  4. {"errno":-111,"code":"ECONNREFUSED","...
    5.4k
52 Beiträge 5 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • DuffyD Duffy
    @glasfaser
    Guten Abend glasfaser, anbei die Antworten auf die Fragen; ich hoffe es enspricht den Anforderungen:
    pi@raspberrypi:~ $ sudo apt update
    Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [233 kB]
    Fetched 233 kB in 2s (109 kB/s)
    Reading package lists... Done
    All packages are up to date.
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ apt policy influxdb*
    influxdb2-cli:
      Installed: 2.7.1-2
      Candidate: 2.7.1-2
      Version table:
     *** 2.7.1-2 500
            500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    influxdb-client:
      Installed: (none)
      Candidate: 1.6.7~rc0-1+b5
      Version table:
         1.6.7~rc0-1+b5 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    influxdb-dev:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb2-client:
      Installed: (none)
      Candidate: 2.7.1-1
      Version table:
         2.7.1-1 500
    influxdb:
      Installed: (none)
      Candidate: 1.8.10-1
      Version table:
         1.8.10-1 500
         1.6.7~rc0-1+b5 500
    influxdb2:
      Installed: 2.7.0-1
      Candidate: 2.7.0-1
      Version table:
     *** 2.7.0-1 500
         2.6.1-1 500
         2.6.0-1 500
         2.5.1-1 500
         2.4.0-1 500
         2.3.0-1 500
         2.2.0 500
    pi@raspberrypi:~ $
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     18:15:49 up 9 min,  3 users,  load average: 0.27, 0.80, 0.57
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=39.4'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Mon 2023-04-17 18:15:49 CEST
               Universal time: Mon 2023-04-17 16:15:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.8G        1.1G         21M        893M        1.9G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        1.2G
             3794 M total memory
             1817 M used memory
             2060 M active memory
              449 M inactive memory
             1082 M free memory
               72 M buffer memory
              821 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  5.7G   51G  11% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Mon Apr 17 18:06:37 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:B3:1A:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e938ada4-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Apr 17 18:06:38 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Apr 17 18:06:38 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Apr 17 18:06:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    521M    /var/
    179M    /var/lib
    161M    /var/cache
    154M    /var/cache/apt
    122M    /var/lib/apt/lists
    Archived and active journals take up 80.0M in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    304M    /opt/iobroker/iobroker-data/
    264M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        6147
    States:         5432
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14751      580/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16754      672/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15217      672/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18751      1621/cupsd
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          12060      566/vncserver-x11-c
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       16235      1652/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18813      1667/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14753      580/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18750      1621/cupsd
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12145      441/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22270      3020/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18708      1225/io.admin.0
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          12059      566/vncserver-x11-c
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14877      484/dhcpcd
    udp        0      0 0.0.0.0:45475           0.0.0.0:*                           108        1911       407/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18404      1622/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1909       407/avahi-daemon: r
    udp6       0      0 :::56432                :::*                                108        1912       407/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1910       407/avahi-daemon: r
    2023-04-17 18:08:44.507  - info: switchbot-hub.0 (2940) All devices and values loaded, adapter ready
    2023-04-17 18:08:44.631  - info: tankerkoenig.0 (2956) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 18:08:44.743  - info: tankerkoenig.0 (2956) Adapter is already in daemon mode
    2023-04-17 18:08:44.744  - info: tankerkoenig.0 (2956) Sync time set to 10 minutes or 600000 ms
    2023-04-17 18:08:45.100  - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 2975
    2023-04-17 18:08:49.197  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 2986
    2023-04-17 18:08:49.422  - info: text2command.0 (2975) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 18:08:53.000  - info: vis-inventwo.0 (2986) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 18:08:57.140  - info: vis.0 (3005) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 18:08:57.248  - info: host.raspberrypi instance system.adapter.web.0 started with pid 3020
    2023-04-17 18:08:57.734  - info: vis.0 (3005) vis license is OK.
    2023-04-17 18:09:01.894  - info: vis.0 (3005) Terminated (NO_ERROR): Without reason
    2023-04-17 18:09:02.091  - info: alexa2.0 (1676) Subscribing to states...
    2023-04-17 18:09:02.524  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2023-04-17 18:09:02.733  - info: web.0 (3020) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 18:09:03.236  - info: web.0 (3020) socket.io server listening on port 8082
    2023-04-17 18:09:03.246  - info: web.0 (3020) http server listening on port 8082
    2023-04-17 18:09:04.333  - info: alexa2.0 (1676) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-04-17 18:09:06.164  - info: tankerkoenig.0 (2956) Start first request
    2023-04-17 18:09:30.583  - info: alexa2.0 (1676) Initialization Done ...
    2023-04-17 18:09:41.318  - info: admin.0 (1225) ==> Connected system.user.admin from ::ffff:192.168.178.116
    2023-04-17 18:09:47.656  - info: admin.0 (1225) ==> Connected system.user.admin from ::ffff:192.168.178.116
    2023-04-17 18:13:14.233  - info: fritzdect.0 (1808) DECT ID: 130770143150-1 identified for command (state) : false
    2023-04-17 18:13:14.274  - info: fritzdect.0 (1808) DECT ID: 130770137317-1 identified for command (state) : false
    2023-04-17 18:13:14.280  - info: fritzdect.0 (1808) DECT ID: 130770151284-1 identified for command (state) : false
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        1.9G        1.0G         21M        896M        1.8G
    Swap:            99M          0B         99M
    Total:          3.9G        1.9G        1.1G
    Active iob-Instances:   29
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                6147
    States:                 5432
    Size of iob-Database:
    8.0M    /opt/iobroker/iobroker-data/states.jsonl
    So das sollte es gewesen sein. Ich hoffe es hift der Fehlerfindung weiter.
    Noch 1 Screenshots der vielleicht noch was helfen kann.
    Vielen Grüße Duffy
    @duffy
    Den influxdb2-client musst du noch nachinstallieren.
    Und den Desktop würde ich auch ausknipsen.
    DuffyD 1 Antwort Letzte Antwort
      @duffy
      DuffyD Online
      DuffyD Online
      Duffy
      schrieb am zuletzt editiert von Duffy
      Hallo thomas-braun,
      "Den influxdb2-client musst du noch nachinstallieren."
      Wie geht das? ich habe influxDB so installiert wie es im ioBrokerkurs gezeigt wurde, sowohl bei der Erstinstallation von der auch die Backups kommen als auch bei der Neuinstallation.
      Aber wenn du mir sagst wie das geht würde ich das gerne mal nachholen.
      "Und den Desktop würde ich auch ausknipsen."
      du meinst über Sudo raspi-config?
      Den Desktop hatte ich eigentlich nur installiert um Wlan und Bluetooth abzuschalten
      Viele Grüße Duffy
      Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
      Node.js: v22.23.1
      NPM: 10.9.4
      js-controller 7.1.2
      Linux: Trixie
      • DuffyD Duffy
        Hallo thomas-braun,
        Viele Grüße Duffy
        @duffy
        Ich glaube ich hab das was verwechselt.
        influxdb2-cli ist ja installiert.
        Haben die das bei influx jetzt anders gepackt?
        Was ist der Unterschied zwischen influxdb2-cli und influxdb2-client? Ich meine bislang wäre das nur ein Zusatz-Paket gewesen.
        • DuffyD Duffy
          Hallo thomas-braun,
          Viele Grüße Duffy
          @duffy sagte in {"errno":-111,"code":"ECONNREFUSED","...:
          Kann man alles in raspi-config machen. Natürlich auch ohne Desktop. Wäre ja widersinnig, wenn das nicht auch per Kommandozeile ginge.
            @duffy
            DuffyD Online
            DuffyD Online
            Duffy
            Ich kann da gar nichts zu sagen, ich tippe (kopiere) einfach nur die Befehle.
            Aber die waren so:
            wget -qO- https://repos.influxdata.com/influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
            echo "deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
            sudo apt update
            sudo apt full-upgrade
            sudo apt install influxdb2
            sudo service influxdb start
            Vielleicht hilft dir das bei der Antwort zu deiner Fage.
            Gruß Duffy
            Node.js: v22.23.1
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
              DuffyD Online
              DuffyD Online
              Duffy
              "Kann man alles in raspi-config machen. Natürlich auch ohne Desktop. Wäre ja widersinnig, wenn das nicht auch per Kommandozeile ginge."
              Wie vermutlich unschwer zu erkennen ist bin ich blutiger Pi Anfänger und da hat man mir das so geraten.
              Es wäre fast nicht möglich ohne Desktopoberfläche Wlan und Bluetooth auszuschalten.
              Auch hatte ich im Netz gelesen das beim Pi das Wlan nie wirklich richtig aus ist.
              Wo hätte ich das den in der config oder über Komandozeile einstellen müssen, mit welchen Befehlen?
              Gruß Duffy
              Node.js: v22.23.1
              NPM: 10.9.4
              js-controller 7.1.2
              Linux: Trixie
              • DuffyD Duffy
                Gruß Duffy
                Das ist richtig, da liegt immer Spannung an und der funkt da lustig leer durch die Gegend.
                Ich meinte unter Interfaces kann man Bluetooth ausknipsen. WLAN einfach nicht konfigurieren.
                • Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @thomas-braun sagte in {"errno":-111,"code":"ECONNREFUSED","...:
                  "influxdb2-client" kenne ich nur in Verbindung mit Python und hat meines Wissens nichts mit der CLI zu tun. influxdb2-cli ist das, was man hier benötigt
                  • Marc BergM Marc Berg
                    DuffyD Online
                    DuffyD Online
                    Duffy
                    @marc-berg
                    Hallo marc-berg,
                    „influxdb2-cli ist das, was man hier benötigt“
                    Soll das heissen das das bei mir fehlt? Ich bin etwas verwirrt.
                    Viele Grüße
                    Node.js: v22.23.1
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                    • DuffyD Duffy
                      @marc-berg
                      Hallo marc-berg,
                      Viele Grüße
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      @marc-berg
                      Hallo marc-berg,
                      Viele Grüße
                      Hast Du doch drauf. Alles gut (von DER Seite)
                        @marc-berg
                        Hallo marc-berg,
                        Viele Grüße
                        DuffyD Online
                        DuffyD Online
                        Duffy
                        @marc-berg
                        Danke schön.
                        Gruß Duffy
                        Node.js: v22.23.1
                        NPM: 10.9.4
                        js-controller 7.1.2
                        Linux: Trixie
                        Marc BergM simatecS 2 Antworten Letzte Antwort
                        • DuffyD Duffy
                          @marc-berg
                          Danke schön.
                          Gruß Duffy
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          @duffy
                          Was ist jetzt eigentlich aus deinem Problem geworden?
                            @duffy
                            DuffyD Online
                            DuffyD Online
                            Duffy
                            @marc-berg
                            Leider noch nichts.
                            Viele Grüße
                            Node.js: v22.23.1
                            NPM: 10.9.4
                            js-controller 7.1.2
                            Linux: Trixie
                            • DuffyD Duffy
                              @marc-berg
                              Leider noch nichts.
                              Viele Grüße
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Leider noch nichts.
                              Viele Grüße
                              Das ist sehr seltsam. Wenn du influxdb V2 auswählst, dürfte niemals Port 8088 angemeckert werden. Die V2 kommuniziert ausschließlich via 8086. Da ist irgendwas schief. Mein erster Versuch wäre, einfach nochmal die Auswahlfelder für die DB Version von 2.x auf 1.x und zurück zu ändern, zwischendurch mal speichern. Try and error, aber was soll's...
                              • DuffyD Duffy
                                @marc-berg
                                Danke schön.
                                Gruß Duffy
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @duffy Erstmal würde ich das Backup lokal ablegen und dann aus der lokalen Quelle wiederherstellen.
                                FTP ist da nicht optimal
                                Dann gibt es in der Doku von Backitup eine Anleitung zum Restore von Influx 2.x
                                https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#influxdb2-restore
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                  Leider noch nichts.
                                  Viele Grüße
                                  DuffyD Online
                                  DuffyD Online
                                  Duffy
                                  @marc-berg
                                  Hast du den Backup Adapter im Einsatz für influxdb2?
                                  Node.js: v22.23.1
                                  NPM: 10.9.4
                                  js-controller 7.1.2
                                  Linux: Trixie
                                  • DuffyD Duffy
                                    @marc-berg
                                    Marc BergM Offline
                                    Marc BergM Offline
                                    Marc Berg
                                    @duffy ja
                                    • DuffyD Duffy
                                      @marc-berg
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @duffy Zeige doch mal deine Config als JSON.
                                      Kannst du in Backitup über die Pfeile oben rechts runterladen.
                                      So du nutzt influxdb2 .... War auf deinem alten System ebenfalls influxdb2 installiert oder hattest du dort noch die 1.x installiert?
                                      • simatecS simatec
                                        DuffyD Online
                                        DuffyD Online
                                        Duffy
                                        @simatec
                                        Hallo simatec,
                                        zu deiner Frage, ja ich habe auf dem Vorgängersystem auch influxdb2 installiert gehabt und es auch genau so wieder auf das neue iob System installiert; auch die genau gleiche Hardware. (Bin erst seit Januar 23 dabei, auch deshalb hatte ich nie Vers. 1)
                                        Vor diesem Beitrag habe ich die SD Karte über das zuvor erstellt Image wieder zurück gesetzt um dann neu zu starten.
                                        Ich habe natürlich Deine Anleitung gelesen, habe aber derzeit das Backup nur auf der Fritzbox als FTP. Da ich nicht weis wie ich die Daten vom FTP auf Lokal (vermutlich Linux) bringen soll habe ich versucht meine Sicherung von dort aus zu machen.
                                        Dummerweise verstehe ich auch die Anleitung nicht mit den Token und der Umstellung.
                                        Deshalb möchte ich dir mein Vorgehen erklären:
                                        Also, ich habe iob installiert und dann das iob Backup aufgespielt. Alles ging hervorragend.
                                        Dann habe ich influxDB2 installiert und den dort erzeugten Token in den influxDB Adapter vers. 3.2.0 eingefügt.
                                        (heute von SD image wiederhergestellt)
                                        Beim Backupadapter habe ich noch nichts gemacht da ich ja wie gesagt das mit der Anleitung nicht verstanden hatte; ist bestimmt noch der vom ersten System drin.
                                        (Man sieht an mir ist kein EV Fachmann verloren gegengen, sorry)
                                        dann habe ich wie von dir gewünscht die json heruntergeladen ((1)system.adapter.backitup.0.json)
                                        Danch habe ich versucht ein Backup zu erstellen.
                                        nachdem es nicht fertig wurde habe ich "schießen" geklickt
                                        Nach deiner Anleitung eigentlich klar das es nicht geht da der Backup Adapter keinen Token hatte, aber ich bekomme das ja nicht hin ;-(
                                        Dann noch mal eine json heruntergeladen weil ich ja nicht weis ob sich da durch den Versuch was geändert hat.
                                        ((2)system.adapter.backitup.0.json)
                                        (1)system.adapter.backitup.0.json (2)system.adapter.backitup.0.json
                                        So ist der aktuelle Stand. Ich hoffe ja nicht das mein Beitrag schon zur iob Forumweiten Erheiterung beiträgt 😕
                                        Viele Grüße Duffy
                                        Node.js: v22.23.1
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          @simatec
                                          Hallo simatec,
                                          Viele Grüße Duffy
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          @duffy Stelle es mal wie folgt ein .... (natürlich mit deinem gültigen Token und ganz wichtig Port 8086)
                                          Den Download kannst du wie folgt ausführen (Damit wird das Backup auf deinen PC geladen und liegt auch danach lokal auf deinem System.
                                          Danach kannst du die Quelle Lokal für den Restore wählen und den Restore starten.
