  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @thomas-braun said in ioBroker Backup wieder einspielen:
    @federal
    Der admin läuft nicht.
    iob start admin
    Hast du zwischenzeitlich den
    iob fix
    ausgeführt?
    leider unverändert
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker/backups $ iob start
    pi@raspberrypi:/opt/iobroker/backups $ iob start admin
    The adapter "admin.0" was started.
    pi@raspberrypi:/opt/iobroker/backups $ iob list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
      system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
      system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
      system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
    + instance is alive
    unter iobroker logs --watch läuft was
    @federal sagte in ioBroker Backup wieder einspielen:
    läuft was
    Aha. Was geheimes?
    • F federal
      @federal
      iob start admin
      iob fix
      ausgeführt?
      leider unverändert
      + instance is alive
      @federal
      iob diag
      sagt nun?
      F 1 Antwort Letzte Antwort
        @federal
        iob diag
        sagt nun?
        federal
        iob diag
        Skript v.2023-04-02
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Mon 2023-04-03 20:09:23 CEST
                   Universal time: Mon 2023-04-03 18:09:23 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
        Swap:           99M         55M         44M
        Total:         3.9G        2.1G        128M
                 3838 M total memory
                 2019 M used memory
                  487 M active memory
                 3075 M inactive memory
                   84 M free memory
                  196 M buffer memory
                 1537 M swap cache
                   99 M total swap
                   55 M used swap
                   44 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       29G  8.5G   20G  31% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        576M    /var/
        213M    /var/cache
        200M    /var/cache/apt
        142M    /var/log
        141M    /var/cache/apt/archives
        /opt/iobroker/backups:
        103M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        435M    /opt/iobroker/iobroker-data/
        311M    /opt/iobroker/iobroker-data/files
        85M     /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        11M     /opt/iobroker/iobroker-data/objects.jsonl
        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
        9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.1
        /usr/bin/node           v16.19.1
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Installed: 16.19.1-deb-1nodesource1
          Candidate: 16.19.1-deb-1nodesource1
          Version table:
         *** 16.19.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
             10.24.0~dfsg-1~deb10u3 500
        Temp directories causing npm8 problem: 894
        Some problems detected, please run iob fix
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Installed ioBroker-Instances
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.14.2   , installed 1.14.2
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
        Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "tado"         : 0.4.5    , installed 0.4.5
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "text2command" : 2.3.0    , installed 2.3.0
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
        Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "worx"         : 2.0.3    , installed 2.0.3
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects:        8552
        States:         8771
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
        udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
        udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
        2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
        2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
        2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
        2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
        2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
        2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
        2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
        2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
        2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
        2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
        2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
        2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
        2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
        2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
        2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
        2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
        iob diag has finished.
        Press any key for a summary
        führe gleich iob fix aus
        • F federal
          iob diag
          Skript v.2023-04-02
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M         55M         44M
                   3838 M total memory
                   2019 M used memory
                    487 M active memory
                     84 M free memory
                    196 M buffer memory
                   1537 M swap cache
                     99 M total swap
                     55 M used swap
                     44 M free swap
          *** FILESYSTEM ***
          /var:
          576M    /var/
          213M    /var/cache
          200M    /var/cache/apt
          142M    /var/log
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8552
          States:         8771
          Pending Updates: 0
          Hast du da mal als root herumgehampelt?
          Das sollte der iob fix nämlich eigentlich bereinigen.
          find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
          bringt?
          • F federal
            @glasfaser said in ioBroker Backup wieder einspielen:
            so wie ich es verstehe, wurden nur 5 Adapter gestartet.
            Du hast doch ein Backup/Restore eingespielt ... und das dauert
            Aber :
            durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
            Wie soll ich weiter vorgehen?
            Neues Backup/Restore einspielen .
            habe ein Backup eigespielt
            System successfully restored!
            pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
            The adapter "history.0" was started.
            The adapter "javascript.0" was started.
            The adapter "scenes.0" was started.
            The adapter "telegram.0" was started.
            The adapter "chromecast.0" was started.
            The adapter "hmip.0" was started.
            The adapter "ical.0" was started.
            The adapter "netatmo.0" was started.
            The adapter "ping.0" was started.
            The adapter "shelly.0" was started.
            The adapter "sonoff.0" was started.
            The adapter "tuya.0" was started.
            The adapter "weatherunderground.0" was started.
            The adapter "zigbee.0" was started.
            The adapter "broadlink2.0" was started.
            The adapter "cloud.0" was started.
            The adapter "discovery.0" was started.
            The adapter "echarts.0" was started.
            The adapter "fb-checkpresence.0" was started.
            The adapter "feiertage.0" was started.
            The adapter "fullybrowser.0" was started.
            The adapter "harmony.0" was started.
            The adapter "info.0" was started.
            The adapter "iot.0" was started.
            The adapter "panasonic-comfort-cloud.0" was started.
            The adapter "sayit.0" was started.
            The adapter "sayit.1" was started.
            The adapter "sayit.2" was started.
            The adapter "sayit.3" was started.
            The adapter "tado.0" was started.
            The adapter "tankerkoenig.0" was started.
            The adapter "text2command.1" was started.
            The adapter "trashschedule.0" was started.
            The adapter "vis-inventwo.0" was started.
            The adapter "vis-timeandweather.0" was started.
            The adapter "vis.0" was started.
            The adapter "web.0" was started.
            The adapter "worx.0" was started.
            kann aber nach wie vor nicht auf iob zugreifen
            @homoran sagte in ioBroker Backup wieder einspielen:
            admin als https konfiguriert?
            und deaktiviert
              bringt?
              federal
              wenn, dann unbewusst
              • F federal
                @federal
                Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
                HomoranH F 2 Antworten Letzte Antwort
                  und deaktiviert
                  federal
                  @homoran said in ioBroker Backup wieder einspielen:
                  und deaktiviert
                  https war eingerichtet. Wie kann ich es deaktivieren?
                    @federal
                    load average: 2.40, 2.64, 2.80
                    hat auch gut zu rödeln!
                    ich werde anscheinend ignoriert
                      <4 ist doch i.O.
                        <4 ist doch i.O.
                        @thomas-braun aber nicht, wenn angeblich nichts läuft
                        • F federal
                          @federal
                          iob start admin
                          iob fix
                          ausgeführt?
                          leider unverändert
                          + instance is alive
                          federal
                          @federal said in ioBroker Backup wieder einspielen:
                          @federal
                          iob start admin
                          iob fix
                          habe mal ein Ausschnitt gemacht
                          2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                          2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                          2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                          2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                          2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                          2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                          2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                          2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                          2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                          2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                          2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                          2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                          2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                          2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                          • F federal
                            @federal
                            iob start admin
                            iob fix
                            @federal
                            Starte die Kiste mal durch...
                            Sauber!
                            sudo reboot
                              @federal
                              Sauber!
                              sudo reboot
                              federal
                              @federal
                              Sauber!
                              sudo reboot
                              jetzt bin ich wieder am Anfang von heute
                              pi@raspberrypi:~ $ iobroker status
                              node:internal/modules/cjs/loader:1024
                                throw err;
                              Error: Cannot find module 'buffer-equal-constant-time'
                              Require stack:
                              - /opt/iobroker/node_modules/jwa/index.js
                              - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                              - /opt/iobroker/node_modules/jws/index.js
                              - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                              - /opt/iobroker/node_modules/jsonwebtoken/index.js
                              - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                              - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                                  at Module.require (node:internal/modules/cjs/loader:1093:19)
                                  at require (node:internal/modules/cjs/helpers:108:18)
                                  at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                                  at Module._compile (node:internal/modules/cjs/loader:1191:14)
                                  at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                                  at Module.load (node:internal/modules/cjs/loader:1069:32)
                                  at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                                  at Module.require (node:internal/modules/cjs/loader:1093:19) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/opt/iobroker/node_modules/jwa/index.js',
                                  '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                                  '/opt/iobroker/node_modules/jws/index.js',
                                  '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                                  '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                @federal
                                federal
                                @federal
                                ich verstehe es leider nicht
                                • Thomas BraunT Online
                                  Ich auch nicht.
                                  Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                                  Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                                  Mit
                                  top
                                  schauen was da los ist.
                                  Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                                  echad@chet:~ $ uptime
                                   20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                                    Ich auch nicht.
                                    Mit
                                    top
                                    federal
                                    Ich auch nicht.
                                    Mit
                                    top
                                    • F federal
                                      Ich auch nicht.
                                      Mit
                                      top
                                      @federal
                                      Nach dem reboot schaut es gesünder aus.
                                        @federal
                                        federal
                                        @federal
                                        iob ist immer noch nicht erreichbar.
                                        Ich muss mich ausklinken. Danke an alle.
                                        • F federal
                                          @federal
                                          Er läuft ja auch nicht.
