  4. Node-Red
  5. Shelly addon über Node Red
    6.4k
97 Beiträge 3 Kommentatoren 13.8k Aufrufe 2 Beobachtet
  • D Dirk 4
    @mickym ```
    code_text
    -rw-r--r-- 1 root root  142  9. Jun 2021  README
    iobroker@iobroker:/etc/mosquitto/conf.d $ cat local.conf
    listener 1884
    allow_anonymous true
    mickymM Offline
    mickymM Offline
    mickym
    @dirk-4 Das it den codetags schaut nun besser aus. Kannst du die Datei nochmal mit nano öffnen und schauen, dass Du nach dem allow_anonymous true noch ein Zeilenumbruch existiert.
    Dann bitte das log anschauen:
    sudo cat /var/log/mosquitto/mosquitto.log
    • mickymM mickym
      Dirk 4
      @mickym ```
      code_text
      iobroker@iobroker:/etc/mosquitto/conf.d $ sudo systemctl start mosquitto
      iobroker@iobroker:/etc/mosquitto/conf.d $ systemctl status mosquitto
      ● mosquitto.service - Mosquitto MQTT Broker
           Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
           Active: active (running) since Mon 2023-04-17 23:48:05 CEST; 10s ago
             Docs: man:mosquitto.conf(5)
                   man:mosquitto(8)
          Process: 2650140 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
          Process: 2650141 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
          Process: 2650142 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
          Process: 2650143 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
         Main PID: 2650144 (mosquitto)
            Tasks: 1 (limit: 4164)
              CPU: 42ms
           CGroup: /system.slice/mosquitto.service
                   └─2650144 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
      Apr 17 23:48:05 iobroker systemd[1]: Starting Mosquitto MQTT Broker...
      Apr 17 23:48:05 iobroker mosquitto[2650144]: 1681768085: Loading config file /etc/mosquitto/conf.d/local.conf
      Apr 17 23:48:05 iobroker systemd[1]: Started Mosquitto MQTT Broker.
      D mickymM 2 Antworten Letzte Antwort
      • D Dirk 4
        @mickym ```
        code_text
                     man:mosquitto(8)
                CPU: 42ms
        Dirk 4
        @dirk-4 jetzt aber
        • D Dirk 4
          @mickym ```
          code_text
                       man:mosquitto(8)
                  CPU: 42ms
          mickymM Offline
          mickymM Offline
          mickym
          @dirk-4 na das schaut doch gut aus. :) - Was
          @dirk-4 sagte in Shelly addon über Node Red:
          @dirk-4 jetzt aber
          Na das schaut doch gut aus, was hast Du geändert?
          • mickymM mickym
            @dirk-4 jetzt aber
            Dirk 4
            @mickym nur nochmal mit der leerzeile
            • D Dirk 4
              Dirk 4
              @dirk-4 ```
              code_text
              iobroker@iobroker:/etc/mosquitto/conf.d $ sudo cat /var/log/mosquitto/mosquitto.log
              1681765635: mosquitto version 2.0.11 starting
              1681765635: Config loaded from /etc/mosquitto/mosquitto.conf.
              1681765635: Starting in local only mode. Connections will only be possible from clients running on this machine.
              1681765635: Create a configuration file which defines a listener to allow remote access.
              1681765635: For more details see https://mosquitto.org/documentation/authentication-methods/
              1681765635: Opening ipv4 listen socket on port 1883.
              1681765635: Error: Address already in use
              1681765635: Opening ipv6 listen socket on port 1883.
              1681765635: mosquitto version 2.0.11 running
              1681766971: mosquitto version 2.0.11 terminating
              1681766971: Saving in-memory database to /var/lib/mosquitto//mosquitto.db.
              1681768085: mosquitto version 2.0.11 starting
              1681768085: Config loaded from /etc/mosquitto/mosquitto.conf.
              1681768085: Opening ipv4 listen socket on port 1884.
              1681768085: Opening ipv6 listen socket on port 1884.
              1681768085: mosquitto version 2.0.11 running
              • D Dirk 4
                mickymM Offline
                mickymM Offline
                mickym
                Na hatte ich die richtige Vermutung. ;)
                Das Log passt jetzt auch. Nun konfigurieren wir mosquitto noch dass es automatisch beim Systemstart mit startet:
                sudo systemctl enable mosquitto
                • mickymM mickym
                  Dirk 4
                  @mickym OK
                  • D Dirk 4
                    @mickym OK
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @dirk-4 Gut dann installieren wir nun den mqtt-Client/Server Adapter im iobroker.
                    Du installierst nun diesen Adapter im iobroker.
                    • mickymM mickym
                      Dirk 4
                      @mickym OK hab ich
                      • D Dirk 4
                        @mickym OK hab ich
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @mickym OK hab ich
                        In der Konfiguration bei Verbindung
                        gibst Du Port 1884 ein.
                        Und dann sollte die Verbindung zum Server klappen. Benutzer und Passwort hast Du keines.
                        • mickymM mickym
                          @mickym OK hab ich
                          Dirk 4
                          Ja verbindung ist da
                          • mickymM mickym
                            @mickym OK hab ich
                            mickymM Offline
                            mickymM Offline
                            mickym
                            Bei den mqtt Einstellungen schaust Du bitte das alle Haken weg sind:
                            Also Subscribe Patter steht ein: # (Hash)
                            Bei den eigenen States steht bei dir natürlich mqtt.0.*
                            Eine Client ID - kannst Du eingeben, musst Du aber nicht.
                            • D Dirk 4
                              mickymM Offline
                              mickymM Offline
                              mickym
                              Sehr gut. :) - Du bist Klasse. :) 👍 👍 👍
                              • mickymM mickym
                                Dirk 4
                                @mickym Danke ohne dich keine Chance
                                • D Dirk 4
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Wird schon - wenn Du was nicht verstehst, musst Du halt fragen. Hast Du die Haken bei dem mqtt-Einstellungen des Adapters alle raus gemacht?
                                  • mickymM mickym
                                    Dirk 4
                                    @mickym Ja hab ich
                                    • D Dirk 4
                                      @mickym Ja hab ich
                                      Dirk 4
                                      @dirk-4 Startet der moscito automatisch immer mit wenn ich neu starte?
                                      • D Dirk 4
                                        @mickym Ja hab ich
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @dirk-4 Gut dann werden wir jetzt mal aus NodeRed eine Mqtt Nachricht pubishen.
                                        Dazu ziehst Du bitte erst mal eine mqtt-Out Node in deinen Arbeitsbereich.
                                        • D Dirk 4
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          Ja das haben wir mit dem Kommando
                                          so eingestellt. Wenn Du das nicht willst, dann musst Du das mit
                                          sudo systemctl disable mosquitto
                                          wieder aufheben.
