  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 261.5k Aufrufe 52 Beobachtet
    @habedere
    Und kommt der jetzt auf die Beine?
    H
    H
    Habedere
    #86
    Leider nein - hängt immer noch an der selben stelle :(
    Also quasi noch schlechter wie vorher....
    • H Habedere
      Thomas BraunT
      Thomas BraunT
      #87
      @habedere sagte in Troubleshooting NodeJS update:
      Heißt?
      H 1 Antwort Letzte Antwort
        Heißt?
        H
        H
        Habedere
        #88
        Freeze
        nulu@raspberrypi:/opt/iobroker $ cd /opt/iobroker
        npm ls | grep -E 'github|ERR'
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
        npm ERR!     /home/iobroker/.npm/_logs/2023-04-23T11_39_17_688Z-debug-0.log
        sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not tran        sfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        ^C^C###############) ⠧ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.3.5.tgz 52083ms (cache miss)
        • H Habedere
          Freeze
          Thomas BraunT
          Thomas BraunT
          #89
          Freeze
          Glaube ich nicht. Lass das mal laufen.
            Freeze
            H
            H
            Habedere
            schrieb am zuletzt editiert von Habedere
            #90
            Mach ich - steht halt schon seit ner guten 2 Stunden an der selben Stelle ;)
            • H Habedere
              H
              H
              Habedere
              #91
              @habedere
              Also Shell hat sich nicht mehr bewegt und nach dem ich das Terminal geschlossen habe war eine erneute Anmeldung über SSH nicht möglich. Hab dann den Strom ziehen müssen - aber siehe da, es läuft :)
              nulu@raspberrypi:~ $ /opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs &>        /dev/null
              uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx        -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt u        pdate &> /dev/null && sudo apt update && apt policy nodejs
              aarch64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v18.16.0
              v18.16.0
              9.5.1
              9.5.1
              4.0.24
              nulu
              nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobr                                                           oker
              tty
              /home/nulu
              OK:1 http://deb.debian.org/debian bullseye InRelease
              OK:2 http://deb.debian.org/debian bullseye-updates InRelease
              OK:3 http://security.debian.org/debian-security bullseye-security InRelease
              OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
              Alle Pakete sind aktuell.
              nodejs:
                Installiert:           18.16.0-deb-1nodesource1
                Installationskandidat: 18.16.0-deb-1nodesource1
                Versionstabelle:
               *** 18.16.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.5~dfsg-2~11u1 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              Werde jetzt mal das Backup einspielen...
              Vielen vielen Dank für die Hilfe!
              HomoranH H 3 Antworten Letzte Antwort
              • H Habedere
                @habedere
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v18.16.0
                v18.16.0
                9.5.1
                9.5.1
                4.0.24
                nulu
                tty
                /home/nulu
                nodejs:
                  Versionstabelle:
                #92
                nein!
                • H Habedere
                  @habedere
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v18.16.0
                  v18.16.0
                  9.5.1
                  9.5.1
                  4.0.24
                  nulu
                  tty
                  /home/nulu
                  nodejs:
                    Versionstabelle:
                  #93
                  wirklich oder nur scheinbar?
                  bitte Ausgabe von iob diag in der Vollversion
                  • H Habedere
                    @habedere
                    aarch64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v18.16.0
                    v18.16.0
                    9.5.1
                    9.5.1
                    4.0.24
                    nulu
                    tty
                    /home/nulu
                    nodejs:
                      Versionstabelle:
                    H
                    H
                    Habedere
                    #94
                    @habedere
                    Gestopt! Why?
                    • H Habedere
                      @habedere
                      Gestopt! Why?
                      #95
                      @habedere
                      Gestopt! Why?
                      einmal s.o. und zum zweiten: hast du vis manuell installiert?
                      und gestoppt ist abgebrochen ist undefinierter Zustand?
                        @habedere
                        Gestopt! Why?
                        H
                        H
                        Habedere
                        #96
                        sorry - mit gestopt meinte ich mich. Hab das Backup noch nicht gestartet weil ich gerade noch deine Nachricht gelesen habe. Hab nur die json des Backup-Adapter eingespielt damit die Zugangsdaten zum Server etc. wieder drin sind...
                        Full diag:
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Model           : Raspberry Pi 3 Model B Rev 1.2
                        Architecture    : aarch64
                        Docker          : false
                        Virtualization  : none
                        Distributor ID: Debian
                        Description:    Debian GNU/Linux 11 (bullseye)
                        Release:        11
                        Codename:       bullseye
                        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                        NAME="Debian GNU/Linux"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=debian
                        HOME_URL="https://www.debian.org/"
                        SUPPORT_URL="https://www.debian.org/support"
                        BUG_REPORT_URL="https://bugs.debian.org/"
                        Systemuptime and Load:
                         19:51:34 up 14 min,  3 users,  load average: 0.91, 0.88, 0.56
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        Other values than 0x0 hint to temperature/voltage problems
                        temp=54.2'C
                        volt=1.3000V
                        *** Time and Time Zones ***
                                       Local time: Sun 2023-04-23 19:51:34 CEST
                                   Universal time: Sun 2023-04-23 17:51:34 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        nulu
                        /home/nulu
                        nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            909M        447M        105M        9.0M        356M        389M
                        Swap:            99M        3.0M         96M
                        Total:          1.0G        450M        201M
                                  909 M total memory
                                  447 M used memory
                                  491 M active memory
                                  192 M inactive memory
                                  105 M free memory
                                    2 M buffer memory
                                  354 M swap cache
                                   99 M total swap
                                    3 M used swap
                                   96 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4      110G  4.3G  101G   5% /
                        devtmpfs       devtmpfs  325M     0  325M   0% /dev
                        tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                        tmpfs          tmpfs     182M  1.2M  181M   1% /run
                        /dev/sda1      vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs      91M   20K   91M   1% /run/user/1000
                        [Sun Apr 23 19:37:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bdb8b6dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                        [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): write access will be enabled during recovery
                        [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): recovery complete
                        [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Apr 23 19:37:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Sun Apr 23 19:37:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET  SOURCE    FSTYPE OPTIONS
                        /       /dev/sda2 ext4   rw,noatime
                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        628M    /var/
                        245M    /var/cache
                        239M    /var/cache/apt
                        184M    /var/lib
                        138M    /var/cache/apt/archives
                        Archived and active journals take up 96.0M in the file system.
                        /opt/iobroker/backups:
                        4.0K    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        18M     /opt/iobroker/iobroker-data/
                        15M     /opt/iobroker/iobroker-data/files
                        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        3.5M    /opt/iobroker/iobroker-data/objects.jsonl
                        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                        652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.16.0
                        /usr/bin/node           v18.16.0
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Installed: 18.16.0-deb-1nodesource1
                          Candidate: 18.16.0-deb-1nodesource1
                          Version table:
                        No problems detected
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          6.3.5
                        javascript:     "javascript" not found
                        npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                        npm ERR! invalid: iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                        npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                        npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR!     /home/nulu/.npm/_logs/2023-04-23T17_52_10_992Z-debug-0.log
                        Adapters from github:   0
                        Adapter State
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                        Objects and States
                        Objects:        142
                        States:         104
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13265      586/cupsd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          747        610/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15706      591/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15697      591/iobroker.js-con
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13264      586/cupsd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21681      2506/io.admin.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          749        610/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14638      429/avahi-daemon: r
                        udp        0      0 0.0.0.0:55672           0.0.0.0:*                           108        14640      429/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13255      525/dhcpcd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15364      629/cups-browsed
                        udp6       0      0 :::5353                 :::*                                108        14639      429/avahi-daemon: r
                        udp6       0      0 :::53577                :::*                                108        14641      429/avahi-daemon: r
                        2023-04-23 19:47:34.054  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-04-23 19:47:34.292  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-04-23 19:47:36.168  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2506
                        2023-04-23 19:47:36.527  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2513
                        2023-04-23 19:47:36.801  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2520
                        2023-04-23 19:47:41.401  - info: discovery.0 (2520) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-04-23 19:47:41.573  - info: admin.0 (2506) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-04-23 19:47:41.828  - info: discovery.0 (2520) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                        2023-04-23 19:47:41.912  - info: backitup.0 (2513) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                        2023-04-23 19:47:42.042  - info: admin.0 (2506) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                        2023-04-23 19:47:42.169  - info: admin.0 (2506) requesting all states
                        2023-04-23 19:47:42.221  - info: backitup.0 (2513) [iobroker] backup was activated at 02:00 every 90 day(s)
                        2023-04-23 19:47:42.171  - info: admin.0 (2506) requesting all objects
                        2023-04-23 19:47:44.040  - info: admin.0 (2506) received all objects
                        2023-04-23 19:47:44.833  - info: admin.0 (2506) http server listening on port 8081
                        2023-04-23 19:47:44.837  - info: admin.0 (2506) Use link "http://localhost:8081" to configure.
                        2023-04-23 19:47:44.866  - info: admin.0 (2506) socket.io server listening on port 8081
                        2023-04-23 19:47:45.104  - error: backitup.0 (2513) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
                        mount error(13): Permission denied
                        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                        2023-04-23 19:47:46.111  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                        2023-04-23 19:47:46.661  - info: admin.0 (2506) <== Disconnect system.user.admin from ::ffff:192.168.178.10 admin
                        2023-04-23 19:47:47.674  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                        2023-04-23 19:48:00.026  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                        Ein paar Error scheinen schon noch drin zu sein...
                        Hab nie VIS genutzt geschweige denn installiert.
                        • H Habedere
                          Full diag:
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=54.2'C
                          volt=1.3000V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          nulu
                          /home/nulu
                          X-Server:       true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M        3.0M         96M
                                    909 M total memory
                                    447 M used memory
                                    491 M active memory
                                    105 M free memory
                                      2 M buffer memory
                                    354 M swap cache
                                     99 M total swap
                                      3 M used swap
                                     96 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          628M    /var/
                          245M    /var/cache
                          239M    /var/cache/apt
                          184M    /var/lib
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        142
                          States:         104
                          Pending Updates: 0
                          Thomas BraunT
                          Thomas BraunT
                          #97
                          Dann schalte den Desktop an der Kiste aus.
                          • H Habedere
                            Full diag:
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        11
                            Codename:       bullseye
                            VERSION_ID="11"
                            ID=debian
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=54.2'C
                            volt=1.3000V
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            nulu
                            /home/nulu
                            X-Server:       true
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M        3.0M         96M
                                      909 M total memory
                                      447 M used memory
                                      491 M active memory
                                      105 M free memory
                                        2 M buffer memory
                                      354 M swap cache
                                       99 M total swap
                                        3 M used swap
                                       96 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            628M    /var/
                            245M    /var/cache
                            239M    /var/cache/apt
                            184M    /var/lib
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.3.5
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        142
                            States:         104
                            Pending Updates: 0
                            #98
                            X-Server: true
                            warum schleppst du mit den mickrigen 1GB RAM noch einen kompletten Desktop mit?
                            und die ELSPROBLEMS gefallen mir auch nicht.
                              H
                              H
                              Habedere
                              #99
                              Du meinst am Raspberry OS oder am ioBroker?
                              VIS möchte ich zukünftig evtl. schon nutzen...
                                X-Server: true
                                H
                                H
                                Habedere
                                #100
                                Weil ich nur Bahnhof verstehe :)
                                Ich schau gleich mal in die Einstellungen vom Raspberry OS
                                • H Habedere
                                  Thomas BraunT
                                  Thomas BraunT
                                  #101
                                  Mit Display an der gleichen Kiste?
                                  Ich würde das nochmal installieren, diesmal gleich in der Lite-Version, ohne X-Server und ohne CUPS.
                                  H 2 Antworten Letzte Antwort
                                    H
                                    H
                                    Habedere
                                    #102
                                    nene - extern.
                                    Alles klar - ich mach nochmal alles neu...
                                    • H Habedere
                                      nene - extern.
                                      Thomas BraunT
                                      Thomas BraunT
                                      #103
                                      nene - extern.
                                      Dann brauchst du natürlich auf dem Server auch keinen X-Server/Desktop.
                                        H
                                        H
                                        Habedere
                                        #104
                                        Neuer Versuch...
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                         20:04:34 up 50 min,  2 users,  load average: 0.30, 0.24, 0.30
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=51.5'C
                                        volt=1.2938V
                                                       Local time: Sun 2023-04-23 20:04:35 BST
                                                   Universal time: Sun 2023-04-23 19:04:35 UTC
                                                         RTC time: n/a
                                                        Time zone: Europe/London (BST, +0100)
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        nulu
                                        /home/nulu
                                        nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            909M        232M        452M        0.0K        224M        613M
                                        Swap:            99M         18M         81M
                                        Total:          1.0G        250M        533M
                                                  909 M total memory
                                                  232 M used memory
                                                  122 M active memory
                                                  233 M inactive memory
                                                  452 M free memory
                                                   24 M buffer memory
                                                  200 M swap cache
                                                   99 M total swap
                                                   18 M used swap
                                                   81 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      110G  2.3G  104G   3% /
                                        tmpfs          tmpfs     182M  1.1M  181M   1% /run
                                        /dev/sda1      vfat      255M   31M  225M  12% /boot
                                        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                        [Sun Apr 23 19:13:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Sun Apr 23 19:14:02 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Sun Apr 23 19:14:02 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Sun Apr 23 19:14:06 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                                        /var:
                                        458M    /var/
                                        179M    /var/cache
                                        173M    /var/cache/apt
                                        147M    /var/lib
                                        122M    /var/lib/apt/lists
                                        Archived and active journals take up 32.0M in the file system.
                                        384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        142
                                        States:         104
                                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Pending Updates: 19
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12940      821/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32536      7399/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32529      7399/iobroker.js-co
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12942      821/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31304      7481/io.admin.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14288      920/dhcpcd
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11804      428/avahi-daemon: r
                                        udp        0      0 0.0.0.0:47649           0.0.0.0:*                           108        11806      428/avahi-daemon: r
                                        udp6       0      0 :::54407                :::*                                108        11807      428/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        11805      428/avahi-daemon: r
                                        2023-04-23 19:25:03.203  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                        2023-04-23 19:25:03.206  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                        2023-04-23 19:25:04.032  - info: host.raspberrypi connected to Objects and States
                                        2023-04-23 19:25:04.118  - info: host.raspberrypi Node.js version has changed from unknown to 18.16.0
                                        2023-04-23 19:25:04.231  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                        2023-04-23 19:25:04.292  - info: host.raspberrypi added notifications configuration of host
                                        2023-04-23 19:25:05.103  - info: host.raspberrypi 3 instances found
                                        2023-04-23 19:25:05.124  - info: host.raspberrypi starting 3 instances
                                        2023-04-23 19:25:05.241  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7481
                                        2023-04-23 19:25:09.197  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7488
                                        2023-04-23 19:25:10.651  - info: admin.0 (7481) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                                        2023-04-23 19:25:10.780  - info: admin.0 (7481) requesting all states
                                        2023-04-23 19:25:10.782  - info: admin.0 (7481) requesting all objects
                                        2023-04-23 19:25:11.389  - info: admin.0 (7481) received all objects
                                        2023-04-23 19:25:12.036  - info: admin.0 (7481) http server listening on port 8081
                                        2023-04-23 19:25:12.039  - info: admin.0 (7481) Use link "http://localhost:8081" to configure.
                                        2023-04-23 19:25:12.101  - info: admin.0 (7481) socket.io server listening on port 8081
                                        2023-04-23 19:25:12.257  - warn: admin.0 (7481) Repository cannot be read: Active repo - stable
                                        2023-04-23 19:25:12.262  - warn: admin.0 (7481) Active repository "stable" cannot be read
                                        2023-04-23 19:25:13.215  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7516
                                        2023-04-23 19:25:14.316  - info: discovery.0 (7488) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                                        2023-04-23 19:25:18.369  - info: backitup.0 (7516) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                                        2023-04-23 19:25:18.629  - info: backitup.0 (7516) [iobroker] backup was activated at 02:40 every 1 day(s)
                                        2023-04-23 19:25:24.768  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                        2023-04-23 19:25:44.524  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                        • H Habedere
                                          Neuer Versuch...
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=51.5'C
                                          volt=1.2938V
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          nulu
                                          /home/nulu
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M         18M         81M
                                                    909 M total memory
                                                    232 M used memory
                                                    122 M active memory
                                                    452 M free memory
                                                     24 M buffer memory
                                                    200 M swap cache
                                                     99 M total swap
                                                     18 M used swap
                                                     81 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          458M    /var/
                                          179M    /var/cache
                                          173M    /var/cache/apt
                                          147M    /var/lib
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        142
                                          States:         104
                                          Pending Updates: 19
                                          Thomas BraunT
                                          Thomas BraunT
                                          #105
                                          Zeitzone setzen.
                                          Pending Updates: 19
                                          System auf Stand halten.
                                          83.8k
