  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 515.0k Aufrufe 93 Beobachtet
  • efxzE efxz
    @rene55
    Kann es sein, dass der Adapter nicht unter node18 npm 9.5.0 läuft?
    Bekomme folgende Fehlermeldung:
    $ iobroker url https://github.com/raschy/ioBroker.deyeidc.git --host macmini --debug
    install raschy/ioBroker.deyeidc#6453534611a508d330e7da7d6d6216b8de3122e3
    NPM version: 9.3.1
    Installing raschy/ioBroker.deyeidc#6453534611a508d330e7da7d6d6216b8de3122e3... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/raschy/ioBroker.deyeidc.git
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/utf-8-validatenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.3.0npm ERR! gyp info using node@18.15.0 | linux | arm64npm ERR! gyp info find Python using Python version 3.10.10 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/utf-8-validate/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/utf-8-validate',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: not found: makenpm ERR! gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:10:17)npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:57:18npm ERR! gyp ERR! stack at new Promise (<anonymous>)npm ERR! gyp ERR! stack at step (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:54:21)npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:71:22npm ERR! gyp ERR! stack at new Promise (<anonymous>)npm ERR! gyp ERR! stack at subStep (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:69:33)npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:80:22npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5npm ERR! gyp ERR! System Linux 6.2.0-asahi-11-1-edge-ARCHnpm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm ERR! gyp ERR! node -v v18.15.0npm ERR! gyp ERR! node-gyp -v v9.3.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-04-21T11_18_59_850Z-debug-0.log
    host.macmini Cannot install raschy/ioBroker.deyeidc#6453534611a508d330e7da7d6d6216b8de3122e3: 1
    ERROR: Process exited with code 25
    Rene55R Online
    Rene55R Online
    Rene55
    #142
    @efxz Doch! Kann ich nur bestätigen. Der Adapter ist unter node 18.14.1, allerdings mit npm 9.4.1 entwickelt worden.
    • Rene55R Rene55
      @frank70 Lass uns das mal in den nächsten Tagen in Ruhe angehen. Du kannst mir ja schon mal schreiben (raschy@gmx.de) was genau du bisher erreicht hast.
      ___manalishi_ Offline
      ___manalishi
      schrieb am zuletzt editiert von ___manalishi
      #143
      @rene55 Ich habe nun eine Lösung gefunden:
      1. Ich verwende die https://github.com/bagges/deye-esp32-bridge . Habe eine V1 der Platine und diesen RS485 Adapter verbaut. https://www.amazon.de/-/en/dp/B09VGJCJKQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
        Generell geht es auch ohne diese Platine. Markus Bagges arbeitet gerade an einem PCB-Update.
      2. Der RS485 Adapter muss mit 5V versorgt werden
      3. Der ESPHOME Adapter im IOBROKER läuft bei mir nicht sauber. Daher habe ich auf dem ESP32 einen MQTT Client eingerichtet und die API ausgeschaltet.
      #api:
          # password: ""
      mqtt:
        broker: 192.168.XXX.XXX
        port: 1887
        topic_prefix: DEYE-12kW-1
        birth_message:
          topic: DEYE-12kW-1/status
          payload: online
        will_message:
          payload: offline
      Mit diesen Einstellungen werden alle Sensoren und Switches automatisch im ioBroker angelegt. Das ist der Hammer. Gratulation an die Entwickler.
      /ioBoker auf PVE LXC
      • ___manalishi_ ___manalishi
        #api:
            # password: ""
        mqtt:
          port: 1887
          birth_message:
            payload: online
          will_message:
            payload: offline
        Rene55R Online
        Rene55R Online
        Rene55
        #144
        @frank70 Das sieht ja tip-top aus 😊 . Aber da sind wir hier bei einer Hardware-basierten Lösung und sollten den Dialog hierüber in einem separaten Thread fortführen.
        Die Nutzer, die einen "kleinen" Wechselrichter und somit keine Möglichkeit haben, hier diese Lösung zu verwenden, finden sich sonst nicht mehr zu recht.
        Trotzdem Danke für das Aufzeigen der Lösung.
        ___manalishi_ ralleR 2 Antworten Letzte Antwort
        • Rene55R Rene55
          ___manalishi
          #145
          @rene55 hast recht. hier noch abschliessend mein Bsp zur Steuerung des WR auf Basis der Awattar Daten
          Vielen Dank nochmal für deinen Support!
          • Rene55R Rene55
            ralleR Offline
            ralleR Offline
            ralle
            #146
            @rene55
            Ich hab mal den neuen Adapter installiert, musste den heut auch mal neu einlesen und jetzt bekomme ich diverse Warnungen und auch einen Fehler.
            Wie kann ich raus finden wo der Fehler ist....
            2023-04-23 12:41:52.392 - warn: deyeidc.0 (14552) State "deyeidc.0.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:52.437 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:52.845 - error: deyeidc.0 (14552) Error: ControlCode faulty!
            2023-04-23 12:41:53.067 - warn: deyeidc.1 (6577) State "deyeidc.1.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:53.068 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:53.078 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:53.080 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:58.388 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:41:58.492 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:00.108 - info: host.raspberrypi instance system.adapter.solarmanpv.0 started with pid 17007
            2023-04-23 12:42:03.200 - info: solarmanpv.0 (17007) starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.20.0, js-controller: 4.0.24
            2023-04-23 12:42:06.658 - info: solarmanpv.0 (17007) State value to set for "solarmanpv.0.3050628.generationPower" has to be type "string" but received type "number"
            2023-04-23 12:42:09.356 - info: solarmanpv.0 (17007) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2023-04-23 12:42:09.883 - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-04-23 12:42:11.048 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:31.005 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 energiefluss.0
            2023-04-23 12:42:31.014 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.017 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.022 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.028 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.030 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 energiefluss.0
            2023-04-23 12:42:31.038 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.041 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.043 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.049 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 flot
            2023-04-23 12:42:31.055 - info: web.0 (1916) <== Disconnect system.user.admin from ::ffff:192.168.1.207 vis.0
            2023-04-23 12:42:48.001 - info: admin.0 (1408) ==> Connected system.user.admin from ::ffff:192.168.1.207
            2023-04-23 12:42:52.389 - warn: deyeidc.0 (14552) State "deyeidc.0.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:52.437 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.034 - warn: deyeidc.1 (6577) State "deyeidc.1.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.080 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.412 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.548 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.704 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:42:53.756 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:06.744 - info: admin.0 (1408) <== Disconnect system.user.admin from ::ffff:192.168.1.207 admin
            2023-04-23 12:43:47.005 - info: admin.0 (1408) <== Disconnect system.user.admin from ::ffff:192.168.1.207 admin
            2023-04-23 12:43:48.237 - info: admin.0 (1408) ==> Connected system.user.admin from ::ffff:192.168.1.207
            2023-04-23 12:43:52.389 - warn: deyeidc.0 (14552) State "deyeidc.0.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:52.395 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:52.826 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:52.916 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:53.036 - warn: deyeidc.1 (6577) State "deyeidc.1.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:53.080 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:53.483 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:53.622 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:43:55.470 - info: admin.0 (1408) <== Disconnect system.user.admin from ::ffff:192.168.1.207
            2023-04-23 12:44:09.670 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:11.122 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:52.391 - warn: deyeidc.0 (14552) State "deyeidc.0.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:52.437 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:52.788 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:52.888 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:53.036 - warn: deyeidc.1 (6577) State "deyeidc.1.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:53.082 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:53.493 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:44:53.571 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:52.391 - warn: deyeidc.0 (14552) State "deyeidc.0.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:52.437 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:52.799 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:52.831 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:53.038 - warn: deyeidc.1 (6577) State "deyeidc.1.info.lastUpdate" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:53.084 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:53.647 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:45:53.811 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:46:09.457 - warn: deyeidc.0 (14552) State "deyeidc.0.info.status" has no existing object, this might lead to an error in future versions
            2023-04-23 12:46:11.117 - warn: deyeidc.1 (6577) State "deyeidc.1.info.status" has no existing object, this might lead to an error in future versions
            • ralleR ralle
              @rene55
              Rene55R Online
              Rene55R Online
              Rene55
              #147
              @ralle Du hast zwei Instanzen laufen? Ist das so richtig. Die Warnungen sollten eigentlich gar nicht kommen und wenn nur einmal nach dem Start.
              Der Fehler Error: ControlCode faulty! kommt daher, dass der Inverter keine gültigen Daten geschickt hat - sollte sich aber auch gleich zurechtgeruckelt haben.
              ralleR 1 Antwort Letzte Antwort
              • Rene55R Rene55
                ralleR Offline
                ralleR Offline
                ralle
                #148
                @rene55
                Danke fürs schnelle beantworten.
                Ja, es sind 2 Instanzen, das ist korrekt.
                Hat sich anscheint bis jetzt beruhigt, außer bei der ersten Instanz, da kommt noch immer eine Fehlermeldung......
                2023-04-23 16:47:56.565 - error: deyeidc.0 (17531) Error: ControlCode faulty!
                2023-04-23 16:49:56.562 - error: deyeidc.0 (17531) Error: ControlCode faulty!
                • ralleR ralle
                  @rene55
                  Rene55R Online
                  Rene55R Online
                  Rene55
                  #149
                  @ralle Wie schon gesagt - das liefert der Inverter. Welcher Typ ist das?
                  • Rene55R Rene55
                    ralleR Offline
                    ralleR Offline
                    ralle
                    #150
                    @rene55
                    Hi, wie du schon erwähnt hast hat es sich beruhigt.
                    Ich habe aber wie vorher immer noch eine Fehlermeldung!
                    Habe diesen log schon mehrfach gelöscht, er kommt aber immer wieder
                    Wie kann ich rausfinden welcher Code falsch ist.
                    Bei mir laufen 2 Deye600, beide so habe ich kontrolliert mit den gleichen Registern usw....
                    deyeidc.1
                    4733	2023-04-24 15:46:29.211	error	Error: ControlCode faulty!
                    • ralleR ralle
                      @rene55
                      deyeidc.1
                      Rene55R Online
                      Rene55R Online
                      Rene55
                      #151
                      @ralle Bei jeder Anfrage an den Inverter wird im Inverter ein Controllcode erzeugt, der gegen einen erwarteten Wert geprüft wird. Unter welchen Bedingungen der Code nicht ok ist, habe ich noch nicht finden können.
                      Du kannst daran nichts machen, brauchst also nicht nach irgendeinem Fehler suchen. Es wäre nur interessant zu wissen, wie oft dieser Fehler kommt und dann unter welchen Umständen. Ich denke da an WLAN-Abbruch oder zu häufiges Abfragen oder ähnliches.
                      Übrigens gibt es etwas ähnliches mit der Uhrzeit im Inverter: Error: Offset Time is invalid. Der kommt meist beim Neustart des Inverters am Morgen.
                        MPF
                        #152
                        ich habe gestern ein Update von Version 0.0.4 auf 0.0.5 gemacht.
                        Jetzt verbindet sich der Adapter nicht mehr mit dem Deye.
                        "Verbunden mit Gerät oder Dienst" bleibt rot.
                        Lief mit der 4er Version einwandfrei ?
                        Hab den Adapter auch schon komplett deinstalliert und wieder installiert.
                        • R Rico Sander
                          @w00dst0ck
                          Ich weiß nicht, ob das hier zutrifft. Ich möchte daher nur daran erinnern, dass Leistung != Wirkleistung ist. Was sich möglicherweise auf die berechnete Stromstärke auswirkt.
                          VG Peter
                          #153
                          Ich konnte meinen Inverter zwar verbinden, bekomme aber keine Daten angezeigt. Woran könnte das liegen?
                            JB_SullivanJ Offline
                            JB_Sullivan
                            #154
                            @gintonik Du hast aber bei den Instanz Einstellungen alle ModBus Adressen und Register eingetragen die du angezeigt haben willst?
                            • Rene55R Rene55
                              ralleR Offline
                              ralleR Offline
                              ralle
                              schrieb am zuletzt editiert von ralle
                              #155
                              @Rene55
                              Hi, hab auch gerade das UPDATE AUF 0.0.5 gemacht, der Adapter verbindet sich nicht mehr mit dem Wechselrichter....
                              deyeidc.0
                              8498	2023-04-29 16:02:26.615	error	Cannot read properties of undefined (reading 'indexOf')
                              deyeidc.0
                              8498	2023-04-29 16:02:26.614	error	TypeError: Cannot read properties of undefined (reading 'indexOf') at mathOperation (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:324:30) at Deyeidc.readComputeAndWatch (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:287:22) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:186:16)
                              deyeidc.0
                              8498	2023-04-29 16:02:26.613	error	unhandled promise rejection: Cannot read properties of undefined (reading 'indexOf')
                              deyeidc.0
                              8498	2023-04-29 16:02:26.612	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              • Rene55R Online
                                Rene55R Online
                                Rene55
                                schrieb am zuletzt editiert von Rene55
                                #156
                                @ralle Eine Änderung besteht in den berechneten Werten (=Compute). Hier gab es vormals 2 Eingabefelder, jetzt gibt es nur noch eins das z.B. so "DV1*DC1" befüllt werden muss.
                                Sorry, hab ich bisher oben noch nicht beschrieben (Hol ich gleich nach). Pass bitte mal deine Computes an, dann sehen wir nochmal weiter.
                                • Rene55R Rene55
                                  ralleR Offline
                                  ralleR Offline
                                  ralle
                                  #157
                                  @rene55
                                  Das war es wohl, nach dem Update waren die Felder leer. derzeit ist der Adapter wieder "grün"
                                  • ralleR ralle
                                    @rene55
                                    Rene55R Online
                                    Rene55R Online
                                    Rene55
                                    #158
                                    @ralle Super. Bitte weiter beobachten und melden. (ist ja noch in Entwicklung 🤒 ).
                                    • JB_SullivanJ Offline
                                      JB_Sullivan
                                      #159
                                      Was hat es eigentlich mit dieser Meldung so auf sich? Ich bin noch bei Adapter Version 0.0.4 (welche Vorteile / Verbesserungen hat die 0.0.5?)
                                      deyeidc.0
                                      9824	2023-04-30 09:46:54.645	error	Error: ControlCode faulty!
                                      • JB_SullivanJ JB_Sullivan
                                        deyeidc.0
                                        Rene55R Online
                                        Rene55R Online
                                        Rene55
                                        #160
                                        @jb_sullivan Die Meldung habe ich hier #150 schon mal versucht zu erklären.
                                        Die Verbesserung in der Version 0.0.5 ist nur im Bereich der berechneten Werte zu finden. Hier gibt es quasi eine Ausweitung auf die vier Grundrechenarten. Siehe hierzu auch Post #1.
                                        • R Offline
                                          RaMue
                                          schrieb am zuletzt editiert von RaMue
                                          #161
                                          Hallo rene55,
                                          erst mal danke für die Arbeit,
                                          Ich habe drei Wechselrichter am laufen, funktioniert wunderbar.
                                          Jetzt meine Frage:
                                          gibt es die Möglichkeit über den Adapter die Wirkleistung zu regeln (Nulleinspeisung) ?
                                          Gruß Ralf
