  4. 2 Fehler beim Backitup Restore
    5.4k
92 Beiträge 8 Kommentatoren 14.4k Aufrufe 8 Beobachtet
  • C cbrocker
    @djmarc75 weil ich gerade gefixt habe und deswegen noch nicht gestartet
    @cbrocker
    mount | sort
    ls -lAh /opt/iobroker/backups
    sagt?
    C 2 Antworten Letzte Antwort
      @cbrocker
      mount | sort
      sagt?
      cbrocker
      root@iobroker-prox:~# mount | sort
      /dev/mapper/pve-vm--100--disk--0 on / type ext4 (rw,relatime,stripe=16)
      devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
      devpts on /dev/ptmx type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
      devpts on /dev/tty1 type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
      devpts on /dev/tty2 type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
      hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
      lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/loadavg type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/slabinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      lxcfs on /sys/devices/system/cpu type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
      none on /dev type tmpfs (rw,relatime,size=492k,mode=755,inode64)
      none on /proc/sys/kernel/random/boot_id type tmpfs (ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64)
      none on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
      proc on /dev/.lxc/proc type proc (rw,relatime)
      proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
      proc on /proc/sys type proc (ro,relatime)
      proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
      proc on /proc/sysrq-trigger type proc (ro,relatime)
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      sys on /dev/.lxc/sys type sysfs (rw,relatime)
      sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
      sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
      tmpfs on /run type tmpfs (rw,nosuid,nodev,size=3255460k,nr_inodes=819200,mode=755,inode64)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
      Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
        @cbrocker
        mount | sort
        sagt?
        cbrocker
        root@iobroker-prox:~# ls -lAh /opt/iobroker/backups
        total 0
        -rw-rwxr--+ 1 iobroker iobroker 0 Apr  9 16:57 iobroker_2023_04_09-16_51_21_backupiobroker.tar.gz
        -rw-rwxr--+ 1 iobroker iobroker 0 Apr  9 18:16 iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz
        • C cbrocker
          @cbrocker sagte in 2 Fehler beim Backitup Restore:
          root
          Hausaufgabe "User anlegen" erledigen!
          C 1 Antwort Letzte Antwort
            root
            cbrocker
            @thomas-braun said in 2 Fehler beim Backitup Restore:
            ja, mache ich :-)
            • C cbrocker
              ja, mache ich :-)
              @cbrocker
              muss leer sein, wenn das Verzeichnis als Mountpunkt dient und das Dateisystem gerade nicht eingehängt ist.
              Zu Container spezifischen Besonderheiten kann ich nix sagen.
                @cbrocker
                cbrocker
                @thomas-braun ok, ich lösche den inhalt und lege erst mal einen User an.
                ist das Problem "unrecognized archive format" aber wohl ein Problem vom alten iobroker oder vom neuen (Proxmox)?
                DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                • C cbrocker
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  teste doch mal im "alten" iobroker einen Restore, dann kann man sehen ob es am Backup liegt.
                  Lehrling seit 1975 !!!
                  crunchipC C 2 Antworten Letzte Antwort
                  • C cbrocker
                    Da dürfte die Datei einen Schuss haben. Das sind in der Regel tar.gz, die sollten natürlich erkannt werden können.
                    • DJMarc75D DJMarc75
                      crunchipC Offline
                      crunchipC Offline
                      @djmarc75 er braucht doch nur die Backupdateien ansehen, ob die was enthalten oder ob die Größe gleich 0 ist
                      C DJMarc75D 2 Antworten Letzte Antwort
                        cbrocker
                        @djmarc75 said in 2 Fehler beim Backitup Restore:
                        ja, habe ich mir auch schon überlegt, aber wird dann nach wie vor alles noch laufen? habe dort noch grafana und influx.
                          cbrocker
                          @crunchip said in 2 Fehler beim Backitup Restore:
                          Inhalt ist drin und die backup-datei hat 13 MB. Also scheint es schon zu klappen.
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @crunchip sagte in 2 Fehler beim Backitup Restore:
                            stimmt auffallend :)
                            • C cbrocker
                              @cbrocker
                              Was sagt denn
                              file /pfad/zur/backupdatei
                              dazu?
                                @cbrocker
                                Was sagt denn
                                dazu?
                                cbrocker
                                schrieb am zuletzt editiert von cbrocker
                                pi@iobroker:~ $ file /opt/iobroker/backups
                                /opt/iobroker/backups: directory
                                pi@iobroker:~ $
                                ist jetzt im alten iobroker
                                im Container das gleiche
                                • C cbrocker
                                  pi@iobroker:~ $
                                  @cbrocker
                                  Nein, zur der Datei, nicht zum Verzeichnis.
                                    @cbrocker
                                    cbrocker
                                    @thomas-braun im alten iobroker oder Container?
                                      @cbrocker
                                      cbrocker
                                      das ist im alten iobroker
                                      pi@iobroker:/opt/iobroker/backups $ file /opt/iobroker/backups/iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz
                                      /opt/iobroker/backups/iobroker_2023_04_09-18_09_27_backupiobroker.tar.gz: gzip compressed data, from Unix, original size 77511680
                                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                      • C cbrocker
                                        @cbrocker
                                        Da wird die Datei offenbar korrekt erkannt.
                                          @cbrocker
                                          cbrocker
                                          ja, sieht mal im alten gut aus.
                                          Frage, wie lange wird das Restore so ca. gehen?
                                          Sollte da im Statusfenster schnell was kommen?
