  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @glasfaser said in ioBroker Backup wieder einspielen:
    @federal sagte in ioBroker Backup wieder einspielen:
    so wie ich es verstehe, wurden nur 5 Adapter gestartet.
    Du hast doch ein Backup/Restore eingespielt ... und das dauert
    Aber :
    durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
    Wie soll ich weiter vorgehen?
    Neues Backup/Restore einspielen .
    habe ein Backup eigespielt
    System successfully restored!
    pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
    The adapter "history.0" was started.
    The adapter "javascript.0" was started.
    The adapter "scenes.0" was started.
    The adapter "telegram.0" was started.
    The adapter "chromecast.0" was started.
    The adapter "hmip.0" was started.
    The adapter "ical.0" was started.
    The adapter "netatmo.0" was started.
    The adapter "ping.0" was started.
    The adapter "shelly.0" was started.
    The adapter "sonoff.0" was started.
    The adapter "tuya.0" was started.
    The adapter "weatherunderground.0" was started.
    The adapter "zigbee.0" was started.
    The adapter "broadlink2.0" was started.
    The adapter "cloud.0" was started.
    The adapter "discovery.0" was started.
    The adapter "echarts.0" was started.
    The adapter "fb-checkpresence.0" was started.
    The adapter "feiertage.0" was started.
    The adapter "fullybrowser.0" was started.
    The adapter "harmony.0" was started.
    The adapter "info.0" was started.
    The adapter "iot.0" was started.
    The adapter "panasonic-comfort-cloud.0" was started.
    The adapter "sayit.0" was started.
    The adapter "sayit.1" was started.
    The adapter "sayit.2" was started.
    The adapter "sayit.3" was started.
    The adapter "tado.0" was started.
    The adapter "tankerkoenig.0" was started.
    The adapter "text2command.1" was started.
    The adapter "trashschedule.0" was started.
    The adapter "vis-inventwo.0" was started.
    The adapter "vis-timeandweather.0" was started.
    The adapter "vis.0" was started.
    The adapter "web.0" was started.
    The adapter "worx.0" was started.
    kann aber nach wie vor nicht auf iob zugreifen
    @homoran sagte in ioBroker Backup wieder einspielen:
    admin als https konfiguriert?
    und deaktiviert
    F 1 Antwort Letzte Antwort
      Temp directories causing npm8 problem: 894
      Hast du da mal als root herumgehampelt?
      Das sollte der iob fix nämlich eigentlich bereinigen.
      find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
      bringt?
      federal
      @thomas-braun said in ioBroker Backup wieder einspielen:
      wenn, dann unbewusst
      • F federal
        @federal
        load average: 12.11, 9.94, 6.40
        Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
        HomoranH F 2 Antworten Letzte Antwort
          und deaktiviert
          federal
          @homoran said in ioBroker Backup wieder einspielen:
          und deaktiviert
          https war eingerichtet. Wie kann ich es deaktivieren?
            @federal
            load average: 2.40, 2.64, 2.80
            hat auch gut zu rödeln!
            ich werde anscheinend ignoriert
              <4 ist doch i.O.
                <4 ist doch i.O.
                @thomas-braun aber nicht, wenn angeblich nichts läuft
                • F federal
                  @federal
                  Der admin läuft nicht.
                  iob start admin
                  Hast du zwischenzeitlich den
                  iob fix
                  ausgeführt?
                  leider unverändert
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  pi@raspberrypi:/opt/iobroker/backups $ iob start
                  pi@raspberrypi:/opt/iobroker/backups $ iob start admin
                  The adapter "admin.0" was started.
                  pi@raspberrypi:/opt/iobroker/backups $ iob list instances
                    system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                    system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                    system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                    system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                    system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                    system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                    system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                    system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                    system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                    system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
                  + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                    system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                    system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
                    system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
                    system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
                  + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                    system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                    system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
                    system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                  + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                    system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
                  + instance is alive
                  unter iobroker logs --watch läuft was
                  federal
                  @federal said in ioBroker Backup wieder einspielen:
                  @federal
                  iob start admin
                  iob fix
                  habe mal ein Ausschnitt gemacht
                  2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                  2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                  2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                  2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                  2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                  2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                  2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                  2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                  2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                  2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                  2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                  2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                  2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                  2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                  • F federal
                    @federal
                    iob start admin
                    iob fix
                    @federal
                    Starte die Kiste mal durch...
                    Sauber!
                    sudo reboot
                      @federal
                      Sauber!
                      sudo reboot
                      federal
                      @federal
                      Sauber!
                      sudo reboot
                      jetzt bin ich wieder am Anfang von heute
                      pi@raspberrypi:~ $ iobroker status
                      node:internal/modules/cjs/loader:1024
                        throw err;
                      Error: Cannot find module 'buffer-equal-constant-time'
                      Require stack:
                      - /opt/iobroker/node_modules/jwa/index.js
                      - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                      - /opt/iobroker/node_modules/jws/index.js
                      - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                      - /opt/iobroker/node_modules/jsonwebtoken/index.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                          at Module.require (node:internal/modules/cjs/loader:1093:19)
                          at require (node:internal/modules/cjs/helpers:108:18)
                          at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                          at Module._compile (node:internal/modules/cjs/loader:1191:14)
                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                          at Module.load (node:internal/modules/cjs/loader:1069:32)
                          at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                          at Module.require (node:internal/modules/cjs/loader:1093:19) {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/opt/iobroker/node_modules/jwa/index.js',
                          '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                          '/opt/iobroker/node_modules/jws/index.js',
                          '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                          '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        @federal
                        federal
                        @federal
                        ich verstehe es leider nicht
                        • Thomas BraunT Online
                          Ich auch nicht.
                          Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                          Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                          Mit
                          top
                          schauen was da los ist.
                          Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                          echad@chet:~ $ uptime
                           20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                            Ich auch nicht.
                            Mit
                            top
                            federal
                            Ich auch nicht.
                            Mit
                            top
                            • F federal
                              Ich auch nicht.
                              Mit
                              top
                              @federal
                              Nach dem reboot schaut es gesünder aus.
                                @federal
                                federal
                                @federal
                                iob ist immer noch nicht erreichbar.
                                Ich muss mich ausklinken. Danke an alle.
                                • F federal
                                  @federal
                                  Er läuft ja auch nicht.
                                    federal
                                    schrieb am zuletzt editiert von federal
                                    lässt sich auch nicht starten. Was kann ich noch tun?
                                    das zeigt die Statusanzeige
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    • F federal
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      @federal
                                      Last login: Tue Apr  4 15:43:58 2023 from 100.75.198.95
                                      echad@chet:~ $ cd /opt/iobroker/
                                      echad@chet:/opt/iobroker $ npm ls buffer-equal-constant-time
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├─┬ iobroker.backitup@2.6.16
                                      │ └─┬ google-auth-library@8.7.0
                                      │   └─┬ jws@4.0.0
                                      │     └─┬ jwa@2.0.0
                                      │       └── buffer-equal-constant-time@1.0.1
                                      └─┬ iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
                                        └─┬ jsonwebtoken@9.0.0
                                          └─┬ jws@3.2.2
                                            └─┬ jwa@1.4.1
                                              └── buffer-equal-constant-time@1.0.1 deduped
                                      Ich würde den js-controller nochmal installieren.
                                        @federal
                                        │   └─┬ jws@4.0.0
                                        │     └─┬ jwa@2.0.0
                                            └─┬ jws@3.2.2
                                              └─┬ jwa@1.4.1
                                        federal
                                        @federal
                                        │   └─┬ jws@4.0.0
                                        │     └─┬ jwa@2.0.0
                                            └─┬ jws@3.2.2
                                              └─┬ jwa@1.4.1
                                        wie mache ich das?
                                        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                        • F federal
                                          @federal
                                          │   └─┬ jws@4.0.0
                                          │     └─┬ jwa@2.0.0
                                              └─┬ jws@3.2.2
                                                └─┬ jwa@1.4.1
                                          wie mache ich das?
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          wie mache ich das?
                                          https://forum.iobroker.net/post/972634
