  4. TEST - Adapter Fully Browser mit MQTT (0.0.11)
87 Beiträge 13 Kommentatoren 19.0k Aufrufe 22 Beobachtet
    @acgua
    Super, vielen Dank!
    Funktioniert hier einwandfrei, sauber programmiert, nur eins wird gemeldet:
    Meine den hier:
    Info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:46:53.540  - info: host.iobroker instance system.adapter.fully-mqtt.0 started with pid 290320
    2023-03-09 20:46:54.103  - debug: fully-mqtt.0 (290320) Redis Objects: Use Redis connection: 10.1.1.4:6379
    2023-03-09 20:46:54.125  - debug: fully-mqtt.0 (290320) Objects client ready ... initialize now
    2023-03-09 20:46:54.126  - debug: fully-mqtt.0 (290320) Objects create System PubSub Client
    2023-03-09 20:46:54.127  - debug: fully-mqtt.0 (290320) Objects create User PubSub Client
    2023-03-09 20:46:54.376  - debug: fully-mqtt.0 (290320) Objects client initialize lua scripts
    2023-03-09 20:46:54.381  - debug: fully-mqtt.0 (290320) Objects connected to redis: 10.1.1.4:6379
    2023-03-09 20:46:54.654  - debug: fully-mqtt.0 (290320) Redis States: Use Redis connection: 10.1.1.4:6379
    2023-03-09 20:46:54.657  - debug: fully-mqtt.0 (290320) States create System PubSub Client
    2023-03-09 20:46:54.658  - debug: fully-mqtt.0 (290320) States create User PubSub Client
    2023-03-09 20:46:54.661  - debug: fully-mqtt.0 (290320) States connected to redis: 10.1.1.4:6379
    2023-03-09 20:46:55.037  - info: fully-mqtt.0 (290320) starting. Version 0.0.1-alpha (non-npm: Acgua/ioBroker.fully-mqtt#9f946a67a951d57ba770ec08be30eedb3c0d711d) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.1, js-controller: 4.0.24
    2023-03-09 20:46:55.059  - debug: fully-mqtt.0 (290320) Final Config: {"name":"Huawei-WZDG","id":"Huawei-WZDG","ip":"10.1.1.54","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"Winston2006","lastSeen":0,"isAlive":false}
    2023-03-09 20:46:55.060  - info: fully-mqtt.0 (290320) 🗸​ Config of Huawei-WZDG (10.1.1.54) successfully verified.
    2023-03-09 20:46:55.061  - debug: fully-mqtt.0 (290320) Adapter settings successfully verified and initialized.
    2023-03-09 20:46:55.067  - debug: fully-mqtt.0 (290320) Start main() - Huawei-WZDG (10.1.1.54)…
    2023-03-09 20:46:55.068  - info: fully-mqtt.0 (290320) [MQTT]🚀​ Server started and listening on port 1888
    2023-03-09 20:46:59.959  - debug: fully-mqtt.0 (290320) [MQTT] client.conn.remoteAddress = "::ffff:10.1.1.54" - Huawei-WZDG
    2023-03-09 20:46:59.961  - info: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG (10.1.1.54) trys to authenticate...
    2023-03-09 20:46:59.961  - info: fully-mqtt.0 (290320) [MQTT]🔑​ Client Huawei-WZDG (10.1.1.54) authenticated successfully.
    2023-03-09 20:46:59.963  - info: fully-mqtt.0 (290320) [MQTT] Huawei-WZDG is alive.
    2023-03-09 20:46:59.964  - debug: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG (10.1.1.54) connected to broker a621d092-8b12-4b18-b371-f5bbb3e5d489
    2023-03-09 20:46:59.964  - info: fully-mqtt.0 (290320) [MQTT]🔗​ Client Huawei-WZDG (10.1.1.54) successfully connected.
    2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG = Huawei-WZDG = 10.1.1.54
    2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT] Huawei-WZDG: Creating info objects (if not yet existing)
    2023-03-09 20:47:00.167  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:47:33.794  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:47:33.804  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:48:19.617  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:48:19.627  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:49:00.217  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:49:00.282  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:49:33.914  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:49:33.922  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:50:19.720  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:50:19.729  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:51:00.350  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:51:00.357  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    2023-03-09 20:51:33.996  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
    2023-03-09 20:51:34.006  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
    [/s]
    AcguaA Offline
    AcguaA Offline
    Acgua
    schrieb am zuletzt editiert von Acgua
    @ilovegym said in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
    Meine den hier:
    Danke für die Rückmeldung. Hier beschrieben:
    @paul53 said in Fehler nach update js-controller 3.3.9:
    Ab Version 3.3 des js-controllers sollen keine Objekte / Arrays mehr in Datenpunkte geschrieben werden, sondern nur noch per JSON.stringify(obj) gewandelte Objekte. Diese Info-Logs sollen die Adapter-Entwickler informieren, dies anzupassen.
    Wenn die Logs stören, stelle die Log-Stufe des js-controllers in der Datei /opt/iobroker/iobroker-data/iobroker.json auf "warn" (anschließend ioBroker neu starten).
    Ich mache jetzt
    const newVal = typeof infoObj[key] === 'object' ? JSON.stringify(infoObj[key]) : infoObj[key];
    Ich verstehe zwar diese ioBroker-Einschränkung nicht wirklich, aber nun eingebaut :-)
    Bitte Adapter noch mal neu installieren von URL (https://github.com/Acgua/ioBroker.fully-mqtt) und testen.
      @acgua
      ab und zu gibts n keep alive timeout, komischerweise bei den Tablets auch, die per LAN verbunden sind.. kann ich da das Timeout irgendwo einstellen??
      2023-03-10 11:48:30.069  - warn: fully-mqtt.0 (1061251) [MQTT] Huawei-FlurOG is not alive!
      2023-03-10 11:48:30.717  - error: fully-mqtt.0 (1061251) [MQTT]🔥 Client error - keep alive timeout
      2023-03-10 11:48:30.718  - warn: fully-mqtt.0 (1061251) [MQTT] Client Huawei-FlurOG disconnected.
      2023-03-10 11:48:34.700  - info: lightcontrol.1 (1566) [ Controller ] Reaching, Group="Muellanzeige" Property="actualLux" NewVal="137.87", OldVal=137.87"
      2023-03-10 11:48:42.252  - info: fully-mqtt.0 (1061251) [MQTT] Client Huawei-FlurOG (10.1.1.56) trys to authenticate...
      2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT]🔑 Client Huawei-FlurOG (10.1.1.56) authenticated successfully.
      2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT] Huawei-FlurOG is alive.
      2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT]🔗 Client Huawei-FlurOG (10.1.1.56) successfully connected.
      Hier meine Config vom Adapter:
      oder kann man das im Fullybrowser einstellen? Hab da nix gefunden..
      AcguaA Offline
      AcguaA Offline
      Acgua
      (hier stand vorher eine andere, falsche, Antwort von mir)
      Hier hat sich tatsächlich der Client, also der Fully Browser und/oder das Tablet, verabschiedet.
      Das kann ich nicht wirklich beeinflussen mit dem Adapter.
      Kommt das öfter vor, und in welchem Abstand in Sekunden wird "is not alive" -> "is alive" angezeigt im Log (also jeweils separate Log-Zeilen), so im Durchschnitt?
      • AcguaA Acgua
        @acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
        hmm das ist komisch, denn ich komme ganz normal auf die Gui von Fullybrowser, wenn das kommt. . und dann ist er ja nach 12 Sek. auch wieder fuer den Adapter erreichbar.. hier sieht es mir nach einem timeout problem aus.. ich hab zeitgleich mal n ping durchlaufen lassen, da gibts keine breaks/interrupts und auch keine lost packets oder so..
        Was mich wundert, es sind bei der Meldung immer 12sek, dann ist er wieder erreichbar..
        naja, ich behalts mal im Auge.. denn:
        98% meiner Tablets schalten sich um 23.00 Uhr aus, und um 5 / 7 uhr morgens wieder ein, in der zwischenzeit sind die natuerlich offline.
        Auch da sollte der Adapter das abkoennen, oder das log zu zu pflastern.. kannste das vielleicht so machen, wie beim mqtt oder sonoff adapter, dass man in den Instanzen sieht, welcher client verbunden ist?
        Dann hat der Adapter noch Probleme, die Datenpunkte im '/Info directory anzulegen, das geht meist erst, wenn ich mqtt im Adapter ausschalte, dann legt er alle Datenpunkte an, schalte ich dann mqtt ein, funktionierts...
        Hab jetzt den alten Adapter geloscht, auch die Datenpunkte, neu von Git installiert, die Konfig importiert, und alles neu anlegen lassen.
        Es kommen immer noch Warnings mit
        2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.deviceId" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.longitude" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.latitude" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.version" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.versionCode" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.model" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.manufacturer" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.SDK" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.foreground" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.788  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.appStartTime" has no existing object, this might lead to an error in future versions
        2023-03-12 09:41:26.789  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.currentPageUrl" has no existing object, this might lead to an error in future versions
        AcguaA 2 Antworten Letzte Antwort
          AcguaA Offline
          AcguaA Offline
          Acgua
          @ilovegym
          Nochmals vielen Dank fürs Testen!
          Info-Datenpunkte
          Das war ein Bug, wenn mehrere Tablets konfiguriert sind und ist nun behoben auf Github, werden nun also für alle Tablets sauber angelegt.
          MQTT Keep Alive Timeout
          Ich hatte zunächst mit einem Lenovo-Tablet getestet, da kam das nie. Aber beim Testen mit einem Huawei-Tablet habe ich das auch schon mal gesehen jetzt.
          Was hier passiert: Der Aedes MQTT Server bekommt einen "client error" Event gemeldet vom Tablet.
          Aktuell wird im Adapter bei einem solchen Client Error sofort ein Error "[MQTT] Client error - ..." ausgegeben und der Status des Tablets auf "not alive" gesetzt.
          Ich überlege, hier "keep alive timeout" Error abzufangen und nicht gleich einen Error auszugeben. Meldet sich das Tablet länger nicht, geht es eh auf "not alive".
          Hab bei mir auch kurzzeitig ein "Huawei: Client error - read ECONNRESET" Error, und paar Sekunden später ist das Tablet aber wieder verbunden.
          Ich bleib dran und verbessere das mit Logausgaben und Fehler abfangen.
          Zu "welcher Client verbunden ist"
          Absolut muss ein Adapter das abkönnen :)
          Wie meinst du das mit den "in den Instanzen sehen"?
          Derzeit wird der Status für jedes Tablet über fully-mqtt.0.Tablet-Name.alive angezeigt. Zusätzlich geht die Adapter-Instanz von gelb auf grün, wenn alle Clients verbunden sind. Ist ein Client nicht verbunden -> gelb. (über fully-mqtt.0.info.connection).
            AcguaA Offline
            AcguaA Offline
            Acgua
            Du meinst sowas, oder?
            Ist jetzt drin.
            Ebenso diese MQTT-Option. Wenn aktiviert, werden die client errors etc. nur noch als Info ausgegeben. Wenn nach einer Weile (60s + 10s) der Fully sich gar nicht mehr meldet per MQTT, wird einmalig ein "[MQTT] Tablet-Name is not alive!" ausgegeben als Warn ausgegeben, mehr nicht.
            Ansonsten noch paar Fixes.
            0.0.3-alpha (2023-03-12)
            • (Acgua) Fix: various issues
            • (Acgua) Encrypt MQTT password (#11)
            • (Acgua) New: MQTT option to log client and connection errors as info and not error
            • (Acgua) New: Online status for each device is now displayed in objects: e.g. 'fully-mqtt.0.Tablet-Hallway' is green with a connection icon if it is alive
            • AcguaA Acgua
              Ist jetzt drin.
              @acgua
              guten Morgen,
              super, die Warnings sind weg, das Log sieht jetzt sehr sauber aus, in allen Konfigurationen ( also Client and Connection enabled und auch disabled), die verschiedenen Logstufen funktionieren auch.
              Was nicht geht, ist die Anzeige
              https://forum.iobroker.net/assets/uploads/files/1678650418308-28617329-ad62-4cfd-8258-3e17aced1ede-image.png
              bei mir sieht das im Chrome und Firefox so aus:
              brauchst Du ein debug-log?
              AcguaA 1 Antwort Letzte Antwort
                @acgua
                guten Morgen,
                AcguaA Offline
                AcguaA Offline
                Acgua
                Hi @ilovegym
                nein, danke, die Objekte müssen neu erstellt werden vom Adapter. D.h. am besten die Adapter-Instanz löschen und neu hinzufügen. Alternativ kannst du auch die Objekte fully-mqtt.0.FireHD-BueroBad, fully-mqtt.0.FireHD-Isa, .... und alle Objekte / Datenpunkte darunter löschen und dann die Adapter-Instanz neu starten.
                • AcguaA Acgua
                  Hi @ilovegym
                  @acgua
                  Ja, das war’s, funktioniert jetzt!
                  Dankeschön!
                    @acgua
                    Dankeschön!
                    AcguaA Offline
                    AcguaA Offline
                    Acgua
                    Kurzes Update, also neue Version. Allerdings nichts Signifikantes, aber Admin nun übersetzt (u.a. nun in Deutsch), sowie Doku vorbereitet.
                    0.0.4 (2023-03-14)
                    • (Acgua) Added all translations to admin/jsonConfig.json
                    • (Acgua) Fixed test error by removing nodejs 12 support, and added nodejs 18
                    • (Acgua) readme updated and prepared for adapter documentation
                    • (Acgua) Fixed a few issues
                    • AcguaA Acgua
                      0.0.4 (2023-03-14)
                      @acgua
                      Dankeschön, läuft ohne Auffälligkeiten!
                        @acgua
                        AcguaA Offline
                        AcguaA Offline
                        Acgua
                        Kurzes Update
                        Adapter ist mittlerweile in Version 0.0.8, aber nur diverses unter der Haube gemacht und keine neuen Features. Ich habe noch Doku in Deutsch und Englisch ergänzt und den Adapter vorbereitet für Latest Repository, also für Beta Testing. Außerdem habe ich Anträge zur Aufnahme im Latest eingereicht, sowie um Sentry hinzuzufügen, und auch Weblate für Übersetzungen.
                        Frage:
                        Fehlen noch wesentliche Funktionen oder gab es noch Fehler?
                        Was ich noch einbaue, ist eine bessere Handhabung der Geräte-Objekte. D.h. wenn ein Tablet in den Adapter-Optionen inaktiv gesetzt wird oder die Tabellenzeile in den ganz gelöscht wird, dass dann auch die Objekte, also alle Objekte von fully-mqtt.0.Tablet-Küche (und unterhalb) entfernt werden. Dabei mit einer Option "Objekte nicht löschen, wenn ein Tablet deaktiviert wird".
                        To Do and/or In Progress
                        • To Do: Delete device objects once device is deleted in adapter options
                        • To Do: Add option to delete device objects if device is deactivated
                        • In Progress: Add Adapter to Latest Repository for beta testing (requested, PR #2184)
                        • In Progress: Add Adapter to Weblate (requested, #108)
                        • In Progress: Add Sentry (requested, #213)
                        • ? Offline
                          @acgua
                          Hab gestern die 0.0.8 installiert, läuft.
                          Keine Fehler, passt.
                          Dankeschön 👍
                            ManfredHi
                            Ich bekomme keine Verbindung. Im debug-Logfile steht folgendes:
                            2023-03-21 19:50:23.331 - debug: fully-mqtt.0 (3757147) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-03-21 19:50:23.399 - debug: fully-mqtt.0 (3757147) Objects client ready ... initialize now
                            2023-03-21 19:50:23.400 - debug: fully-mqtt.0 (3757147) Objects create System PubSub Client
                            2023-03-21 19:50:23.401 - debug: fully-mqtt.0 (3757147) Objects create User PubSub Client
                            2023-03-21 19:50:23.573 - debug: fully-mqtt.0 (3757147) Objects client initialize lua scripts
                            2023-03-21 19:50:23.577 - debug: fully-mqtt.0 (3757147) Objects connected to redis: 127.0.0.1:9001
                            2023-03-21 19:50:23.643 - debug: fully-mqtt.0 (3757147) Redis States: Use Redis connection: 127.0.0.1:6379
                            2023-03-21 19:50:23.649 - debug: fully-mqtt.0 (3757147) States create System PubSub Client
                            2023-03-21 19:50:23.650 - debug: fully-mqtt.0 (3757147) States create User PubSub Client
                            2023-03-21 19:50:23.659 - debug: fully-mqtt.0 (3757147) States connected to redis: 127.0.0.1:6379
                            2023-03-21 19:50:23.811 - info: fully-mqtt.0 (3757147) starting. Version 0.0.8 (non-npm: Acgua/ioBroker.fully-mqtt#9dbcc3f09e70be6688d93d8544027aab1514a846) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.0, js-controller: 4.0.24
                            2023-03-21 19:50:23.827 - debug: fully-mqtt.0 (3757147) Final Config: {"name":"Galaxy Tab S2","id":"Galaxy_Tab_S2","ip":"192.168.0.88","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"xxxx","lastSeen":0,"isAlive":false,"timeoutRestRequestInfo":null,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restInfoKeys":[]}
                            2023-03-21 19:50:23.828 - debug: fully-mqtt.0 (3757147) Device Galaxy Tab S2 (192.168.0.88) is not enabled, so skip it.
                            2023-03-21 19:50:23.828 - error: fully-mqtt.0 (3757147) No active devices with correct configuration found.
                            2023-03-21 19:50:23.829 - error: fully-mqtt.0 (3757147) Adapter settings initialization failed. ---> Please check your adapter instance settings!
                            Im Fullybrowser ist folgendes eingestellt:
                            Der Adapter hat folgende Einstellungen:
                            Wo hab ich da den Fehler ?
                            • ? Offline
                              @manfredhi
                              Lt logfile ist das Tablett im Adapter nicht enabled, also mal Haken raus und wieder rein…
                                @manfredhi
                                ManfredHi
                                @ilovegym sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                                @manfredhi
                                Alles schon ausprobiert. Funktioniert einfach nicht. Adapter bleibt gelb und immer die gleiche Fehlermeldung im Log.
                                metaxaM 1 Antwort Letzte Antwort
                                • M ManfredHi
                                  @manfredhi
                                  metaxaM Offline
                                  metaxaM Offline
                                  metaxa
                                  schrieb am zuletzt editiert von metaxa
                                  @acgua & @manfredhi ich schließe mich an, bei mir exakt das gleiche Fehlerbild.
                                  fully-mqtt.0
                                  3405440	2023-03-21 23:26:16.730	error	Adapter settings initialization failed. ---> Please check your adapter instance settings!
                                  fully-mqtt.0
                                  3405440	2023-03-21 23:26:16.727	error	No active devices with correct configuration found.
                                  fully-mqtt.0
                                  3405440	2023-03-21 23:26:16.726	debug	Device Tab3_Bad (192.168.0.121) is not enabled, so skip it.
                                  fully-mqtt.0
                                  3405440	2023-03-21 23:26:16.723	debug	Final Config: {"name":"Tab3_Bad","id":"Tab3_Bad","ip":"192.168.0.121","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"xxxxxxx","lastSeen":0,"isAlive":false,"timeoutRestRequestInfo":null,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restInfoKeys":[]}
                                  fully-mqtt.0
                                  3405440	2023-03-21 23:26:16.655	info	starting. Version 0.0.8 (non-npm: Acgua/ioBroker.fully-mqtt#9dbcc3f09e70be6688d93d8544027aab1514a846) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.1, js-controller: 4.0.24
                                  fully-mqtt.0
                                  3403847	2023-03-21 23:26:02.333	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  Hakerl schon mehrfach raus & rein und immer wieder abgespeichert. Leider nein. Tablet auch schon neu gestartet, leider keine Änderung.
                                  • metaxaM metaxa
                                    fully-mqtt.0
                                    fully-mqtt.0
                                    fully-mqtt.0
                                    fully-mqtt.0
                                    fully-mqtt.0
                                    fully-mqtt.0
                                    @metaxa @ManfredHi @Acgua
                                    den einzigsten Unterschied, den ich erkenne, ist, dass ich bei mqtt ein Username und Passwort verwende, und bei euch das nicht der Fall ist.
                                    Vielleicht ist hier im Code der Wurm drin ?
                                      metaxaM Offline
                                      metaxaM Offline
                                      metaxa
                                      @ilovegym @ManfredHi @Acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                                      Leider Nein!
                                      ? M 2 Antworten Letzte Antwort
                                      • metaxaM metaxa
                                        Leider Nein!
                                        @metaxa @Acgua
                                        da ist ein Bug in der 0.0.8, bei mir sind nach dem upgrade KEINE Haken vorne gesetzt, und es funktioniert...
                                        • metaxaM metaxa
                                          Leider Nein!
                                          ManfredHi
                                          @metaxa @ilovegym @Acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                                          Leider Nein!
                                          Bei mir genauso. Kein Unterschied ob mit username und password oder ohne, egal ob das nicht verifizieren angehakt ist oder nicht. Der Adapter bleibt auf gelb und es ist immer die gleiche FEhlermeldung im log.
