled
        + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
          system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
        + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
          system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
          system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
          system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
        + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
          system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
          system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
        Adapter    "admin"        : 6.3.5    , installed 6.2.17 [Updatable]
        Adapter    "alexa2"       : 3.23.2   , installed 3.19.9 [Updatable]
        Adapter    "backitup"     : 2.6.16   , installed 2.4.10 [Updatable]
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
        Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
        Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
        Adapter    "javascript"   : 6.1.4    , installed 6.0.0  [Updatable]
        Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.0.7  [Updatable]
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "openweathermap": 0.3.3   , installed 0.3.3
        Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
        Adapter    "schoolfree"   : 1.1.1    , installed 1.0.1  [Updatable]
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.3  [Updatable]
        Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
        Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Objects and States
        Objects:        9978
        States:         8091
        Wie ich gesehen habe ist es bei der VIS genauso.
        Hab jetzt beide deinstalliert und nur HABPanel wieder installiert.
        Aber es erscheint wieder 2x im Dashboard und dann der Fehler wenn man ihn aufruft.
        da ist auch nichts zum starten oder Einstellungen usw.
        GlasfaserG Offline
        GlasfaserG Offline
        #433
        @sebi_7_6 sagte in [HowTo] ioBroker Restore unter Linux durchführen:
        @crunchip sagte in [HowTo] ioBroker Restore unter Linux durchführen:
        Ich würde den mal anschalten ;)
        H S 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          Habedere
          #434
          @crunchip
          Wollte den aktuellen Stand nochmal absichern - bekomme aber nun nen Error im Adapter:
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
          mount error(16): Device or resource busy
          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
          Der Server läuft aber - ich kann darauf im Explorer zugreifen. Und auch der Adapter findet die bestehenden Backup-Files.
          Ne Idee woran das liegen könnte?
          HomoranH crunchipC GlasfaserG 3 Antworten Letzte Antwort
          • H Habedere
            @crunchip
            #435
            @habedere sagte in [HowTo] ioBroker Restore unter Linux durchführen:
            natürlich! sogar sehr aktiv
            H 1 Antwort Letzte Antwort
            • H Habedere
              @crunchip
              crunchipC Offline
              crunchipC Offline
              #436
              cifs
              sind die cifs utils auf deinem neuen system auch installiert?
                Habedere
                #437
                Leider nein - OMV dümpelt vor sich hin...
                  cifs
                  Habedere
                  #438
                  @crunchip
                  ach herrje - du kannst Fragen fragen :) ich weiß es nicht... Sollte das nicht mit dem Backup übernommen worden sein? Was auch immer das ist ;)
                  crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                  • H Habedere
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    #439
                    ich denke nicht
                    https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
                    • H Habedere
                      @crunchip
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #440
                      da ist noch ein Mount vorhanden
                      sudo umount /opt/iobroker/backups
                      • H Habedere
                        @crunchip
                        #441
                        Nein, das sind Softwarepakete aus dem Betriebssystem, das wird natürlich nicht in ein iobroker-Backup gesteckt.
                        • H Offline
                          Habedere
                          #442
                          der Broker ist mir erneut abgestürzt als ich den Script-Adapter starten wollte. Nach dem Reboot kommt der cfis Fehler nicht mehr - aber erneut hängt sich der ganze ioBroker auf wenn ich das Backupt erstellen möchte.
                          Er mountet noch alles und schreibt dass einige Objekte erstellt wurden etc - aber dann hängt alles. Auf dem Server erscheint nichts. Irgendwas ist da komplett faul :( muss nochmal probieren...
                            Sebi_7_6
                            #443
                            @glasfaser
                            Oh wie peinlich und doof von mir.Sorry
                              @habedere
                              iob start admin
                              liefert?
                              Habedere
                              schrieb am zuletzt editiert von Habedere
                              #444
                              Servus,
                              nach dem mein Raspy zu wenig RAM hatte, bin ich nun auf neue Hardware umgestiegen... Nun läuft ioBroker in einem Proxmox LXC.
                              Hab nun mein Backup einspielen wollen und nun geht nichts mehr - wieder.
                              Letztes mal lage es an Redis. Hier kam dann die Frage auf warum ich das überhaupt installiert hatte - was mir garnicht bewusst war.
                              Bevor ich hier wieder rum murxe bitte ich gleich auf einen blick auf iob Diag:
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Architecture    : x86_64
                              Docker          : false
                              Virtualization  : lxc
                              Distributor ID: Debian
                              Description:    Debian GNU/Linux 11 (bullseye)
                              Release:        11
                              Codename:       bullseye
                              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                              NAME="Debian GNU/Linux"
                              VERSION_ID="11"
                              VERSION="11 (bullseye)"
                              VERSION_CODENAME=bullseye
                              ID=debian
                              HOME_URL="https://www.debian.org/"
                              SUPPORT_URL="https://www.debian.org/support"
                              BUG_REPORT_URL="https://bugs.debian.org/"
                              Systemuptime and Load:
                               21:28:48 up 35 min,  2 users,  load average: 0.09, 0.08, 0.02
                              CPU threads: 8
                              *** Time and Time Zones ***
                                             Local time: Tue 2023-06-27 21:28:48 CEST
                                         Universal time: Tue 2023-06-27 19:28:48 UTC
                                               RTC time: n/a
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** User and Groups ***
                              admin
                              /home/admin
                              admin sudo iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.1G        133M        3.0G        0.0K        938M        4.0G
                              Swap:           512M          0B        512M
                              Total:          4.6G        133M        3.5G
                                       4096 M total memory
                                        133 M used memory
                                        233 M active memory
                                        772 M inactive memory
                                       3024 M free memory
                                          0 M buffer memory
                                        938 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              *** FILESYSTEM ***
                              Filesystem                       Type   Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--100--disk--1 ext4    63G  2.3G   57G   4% /
                              none                             tmpfs  492K  4.0K  488K   1% /dev
                              tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                              tmpfs                            tmpfs  3.1G  124K  3.1G   1% /run
                              tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                              tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
                              [Mon Jun 19 16:20:05 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              [Mon Jun 19 16:20:06 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                              [Tue Jun 27 18:40:35 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              [Tue Jun 27 20:47:38 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              [Tue Jun 27 20:52:55 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:326: MMP interval 42 higher than expected, please wait.
                              [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): 1 orphan inode deleted
                              [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): recovery complete
                              [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              TARGET SOURCE                           FSTYPE OPTIONS
                              /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
                              /var:
                              409M    /var/
                              224M    /var/cache
                              220M    /var/cache/apt
                              153M    /var/cache/apt/archives
                              136M    /var/lib
                              Archived and active journals take up 8.0M in the file system.
                              /opt/iobroker/backups:
                              394M    /opt/iobroker/backups/
                              1.7M    /opt/iobroker/backups/redistmp
                              /opt/iobroker/iobroker-data:
                              33M     /opt/iobroker/iobroker-data/
                              15M     /opt/iobroker/iobroker-data/files
                              13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                              17M     /opt/iobroker/iobroker-data/objects.jsonl
                              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                              1.6M    /opt/iobroker/iobroker-data/states.jsonl
                              1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.16.0
                              /usr/bin/node           v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Installed: 18.16.0-deb-1nodesource1
                                Candidate: 18.16.1-deb-1nodesource1
                                Version table:
                                   18.16.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                               *** 18.16.0-deb-1nodesource1 100
                                   12.22.12~dfsg-1~deb11u4 500
                                      500 http://security.debian.org bullseye-security/main amd64 Packages
                                   12.22.12~dfsg-1~deb11u3 500
                                      500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                              No problems detected
                              *** ioBroker-Installation ***
                              ioBroker Status
                               Cannot read system.config: null (OK when migrating or restoring)
                              No connection to states 127.0.0.1:6379[redis]
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.5
                              javascript:     "javascript" not found
                              Adapters from github:   0
                              Adapter State
                              Objects and States
                              Objects:        2
                              States:         3
                              Hit:1 http://security.debian.org bullseye-security InRelease
                              Hit:2 http://ftp.debian.org/debian bullseye InRelease
                              Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Reading package lists...
                              Pending Updates: 7
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7944006    313/master
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8016850    4495/iobroker.js-co
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7942530    1/init
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        7941930    108/systemd-resolve
                              tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        7941924    108/systemd-resolve
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          7946286    1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          7945419    1/init
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7944007    313/master
                              tcp6       0      0 :::5355                 :::*                    LISTEN      104        7941927    108/systemd-resolve
                              udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        7941923    108/systemd-resolve
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        7941929    108/systemd-resolve
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7945326    1/init
                              udp6       0      0 :::5355                 :::*                                104        7941926    108/systemd-resolve
                              udp6       0      0 :::111                  :::*                                0          7941839    1/init
                              2023-06-27 21:29:45.852  - info: host.IoBroker iobroker _restart
                              2023-06-27 21:29:46.047  - info: host.IoBroker iobroker Starting node restart.js
                              2023-06-27 21:29:46.078  - info: host.IoBroker received SIGTERM
                              2023-06-27 21:29:46.081  - info: host.IoBroker iobroker exit null
                              2023-06-27 21:29:46.082  - warn: host.IoBroker get state error: Connection is closed.
                              2023-06-27 21:29:46.082  - info: host.IoBroker terminated
                              2023-06-27 21:29:47.082  - info: host.IoBroker iobroker.js-controller version 4.0.24 js-controller starting
                              2023-06-27 21:29:47.084  - info: host.IoBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2023-06-27 21:29:47.084  - info: host.IoBroker hostname: IoBroker, node: v18.16.0
                              2023-06-27 21:29:47.084  - info: host.IoBroker ip addresses: 192.168.178.100 fdc8:6d06:a691:4a6d:f434:68ff:fe39:49bc fe80::f434:68ff:fe39:49bc
                              2023-06-27 21:29:47.154  - error: host.IoBroker Cannot read system.config: null (OK when migrating or restoring)
                              2023-06-27 21:29:47.200  - error: host.IoBroker Cannot find view "system" for search "host"
                              2023-06-27 21:30:17.094  - error: host.IoBroker No connection to databases possible, restart
                              2023-06-27 21:30:17.095  - info: host.IoBroker iobroker _restart
                              2023-06-27 21:30:17.294  - info: host.IoBroker iobroker Starting node restart.js
                              2023-06-27 21:30:17.326  - info: host.IoBroker received SIGTERM
                              2023-06-27 21:30:17.328  - info: host.IoBroker iobroker exit null
                              2023-06-27 21:30:17.330  - warn: host.IoBroker get state error: Connection is closed.
                              2023-06-27 21:30:17.330  - info: host.IoBroker terminated
                              2023-06-27 21:30:18.324  - info: host.IoBroker iobroker.js-controller version 4.0.24 js-controller starting
                              2023-06-27 21:30:18.325  - info: host.IoBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2023-06-27 21:30:18.325  - info: host.IoBroker hostname: IoBroker, node: v18.16.0
                              2023-06-27 21:30:18.326  - info: host.IoBroker ip addresses: 192.168.178.100 fdc8:6d06:a691:4a6d:f434:68ff:fe39:49bc fe80::f434:68ff:fe39:49bc
                              2023-06-27 21:30:18.395  - error: host.IoBroker Cannot read system.config: null (OK when migrating or restoring)
                              2023-06-27 21:30:18.441  - error: host.IoBroker Cannot find view "system" for search "host"
                              PS: an den offenen Updates bin ich schon dran -hab ich übersehen...
                              • H Habedere
                                Servus,
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=debian
                                CPU threads: 8
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                admin
                                /home/admin
                                admin sudo iobroker
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           512M          0B        512M
                                         4096 M total memory
                                          133 M used memory
                                          233 M active memory
                                         3024 M free memory
                                            0 M buffer memory
                                          938 M swap cache
                                          512 M total swap
                                            0 M used swap
                                          512 M free swap
                                *** FILESYSTEM ***
                                /var:
                                409M    /var/
                                224M    /var/cache
                                220M    /var/cache/apt
                                136M    /var/lib
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                admin:          6.3.5
                                Adapter State
                                Objects and States
                                Objects:        2
                                States:         3
                                Pending Updates: 7
                                #445
                                adm
                                Steck deinen User 'admin' auch in die Gruppe 'adm'.
                                Ist redis installiert?
                                apt policy redis
                                Und was ist da passiert:
                                  adm
                                  apt policy redis
                                  Habedere
                                  #446
                                  @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                  Das mache ich wie?
                                  Redis scheint wieder nicht installiert zu sein
                                  redis:
                                    Installed: (none)
                                    Candidate: 5:6.0.16-1+deb11u2
                                    Version table:
                                       5:6.0.16-1+deb11u2 500
                                  Keine Ahung was das mit EXT4-fs war. Glaub ich wollte nur irgendwelche Daten auslesen...
                                  Hab ich was verpfuscht?
                                  Könnte Snapshot zurück setzen...
                                  PS: sudo apt install redis-server ->
                                  redis:
                                    Installed: (none)
                                    Version table:
                                  muss wohl noch einstellen...
                                  • H Habedere
                                    Das mache ich wie?
                                    redis:
                                      Installed: (none)
                                      Version table:
                                    redis:
                                      Installed: (none)
                                      Version table:
                                    #447
                                    @habedere
                                    Deleted inodes sind nie gut. Ist halt weg, was auch immer da drin stand...
                                    Auch Container wollen sauber gestoppt und gestartet werden.
                                    Gruppen hinzufügen:
                                    sudo usermod -a -G adm admin
                                    Den user dann einmal aus- und wieder einloggen.
                                    • H Habedere
                                      Das mache ich wie?
                                      redis:
                                        Installed: (none)
                                        Version table:
                                      redis:
                                        Installed: (none)
                                        Version table:
                                      #448
                                      Das ist ja auch kein default package. Muss immer nachinstalliert werden.
                                      HomoranH H 2 Antworten Letzte Antwort
                                        @habedere
                                        Gruppen hinzufügen:
                                        Habedere
                                        #449
                                        alles klar - danke.
                                        Ich mache nochmal Fallback und dann auch nach den Updates redis ordentlich mit installieren.
                                        Plus Admin einstellen
                                          #450
                                          Ich weiß jetz nie, ob es um die interne Redis geht oder die redis-server für states aus Raspi1/2 Zeiten
