  4. influxdb 1.8.10 läuft aber port 8086 antwortet nicht mehr
    5.4k
30 Beiträge 3 Kommentatoren 4.5k Aufrufe 3 Beobachtet
  • T ThomKast
    Hallo Thomas. Vielen Dank für Deine Antwort.
    Ich wollte damit auch nur gemeint haben, dass ich versuche "alles streng nach Vorschrift" zu machen :-)
    Skript v.2023-04-02
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 10 (buster)
    Release:	10
    Codename:	buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     23:35:26 up  1:09,  1 user,  load average: 3.17, 3.46, 3.73
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-04-10 23:35:26 CEST
               Universal time: Mon 2023-04-10 21:35:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           7.9G        2.2G        2.1G         53M        3.6G        6.0G
    Swap:           99M          0B         99M
    Total:         8.0G        2.2G        2.2G
             7941 M total memory
             2231 M used memory
              695 M active memory
             5014 M inactive memory
             2104 M free memory
              180 M buffer memory
             3425 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      110G   15G   89G  15% /
    devtmpfs       devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   49M  3.9G   2% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
    [Mon Apr 10 22:26:01 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:DC:9C:02 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=67f786c6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Apr 10 22:26:03 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Apr 10 22:26:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Apr 10 22:26:04 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET                       SOURCE       FSTYPE            OPTIONS
    /                            /dev/sda2    ext4              rw,noatime,stripe=8191
    |-/sys/fs/bpf                none         bpf               rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs        gvfsd-fuse   fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot                      /dev/sda1    vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    6.6G	/var/
    4.2G	/var/lib
    4.0G	/var/lib/influxdb
    3.9G	/var/lib/influxdb/data/HH_IoT/global
    /opt/iobroker/backups:
    184M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    321M	/opt/iobroker/iobroker-data/
    115M	/opt/iobroker/iobroker-data/backup-objects
    114M	/opt/iobroker/iobroker-data/files
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    32M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    37M	/opt/iobroker/iobroker-data/objects.jsonl
    9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
    9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.2M	/opt/iobroker/iobroker-data/states.jsonl
    6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.19.1
    /usr/bin/node 		v16.19.1
    /usr/bin/npm 		8.19.3
    /usr/local/bin/npx 		9.2.0
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    @thomkast
    Buster muss durch Bullseye ersetzt werden, Server werden ohne Desktop betrieben, das ist falsch:
    Und die Langfassung oben ist nicht vollständig.
    T 2 Antworten Letzte Antwort
      @thomkast
      ThomKast
      schrieb am zuletzt editiert von ThomKast
      Öhm, sorry.... In der Langfassung ist die erste Zeile zu der ich hoch rollen kann " === Start marking the full check here ===". Und ab dort habe ich alles markiert... bis zu " === Mark until here for C&P ==="
      Hier ein neuer Versuch
      Skript v.2023-04-02
      *** BASE SYSTEM ***
      Docker          : false
      Release:	10
      Codename:	buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
       23:44:20 up  1:18,  1 user,  load average: 3.31, 3.70, 3.83
      CPU threads: 4
                     Local time: Mon 2023-04-10 23:44:21 CEST
                 Universal time: Mon 2023-04-10 21:44:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Mem:           7.9G        2.3G        1.8G         55M        3.8G        5.8G
      Swap:           99M          0B         99M
      Total:         8.0G        2.3G        1.9G
               7941 M total memory
               2342 M used memory
                808 M active memory
               5193 M inactive memory
               1793 M free memory
                211 M buffer memory
               3594 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      tmpfs          tmpfs     3.9G   51M  3.9G   2% /run
      /var:
      6.6G	/var/
      4.2G	/var/lib
      325M	/opt/iobroker/iobroker-data/
      13M	/opt/iobroker/iobroker-data/states.jsonl
      /usr/bin/npm 		8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.23
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	1
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
      + system.adapter.bydhvs.0                 : bydhvs                : raspberrypi                              -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.10                : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.11                : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.3                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.4                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.5                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.6                 : modbus                : raspberrypi                              -  enabled
        system.adapter.modbus.7                 : modbus                : raspberrypi                              - disabled
      + system.adapter.modbus.8                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.9                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.plenticore.0             : plenticore            : raspberrypi                              -  enabled, port: 443
      + system.adapter.plenticore.1             : plenticore            : raspberrypi                              -  enabled, port: 443
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              - disabled
      + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.tibberconnect.0          : tibberconnect         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
        system.adapter.warp.0                   : warp                  : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_980636923f98ec1187429fd044d80d13-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "bydhvs"       : 1.4.0    , installed 1.4.0
      Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
      Adapter    "warp"         : 1.2.2    , installed 1.2.2
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects: 	8232
      States: 	7631
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian any-version InRelease [5124 B]
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Fetched 5124 B in 4s (1241 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        15968      451/systemd-resolve
      tcp        0      0 192.168.111.253:502     0.0.0.0:*               LISTEN      1001       31132      1937/io.modbus.11
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20483      585/sshd
      tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          17749      464/cupsd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        112125     11387/influxd
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       27313      1794/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          20019      697/mosquitto
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       31809      1716/io.sonoff.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       30780      1687/io.mqtt.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22106      1009/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24656      1009/iobroker.js-co
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        15961      451/systemd-resolve
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27731      1132/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32255      2235/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20485      585/sshd
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18640      576/xrdp-sesman
      tcp6       0      0 :::631                  :::*                    LISTEN      0          17750      464/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        21834      693/grafana
      tcp6       0      0 :::1883                 :::*                    LISTEN      0          20020      697/mosquitto
      tcp6       0      0 :::3389                 :::*                    LISTEN      115        20536      613/xrdp
      tcp6       0      0 :::7070                 :::*                    LISTEN      120        32412      2615/evcc
      tcp6       0      0 :::5355                 :::*                    LISTEN      102        15964      451/systemd-resolve
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       31287      2001/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       31288      2001/io.tuya.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        15966      451/systemd-resolve
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17890      567/cups-browsed
      udp        0      0 0.0.0.0:36010           0.0.0.0:*                           108        17757      463/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           120        32939      2615/evcc
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17755      463/avahi-daemon: r
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        15960      451/systemd-resolve
      udp        0      0 0.0.0.0:1905            0.0.0.0:*                           1001       111109     1966/io.sonos.0
      udp6       0      0 :::5353                 :::*                                120        32940      2615/evcc
      udp6       0      0 :::5353                 :::*                                108        17756      463/avahi-daemon: r
      udp6       0      0 :::5355                 :::*                                102        15963      451/systemd-resolve
      udp6       0      0 :::60204                :::*                                108        17758      463/avahi-daemon: r
      2023-04-10 23:42:36.417  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:42:41.510  - info: web.0 (2235) ==> Connected system.user.admin from ::ffff:192.168.111.86
      2023-04-10 23:42:46.427  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:42:56.439  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:06.454  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:16.468  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:26.482  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:36.495  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:46.507  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:43:56.515  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:06.523  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:16.531  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:26.549  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:36.557  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:46.588  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:44:56.620  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:06.637  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:16.652  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:26.674  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:36.696  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:46.708  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:45:56.716  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:46:06.738  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:46:16.754  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      2023-04-10 23:46:26.761  - error: influxdb.0 (7905) Error: connect ECONNREFUSED 127.0.0.1:8086
      iob diag has finished.
      Press any key for a summary
      Und dann noch mal die Summary:
      		     v.2023-04-02
      Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
      Kernel: 		5.10.103-v7l+
      Installation: 		Native
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      X-Server: 		true
      Pending OS-Updates: 	0
      Pending iob updates: 	1
      Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.1
      			/usr/bin/npm 		8.19.3
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:           7.9G        2.6G        1.6G         63M        3.8G        5.6G
      Swap:           99M          0B         99M
      Total:         8.0G        2.6G        1.7G
      Active iob-Instances: 	38
      ioBroker Core: 		js-controller 		4.0.23
      			admin 			6.3.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		8232
      States: 		7631
      Size of iob-Database:
      2.6M	/opt/iobroker/iobroker-data/states.jsonl
      748K	/opt/iobroker/iobroker-data/states.json.migrated
      748K	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
        @thomkast
        ThomKast
        Bullseye in 64bit ist schon auf einem zweitem raspi aufgesetzt. Ich habe nur noch keinen Plan, wie ich alles vom alten auf den neuen bekomme - vorallem die influxdb mit allen Daten...
        Ah... NPX darf nicht in local liegen. Habe ich gerdae in Deinem Werkzeugkasten gefunden :-)
        • T ThomKast
          @thomkast sagte in influxdb 1.8.10 läuft aber port 8086 antwortet nicht mehr:
          Mit einem Backup?
          Ja, zu falschen Pfaden findet sich was in meinem nodejs-HowTo.
          Kurzform: Lösch die Datei.
            Mit einem Backup?
            ThomKast
            Ja klar, ich wollte dann aber auch auf Influxdb2 umsteigen und die Migration ist mir nicht klar.
            Die Pfade passen doch alle bis auf NPX. Das lösche ich jetzt aus dem local Pfad.
            Und an den Upgrade von Nodejs auf V18 habe ich mich noch nicht drangetraut. Das muss ich noch ein paar mal bei Dir lesen...
            Aber sind das die Gründe für die aktuellen Probleme? Ich hatte nichts gelesen, dass ich für den weiteren Betrieb / Updates umsteiegen muss. ich dacht eich hätte noch ein wenig Ziet...
            • T ThomKast
              Nein, Buster ist seit September 2022 abgekündigt.
                ThomKast
                ok NPX ist gelöscht und DIAG meldet dazu :
                /usr/bin/npm 		8.19.3
                /usr/bin/npx 		8.19.3
                • T ThomKast
                  /usr/bin/npm 		8.19.3
                  /usr/bin/npx 		8.19.3
                  @thomkast
                  Dann kannst du ja jetzt nodejs18 und bullseye installieren.
                    @thomkast
                    ThomKast
                    @thomas-braun @thomas-braun
                    Guten Morgen Thomas. Dann würde ich vorschlagen, dass ich gleich den neuen raspi 64 bit verwende... Würdest Du mich dabei auch unterstützen. Würde mich sehr freuen, denn dann habe ich sicherlich ein korrekt aufgesetztes System...
                    Da ich jetzt am WIN-PC im Forum bin, gestaltet sich das mit dem c&p problematisch... Aber die Ausgangsituation ist wie folgt....
                    • bullseye installiert und alle update/upgrade durchgeführt
                    • node, nodejs, npm, npx wie bei Dir beschrieben installiert - Version 18.15.0 und 9.5.0 und alle in /usr/bin/
                    • nodejs: installed: 18.15.0-deb-1nodesource1 und nodejs: candidate: 18.15.0-deb-1nodesource1
                    • iob noch nicht installiert
                    Meine Backups habe ich mit "backitup" unter iob - für iob, influx, grafana, vis durchgeführt.
                    Wie gehe ich denn nun weiter vor? Was ist der nächste Schritt?^
                    Muss ich jetzt erst iob installieren, um dann mit backitup zu restoren? Oder funktioniert ein Restore so, dass auch iob wieder hergestellt wird?
                    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                    • T ThomKast
                      crunchipC Offline
                      crunchipC Offline
                      für iobroker , ja, allerdings muss vis/web ebenfalls installiert werden bevor das backup zurückgespielt wird
                      schau dir die Readme im backitup Adapter dazu an
                      • T ThomKast
                        @thomkast
                        Dafür benutzt man eine ssh-Verbindung. Dann kannan aus dem Windows-Terminal kopieren.
                          ThomKast
                          @crunchip
                          Vielen Dank für Dein Feedback. Ich bereite noch vor und ziehe noch Backups bevor es dann losgeht...
                          Eine Frage noch vorab... Ich möchte gerne influxdb auf V2 einsetzen. Die aktuelle DB ist noch 1.8.10. Spiele ich die Sicherung erst als 1.8.10 zurück und führ dann einen influxdb-Upgrade durch?
                          Ist das die sauberste Lösung für einen Umstieg? Da ich ja auf einen komplett neuen raspi gehe bin ich ja nicht auf ein Upgrade angewiesen... Nur wüsste ich nicht, wie ich eine alte-DB in eine neue einlese...
                          • T ThomKast
                            @crunchip
                            @thomkast
                            Ich würde wohl auf dem neuen System beide Datenbanken aufsetzen, das Backup zuerst in die 1.8 einspielen und dann die Migration auf influxdb2 machen.
                            • T ThomKast
                              @crunchip
                              crunchipC Offline
                              crunchipC Offline
                              ja, denn du kannst nicht einfach dein altes in die V2 einspielen, allerdings kannst du beide parallel betreiben oder aber auch danach migrieren
                              Ausnahmsweise mal ein Video
                              https://www.youtube.com/watch?v=QFOqLnBMTW4
                                ThomKast
                                @crunchip
                                Lustig... Läuft schon parallel :-)
                                  ThomKast
                                  @crunchip
                                  heißt das dann, dass wenn
                                  • die DB auf V2 umgestellt ist
                                  • alle Graphen auf flux umgestellt sind
                                  dass dann die V1.8 deinstalliert werden kann?
                                  Denn so wie das Video endet, würden dauerhaft V1 und V2 koexistieren... Muss ja nicht, oder?
                                  • T ThomKast
                                    @crunchip
                                    dass dann die V1.8 gelöscht werden kann?
                                    Wenn die leer geräumt wurde und alles in die v2 rein (und auch wieder raus) läuft kann man die influxdb1 auch löschen deinstallieren.
                                      ThomKast
                                      Hi. Bei der Inst von Grafana wird gefragt ob OSS oder Enterprise installiert werden soll. Mit dem Hinweis, Note: Grafana Enterprise is the recommended and default edition. It is available for free and includes all the features of the OSS edition.
                                      Dann installiere ich Enterprise?
                                      • T ThomKast
                                        crunchipC Offline
                                        crunchipC Offline
                                        @thomkast für den Heimgebrauch üblicherweise OSS
                                        • T ThomKast
                                          @thomkast
                                          Nein, die OSS-Version.
