  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @glasfaser said in ioBroker Backup wieder einspielen:
    iob list instances
    pi@raspberrypi:/opt/iobroker/backups $ iob list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
    + instance is alive
    @federal
    Der admin läuft nicht.
    iob start admin
    Hast du zwischenzeitlich den
    iob fix
    ausgeführt?
    F 1 Antwort Letzte Antwort
      @federal
      iob start admin
      iob fix
      ausgeführt?
      federal
      schrieb am zuletzt editiert von federal
      @thomas-braun said in ioBroker Backup wieder einspielen:
      @federal
      iob start admin
      iob fix
      ausgeführt?
      leider unverändert
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker/backups $ iob start
      pi@raspberrypi:/opt/iobroker/backups $ iob start admin
      The adapter "admin.0" was started.
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      unter iobroker logs --watch läuft was
      Thomas BraunT F 3 Antworten Letzte Antwort
      • F federal
        @federal
        iob start admin
        iob fix
        ausgeführt?
        leider unverändert
        + instance is alive
        @federal sagte in ioBroker Backup wieder einspielen:
        läuft was
        Aha. Was geheimes?
        • F federal
          @federal
          iob start admin
          iob fix
          ausgeführt?
          leider unverändert
          + instance is alive
          @federal
          iob diag
          sagt nun?
            @federal
            iob diag
            sagt nun?
            federal
            iob diag
            Skript v.2023-04-02
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Architecture    : armv7l
            Docker          : false
            Virtualization  : none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Mon 2023-04-03 20:09:23 CEST
                       Universal time: Mon 2023-04-03 18:09:23 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
            Swap:           99M         55M         44M
            Total:         3.9G        2.1G        128M
                     3838 M total memory
                     2019 M used memory
                      487 M active memory
                     3075 M inactive memory
                       84 M free memory
                      196 M buffer memory
                     1537 M swap cache
                       99 M total swap
                       55 M used swap
                       44 M free swap
            *** FILESYSTEM ***
            /dev/root      ext4       29G  8.5G   20G  31% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
            tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            576M    /var/
            213M    /var/cache
            200M    /var/cache/apt
            142M    /var/log
            141M    /var/cache/apt/archives
            /opt/iobroker/backups:
            103M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            435M    /opt/iobroker/iobroker-data/
            311M    /opt/iobroker/iobroker-data/files
            85M     /opt/iobroker/iobroker-data/backup-objects
            72M     /opt/iobroker/iobroker-data/files/telegram.admin
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            11M     /opt/iobroker/iobroker-data/objects.jsonl
            9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
            9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v16.19.1
            /usr/bin/node           v16.19.1
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            nodejs:
              Installed: 16.19.1-deb-1nodesource1
              Candidate: 16.19.1-deb-1nodesource1
              Version table:
             *** 16.19.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u3 500
            Temp directories causing npm8 problem: 894
            Some problems detected, please run iob fix
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     6.1.4
            Adapters from github:   0
            Adapter State
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Installed ioBroker-Instances
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "hmip"         : 1.20.0   , installed 1.20.0
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.14.2   , installed 1.14.2
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
            Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "tado"         : 0.4.5    , installed 0.4.5
            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
            Adapter    "text2command" : 2.3.0    , installed 2.3.0
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
            Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "worx"         : 2.0.3    , installed 2.0.3
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Objects and States
            Objects:        8552
            States:         8771
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
            tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
            tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
            udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
            udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
            2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
            2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
            2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
            2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
            2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
            2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
            2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
            2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
            2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
            iob diag has finished.
            Press any key for a summary
            führe gleich iob fix aus
            • F federal
              iob diag
              Skript v.2023-04-02
              *** BASE SYSTEM ***
              Docker          : false
              Release:        10
              Codename:       buster
              VERSION_ID="10"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           99M         55M         44M
                       3838 M total memory
                       2019 M used memory
                        487 M active memory
                         84 M free memory
                        196 M buffer memory
                       1537 M swap cache
                         99 M total swap
                         55 M used swap
                         44 M free swap
              *** FILESYSTEM ***
              /var:
              576M    /var/
              213M    /var/cache
              200M    /var/cache/apt
              142M    /var/log
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8552
              States:         8771
              Pending Updates: 0
              Hast du da mal als root herumgehampelt?
              Das sollte der iob fix nämlich eigentlich bereinigen.
              find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
              bringt?
              • F federal
                so wie ich es verstehe, wurden nur 5 Adapter gestartet.
                Du hast doch ein Backup/Restore eingespielt ... und das dauert
                Aber :
                durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
                Wie soll ich weiter vorgehen?
                Neues Backup/Restore einspielen .
                habe ein Backup eigespielt
                System successfully restored!
                pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
                The adapter "history.0" was started.
                The adapter "javascript.0" was started.
                The adapter "scenes.0" was started.
                The adapter "telegram.0" was started.
                The adapter "chromecast.0" was started.
                The adapter "hmip.0" was started.
                The adapter "ical.0" was started.
                The adapter "netatmo.0" was started.
                The adapter "ping.0" was started.
                The adapter "shelly.0" was started.
                The adapter "sonoff.0" was started.
                The adapter "tuya.0" was started.
                The adapter "weatherunderground.0" was started.
                The adapter "zigbee.0" was started.
                The adapter "broadlink2.0" was started.
                The adapter "cloud.0" was started.
                The adapter "discovery.0" was started.
                The adapter "echarts.0" was started.
                The adapter "fb-checkpresence.0" was started.
                The adapter "feiertage.0" was started.
                The adapter "fullybrowser.0" was started.
                The adapter "harmony.0" was started.
                The adapter "info.0" was started.
                The adapter "iot.0" was started.
                The adapter "panasonic-comfort-cloud.0" was started.
                The adapter "sayit.0" was started.
                The adapter "sayit.1" was started.
                The adapter "sayit.2" was started.
                The adapter "sayit.3" was started.
                The adapter "tado.0" was started.
                The adapter "tankerkoenig.0" was started.
                The adapter "text2command.1" was started.
                The adapter "trashschedule.0" was started.
                The adapter "vis-inventwo.0" was started.
                The adapter "vis-timeandweather.0" was started.
                The adapter "vis.0" was started.
                The adapter "web.0" was started.
                The adapter "worx.0" was started.
                kann aber nach wie vor nicht auf iob zugreifen
                @homoran sagte in ioBroker Backup wieder einspielen:
                admin als https konfiguriert?
                und deaktiviert
                  bringt?
                  federal
                  wenn, dann unbewusst
                  • F federal
                    @federal
                    Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
                    HomoranH F 2 Antworten Letzte Antwort
                      und deaktiviert
                      federal
                      @homoran said in ioBroker Backup wieder einspielen:
                      und deaktiviert
                      https war eingerichtet. Wie kann ich es deaktivieren?
                        @federal
                        load average: 2.40, 2.64, 2.80
                        hat auch gut zu rödeln!
                        ich werde anscheinend ignoriert
                          <4 ist doch i.O.
                            <4 ist doch i.O.
                            @thomas-braun aber nicht, wenn angeblich nichts läuft
                            • F federal
                              @federal
                              iob start admin
                              iob fix
                              ausgeführt?
                              leider unverändert
                              + instance is alive
                              federal
                              @federal said in ioBroker Backup wieder einspielen:
                              @federal
                              iob start admin
                              iob fix
                              habe mal ein Ausschnitt gemacht
                              2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                              2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                              2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                              2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                              2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                              2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                              2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                              2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                              2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                              2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                              2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                              2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                              2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                              2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                              • F federal
                                @federal
                                iob start admin
                                iob fix
                                @federal
                                Starte die Kiste mal durch...
                                Sauber!
                                sudo reboot
                                  @federal
                                  Sauber!
                                  sudo reboot
                                  federal
                                  @federal
                                  Sauber!
                                  sudo reboot
                                  jetzt bin ich wieder am Anfang von heute
                                  pi@raspberrypi:~ $ iobroker status
                                  node:internal/modules/cjs/loader:1024
                                    throw err;
                                  Error: Cannot find module 'buffer-equal-constant-time'
                                  Require stack:
                                  - /opt/iobroker/node_modules/jwa/index.js
                                  - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                                  - /opt/iobroker/node_modules/jws/index.js
                                  - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                                  - /opt/iobroker/node_modules/jsonwebtoken/index.js
                                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                  - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                  - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                                      at Module.require (node:internal/modules/cjs/loader:1093:19)
                                      at require (node:internal/modules/cjs/helpers:108:18)
                                      at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                                      at Module._compile (node:internal/modules/cjs/loader:1191:14)
                                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                                      at Module.load (node:internal/modules/cjs/loader:1069:32)
                                      at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                                      at Module.require (node:internal/modules/cjs/loader:1093:19) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [
                                      '/opt/iobroker/node_modules/jwa/index.js',
                                      '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                                      '/opt/iobroker/node_modules/jws/index.js',
                                      '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                                      '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                      '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                      '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    @federal
                                    federal
                                    @federal
                                    ich verstehe es leider nicht
                                    • Thomas BraunT Online
                                      Ich auch nicht.
                                      Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                                      Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                                      Mit
                                      top
                                      schauen was da los ist.
                                      Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                                      echad@chet:~ $ uptime
                                       20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                                        Ich auch nicht.
                                        Mit
                                        top
                                        federal
                                        Ich auch nicht.
                                        Mit
                                        top
                                        • F federal
                                          Ich auch nicht.
                                          Mit
                                          top
                                          @federal
                                          Nach dem reboot schaut es gesünder aus.
