  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.9k Aufrufe 52 Beobachtet
  • David G.D David G.
    Gibt's für die beiden eigentlich auch einen Datenpunkt?
    Finde nichts, wo ich denke dass es was entsprechendes ist.
    copystringC Offline
    copystringC Offline
    copystring
    #484
    @david-g said in Roborock Adapter tester gesucht:
    Welche Roboter hast du? Wenn es verfügbar wäre, dann würde es ist HomeData stehen. Wäre das so, dann könnte ich den Adapter darauf anpassen.
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • copystringC copystring
      David G.D Online
      David G.D Online
      David G.
      #485
      @copystring
      In HomeData finde ich nichts.
      Ist ein Roborock S7 MaxV.
      {"id":3997987,"name":"xxxx","lon":null,"lat":null,"geoName":null,"products":[{"id":"42yfoQm5eOY3gARZw6xgU","name":"Roborock S7 MaxV","code":"a27","model":"roborock.vacuum.a27","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"7UreppMhwYr4WlSbCtcsno","name":"Roborock S7 MaxV","attribute":null,"activeTime":1676794696,"localKey":"XmIxKeJ6ysQxGuf0","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"42yfoQm5eOY3gARZw6xgU","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.57.26","pv":"1.0","roomId":10800654,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{\"RRMonitorPrivacyVersion\": \"1\"}","sn":"R21ETS22901883","featureSet":"2234201184108543","newFeatureSet":"0000000000002041","deviceStatus":{"120":0,"121":8,"122":100,"123":102,"124":202,"125":87,"126":80,"127":73,"128":0,"133":1},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10931661,"name":"Eingang unten"},{"id":10803513,"name":"Wohnzimmer"},{"id":10803502,"name":"Esszimmer"},{"id":10803485,"name":"Küche"},{"id":10803465,"name":"Flur oben"},{"id":10803462,"name":"Badezimmer oben"},{"id":10800662,"name":"Badezimmer unten"},{"id":10800659,"name":"Flur unten"},{"id":10800654,"name":"HWR"},{"id":10800645,"name":"Flur"},{"id":10800637,"name":"Badezimmer"},{"id":10800627,"name":"Kinderzimmer 2"},{"id":10800608,"name":"Kinderzimmer 1"},{"id":10800591,"name":"Schlafzimmer"}]}
      copystringC 1 Antwort Letzte Antwort
      • M Menfis
        @copystring
        Ja, sieht man. Allerdings wird immer nur ein einziger Raum bunt.
        copystringC Offline
        copystringC Offline
        copystring
        #486
        @menfis said in Roborock Adapter tester gesucht:
        @copystring
        Sehr merkwürdig, weil der Befehl sauber abgeschickt wurde. Leider kommt aber ein Fehler zurück.
        dps debug: {"id":71,"error":{"code":-10005,"message":"data for segments is invalid"}}
        Ich weiß aber nicht, warum das so ist, weil app_segment_clean with roomIDs: {"segments":[17,23],"repeat":1} result: ok sauber durchläuft. Ich habe z. B. auch einen Raum mit Umlaut (Küche) und das läuft sauber durch. Hast du mal versucht, alle Objekte unter Rooms zu löschen? Noch besser wäre es, wenn du den Adapter ein mal löschst und neu installierst. Ich wüsste sonst nicht wirklich, woran es liegen könnte.
          @copystring
          copystringC Offline
          copystringC Offline
          copystring
          #487
          @copystring
          OK. Mal in dein Log gucken. Dort müsste so etwas wie das hier stehen:
          dps debug: {"id":3442,"result":[{"main_brush_work_time":299562,"side_brush_work_time":299562,"filter_work_time":299562,"filter_element_work_time":0,"sensor_dirty_time":78061,"dust_collection_work_times":79}]} Ist da bei dir vielleicht mehr drin als bei mir?
            @copystring
            David G.D Online
            David G.D Online
            David G.
            #488
            @copystring
            Dke Zeile?
            2023-03-23 06:07:47.773	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154416,"side_brush_work_time":154416,"filter_work_time":154416,"filter_element_work_time":0,"sensor_dirty_time":85652,"strainer_work_times":145,"dust_collection_work_times":102,"cleaning_brush_work_times":145}]}
            Dort scheint es auch nicht zu stehen.
            EDIT
            Hier mal der ganze Adapterstart
            roborock.0
            2023-03-23 06:52:18.110	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:52:18.110	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:52:18.110	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:52:18.109	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:52:18.109	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:52:18.108	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:52:18.108	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:52:18.108	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:52:18.107	debug	dps debug: {"id":79,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:52:18.023	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:52:18.023	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:52:18.010	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:52:18.009	debug	dps debug: {"id":78,"result":["ok"]}
            roborock.0
            2023-03-23 06:52:17.444	debug	Update consumables
            roborock.0
            2023-03-23 06:52:17.443	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:52:16.984	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:52:16.983	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:52:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:52:16.892	debug	dps debug: {"id":72,"result":[{"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:52:16.889	debug	dps debug: {"id":75,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:52:16.887	debug	dps debug: {"id":77,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:52:16.880	debug	dps debug: {"id":74,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:52:16.877	debug	dps debug: {"id":73,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:52:16.875	debug	dps debug: {"id":76,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:52:16.788	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:52:16.787	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:52:16.786	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:52:16.785	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:52:16.784	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:52:16.782	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:52:16.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:51:59.857	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:51:59.856	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:51:59.856	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:51:59.855	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:51:59.854	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:51:59.852	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:51:59.851	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:51:59.850	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:51:59.849	debug	dps debug: {"id":71,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:51:59.768	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:51:59.767	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:51:59.756	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:51:59.755	debug	dps debug: {"id":70,"result":["ok"]}
            roborock.0
            2023-03-23 06:51:57.239	debug	Update consumables
            roborock.0
            2023-03-23 06:51:57.238	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:51:56.951	debug	dps debug: {"id":67,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:51:56.950	debug	dps debug: {"id":65,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:51:56.948	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:51:56.948	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:51:56.945	debug	dps debug: {"id":68,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:51:56.871	debug	dps debug: {"id":69,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:51:56.869	debug	dps debug: {"id":66,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:51:56.852	debug	get_status: {"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:51:56.851	debug	dps debug: {"id":64,"result":[{"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:51:56.787	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:51:56.786	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:51:56.785	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:51:56.785	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:51:56.783	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:51:56.783	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:51:56.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:51:37.882	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:51:37.881	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:51:37.880	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:51:37.879	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:51:37.878	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:51:37.878	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:51:37.877	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:51:37.876	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:51:37.875	debug	dps debug: {"id":63,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:51:37.844	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:51:37.843	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:51:37.758	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:51:37.758	debug	dps debug: {"id":62,"result":["ok"]}
            roborock.0
            2023-03-23 06:51:37.055	debug	Update consumables
            roborock.0
            2023-03-23 06:51:37.054	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:51:36.985	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:51:36.984	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:51:36.927	debug	dps debug: {"id":59,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:51:36.924	debug	dps debug: {"id":61,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:51:36.920	debug	dps debug: {"id":60,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:51:36.907	debug	dps debug: {"id":57,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:51:36.891	debug	get_status: {"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:51:36.890	debug	dps debug: {"id":56,"result":[{"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:51:36.865	debug	dps debug: {"id":58,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:51:36.787	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:51:36.786	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:51:36.785	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:51:36.784	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:51:36.783	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:51:36.782	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:51:36.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:51:19.734	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:51:19.734	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:51:19.733	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:51:19.732	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:51:19.731	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:51:19.731	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:51:19.730	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:51:19.730	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:51:19.729	debug	dps debug: {"id":55,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:51:18.468	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:51:18.467	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:51:18.456	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:51:18.455	debug	dps debug: {"id":54,"result":["ok"]}
            roborock.0
            2023-03-23 06:51:17.341	debug	Update consumables
            roborock.0
            2023-03-23 06:51:17.340	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:51:16.994	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:51:16.993	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:51:16.918	debug	dps debug: {"id":51,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:51:16.915	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:51:16.913	debug	dps debug: {"id":53,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:51:16.903	debug	dps debug: {"id":52,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:51:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:51:16.892	debug	dps debug: {"id":48,"result":[{"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:51:16.887	debug	dps debug: {"id":50,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:51:16.787	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:51:16.786	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:51:16.785	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:51:16.784	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:51:16.783	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:51:16.783	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:51:16.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:50:59.706	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:50:59.705	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:50:59.705	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:50:59.704	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:50:59.703	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:50:59.703	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:50:59.702	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:50:59.701	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:50:59.700	debug	dps debug: {"id":47,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:50:59.607	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:50:59.605	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:50:59.592	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:50:59.591	debug	dps debug: {"id":46,"result":["ok"]}
            roborock.0
            2023-03-23 06:50:57.442	debug	Update consumables
            roborock.0
            2023-03-23 06:50:57.441	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:50:56.972	debug	dps debug: {"id":45,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:50:56.970	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:50:56.969	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:50:56.900	debug	dps debug: {"id":42,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:50:56.891	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:50:56.888	debug	dps debug: {"id":43,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:50:56.874	debug	dps debug: {"id":44,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:50:56.860	debug	get_status: {"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:50:56.858	debug	dps debug: {"id":40,"result":[{"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:50:56.790	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:50:56.788	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:50:56.786	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:50:56.785	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:50:56.784	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:50:56.783	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:50:56.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:50:37.832	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:50:37.832	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:50:37.831	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:50:37.830	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:50:37.829	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:50:37.828	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:50:37.828	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:50:37.827	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:50:37.826	debug	dps debug: {"id":39,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:50:37.708	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:50:37.708	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:50:37.695	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:50:37.694	debug	dps debug: {"id":38,"result":["ok"]}
            roborock.0
            2023-03-23 06:50:37.331	debug	Update consumables
            roborock.0
            2023-03-23 06:50:37.330	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:50:36.951	debug	dps debug: {"id":37,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:50:36.949	debug	dps debug: {"id":35,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:50:36.945	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:50:36.945	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:50:36.875	debug	dps debug: {"id":33,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:50:36.871	debug	dps debug: {"id":34,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:50:36.846	debug	get_status: {"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:50:36.845	debug	dps debug: {"id":32,"result":[{"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:50:36.831	debug	dps debug: {"id":36,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:50:36.788	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:50:36.787	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:50:36.786	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:50:36.785	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:50:36.784	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:50:36.783	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:50:36.782	debug	Latest data requested
            roborock.0
            2023-03-23 06:50:18.702	debug	Mapped room matched: 10800662 with name: Badezimmer unten
            roborock.0
            2023-03-23 06:50:18.701	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
            roborock.0
            2023-03-23 06:50:18.701	debug	Mapped room matched: 10800591 with name: Schlafzimmer
            roborock.0
            2023-03-23 06:50:18.699	debug	Mapped room matched: 10931661 with name: Eingang unten
            roborock.0
            2023-03-23 06:50:18.699	debug	Mapped room matched: 10800659 with name: Flur unten
            roborock.0
            2023-03-23 06:50:18.698	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
            roborock.0
            2023-03-23 06:50:18.697	debug	Mapped room matched: 10800654 with name: HWR
            roborock.0
            2023-03-23 06:50:18.697	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
            roborock.0
            2023-03-23 06:50:18.696	debug	dps debug: {"id":31,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
            roborock.0
            2023-03-23 06:50:18.018	debug	getParameter: get_room_mapping
            roborock.0
            2023-03-23 06:50:18.017	debug	dps debug: {"id":10,"result":["ok"]}
            roborock.0
            2023-03-23 06:50:18.014	debug	foreign.message attribute: 128 with value: 0
            roborock.0
            2023-03-23 06:50:18.014	debug	dps debug: {"128":0}
            roborock.0
            2023-03-23 06:50:17.483	debug	Update consumables
            roborock.0
            2023-03-23 06:50:17.482	debug	homedata successfully updated
            roborock.0
            2023-03-23 06:50:17.159	debug	Cleaning record: {"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.158	debug	dps debug: {"id":26,"result":[{"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.078	debug	Cleaning record: {"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.077	debug	dps debug: {"id":28,"result":[{"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.074	debug	Cleaning record: {"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.073	debug	dps debug: {"id":20,"result":[{"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.070	debug	Cleaning record: {"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:17.069	debug	Cleaning record: {"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.068	debug	dps debug: {"id":29,"result":[{"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:17.067	debug	dps debug: {"id":21,"result":[{"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.064	debug	Cleaning record: {"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:17.063	debug	dps debug: {"id":30,"result":[{"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:17.060	debug	Cleaning record: {"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.060	debug	dps debug: {"id":11,"result":[{"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.057	debug	Cleaning record: {"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:17.057	debug	dps debug: {"id":23,"result":[{"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:17.055	debug	Cleaning record: {"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.053	debug	dps debug: {"id":14,"result":[{"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.051	debug	Cleaning record: {"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.050	debug	dps debug: {"id":19,"result":[{"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.047	debug	Cleaning record: {"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:17.046	debug	dps debug: {"id":24,"result":[{"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:17.044	debug	Cleaning record: {"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.043	debug	dps debug: {"id":25,"result":[{"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.041	debug	Cleaning record: {"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.040	debug	dps debug: {"id":27,"result":[{"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.037	debug	Cleaning record: {"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:17.036	debug	dps debug: {"id":22,"result":[{"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:17.034	debug	Cleaning record: {"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.033	debug	dps debug: {"id":18,"result":[{"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.031	debug	Cleaning record: {"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.030	debug	dps debug: {"id":13,"result":[{"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.027	debug	Cleaning record: {"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.026	debug	dps debug: {"id":16,"result":[{"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.007	debug	Cleaning record: {"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
            roborock.0
            2023-03-23 06:50:17.004	debug	dps debug: {"id":17,"result":[{"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:17.000	debug	Cleaning record: {"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}
            roborock.0
            2023-03-23 06:50:16.999	debug	dps debug: {"id":12,"result":[{"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}]}
            roborock.0
            2023-03-23 06:50:16.993	debug	Cleaning record: {"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}
            roborock.0
            2023-03-23 06:50:16.992	debug	dps debug: {"id":15,"result":[{"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}]}
            roborock.0
            2023-03-23 06:50:16.977	debug	foreign.message attribute: 128 with value: 4
            roborock.0
            2023-03-23 06:50:16.975	debug	dps debug: {"128":4}
            roborock.0
            2023-03-23 06:50:16.945	debug	dps debug: {"id":8,"result":{"water_box_mode":202}}
            roborock.0
            2023-03-23 06:50:16.926	debug	dps debug: {"id":9,"result":{"clean_time":154668,"clean_area":2151037500,"clean_count":234,"dust_collection_count":103,"records":[1679548681,1679485898,1679484869,1679474738,1679474541,1679465459,1679432038,1679417150,1679393236,1679390684,1679389971,1679385601,1679218926,1679213306,1679209436,1679209397,1679205735,1679065431,1679054409,1679044923]}}
            roborock.0
            2023-03-23 06:50:16.913	debug	dps debug: {"id":4,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
            roborock.0
            2023-03-23 06:50:16.910	debug	dps debug: {"id":5,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
            roborock.0
            2023-03-23 06:50:16.896	debug	get_status: {"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
            roborock.0
            2023-03-23 06:50:16.895	debug	dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
            roborock.0
            2023-03-23 06:50:16.890	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
            roborock.0
            2023-03-23 06:50:16.885	debug	dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
            roborock.0
            2023-03-23 06:50:16.883	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
            roborock.0
            2023-03-23 06:50:16.878	debug	dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1679549423,"length":2,"name":"UG","bak_maps":[{"mapFlag":4,"add_time":1676811567}]},{"mapFlag":1,"add_time":1678210539,"length":2,"name":"OG","bak_maps":[{"mapFlag":5,"add_time":1676814827}]}]}]}
            roborock.0
            2023-03-23 06:50:16.804	debug	getParameter: get_water_box_custom_mode
            roborock.0
            2023-03-23 06:50:16.803	debug	getParameter: get_carpet_clean_mode
            roborock.0
            2023-03-23 06:50:16.801	debug	getParameter: get_carpet_mode
            roborock.0
            2023-03-23 06:50:16.799	debug	getParameter: get_network_info
            roborock.0
            2023-03-23 06:50:16.797	debug	getParameter: get_consumable
            roborock.0
            2023-03-23 06:50:16.794	debug	getParameter: get_status
            roborock.0
            2023-03-23 06:50:16.793	debug	Latest data requested
            roborock.0
            2023-03-23 06:50:16.790	debug	getParameter: get_multi_maps_list
            roborock.0
            2023-03-23 06:50:16.784	debug	Firmware features request
            roborock.0
            2023-03-23 06:50:16.783	debug	getParameter: get_fw_features
            roborock.0
            2023-03-23 06:50:14.364	debug	Robot key: roborock.vacuum.a27
            roborock.0
            2023-03-23 06:50:14.362	debug	RoomIDs debug: {"10800591":"Schlafzimmer","10800608":"Kinderzimmer 1","10800627":"Kinderzimmer 2","10800637":"Badezimmer","10800645":"Flur","10800654":"HWR","10800659":"Flur unten","10800662":"Badezimmer unten","10803462":"Badezimmer oben","10803465":"Flur oben","10803485":"Küche","10803502":"Esszimmer","10803513":"Wohnzimmer","10931661":"Eingang unten"}
            roborock.0
            2023-03-23 06:50:14.360	info	MQTT initialized
            roborock.0
            2023-03-23 06:50:13.516	info	starting. Version 0.1.4-beta.3 (non-npm: copystring/ioBroker.roborock#ead555830dcfcc0b2623b231fd97e016a3929bb8) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.15.0, js-controller: 4.0.24
            roborock.0
            2023-03-23 06:50:12.795	debug	Plugin sentry destroyed because not initialized correctly
            roborock.0
            2023-03-23 06:50:12.734	debug	Plugin sentry Do not initialize Plugin (enabled=false)
              @copystring
              Dke Zeile?
              EDIT
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              copystringC Offline
              copystringC Offline
              copystring
              #489
              @david-g was passiert denn, wenn man die Bürste zurücksetzt? Ist dann cleaning_brush_work_times auf 0? Dann könnte man sich den echten wert ausrechnen, wenn man weiß wie lange die Bürste maximal laufen darf.
                David G.D Online
                David G.D Online
                David G.
                #490
                @copystring
                Teste ich nachher, angelegt werden die Punkte ja (hab ich eben nochmal gesehen).
                Der Dust_collection_work_times hat wohl keinen Festen Wert.
                Setzte die Bürste nachher mal zurück.
                EDIT
                Ja, wird zurückgesetzt. Vom Balken her gehe ich mal von aus, dass er bis 300 geht.
                roborock.0
                2023-03-23 14:39:46.795	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":0}]}
                  @copystring
                  Menfis
                  #491
                  @copystring sagte in Roborock Adapter tester gesucht:
                  @copystring
                  Ich habe beides probiert. Die Floors gelöscht aber dadurch änderte sich nichts. Leider brachte auch eine Neuinstallation des Adapters keine Besserung.
                  Es kommt immer noch eine Fehlermeldung alla:
                  	dps debug: {"id":1611,"error":{"code":-10005,"message":"data for segments is invalid"}}
                  Komisch, dass es bei anderen problemlos geht.
                  • M Menfis
                    @copystring
                    copystringC Offline
                    copystringC Offline
                    copystring
                    #492
                    Wie ist das gemeint? Die anderen Räume gehen nur die Küche nicht?
                      michael 1975
                      #493
                      Ich habe heute den Adapter installiert erwurde auch grün, aber leider habe ich keinen Sauger in den Objekten an was kann das liegen.
                      Bentzername=mail Passwort ganz sicher richtig eingegeben.
                      • M michael 1975
                        wendy2702W Offline
                        wendy2702W Offline
                        #494
                        @michael-1975 sagte in Roborock Adapter tester gesucht:
                        Laut log ist das aber eben nicht richtig oder kommt dein IOB nicht ins internet?
                        • wendy2702W wendy2702
                          michael 1975
                          #495
                          @wendy2702 das passwort ist sicher richtig habe komischerweise das Problem auch mit dem mihome vacum adapter das der nicht geht der findet aber der sauger.
                          Und der Ioboker sollte eigentlich auch ins internet kommen ansonsten habe ich keine Probleme
                          wendy2702W CodierknechtC 2 Antworten Letzte Antwort
                          • M michael 1975
                            wendy2702W Offline
                            wendy2702W Offline
                            #496
                            @michael-1975 Soweit mir bekannt musst du dich App technisch entscheiden, beide gehen nicht.
                            Stell das Log mal auf Debug und poste die Ausgabe als Text in Code Tags </>
                            • M michael 1975
                              CodierknechtC Offline
                              Codierknecht
                              #497
                              ... enthält aber möglicherweise Sonderzeichen, die Probleme machen.
                              Wäre ja nicht der erste Adapter, der bei der Verwendung bestimmter Sonderzeichen Probleme hat.
                              Kannst ja mal testweise mit einem Passwort ohne Sonderzeichen probieren.
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              • CodierknechtC Codierknecht
                                wendy2702W Offline
                                wendy2702W Offline
                                #498
                                @codierknecht @michael-1975 und ohne Umlaute
                                  Menfis
                                  #499
                                  @copystring nein, nein. Ich meinte bei anderen Usern.
                                  • D DonToben
                                    @copystring
                                    Habe mir gerade den iobroker log angesehen.
                                    Es gab heute Nacht eine Menge Fehlereinträge, danach wieder alles i.O.
                                    Eine Idee?
                                    Roborock S7 Pro Ultra.
                                    Habe die 0.1.6 installiert. Mit den Version davor hatte ich die Auffälligkeit nicht.
                                    2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 589 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 590 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 591 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 592 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 593 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 594 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 595 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 596 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 597 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 598 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 599 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 600 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 601 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 602 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 603 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 604 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 605 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 606 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 607 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 608 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 609 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 610 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 611 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.529 - error: roborock.0 (5655) Unsported attribute: 612 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.529 - error: roborock.0 (5655) Unsported attribute: 613 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 614 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 615 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 616 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 617 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 618 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 619 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 620 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 621 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 622 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 623 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 624 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 625 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 626 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 627 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 628 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 629 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 630 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 631 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 632 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 633 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 634 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 635 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 636 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 637 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 638 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 639 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 640 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 641 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 642 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 643 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 644 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 645 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 646 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 647 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 648 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 649 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 650 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 651 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 652 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 653 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 654 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 655 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 656 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 657 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.538 - error: roborock.0 (5655) Unsported attribute: 658 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 03:52:31.538 - error: roborock.0 (5655) Unsported attribute: 659 of get_status. Please contact the dev to add the newly found attribute of your robot.
                                    2023-03-15 04:34:31.481 - info: roborock.0 (5655) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_custom_mode" has to be type "number" but received type "string"
                                    2023-03-15 04:44:31.484 - info: roborock.0 (5655) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_custom_mode" has to be type "number" but received type "string"
                                    2023-03-15 04:56:30.926 - warn: roborock.0 (5655) MQTT connection close.
                                    2023-03-15 04:56:30.927 - warn: roborock.0 (5655) MQTT connection reconnect.
                                    DonToben
                                    schrieb am zuletzt editiert von DonToben
                                    #500
                                    @copystring
                                    Könntest du dir das bitte ansehen.
                                    Gerade ein Update der Fritzbox gemacht. Danach hat iobroker den Roborock Adapter automatisch angehalten wegen zu vieler Neustarts.
                                    Kannst du dir das erklären?
                                    -03-24 09:00:11.217 - warn: roborock.0 (29551) MQTT connection close.
                                    2023-03-24 09:00:11.222 - warn: roborock.0 (29551) MQTT connection reconnect.
                                    2023-03-24 12:00:11.212 - warn: roborock.0 (29551) MQTT connection close.
                                    2023-03-24 12:00:11.213 - warn: roborock.0 (29551) MQTT connection reconnect.
                                    2023-03-24 15:00:11.213 - warn: roborock.0 (29551) MQTT connection close.
                                    2023-03-24 15:00:11.214 - warn: roborock.0 (29551) MQTT connection reconnect.
                                    2023-03-24 16:33:11.623 - warn: roborock.0 (29551) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.carpet_clean_mode" has no existing object, this might lead to an error in future versions
                                    2023-03-24 17:14:41.533 - error: roborock.0 (29551) MQTT connection offline: undefined
                                    2023-03-24 17:14:41.534 - warn: roborock.0 (29551) MQTT connection close.
                                    2023-03-24 17:14:42.534 - warn: roborock.0 (29551) MQTT connection reconnect.
                                    2023-03-24 17:14:47.446 - error: roborock.0 (29551) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-03-24 17:14:47.447 - error: roborock.0 (29551) unhandled promise rejection: getaddrinfo EAI_AGAIN api-eu.roborock.com
                                    2023-03-24 17:14:47.449 - error: roborock.0 (29551) Error: getaddrinfo EAI_AGAIN api-eu.roborock.com
                                    at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:825:14)
                                    at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:2973:25)
                                    at RedirectableRequest.emit (node:events:513:28)
                                    at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
                                    at ClientRequest.emit (node:events:513:28)
                                    at TLSSocket.socketErrorListener (node:_http_client:494:9)
                                    at TLSSocket.emit (node:events:513:28)
                                    at emitErrorNT (node:internal/streams/destroy:157:8)
                                    at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                                    at processTicksAndRejections (node:internal/process/task_queues:83:21)
                                    2023-03-24 17:14:47.450 - error: roborock.0 (29551) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api-eu.roborock.com
                                    2023-03-24 17:14:47.458 - info: roborock.0 (29551) terminating
                                    2023-03-24 17:14:47.460 - warn: roborock.0 (29551) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-03-24 17:15:04.040 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2023-03-24 17:15:04.042 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                    2023-03-24 17:15:05.269 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24330
                                    2023-03-24 17:15:08.304 - info: roborock.0 (24330) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                    2023-03-24 17:15:30.675 - error: roborock.0 (24330) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-03-24 17:15:30.677 - error: roborock.0 (24330) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:30.682 - error: roborock.0 (24330) Error: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:30.683 - error: roborock.0 (24330) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:30.694 - info: roborock.0 (24330) terminating
                                    2023-03-24 17:15:30.697 - warn: roborock.0 (24330) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-03-24 17:15:31.326 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2023-03-24 17:15:31.327 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                    2023-03-24 17:15:32.473 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24384
                                    2023-03-24 17:15:35.563 - info: roborock.0 (24384) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                    2023-03-24 17:15:55.287 - error: roborock.0 (24384) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-03-24 17:15:55.288 - error: roborock.0 (24384) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:55.290 - error: roborock.0 (24384) Error: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:55.292 - error: roborock.0 (24384) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
                                    2023-03-24 17:15:55.299 - info: roborock.0 (24384) terminating
                                    2023-03-24 17:15:55.301 - warn: roborock.0 (24384) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-03-24 17:15:55.944 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2023-03-24 17:15:55.945 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                    2023-03-24 17:15:55.945 - warn: host.raspberrypi Do not restart adapter system.adapter.roborock.0 because restart loop detected
                                    copystringC 1 Antwort Letzte Antwort
                                    • D DonToben
                                      @copystring
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #501
                                      @dontoben ich weiß nicht was ich da machen kann. Deine dns Auflösung funktioniert nicht.
                                      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                                      https://paypal.me/copystring
                                      • M Menfis
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #502
                                        @menfis tu mir einen Gefallen und mach bitte eine issue auf GitHub. Ist sonst ein bisschen durcheinander hier Forum. Dann kann ich mir das genauer angucken.
                                        • copystringC copystring
                                          DonToben
                                          #503
                                          @copystring said in Roborock Adapter tester gesucht:
                                          Ist halt blöd, dass der Adapter angehalten wird, wenn die Internetverbindung eine gewisse Zeit nicht vorhanden ist.
                                          Muss das mal beobachten. Das Problem hat nur der Roborock Adapter. Kann man das im iobroker irgendwo deaktivieren?
