  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
    apollon77A
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 263.6k Aufrufe 52 Beobachtet
  • H Habedere
    Leider nein - hängt immer noch an der selben stelle :(
    Also quasi noch schlechter wie vorher....
    Thomas BraunT
    Thomas BraunT
    #87
    @habedere sagte in Troubleshooting NodeJS update:
    Heißt?
    H 1 Antwort Letzte Antwort
      Heißt?
      H
      H
      Habedere
      #88
      Freeze
      nulu@raspberrypi:/opt/iobroker $ cd /opt/iobroker
      npm ls | grep -E 'github|ERR'
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-23T11_39_17_688Z-debug-0.log
      sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not tran        sfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      ^C^C###############) ⠧ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.3.5.tgz 52083ms (cache miss)
      • H Habedere
        Freeze
        Thomas BraunT
        Thomas BraunT
        #89
        Freeze
        Glaube ich nicht. Lass das mal laufen.
          Freeze
          H
          H
          Habedere
          schrieb am zuletzt editiert von Habedere
          #90
          Mach ich - steht halt schon seit ner guten 2 Stunden an der selben Stelle ;)
          • H Habedere
            H
            H
            Habedere
            #91
            @habedere
            Also Shell hat sich nicht mehr bewegt und nach dem ich das Terminal geschlossen habe war eine erneute Anmeldung über SSH nicht möglich. Hab dann den Strom ziehen müssen - aber siehe da, es läuft :)
            nulu@raspberrypi:~ $ /opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs &>        /dev/null
            uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx        -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt u        pdate &> /dev/null && sudo apt update && apt policy nodejs
            aarch64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v18.16.0
            v18.16.0
            9.5.1
            9.5.1
            4.0.24
            nulu
            nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobr                                                           oker
            tty
            /home/nulu
            OK:1 http://deb.debian.org/debian bullseye InRelease
            OK:2 http://deb.debian.org/debian bullseye-updates InRelease
            OK:3 http://security.debian.org/debian-security bullseye-security InRelease
            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
            Alle Pakete sind aktuell.
            nodejs:
              Installiert:           18.16.0-deb-1nodesource1
              Installationskandidat: 18.16.0-deb-1nodesource1
              Versionstabelle:
             *** 18.16.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            Werde jetzt mal das Backup einspielen...
            Vielen vielen Dank für die Hilfe!
            HomoranH H 3 Antworten Letzte Antwort
            • H Habedere
              @habedere
              aarch64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v18.16.0
              v18.16.0
              9.5.1
              9.5.1
              4.0.24
              nulu
              tty
              /home/nulu
              nodejs:
                Versionstabelle:
              #92
              nein!
              • H Habedere
                @habedere
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v18.16.0
                v18.16.0
                9.5.1
                9.5.1
                4.0.24
                nulu
                tty
                /home/nulu
                nodejs:
                  Versionstabelle:
                #93
                wirklich oder nur scheinbar?
                bitte Ausgabe von iob diag in der Vollversion
                • H Habedere
                  @habedere
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v18.16.0
                  v18.16.0
                  9.5.1
                  9.5.1
                  4.0.24
                  nulu
                  tty
                  /home/nulu
                  nodejs:
                    Versionstabelle:
                  H
                  H
                  Habedere
                  #94
                  @habedere
                  Gestopt! Why?
                  • H Habedere
                    @habedere
                    Gestopt! Why?
                    #95
                    @habedere
                    Gestopt! Why?
                    einmal s.o. und zum zweiten: hast du vis manuell installiert?
                    und gestoppt ist abgebrochen ist undefinierter Zustand?
                      @habedere
                      Gestopt! Why?
                      H
                      H
                      Habedere
                      #96
                      sorry - mit gestopt meinte ich mich. Hab das Backup noch nicht gestartet weil ich gerade noch deine Nachricht gelesen habe. Hab nur die json des Backup-Adapter eingespielt damit die Zugangsdaten zum Server etc. wieder drin sind...
                      Full diag:
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Model           : Raspberry Pi 3 Model B Rev 1.2
                      Architecture    : aarch64
                      Docker          : false
                      Virtualization  : none
                      Distributor ID: Debian
                      Description:    Debian GNU/Linux 11 (bullseye)
                      Release:        11
                      Codename:       bullseye
                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                      NAME="Debian GNU/Linux"
                      VERSION_ID="11"
                      VERSION="11 (bullseye)"
                      VERSION_CODENAME=bullseye
                      ID=debian
                      HOME_URL="https://www.debian.org/"
                      SUPPORT_URL="https://www.debian.org/support"
                      BUG_REPORT_URL="https://bugs.debian.org/"
                      Systemuptime and Load:
                       19:51:34 up 14 min,  3 users,  load average: 0.91, 0.88, 0.56
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      Other values than 0x0 hint to temperature/voltage problems
                      temp=54.2'C
                      volt=1.3000V
                      *** Time and Time Zones ***
                                     Local time: Sun 2023-04-23 19:51:34 CEST
                                 Universal time: Sun 2023-04-23 17:51:34 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      nulu
                      /home/nulu
                      nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            909M        447M        105M        9.0M        356M        389M
                      Swap:            99M        3.0M         96M
                      Total:          1.0G        450M        201M
                                909 M total memory
                                447 M used memory
                                491 M active memory
                                192 M inactive memory
                                105 M free memory
                                  2 M buffer memory
                                354 M swap cache
                                 99 M total swap
                                  3 M used swap
                                 96 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4      110G  4.3G  101G   5% /
                      devtmpfs       devtmpfs  325M     0  325M   0% /dev
                      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                      tmpfs          tmpfs     182M  1.2M  181M   1% /run
                      /dev/sda1      vfat      255M   31M  225M  13% /boot
                      tmpfs          tmpfs      91M   20K   91M   1% /run/user/1000
                      [Sun Apr 23 19:37:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bdb8b6dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                      [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): write access will be enabled during recovery
                      [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): recovery complete
                      [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Apr 23 19:37:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Sun Apr 23 19:37:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      TARGET  SOURCE    FSTYPE OPTIONS
                      /       /dev/sda2 ext4   rw,noatime
                      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      628M    /var/
                      245M    /var/cache
                      239M    /var/cache/apt
                      184M    /var/lib
                      138M    /var/cache/apt/archives
                      Archived and active journals take up 96.0M in the file system.
                      /opt/iobroker/backups:
                      4.0K    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      18M     /opt/iobroker/iobroker-data/
                      15M     /opt/iobroker/iobroker-data/files
                      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                      3.5M    /opt/iobroker/iobroker-data/objects.jsonl
                      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.16.0
                      /usr/bin/node           v18.16.0
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Installed: 18.16.0-deb-1nodesource1
                        Candidate: 18.16.0-deb-1nodesource1
                        Version table:
                      No problems detected
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  4.0.24
                      admin:          6.3.5
                      javascript:     "javascript" not found
                      npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                      npm ERR! invalid: iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                      npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                      npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR!     /home/nulu/.npm/_logs/2023-04-23T17_52_10_992Z-debug-0.log
                      Adapters from github:   0
                      Adapter State
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                      Objects and States
                      Objects:        142
                      States:         104
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 http://deb.debian.org/debian bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13265      586/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          747        610/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15706      591/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15697      591/iobroker.js-con
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13264      586/cupsd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21681      2506/io.admin.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          749        610/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14638      429/avahi-daemon: r
                      udp        0      0 0.0.0.0:55672           0.0.0.0:*                           108        14640      429/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13255      525/dhcpcd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15364      629/cups-browsed
                      udp6       0      0 :::5353                 :::*                                108        14639      429/avahi-daemon: r
                      udp6       0      0 :::53577                :::*                                108        14641      429/avahi-daemon: r
                      2023-04-23 19:47:34.054  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-04-23 19:47:34.292  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-04-23 19:47:36.168  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2506
                      2023-04-23 19:47:36.527  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2513
                      2023-04-23 19:47:36.801  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2520
                      2023-04-23 19:47:41.401  - info: discovery.0 (2520) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2023-04-23 19:47:41.573  - info: admin.0 (2506) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2023-04-23 19:47:41.828  - info: discovery.0 (2520) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                      2023-04-23 19:47:41.912  - info: backitup.0 (2513) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                      2023-04-23 19:47:42.042  - info: admin.0 (2506) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                      2023-04-23 19:47:42.169  - info: admin.0 (2506) requesting all states
                      2023-04-23 19:47:42.221  - info: backitup.0 (2513) [iobroker] backup was activated at 02:00 every 90 day(s)
                      2023-04-23 19:47:42.171  - info: admin.0 (2506) requesting all objects
                      2023-04-23 19:47:44.040  - info: admin.0 (2506) received all objects
                      2023-04-23 19:47:44.833  - info: admin.0 (2506) http server listening on port 8081
                      2023-04-23 19:47:44.837  - info: admin.0 (2506) Use link "http://localhost:8081" to configure.
                      2023-04-23 19:47:44.866  - info: admin.0 (2506) socket.io server listening on port 8081
                      2023-04-23 19:47:45.104  - error: backitup.0 (2513) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
                      mount error(13): Permission denied
                      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                      2023-04-23 19:47:46.111  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                      2023-04-23 19:47:46.661  - info: admin.0 (2506) <== Disconnect system.user.admin from ::ffff:192.168.178.10 admin
                      2023-04-23 19:47:47.674  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                      2023-04-23 19:48:00.026  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                      Ein paar Error scheinen schon noch drin zu sein...
                      Hab nie VIS genutzt geschweige denn installiert.
                      • H Habedere
                        Full diag:
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=54.2'C
                        volt=1.3000V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        nulu
                        /home/nulu
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M        3.0M         96M
                                  909 M total memory
                                  447 M used memory
                                  491 M active memory
                                  105 M free memory
                                    2 M buffer memory
                                  354 M swap cache
                                   99 M total swap
                                    3 M used swap
                                   96 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        628M    /var/
                        245M    /var/cache
                        239M    /var/cache/apt
                        184M    /var/lib
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        142
                        States:         104
                        Pending Updates: 0
                        Thomas BraunT
                        Thomas BraunT
                        #97
                        Dann schalte den Desktop an der Kiste aus.
                        • H Habedere
                          Full diag:
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=54.2'C
                          volt=1.3000V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          nulu
                          /home/nulu
                          X-Server:       true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M        3.0M         96M
                                    909 M total memory
                                    447 M used memory
                                    491 M active memory
                                    105 M free memory
                                      2 M buffer memory
                                    354 M swap cache
                                     99 M total swap
                                      3 M used swap
                                     96 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          628M    /var/
                          245M    /var/cache
                          239M    /var/cache/apt
                          184M    /var/lib
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        142
                          States:         104
                          Pending Updates: 0
                          #98
                          X-Server: true
                          warum schleppst du mit den mickrigen 1GB RAM noch einen kompletten Desktop mit?
                          und die ELSPROBLEMS gefallen mir auch nicht.
                            H
                            H
                            Habedere
                            #99
                            Du meinst am Raspberry OS oder am ioBroker?
                            VIS möchte ich zukünftig evtl. schon nutzen...
                              X-Server: true
                              H
                              H
                              Habedere
                              #100
                              Weil ich nur Bahnhof verstehe :)
                              Ich schau gleich mal in die Einstellungen vom Raspberry OS
                              • H Habedere
                                Thomas BraunT
                                Thomas BraunT
                                #101
                                Mit Display an der gleichen Kiste?
                                Ich würde das nochmal installieren, diesmal gleich in der Lite-Version, ohne X-Server und ohne CUPS.
                                H 2 Antworten Letzte Antwort
                                  H
                                  H
                                  Habedere
                                  #102
                                  nene - extern.
                                  Alles klar - ich mach nochmal alles neu...
                                  • H Habedere
                                    nene - extern.
                                    Thomas BraunT
                                    Thomas BraunT
                                    #103
                                    nene - extern.
                                    Dann brauchst du natürlich auf dem Server auch keinen X-Server/Desktop.
                                      H
                                      H
                                      Habedere
                                      #104
                                      Neuer Versuch...
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                       20:04:34 up 50 min,  2 users,  load average: 0.30, 0.24, 0.30
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=51.5'C
                                      volt=1.2938V
                                                     Local time: Sun 2023-04-23 20:04:35 BST
                                                 Universal time: Sun 2023-04-23 19:04:35 UTC
                                                       RTC time: n/a
                                                      Time zone: Europe/London (BST, +0100)
                                                    NTP service: active
                                                RTC in local TZ: no
                                      nulu
                                      /home/nulu
                                      nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      Boot Target:    multi-user.target
                                      *** MEMORY ***
                                      Mem:            909M        232M        452M        0.0K        224M        613M
                                      Swap:            99M         18M         81M
                                      Total:          1.0G        250M        533M
                                                909 M total memory
                                                232 M used memory
                                                122 M active memory
                                                233 M inactive memory
                                                452 M free memory
                                                 24 M buffer memory
                                                200 M swap cache
                                                 99 M total swap
                                                 18 M used swap
                                                 81 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/root      ext4      110G  2.3G  104G   3% /
                                      tmpfs          tmpfs     182M  1.1M  181M   1% /run
                                      /dev/sda1      vfat      255M   31M  225M  12% /boot
                                      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                      [Sun Apr 23 19:13:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Sun Apr 23 19:14:02 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                      [Sun Apr 23 19:14:02 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                      [Sun Apr 23 19:14:06 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                                      /var:
                                      458M    /var/
                                      179M    /var/cache
                                      173M    /var/cache/apt
                                      147M    /var/lib
                                      122M    /var/lib/apt/lists
                                      Archived and active journals take up 32.0M in the file system.
                                      384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        142
                                      States:         104
                                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Pending Updates: 19
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12940      821/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32536      7399/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32529      7399/iobroker.js-co
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12942      821/sshd: /usr/sbin
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31304      7481/io.admin.0
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14288      920/dhcpcd
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11804      428/avahi-daemon: r
                                      udp        0      0 0.0.0.0:47649           0.0.0.0:*                           108        11806      428/avahi-daemon: r
                                      udp6       0      0 :::54407                :::*                                108        11807      428/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        11805      428/avahi-daemon: r
                                      2023-04-23 19:25:03.203  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                      2023-04-23 19:25:03.206  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                      2023-04-23 19:25:04.032  - info: host.raspberrypi connected to Objects and States
                                      2023-04-23 19:25:04.118  - info: host.raspberrypi Node.js version has changed from unknown to 18.16.0
                                      2023-04-23 19:25:04.231  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                      2023-04-23 19:25:04.292  - info: host.raspberrypi added notifications configuration of host
                                      2023-04-23 19:25:05.103  - info: host.raspberrypi 3 instances found
                                      2023-04-23 19:25:05.124  - info: host.raspberrypi starting 3 instances
                                      2023-04-23 19:25:05.241  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7481
                                      2023-04-23 19:25:09.197  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7488
                                      2023-04-23 19:25:10.651  - info: admin.0 (7481) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                                      2023-04-23 19:25:10.780  - info: admin.0 (7481) requesting all states
                                      2023-04-23 19:25:10.782  - info: admin.0 (7481) requesting all objects
                                      2023-04-23 19:25:11.389  - info: admin.0 (7481) received all objects
                                      2023-04-23 19:25:12.036  - info: admin.0 (7481) http server listening on port 8081
                                      2023-04-23 19:25:12.039  - info: admin.0 (7481) Use link "http://localhost:8081" to configure.
                                      2023-04-23 19:25:12.101  - info: admin.0 (7481) socket.io server listening on port 8081
                                      2023-04-23 19:25:12.257  - warn: admin.0 (7481) Repository cannot be read: Active repo - stable
                                      2023-04-23 19:25:12.262  - warn: admin.0 (7481) Active repository "stable" cannot be read
                                      2023-04-23 19:25:13.215  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7516
                                      2023-04-23 19:25:14.316  - info: discovery.0 (7488) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                                      2023-04-23 19:25:18.369  - info: backitup.0 (7516) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                                      2023-04-23 19:25:18.629  - info: backitup.0 (7516) [iobroker] backup was activated at 02:40 every 1 day(s)
                                      2023-04-23 19:25:24.768  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                      2023-04-23 19:25:44.524  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                      • H Habedere
                                        Neuer Versuch...
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=51.5'C
                                        volt=1.2938V
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        nulu
                                        /home/nulu
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M         18M         81M
                                                  909 M total memory
                                                  232 M used memory
                                                  122 M active memory
                                                  452 M free memory
                                                   24 M buffer memory
                                                  200 M swap cache
                                                   99 M total swap
                                                   18 M used swap
                                                   81 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        458M    /var/
                                        179M    /var/cache
                                        173M    /var/cache/apt
                                        147M    /var/lib
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        142
                                        States:         104
                                        Pending Updates: 19
                                        Thomas BraunT
                                        Thomas BraunT
                                        #105
                                        Zeitzone setzen.
                                        Pending Updates: 19
                                        System auf Stand halten.
                                          Zeitzone setzen.
                                          Pending Updates: 19
                                          H
                                          H
                                          Habedere
                                          #106
                                          Beides erledgit - also Zeit fürs Backup?
                                          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                          Kernel:                 6.1.21-v8+
                                          Installation:           Native
                                          Timezone:               Europe/London (BST, +0100)
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Pending iob updates:    0
                                          nulu@raspberrypi:~ $ date
                                          Sun 23 Apr 21:27:45 CEST 2023
                                          83.9k
