  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.9k Aufrufe 52 Beobachtet
    DonToben
    #475
    @copystring
    Heute die Meldung im IOBroker gesehen, dass der Roborock Adapter angehalten wurde, weil zu viele Neustarts.
    Hier das Log:
    2023-03-16 01:26:25.565 - info: host.raspberrypi Delete log file iobroker.2023-03-08.log.gz
    2023-03-16 01:37:38.781 - warn: roborock.0 (11667) MQTT connection close.
    2023-03-16 01:37:38.790 - warn: roborock.0 (11667) MQTT connection reconnect.
    2023-03-16 02:19:39.184 - warn: roborock.0 (11667) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.enable" has no existing object, this might lead to an error in future versions
    2023-03-16 02:19:39.228 - warn: roborock.0 (11667) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.current_integral" has no existing object, this might lead to an error in future versions
    2023-03-16 02:19:39.229 - warn: roborock.0 (11667) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.current_high" has no existing object, this might lead to an error in future versions
    2023-03-16 02:19:39.230 - warn: roborock.0 (11667) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.current_low" has no existing object, this might lead to an error in future versions
    2023-03-16 02:19:39.231 - warn: roborock.0 (11667) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.stall_time" has no existing object, this might lead to an error in future versions
    2023-03-16 04:37:38.782 - warn: roborock.0 (11667) MQTT connection close.
    2023-03-16 04:37:38.784 - warn: roborock.0 (11667) MQTT connection reconnect.
    2023-03-16 06:00:00.068 - info: roborock.0 (11667) Scheduled restart.
    2023-03-16 06:00:00.080 - info: roborock.0 (11667) terminating
    2023-03-16 06:00:00.083 - info: roborock.0 (11667) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-03-16 06:00:00.076 - info: alexa2.0 (11823) Scheduled restart.
    2023-03-16 06:00:00.089 - info: javascript.0 (11724) Scheduled restart.
    2023-03-16 06:00:00.103 - info: javascript.0 (11724) Stop script script.js.common.Alexa_TTS
    2023-03-16 06:00:00.104 - info: javascript.0 (11724) Stop script script.js.common.Landroid_OLM_Zonen_Planer
    2023-03-16 06:00:00.104 - info: javascript.0 (11724) Stop script script.js.common.Roborock_V5_Alexa_Bereichsreinigung
    2023-03-16 06:00:00.117 - info: javascript.0 (11724) terminating
    2023-03-16 06:00:00.119 - info: javascript.0 (11724) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-03-16 06:00:00.138 - info: alexa2.0 (11823) terminating
    2023-03-16 06:00:00.140 - info: alexa2.0 (11823) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-03-16 06:00:00.741 - info: host.raspberrypi instance system.adapter.roborock.0 scheduled normal terminated and will be restarted on schedule.
    2023-03-16 06:00:00.743 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-16 06:00:00.820 - info: host.raspberrypi instance system.adapter.javascript.0 scheduled normal terminated and will be restarted on schedule.
    2023-03-16 06:00:00.820 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2023-03-16 06:00:00.973 - info: host.raspberrypi instance system.adapter.alexa2.0 scheduled normal terminated and will be restarted on schedule.
    2023-03-16 06:00:00.974 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
    2023-03-16 06:00:01.968 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 17361
    2023-03-16 06:00:02.090 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 17368
    2023-03-16 06:00:02.188 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 17374
    2023-03-16 06:00:05.746 - info: roborock.0 (17361) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-03-16 06:00:05.920 - info: alexa2.0 (17374) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
    2023-03-16 06:00:06.609 - info: roborock.0 (17361) MQTT initialized
    2023-03-16 06:00:06.620 - info: alexa2.0 (17374) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2023-03-16 06:00:07.302 - info: javascript.0 (17368) starting. Version 7.0.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
    2023-03-16 06:00:08.215 - info: javascript.0 (17368) requesting all states
    2023-03-16 06:00:08.218 - info: javascript.0 (17368) requesting all objects
    2023-03-16 06:00:09.907 - info: javascript.0 (17368) received all objects
    2023-03-16 06:00:10.083 - info: javascript.0 (17368) received all states
    2023-03-16 06:00:10.207 - info: javascript.0 (17368) Start javascript script.js.common.Alexa_TTS
    2023-03-16 06:00:10.275 - info: javascript.0 (17368) script.js.common.Alexa_TTS: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-03-16 06:00:10.276 - info: javascript.0 (17368) Start javascript script.js.common.Landroid_OLM_Zonen_Planer
    2023-03-16 06:00:10.299 - info: javascript.0 (17368) script.js.common.Landroid_OLM_Zonen_Planer: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-03-16 06:00:10.300 - info: javascript.0 (17368) Start javascript script.js.common.Roborock_V5_Alexa_Bereichsreinigung
    2023-03-16 06:00:10.309 - info: javascript.0 (17368) script.js.common.Roborock_V5_Alexa_Bereichsreinigung: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-03-16 06:00:11.181 - info: alexa2.0 (17374) Initialize all Device states ...
    2023-03-16 06:01:03.452 - info: alexa2.0 (17374) No smart home devices to query
    2023-03-16 06:01:04.742 - info: alexa2.0 (17374) Subscribing to states...
    2023-03-16 06:01:04.747 - info: alexa2.0 (17374) Deleting the following states: ["Smart-Home-Devices.5d5e7f46-b56d-4d23-945c-8e75c66802c7","Smart-Home-Devices.5d5e7f46-b56d-4d23-945c-8e75c66802c7.#delete","Smart-Home-Devices.5d5e7f46-b56d-4d23-945c-8e75c66802c7.#enabled","Smart-Home-Devices.5d5e7f46-b56d-4d23-945c-8e75c66802c7.powerState"]
    2023-03-16 06:01:06.672 - info: alexa2.0 (17374) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-03-16 06:01:20.146 - info: alexa2.0 (17374) Initialization Done ...
    2023-03-16 06:55:45.666 - error: roborock.0 (17361) MQTT connection offline: undefined
    2023-03-16 06:55:45.671 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 06:55:46.673 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 07:10:06.399 - info: admin.0 (11592) ==> Connected system.user.admin from ::ffff:192.168.178.202
    2023-03-16 07:11:41.409 - info: admin.0 (11592) <== Disconnect system.user.admin from ::ffff:192.168.178.202 admin
    2023-03-16 09:00:08.086 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 09:00:08.087 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 12:00:08.084 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 12:00:08.085 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 13:34:08.429 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.msg_ver" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.430 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.msg_seq" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.431 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.state" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.431 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.battery" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.432 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.clean_time" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.433 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.clean_area" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.434 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.error_code" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.434 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.map_present" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.435 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.in_cleaning" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.436 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.in_returning" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.436 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.in_fresh_state" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.437 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.lab_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.437 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.water_box_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.438 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.back_type" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.438 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.wash_phase" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.439 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.wash_ready" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.439 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.fan_power" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.440 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.dnd_enabled" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.440 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.map_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.441 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.is_locating" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.441 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.lock_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.442 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.water_box_mode" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.442 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.water_box_carriage_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.443 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.443 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.adbumper_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.444 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.water_shortage_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.444 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.dock_type" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.445 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.dust_collection_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.445 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.auto_dust_collection" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.446 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.mop_mode" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.446 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.debug_mode" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.469 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.switch_map_mode" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.470 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.dock_error_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.471 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.charge_status" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.471 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.unsave_map_reason" has no existing object, this might lead to an error in future versions
    2023-03-16 13:34:08.472 - warn: roborock.0 (17361) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.unsave_map_flag" has no existing object, this might lead to an error in future versions
    2023-03-16 15:00:08.220 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 15:00:08.222 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 18:00:08.088 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 18:00:08.089 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 19:37:13.320 - info: admin.0 (11592) Adapter rating updated
    2023-03-16 19:37:23.232 - info: admin.0 (11592) Request actual repository...
    2023-03-16 19:37:23.998 - info: host.raspberrypi Updating repository "Beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-03-16 19:37:31.500 - info: admin.0 (11592) Repository received successfully.
    2023-03-16 19:45:43.592 - info: admin.0 (11592) ==> Connected system.user.admin from ::ffff:192.168.178.62
    2023-03-16 19:46:38.601 - info: admin.0 (11592) <== Disconnect system.user.admin from ::ffff:192.168.178.62 admin
    2023-03-16 19:46:57.741 - info: admin.0 (11592) ==> Connected system.user.admin from ::ffff:192.168.178.62
    2023-03-16 19:47:22.743 - info: admin.0 (11592) <== Disconnect system.user.admin from ::ffff:192.168.178.62 admin
    2023-03-16 19:47:52.430 - info: admin.0 (11592) ==> Connected system.user.admin from ::ffff:192.168.178.62
    2023-03-16 19:48:22.436 - info: admin.0 (11592) <== Disconnect system.user.admin from ::ffff:192.168.178.62 admin
    2023-03-16 21:00:08.085 - warn: roborock.0 (17361) MQTT connection close.
    2023-03-16 21:00:08.087 - warn: roborock.0 (17361) MQTT connection reconnect.
    2023-03-16 21:59:30.630 - error: roborock.0 (17361) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-16 21:59:30.631 - error: roborock.0 (17361) unhandled promise rejection: getaddrinfo ENOTFOUND api-eu.roborock.com
    2023-03-16 21:59:30.634 - error: roborock.0 (17361) Error: getaddrinfo ENOTFOUND api-eu.roborock.com
    at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:825:14)
    at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:2973:25)
    at RedirectableRequest.emit (node:events:513:28)
    at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
    at ClientRequest.emit (node:events:513:28)
    at TLSSocket.socketErrorListener (node:_http_client:494:9)
    at TLSSocket.emit (node:events:513:28)
    at emitErrorNT (node:internal/streams/destroy:157:8)
    at emitErrorCloseNT (node:internal/streams/destroy:122:3)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
    2023-03-16 21:59:30.635 - error: roborock.0 (17361) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND api-eu.roborock.com
    2023-03-16 21:59:30.643 - info: roborock.0 (17361) terminating
    2023-03-16 21:59:30.647 - warn: roborock.0 (17361) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-16 21:59:31.326 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-16 21:59:31.328 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-16 21:59:33.697 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 26016
    2023-03-16 21:59:36.695 - info: roborock.0 (26016) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-03-16 21:59:55.416 - error: roborock.0 (26016) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-16 21:59:55.417 - error: roborock.0 (26016) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 21:59:55.419 - error: roborock.0 (26016) Error: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 21:59:55.420 - error: roborock.0 (26016) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 21:59:55.429 - info: roborock.0 (26016) terminating
    2023-03-16 21:59:55.431 - warn: roborock.0 (26016) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-16 21:59:56.046 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-16 21:59:56.047 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-16 21:59:57.202 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 26074
    2023-03-16 22:00:00.215 - info: roborock.0 (26074) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-03-16 22:00:20.248 - error: roborock.0 (26074) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-16 22:00:20.250 - error: roborock.0 (26074) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 22:00:20.252 - error: roborock.0 (26074) Error: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 22:00:20.253 - error: roborock.0 (26074) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-16 22:00:20.264 - info: roborock.0 (26074) terminating
    2023-03-16 22:00:20.266 - warn: roborock.0 (26074) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-16 22:00:20.879 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-16 22:00:20.881 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-16 22:00:20.881 - warn: host.raspberrypi Do not restart adapter system.adapter.roborock.0 because restart loop detected
    2023-03-16 22:01:06.810 - info: alexa2.0 (17374) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
    2023-03-16 22:01:17.608 - info: alexa2.0 (17374) Alexa-Push-Connection (macDms = true) established. Disable Polling
      bongsao
      #476
      host.HomsServer
      2023-03-17 16:27:42.452	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.HomsServer
      2023-03-17 16:27:42.452	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:376:139
      host.HomsServer
      2023-03-17 16:27:42.451	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'toString')
      host.HomsServer
      2023-03-17 16:27:42.451	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      roborock.0
      2023-03-17 16:27:41.878	error	Cannot read properties of undefined (reading 'toString')
      roborock.0
      2023-03-17 16:27:41.878	error	TypeError: Cannot read properties of undefined (reading 'toString') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:376:139
      roborock.0
      2023-03-17 16:27:41.876	error	unhandled promise rejection: Cannot read properties of undefined (reading 'toString')
      roborock.0
      2023-03-17 16:27:41.875	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mit Version 0.1.6
      MOD EDIT: LOG IN CODE TAGS </> GESETZT
      • copystringC copystring
        @copystring said in Roborock Adapter tester gesucht:
        @dimi said in Roborock Adapter tester gesucht:
        @copystring
        Schade, ich dachte es ist wie in der APP. Wenn man den Sauger ausschaltet, dann wird er auch in der APP als offline Angezeigt. Sprich die Cloud kennt ja den Zustand sonst würde die APP den Sauger nicht als offline anzeigen.
        Ja. Ich könnte sicherlich Zustände für jeden Roboter einbauen. Der Adapter bleibt aber trotzdem grün.
        In der dev branch ist das jetzt eingebaut. Außerdem sind dort auch alle anderen Informationen abgelegt, welche vorher nicht abgerufen wurden.
        Das sieht dann so aus: 01da10f0-3d90-4fcc-b673-83b81ffde36b-image.png
        https://github.com/copystring/ioBroker.roborock/tree/dev
        Dimi
        #477
        @copystring sagte in Roborock Adapter tester gesucht:
        Danke habe es getestet. Die Infos wie Firmware usw. sind alle wieder da. Und auch der Onlinestatus des Saugers wird angezeigt und auch zeitnah aktualisiert. 👍
          @menfis bitte ein vollständiges Debug hier anhängen nachdem die Raumreinigung gestartet wurde
          Menfis
          #478
          @copystring
          Hi, hier mal mein Debug-File, nachdem er wieder nach einem Raum abgebrochen hat und zur Station zurückgefahren ist.
          DebugFileRoborock.txt
          Ich hoffe, das hilft irgendwie weiter.
          Ich glaube bei Zeile 716 ist er fertig gewesen und zur Station zurückgefahren.
          Gruß,
          Menfis
          copystringC 1 Antwort Letzte Antwort
          • M Menfis
            @copystring
            Gruß,
            Menfis
            copystringC Offline
            copystringC Offline
            copystring
            #479
            @menfis said in Roborock Adapter tester gesucht:
            @copystring
            Gruß,
            Menfis
            Ok. Ich müsste nur noch wissen, welche Räume tatsächlich gereinigt werden sollten. Vielleicht „Kleiner Flur“ und „Küche“?
            Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
            https://paypal.me/copystring
              @copystring
              Gruß,
              Menfis
              Menfis
              #480
              @copystring
              Ja, richtig.
              Und nach dem kleinen Flur war einfach wieder Schluss.
              Hab ich vielleicht etwas falsch eingestellt oder darf ein Raumname vielleicht keine Umlaute beinhalten?
              • M Menfis
                @copystring
                Ja, richtig.
                copystringC Offline
                copystringC Offline
                copystring
                #481
                @copystring
                Ja, richtig.
                Die Räume werden nur anhand von IDs übergeben. Die Protokolle zeigen mir, dass dies sauber durchlief. Wenn du das machst, sieht man dann in der App, welche Räume der Roboter reinigen soll?
                  @copystring
                  Ja, richtig.
                  Menfis
                  #482
                  @copystring
                  Ja, sieht man. Allerdings wird immer nur ein einziger Raum bunt.
                  • David G.D Online
                    David G.D Online
                    David G.
                    #483
                    Gibt's für die beiden eigentlich auch einen Datenpunkt?
                    Finde nichts, wo ich denke dass es was entsprechendes ist.
                    • David G.D David G.
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #484
                      @david-g said in Roborock Adapter tester gesucht:
                      Welche Roboter hast du? Wenn es verfügbar wäre, dann würde es ist HomeData stehen. Wäre das so, dann könnte ich den Adapter darauf anpassen.
                        David G.D Online
                        David G.D Online
                        David G.
                        #485
                        @copystring
                        In HomeData finde ich nichts.
                        Ist ein Roborock S7 MaxV.
                        {"id":3997987,"name":"xxxx","lon":null,"lat":null,"geoName":null,"products":[{"id":"42yfoQm5eOY3gARZw6xgU","name":"Roborock S7 MaxV","code":"a27","model":"roborock.vacuum.a27","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"7UreppMhwYr4WlSbCtcsno","name":"Roborock S7 MaxV","attribute":null,"activeTime":1676794696,"localKey":"XmIxKeJ6ysQxGuf0","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"42yfoQm5eOY3gARZw6xgU","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.57.26","pv":"1.0","roomId":10800654,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{\"RRMonitorPrivacyVersion\": \"1\"}","sn":"R21ETS22901883","featureSet":"2234201184108543","newFeatureSet":"0000000000002041","deviceStatus":{"120":0,"121":8,"122":100,"123":102,"124":202,"125":87,"126":80,"127":73,"128":0,"133":1},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10931661,"name":"Eingang unten"},{"id":10803513,"name":"Wohnzimmer"},{"id":10803502,"name":"Esszimmer"},{"id":10803485,"name":"Küche"},{"id":10803465,"name":"Flur oben"},{"id":10803462,"name":"Badezimmer oben"},{"id":10800662,"name":"Badezimmer unten"},{"id":10800659,"name":"Flur unten"},{"id":10800654,"name":"HWR"},{"id":10800645,"name":"Flur"},{"id":10800637,"name":"Badezimmer"},{"id":10800627,"name":"Kinderzimmer 2"},{"id":10800608,"name":"Kinderzimmer 1"},{"id":10800591,"name":"Schlafzimmer"}]}
                        • M Menfis
                          @copystring
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #486
                          @copystring
                          Sehr merkwürdig, weil der Befehl sauber abgeschickt wurde. Leider kommt aber ein Fehler zurück.
                          dps debug: {"id":71,"error":{"code":-10005,"message":"data for segments is invalid"}}
                          Ich weiß aber nicht, warum das so ist, weil app_segment_clean with roomIDs: {"segments":[17,23],"repeat":1} result: ok sauber durchläuft. Ich habe z. B. auch einen Raum mit Umlaut (Küche) und das läuft sauber durch. Hast du mal versucht, alle Objekte unter Rooms zu löschen? Noch besser wäre es, wenn du den Adapter ein mal löschst und neu installierst. Ich wüsste sonst nicht wirklich, woran es liegen könnte.
                            @copystring
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #487
                            @copystring
                            OK. Mal in dein Log gucken. Dort müsste so etwas wie das hier stehen:
                            dps debug: {"id":3442,"result":[{"main_brush_work_time":299562,"side_brush_work_time":299562,"filter_work_time":299562,"filter_element_work_time":0,"sensor_dirty_time":78061,"dust_collection_work_times":79}]} Ist da bei dir vielleicht mehr drin als bei mir?
                              @copystring
                              David G.D Online
                              David G.D Online
                              David G.
                              #488
                              @copystring
                              Dke Zeile?
                              2023-03-23 06:07:47.773	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154416,"side_brush_work_time":154416,"filter_work_time":154416,"filter_element_work_time":0,"sensor_dirty_time":85652,"strainer_work_times":145,"dust_collection_work_times":102,"cleaning_brush_work_times":145}]}
                              Dort scheint es auch nicht zu stehen.
                              EDIT
                              Hier mal der ganze Adapterstart
                              roborock.0
                              2023-03-23 06:52:18.110	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:52:18.110	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:52:18.110	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:52:18.109	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:52:18.109	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:52:18.108	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:52:18.108	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:52:18.108	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:52:18.107	debug	dps debug: {"id":79,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:52:18.023	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:52:18.023	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:52:18.010	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:52:18.009	debug	dps debug: {"id":78,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:52:17.444	debug	Update consumables
                              roborock.0
                              2023-03-23 06:52:17.443	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:52:16.984	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:52:16.983	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:52:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:52:16.892	debug	dps debug: {"id":72,"result":[{"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:52:16.889	debug	dps debug: {"id":75,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:52:16.887	debug	dps debug: {"id":77,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:52:16.880	debug	dps debug: {"id":74,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:52:16.877	debug	dps debug: {"id":73,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:52:16.875	debug	dps debug: {"id":76,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:52:16.788	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:52:16.787	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:52:16.786	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:52:16.785	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:52:16.784	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:52:16.782	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:52:16.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:51:59.857	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:51:59.856	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:51:59.856	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:51:59.855	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:51:59.854	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:51:59.852	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:51:59.851	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:51:59.850	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:51:59.849	debug	dps debug: {"id":71,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:51:59.768	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:51:59.767	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:51:59.756	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:51:59.755	debug	dps debug: {"id":70,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:51:57.239	debug	Update consumables
                              roborock.0
                              2023-03-23 06:51:57.238	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:51:56.951	debug	dps debug: {"id":67,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:51:56.950	debug	dps debug: {"id":65,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:51:56.948	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:51:56.948	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:51:56.945	debug	dps debug: {"id":68,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:51:56.871	debug	dps debug: {"id":69,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:51:56.869	debug	dps debug: {"id":66,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:51:56.852	debug	get_status: {"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:51:56.851	debug	dps debug: {"id":64,"result":[{"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:51:56.787	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:51:56.786	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:51:56.785	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:51:56.785	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:51:56.783	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:51:56.783	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:51:56.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:51:37.882	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:51:37.881	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:51:37.880	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:51:37.879	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:51:37.878	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:51:37.878	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:51:37.877	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:51:37.876	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:51:37.875	debug	dps debug: {"id":63,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:51:37.844	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:51:37.843	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:51:37.758	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:51:37.758	debug	dps debug: {"id":62,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:51:37.055	debug	Update consumables
                              roborock.0
                              2023-03-23 06:51:37.054	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:51:36.985	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:51:36.984	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:51:36.927	debug	dps debug: {"id":59,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:51:36.924	debug	dps debug: {"id":61,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:51:36.920	debug	dps debug: {"id":60,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:51:36.907	debug	dps debug: {"id":57,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:51:36.891	debug	get_status: {"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:51:36.890	debug	dps debug: {"id":56,"result":[{"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:51:36.865	debug	dps debug: {"id":58,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:51:36.787	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:51:36.786	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:51:36.785	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:51:36.784	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:51:36.783	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:51:36.782	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:51:36.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:51:19.734	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:51:19.734	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:51:19.733	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:51:19.732	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:51:19.731	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:51:19.731	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:51:19.730	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:51:19.730	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:51:19.729	debug	dps debug: {"id":55,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:51:18.468	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:51:18.467	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:51:18.456	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:51:18.455	debug	dps debug: {"id":54,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:51:17.341	debug	Update consumables
                              roborock.0
                              2023-03-23 06:51:17.340	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:51:16.994	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:51:16.993	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:51:16.918	debug	dps debug: {"id":51,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:51:16.915	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:51:16.913	debug	dps debug: {"id":53,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:51:16.903	debug	dps debug: {"id":52,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:51:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:51:16.892	debug	dps debug: {"id":48,"result":[{"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:51:16.887	debug	dps debug: {"id":50,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:51:16.787	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:51:16.786	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:51:16.785	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:51:16.784	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:51:16.783	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:51:16.783	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:51:16.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:50:59.706	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:50:59.705	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:50:59.705	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:50:59.704	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:50:59.703	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:50:59.703	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:50:59.702	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:50:59.701	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:50:59.700	debug	dps debug: {"id":47,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:50:59.607	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:50:59.605	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:50:59.592	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:50:59.591	debug	dps debug: {"id":46,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:50:57.442	debug	Update consumables
                              roborock.0
                              2023-03-23 06:50:57.441	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:50:56.972	debug	dps debug: {"id":45,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:50:56.970	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:50:56.969	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:50:56.900	debug	dps debug: {"id":42,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:50:56.891	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:50:56.888	debug	dps debug: {"id":43,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:50:56.874	debug	dps debug: {"id":44,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:50:56.860	debug	get_status: {"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:50:56.858	debug	dps debug: {"id":40,"result":[{"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:56.790	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:50:56.788	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:50:56.786	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:50:56.785	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:50:56.784	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:50:56.783	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:50:56.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:50:37.832	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:50:37.832	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:50:37.831	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:50:37.830	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:50:37.829	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:50:37.828	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:50:37.828	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:50:37.827	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:50:37.826	debug	dps debug: {"id":39,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:50:37.708	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:50:37.708	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:50:37.695	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:50:37.694	debug	dps debug: {"id":38,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:50:37.331	debug	Update consumables
                              roborock.0
                              2023-03-23 06:50:37.330	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:50:36.951	debug	dps debug: {"id":37,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:50:36.949	debug	dps debug: {"id":35,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:50:36.945	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:50:36.945	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:50:36.875	debug	dps debug: {"id":33,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:50:36.871	debug	dps debug: {"id":34,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:50:36.846	debug	get_status: {"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:50:36.845	debug	dps debug: {"id":32,"result":[{"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:36.831	debug	dps debug: {"id":36,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:50:36.788	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:50:36.787	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:50:36.786	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:50:36.785	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:50:36.784	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:50:36.783	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:50:36.782	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:50:18.702	debug	Mapped room matched: 10800662 with name: Badezimmer unten
                              roborock.0
                              2023-03-23 06:50:18.701	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
                              roborock.0
                              2023-03-23 06:50:18.701	debug	Mapped room matched: 10800591 with name: Schlafzimmer
                              roborock.0
                              2023-03-23 06:50:18.699	debug	Mapped room matched: 10931661 with name: Eingang unten
                              roborock.0
                              2023-03-23 06:50:18.699	debug	Mapped room matched: 10800659 with name: Flur unten
                              roborock.0
                              2023-03-23 06:50:18.698	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
                              roborock.0
                              2023-03-23 06:50:18.697	debug	Mapped room matched: 10800654 with name: HWR
                              roborock.0
                              2023-03-23 06:50:18.697	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
                              roborock.0
                              2023-03-23 06:50:18.696	debug	dps debug: {"id":31,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
                              roborock.0
                              2023-03-23 06:50:18.018	debug	getParameter: get_room_mapping
                              roborock.0
                              2023-03-23 06:50:18.017	debug	dps debug: {"id":10,"result":["ok"]}
                              roborock.0
                              2023-03-23 06:50:18.014	debug	foreign.message attribute: 128 with value: 0
                              roborock.0
                              2023-03-23 06:50:18.014	debug	dps debug: {"128":0}
                              roborock.0
                              2023-03-23 06:50:17.483	debug	Update consumables
                              roborock.0
                              2023-03-23 06:50:17.482	debug	homedata successfully updated
                              roborock.0
                              2023-03-23 06:50:17.159	debug	Cleaning record: {"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.158	debug	dps debug: {"id":26,"result":[{"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.078	debug	Cleaning record: {"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.077	debug	dps debug: {"id":28,"result":[{"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.074	debug	Cleaning record: {"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.073	debug	dps debug: {"id":20,"result":[{"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.070	debug	Cleaning record: {"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:17.069	debug	Cleaning record: {"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.068	debug	dps debug: {"id":29,"result":[{"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:17.067	debug	dps debug: {"id":21,"result":[{"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.064	debug	Cleaning record: {"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:17.063	debug	dps debug: {"id":30,"result":[{"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:17.060	debug	Cleaning record: {"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.060	debug	dps debug: {"id":11,"result":[{"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.057	debug	Cleaning record: {"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:17.057	debug	dps debug: {"id":23,"result":[{"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:17.055	debug	Cleaning record: {"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.053	debug	dps debug: {"id":14,"result":[{"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.051	debug	Cleaning record: {"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.050	debug	dps debug: {"id":19,"result":[{"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.047	debug	Cleaning record: {"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:17.046	debug	dps debug: {"id":24,"result":[{"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:17.044	debug	Cleaning record: {"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.043	debug	dps debug: {"id":25,"result":[{"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.041	debug	Cleaning record: {"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.040	debug	dps debug: {"id":27,"result":[{"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.037	debug	Cleaning record: {"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:17.036	debug	dps debug: {"id":22,"result":[{"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:17.034	debug	Cleaning record: {"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.033	debug	dps debug: {"id":18,"result":[{"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.031	debug	Cleaning record: {"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.030	debug	dps debug: {"id":13,"result":[{"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.027	debug	Cleaning record: {"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.026	debug	dps debug: {"id":16,"result":[{"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.007	debug	Cleaning record: {"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:17.004	debug	dps debug: {"id":17,"result":[{"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:17.000	debug	Cleaning record: {"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}
                              roborock.0
                              2023-03-23 06:50:16.999	debug	dps debug: {"id":12,"result":[{"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}]}
                              roborock.0
                              2023-03-23 06:50:16.993	debug	Cleaning record: {"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}
                              roborock.0
                              2023-03-23 06:50:16.992	debug	dps debug: {"id":15,"result":[{"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:16.977	debug	foreign.message attribute: 128 with value: 4
                              roborock.0
                              2023-03-23 06:50:16.975	debug	dps debug: {"128":4}
                              roborock.0
                              2023-03-23 06:50:16.945	debug	dps debug: {"id":8,"result":{"water_box_mode":202}}
                              roborock.0
                              2023-03-23 06:50:16.926	debug	dps debug: {"id":9,"result":{"clean_time":154668,"clean_area":2151037500,"clean_count":234,"dust_collection_count":103,"records":[1679548681,1679485898,1679484869,1679474738,1679474541,1679465459,1679432038,1679417150,1679393236,1679390684,1679389971,1679385601,1679218926,1679213306,1679209436,1679209397,1679205735,1679065431,1679054409,1679044923]}}
                              roborock.0
                              2023-03-23 06:50:16.913	debug	dps debug: {"id":4,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
                              roborock.0
                              2023-03-23 06:50:16.910	debug	dps debug: {"id":5,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
                              roborock.0
                              2023-03-23 06:50:16.896	debug	get_status: {"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                              roborock.0
                              2023-03-23 06:50:16.895	debug	dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                              roborock.0
                              2023-03-23 06:50:16.890	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                              roborock.0
                              2023-03-23 06:50:16.885	debug	dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                              roborock.0
                              2023-03-23 06:50:16.883	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
                              roborock.0
                              2023-03-23 06:50:16.878	debug	dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1679549423,"length":2,"name":"UG","bak_maps":[{"mapFlag":4,"add_time":1676811567}]},{"mapFlag":1,"add_time":1678210539,"length":2,"name":"OG","bak_maps":[{"mapFlag":5,"add_time":1676814827}]}]}]}
                              roborock.0
                              2023-03-23 06:50:16.804	debug	getParameter: get_water_box_custom_mode
                              roborock.0
                              2023-03-23 06:50:16.803	debug	getParameter: get_carpet_clean_mode
                              roborock.0
                              2023-03-23 06:50:16.801	debug	getParameter: get_carpet_mode
                              roborock.0
                              2023-03-23 06:50:16.799	debug	getParameter: get_network_info
                              roborock.0
                              2023-03-23 06:50:16.797	debug	getParameter: get_consumable
                              roborock.0
                              2023-03-23 06:50:16.794	debug	getParameter: get_status
                              roborock.0
                              2023-03-23 06:50:16.793	debug	Latest data requested
                              roborock.0
                              2023-03-23 06:50:16.790	debug	getParameter: get_multi_maps_list
                              roborock.0
                              2023-03-23 06:50:16.784	debug	Firmware features request
                              roborock.0
                              2023-03-23 06:50:16.783	debug	getParameter: get_fw_features
                              roborock.0
                              2023-03-23 06:50:14.364	debug	Robot key: roborock.vacuum.a27
                              roborock.0
                              2023-03-23 06:50:14.362	debug	RoomIDs debug: {"10800591":"Schlafzimmer","10800608":"Kinderzimmer 1","10800627":"Kinderzimmer 2","10800637":"Badezimmer","10800645":"Flur","10800654":"HWR","10800659":"Flur unten","10800662":"Badezimmer unten","10803462":"Badezimmer oben","10803465":"Flur oben","10803485":"Küche","10803502":"Esszimmer","10803513":"Wohnzimmer","10931661":"Eingang unten"}
                              roborock.0
                              2023-03-23 06:50:14.360	info	MQTT initialized
                              roborock.0
                              2023-03-23 06:50:13.516	info	starting. Version 0.1.4-beta.3 (non-npm: copystring/ioBroker.roborock#ead555830dcfcc0b2623b231fd97e016a3929bb8) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.15.0, js-controller: 4.0.24
                              roborock.0
                              2023-03-23 06:50:12.795	debug	Plugin sentry destroyed because not initialized correctly
                              roborock.0
                              2023-03-23 06:50:12.734	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                                @copystring
                                Dke Zeile?
                                EDIT
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                copystringC Offline
                                copystringC Offline
                                copystring
                                #489
                                @david-g was passiert denn, wenn man die Bürste zurücksetzt? Ist dann cleaning_brush_work_times auf 0? Dann könnte man sich den echten wert ausrechnen, wenn man weiß wie lange die Bürste maximal laufen darf.
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #490
                                  @copystring
                                  Teste ich nachher, angelegt werden die Punkte ja (hab ich eben nochmal gesehen).
                                  Der Dust_collection_work_times hat wohl keinen Festen Wert.
                                  Setzte die Bürste nachher mal zurück.
                                  EDIT
                                  Ja, wird zurückgesetzt. Vom Balken her gehe ich mal von aus, dass er bis 300 geht.
                                  roborock.0
                                  2023-03-23 14:39:46.795	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":0}]}
                                    @copystring
                                    Menfis
                                    #491
                                    @copystring
                                    Ich habe beides probiert. Die Floors gelöscht aber dadurch änderte sich nichts. Leider brachte auch eine Neuinstallation des Adapters keine Besserung.
                                    Es kommt immer noch eine Fehlermeldung alla:
                                    	dps debug: {"id":1611,"error":{"code":-10005,"message":"data for segments is invalid"}}
                                    Komisch, dass es bei anderen problemlos geht.
                                    • M Menfis
                                      @copystring
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #492
                                      Wie ist das gemeint? Die anderen Räume gehen nur die Küche nicht?
                                        michael 1975
                                        #493
                                        Ich habe heute den Adapter installiert erwurde auch grün, aber leider habe ich keinen Sauger in den Objekten an was kann das liegen.
                                        Bentzername=mail Passwort ganz sicher richtig eingegeben.
                                        • M michael 1975
                                          wendy2702W Online
                                          wendy2702W Online
                                          #494
                                          @michael-1975 sagte in Roborock Adapter tester gesucht:
                                          Laut log ist das aber eben nicht richtig oder kommt dein IOB nicht ins internet?
