  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.9k Aufrufe 52 Beobachtet
  • copystringC copystring
    @david-g said in Roborock Adapter tester gesucht:
    @copystring
    In HomeData finde ich nichts.
    Ist ein Roborock S7 MaxV.
    {"id":3997987,"name":"xxxx","lon":null,"lat":null,"geoName":null,"products":[{"id":"42yfoQm5eOY3gARZw6xgU","name":"Roborock S7 MaxV","code":"a27","model":"roborock.vacuum.a27","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"7UreppMhwYr4WlSbCtcsno","name":"Roborock S7 MaxV","attribute":null,"activeTime":1676794696,"localKey":"XmIxKeJ6ysQxGuf0","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"42yfoQm5eOY3gARZw6xgU","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.57.26","pv":"1.0","roomId":10800654,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{\"RRMonitorPrivacyVersion\": \"1\"}","sn":"R21ETS22901883","featureSet":"2234201184108543","newFeatureSet":"0000000000002041","deviceStatus":{"120":0,"121":8,"122":100,"123":102,"124":202,"125":87,"126":80,"127":73,"128":0,"133":1},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10931661,"name":"Eingang unten"},{"id":10803513,"name":"Wohnzimmer"},{"id":10803502,"name":"Esszimmer"},{"id":10803485,"name":"Küche"},{"id":10803465,"name":"Flur oben"},{"id":10803462,"name":"Badezimmer oben"},{"id":10800662,"name":"Badezimmer unten"},{"id":10800659,"name":"Flur unten"},{"id":10800654,"name":"HWR"},{"id":10800645,"name":"Flur"},{"id":10800637,"name":"Badezimmer"},{"id":10800627,"name":"Kinderzimmer 2"},{"id":10800608,"name":"Kinderzimmer 1"},{"id":10800591,"name":"Schlafzimmer"}]}
    OK. Mal in dein Log gucken. Dort müsste so etwas wie das hier stehen:
    dps debug: {"id":3442,"result":[{"main_brush_work_time":299562,"side_brush_work_time":299562,"filter_work_time":299562,"filter_element_work_time":0,"sensor_dirty_time":78061,"dust_collection_work_times":79}]} Ist da bei dir vielleicht mehr drin als bei mir?
    David G.D Online
    David G.D Online
    David G.
    #488
    @copystring
    Dke Zeile?
    2023-03-23 06:07:47.773	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154416,"side_brush_work_time":154416,"filter_work_time":154416,"filter_element_work_time":0,"sensor_dirty_time":85652,"strainer_work_times":145,"dust_collection_work_times":102,"cleaning_brush_work_times":145}]}
    Dort scheint es auch nicht zu stehen.
    EDIT
    Hier mal der ganze Adapterstart
    roborock.0
    2023-03-23 06:52:18.110	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:52:18.110	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:52:18.110	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:52:18.109	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:52:18.109	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:52:18.108	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:52:18.108	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:52:18.108	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:52:18.107	debug	dps debug: {"id":79,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:52:18.023	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:52:18.023	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:52:18.010	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:52:18.009	debug	dps debug: {"id":78,"result":["ok"]}
    roborock.0
    2023-03-23 06:52:17.444	debug	Update consumables
    roborock.0
    2023-03-23 06:52:17.443	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:52:16.984	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:52:16.983	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:52:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:52:16.892	debug	dps debug: {"id":72,"result":[{"msg_ver":2,"msg_seq":2291,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:52:16.889	debug	dps debug: {"id":75,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:52:16.887	debug	dps debug: {"id":77,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:52:16.880	debug	dps debug: {"id":74,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:52:16.877	debug	dps debug: {"id":73,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:52:16.875	debug	dps debug: {"id":76,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:52:16.788	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:52:16.787	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:52:16.786	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:52:16.785	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:52:16.784	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:52:16.782	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:52:16.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:51:59.857	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:51:59.856	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:51:59.856	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:51:59.855	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:51:59.854	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:51:59.852	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:51:59.851	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:51:59.850	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:51:59.849	debug	dps debug: {"id":71,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:51:59.768	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:51:59.767	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:51:59.756	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:51:59.755	debug	dps debug: {"id":70,"result":["ok"]}
    roborock.0
    2023-03-23 06:51:57.239	debug	Update consumables
    roborock.0
    2023-03-23 06:51:57.238	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:51:56.951	debug	dps debug: {"id":67,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:51:56.950	debug	dps debug: {"id":65,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:51:56.948	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:51:56.948	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:51:56.945	debug	dps debug: {"id":68,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:51:56.871	debug	dps debug: {"id":69,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:51:56.869	debug	dps debug: {"id":66,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:51:56.852	debug	get_status: {"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:51:56.851	debug	dps debug: {"id":64,"result":[{"msg_ver":2,"msg_seq":2287,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:51:56.787	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:51:56.786	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:51:56.785	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:51:56.785	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:51:56.783	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:51:56.783	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:51:56.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:51:37.882	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:51:37.881	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:51:37.880	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:51:37.879	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:51:37.878	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:51:37.878	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:51:37.877	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:51:37.876	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:51:37.875	debug	dps debug: {"id":63,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:51:37.844	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:51:37.843	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:51:37.758	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:51:37.758	debug	dps debug: {"id":62,"result":["ok"]}
    roborock.0
    2023-03-23 06:51:37.055	debug	Update consumables
    roborock.0
    2023-03-23 06:51:37.054	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:51:36.985	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:51:36.984	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:51:36.927	debug	dps debug: {"id":59,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:51:36.924	debug	dps debug: {"id":61,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:51:36.920	debug	dps debug: {"id":60,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:51:36.907	debug	dps debug: {"id":57,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:51:36.891	debug	get_status: {"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:51:36.890	debug	dps debug: {"id":56,"result":[{"msg_ver":2,"msg_seq":2283,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:51:36.865	debug	dps debug: {"id":58,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:51:36.787	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:51:36.786	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:51:36.785	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:51:36.784	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:51:36.783	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:51:36.782	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:51:36.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:51:19.734	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:51:19.734	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:51:19.733	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:51:19.732	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:51:19.731	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:51:19.731	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:51:19.730	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:51:19.730	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:51:19.729	debug	dps debug: {"id":55,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:51:18.468	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:51:18.467	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:51:18.456	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:51:18.455	debug	dps debug: {"id":54,"result":["ok"]}
    roborock.0
    2023-03-23 06:51:17.341	debug	Update consumables
    roborock.0
    2023-03-23 06:51:17.340	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:51:16.994	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:51:16.993	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:51:16.918	debug	dps debug: {"id":51,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:51:16.915	debug	dps debug: {"id":49,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:51:16.913	debug	dps debug: {"id":53,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:51:16.903	debug	dps debug: {"id":52,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:51:16.893	debug	get_status: {"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:51:16.892	debug	dps debug: {"id":48,"result":[{"msg_ver":2,"msg_seq":2279,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:51:16.887	debug	dps debug: {"id":50,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:51:16.787	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:51:16.786	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:51:16.785	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:51:16.784	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:51:16.783	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:51:16.783	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:51:16.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:50:59.706	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:50:59.705	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:50:59.705	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:50:59.704	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:50:59.703	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:50:59.703	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:50:59.702	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:50:59.701	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:50:59.700	debug	dps debug: {"id":47,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:50:59.607	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:50:59.605	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:50:59.592	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:50:59.591	debug	dps debug: {"id":46,"result":["ok"]}
    roborock.0
    2023-03-23 06:50:57.442	debug	Update consumables
    roborock.0
    2023-03-23 06:50:57.441	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:50:56.972	debug	dps debug: {"id":45,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:50:56.970	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:50:56.969	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:50:56.900	debug	dps debug: {"id":42,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:50:56.891	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:50:56.888	debug	dps debug: {"id":43,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:50:56.874	debug	dps debug: {"id":44,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:50:56.860	debug	get_status: {"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:50:56.858	debug	dps debug: {"id":40,"result":[{"msg_ver":2,"msg_seq":2275,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:50:56.790	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:50:56.788	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:50:56.786	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:50:56.785	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:50:56.784	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:50:56.783	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:50:56.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:50:37.832	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:50:37.832	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:50:37.831	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:50:37.830	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:50:37.829	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:50:37.828	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:50:37.828	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:50:37.827	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:50:37.826	debug	dps debug: {"id":39,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:50:37.708	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:50:37.708	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:50:37.695	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:50:37.694	debug	dps debug: {"id":38,"result":["ok"]}
    roborock.0
    2023-03-23 06:50:37.331	debug	Update consumables
    roborock.0
    2023-03-23 06:50:37.330	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:50:36.951	debug	dps debug: {"id":37,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:50:36.949	debug	dps debug: {"id":35,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:50:36.945	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:50:36.945	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:50:36.875	debug	dps debug: {"id":33,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:50:36.871	debug	dps debug: {"id":34,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:50:36.846	debug	get_status: {"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:50:36.845	debug	dps debug: {"id":32,"result":[{"msg_ver":2,"msg_seq":2271,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:50:36.831	debug	dps debug: {"id":36,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:50:36.788	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:50:36.787	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:50:36.786	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:50:36.785	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:50:36.784	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:50:36.783	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:50:36.782	debug	Latest data requested
    roborock.0
    2023-03-23 06:50:18.702	debug	Mapped room matched: 10800662 with name: Badezimmer unten
    roborock.0
    2023-03-23 06:50:18.701	debug	Mapped room matched: 10800608 with name: Kinderzimmer 1
    roborock.0
    2023-03-23 06:50:18.701	debug	Mapped room matched: 10800591 with name: Schlafzimmer
    roborock.0
    2023-03-23 06:50:18.699	debug	Mapped room matched: 10931661 with name: Eingang unten
    roborock.0
    2023-03-23 06:50:18.699	debug	Mapped room matched: 10800659 with name: Flur unten
    roborock.0
    2023-03-23 06:50:18.698	debug	Mapped room matched: 10800627 with name: Kinderzimmer 2
    roborock.0
    2023-03-23 06:50:18.697	debug	Mapped room matched: 10800654 with name: HWR
    roborock.0
    2023-03-23 06:50:18.697	debug	All mapped rooms: [[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]
    roborock.0
    2023-03-23 06:50:18.696	debug	dps debug: {"id":31,"result":[[16,"10800654",12],[17,"10800627",12],[18,"10800659",8],[19,"10931661",12],[20,"10800591",1],[21,"10800608",1],[22,"10800662",15]]}
    roborock.0
    2023-03-23 06:50:18.018	debug	getParameter: get_room_mapping
    roborock.0
    2023-03-23 06:50:18.017	debug	dps debug: {"id":10,"result":["ok"]}
    roborock.0
    2023-03-23 06:50:18.014	debug	foreign.message attribute: 128 with value: 0
    roborock.0
    2023-03-23 06:50:18.014	debug	dps debug: {"128":0}
    roborock.0
    2023-03-23 06:50:17.483	debug	Update consumables
    roborock.0
    2023-03-23 06:50:17.482	debug	homedata successfully updated
    roborock.0
    2023-03-23 06:50:17.159	debug	Cleaning record: {"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.158	debug	dps debug: {"id":26,"result":[{"begin":1679209397,"end":1679209428,"duration":27,"area":365000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.078	debug	Cleaning record: {"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.077	debug	dps debug: {"id":28,"result":[{"begin":1679065431,"end":1679065902,"duration":337,"area":5760000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.074	debug	Cleaning record: {"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.073	debug	dps debug: {"id":20,"result":[{"begin":1679390684,"end":1679391608,"duration":924,"area":14262500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":28,"wash_count":1,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.070	debug	Cleaning record: {"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:17.069	debug	Cleaning record: {"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.068	debug	dps debug: {"id":29,"result":[{"begin":1679054409,"end":1679055002,"duration":593,"area":6037500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:17.067	debug	dps debug: {"id":21,"result":[{"begin":1679389971,"end":1679390656,"duration":685,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":34,"wash_count":0,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.064	debug	Cleaning record: {"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:17.063	debug	dps debug: {"id":30,"result":[{"begin":1679044923,"end":1679046254,"duration":1331,"area":25282500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:17.060	debug	Cleaning record: {"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.060	debug	dps debug: {"id":11,"result":[{"begin":1679548681,"end":1679549084,"duration":256,"area":2947500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":8,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.057	debug	Cleaning record: {"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:17.057	debug	dps debug: {"id":23,"result":[{"begin":1679218926,"end":1679219143,"duration":217,"area":2290000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":0,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:17.055	debug	Cleaning record: {"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.053	debug	dps debug: {"id":14,"result":[{"begin":1679474738,"end":1679474952,"duration":214,"area":2872500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.051	debug	Cleaning record: {"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.050	debug	dps debug: {"id":19,"result":[{"begin":1679393236,"end":1679395216,"duration":1696,"area":29892500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":26,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.047	debug	Cleaning record: {"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:17.046	debug	dps debug: {"id":24,"result":[{"begin":1679213306,"end":1679216948,"duration":3642,"area":49580000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0,"avoid_count":94,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:17.044	debug	Cleaning record: {"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.043	debug	dps debug: {"id":25,"result":[{"begin":1679209436,"end":1679211928,"duration":2236,"area":39357500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":35,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.041	debug	Cleaning record: {"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.040	debug	dps debug: {"id":27,"result":[{"begin":1679205735,"end":1679207893,"duration":1786,"area":16120000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":21,"wash_count":3,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.037	debug	Cleaning record: {"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:17.036	debug	dps debug: {"id":22,"result":[{"begin":1679385601,"end":1679389046,"duration":3445,"area":47657500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":85,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:17.034	debug	Cleaning record: {"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.033	debug	dps debug: {"id":18,"result":[{"begin":1679417150,"end":1679417512,"duration":230,"area":2992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.031	debug	Cleaning record: {"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.030	debug	dps debug: {"id":13,"result":[{"begin":1679484869,"end":1679484870,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0,"avoid_count":12,"wash_count":0,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.027	debug	Cleaning record: {"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.026	debug	dps debug: {"id":16,"result":[{"begin":1679465459,"end":1679465840,"duration":250,"area":2965000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.007	debug	Cleaning record: {"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}
    roborock.0
    2023-03-23 06:50:17.004	debug	dps debug: {"id":17,"result":[{"begin":1679432038,"end":1679432411,"duration":246,"area":2950000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":5,"wash_count":2,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:17.000	debug	Cleaning record: {"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}
    roborock.0
    2023-03-23 06:50:16.999	debug	dps debug: {"id":12,"result":[{"begin":1679485898,"end":1679489833,"duration":3764,"area":48860000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":119,"wash_count":0,"map_flag":1}]}
    roborock.0
    2023-03-23 06:50:16.993	debug	Cleaning record: {"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}
    roborock.0
    2023-03-23 06:50:16.992	debug	dps debug: {"id":15,"result":[{"begin":1679474541,"end":1679474710,"duration":42,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":62,"dust_collection_status":0,"avoid_count":2,"wash_count":1,"map_flag":0}]}
    roborock.0
    2023-03-23 06:50:16.977	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-03-23 06:50:16.975	debug	dps debug: {"128":4}
    roborock.0
    2023-03-23 06:50:16.945	debug	dps debug: {"id":8,"result":{"water_box_mode":202}}
    roborock.0
    2023-03-23 06:50:16.926	debug	dps debug: {"id":9,"result":{"clean_time":154668,"clean_area":2151037500,"clean_count":234,"dust_collection_count":103,"records":[1679548681,1679485898,1679484869,1679474738,1679474541,1679465459,1679432038,1679417150,1679393236,1679390684,1679389971,1679385601,1679218926,1679213306,1679209436,1679209397,1679205735,1679065431,1679054409,1679044923]}}
    roborock.0
    2023-03-23 06:50:16.913	debug	dps debug: {"id":4,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":147}]}
    roborock.0
    2023-03-23 06:50:16.910	debug	dps debug: {"id":5,"result":{"ssid":"meins","ip":"192.168.99.54","mac":"b0:4a:39:52:da:f2","bssid":"e8:df:70:00:e7:d0","rssi":-59}}
    roborock.0
    2023-03-23 06:50:16.896	debug	get_status: {"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    roborock.0
    2023-03-23 06:50:16.895	debug	dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":2267,"state":8,"battery":100,"clean_time":256,"clean_area":2947500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":421,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":8,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    roborock.0
    2023-03-23 06:50:16.890	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    roborock.0
    2023-03-23 06:50:16.885	debug	dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
    roborock.0
    2023-03-23 06:50:16.883	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
    roborock.0
    2023-03-23 06:50:16.878	debug	dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1679549423,"length":2,"name":"UG","bak_maps":[{"mapFlag":4,"add_time":1676811567}]},{"mapFlag":1,"add_time":1678210539,"length":2,"name":"OG","bak_maps":[{"mapFlag":5,"add_time":1676814827}]}]}]}
    roborock.0
    2023-03-23 06:50:16.804	debug	getParameter: get_water_box_custom_mode
    roborock.0
    2023-03-23 06:50:16.803	debug	getParameter: get_carpet_clean_mode
    roborock.0
    2023-03-23 06:50:16.801	debug	getParameter: get_carpet_mode
    roborock.0
    2023-03-23 06:50:16.799	debug	getParameter: get_network_info
    roborock.0
    2023-03-23 06:50:16.797	debug	getParameter: get_consumable
    roborock.0
    2023-03-23 06:50:16.794	debug	getParameter: get_status
    roborock.0
    2023-03-23 06:50:16.793	debug	Latest data requested
    roborock.0
    2023-03-23 06:50:16.790	debug	getParameter: get_multi_maps_list
    roborock.0
    2023-03-23 06:50:16.784	debug	Firmware features request
    roborock.0
    2023-03-23 06:50:16.783	debug	getParameter: get_fw_features
    roborock.0
    2023-03-23 06:50:14.364	debug	Robot key: roborock.vacuum.a27
    roborock.0
    2023-03-23 06:50:14.362	debug	RoomIDs debug: {"10800591":"Schlafzimmer","10800608":"Kinderzimmer 1","10800627":"Kinderzimmer 2","10800637":"Badezimmer","10800645":"Flur","10800654":"HWR","10800659":"Flur unten","10800662":"Badezimmer unten","10803462":"Badezimmer oben","10803465":"Flur oben","10803485":"Küche","10803502":"Esszimmer","10803513":"Wohnzimmer","10931661":"Eingang unten"}
    roborock.0
    2023-03-23 06:50:14.360	info	MQTT initialized
    roborock.0
    2023-03-23 06:50:13.516	info	starting. Version 0.1.4-beta.3 (non-npm: copystring/ioBroker.roborock#ead555830dcfcc0b2623b231fd97e016a3929bb8) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.15.0, js-controller: 4.0.24
    roborock.0
    2023-03-23 06:50:12.795	debug	Plugin sentry destroyed because not initialized correctly
    roborock.0
    2023-03-23 06:50:12.734	debug	Plugin sentry Do not initialize Plugin (enabled=false)
    copystringC 1 Antwort Letzte Antwort
    • David G.D David G.
      @copystring
      Dke Zeile?
      EDIT
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      copystringC Offline
      copystringC Offline
      copystring
      #489
      @david-g was passiert denn, wenn man die Bürste zurücksetzt? Ist dann cleaning_brush_work_times auf 0? Dann könnte man sich den echten wert ausrechnen, wenn man weiß wie lange die Bürste maximal laufen darf.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
        David G.D Online
        David G.D Online
        David G.
        #490
        @copystring
        Teste ich nachher, angelegt werden die Punkte ja (hab ich eben nochmal gesehen).
        Der Dust_collection_work_times hat wohl keinen Festen Wert.
        Setzte die Bürste nachher mal zurück.
        EDIT
        Ja, wird zurückgesetzt. Vom Balken her gehe ich mal von aus, dass er bis 300 geht.
        roborock.0
        2023-03-23 14:39:46.795	debug	dps debug: {"id":41,"result":[{"main_brush_work_time":154672,"side_brush_work_time":154672,"filter_work_time":154672,"filter_element_work_time":0,"sensor_dirty_time":85908,"strainer_work_times":147,"dust_collection_work_times":103,"cleaning_brush_work_times":0}]}
          @menfis said in Roborock Adapter tester gesucht:
          @copystring
          Ja, sieht man. Allerdings wird immer nur ein einziger Raum bunt.
          Sehr merkwürdig, weil der Befehl sauber abgeschickt wurde. Leider kommt aber ein Fehler zurück.
          dps debug: {"id":71,"error":{"code":-10005,"message":"data for segments is invalid"}}
          Ich weiß aber nicht, warum das so ist, weil app_segment_clean with roomIDs: {"segments":[17,23],"repeat":1} result: ok sauber durchläuft. Ich habe z. B. auch einen Raum mit Umlaut (Küche) und das läuft sauber durch. Hast du mal versucht, alle Objekte unter Rooms zu löschen? Noch besser wäre es, wenn du den Adapter ein mal löschst und neu installierst. Ich wüsste sonst nicht wirklich, woran es liegen könnte.
          Menfis
          #491
          @copystring sagte in Roborock Adapter tester gesucht:
          @copystring
          Ich habe beides probiert. Die Floors gelöscht aber dadurch änderte sich nichts. Leider brachte auch eine Neuinstallation des Adapters keine Besserung.
          Es kommt immer noch eine Fehlermeldung alla:
          	dps debug: {"id":1611,"error":{"code":-10005,"message":"data for segments is invalid"}}
          Komisch, dass es bei anderen problemlos geht.
          • M Menfis
            @copystring
            copystringC Offline
            copystringC Offline
            copystring
            #492
            Wie ist das gemeint? Die anderen Räume gehen nur die Küche nicht?
              michael 1975
              #493
              Ich habe heute den Adapter installiert erwurde auch grün, aber leider habe ich keinen Sauger in den Objekten an was kann das liegen.
              Bentzername=mail Passwort ganz sicher richtig eingegeben.
              • M michael 1975
                wendy2702W Offline
                wendy2702W Offline
                #494
                @michael-1975 sagte in Roborock Adapter tester gesucht:
                Laut log ist das aber eben nicht richtig oder kommt dein IOB nicht ins internet?
                • wendy2702W wendy2702
                  michael 1975
                  #495
                  @wendy2702 das passwort ist sicher richtig habe komischerweise das Problem auch mit dem mihome vacum adapter das der nicht geht der findet aber der sauger.
                  Und der Ioboker sollte eigentlich auch ins internet kommen ansonsten habe ich keine Probleme
                  wendy2702W CodierknechtC 2 Antworten Letzte Antwort
                  • M michael 1975
                    wendy2702W Offline
                    wendy2702W Offline
                    #496
                    @michael-1975 Soweit mir bekannt musst du dich App technisch entscheiden, beide gehen nicht.
                    Stell das Log mal auf Debug und poste die Ausgabe als Text in Code Tags </>
                    • M michael 1975
                      CodierknechtC Offline
                      Codierknecht
                      #497
                      ... enthält aber möglicherweise Sonderzeichen, die Probleme machen.
                      Wäre ja nicht der erste Adapter, der bei der Verwendung bestimmter Sonderzeichen Probleme hat.
                      Kannst ja mal testweise mit einem Passwort ohne Sonderzeichen probieren.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        wendy2702W Offline
                        wendy2702W Offline
                        #498
                        @codierknecht @michael-1975 und ohne Umlaute
                          Menfis
                          #499
                          @copystring nein, nein. Ich meinte bei anderen Usern.
                          • D DonToben
                            @copystring
                            Habe mir gerade den iobroker log angesehen.
                            Es gab heute Nacht eine Menge Fehlereinträge, danach wieder alles i.O.
                            Eine Idee?
                            Roborock S7 Pro Ultra.
                            Habe die 0.1.6 installiert. Mit den Version davor hatte ich die Auffälligkeit nicht.
                            2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 589 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 590 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 591 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.523 - error: roborock.0 (5655) Unsported attribute: 592 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 593 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 594 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 595 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.524 - error: roborock.0 (5655) Unsported attribute: 596 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 597 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 598 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 599 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.525 - error: roborock.0 (5655) Unsported attribute: 600 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 601 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 602 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.526 - error: roborock.0 (5655) Unsported attribute: 603 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 604 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 605 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 606 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.527 - error: roborock.0 (5655) Unsported attribute: 607 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 608 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 609 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 610 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.528 - error: roborock.0 (5655) Unsported attribute: 611 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.529 - error: roborock.0 (5655) Unsported attribute: 612 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.529 - error: roborock.0 (5655) Unsported attribute: 613 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 614 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 615 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 616 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.530 - error: roborock.0 (5655) Unsported attribute: 617 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 618 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 619 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 620 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 621 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 622 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.531 - error: roborock.0 (5655) Unsported attribute: 623 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 624 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 625 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 626 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 627 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 628 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.532 - error: roborock.0 (5655) Unsported attribute: 629 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 630 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 631 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 632 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 633 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 634 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.533 - error: roborock.0 (5655) Unsported attribute: 635 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 636 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 637 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 638 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 639 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.534 - error: roborock.0 (5655) Unsported attribute: 640 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 641 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 642 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 643 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 644 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.535 - error: roborock.0 (5655) Unsported attribute: 645 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 646 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 647 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 648 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 649 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 650 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.536 - error: roborock.0 (5655) Unsported attribute: 651 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 652 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 653 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 654 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 655 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 656 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.537 - error: roborock.0 (5655) Unsported attribute: 657 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.538 - error: roborock.0 (5655) Unsported attribute: 658 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 03:52:31.538 - error: roborock.0 (5655) Unsported attribute: 659 of get_status. Please contact the dev to add the newly found attribute of your robot.
                            2023-03-15 04:34:31.481 - info: roborock.0 (5655) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_custom_mode" has to be type "number" but received type "string"
                            2023-03-15 04:44:31.484 - info: roborock.0 (5655) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_custom_mode" has to be type "number" but received type "string"
                            2023-03-15 04:56:30.926 - warn: roborock.0 (5655) MQTT connection close.
                            2023-03-15 04:56:30.927 - warn: roborock.0 (5655) MQTT connection reconnect.
                            DonToben
                            schrieb am zuletzt editiert von DonToben
                            #500
                            @copystring
                            Könntest du dir das bitte ansehen.
                            Gerade ein Update der Fritzbox gemacht. Danach hat iobroker den Roborock Adapter automatisch angehalten wegen zu vieler Neustarts.
                            Kannst du dir das erklären?
                            -03-24 09:00:11.217 - warn: roborock.0 (29551) MQTT connection close.
                            2023-03-24 09:00:11.222 - warn: roborock.0 (29551) MQTT connection reconnect.
                            2023-03-24 12:00:11.212 - warn: roborock.0 (29551) MQTT connection close.
                            2023-03-24 12:00:11.213 - warn: roborock.0 (29551) MQTT connection reconnect.
                            2023-03-24 15:00:11.213 - warn: roborock.0 (29551) MQTT connection close.
                            2023-03-24 15:00:11.214 - warn: roborock.0 (29551) MQTT connection reconnect.
                            2023-03-24 16:33:11.623 - warn: roborock.0 (29551) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.carpet_clean_mode" has no existing object, this might lead to an error in future versions
                            2023-03-24 17:14:41.533 - error: roborock.0 (29551) MQTT connection offline: undefined
                            2023-03-24 17:14:41.534 - warn: roborock.0 (29551) MQTT connection close.
                            2023-03-24 17:14:42.534 - warn: roborock.0 (29551) MQTT connection reconnect.
                            2023-03-24 17:14:47.446 - error: roborock.0 (29551) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2023-03-24 17:14:47.447 - error: roborock.0 (29551) unhandled promise rejection: getaddrinfo EAI_AGAIN api-eu.roborock.com
                            2023-03-24 17:14:47.449 - error: roborock.0 (29551) Error: getaddrinfo EAI_AGAIN api-eu.roborock.com
                            at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:825:14)
                            at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:2973:25)
                            at RedirectableRequest.emit (node:events:513:28)
                            at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
                            at ClientRequest.emit (node:events:513:28)
                            at TLSSocket.socketErrorListener (node:_http_client:494:9)
                            at TLSSocket.emit (node:events:513:28)
                            at emitErrorNT (node:internal/streams/destroy:157:8)
                            at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                            at processTicksAndRejections (node:internal/process/task_queues:83:21)
                            2023-03-24 17:14:47.450 - error: roborock.0 (29551) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api-eu.roborock.com
                            2023-03-24 17:14:47.458 - info: roborock.0 (29551) terminating
                            2023-03-24 17:14:47.460 - warn: roborock.0 (29551) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2023-03-24 17:15:04.040 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2023-03-24 17:15:04.042 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                            2023-03-24 17:15:05.269 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24330
                            2023-03-24 17:15:08.304 - info: roborock.0 (24330) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                            2023-03-24 17:15:30.675 - error: roborock.0 (24330) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2023-03-24 17:15:30.677 - error: roborock.0 (24330) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:30.682 - error: roborock.0 (24330) Error: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:30.683 - error: roborock.0 (24330) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:30.694 - info: roborock.0 (24330) terminating
                            2023-03-24 17:15:30.697 - warn: roborock.0 (24330) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2023-03-24 17:15:31.326 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2023-03-24 17:15:31.327 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                            2023-03-24 17:15:32.473 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24384
                            2023-03-24 17:15:35.563 - info: roborock.0 (24384) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                            2023-03-24 17:15:55.287 - error: roborock.0 (24384) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2023-03-24 17:15:55.288 - error: roborock.0 (24384) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:55.290 - error: roborock.0 (24384) Error: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:55.292 - error: roborock.0 (24384) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
                            2023-03-24 17:15:55.299 - info: roborock.0 (24384) terminating
                            2023-03-24 17:15:55.301 - warn: roborock.0 (24384) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2023-03-24 17:15:55.944 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2023-03-24 17:15:55.945 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                            2023-03-24 17:15:55.945 - warn: host.raspberrypi Do not restart adapter system.adapter.roborock.0 because restart loop detected
                            • D DonToben
                              @copystring
                              copystringC Offline
                              copystringC Offline
                              copystring
                              #501
                              @dontoben ich weiß nicht was ich da machen kann. Deine dns Auflösung funktioniert nicht.
                              • M Menfis
                                copystringC Offline
                                copystringC Offline
                                copystring
                                #502
                                @menfis tu mir einen Gefallen und mach bitte eine issue auf GitHub. Ist sonst ein bisschen durcheinander hier Forum. Dann kann ich mir das genauer angucken.
                                • copystringC copystring
                                  DonToben
                                  #503
                                  @copystring said in Roborock Adapter tester gesucht:
                                  Ist halt blöd, dass der Adapter angehalten wird, wenn die Internetverbindung eine gewisse Zeit nicht vorhanden ist.
                                  Muss das mal beobachten. Das Problem hat nur der Roborock Adapter. Kann man das im iobroker irgendwo deaktivieren?
                                  • D DonToben
                                    copystringC Offline
                                    copystringC Offline
                                    copystring
                                    #504
                                    @dontoben ach so. Jetzt weiß ich was du meinst. Ja, dann musst euch das irgendwie abfangen. Wäre Klasse, wenn du dafür ein issue auf GitHub öffnen würdest, damit das nicht untergeht. Ich muss dann Mal schauen wie ich Zeit dafür finden kann.
                                    • wendy2702W Offline
                                      wendy2702W Offline
                                      #505
                                      Habe gerade mal wegen einem anderen Thema mein Log durchgesehen und bin auf diese Meldungen gestossen: Version 0.1.6
                                      Leider nur als text da zu viele Zeichen.
                                      Soll ich ein Issue aufmachen oder ist das schon bekannt?
                                      roborock.txt
                                        roborock.txt
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #506
                                        @wendy2702 Das ist schon bekannt und in der dev bereits behoben. Ich brauche noch ein bisschen Zeit für den nächsten Release weil die integrierung der Kamera vom den MaxV Robotern noch nicht geht fertig ist. ;)
                                        wendy2702W David G.D 2 Antworten Letzte Antwort
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #507
                                          @copystring OK, Danke für die Info.
                                          Dann warte ich mal auf den nächsten Release.
