  4. 2 Fehler beim Backitup Restore
    5.4k
92 Beiträge 8 Kommentatoren 14.4k Aufrufe 8 Beobachtet
    @cbrocker
    mount | sort
    ls -lAh /opt/iobroker/backups
    sagt?
    cbrocker
    root@iobroker-prox:~# mount | sort
    /dev/mapper/pve-vm--100--disk--0 on / type ext4 (rw,relatime,stripe=16)
    devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
    devpts on /dev/ptmx type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
    devpts on /dev/tty1 type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
    devpts on /dev/tty2 type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
    lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/loadavg type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/slabinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    lxcfs on /sys/devices/system/cpu type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    none on /dev type tmpfs (rw,relatime,size=492k,mode=755,inode64)
    none on /proc/sys/kernel/random/boot_id type tmpfs (ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64)
    none on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
    proc on /dev/.lxc/proc type proc (rw,relatime)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    proc on /proc/sys type proc (ro,relatime)
    proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
    proc on /proc/sysrq-trigger type proc (ro,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sys on /dev/.lxc/sys type sysfs (rw,relatime)
    sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
    sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=3255460k,nr_inodes=819200,mode=755,inode64)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
    Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
      @cbrocker
      mount | sort
      sagt?
      cbrocker
      root@iobroker-prox:~# ls -lAh /opt/iobroker/backups
      total 0
      -rw-rwxr--+ 1 iobroker iobroker 0 Apr  9 16:57 iobroker_2023_04_09-16_51_21_backupiobroker.tar.gz
      -rw-rwxr--+ 1 iobroker iobroker 0 Apr  9 18:16 iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz
      • C cbrocker
        @cbrocker sagte in 2 Fehler beim Backitup Restore:
        root
        Hausaufgabe "User anlegen" erledigen!
        C 1 Antwort Letzte Antwort
          root
          cbrocker
          @thomas-braun said in 2 Fehler beim Backitup Restore:
          ja, mache ich :-)
          • C cbrocker
            ja, mache ich :-)
            @cbrocker
            muss leer sein, wenn das Verzeichnis als Mountpunkt dient und das Dateisystem gerade nicht eingehängt ist.
            Zu Container spezifischen Besonderheiten kann ich nix sagen.
              @cbrocker
              cbrocker
              @thomas-braun ok, ich lösche den inhalt und lege erst mal einen User an.
              ist das Problem "unrecognized archive format" aber wohl ein Problem vom alten iobroker oder vom neuen (Proxmox)?
              DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
              • C cbrocker
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                teste doch mal im "alten" iobroker einen Restore, dann kann man sehen ob es am Backup liegt.
                Lehrling seit 1975 !!!
                crunchipC C 2 Antworten Letzte Antwort
                • C cbrocker
                  Da dürfte die Datei einen Schuss haben. Das sind in der Regel tar.gz, die sollten natürlich erkannt werden können.
                  • DJMarc75D DJMarc75
                    crunchipC Offline
                    crunchipC Offline
                    @djmarc75 er braucht doch nur die Backupdateien ansehen, ob die was enthalten oder ob die Größe gleich 0 ist
                    C DJMarc75D 2 Antworten Letzte Antwort
                      cbrocker
                      @djmarc75 said in 2 Fehler beim Backitup Restore:
                      ja, habe ich mir auch schon überlegt, aber wird dann nach wie vor alles noch laufen? habe dort noch grafana und influx.
                        cbrocker
                        @crunchip said in 2 Fehler beim Backitup Restore:
                        Inhalt ist drin und die backup-datei hat 13 MB. Also scheint es schon zu klappen.
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @crunchip sagte in 2 Fehler beim Backitup Restore:
                          stimmt auffallend :)
                          • C cbrocker
                            @cbrocker
                            Was sagt denn
                            file /pfad/zur/backupdatei
                            dazu?
                              @cbrocker
                              Was sagt denn
                              dazu?
                              cbrocker
                              schrieb am zuletzt editiert von cbrocker
                              pi@iobroker:~ $ file /opt/iobroker/backups
                              /opt/iobroker/backups: directory
                              pi@iobroker:~ $
                              ist jetzt im alten iobroker
                              im Container das gleiche
                              • C cbrocker
                                pi@iobroker:~ $
                                @cbrocker
                                Nein, zur der Datei, nicht zum Verzeichnis.
                                  @cbrocker
                                  cbrocker
                                  @thomas-braun im alten iobroker oder Container?
                                    @cbrocker
                                    cbrocker
                                    das ist im alten iobroker
                                    pi@iobroker:/opt/iobroker/backups $ file /opt/iobroker/backups/iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz
                                    /opt/iobroker/backups/iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz: gzip compressed data, from Unix, original size 77511680
                                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                    • C cbrocker
                                      @cbrocker
                                      Da wird die Datei offenbar korrekt erkannt.
                                        @cbrocker
                                        cbrocker
                                        ja, sieht mal im alten gut aus.
                                        Frage, wie lange wird das Restore so ca. gehen?
                                        Sollte da im Statusfenster schnell was kommen?
                                        • C cbrocker
                                          Hängt davon ab...
                                          Von wenigen Minuten bis einer Stunde und mehr ist da alles drin.
