  4. Backitup und Grafana
62 Beiträge 7 Kommentatoren 10.8k Aufrufe 6 Beobachtet
  • simatecS simatec
    @kratan75 Bitte die aktuelle Version v2.6.16 installieren
    kratan75
    @simatec Die ist bereits drauf. Selbes Ergebnis.
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [ERROR] [grafana] - Error on Grafana Datasource Request
    [ERROR] [grafana] - Error on Grafana Dashoard Request: AxiosError: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [ERROR] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    Email an mich:
    Your backup was not completely created. Please check the errors!!
    grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (events.js:412:35)\n at endReadableNT (internal/streams/readable.js:1333:12)\n at processTicksAndRejections (internal/process/task_queues.js:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{"Blob":null},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.3.152:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
    Gruß Andi
    • K kratan75
      Email an mich:
      Gruß Andi
      simatecS Online
      simatecS Online
      simatec
      @kratan75 Zeige mal deine Config. In den neuen Versionen von Backitup wurde Fehlerbehandlung verbessert.
      Bist du sicher, dass überhaupt Grafana Backups in der Vergangenheit erstellt wurden?
      So wie es ausschaut, ist Grafana nicht erreichbar
      Falsche IP oder http/https Fehler in der Config
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        kratan75
        schrieb am zuletzt editiert von kratan75
        @simatec Hallo, hier meine Config
        Hier der Logeintrag welcher seitdem auch immer kommt:
        host.iobroker 2023-04-08 11:42:52.045 error Invalid request getRepository. "callback" or "from" is null
        Keine Ahnung ob der auch irgendwas damit zu tun hat.
        Ja, vor dem Update wurden meine Backups erstellt. Keine Fehlermeldung !!!
        Grafana funktioniert auch ganz normal in meiner Installation. Die InfluxDB läuft noch in Version 1.0.
        Es läuft auch alles über http, nicht https weil das System nur im internen Netzwerk läuft.
        Einziges was ich noch nicht geupdatet habe ist die Host Instance( noch 4.0.23).
        Aber diese habe ich bewusst noch nicht hochgerüstet um andere Fehlfunktionen zu vermeiden. Ich muss dafür erst eine SD-Kartensicherung des Raspberry machen bevor ich das ausprobiere.
        Ich hoffe es liegt nicht am Host.
        Oder meinst Du es hilft was, noch einmal eine neue API in Grafana zu erstellen ?
        Gruß Andi
        • K kratan75
          Gruß Andi
          simatecS Online
          simatecS Online
          simatec
          @kratan75 sagte in Backitup und Grafana:
          Das sieht mir nach einem Netzwerkproblem aus.
          Kannst du denn über die CLI dein Grafana pingen?
          Läuft Grafana auf dem gleichen System? Falls ja, dann kannst du mal die 127.0.0.1 oder auch localhost verwenden
          iobroker kann deine Grafana Installation nicht erreichen... Backitup macht vor dem Backup einen Check, ob mit der Config Grafana erreichbar ist
          • simatecS simatec
            kratan75
            @simatec Ja, läuft auf dem selben System.
            Ich habe es mal mit localhost oder 127.0.0.1 probiert mit selben Ergebnis.
            Was kann das sein ?
            Gruß Andi
            • K kratan75
              Was kann das sein ?
              Gruß Andi
              simatecS Online
              simatecS Online
              simatec
              @kratan75 Zeige mir mal die Ausgabe der installierten Pakete
              cd /opt/iobroker/node_modules/iobroker.backitup
              npm list
              • simatecS simatec
                npm list
                kratan75
                @simatec Hi, da scheint es eine Menge Probleme zu geben. Hier mal die Ausgabe. Kann es sein das beim Update ein paar Pakete nicht installiert wurden ?
                root@iobroker:/home/pi# cd /opt/iobroker/node_modules/iobroker.backitup
                root@iobroker:/opt/iobroker/node_modules/iobroker.backitup# npm list
                iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                ├── UNMET DEPENDENCY @googleapis/drive@^4.0.2
                ├─┬ @iobroker/adapter-core@2.6.8
                │ └─┬ @types/iobroker@4.0.5
                │ └── UNMET DEPENDENCY @types/node@*
                ├─┬ axios@1.3.5
                │ ├── UNMET DEPENDENCY follow-redirects@^1.15.0
                │ ├── UNMET DEPENDENCY form-data@^4.0.0
                │ └── UNMET DEPENDENCY proxy-from-env@^1.1.0
                ├── UNMET DEPENDENCY dropbox-v2-api@^2.5.10
                ├─┬ express@4.18.2
                │ ├── UNMET DEPENDENCY accepts@~1.3.8
                │ ├── UNMET DEPENDENCY array-flatten@1.1.1
                │ ├─┬ body-parser@1.20.1
                │ │ ├── UNMET DEPENDENCY bytes@3.1.2
                │ │ ├── UNMET DEPENDENCY content-type@~1.0.4
                │ │ ├── UNMET DEPENDENCY debug@2.6.9
                │ │ ├── UNMET DEPENDENCY depd@2.0.0
                │ │ ├── UNMET DEPENDENCY destroy@1.2.0
                │ │ ├── UNMET DEPENDENCY http-errors@2.0.0
                │ │ ├── UNMET DEPENDENCY iconv-lite@0.4.24
                │ │ ├── UNMET DEPENDENCY on-finished@2.4.1
                │ │ ├── qs@6.11.0 deduped
                │ │ ├── UNMET DEPENDENCY raw-body@2.5.1
                │ │ ├── UNMET DEPENDENCY type-is@~1.6.18
                │ │ └── UNMET DEPENDENCY unpipe@1.0.0
                │ ├── UNMET DEPENDENCY content-disposition@0.5.4
                │ ├── cookie@0.5.0
                │ ├── UNMET DEPENDENCY cookie-signature@1.0.6
                │ ├── UNMET DEPENDENCY encodeurl@~1.0.2
                │ ├── UNMET DEPENDENCY escape-html@~1.0.3
                │ ├── UNMET DEPENDENCY etag@~1.8.1
                │ ├── UNMET DEPENDENCY finalhandler@1.2.0
                │ ├── UNMET DEPENDENCY fresh@0.5.2
                │ ├── UNMET DEPENDENCY merge-descriptors@1.0.1
                │ ├── UNMET DEPENDENCY methods@~1.1.2
                │ ├── UNMET DEPENDENCY parseurl@~1.3.3
                │ ├── UNMET DEPENDENCY path-to-regexp@0.1.7
                │ ├── UNMET DEPENDENCY proxy-addr@~2.0.7
                │ ├─┬ qs@6.11.0
                │ │ └── UNMET DEPENDENCY side-channel@^1.0.4
                │ ├── UNMET DEPENDENCY range-parser@~1.2.1
                │ ├── safe-buffer@5.2.1
                │ ├── UNMET DEPENDENCY send@0.18.0
                │ ├── UNMET DEPENDENCY serve-static@1.15.0
                │ ├── UNMET DEPENDENCY setprototypeof@1.2.0
                │ ├── UNMET DEPENDENCY statuses@2.0.1
                │ ├── UNMET DEPENDENCY utils-merge@1.0.1
                │ └── UNMET DEPENDENCY vary@~1.1.2
                ├─┬ fs-extra@11.1.1
                │ ├── UNMET DEPENDENCY graceful-fs@^4.2.0
                │ ├── UNMET DEPENDENCY jsonfile@^6.0.1
                │ └── UNMET DEPENDENCY universalify@^2.0.0
                ├── UNMET DEPENDENCY ftp@^0.3.10
                ├── UNMET DEPENDENCY google-auth-library@^8.7.0
                ├─┬ node-schedule@2.1.1
                │ ├─┬ cron-parser@4.8.1
                │ │ └── luxon@3.3.0
                │ ├── UNMET DEPENDENCY long-timeout@0.1.1
                │ └── UNMET DEPENDENCY sorted-array-functions@^1.3.0
                ├── UNMET DEPENDENCY node-wol@^0.1.1
                ├── UNMET DEPENDENCY onedrive-api@^1.0.7
                ├── UNMET DEPENDENCY request@^2.88.2
                ├── UNMET DEPENDENCY tar-fs@^2.1.1
                └── UNMET DEPENDENCY webdav@^4.11.2
                npm ERR! missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
                npm ERR! missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
                npm ERR! missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
                npm ERR! missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6. 16
                npm ERR! missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
                npm ERR! missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
                npm ERR! missing: request@^2.88.2, required by iobroker.backitup@2.6.16
                npm ERR! missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
                npm ERR! missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
                npm ERR! missing: @types/node@*, required by @types/iobroker@4.0.5
                npm ERR! missing: follow-redirects@^1.15.0, required by axios@1.3.5
                npm ERR! missing: form-data@^4.0.0, required by axios@1.3.5
                npm ERR! missing: proxy-from-env@^1.1.0, required by axios@1.3.5
                npm ERR! missing: accepts@~1.3.8, required by express@4.18.2
                npm ERR! missing: array-flatten@1.1.1, required by express@4.18.2
                npm ERR! missing: content-disposition@0.5.4, required by express@4.18.2
                npm ERR! missing: content-type@~1.0.4, required by express@4.18.2
                npm ERR! missing: cookie-signature@1.0.6, required by express@4.18.2
                npm ERR! missing: debug@2.6.9, required by express@4.18.2
                npm ERR! missing: depd@2.0.0, required by express@4.18.2
                npm ERR! missing: encodeurl@~1.0.2, required by express@4.18.2
                npm ERR! missing: escape-html@~1.0.3, required by express@4.18.2
                npm ERR! missing: etag@~1.8.1, required by express@4.18.2
                npm ERR! missing: finalhandler@1.2.0, required by express@4.18.2
                npm ERR! missing: fresh@0.5.2, required by express@4.18.2
                npm ERR! missing: http-errors@2.0.0, required by express@4.18.2
                npm ERR! missing: merge-descriptors@1.0.1, required by express@4.18.2
                npm ERR! missing: methods@~1.1.2, required by express@4.18.2
                npm ERR! missing: on-finished@2.4.1, required by express@4.18.2
                npm ERR! missing: parseurl@~1.3.3, required by express@4.18.2
                npm ERR! missing: path-to-regexp@0.1.7, required by express@4.18.2
                npm ERR! missing: proxy-addr@~2.0.7, required by express@4.18.2
                npm ERR! missing: range-parser@~1.2.1, required by express@4.18.2
                npm ERR! missing: send@0.18.0, required by express@4.18.2
                npm ERR! missing: serve-static@1.15.0, required by express@4.18.2
                npm ERR! missing: setprototypeof@1.2.0, required by express@4.18.2
                npm ERR! missing: statuses@2.0.1, required by express@4.18.2
                npm ERR! missing: type-is@~1.6.18, required by express@4.18.2
                npm ERR! missing: utils-merge@1.0.1, required by express@4.18.2
                npm ERR! missing: vary@~1.1.2, required by express@4.18.2
                npm ERR! missing: bytes@3.1.2, required by body-parser@1.20.1
                npm ERR! missing: content-type@~1.0.4, required by body-parser@1.20.1
                npm ERR! missing: debug@2.6.9, required by body-parser@1.20.1
                npm ERR! missing: depd@2.0.0, required by body-parser@1.20.1
                npm ERR! missing: destroy@1.2.0, required by body-parser@1.20.1
                npm ERR! missing: http-errors@2.0.0, required by body-parser@1.20.1
                npm ERR! missing: iconv-lite@0.4.24, required by body-parser@1.20.1
                npm ERR! missing: on-finished@2.4.1, required by body-parser@1.20.1
                npm ERR! missing: raw-body@2.5.1, required by body-parser@1.20.1
                npm ERR! missing: type-is@~1.6.18, required by body-parser@1.20.1
                npm ERR! missing: unpipe@1.0.0, required by body-parser@1.20.1
                npm ERR! missing: side-channel@^1.0.4, required by qs@6.11.0
                npm ERR! missing: graceful-fs@^4.2.0, required by fs-extra@11.1.1
                npm ERR! missing: jsonfile@^6.0.1, required by fs-extra@11.1.1
                npm ERR! missing: universalify@^2.0.0, required by fs-extra@11.1.1
                npm ERR! missing: long-timeout@0.1.1, required by node-schedule@2.1.1
                npm ERR! missing: sorted-array-functions@^1.3.0, required by node-schedule@2.1.1
                Thomas BraunT simatecS 3 Antworten Letzte Antwort
                • K kratan75
                  ├─┬ axios@1.3.5
                  ├─┬ express@4.18.2
                  │ ├── cookie@0.5.0
                  │ ├─┬ qs@6.11.0
                  ├─┬ fs-extra@11.1.1
                  │ │ └── luxon@3.3.0
                  Warum? Macht euch doch nicht immer das Leben durch den Scheiss root selber schwer...
                  • K kratan75
                    ├─┬ axios@1.3.5
                    ├─┬ express@4.18.2
                    │ ├── cookie@0.5.0
                    │ ├─┬ qs@6.11.0
                    ├─┬ fs-extra@11.1.1
                    │ │ └── luxon@3.3.0
                    simatecS Online
                    simatecS Online
                    simatec
                    @kratan75 Hmmm sieht etwas komisch aus...
                    sudo -u iobroker npm install
                    Und arbeite nicht als root auf dem System
                    • simatecS Online
                      simatecS Online
                      simatec
                      Gab es beim Update Fehlermeldungen?
                      Es ist grundsätzlch nicht sinnvoll als root zu arbeiten. Wie @Thomas-Braun schrieb, damt macht ihr euch nur Probleme
                      • K kratan75
                        ├─┬ axios@1.3.5
                        ├─┬ express@4.18.2
                        │ ├── cookie@0.5.0
                        │ ├─┬ qs@6.11.0
                        ├─┬ fs-extra@11.1.1
                        │ │ └── luxon@3.3.0
                        @kratan75
                        Als root ausloggen und niemehr direkt als root einloggen.
                        iob stop
                        iob fix
                        iob start
                        cd /opt/iobroker
                        npm ls
                        • simatecS simatec
                          kratan75
                          @simatec Ich habe es jetzt so gemacht wie Du und Thomas gesagt haben.
                          Alos nicht als root eingeloggt und den npm installiert nun sieht die Ausgabe zwar besser aus, jedoch kommt immer noch ein Fehler am Ende der Liste.
                          Grafana lässt sich trotzdem nicht sichern. Auch nicht mit der IP des Hosts 127.0.0.1, localhost oder die direkte IP-Adresse.
                          iob stop
                          iob fix
                          iob start
                          cd /opt/iobroker
                          npm ls
                          Was bedeutet das nun schon wieder ? Was ist "peer dep" ?
                          pi@iobroker:/opt/iobroker $ npm ls
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├─┬ iobroker.admin@6.3.5
                          │ ├─┬ @iobroker/adapter-core@2.6.7
                          │ │ └─┬ @types/iobroker@4.0.5
                          │ │ └── @types/node@18.0.0 deduped
                          │ ├─┬ @iobroker/socket-classes@1.0.2
                          │ │ ├─┬ @iobroker/adapter-core@2.6.7
                          │ │ │ └─┬ @types/iobroker@4.0.5
                          │ │ │ └── @types/node@18.0.0 deduped
                          │ │ ├─┬ engine.io-client@3.5.2
                          │ │ │ ├── component-emitter@1.3.0 deduped
                          │ │ │ ├── component-inherit@0.0.3
                          │ │ │ ├─┬ debug@3.1.0
                          │ │ │ │ └── ms@2.0.0 deduped
                          │ │ │ ├── engine.io-parser@2.2.1 deduped
                          │ │ │ ├── has-cors@1.1.0
                          │ │ │ ├── indexof@0.0.1 deduped
                          │ │ │ ├── parseqs@0.0.6 deduped
                          │ │ │ ├── parseuri@0.0.6 deduped
                          │ │ │ ├── ws@7.4.6
                          │ │ │ ├── xmlhttprequest-ssl@1.6.3
                          │ │ │ └── yeast@0.1.2
                          │ │ ├── has-binary2@1.0.3 deduped
                          │ │ ├─┬ socket.io-parser@3.3.2
                          │ │ │ ├── debug@3.1.0 deduped
                          │ │ │ └── isarray@2.0.1
                          │ │ └── to-array@0.1.4
                          │ └─┬ socket.io-parser@3.4.1
                          │ ├── component-emitter@1.2.1
                          │ ├─┬ debug@4.1.1
                          │ │ └── ms@2.1.3
                          │ └── isarray@2.0.1
                          ├─┬ iobroker.ws@1.3.0
                          │ ├── @iobroker/adapter-core@2.6.0 deduped
                          │ ├── axios@0.26.1 deduped
                          │ ├── cookie-parser@1.4.6 deduped
                          │ ├── express-session@1.17.3 deduped
                          │ ├─┬ iobroker.ws.server@1.0.1
                          │ │ └── ws@8.8.0 deduped
                          │ └── passport@0.5.3 deduped
                          ├─┬ mime-types@2.1.35
                          │ └── mime-db@1.52.0
                          ├─┬ passport@0.5.3
                          │ ├── passport-strategy@1.0.0 deduped
                          │ └── pause@0.0.1 deduped
                          ├── passport-local@1.0.0 deduped
                          └── xtend@4.0.2
                          npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                          Die Ausgabe bei der Instance ist dieselbe wie vorher.
                          fb59bb1a-597b-4979-bc74-8f28cb8ea6e7-image.png 😠
                          Was kann das sein ?
                          Gruß Andi
                          • K kratan75
                            iob stop
                            iob fix
                            iob start
                            cd /opt/iobroker
                            npm ls
                            │ │ │ ├── ws@7.4.6
                            │ ├─┬ debug@4.1.1
                            │ │ └── ms@2.1.3
                            │ └── isarray@2.0.1
                            ├─┬ passport@0.5.3
                            └── xtend@4.0.2
                            Was kann das sein ?
                            Gruß Andi
                            @kratan75
                            Bitte keine Scteenshots aus der Konsole sondern den Text in CodeTags eingebettet hier rein.
                            iob diag
                            sagt nun zu deiner Installation?
                            Ich vermute da ist deine nodejs-Installation nicht auf Stand.
                              @kratan75
                              iob diag
                              simatecS Online
                              simatecS Online
                              simatec
                              @thomas-braun sieht mir auch so aus. Da sind teilweise ganz alte Versionen
                              • simatecS simatec
                                @simatec
                                Ja, npm>7 sollte auch eigentlich für eine andere Ausgabe bei npm ls sorgen.
                                  kratan75
                                  @simatec Meinst du den js-controller ?
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                                  Adapter    "countdown"    : 1.2.5    , installed 1.2.5
                                  Adapter    "email"        : 1.1.4    , installed 1.1.4
                                  Adapter    "fronius"      : 1.1.3    , installed 1.1.3
                                  Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                  Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                  Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                                  Adapter    "kecontact"    : 1.5.2    , installed 1.5.2
                                  Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                  Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                                  Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                                  Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                                  Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                  • K kratan75
                                    kratan75
                                    @kratan75 Hier nochmal die ganze Ausgabe.
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Model : Raspberry Pi 4 Model B Rev 1.5
                                    Architecture : armv7l
                                    Docker : false
                                    Virtualization : none
                                    Distributor ID: Raspbian
                                    Description: Raspbian GNU/Linux 10 (buster)
                                    Release: 10
                                    Codename: buster
                                    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                    NAME="Raspbian GNU/Linux"
                                    VERSION_ID="10"
                                    VERSION="10 (buster)"
                                    VERSION_CODENAME=buster
                                    ID=raspbian
                                    ID_LIKE=debian
                                    HOME_URL="http://www.raspbian.org/"
                                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                    Systemuptime and Load:
                                    15:36:22 up 19:59, 1 user, load average: 0.54, 0.64, 0.79
                                    CPU threads: 4
                                    *** Time and Time Zones ***
                                    Local time: Sat 2023-04-08 15:36:22 CEST
                                    Universal time: Sat 2023-04-08 13:36:22 UTC
                                    RTC time: n/a
                                    NTP service: active
                                    RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                                    *** X-Server-Setup ***
                                    X-Server: false
                                    Desktop:
                                    Terminal: tty
                                    Boot Target: graphical.target
                                    *** MEMORY ***
                                    total used free shared buff/cache available
                                    Mem: 3.8G 1.1G 1.5G 48M 1.2G 2.9G
                                    Swap: 99M 0B 99M
                                    Total: 3.9G 1.1G 1.6G
                                         3838 M total memory
                                         1141 M used memory
                                          401 M active memory
                                         1774 M inactive memory
                                         1478 M free memory
                                          130 M buffer memory
                                         1088 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                    *** FILESYSTEM ***
                                    Filesystem Type Size Used Avail Use% Mounted on
                                    /dev/root ext4 30G 4.8G 24G 18% /
                                    devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev
                                    tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
                                    tmpfs tmpfs 1.9G 49M 1.9G 3% /run
                                    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                                    tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
                                    /dev/loop1 squashfs 99M 99M 0 100% /snap/core/14788
                                    /dev/loop0 squashfs 384K 384K 0 100% /snap/minicom/1
                                    /dev/loop2 squashfs 99M 99M 0 100% /snap/core/14950
                                    /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot
                                    tmpfs tmpfs 384M 0 384M 0% /run/user/1000
                                    [Fri Apr 7 19:36:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4 :5F:01:A9:73:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=t tyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=y es rootwait
                                    [Fri Apr 7 19:36:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                    [Fri Apr 7 19:36:27 2023] VFS: Mounted root (ext4 filesystem) readonly on devic e 179:2.
                                    [Fri Apr 7 19:36:29 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                    TARGET SOURCE FSTYPE OPTIONS
                                    / /dev/mmcblk0p2 ext4 rw,noatime
                                    |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode= 700
                                    |-/snap/core/14788 /dev/loop1 squashfs ro,nodev,relatime
                                    |-/snap/minicom/1 /dev/loop0 squashfs ro,nodev,relatime
                                    |-/snap/core/14950 /dev/loop2 squashfs ro,nodev,relatime
                                    `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,cod epage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    1.2G /var/
                                    510M /var/lib
                                    325M /var/log
                                    294M /var/lib/snapd
                                    197M /var/lib/snapd/snaps
                                    /opt/iobroker/backups:
                                    461M /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    302M /opt/iobroker/iobroker-data/
                                    252M /opt/iobroker/iobroker-data/files
                                    78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                    51M /opt/iobroker/iobroker-data/files/javascript.admin
                                    35M /opt/iobroker/iobroker-data/backup-objects
                                    11M /opt/iobroker/iobroker-data/objects.jsonl
                                    6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c 9.chunk.js.map
                                    6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.j s.map
                                    6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js.map
                                    5.3M /opt/iobroker/iobroker-data/states.jsonl
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs v14.19.3
                                    /usr/bin/node v14.19.3
                                    /usr/bin/npm 6.14.17
                                    /usr/bin/npx 6.14.17
                                    nodejs:
                                    Installed: 14.19.3-deb-1nodesource1
                                    Candidate: 14.21.3-deb-1nodesource1
                                    Version table:
                                    14.21.3-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                    *** 14.19.3-deb-1nodesource1 100
                                    10.24.0~dfsg-1~deb10u3 500
                                    No problems detected
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States type: jsonl
                                    Core adapters versions
                                    js-controller: 4.0.23
                                    admin: 6.3.5
                                    javascript: 6.1.4
                                    Adapters from github: 5
                                    Adapter State
                                    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admi n
                                    • system.adapter.backitup.0 : backitup : iobroker - enabled
                                    • system.adapter.countdown.0 : countdown : iobroker - enabled
                                    • system.adapter.discovery.0 : discovery : iobroker - enabled
                                    • system.adapter.email.0 : email : iobroker - enabled
                                    • system.adapter.fronius.0 : fronius : iobroker - enabled
                                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob roker - enabled
                                      system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled
                                      system.adapter.icons-material-png.0 : icons-material-png : iobroker - enabled
                                      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - enabled
                                      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled
                                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob roker - enabled
                                      system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled
                                    • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
                                    • system.adapter.javascript.0 : javascript : iobroker - enabled
                                    • system.adapter.kecontact.0 : kecontact : iobroker - enabled
                                    • system.adapter.modbus.0 : modbus : iobroker - enabled
                                    • system.adapter.modbus.1 : modbus : iobroker - enabled
                                    • system.adapter.modbus.2 : modbus : iobroker - enabled
                                    • system.adapter.modbus.3 : modbus : iobroker - enabled
                                      system.adapter.openweathermap.0 : openweathermap : iobroker - enabled
                                    • system.adapter.ping.0 : ping : iobroker - enabled
                                    • system.adapter.pvforecast.0 : pvforecast : iobroker - enabled
                                    • system.adapter.rpi2.0 : rpi2 : iobroker - enabled
                                    • system.adapter.smartmeter.0 : smartmeter : iobroker - enabled
                                      system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled
                                    • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
                                      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
                                      system.adapter.vis.0 : vis : iobroker - enabled
                                      system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled
                                    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admi n
                                    • instance is alive
                                    ioBroker-Repositories
                                    stable : http://download.iobroker.net/sources-dist.json
                                    beta : http://download.iobroker.net/sources-dist-latest.json
                                    Active repo(s): stable
                                    Adapter "simple-api" : 2.7.2 , installed 2.7.2
                                    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
                                    Objects and States
                                    Objects: 3680
                                    States: 3190
                                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Some index files failed to download. They have been ignored, or old ones used instead.
                                    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Hit:3 http://archive.raspbian.org/raspbian buster InRelease
                                    Get:4 https://repos.influxdata.com/debian buster InRelease [7029 B]
                                    Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
                                    Err:4 https://repos.influxdata.com/debian buster InRelease
                                    Fetched 7029 B in 2s (4352 B/s)
                                    Reading package lists...
                                    Pending Updates: 107
                                    *** Listening Ports ***
                                    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                                    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18055 659/sshd
                                    tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 15205 652/influxd
                                    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1140135 19291/iobroker.js-c
                                    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1140128 19291/iobroker.js-c
                                    tcp6 0 0 :::8081 :::* LISTEN 1001 1141192 19309/io.admin.0
                                    tcp6 0 0 :::8082 :::* LISTEN 1001 1140639 19686/io.web.0
                                    tcp6 0 0 :::8086 :::* LISTEN 999 18118 652/influxd
                                    tcp6 0 0 :::22 :::* LISTEN 0 18057 659/sshd
                                    tcp6 0 0 :::3000 :::* LISTEN 109 16125 643/grafana-server
                                    udp 0 0 0.0.0.0:60833 0.0.0.0:* 108 16868 396/avahi-daemon: r
                                    udp 0 0 0.0.0.0:7090 0.0.0.0:* 1001 1141592 19670/io.kecontact.
                                    udp 0 0 0.0.0.0:7092 0.0.0.0:* 1001 1141593 19670/io.kecontact.
                                    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15891 633/dhcpcd
                                    udp 0 0 0.0.0.0:47717 0.0.0.0:* 1001 1141594 19670/io.kecontact.
                                    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 16866 396/avahi-daemon: r
                                    udp6 0 0 :::49312 :::* 108 16869 396/avahi-daemon: r
                                    udp6 0 0 :::5353 :::* 108 16867 396/avahi-daemon: r
                                    2023-04-08 15:34:52.440 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:34:58.571 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                    2023-04-08 15:35:04.644 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:10.874 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:17.246 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:23.619 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:30.126 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:36.534 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:42.060 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:47.670 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:35:53.339 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                    2023-04-08 15:35:59.067 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:04.617 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:10.358 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:16.341 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:22.283 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:28.263 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:34.442 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:40.609 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:47.138 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:36:54.256 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:37:00.904 - info: smartmeter.0 (19375) Received 13 values, 5 updated
                                    2023-04-08 15:37:07.485 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:37:16.405 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    2023-04-08 15:37:23.365 - info: smartmeter.0 (19375) Received 13 values, 6 updated
                                    iob diag has finished.
                                    • K kratan75
                                      Skript v.2023-04-02
                                      *** BASE SYSTEM ***
                                      Docker : false
                                      Release: 10
                                      Codename: buster
                                      VERSION_ID="10"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                      RTC time: n/a
                                      NTP service: active
                                      RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server: false
                                      Desktop:
                                      Terminal: tty
                                      *** MEMORY ***
                                      Swap: 99M 0B 99M
                                           3838 M total memory
                                           1141 M used memory
                                            401 M active memory
                                           1478 M free memory
                                            130 M buffer memory
                                           1088 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.2G /var/
                                      510M /var/lib
                                      325M /var/log
                                      294M /var/lib/snapd
                                      nodejs:
                                      Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States type: jsonl
                                      admin: 6.3.5
                                      javascript: 6.1.4
                                      Adapter State
                                      • instance is alive
                                      Objects and States
                                      Objects: 3680
                                      States: 3190
                                      kratan75
                                      @kratan75 Hier die NodeJS Installation. Denke die wolltet Ihr sehen.
                                      nodejs:
                                        Version table:
                                      K Thomas BraunT 2 Antworten Letzte Antwort
                                      • K kratan75
                                        nodejs:
                                          Version table:
                                        kratan75
                                        @kratan75 ```
                                                             v.2023-04-02
                                        Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                                        Kernel:                 5.10.103-v7l+
                                        Installation:           Native
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     107
                                        Pending iob updates:    2
                                        Nodejs-Installation:    /usr/bin/nodejs         v14.19.3
                                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                                        MEMORY:
                                        Mem:           3.8G        1.2G        1.5G         48M        1.2G        2.9G
                                        Swap:           99M          0B         99M
                                        Total:         3.9G        1.2G        1.6G
                                        Active iob-Instances:   20
                                        ioBroker Core:          js-controller           4.0.23
        admin                   6.3.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                3680
                                        States:                 3190
                                        Size of iob-Database:
                                        6.9M    /opt/iobroker/iobroker-data/states.jsonl
                                        ext
                                        • K kratan75
                                          nodejs:
                                            Version table:
                                          @kratan75
                                          Die influxdb-Quelle muss angepackt werden.
                                          Dann funktionieren auch Upgrades wieder und du kannst die 107 geschluderten Upgrades einspielen.
                                          Und was haste da mit snapd gemacht? Vollkommen unüblich für Server.
                                          Dann das Ganze auf nodejs 18 bringen.
                                          Und zu guter Letzt den abgekündigten Buster beerdigen und Bullseye installieren.
                                          Das wiederum würde ich in der 64bit-Version gleich neu installieren.
