  4. Backitup und Grafana
62 Beiträge 7 Kommentatoren 10.8k Aufrufe 6 Beobachtet
  • K kratan75
    @simatec Die ist bereits drauf. Selbes Ergebnis.
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [ERROR] [grafana] - Error on Grafana Datasource Request
    [ERROR] [grafana] - Error on Grafana Dashoard Request: AxiosError: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [ERROR] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    Email an mich:
    Your backup was not completely created. Please check the errors!!
    grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (events.js:412:35)\n at endReadableNT (internal/streams/readable.js:1333:12)\n at processTicksAndRejections (internal/process/task_queues.js:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{"Blob":null},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.3.152:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
    Gruß Andi
    simatecS Online
    simatecS Online
    simatec
    @kratan75 Zeige mal deine Config. In den neuen Versionen von Backitup wurde Fehlerbehandlung verbessert.
    Bist du sicher, dass überhaupt Grafana Backups in der Vergangenheit erstellt wurden?
    So wie es ausschaut, ist Grafana nicht erreichbar
    Falsche IP oder http/https Fehler in der Config
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      kratan75
      schrieb am zuletzt editiert von kratan75
      @simatec Hallo, hier meine Config
      Hier der Logeintrag welcher seitdem auch immer kommt:
      host.iobroker 2023-04-08 11:42:52.045 error Invalid request getRepository. "callback" or "from" is null
      Keine Ahnung ob der auch irgendwas damit zu tun hat.
      Ja, vor dem Update wurden meine Backups erstellt. Keine Fehlermeldung !!!
      Grafana funktioniert auch ganz normal in meiner Installation. Die InfluxDB läuft noch in Version 1.0.
      Es läuft auch alles über http, nicht https weil das System nur im internen Netzwerk läuft.
      Einziges was ich noch nicht geupdatet habe ist die Host Instance( noch 4.0.23).
      Aber diese habe ich bewusst noch nicht hochgerüstet um andere Fehlfunktionen zu vermeiden. Ich muss dafür erst eine SD-Kartensicherung des Raspberry machen bevor ich das ausprobiere.
      Ich hoffe es liegt nicht am Host.
      Oder meinst Du es hilft was, noch einmal eine neue API in Grafana zu erstellen ?
      Gruß Andi
      • K kratan75
        Gruß Andi
        simatecS Online
        simatecS Online
        simatec
        @kratan75 sagte in Backitup und Grafana:
        Das sieht mir nach einem Netzwerkproblem aus.
        Kannst du denn über die CLI dein Grafana pingen?
        Läuft Grafana auf dem gleichen System? Falls ja, dann kannst du mal die 127.0.0.1 oder auch localhost verwenden
        iobroker kann deine Grafana Installation nicht erreichen... Backitup macht vor dem Backup einen Check, ob mit der Config Grafana erreichbar ist
        • simatecS simatec
          kratan75
          @simatec Ja, läuft auf dem selben System.
          Ich habe es mal mit localhost oder 127.0.0.1 probiert mit selben Ergebnis.
          Was kann das sein ?
          Gruß Andi
          • K kratan75
            Was kann das sein ?
            Gruß Andi
            simatecS Online
            simatecS Online
            simatec
            @kratan75 Zeige mir mal die Ausgabe der installierten Pakete
            cd /opt/iobroker/node_modules/iobroker.backitup
            npm list
            • simatecS simatec
              npm list
              kratan75
              @simatec Hi, da scheint es eine Menge Probleme zu geben. Hier mal die Ausgabe. Kann es sein das beim Update ein paar Pakete nicht installiert wurden ?
              root@iobroker:/home/pi# cd /opt/iobroker/node_modules/iobroker.backitup
              root@iobroker:/opt/iobroker/node_modules/iobroker.backitup# npm list
              iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
              ├── UNMET DEPENDENCY @googleapis/drive@^4.0.2
              ├─┬ @iobroker/adapter-core@2.6.8
              │ └─┬ @types/iobroker@4.0.5
              │ └── UNMET DEPENDENCY @types/node@*
              ├─┬ axios@1.3.5
              │ ├── UNMET DEPENDENCY follow-redirects@^1.15.0
              │ ├── UNMET DEPENDENCY form-data@^4.0.0
              │ └── UNMET DEPENDENCY proxy-from-env@^1.1.0
              ├── UNMET DEPENDENCY dropbox-v2-api@^2.5.10
              ├─┬ express@4.18.2
              │ ├── UNMET DEPENDENCY accepts@~1.3.8
              │ ├── UNMET DEPENDENCY array-flatten@1.1.1
              │ ├─┬ body-parser@1.20.1
              │ │ ├── UNMET DEPENDENCY bytes@3.1.2
              │ │ ├── UNMET DEPENDENCY content-type@~1.0.4
              │ │ ├── UNMET DEPENDENCY debug@2.6.9
              │ │ ├── UNMET DEPENDENCY depd@2.0.0
              │ │ ├── UNMET DEPENDENCY destroy@1.2.0
              │ │ ├── UNMET DEPENDENCY http-errors@2.0.0
              │ │ ├── UNMET DEPENDENCY iconv-lite@0.4.24
              │ │ ├── UNMET DEPENDENCY on-finished@2.4.1
              │ │ ├── qs@6.11.0 deduped
              │ │ ├── UNMET DEPENDENCY raw-body@2.5.1
              │ │ ├── UNMET DEPENDENCY type-is@~1.6.18
              │ │ └── UNMET DEPENDENCY unpipe@1.0.0
              │ ├── UNMET DEPENDENCY content-disposition@0.5.4
              │ ├── cookie@0.5.0
              │ ├── UNMET DEPENDENCY cookie-signature@1.0.6
              │ ├── UNMET DEPENDENCY encodeurl@~1.0.2
              │ ├── UNMET DEPENDENCY escape-html@~1.0.3
              │ ├── UNMET DEPENDENCY etag@~1.8.1
              │ ├── UNMET DEPENDENCY finalhandler@1.2.0
              │ ├── UNMET DEPENDENCY fresh@0.5.2
              │ ├── UNMET DEPENDENCY merge-descriptors@1.0.1
              │ ├── UNMET DEPENDENCY methods@~1.1.2
              │ ├── UNMET DEPENDENCY parseurl@~1.3.3
              │ ├── UNMET DEPENDENCY path-to-regexp@0.1.7
              │ ├── UNMET DEPENDENCY proxy-addr@~2.0.7
              │ ├─┬ qs@6.11.0
              │ │ └── UNMET DEPENDENCY side-channel@^1.0.4
              │ ├── UNMET DEPENDENCY range-parser@~1.2.1
              │ ├── safe-buffer@5.2.1
              │ ├── UNMET DEPENDENCY send@0.18.0
              │ ├── UNMET DEPENDENCY serve-static@1.15.0
              │ ├── UNMET DEPENDENCY setprototypeof@1.2.0
              │ ├── UNMET DEPENDENCY statuses@2.0.1
              │ ├── UNMET DEPENDENCY utils-merge@1.0.1
              │ └── UNMET DEPENDENCY vary@~1.1.2
              ├─┬ fs-extra@11.1.1
              │ ├── UNMET DEPENDENCY graceful-fs@^4.2.0
              │ ├── UNMET DEPENDENCY jsonfile@^6.0.1
              │ └── UNMET DEPENDENCY universalify@^2.0.0
              ├── UNMET DEPENDENCY ftp@^0.3.10
              ├── UNMET DEPENDENCY google-auth-library@^8.7.0
              ├─┬ node-schedule@2.1.1
              │ ├─┬ cron-parser@4.8.1
              │ │ └── luxon@3.3.0
              │ ├── UNMET DEPENDENCY long-timeout@0.1.1
              │ └── UNMET DEPENDENCY sorted-array-functions@^1.3.0
              ├── UNMET DEPENDENCY node-wol@^0.1.1
              ├── UNMET DEPENDENCY onedrive-api@^1.0.7
              ├── UNMET DEPENDENCY request@^2.88.2
              ├── UNMET DEPENDENCY tar-fs@^2.1.1
              └── UNMET DEPENDENCY webdav@^4.11.2
              npm ERR! missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
              npm ERR! missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
              npm ERR! missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
              npm ERR! missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6. 16
              npm ERR! missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
              npm ERR! missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
              npm ERR! missing: request@^2.88.2, required by iobroker.backitup@2.6.16
              npm ERR! missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
              npm ERR! missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
              npm ERR! missing: @types/node@*, required by @types/iobroker@4.0.5
              npm ERR! missing: follow-redirects@^1.15.0, required by axios@1.3.5
              npm ERR! missing: form-data@^4.0.0, required by axios@1.3.5
              npm ERR! missing: proxy-from-env@^1.1.0, required by axios@1.3.5
              npm ERR! missing: accepts@~1.3.8, required by express@4.18.2
              npm ERR! missing: array-flatten@1.1.1, required by express@4.18.2
              npm ERR! missing: content-disposition@0.5.4, required by express@4.18.2
              npm ERR! missing: content-type@~1.0.4, required by express@4.18.2
              npm ERR! missing: cookie-signature@1.0.6, required by express@4.18.2
              npm ERR! missing: debug@2.6.9, required by express@4.18.2
              npm ERR! missing: depd@2.0.0, required by express@4.18.2
              npm ERR! missing: encodeurl@~1.0.2, required by express@4.18.2
              npm ERR! missing: escape-html@~1.0.3, required by express@4.18.2
              npm ERR! missing: etag@~1.8.1, required by express@4.18.2
              npm ERR! missing: finalhandler@1.2.0, required by express@4.18.2
              npm ERR! missing: fresh@0.5.2, required by express@4.18.2
              npm ERR! missing: http-errors@2.0.0, required by express@4.18.2
              npm ERR! missing: merge-descriptors@1.0.1, required by express@4.18.2
              npm ERR! missing: methods@~1.1.2, required by express@4.18.2
              npm ERR! missing: on-finished@2.4.1, required by express@4.18.2
              npm ERR! missing: parseurl@~1.3.3, required by express@4.18.2
              npm ERR! missing: path-to-regexp@0.1.7, required by express@4.18.2
              npm ERR! missing: proxy-addr@~2.0.7, required by express@4.18.2
              npm ERR! missing: range-parser@~1.2.1, required by express@4.18.2
              npm ERR! missing: send@0.18.0, required by express@4.18.2
              npm ERR! missing: serve-static@1.15.0, required by express@4.18.2
              npm ERR! missing: setprototypeof@1.2.0, required by express@4.18.2
              npm ERR! missing: statuses@2.0.1, required by express@4.18.2
              npm ERR! missing: type-is@~1.6.18, required by express@4.18.2
              npm ERR! missing: utils-merge@1.0.1, required by express@4.18.2
              npm ERR! missing: vary@~1.1.2, required by express@4.18.2
              npm ERR! missing: bytes@3.1.2, required by body-parser@1.20.1
              npm ERR! missing: content-type@~1.0.4, required by body-parser@1.20.1
              npm ERR! missing: debug@2.6.9, required by body-parser@1.20.1
              npm ERR! missing: depd@2.0.0, required by body-parser@1.20.1
              npm ERR! missing: destroy@1.2.0, required by body-parser@1.20.1
              npm ERR! missing: http-errors@2.0.0, required by body-parser@1.20.1
              npm ERR! missing: iconv-lite@0.4.24, required by body-parser@1.20.1
              npm ERR! missing: on-finished@2.4.1, required by body-parser@1.20.1
              npm ERR! missing: raw-body@2.5.1, required by body-parser@1.20.1
              npm ERR! missing: type-is@~1.6.18, required by body-parser@1.20.1
              npm ERR! missing: unpipe@1.0.0, required by body-parser@1.20.1
              npm ERR! missing: side-channel@^1.0.4, required by qs@6.11.0
              npm ERR! missing: graceful-fs@^4.2.0, required by fs-extra@11.1.1
              npm ERR! missing: jsonfile@^6.0.1, required by fs-extra@11.1.1
              npm ERR! missing: universalify@^2.0.0, required by fs-extra@11.1.1
              npm ERR! missing: long-timeout@0.1.1, required by node-schedule@2.1.1
              npm ERR! missing: sorted-array-functions@^1.3.0, required by node-schedule@2.1.1
              Thomas BraunT simatecS 3 Antworten Letzte Antwort
              • K kratan75
                ├─┬ axios@1.3.5
                ├─┬ express@4.18.2
                │ ├── cookie@0.5.0
                │ ├─┬ qs@6.11.0
                ├─┬ fs-extra@11.1.1
                │ │ └── luxon@3.3.0
                Warum? Macht euch doch nicht immer das Leben durch den Scheiss root selber schwer...
                • K kratan75
                  ├─┬ axios@1.3.5
                  ├─┬ express@4.18.2
                  │ ├── cookie@0.5.0
                  │ ├─┬ qs@6.11.0
                  ├─┬ fs-extra@11.1.1
                  │ │ └── luxon@3.3.0
                  simatecS Online
                  simatecS Online
                  simatec
                  @kratan75 Hmmm sieht etwas komisch aus...
                  sudo -u iobroker npm install
                  Und arbeite nicht als root auf dem System
                  • simatecS Online
                    simatecS Online
                    simatec
                    Gab es beim Update Fehlermeldungen?
                    Es ist grundsätzlch nicht sinnvoll als root zu arbeiten. Wie @Thomas-Braun schrieb, damt macht ihr euch nur Probleme
                    • K kratan75
                      ├─┬ axios@1.3.5
                      ├─┬ express@4.18.2
                      │ ├── cookie@0.5.0
                      │ ├─┬ qs@6.11.0
                      ├─┬ fs-extra@11.1.1
                      │ │ └── luxon@3.3.0
                      @kratan75
                      Als root ausloggen und niemehr direkt als root einloggen.
                      iob stop
                      iob fix
                      iob start
                      cd /opt/iobroker
                      npm ls
                      • simatecS simatec
                        kratan75
                        @simatec Ich habe es jetzt so gemacht wie Du und Thomas gesagt haben.
                        Alos nicht als root eingeloggt und den npm installiert nun sieht die Ausgabe zwar besser aus, jedoch kommt immer noch ein Fehler am Ende der Liste.
                        Grafana lässt sich trotzdem nicht sichern. Auch nicht mit der IP des Hosts 127.0.0.1, localhost oder die direkte IP-Adresse.
                        iob stop
                        iob fix
                        iob start
                        cd /opt/iobroker
                        npm ls
                        Was bedeutet das nun schon wieder ? Was ist "peer dep" ?
                        pi@iobroker:/opt/iobroker $ npm ls
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├─┬ iobroker.admin@6.3.5
                        │ ├─┬ @iobroker/adapter-core@2.6.7
                        │ │ └─┬ @types/iobroker@4.0.5
                        │ │ └── @types/node@18.0.0 deduped
                        │ ├─┬ @iobroker/socket-classes@1.0.2
                        │ │ ├─┬ @iobroker/adapter-core@2.6.7
                        │ │ │ └─┬ @types/iobroker@4.0.5
                        │ │ │ └── @types/node@18.0.0 deduped
                        │ │ ├─┬ engine.io-client@3.5.2
                        │ │ │ ├── component-emitter@1.3.0 deduped
                        │ │ │ ├── component-inherit@0.0.3
                        │ │ │ ├─┬ debug@3.1.0
                        │ │ │ │ └── ms@2.0.0 deduped
                        │ │ │ ├── engine.io-parser@2.2.1 deduped
                        │ │ │ ├── has-cors@1.1.0
                        │ │ │ ├── indexof@0.0.1 deduped
                        │ │ │ ├── parseqs@0.0.6 deduped
                        │ │ │ ├── parseuri@0.0.6 deduped
                        │ │ │ ├── ws@7.4.6
                        │ │ │ ├── xmlhttprequest-ssl@1.6.3
                        │ │ │ └── yeast@0.1.2
                        │ │ ├── has-binary2@1.0.3 deduped
                        │ │ ├─┬ socket.io-parser@3.3.2
                        │ │ │ ├── debug@3.1.0 deduped
                        │ │ │ └── isarray@2.0.1
                        │ │ └── to-array@0.1.4
                        │ └─┬ socket.io-parser@3.4.1
                        │ ├── component-emitter@1.2.1
                        │ ├─┬ debug@4.1.1
                        │ │ └── ms@2.1.3
                        │ └── isarray@2.0.1
                        ├─┬ iobroker.ws@1.3.0
                        │ ├── @iobroker/adapter-core@2.6.0 deduped
                        │ ├── axios@0.26.1 deduped
                        │ ├── cookie-parser@1.4.6 deduped
                        │ ├── express-session@1.17.3 deduped
                        │ ├─┬ iobroker.ws.server@1.0.1
                        │ │ └── ws@8.8.0 deduped
                        │ └── passport@0.5.3 deduped
                        ├─┬ mime-types@2.1.35
                        │ └── mime-db@1.52.0
                        ├─┬ passport@0.5.3
                        │ ├── passport-strategy@1.0.0 deduped
                        │ └── pause@0.0.1 deduped
                        ├── passport-local@1.0.0 deduped
                        └── xtend@4.0.2
                        npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                        Die Ausgabe bei der Instance ist dieselbe wie vorher.
                        fb59bb1a-597b-4979-bc74-8f28cb8ea6e7-image.png 😠
                        Was kann das sein ?
                        Gruß Andi
                        • K kratan75
                          iob stop
                          iob fix
                          iob start
                          cd /opt/iobroker
                          npm ls
                          │ │ │ ├── ws@7.4.6
                          │ ├─┬ debug@4.1.1
                          │ │ └── ms@2.1.3
                          │ └── isarray@2.0.1
                          ├─┬ passport@0.5.3
                          └── xtend@4.0.2
                          Was kann das sein ?
                          Gruß Andi
                          @kratan75
                          Bitte keine Scteenshots aus der Konsole sondern den Text in CodeTags eingebettet hier rein.
                          iob diag
                          sagt nun zu deiner Installation?
                          Ich vermute da ist deine nodejs-Installation nicht auf Stand.
                            @kratan75
                            iob diag
                            simatecS Online
                            simatecS Online
                            simatec
                            @thomas-braun sieht mir auch so aus. Da sind teilweise ganz alte Versionen
                            • simatecS simatec
                              @simatec
                              Ja, npm>7 sollte auch eigentlich für eine andere Ausgabe bei npm ls sorgen.
                                kratan75
                                @simatec Meinst du den js-controller ?
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                                Adapter    "countdown"    : 1.2.5    , installed 1.2.5
                                Adapter    "email"        : 1.1.4    , installed 1.1.4
                                Adapter    "fronius"      : 1.1.3    , installed 1.1.3
                                Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                                Adapter    "kecontact"    : 1.5.2    , installed 1.5.2
                                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                                Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                                Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                                Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                • K kratan75
                                  kratan75
                                  @kratan75 Hier nochmal die ganze Ausgabe.
                                  Skript v.2023-04-02
                                  *** BASE SYSTEM ***
                                  Model : Raspberry Pi 4 Model B Rev 1.5
                                  Architecture : armv7l
                                  Docker : false
                                  Virtualization : none
                                  Distributor ID: Raspbian
                                  Description: Raspbian GNU/Linux 10 (buster)
                                  Release: 10
                                  Codename: buster
                                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                  NAME="Raspbian GNU/Linux"
                                  VERSION_ID="10"
                                  VERSION="10 (buster)"
                                  VERSION_CODENAME=buster
                                  ID=raspbian
                                  ID_LIKE=debian
                                  HOME_URL="http://www.raspbian.org/"
                                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                  Systemuptime and Load:
                                  15:36:22 up 19:59, 1 user, load average: 0.54, 0.64, 0.79
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                  Local time: Sat 2023-04-08 15:36:22 CEST
                                  Universal time: Sat 2023-04-08 13:36:22 UTC
                                  RTC time: n/a
                                  NTP service: active
                                  RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                                  *** X-Server-Setup ***
                                  X-Server: false
                                  Desktop:
                                  Terminal: tty
                                  Boot Target: graphical.target
                                  *** MEMORY ***
                                  total used free shared buff/cache available
                                  Mem: 3.8G 1.1G 1.5G 48M 1.2G 2.9G
                                  Swap: 99M 0B 99M
                                  Total: 3.9G 1.1G 1.6G
                                       3838 M total memory
                                       1141 M used memory
                                        401 M active memory
                                       1774 M inactive memory
                                       1478 M free memory
                                        130 M buffer memory
                                       1088 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                                  *** FILESYSTEM ***
                                  Filesystem Type Size Used Avail Use% Mounted on
                                  /dev/root ext4 30G 4.8G 24G 18% /
                                  devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev
                                  tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
                                  tmpfs tmpfs 1.9G 49M 1.9G 3% /run
                                  tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                                  tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
                                  /dev/loop1 squashfs 99M 99M 0 100% /snap/core/14788
                                  /dev/loop0 squashfs 384K 384K 0 100% /snap/minicom/1
                                  /dev/loop2 squashfs 99M 99M 0 100% /snap/core/14950
                                  /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot
                                  tmpfs tmpfs 384M 0 384M 0% /run/user/1000
                                  [Fri Apr 7 19:36:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4 :5F:01:A9:73:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=t tyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=y es rootwait
                                  [Fri Apr 7 19:36:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Fri Apr 7 19:36:27 2023] VFS: Mounted root (ext4 filesystem) readonly on devic e 179:2.
                                  [Fri Apr 7 19:36:29 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                  TARGET SOURCE FSTYPE OPTIONS
                                  / /dev/mmcblk0p2 ext4 rw,noatime
                                  |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode= 700
                                  |-/snap/core/14788 /dev/loop1 squashfs ro,nodev,relatime
                                  |-/snap/minicom/1 /dev/loop0 squashfs ro,nodev,relatime
                                  |-/snap/core/14950 /dev/loop2 squashfs ro,nodev,relatime
                                  `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,cod epage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  1.2G /var/
                                  510M /var/lib
                                  325M /var/log
                                  294M /var/lib/snapd
                                  197M /var/lib/snapd/snaps
                                  /opt/iobroker/backups:
                                  461M /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  302M /opt/iobroker/iobroker-data/
                                  252M /opt/iobroker/iobroker-data/files
                                  78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                  51M /opt/iobroker/iobroker-data/files/javascript.admin
                                  35M /opt/iobroker/iobroker-data/backup-objects
                                  11M /opt/iobroker/iobroker-data/objects.jsonl
                                  6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c 9.chunk.js.map
                                  6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.j s.map
                                  6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js.map
                                  5.3M /opt/iobroker/iobroker-data/states.jsonl
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs v14.19.3
                                  /usr/bin/node v14.19.3
                                  /usr/bin/npm 6.14.17
                                  /usr/bin/npx 6.14.17
                                  nodejs:
                                  Installed: 14.19.3-deb-1nodesource1
                                  Candidate: 14.21.3-deb-1nodesource1
                                  Version table:
                                  14.21.3-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                  *** 14.19.3-deb-1nodesource1 100
                                  10.24.0~dfsg-1~deb10u3 500
                                  No problems detected
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States type: jsonl
                                  Core adapters versions
                                  js-controller: 4.0.23
                                  admin: 6.3.5
                                  javascript: 6.1.4
                                  Adapters from github: 5
                                  Adapter State
                                  • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admi n
                                  • system.adapter.backitup.0 : backitup : iobroker - enabled
                                  • system.adapter.countdown.0 : countdown : iobroker - enabled
                                  • system.adapter.discovery.0 : discovery : iobroker - enabled
                                  • system.adapter.email.0 : email : iobroker - enabled
                                  • system.adapter.fronius.0 : fronius : iobroker - enabled
                                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob roker - enabled
                                    system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled
                                    system.adapter.icons-material-png.0 : icons-material-png : iobroker - enabled
                                    system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - enabled
                                    system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob roker - enabled
                                    system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled
                                  • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
                                  • system.adapter.javascript.0 : javascript : iobroker - enabled
                                  • system.adapter.kecontact.0 : kecontact : iobroker - enabled
                                  • system.adapter.modbus.0 : modbus : iobroker - enabled
                                  • system.adapter.modbus.1 : modbus : iobroker - enabled
                                  • system.adapter.modbus.2 : modbus : iobroker - enabled
                                  • system.adapter.modbus.3 : modbus : iobroker - enabled
                                    system.adapter.openweathermap.0 : openweathermap : iobroker - enabled
                                  • system.adapter.ping.0 : ping : iobroker - enabled
                                  • system.adapter.pvforecast.0 : pvforecast : iobroker - enabled
                                  • system.adapter.rpi2.0 : rpi2 : iobroker - enabled
                                  • system.adapter.smartmeter.0 : smartmeter : iobroker - enabled
                                    system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled
                                  • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
                                    system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
                                    system.adapter.vis.0 : vis : iobroker - enabled
                                    system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled
                                  • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admi n
                                  • instance is alive
                                  ioBroker-Repositories
                                  stable : http://download.iobroker.net/sources-dist.json
                                  beta : http://download.iobroker.net/sources-dist-latest.json
                                  Active repo(s): stable
                                  Adapter "simple-api" : 2.7.2 , installed 2.7.2
                                  Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
                                  Objects and States
                                  Objects: 3680
                                  States: 3190
                                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:3 http://archive.raspbian.org/raspbian buster InRelease
                                  Get:4 https://repos.influxdata.com/debian buster InRelease [7029 B]
                                  Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
                                  Err:4 https://repos.influxdata.com/debian buster InRelease
                                  Fetched 7029 B in 2s (4352 B/s)
                                  Reading package lists...
                                  Pending Updates: 107
                                  *** Listening Ports ***
                                  Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                                  tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18055 659/sshd
                                  tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 15205 652/influxd
                                  tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1140135 19291/iobroker.js-c
                                  tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1140128 19291/iobroker.js-c
                                  tcp6 0 0 :::8081 :::* LISTEN 1001 1141192 19309/io.admin.0
                                  tcp6 0 0 :::8082 :::* LISTEN 1001 1140639 19686/io.web.0
                                  tcp6 0 0 :::8086 :::* LISTEN 999 18118 652/influxd
                                  tcp6 0 0 :::22 :::* LISTEN 0 18057 659/sshd
                                  tcp6 0 0 :::3000 :::* LISTEN 109 16125 643/grafana-server
                                  udp 0 0 0.0.0.0:60833 0.0.0.0:* 108 16868 396/avahi-daemon: r
                                  udp 0 0 0.0.0.0:7090 0.0.0.0:* 1001 1141592 19670/io.kecontact.
                                  udp 0 0 0.0.0.0:7092 0.0.0.0:* 1001 1141593 19670/io.kecontact.
                                  udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15891 633/dhcpcd
                                  udp 0 0 0.0.0.0:47717 0.0.0.0:* 1001 1141594 19670/io.kecontact.
                                  udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 16866 396/avahi-daemon: r
                                  udp6 0 0 :::49312 :::* 108 16869 396/avahi-daemon: r
                                  udp6 0 0 :::5353 :::* 108 16867 396/avahi-daemon: r
                                  2023-04-08 15:34:52.440 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:34:58.571 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                  2023-04-08 15:35:04.644 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:10.874 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:17.246 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:23.619 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:30.126 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:36.534 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:42.060 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:47.670 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:35:53.339 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                  2023-04-08 15:35:59.067 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:04.617 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:10.358 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:16.341 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:22.283 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:28.263 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:34.442 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:40.609 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:47.138 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:36:54.256 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:37:00.904 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                  2023-04-08 15:37:07.485 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:37:16.405 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  2023-04-08 15:37:23.365 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                  iob diag has finished.
                                  • K kratan75
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Docker : false
                                    Release: 10
                                    Codename: buster
                                    VERSION_ID="10"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                    RTC time: n/a
                                    NTP service: active
                                    RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server: false
                                    Desktop:
                                    Terminal: tty
                                    *** MEMORY ***
                                    Swap: 99M 0B 99M
                                         3838 M total memory
                                         1141 M used memory
                                          401 M active memory
                                         1478 M free memory
                                          130 M buffer memory
                                         1088 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.2G /var/
                                    510M /var/lib
                                    325M /var/log
                                    294M /var/lib/snapd
                                    nodejs:
                                    Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States type: jsonl
                                    admin: 6.3.5
                                    javascript: 6.1.4
                                    Adapter State
                                    • instance is alive
                                    Objects and States
                                    Objects: 3680
                                    States: 3190
                                    kratan75
                                    @kratan75 Hier die NodeJS Installation. Denke die wolltet Ihr sehen.
                                    nodejs:
                                      Version table:
                                    K Thomas BraunT 2 Antworten Letzte Antwort
                                    • K kratan75
                                      nodejs:
                                        Version table:
                                      kratan75
                                      @kratan75 ```
                                                           v.2023-04-02
                                      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                                      Kernel:                 5.10.103-v7l+
                                      Installation:           Native
                                      User-ID:                1000
                                      X-Server:               false
                                      Pending OS-Updates:     107
                                      Pending iob updates:    2
                                      Nodejs-Installation:    /usr/bin/nodejs         v14.19.3
                                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                                      MEMORY:
                                      Mem:           3.8G        1.2G        1.5G         48M        1.2G        2.9G
                                      Swap:           99M          0B         99M
                                      Total:         3.9G        1.2G        1.6G
                                      Active iob-Instances:   20
                                      ioBroker Core:          js-controller           4.0.23
                                                              admin                   6.3.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                3680
                                      States:                 3190
                                      Size of iob-Database:
                                      6.9M    /opt/iobroker/iobroker-data/states.jsonl
                                      ext
                                      • K kratan75
                                        nodejs:
                                          Version table:
                                        @kratan75
                                        Die influxdb-Quelle muss angepackt werden.
                                        Dann funktionieren auch Upgrades wieder und du kannst die 107 geschluderten Upgrades einspielen.
                                        Und was haste da mit snapd gemacht? Vollkommen unüblich für Server.
                                        Dann das Ganze auf nodejs 18 bringen.
                                        Und zu guter Letzt den abgekündigten Buster beerdigen und Bullseye installieren.
                                        Das wiederum würde ich in der 64bit-Version gleich neu installieren.
                                          @kratan75
                                          kratan75
                                          @thomas-braun Kannst mir das bitte etwas näher erklären ?
                                          Vor dem Update hat ja alles noch wunderbar funktioniert.
                                          Wie passe ich die influxdb-Quelle an ?Die Upgrades denke ich bekomme ich mit
                                          sudo apt-get update
                                          sudo apt-get upgrade
                                          noch hin, aber wo passe ich zum Henker die InfluxDB Quelle an.
                                          Sorry, ich arbeite eigentlich fast nur mit IObroker selbst, nicht mit dem Linuxsystem dahinter.
                                          Gruß Andi
