  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
    apollon77A
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 271.6k Aufrufe 52 Beobachtet
  • KnallochseK Knallochse
    Eine Installation des Adapters vofo-speedtest unter Node Version 18.15.0 ist leider nicht mehr möglich.
    $ iobroker add vofo-speedtest auto --host buanet-iobroker1 --debug
    NPM version: 9.5.0
    Installing iobroker.vofo-speedtest@0.0.13... (System call)
    npm ERR! code 1
    npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
    npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2023-04-04T09_56_47_982Z-debug-0.log
    host.buanet-iobroker1 Cannot install iobroker.vofo-speedtest@0.0.13: 1
    ERROR: Process exited with code 25
    Github Issues dazu
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @knallochse sagte in Troubleshooting NodeJS update:
    Schau mal ob das installiert ist. Wobei mich die Abhängigkeit von libcurl-dev irritiert...
    Das dürfte eher kein Problem von/mit nodejs sein.
    sudo apt update
    apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
    sagt?
    • KnallochseK
      KnallochseK
      Knallochse
      @thomas-braun sagte in Troubleshooting NodeJS update:
      Danke für deine Antwort.
      Hier die Ausgabe :
      root@buanet-iobroker1:/opt/iobroker# sudo apt update
      sudo: unable to resolve host buanet-iobroker1: Name or service not known
      Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:2 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
      Get:4 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
      Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.183 kB]
      Get:6 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages [776 B]
      Get:7 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages [236 kB]
      Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [14,6 kB]
      Fetched 8.648 kB in 5s (1.761 kB/s)
      Reading package lists... Done
      All packages are up to date.
      root@buanet-iobroker1:/opt/iobroker# apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
      libcurl4-gnutls-dev:
        Installed: (none)
        Candidate: 7.74.0-1.3+deb11u7
        Version table:
           7.74.0-1.3+deb11u7 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           7.74.0-1.3+deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      libcurl4-nss-dev:
        Installed: (none)
        Version table:
      libcurl4-openssl-dev:
        Installed: (none)
        Version table:
        Hier die Ausgabe :
          Installed: (none)
          Version table:
        libcurl4-nss-dev:
          Installed: (none)
          Version table:
          Installed: (none)
          Version table:
        Thomas BraunT
        Thomas BraunT
        @knallochse
        Siehste. Nix installiert, dann kann auch curl-config nicht aufgerufen werden.
        Ist kein nodejs-Thema, eines der Pakete muss installiert werden.
        KnallochseK 1 Antwort Letzte Antwort
          @knallochse
          KnallochseK
          KnallochseK
          Knallochse
          @thomas-braun Dankeschön 👍
            sudo apt update
            sagt?
            Thomas BraunT
            Thomas BraunT
            Wenn man drüber nachdenkt...
            gyp als 'Kompiler' braucht natürlich entsprechende dev-Pakete. Also alles i. O.
            • T
              T
              tschfs
              ich bin nach Jahrzehnten wieder neu gestartet mit Linux und will den ioBroker auf Debian zum Laufen bekommen. Meine Linux Kenntnisse stammen daher noch aus der Informatiker Ausbildung und geben nicht mehr viel her. Leider fehlt dem iobroker die richtige npm und nodejs Version. Ich bin entsprechend der Anleitung hier im Forum vorgegangen, es wird aber immer die Version v12.22.12 installiert.
              apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev nodejs npm
                Installiert:           (keine)
                Installationskandidat: 7.74.0-1.3+deb11u7
                Versionstabelle:
                      500 http://security.debian.org/debian-security bullseye-security/main i386 Packages
                      500 http://deb.debian.org/debian bullseye/main i386 Packages
                   7.64.0-4+deb10u2 500
                      500 http://http.debian.net/debian buster/main i386 Packages
              libcurl4-nss-dev:
                Versionstabelle:
                Versionstabelle:
              nodejs:
                Installiert:           12.22.12~dfsg-1~deb11u3
                Installationskandidat: 12.22.12~dfsg-1~deb11u3
                Versionstabelle:
               *** 12.22.12~dfsg-1~deb11u3 500
                   12.22.5~dfsg-2~11u1 500
                   10.24.0~dfsg-1~deb10u1 500
              npm:
                Installationskandidat: 7.5.2+ds-2
                Versionstabelle:
                   7.5.2+ds-2 500
                   5.8.0+ds6-4+deb10u2 500
              Würde mich freuen, wenn mir jemand weiterhelfen kann.
              Ich habe auch bereits versucht nodejs über nvm zu installieren, nvm findet aber kein passendes linux-x86 Paket, daher schlägt der Download fehl. Nachdem ich schon 2 Tage alles versuche habe ich heute das OS nochmal komplett frisch installiert und aktuell nach der Debian Installation nichts weiter verändert außer nodejs v18 zu installieren versucht.
              • T tschfs
                  Versionstabelle:
                libcurl4-nss-dev:
                  Versionstabelle:
                  Versionstabelle:
                nodejs:
                  Versionstabelle:
                npm:
                  Versionstabelle:
                     7.5.2+ds-2 500
                Thomas BraunT
                Thomas BraunT
                @tschfs sagte in Troubleshooting NodeJS update:
                Lass die Finger von nvm.
                In meiner Signatur findest du eine Anleitung, wie man nodejs ordentlich über den bordeigenen Paketmanager installiert.
                Für i386 wirst du auch nichts aktuelles finden, weil dafür keiner mehr baut.
                Wo haste denn den i386 ausgegraben? Sind die nicht vom letzten Kaiser verboten worden? Installier da ein 64bit-Debian.
                  T
                  T
                  tschfs
                  @thomas-braun danke, habe ich nach der Neuinstallation des OS genau nach deiner Anleitung versucht. Es kommt immer wieder die v12.x raus.
                  • T tschfs
                    Thomas BraunT
                    Thomas BraunT
                    @tschfs
                    Liegt an i386. Siehe edit oben.
                      @tschfs
                      T
                      T
                      tschfs
                      @thomas-braun habs zu spät gesehen, habs aber schon befürchtet. Hatte mir spontan was von Heise gezogen und eine Boot-Stick gebaut. Dann werd ichs wohl nochmal von vorne angehen. Melde mich dann wieder ;-)
                      • T tschfs
                        Thomas BraunT
                        Thomas BraunT
                        @tschfs
                        Und du fährst da einen kruden Mix aus buster und bullseye Repos. Das bricht dir auch beide Beine.
                        • T tschfs
                          Thomas BraunT
                          Thomas BraunT
                          Wat treibt ihr eigentlich immer für schräges Zeuch... seufz.
                            T
                            T
                            tschfs
                            @thomas-braun So läuft jetzt mit einem 64bit Debian. Danke nochmal für den Tipp!
                            • T tschfs
                              Thomas BraunT
                              Thomas BraunT
                              @tschfs
                              Und was haste da jetzt am Start?
                              Zeig mal die Zusammenfassung von
                              iob diag
                              • astuermerA
                                astuermerA
                                astuermer
                                schrieb am zuletzt editiert von astuermer
                                Hab hier ioBroker auf Bullseye installiert und bekomme beim Eintragen der Node 18.x Quellen untenstehende Fehlermeldung. Auch /node_16.x/ nimmt er nicht (um zumindest 16.20.0 zu installieren) - selbe Fehlermeldung. Ich kann nur die vorhin installierte 16.19.1 wieder installieren.
                                Ne Idee?
                                ## Confirming "" is supported...
                                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists//Release'
                                ## Your distribution, identified as "", is not currently supported, please contact NodeSource at https://github.com/nodesource/distributions/issues if you think this is incorrect or would like your distribution to be considered for support
                                • astuermerA astuermer
                                  Ne Idee?
                                  Thomas BraunT
                                  Thomas BraunT
                                  @astuermer
                                  Was haste denn da laufen?
                                  sudo apt update
                                  schaut wie aus?
                                  astuermerA 1 Antwort Letzte Antwort
                                    @astuermer
                                    sudo apt update
                                    schaut wie aus?
                                    astuermerA
                                    astuermerA
                                    astuermer
                                    @thomas-braun said in Troubleshooting NodeJS update:
                                    sudo apt update
                                    OK:1 http://phoscon.de/apt/deconz buster InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:3 https://downloads.plex.tv/repo/deb public InRelease
                                    OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                    OK:5 http://archive.raspberrypi.org/debian buster InRelease
                                    Alle Pakete sind aktuell.
                                      sudo apt update
                                      Thomas BraunT
                                      Thomas BraunT
                                      @astuermer sagte in Troubleshooting NodeJS update:
                                      Aber dein Betriebssystem nicht. Bzw. die Einträge in den list-Dateien nicht.
                                      Wie willst du denn damit bullseye installiert haben?
                                      iob diag
                                      sagt?
                                        iob diag
                                        sagt?
                                        astuermerA
                                        astuermerA
                                        astuermer
                                        iob diag
                                        Ach Mist, da läuft ja tatsächlich noch der Buster drauf facepalm
                                        Mir kommen schon meine Pi's durcheinander.
                                        Sorry...
                                          iob diag
                                          Sorry...
                                          Thomas BraunT
                                          Thomas BraunT
                                          @astuermer
                                          Dann upgrade das ordentlich auf Bullseye, der Buster hat sein EndOfLife erreicht.
                                          84.1k
