  3. Einsteigerfragen
  4. Installation
  5. iobroker lässt sich nicht mehr starten
106 Beiträge 4 Kommentatoren 10.9k Aufrufe 3 Beobachtet
  • B balu67
    @homoran said in iobroker lässt sich nicht mehr starten:
    bei iob diag?
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     14:51:31 up  4:26,  2 users,  load average: 0.68, 0.49, 0.21
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=42.8'C
    volt=0.9460V
    *** Time and Time Zones ***
                   Local time: Mon 2023-04-24 14:51:31 CEST
               Universal time: Mon 2023-04-24 12:51:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    al
    /home/al
    al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.8G        950M        1.5G         41M        1.3G        2.8G
    Swap:            99M          0B         99M
    Total:          3.9G        950M        1.6G
             3794 M total memory
              950 M used memory
             1447 M active memory
              590 M inactive memory
             1525 M free memory
              135 M buffer memory
             1183 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  9.6G   19G  35% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.3M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Mon Apr 24 10:25:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Apr 24 10:25:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Apr 24 10:25:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Apr 24 10:25:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.0G	/var/
    3.4G	/var/log
    3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
    304M	/var/cache
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    24M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    580M	/opt/iobroker/iobroker-data/
    447M	/opt/iobroker/iobroker-data/history
    99M	/opt/iobroker/iobroker-data/files
    59M	/opt/iobroker/iobroker-data/history/20230328
    58M	/opt/iobroker/iobroker-data/history/20230329
    9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
    9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
    9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
    9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
    9.3M	/opt/iobroker/iobroker-data/history/20230402/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.0
    /usr/bin/node 		v18.16.0
    /usr/bin/npm 		9.5.1
    /usr/bin/npx 		9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.1.4
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
    + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
    + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
    + system.adapter.history.0                : history               : Raspberry                                -  enabled
    + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
    + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
    + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Objects and States
    Objects: 	548
    States: 	426
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 https://packages.grafana.com/oss/deb stable InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15485      534/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123254     6824/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123247     6824/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14033      583/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        1848       554/influxd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       122473     6917/io.shelly.0
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15495      567/vncserver-x11-c
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        15946      542/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14044      583/sshd: /usr/sbin
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15494      567/vncserver-x11-c
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15484      534/cupsd
    tcp6       0      0 :::8086                 :::*                    LISTEN      116        15042      554/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       121728     6842/io.admin.0
    udp        0      0 0.0.0.0:45059           0.0.0.0:*                           108        13969      403/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15531      477/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15522      616/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13967      403/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15550      477/dhcpcd
    udp6       0      0 :::35639                :::*                                108        13970      403/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13968      403/avahi-daemon: r
    2023-04-24 14:47:28.051  - info: javascript.0 (6902) requesting all objects
    2023-04-24 14:47:28.425  - info: javascript.0 (6902) received all objects
    2023-04-24 14:47:28.467  - info: javascript.0 (6902) received all states
    2023-04-24 14:47:28.494  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 6917
    2023-04-24 14:47:28.567  - info: javascript.0 (6902) Start javascript script.js.Test
    2023-04-24 14:47:28.632  - info: javascript.0 (6902) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-04-24 14:47:30.990  - info: shelly.0 (6917) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 4.0.24
    2023-04-24 14:47:31.209  - info: shelly.0 (6917) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
    2023-04-24 14:47:32.475  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 6932
    2023-04-24 14:47:34.385  - info: discovery.0 (6932) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-04-24 14:47:36.472  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 6947
    2023-04-24 14:47:38.590  - info: backitup.0 (6947) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-04-24 14:47:38.700  - info: backitup.0 (6947) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-04-24 14:47:39.424  - info: shelly.0 (6917) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
    2023-04-24 14:47:40.479  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 6962
    2023-04-24 14:47:42.480  - info: echarts.0 (6962) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
    2023-04-24 14:47:43.124  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
    2023-04-24 14:47:44.472  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 6977
    2023-04-24 14:47:46.305  - info: panasonic-comfort-cloud.0 (6977) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v18.16.0, js-controller: 4.0.24
    2023-04-24 14:47:46.514  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
    2023-04-24 14:47:48.970  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
    2023-04-24 14:47:51.127  - info: panasonic-comfort-cloud.0 (6977) Login successful.
    2023-04-24 14:47:51.145  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
    2023-04-24 14:50:28.444  - info: admin.0 (6842) ==> Connected system.user.admin from ::ffff:192.168.178.28
    2023-04-24 14:52:20.614  - info: admin.0 (6842) <== Disconnect system.user.admin from ::ffff:192.168.178.28 admin
    #73
    @balu67 sagte in iobroker lässt sich nicht mehr starten:
    X-Server: true Desktop: LXDE-pi
    Keinen Desktop!
      @balu67 sieht mir eher nach nem Browsercache Fehler aus
      balu67
      #74
      @crunchip said in iobroker lässt sich nicht mehr starten:
      was kann ich noch machen?
        Keinen Desktop!
        balu67
        #75
        @thomas-braun said in iobroker lässt sich nicht mehr starten:
        Keinen Desktop!
        den brauch ich, da ich sonst gar nichts machen kann......nicht mal nach Dateien sehen oder......
        • B balu67
          Keinen Desktop!
          #76
          @balu67
          Macht man natürlich im Terminal.
          • B balu67
            #77
            STRG-F5
            und was kommt Jetzt als Meldung?
            • B balu67
              Keinen Desktop!
              crunchipC Abwesend
              crunchipC Abwesend
              #78
              @balu67 das kannst du z.b mit WinSCP von deinem Rechner aus, falls es unbedingt sein muss
                #79
                @crunchip sagte in iobroker lässt sich nicht mehr starten:
                aber nur mit dem richtigen user und Editor (wenn benutzt)
                  @balu67
                  balu67
                  #80
                  das kann ich leider nicht bedienen. Bin froh, dass ich eure Vorgaben eingeben konnte
                  crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                  • B balu67
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #81
                    @balu67 was ist jetzt mit dem Browser?
                    • B balu67
                      #82
                      @balu67
                      Dann nimm halt WinSCP oder sowas her. Jedenfalls tust du dir selber keinen Gefallen mit dem mitgeschleppten vollen Desktop.
                      Das halbe Dutzend Befehle für die Navigation durch das Dateisystem und sonstige Operationen man sich aber auch drauf schaffen, denke ich.
                        STRG-F5
                        balu67
                        #83
                        STRG-F5
                        keine Meldung kommt nur
                        • B balu67
                          STRG-F5
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #84
                          @balu67 im Browser nicht in der Konsole
                          dein Browserfenster anklicken wo dir die Iobroker startseite angezeigt wird und F5 drücken, damit die Seite neu geladen wird
                            balu67
                            #85
                            dann wird der iobroker nur neu geladen, aber wieder mit Ergebnis
                            crunchipC HomoranH 2 Antworten Letzte Antwort
                            • B balu67
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #86
                              @balu67 ok dann drück mal F12 oder ctrl + shift + c und zeig mal die Browserconsole
                              oder hast du noch nen anderen Browser zur Verfügung mit dem du mal die iobrokerseite aufrufst, zur Not mal mit dem Handy?
                                balu67
                                #87
                                übrigens wurde vorher das blockly Skript ausgeführt, an dem wir gestern rumgedoktert haben (Klimaanlage ein, wenn bestimmte Temperatur erreicht wurde)
                                  balu67
                                  schrieb am zuletzt editiert von balu67
                                  #88
                                  oder hast du noch nen anderen Browser zur Verfügung?
                                  soll ich den iobroker dazu starten?
                                  UNd F12 auf dem windows PC oder auf dem Raspberry machen?
                                  • B balu67
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #89
                                    @balu67 na von deinem Windows Pc, welchen Browser verwendest du denn
                                    der läuft doch
                                    die Browserseite die nicht richtig angezeigt wird, da sollst du F12 drücken
                                      der läuft doch
                                      balu67
                                      #90
                                      @crunchip
                                      das kommt am Windows PC
                                      das am Raspy
                                      Am handy ging es bei mir noch nie, da wird nur immer die IP angezeigt
                                      • B balu67
                                        #91
                                        dann ändere mal in der Adressleiste das ...#tab-intro in ...#tab-logs und drück Enter
                                        • B balu67
                                          @crunchip
                                          das am Raspy
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #92
                                          @balu67 da stimmt doch die Uhrzeit nicht, oder täusche ich mich jetzt
                                          @Homoran
                                          Oder ist das die Uhrzeit seit dem der iobroker wieder läuft?
                                          HomoranH B 2 Antworten Letzte Antwort
