  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
    @federal
    iob diag
    sagt nun?
    federal
    @thomas-braun said in ioBroker Backup wieder einspielen:
    iob diag
    Skript v.2023-04-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-04-03 20:09:23 CEST
               Universal time: Mon 2023-04-03 18:09:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
    Swap:           99M         55M         44M
    Total:         3.9G        2.1G        128M
             3838 M total memory
             2019 M used memory
              487 M active memory
             3075 M inactive memory
               84 M free memory
              196 M buffer memory
             1537 M swap cache
               99 M total swap
               55 M used swap
               44 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  8.5G   20G  31% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    576M    /var/
    213M    /var/cache
    200M    /var/cache/apt
    142M    /var/log
    141M    /var/cache/apt/archives
    /opt/iobroker/backups:
    103M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    435M    /opt/iobroker/iobroker-data/
    311M    /opt/iobroker/iobroker-data/files
    85M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    Temp directories causing npm8 problem: 894
    Some problems detected, please run iob fix
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tado"         : 0.4.5    , installed 0.4.5
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "worx"         : 2.0.3    , installed 2.0.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        8552
    States:         8771
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
    udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
    udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
    2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
    2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
    2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
    2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
    2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
    2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
    2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
    2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
    2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
    2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
    2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
    2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
    2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    Press any key for a summary
    führe gleich iob fix aus
    • F federal
      iob diag
      Skript v.2023-04-02
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M         55M         44M
               3838 M total memory
               2019 M used memory
                487 M active memory
                 84 M free memory
                196 M buffer memory
               1537 M swap cache
                 99 M total swap
                 55 M used swap
                 44 M free swap
      *** FILESYSTEM ***
      /var:
      576M    /var/
      213M    /var/cache
      200M    /var/cache/apt
      142M    /var/log
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8552
      States:         8771
      Pending Updates: 0
      @federal sagte in ioBroker Backup wieder einspielen:
      Hast du da mal als root herumgehampelt?
      Das sollte der iob fix nämlich eigentlich bereinigen.
      find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
      bringt?
      F 1 Antwort Letzte Antwort
      • F federal
        @glasfaser said in ioBroker Backup wieder einspielen:
        so wie ich es verstehe, wurden nur 5 Adapter gestartet.
        Du hast doch ein Backup/Restore eingespielt ... und das dauert
        Aber :
        durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
        Wie soll ich weiter vorgehen?
        Neues Backup/Restore einspielen .
        habe ein Backup eigespielt
        System successfully restored!
        pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
        The adapter "history.0" was started.
        The adapter "javascript.0" was started.
        The adapter "scenes.0" was started.
        The adapter "telegram.0" was started.
        The adapter "chromecast.0" was started.
        The adapter "hmip.0" was started.
        The adapter "ical.0" was started.
        The adapter "netatmo.0" was started.
        The adapter "ping.0" was started.
        The adapter "shelly.0" was started.
        The adapter "sonoff.0" was started.
        The adapter "tuya.0" was started.
        The adapter "weatherunderground.0" was started.
        The adapter "zigbee.0" was started.
        The adapter "broadlink2.0" was started.
        The adapter "cloud.0" was started.
        The adapter "discovery.0" was started.
        The adapter "echarts.0" was started.
        The adapter "fb-checkpresence.0" was started.
        The adapter "feiertage.0" was started.
        The adapter "fullybrowser.0" was started.
        The adapter "harmony.0" was started.
        The adapter "info.0" was started.
        The adapter "iot.0" was started.
        The adapter "panasonic-comfort-cloud.0" was started.
        The adapter "sayit.0" was started.
        The adapter "sayit.1" was started.
        The adapter "sayit.2" was started.
        The adapter "sayit.3" was started.
        The adapter "tado.0" was started.
        The adapter "tankerkoenig.0" was started.
        The adapter "text2command.1" was started.
        The adapter "trashschedule.0" was started.
        The adapter "vis-inventwo.0" was started.
        The adapter "vis-timeandweather.0" was started.
        The adapter "vis.0" was started.
        The adapter "web.0" was started.
        The adapter "worx.0" was started.
        kann aber nach wie vor nicht auf iob zugreifen
        @homoran sagte in ioBroker Backup wieder einspielen:
        admin als https konfiguriert?
        und deaktiviert
          bringt?
          federal
          wenn, dann unbewusst
          • F federal
            @federal
            Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
            HomoranH F 2 Antworten Letzte Antwort
              und deaktiviert
              federal
              @homoran said in ioBroker Backup wieder einspielen:
              und deaktiviert
              https war eingerichtet. Wie kann ich es deaktivieren?
                @federal
                load average: 2.40, 2.64, 2.80
                hat auch gut zu rödeln!
                ich werde anscheinend ignoriert
                  <4 ist doch i.O.
                    <4 ist doch i.O.
                    @thomas-braun aber nicht, wenn angeblich nichts läuft
                    • F federal
                      @federal
                      Der admin läuft nicht.
                      iob start admin
                      Hast du zwischenzeitlich den
                      iob fix
                      ausgeführt?
                      leider unverändert
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      pi@raspberrypi:/opt/iobroker/backups $ iob start
                      pi@raspberrypi:/opt/iobroker/backups $ iob start admin
                      The adapter "admin.0" was started.
                      pi@raspberrypi:/opt/iobroker/backups $ iob list instances
                      + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                      + instance is alive
                      unter iobroker logs --watch läuft was
                      federal
                      @federal said in ioBroker Backup wieder einspielen:
                      @federal
                      iob start admin
                      iob fix
                      habe mal ein Ausschnitt gemacht
                      2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                      2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                      2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                      2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                      2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                      2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                      2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                      2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                      2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                      2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                      2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                      2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                      2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                      2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                      2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                      2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                      2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                      2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                      2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                      • F federal
                        @federal
                        iob start admin
                        iob fix
                        @federal
                        Starte die Kiste mal durch...
                        Sauber!
                        sudo reboot
                          @federal
                          Sauber!
                          sudo reboot
                          federal
                          @federal
                          Sauber!
                          sudo reboot
                          jetzt bin ich wieder am Anfang von heute
                          pi@raspberrypi:~ $ iobroker status
                          node:internal/modules/cjs/loader:1024
                            throw err;
                          Error: Cannot find module 'buffer-equal-constant-time'
                          Require stack:
                          - /opt/iobroker/node_modules/jwa/index.js
                          - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                          - /opt/iobroker/node_modules/jws/index.js
                          - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                          - /opt/iobroker/node_modules/jsonwebtoken/index.js
                          - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                          - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                              at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                              at Module.require (node:internal/modules/cjs/loader:1093:19)
                              at require (node:internal/modules/cjs/helpers:108:18)
                              at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                              at Module._compile (node:internal/modules/cjs/loader:1191:14)
                              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                              at Module.load (node:internal/modules/cjs/loader:1069:32)
                              at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                              at Module.require (node:internal/modules/cjs/loader:1093:19) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/opt/iobroker/node_modules/jwa/index.js',
                              '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                              '/opt/iobroker/node_modules/jws/index.js',
                              '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                              '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                              '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                              '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            @federal
                            federal
                            @federal
                            ich verstehe es leider nicht
                            • Thomas BraunT Online
                              Ich auch nicht.
                              Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                              Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                              Mit
                              top
                              schauen was da los ist.
                              Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                              echad@chet:~ $ uptime
                               20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                                Ich auch nicht.
                                Mit
                                top
                                federal
                                Ich auch nicht.
                                Mit
                                top
                                • F federal
                                  Ich auch nicht.
                                  Mit
                                  top
                                  @federal
                                  Nach dem reboot schaut es gesünder aus.
                                    @federal
                                    federal
                                    @federal
                                    iob ist immer noch nicht erreichbar.
                                    Ich muss mich ausklinken. Danke an alle.
                                    • F federal
                                      @federal
                                      Er läuft ja auch nicht.
                                        federal
                                        schrieb am zuletzt editiert von federal
                                        lässt sich auch nicht starten. Was kann ich noch tun?
                                        das zeigt die Statusanzeige
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        • F federal
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          @federal
                                          Last login: Tue Apr  4 15:43:58 2023 from 100.75.198.95
                                          echad@chet:~ $ cd /opt/iobroker/
                                          echad@chet:/opt/iobroker $ npm ls buffer-equal-constant-time
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├─┬ iobroker.backitup@2.6.16
                                          │ └─┬ google-auth-library@8.7.0
                                          │   └─┬ jws@4.0.0
                                          │     └─┬ jwa@2.0.0
                                          │       └── buffer-equal-constant-time@1.0.1
                                          └─┬ iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
                                            └─┬ jsonwebtoken@9.0.0
                                              └─┬ jws@3.2.2
                                                └─┬ jwa@1.4.1
                                                  └── buffer-equal-constant-time@1.0.1 deduped
                                          Ich würde den js-controller nochmal installieren.
