  4. Node-Red
  5. [Gelöst] Benötige Hilfe mit Node-Red in Verbindung mit homee
node-red
121 Beiträge 3 Kommentatoren 22.9k Aufrufe 4 Beobachtet
  • O Oli
    @mickym
    [{"id":268,"node_id":32,"instance":0,"minimum":0,"maximum":50,"current_value":15.3,"target_value":15.3,"last_value":15.4,"unit":"%C2%B0C","step_value":0.5,"editable":0,"type":5,"state":1,"last_changed":1678639577,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":269,"node_id":32,"instance":0,"minimum":0,"maximum":100,"current_value":42,"target_value":42,"last_value":41,"unit":"%25","step_value":1,"editable":0,"type":7,"state":1,"last_changed":1678641980,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":270,"node_id":32,"instance":0,"minimum":0,"maximum":5000,"current_value":538,"target_value":538,"last_value":537,"unit":"ppm","step_value":50,"editable":0,"type":20,"state":1,"last_changed":1678641980,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":271,"node_id":32,"instance":0,"minimum":0,"maximum":4,"current_value":4,"target_value":4,"last_value":3,"unit":"n%2Fa","step_value":1,"editable":0,"type":33,"state":1,"last_changed":1677590493,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":""},{"id":272,"node_id":32,"instance":0,"minimum":0,"maximum":1,"current_value":0,"target_value":0,"last_value":1,"unit":"n%2Fa","step_value":1,"editable":0,"type":69,"state":1,"last_changed":1666168057,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":182,"week":26,"month":6,"stepped":true}}},{"id":478,"node_id":32,"instance":0,"minimum":0,"maximum":1,"current_value":1,"target_value":1,"last_value":0,"unit":"","step_value":1,"editable":1,"type":385,"state":1,"last_changed":0,"changed_by":0,"changed_by_id":0,"based_on":0,"data":"","name":""}]
    Normalerweise sollte da 0, oder 1 da stehen für den Batteriealarm
    mickymM Offline
    mickymM Offline
    mickym
    @oli Mit dem typ 69 das mag ja sein - aber das passt nicht zu den Werten - dann würde ich lieber einen extra Wert Batteriealarm empfehlen. So kann man das jedenfalls nicht mischen. Wir können generell auf die Prozente verzichten und nur Alarm true oder false ausgeben, oder machen eben eine extra Geschichte daraus oder generell verarbeitest Du es in einem Flow - anstelle einer Tabelle.
    O 1 Antwort Letzte Antwort
    • mickymM Offline
      mickymM Offline
      mickym
      @Oli Du ich finde es gerade nicht mehr, aber wenn Du lieber mit Javascript programmierst ist doch auch OK. Dann nimm doch wieder die function Node und passe sie halt entsprechend an.
      Du musst das nicht lernen, wenn Du eh ein Javascript Programmierer bist. Es geht auch schneller in Javascript - auch wenn Du mehr codieren musst, weil Du mit JSONATA ja nochmal eine Bibliothek dazwischen hast.
      Ich unterstütze Dich da auch - aber ich habe keine Lust Code zu schreiben, aber ich denke ich kann ihn nachvollziehen. Zumindest mit der function Node ist mir das ja geglückt.
      Ich spare mir jedenfalls eine Menge - wenn Du kein JSONATA lernen willst.
      • mickymM mickym
        O Online
        O Online
        Oli
        @mickym said in Benötige Hilfe mit Node-Red in Verbindung mit homee:
        Das Problem hierbei, das einige Geräte nur den Batteriewert habe, einige nur den Batteriealarm und dann gibt es Geräte die haben beides, deshalb dachte ich, dass man abfragen kann, ob der Batteriewert existiert. Wenn dieser existiert, zählt man einen count hoch. Sollte er nicht existieren prüft man ob der Batteriealarm existiert und zählt ebenfalls einen count hoch
        Oliver
        • O Oli
          mickymM Offline
          mickymM Offline
          mickym
          @oli Ja kann man alles machen - wird aber sehr komplex dann. JSONATA ist ein descriptive Sprache und Du kannst Objekte filtern und neu zusammensetzen - aber ich hatte eigentlich keine Lust ein Programm zu schreiben. Das geht auch - aber sicher nicht auf die schnelle - und ist halt nicht so einfach wie Du das denkst - da ich die Filter nur begrenzt dynamisch aufbauen kann. Zumindest ich bin da auch noch nicht geübt genug. Ich überlege mir was - aber nicht in den nächsten Stunden.
          Das Abfragen, dass die mit type 69 noch bei der Anzahl der Batteriegeräte sind, das ist nicht das Problem - aber das zusammen in einer Tabelle zusammenzustellen schon.
          • O Oli
            mickymM Offline
            mickymM Offline
            mickym
            @oli sagte in Benötige Hilfe mit Node-Red in Verbindung mit homee:
            So die Abfragen habe ich:
                   "id": "6624873c35b06eae",
                   "type": "change",
                   "z": "9c280ddf049b2b4d",
                   "name": "Alle Batterie Geräte",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "payload[attributes[type =  8] ]",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1270,
                   "y": 3400,
                   "wires": [
                           "0c5dce5940776e17",
                           "676c2655140cea7e"
                   "id": "0c5dce5940776e17",
                   "type": "debug",
                   "name": "Geräte mit Batterie",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "payload",
                   "targetType": "msg",
                   "statusVal": "",
                   "statusType": "auto",
                   "x": 1510,
                   "y": 3340,
                   "wires": []
                   "id": "676c2655140cea7e",
                   "type": "change",
                   "name": "Anzahl",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "payload ? $count(payload) : 0",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1470,
                   "y": 3400,
                   "wires": [
                           "7cb6f5cee79a8d0b"
                   "id": "7cb6f5cee79a8d0b",
                   "type": "debug",
                   "name": "Anzahl Geräte Batterie",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1660,
                   "y": 3400,
                   "wires": []
                   "id": "ca23c275d6a0610b",
                   "type": "change",
                   "name": "Alle Batterie Geräte mit 69",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "payload[attributes[type =  8] or  attributes[type =  69]]",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1300,
                   "y": 3500,
                   "wires": [
                           "a635f8e5d7ac99cf",
                           "ce0af757e6116705"
                   "id": "a635f8e5d7ac99cf",
                   "type": "debug",
                   "name": "Geräte mit Batterie type 8 oder type 69",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1610,
                   "y": 3460,
                   "wires": []
                   "id": "ce0af757e6116705",
                   "type": "change",
                   "name": "Anzahl",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1510,
                   "y": 3500,
                   "wires": [
                           "da4725cbfd61cda4"
                   "id": "da4725cbfd61cda4",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1750,
                   "y": 3500,
                   "wires": []
                   "id": "83190417b6055b66",
                   "type": "change",
                   "name": "Alle Batterie Geräte mit type 69 ohne type 8",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "$filter(payload,function($v){$not($exists($v[attributes[type = 8]]))})[attributes[type=69]]",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1350,
                   "y": 3600,
                   "wires": [
                           "a8736ad1d187fbb3",
                           "e25d074f8f30181c"
                   "id": "a8736ad1d187fbb3",
                   "type": "change",
                   "name": "Anzahl",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1610,
                   "y": 3600,
                   "wires": [
                           "643ccdc3d84091fd"
                   "id": "643ccdc3d84091fd",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1890,
                   "y": 3600,
                   "wires": []
                   "id": "e25d074f8f30181c",
                   "type": "debug",
                   "name": "Geräte mit Batterie type 69 ohne type 8",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1720,
                   "y": 3560,
                   "wires": []
            Um die Tabelle zu machen, muss ja anders gemappt werden.
            Ist halt bissi schwierig mit den Informationen. Wenn type=69 der Batteriealarm ist, der ja dann genutzt werden soll, wenn kein battery Level vorhanden ist (also kein type 8 ) und das alles zusammen in der Tabelle auftauchen soll, gehe ich nun davon aus, das current_value = 0 (kein Alarm bedeutet) und current_value = 1 (Alarm bedeutet). Um das in die gleiche Spalte für Batterie zu bringen - übersetze ich dann 0 in 100% und 1 in 0%.
            Deine Idee
            attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]
            funktioniert - aber man muss das halt anders behandeln bei type 69 als den value. Also richtig überlegt.
            • mickymM Offline
              mickymM Offline
              mickym
              So ich denke ich habe es geschafft. ;) - Stunden später - aber das ist für mich auch immer komplexer. ;)
              So die type=69 attribute, sind nun in die Batteriespalte mit aufgenommen: Wenn der current_value eines type=69 Eintrags ist 0 (kein Alarm) wird das Batterielevel auf 100% gesetzt, anderenfalls auf 0%.
              Hier wieder zum Ausprobieren: https://try.jsonata.org/bxx5ycClY
              payload.{"name" :name,
                      "type" : cube_type,
                      "protocol" : $single($$.protocols, function($v){$v.id = protocol}).name,
                      "state" : ' <font color=\"' & $single($$.states, function($v){$v.id = state}).color & '\"> ' & $single($$.states, function($v){$v.id = state}).name,
                      "battery" : (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 8 ? attributes[type=8 ].current_value :
                      (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 69 ? attributes[type=69 ].current_value = 0 ? 100 : 0
              } ~> |$|{"battery" : $exists(battery) ? ' <font color=\"' & $filter($$.battery, function($v){battery >= $v.level})[0].color & '\"> ' & battery & " %"}|
              So hier der Flow als Tabelle 6
                     "id": "dfb85691acadb5e8",
                     "type": "change",
                     "name": "VIS Tabelle 6",
                     "rules": [
                             "t": "set",
                             "p": "protocols",
                             "pt": "msg",
                             "to": "[{\"id\":1,\"name\":\"ZWave\"},{\"id\":2,\"name\":\"Zigbee\"},{\"id\":3,\"name\":\"EnOcean\"},{\"id\":9,\"name\":\"WLan\"}]",
                             "tot": "json"
                             "t": "set",
                             "p": "states",
                             "pt": "msg",
                             "to": "[{\"id\":1,\"name\":\"aktiv\",\"color\":\"green\"},{\"id\":2,\"name\":\"inaktiv\",\"color\":\"rot\"},{\"id\":12,\"name\":\"wird aktualisiert\",\"color\":\"orange\"}]",
                             "tot": "json"
                             "t": "set",
                             "p": "battery",
                             "pt": "msg",
                             "to": "[{\"level\":30,\"color\":\"green\"},{\"level\":20,\"color\":\"yellow\"},{\"level\":15,\"color\":\"orange\"},{\"level\":0,\"color\":\"red\"}]",
                             "tot": "json"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "payload.{\"name\" :name,\t        \"type\" : cube_type,\t        \"protocol\" : $single($$.protocols, function($v){$v.id = protocol}).name,\t        \"state\" : ' <font color=\\\"' & $single($$.states, function($v){$v.id = state}).color & '\\\"> ' & $single($$.states, function($v){$v.id = state}).name,\t        \"battery\" : (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 8 ? attributes[type=8 ].current_value : \t        (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 69 ? attributes[type=69 ].current_value = 0 ? 100 : 0\t} ~> |$|{\"battery\" : $exists(battery) ? ' <font color=\\\"' & $filter($$.battery, function($v){battery >= $v.level})[0].color & '\\\"> ' & battery & \" %\"}|",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1250,
                     "y": 4100,
                     "wires": [
                             "2b7218100bc7ac23"
              Das Ergebnis ist diese Tabelle:
                  "name": "DG / Schlafzimmer / Bewegungsmelder / Kirsten",
                  "type": 2,
                  "protocol": "Zigbee",
                  "state": " <font color=\"green\"> aktiv"
                  "name": "DG / Schlafzimmer / Bewegungsmelder Oliver",
                  "type": 2,
                  "name": "DG / Schlafzimmer / Luftreiniger",
                  "type": 2,
                  "name": "DG / Schlafzimmer / Nachtlicht TV",
                  "type": 2,
                  "name": "DG / Schlafzimmer / Nachtlicht Kirsten",
                  "type": 2,
                  "name": "DG / Schlafzimmer / Schalter Nachtlicht",
                  "type": 2,
                  "name": "DG / Schlafzimmer / Nachtlicht Oliver",
                  "type": 2,
                  "name": "EG / Wohnzimmer / Heizung Balkon",
                  "type": 1,
                  "protocol": "ZWave",
                  "state": " <font color=\"green\"> aktiv",
                  "battery": " <font color=\"green\"> 55 %"
                  "name": "UG / Keller / Waschmaschine",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Multimedia",
                  "type": 1,
                  "name": "DG / Flur / Rauchmelder",
                  "type": 1,
                  "battery": " <font color=\"green\"> 98 %"
                  "name": "EG / Flur / Rauchmelder",
                  "type": 1,
                  "battery": " <font color=\"green\"> 100 %"
                  "name": "UG / Flur / Rauchmelder",
                  "type": 1,
                  "battery": " <font color=\"green\"> 76 %"
                  "name": "DG / Bad / Fenster",
                  "type": 1,
                  "battery": " <font color=\"green\"> 86 %"
                  "name": "EG / Esszimmer / Balkontüre",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Balkontüre",
                  "type": 1,
                  "battery": " <font color=\"green\"> 90 %"
                  "name": "EG / WC / Fenster",
                  "type": 1,
                  "name": "EG / Büro / Fenster Rechts",
                  "type": 1,
                  "name": "EG / Büro / Fenster Links",
                  "type": 1,
                  "name": "DG / Schlafzimmer / Rauchmelder",
                  "type": 1,
                  "battery": " <font color=\"red\"> 12 %"
                  "name": "UG / Schlafzimmer / Rauchmelder",
                  "type": 1,
                  "battery": " <font color=\"green\"> 88 %"
                  "name": "EG / Büro / Heizung",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Vitrine",
                  "type": 2,
                  "name": "DG / Flur / Vitrine Licht",
                  "type": 1,
                  "state": " <font color=\"rot\"> inaktiv"
                  "name": "EG / Wohnzimmer / Temperatur Weinkühlschrank",
                  "type": 2,
                  "name": "EG / Wohnzimmer / Heizung Links",
                  "type": 1,
                  "battery": " <font color=\"green\"> 85 %"
                  "name": "EG / Wohnzimmer / TV-Schrank",
                  "type": 2,
                  "name": "EG / Esszimmer / Heizung",
                  "type": 1,
                  "battery": " <font color=\"green\"> 95 %"
                  "name": "EG / WC / Heizung",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Weinkühlschrank",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Raumthermostat",
                  "type": 1,
                  "battery": " <font color=\"green\"> 78 %"
                  "name": "EG / Büro / Computer",
                  "type": 1,
                  "name": "EG / Küche / Kühlschrank",
                  "type": 1,
                  "name": "EG / Küche / Geschirrspüler",
                  "type": 1,
                  "name": "EG / Küche / Wassersensor",
                  "type": 1,
                  "name": "DG / Bad / Heizung",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Netatmo",
                  "type": 8,
                  "protocol": "WLan",
                  "name": "Netatmo Aussenraum",
                  "type": 8,
                  "protocol": "WLan",
                  "name": "EG / Büro / Netatmo",
                  "type": 8,
                  "protocol": "WLan",
                  "name": "DG / Schlafzimmer / Netatmo",
                  "type": 8,
                  "protocol": "WLan",
                  "name": "DG / Schlafzimmer / Klimaanlage",
                  "type": 1,
                  "name": "EG / Flur / Tablet",
                  "type": 1,
                  "name": "EG / Wohnzimmer / Stehlampe",
                  "type": 2,
                  "name": "EG / Wohnzimmer / Bar",
                  "type": 2,
                  "name": "EG / Küche / Temperatur Kühlschrank",
                  "type": 2,
              Im Moment haben alle "Nicht-" Batterie Geräte die Eigenschaft battery einfach nicht definiert. Wenn man eine Textausgabe wünscht, dann halt den Code wie folgt anpassen:
                      "type" : cube_type,
              } ~> |$|{"battery" : $exists(battery) ? ' <font color=\"' & $filter($$.battery, function($v){battery >= $v.level})[0].color & '\"> ' & battery & " %" : "Keine Batterie"}  |
              Dies erzeugt, dann für alle Geräte eine battery Eigenschaft:
                  "type": 1,
                  "battery": "Keine Batterie"
                  "type": 1,
              • mickymM mickym
                        "type" : cube_type,
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "protocols",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "states",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "battery",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1250,
                       "y": 4100,
                       "wires": [
                               "2b7218100bc7ac23"
                    "type": 2,
                    "type": 2,
                    "type": 2,
                    "type": 2,
                    "type": 2,
                    "type": 2,
                    "type": 2,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 2,
                    "type": 1,
                    "type": 2,
                    "type": 1,
                    "type": 2,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 1,
                    "type": 8,
                    "protocol": "WLan",
                    "type": 8,
                    "protocol": "WLan",
                    "type": 8,
                    "protocol": "WLan",
                    "type": 8,
                    "protocol": "WLan",
                    "type": 1,
                    "type": 1,
                    "type": 2,
                    "type": 2,
                    "type": 2,
                        "type" : cube_type,
                    "type": 1,
                    "type": 1,
                O Online
                O Online
                Oli
                schrieb am zuletzt editiert von Oli
                @mickym
                nochmals vielen Dank für deine Hilfe, hier jetzt mal der komplette Flow, sowie er jetzt aussieht
                       "id": "b8ad42061a6d5f2e",
                       "type": "tab",
                       "label": "homee Geräteliste",
                       "disabled": false,
                       "info": "",
                       "env": []
                       "id": "bc383b50669e8145",
                       "type": "junction",
                       "z": "b8ad42061a6d5f2e",
                       "x": 960,
                       "y": 660,
                       "wires": [
                               "99528e0bbb0f2491",
                               "afc0236a6dc34b6c",
                               "3baf2b45228f3514",
                               "61efee2e1293f2f8",
                               "18ed2cb5de54b4e1",
                               "8bc0a02357eaa25a",
                               "6624873c35b06eae",
                               "dfb85691acadb5e8"
                       "id": "99528e0bbb0f2491",
                       "type": "change",
                       "name": "Alle inaktiven Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[state = 2]",
                               "tot": "jsonata"
                               "t": "set",
                               "p": "homee.inactive",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1140,
                       "y": 380,
                       "wires": [
                               "79c90e3a205144c8",
                               "1a49f3e7a72eeb98"
                       "id": "79c90e3a205144c8",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 380,
                       "wires": [
                               "6636132bd627fd5a",
                               "a5ac3eaebc5a142d"
                       "id": "6636132bd627fd5a",
                       "type": "debug",
                       "name": "Anzahl inaktive Geräte",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1620,
                       "y": 320,
                       "wires": []
                       "id": "afc0236a6dc34b6c",
                       "type": "change",
                       "name": "Alle Z-Wave Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[protocol = 1]",
                               "tot": "jsonata"
                               "t": "set",
                               "p": "payload.nodes",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 520,
                       "wires": [
                               "3f5d54fa1161d7c3",
                               "fb541319f5065b26"
                       "id": "3f5d54fa1161d7c3",
                       "type": "debug",
                       "name": "Geräte mit Z-Wave",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1370,
                       "y": 460,
                       "wires": []
                       "id": "fb541319f5065b26",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 520,
                       "wires": [
                               "8b5f07919d5020d8",
                               "27bd5b6a0a11f64b"
                       "id": "8b5f07919d5020d8",
                       "type": "debug",
                       "name": "Anzahl Geräte Z-Wave",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1620,
                       "y": 460,
                       "wires": []
                       "id": "27bd5b6a0a11f64b",
                       "type": "ioBroker out",
                       "name": "Anzahl Z-Wave Geräte",
                       "topic": "0_userdata.0.System.homee.ZWave",
                       "ack": "true",
                       "autoCreate": "true",
                       "stateName": "0_userdata.0.System.homee.ZWave",
                       "role": "",
                       "payloadType": "number",
                       "readonly": "false",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1620,
                       "y": 520,
                       "wires": []
                       "id": "3baf2b45228f3514",
                       "type": "change",
                       "name": "Alle ZigBee Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[protocol = 2]",
                               "tot": "jsonata"
                               "t": "set",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 660,
                       "wires": [
                               "b0d34d08416e6c10",
                               "adb5799593bc282a"
                       "id": "b0d34d08416e6c10",
                       "type": "debug",
                       "name": "Geräte mit ZigBee",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1370,
                       "y": 600,
                       "wires": []
                       "id": "adb5799593bc282a",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 660,
                       "wires": [
                               "b553c35fe84e7ff1",
                               "a722c9c32ead9437"
                       "id": "b553c35fe84e7ff1",
                       "type": "debug",
                       "name": "Anzahl Geräte ZigBee",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1620,
                       "y": 600,
                       "wires": []
                       "id": "a722c9c32ead9437",
                       "name": "Anzahl ZigBee Geräte",
                       "topic": "0_userdata.0.System.homee.ZigBee",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.ZigBee",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1620,
                       "y": 660,
                       "wires": []
                       "id": "306e283de06793a5",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "move",
                               "p": "payload",
                               "pt": "msg",
                               "to": "device",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 380,
                       "y": 1080,
                       "wires": [
                               "3fcd14dd3eda98a3"
                       "id": "3fcd14dd3eda98a3",
                       "type": "change",
                       "name": "hole alle Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "{}",
                               "tot": "json"
                               "t": "set",
                               "pt": "msg",
                               "to": "homee.nodes",
                               "tot": "global"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 600,
                       "y": 1080,
                       "wires": [
                               "3981f0834f60fe3d"
                       "id": "3981f0834f60fe3d",
                       "type": "switch",
                       "name": "Nur wenn Gerätestatus geändert",
                       "property": "payload.nodes[id=$$.device.node.id].state = device.node.state",
                       "propertyType": "jsonata",
                       "rules": [
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 250,
                       "y": 820,
                       "wires": [
                               "84e0be29a596b9f6"
                       "id": "e565ecbc06eb639f",
                       "type": "switch",
                       "name": "verify device",
                       "property": "payload.node",
                       "propertyType": "msg",
                       "rules": [
                               "t": "nnull"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 170,
                       "y": 1080,
                       "wires": [
                               "306e283de06793a5"
                       "id": "61efee2e1293f2f8",
                       "type": "change",
                       "name": "Alle EnOcean Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[protocol = 3]",
                               "tot": "jsonata"
                               "t": "set",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1140,
                       "y": 800,
                       "wires": [
                               "6174c1fb73ccadf7",
                               "6bf0970636cc1e4a"
                       "id": "6174c1fb73ccadf7",
                       "type": "debug",
                       "name": "Geräte mit EnOcean",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1380,
                       "y": 740,
                       "wires": []
                       "id": "6bf0970636cc1e4a",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 800,
                       "wires": [
                               "ec17a4f04cc1f205",
                               "39049bb60e657627"
                       "id": "ec17a4f04cc1f205",
                       "type": "debug",
                       "name": "Anzahl Geräte EnOcean",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1630,
                       "y": 740,
                       "wires": []
                       "id": "39049bb60e657627",
                       "name": "Anzahl EnOcean Geräte",
                       "topic": "0_userdata.0.System.homee.EnOcean",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.EnOcean",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1630,
                       "y": 800,
                       "wires": []
                       "id": "18ed2cb5de54b4e1",
                       "type": "change",
                       "name": "Alle WLan Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[protocol = 9]",
                               "tot": "jsonata"
                               "t": "set",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 940,
                       "wires": [
                               "73232d6356145c91",
                               "1f89021c7a98c311"
                       "id": "73232d6356145c91",
                       "type": "debug",
                       "name": "Geräte mit WLan",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1370,
                       "y": 880,
                       "wires": []
                       "id": "1f89021c7a98c311",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 940,
                       "wires": [
                               "1294df0c49809c46",
                               "ab79ca8d13f7e817"
                       "id": "1294df0c49809c46",
                       "type": "debug",
                       "name": "Anzahl Geräte WLan",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1620,
                       "y": 880,
                       "wires": []
                       "id": "ab79ca8d13f7e817",
                       "name": "Anzahl WLan Geräte",
                       "topic": "0_userdata.0.System.homee.WLan",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.WLan",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1620,
                       "y": 940,
                       "wires": []
                       "id": "d8d565711fe0dd22",
                       "type": "link in",
                       "name": "",
                       "links": [
                           "d87f2174cf715cf2"
                       "x": 75,
                       "y": 940,
                       "wires": [
                               "e565ecbc06eb639f"
                       "id": "95b979349f1fd3f0",
                       "name": "Geräteliste",
                       "topic": "0_userdata.0.System.homee.Tabelle",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.Tabelle",
                       "role": "",
                       "payloadType": "array",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1590,
                       "y": 1220,
                       "wires": []
                       "id": "a5ac3eaebc5a142d",
                       "name": "Anzahl nicht verfügbarer Geräte",
                       "topic": "0_userdata.0.System.homee.NichtVerfügbar",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.NichtVerfügbar",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1650,
                       "y": 380,
                       "wires": []
                       "id": "1a49f3e7a72eeb98",
                       "type": "debug",
                       "name": "inaktive Geräte",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1360,
                       "y": 320,
                       "wires": []
                       "id": "33dcf435082928a3",
                       "type": "comment",
                       "name": "homee Geräteliste",
                       "info": "",
                       "x": 150,
                       "y": 80,
                       "wires": []
                       "id": "1b3e55fcd8eadc58",
                       "type": "debug",
                       "name": "VIS Tabelle",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1350,
                       "y": 1160,
                       "wires": []
                       "id": "9c7798317b60270e",
                       "type": "json",
                       "name": "Tabelle JSON",
                       "property": "payload",
                       "action": "str",
                       "pretty": false,
                       "x": 1360,
                       "y": 1220,
                       "wires": [
                               "95b979349f1fd3f0"
                       "id": "8bc0a02357eaa25a",
                       "type": "change",
                       "name": "Anzahl Alle Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 240,
                       "wires": [
                               "33eeadb2829047fd",
                               "858928dd781c86a9"
                       "id": "33eeadb2829047fd",
                       "type": "debug",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1370,
                       "y": 180,
                       "wires": []
                       "id": "858928dd781c86a9",
                       "name": "Anzahl Aller Geräte",
                       "topic": "0_userdata.0.System.homee.GeräteAnzahl",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.GeräteAnzahl",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1370,
                       "y": 240,
                       "wires": []
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 1080,
                       "wires": [
                               "0c5dce5940776e17",
                               "676c2655140cea7e"
                       "type": "debug",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1370,
                       "y": 1020,
                       "wires": []
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1330,
                       "y": 1080,
                       "wires": [
                               "7cb6f5cee79a8d0b",
                               "841edb859544f935"
                       "type": "debug",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1620,
                       "y": 1020,
                       "wires": []
                       "id": "841edb859544f935",
                       "name": "Anzahl Baterrie Geräte",
                       "topic": "0_userdata.0.System.homee.GeräteBatterie",
                       "ack": "true",
                       "stateName": "0_userdata.0.System.homee.GeräteBatterie",
                       "role": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1620,
                       "y": 1080,
                       "wires": []
                       "id": "84e0be29a596b9f6",
                       "type": "change",
                       "name": "decodeUrlComponents",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload ~> |$.nodes|{\"name\":$decodeUrlComponent(name),\t\"note\":$decodeUrlComponent(note),\t\"phonetic_name\":$decodeUrlComponent(phonetic_name)},\"attributes\"|",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 420,
                       "y": 400,
                       "wires": [
                               "8d240adaebd74c1b"
                       "id": "8d240adaebd74c1b",
                       "type": "change",
                       "name": "Alle Geräte",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload.nodes",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 530,
                       "y": 660,
                       "wires": [
                               "76924e9c23983f3d"
                       "id": "76924e9c23983f3d",
                       "type": "change",
                       "name": "Geräte ausschliessen",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload ~> $filter(function($value){$value.id in [-1] != true})",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 740,
                       "y": 660,
                       "wires": [
                               "bc383b50669e8145"
                       "id": "1e1eba7ac4087fac",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "{}",
                               "tot": "json"
                               "t": "set",
                               "pt": "msg",
                               "tot": "global"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 180,
                       "y": 400,
                       "wires": [
                               "84e0be29a596b9f6"
                       "id": "bf1c7f792a4007cf",
                       "type": "inject",
                       "name": "trigger",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "true",
                       "payloadType": "bool",
                       "x": 130,
                       "y": 180,
                       "wires": [
                               "1e1eba7ac4087fac"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "protocols",
                               "pt": "msg",
                               "to": "[{\"id\":1,\"name\":\"Z-Wave\",\"color\":\"#886fa9\"},{\"id\":2,\"name\":\"ZigBee\",\"color\":\"#ee6c1e\"},{\"id\":3,\"name\":\"EnOcean\",\"color\":\"#44abb2\"},{\"id\":9,\"name\":\"WLAN\",\"color\":\"#8f8f8f\"},{\"id\":12,\"name\":\"WLAN\",\"color\":\"#8f8f8f\"}]",
                               "tot": "json"
                               "t": "set",
                               "p": "states",
                               "pt": "msg",
                               "to": "[{\"id\":1,\"name\":\"aktiv\",\"color\":\"green\"},{\"id\":2,\"name\":\"inaktiv\",\"color\":\"red\"},{\"id\":12,\"name\":\"wird aktualisiert\",\"color\":\"orange\"}]",
                               "tot": "json"
                               "t": "set",
                               "p": "battery",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload.{\"name\" :name,\t        \"type\" : note,\t        \"protocol\" : ' <font color=\\\"' & $single($$.protocols, function($v){$v.id = protocol}).color & '\\\"> ' & $single($$.protocols, function($v){$v.id = protocol}).name,\t        \"state\" : ' <font color=\\\"' & $single($$.states, function($v){$v.id = state}).color & '\\\"> ' & $single($$.states, function($v){$v.id = state}).name,\t        \"battery\" : (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 8 ? attributes[type=8 ].current_value : \t        (attributes[type=8 ] ? attributes[type=8 ] : attributes[type=69 ]).type = 69 ? attributes[type=69 ].current_value = 0 ? 100 : 0\t} ~> |$|{\"battery\" : $exists(battery) ? ' <font color=\\\"' & $filter($$.battery, function($v){battery >= $v.level})[0].color & '\\\"> ' & battery & \" %\" : \"Keine Batterie\"}|",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1110,
                       "y": 1220,
                       "wires": [
                               "9c7798317b60270e",
                               "1b3e55fcd8eadc58"
                Ein paar Sachen sind aber noch unklar
                1. Bei mir werden die Batteriewerte nicht mehr abgefragt, um den Fehler einzugrenzen, habe ich mal einen extra Flow gebaut und etwas gespielt
                       "id": "c507c28e5ed6a166",
                       "type": "tab",
                       "label": "Flow 2",
                       "disabled": false,
                       "info": "",
                       "env": []
                       "id": "208825e13d14540f",
                       "type": "change",
                       "z": "c507c28e5ed6a166",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 480,
                       "y": 160,
                       "wires": [
                               "0076bb0c1e2fd9bc"
                       "id": "0076bb0c1e2fd9bc",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 690,
                       "y": 160,
                       "wires": [
                               "1ae07a0e011d9194"
                       "id": "1ae07a0e011d9194",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 900,
                       "y": 160,
                       "wires": [
                               "abed858e371852a5"
                       "id": "9f4ebda01b1eec38",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "{}",
                               "tot": "json"
                               "t": "set",
                               "pt": "msg",
                               "tot": "global"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 280,
                       "y": 160,
                       "wires": [
                               "208825e13d14540f"
                       "id": "1edb395448d6c77b",
                       "type": "inject",
                       "name": "trigger",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "true",
                       "x": 130,
                       "y": 160,
                       "wires": [
                               "9f4ebda01b1eec38"
                       "id": "abed858e371852a5",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload[attributes[type =  8]]",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1130,
                       "y": 160,
                       "wires": [
                               "6c6e91e9d10ad002"
                       "id": "6c6e91e9d10ad002",
                       "type": "change",
                       "name": "Anzahl",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1310,
                       "y": 160,
                       "wires": [
                               "f4714e42703b6af2"
                       "id": "f4714e42703b6af2",
                       "type": "debug",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1500,
                       "y": 160,
                       "wires": []
                       "id": "ebeb0ab972189145",
                       "type": "function",
                       "name": "Abfrage Batterie",
                       "func": "const attributes = global.get('homee.attributes');\nconst nodes = global.get('homee.nodes');\nvar batterie = 0;\n\nvar test = attributes.filter(attribute => ((attribute.type === 8) || (attribute.type === 69)))\n\ntest.forEach(function (attribute){\n    if (attribute.type === 8) {\n        batterie ++\n    } \n})\n\nreturn {\n    \"payload\": batterie\n}\n\n",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 360,
                       "y": 280,
                       "wires": [
                               "d5179d2b54717b77"
                       "id": "d5179d2b54717b77",
                       "type": "debug",
                       "name": "debug 5",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "false",
                       "statusVal": "",
                       "x": 620,
                       "y": 280,
                       "wires": []
                       "id": "6bfceebfb28b5d8f",
                       "type": "inject",
                       "name": "trigger",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "true",
                       "x": 130,
                       "y": 280,
                       "wires": [
                               "ebeb0ab972189145"
                Dabei ist mir aufgefallen, dass in der Funktions Node folgendes Global geladen wird:
                Es wird zwar im oberen Flow die "nodes" geladen, aber die "attributes" habe ich nicht gefunden, kann darin der Fehler liegen?
                1. Was ist der Unterschied "hole alle Geräte" und "Alle Geräte"? Nach meiner Ansicht machen die beide das Gleiche und man könnte "Alle Geräte" herausnehmen
                Oliver
                • O Oli
                  @mickym
                         "type": "tab",
                         "disabled": false,
                         "info": "",
                         "env": []
                         "type": "junction",
                         "x": 960,
                         "y": 660,
                         "wires": [
                                 "99528e0bbb0f2491",
                                 "afc0236a6dc34b6c",
                                 "3baf2b45228f3514",
                                 "61efee2e1293f2f8",
                                 "18ed2cb5de54b4e1",
                                 "8bc0a02357eaa25a",
                                 "6624873c35b06eae",
                                 "dfb85691acadb5e8"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1140,
                         "y": 380,
                         "wires": [
                                 "79c90e3a205144c8",
                                 "1a49f3e7a72eeb98"
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 380,
                         "wires": [
                                 "6636132bd627fd5a",
                                 "a5ac3eaebc5a142d"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1620,
                         "y": 320,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 520,
                         "wires": [
                                 "3f5d54fa1161d7c3",
                                 "fb541319f5065b26"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1370,
                         "y": 460,
                         "wires": []
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 520,
                         "wires": [
                                 "8b5f07919d5020d8",
                                 "27bd5b6a0a11f64b"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1620,
                         "y": 460,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1620,
                         "y": 520,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 660,
                         "wires": [
                                 "b0d34d08416e6c10",
                                 "adb5799593bc282a"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1370,
                         "y": 600,
                         "wires": []
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 660,
                         "wires": [
                                 "b553c35fe84e7ff1",
                                 "a722c9c32ead9437"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1620,
                         "y": 600,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1620,
                         "y": 660,
                         "wires": []
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "move",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "device",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 380,
                         "y": 1080,
                         "wires": [
                                 "3fcd14dd3eda98a3"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "{}",
                                 "tot": "json"
                                 "t": "set",
                                 "pt": "msg",
                                 "tot": "global"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 600,
                         "y": 1080,
                         "wires": [
                                 "3981f0834f60fe3d"
                         "type": "switch",
                         "rules": [
                                 "t": "false"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 250,
                         "y": 820,
                         "wires": [
                                 "84e0be29a596b9f6"
                         "type": "switch",
                         "rules": [
                                 "t": "nnull"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 170,
                         "y": 1080,
                         "wires": [
                                 "306e283de06793a5"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1140,
                         "y": 800,
                         "wires": [
                                 "6174c1fb73ccadf7",
                                 "6bf0970636cc1e4a"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1380,
                         "y": 740,
                         "wires": []
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 800,
                         "wires": [
                                 "ec17a4f04cc1f205",
                                 "39049bb60e657627"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1630,
                         "y": 740,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1630,
                         "y": 800,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 940,
                         "wires": [
                                 "73232d6356145c91",
                                 "1f89021c7a98c311"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1370,
                         "y": 880,
                         "wires": []
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 940,
                         "wires": [
                                 "1294df0c49809c46",
                                 "ab79ca8d13f7e817"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1620,
                         "y": 880,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1620,
                         "y": 940,
                         "wires": []
                         "type": "link in",
                         "name": "",
                         "links": [
                             "d87f2174cf715cf2"
                         "x": 75,
                         "y": 940,
                         "wires": [
                                 "e565ecbc06eb639f"
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1590,
                         "y": 1220,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1650,
                         "y": 380,
                         "wires": []
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1360,
                         "y": 320,
                         "wires": []
                         "type": "comment",
                         "info": "",
                         "x": 150,
                         "y": 80,
                         "wires": []
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1350,
                         "y": 1160,
                         "wires": []
                         "type": "json",
                         "action": "str",
                         "pretty": false,
                         "x": 1360,
                         "y": 1220,
                         "wires": [
                                 "95b979349f1fd3f0"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 240,
                         "wires": [
                                 "33eeadb2829047fd",
                                 "858928dd781c86a9"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1370,
                         "y": 180,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1370,
                         "y": 240,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 1080,
                         "wires": [
                                 "0c5dce5940776e17",
                                 "676c2655140cea7e"
                         "type": "debug",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1370,
                         "y": 1020,
                         "wires": []
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 1080,
                         "wires": [
                                 "7cb6f5cee79a8d0b",
                                 "841edb859544f935"
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1620,
                         "y": 1020,
                         "wires": []
                         "ack": "true",
                         "role": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1620,
                         "y": 1080,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 420,
                         "y": 400,
                         "wires": [
                                 "8d240adaebd74c1b"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 530,
                         "y": 660,
                         "wires": [
                                 "76924e9c23983f3d"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 740,
                         "y": 660,
                         "wires": [
                                 "bc383b50669e8145"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "{}",
                                 "tot": "json"
                                 "t": "set",
                                 "pt": "msg",
                                 "tot": "global"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 180,
                         "y": 400,
                         "wires": [
                                 "84e0be29a596b9f6"
                         "type": "inject",
                         "name": "trigger",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "true",
                         "x": 130,
                         "y": 180,
                         "wires": [
                                 "1e1eba7ac4087fac"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "protocols",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "states",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "battery",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1110,
                         "y": 1220,
                         "wires": [
                                 "9c7798317b60270e",
                                 "1b3e55fcd8eadc58"
                         "type": "tab",
                         "label": "Flow 2",
                         "disabled": false,
                         "info": "",
                         "env": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 480,
                         "y": 160,
                         "wires": [
                                 "0076bb0c1e2fd9bc"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 690,
                         "y": 160,
                         "wires": [
                                 "1ae07a0e011d9194"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 900,
                         "y": 160,
                         "wires": [
                                 "abed858e371852a5"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "{}",
                                 "tot": "json"
                                 "t": "set",
                                 "pt": "msg",
                                 "tot": "global"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 280,
                         "y": 160,
                         "wires": [
                                 "208825e13d14540f"
                         "type": "inject",
                         "name": "trigger",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "true",
                         "x": 130,
                         "y": 160,
                         "wires": [
                                 "9f4ebda01b1eec38"
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 160,
                         "wires": [
                                 "6c6e91e9d10ad002"
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1310,
                         "y": 160,
                         "wires": [
                                 "f4714e42703b6af2"
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1500,
                         "y": 160,
                         "wires": []
                         "type": "function",
                         "outputs": 1,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 360,
                         "y": 280,
                         "wires": [
                                 "d5179d2b54717b77"
                         "type": "debug",
                         "name": "debug 5",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 620,
                         "y": 280,
                         "wires": []
                         "type": "inject",
                         "name": "trigger",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "true",
                         "x": 130,
                         "y": 280,
                         "wires": [
                                 "ebeb0ab972189145"
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #66
                  @oli
                  zu 1.
                  Nun Du musst halt schauen, was im Kontext steht. Meines Erachtens macht es keinen Sinn, die Attribute von den Nodes zu trennen, d.h. Du musst halt schauen, dass die Nodes im globalen Kontext ihre Attribute behalten. Falls die Indizes identisch sind, dann machen wir die Trennung wieder rückgängig. Sinnvoll ist es aber die Attribute bei den Nodes zu belassen, so wie Du es mir als Datei mit allen Geräten zur Verfügung gestellt hast.
                  Wie gesagt ich würde das Trennen an der Quelle unterbinden. Da musst halt suchen, wo der globale Kontext geschrieben wird.
                  zu 2.
                  Na weglassen kannst erst mal nichts - die Nodes machen ja was.
                  aber Du hast Recht ich habe und musst mich ja nach den Daten richten, die Du mir zur Verfügung gestellt und waren Deine Geräte unter Deiner Eigenschaft Nodes. ;)
                  deshalb habe ich das Ganze auch wieder unter Node gemacht. Anschliessend habe ich das Array auf die payload Ebene gehoben, weil diese Node Eigenschaft keinen Sinn macht.
                  Natürlich hätte ich die Nodes auch gleich auf die payload Ebene heben können.
                  Dann kannst die Node Dir die Node "Alle Geräte sparen".
                  Dann musst aber in der Folgenode den Pfad auf $ ändern:
                  Mir ist das egal - Du musst halt dafür sorgen, dass die Attribute bei den Geräten bleiben, sowie Du mir die Daten zur Verfügung gestellt hast. Dafür musst Du halt sorgen.
                  Sprich Du musst dafür sorgen, dass egal wo im globalen Kontext, die den zu den Nodes(Geräten) zugehörigen Eigenschaften auch erhalten bleiben und nicht getrennt werden.
                  O 2 Antworten Letzte Antwort
                  • mickymM mickym
                    @oli
                    zu 1.
                    zu 2.
                    O Online
                    O Online
                    Oli
                    #67
                    @mickym
                    sorry, kaum sucht man 3 Stunden, hat man den Fehler auch gefunden
                    Da war noch der Filter auf die Attribute drin
                    Jetzt laufen beide Flows optimal, nochmals danke für deine Geduld und Hilfe 👍
                    Oliver
                    • mickymM mickym
                      @oli
                      zu 1.
                      zu 2.
                      O Online
                      O Online
                      Oli
                      #68
                      @mickym
                      Sorry, jetzt habe ich doch noch eine Frage, wie kann ich in Node Red rechnen?
                      Geräte Gesamt - Geräte Batterie = Geräte Strom
                      Oliver
                      mickymM 3 Antworten Letzte Antwort
                      • O Oli
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #69
                        • O Oli
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #70
                          @oli In dem speziellen Fall brauchst aber auch nicht rechnen, sondern kannst die Anzahl auch direkt aus der Tabelle ermitteln.
                          Wenn Du die Version genommen hast, dass die stromgebundenen Geräte kein battery Attribut haben - dann einfach Deine Tabelle analysieren - dann musst Du nichts speichern.
                                 "id": "7a511c39fa34881f",
                                 "type": "change",
                                 "name": "Analysiere Tabelle",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "{\t   \"alle Geräte\": $count(payload),\t   \"stromgebundene Geräte\" : $count(payload) - $count(payload[battery]),\t   \"batteriegebundene Geräte\" : $count(payload[battery])\t}",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1450,
                                 "y": 4180,
                                 "wires": [
                                         "9d6c1a64d4757373"
                                 "id": "9d6c1a64d4757373",
                                 "type": "debug",
                                 "name": "Statistik",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1660,
                                 "y": 4180,
                                 "wires": []
                             "alle Geräte": $count(payload),
                             "stromgebundene Geräte" : $count(payload) - $count(payload[battery]),
                             "batteriegebundene Geräte" : $count(payload[battery])
                          • O Oli
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #71
                            @mickym
                            Im Prinzip kannst Du Dir ganzen Abfragen oben sparen, wenn Du die originalen Objekten in keinem Flow mehr brauchst. Du brauchst doch nur Deine Tabelle wieder rückwärts zu analysieren:
                            In der ChangeNode ("Anaylisiere Tabelle") fragst Du halt einfach Deine Tabelle ab - dann kannst Du dir den kompletten anderen Rest sparen
                            Sprich Dein gesamter Flow - lässt sich wie folgt reduzieren:
                                    "id": "43da9c222d7086f2",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "payload ~> |$.nodes|{\"name\":$decodeUrlComponent(name),\t\"note\":$decodeUrlComponent(note),\t\"phonetic_name\":$decodeUrlComponent(phonetic_name)}|",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 840,
                                    "y": 3180,
                                    "wires": [
                                            "1e48720df6900f86"
                                    "id": "1e48720df6900f86",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1050,
                                    "y": 3180,
                                    "wires": [
                                            "2cea4e8be5a4069e"
                                    "id": "2cea4e8be5a4069e",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1260,
                                    "y": 3180,
                                    "wires": [
                                            "36b53e3276c727d9"
                                    "id": "c6b56326d0c8cdc9",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "{}",
                                            "tot": "json"
                                            "t": "set",
                                            "pt": "msg",
                                            "tot": "global"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 600,
                                    "y": 3180,
                                    "wires": [
                                            "43da9c222d7086f2"
                                    "id": "8d512f0feef390b1",
                                    "type": "inject",
                                    "name": "trigger",
                                    "props": [
                                            "p": "payload"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "true",
                                    "x": 430,
                                    "y": 3180,
                                    "wires": [
                                            "c6b56326d0c8cdc9"
                                    "id": "dfd67d5090a5ee3c",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "move",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "device",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 700,
                                    "y": 3280,
                                    "wires": [
                                            "40ce65fe6c573d84"
                                    "id": "40ce65fe6c573d84",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "{}",
                                            "tot": "json"
                                            "t": "set",
                                            "pt": "msg",
                                            "tot": "global"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 920,
                                    "y": 3280,
                                    "wires": [
                                            "8d51d3dcf40934ba"
                                    "id": "8d51d3dcf40934ba",
                                    "type": "switch",
                                    "rules": [
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 1170,
                                    "y": 3280,
                                    "wires": [
                                            "43da9c222d7086f2"
                                    "id": "ce392b92472130c0",
                                    "type": "switch",
                                    "rules": [
                                            "t": "nnull"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 490,
                                    "y": 3280,
                                    "wires": [
                                            "dfd67d5090a5ee3c"
                                    "id": "5af35c4e9a5c92c8",
                                    "type": "link in",
                                    "name": "",
                                    "links": [
                                        "d87f2174cf715cf2"
                                    "x": 355,
                                    "y": 3280,
                                    "wires": [
                                            "ce392b92472130c0"
                                    "id": "36b53e3276c727d9",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "protocols",
                                            "pt": "msg",
                                            "tot": "json"
                                            "t": "set",
                                            "p": "states",
                                            "pt": "msg",
                                            "tot": "json"
                                            "t": "set",
                                            "p": "battery",
                                            "pt": "msg",
                                            "tot": "json"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1490,
                                    "y": 3180,
                                    "wires": [
                                            "39141a4dea9b6dfe",
                                            "be5b77b1fa74bc57"
                                    "id": "39141a4dea9b6dfe",
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1690,
                                    "y": 3180,
                                    "wires": []
                                    "id": "be5b77b1fa74bc57",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "{\t   \"alle Geräte\": $count(payload),\t   \"stromgebundene Geräte\" : $count(payload) - $count(payload[battery]),\t   \"batteriegebundene Geräte\" : $count(payload[battery]),\t   \"aktive Geräte\" : $count(payload[$contains(state, \" aktiv\")]),\t   \"inaktive Geräte\" : $count(payload[$contains(state, \" inaktiv\")]),\t   \"aktualisierende Geräte\" : $count(payload[$contains(state, \" wird aktualisiert\")]),\t   \"Protokolle\" : {\t       \"ZWave\" : $count(payload[protocol = \"ZWave\"]),\t       \"Zigbee\" : $count(payload[protocol = \"Zigbee\"]),\t       \"EnOcean\" : $count(payload[protocol = \"EnOcean\"]),\t       \"WLan\": $count(payload[protocol = \"WLan\"]) \t   }\t}",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1690,
                                    "y": 3260,
                                    "wires": [
                                            "f889528021dc2fb8"
                                    "id": "f889528021dc2fb8",
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1900,
                                    "y": 3260,
                                    "wires": []
                            Wie gesagt das meiste diente zur Demonstration und dass Du damit üben kannst.
                            Eleganter und vielseitiger ist aber natürlich die Analyse der Objekte direkt.
                            In diesem Fall greift man bei der Analyse auf die originalen Objekte und Eigenschaften zurück:
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 840,
                                   "y": 3180,
                                   "wires": [
                                           "1e48720df6900f86"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1050,
                                   "y": 3180,
                                   "wires": [
                                           "2cea4e8be5a4069e"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1260,
                                   "y": 3180,
                                   "wires": [
                                           "36b53e3276c727d9",
                                           "64292bbbaf8bfe9f",
                                           "0491ed58a98c8bdf"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "{}",
                                           "tot": "json"
                                           "t": "set",
                                           "pt": "msg",
                                           "tot": "global"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 600,
                                   "y": 3180,
                                   "wires": [
                                           "43da9c222d7086f2"
                                   "type": "inject",
                                   "name": "trigger",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "true",
                                   "x": 430,
                                   "y": 3180,
                                   "wires": [
                                           "c6b56326d0c8cdc9"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "device",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 700,
                                   "y": 3280,
                                   "wires": [
                                           "40ce65fe6c573d84"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "{}",
                                           "tot": "json"
                                           "t": "set",
                                           "pt": "msg",
                                           "tot": "global"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 920,
                                   "y": 3280,
                                   "wires": [
                                           "8d51d3dcf40934ba"
                                   "type": "switch",
                                   "rules": [
                                           "t": "false"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 1,
                                   "x": 1170,
                                   "y": 3280,
                                   "wires": [
                                           "43da9c222d7086f2"
                                   "type": "switch",
                                   "rules": [
                                           "t": "nnull"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 1,
                                   "x": 490,
                                   "y": 3280,
                                   "wires": [
                                           "dfd67d5090a5ee3c"
                                   "type": "link in",
                                   "name": "",
                                   "links": [
                                       "d87f2174cf715cf2"
                                   "x": 355,
                                   "y": 3280,
                                   "wires": [
                                           "ce392b92472130c0"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "protocols",
                                           "pt": "msg",
                                           "tot": "json"
                                           "t": "set",
                                           "p": "states",
                                           "pt": "msg",
                                           "tot": "json"
                                           "t": "set",
                                           "p": "battery",
                                           "pt": "msg",
                                           "tot": "json"
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1490,
                                   "y": 3180,
                                   "wires": [
                                           "39141a4dea9b6dfe",
                                           "be5b77b1fa74bc57"
                                   "type": "debug",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1690,
                                   "y": 3180,
                                   "wires": []
                                   "type": "change",
                                   "d": true,
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1690,
                                   "y": 3240,
                                   "wires": [
                                           "f889528021dc2fb8"
                                   "type": "debug",
                                   "d": true,
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1900,
                                   "y": 3240,
                                   "wires": []
                                   "id": "64292bbbaf8bfe9f",
                                   "type": "change",
                                   "name": "Analysiere Objekte",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "{\t   \"alle Geräte\": $count(payload),\t   \"stromgebundene Geräte\" : $count(payload) - $count(payload[attributes[type =  8] or  attributes[type =  69]]),\t   \"batteriegebundene Geräte\" : $count(payload[attributes[type =  8] or  attributes[type =  69]]),\t   \"aktive Geräte\" : $count(payload[state = 1]),\t   \"inaktive Geräte\" : $count(payload[state = 2]),\t   \"aktualisierende Geräte\" : $count(payload[state = 12]),\t   \"Protokolle\" : {\t       \"ZWave\" : $count(payload[protocol = 1]),\t       \"Zigbee\" : $count(payload[protocol = 2]),\t       \"EnOcean\" : $count(payload[protocol = 3]),\t       \"WLan\": $count(payload[protocol = 9]) \t   }\t}",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1510,
                                   "y": 3300,
                                   "wires": [
                                           "87c117cf7391af3e"
                                   "id": "87c117cf7391af3e",
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1720,
                                   "y": 3300,
                                   "wires": []
                                   "id": "0491ed58a98c8bdf",
                                   "type": "debug",
                                   "name": "all",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1490,
                                   "y": 3120,
                                   "wires": []
                            Aber nochmal - wenn Du lieber codieren und JS schreiben willst, dann mach das ruhig, ich will Dich nicht dazu überreden JSONATA zu nutzen:
                            Dann mach es wie in der function Node:
                            var batterie = 0;
                                    batterie ++
                            return {
                                "payload": batterie
                            Du kannst gerne weiter in Schleifen zählen, wenn Dir das mehr liegt. Wobei ich es nicht ganz verstehe. Wenn Du eh ein Array ausfilterst mit attribute.type= 8 oder 69, warum Du dann nicht einfach die Anzahl der Elemente in dem Array als Anzahl batteriebetriebener Geräte nimmst.
                            Wäre es dann nicht sinnvoller 2 Arrays zu bilden?
                            Ich habe mal eine Javascript Code geschrieben, weil Dir das ja lieber ist. Aber wie gesagt ich verstehe diese Schleifen nicht:
                            • mickymM mickym
                              @mickym
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 840,
                                      "y": 3180,
                                      "wires": [
                                              "1e48720df6900f86"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 1050,
                                      "y": 3180,
                                      "wires": [
                                              "2cea4e8be5a4069e"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 1260,
                                      "y": 3180,
                                      "wires": [
                                              "36b53e3276c727d9"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "{}",
                                              "tot": "json"
                                              "t": "set",
                                              "pt": "msg",
                                              "tot": "global"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 600,
                                      "y": 3180,
                                      "wires": [
                                              "43da9c222d7086f2"
                                      "type": "inject",
                                      "name": "trigger",
                                      "props": [
                                              "p": "payload"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "payload": "true",
                                      "x": 430,
                                      "y": 3180,
                                      "wires": [
                                              "c6b56326d0c8cdc9"
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "move",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "device",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 700,
                                      "y": 3280,
                                      "wires": [
                                              "40ce65fe6c573d84"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "{}",
                                              "tot": "json"
                                              "t": "set",
                                              "pt": "msg",
                                              "tot": "global"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 920,
                                      "y": 3280,
                                      "wires": [
                                              "8d51d3dcf40934ba"
                                      "type": "switch",
                                      "rules": [
                                              "t": "false"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 1,
                                      "x": 1170,
                                      "y": 3280,
                                      "wires": [
                                              "43da9c222d7086f2"
                                      "type": "switch",
                                      "rules": [
                                              "t": "nnull"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 1,
                                      "x": 490,
                                      "y": 3280,
                                      "wires": [
                                              "dfd67d5090a5ee3c"
                                      "type": "link in",
                                      "name": "",
                                      "links": [
                                          "d87f2174cf715cf2"
                                      "x": 355,
                                      "y": 3280,
                                      "wires": [
                                              "ce392b92472130c0"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "protocols",
                                              "pt": "msg",
                                              "tot": "json"
                                              "t": "set",
                                              "p": "states",
                                              "pt": "msg",
                                              "tot": "json"
                                              "t": "set",
                                              "p": "battery",
                                              "pt": "msg",
                                              "tot": "json"
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 1490,
                                      "y": 3180,
                                      "wires": [
                                              "39141a4dea9b6dfe",
                                              "be5b77b1fa74bc57"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1690,
                                      "y": 3180,
                                      "wires": []
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 1690,
                                      "y": 3260,
                                      "wires": [
                                              "f889528021dc2fb8"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1900,
                                      "y": 3260,
                                      "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 840,
                                     "y": 3180,
                                     "wires": [
                                             "1e48720df6900f86"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1050,
                                     "y": 3180,
                                     "wires": [
                                             "2cea4e8be5a4069e"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1260,
                                     "y": 3180,
                                     "wires": [
                                             "36b53e3276c727d9",
                                             "64292bbbaf8bfe9f",
                                             "0491ed58a98c8bdf"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "{}",
                                             "tot": "json"
                                             "t": "set",
                                             "pt": "msg",
                                             "tot": "global"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 600,
                                     "y": 3180,
                                     "wires": [
                                             "43da9c222d7086f2"
                                     "type": "inject",
                                     "name": "trigger",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "true",
                                     "x": 430,
                                     "y": 3180,
                                     "wires": [
                                             "c6b56326d0c8cdc9"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "move",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "device",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 700,
                                     "y": 3280,
                                     "wires": [
                                             "40ce65fe6c573d84"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "{}",
                                             "tot": "json"
                                             "t": "set",
                                             "pt": "msg",
                                             "tot": "global"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 920,
                                     "y": 3280,
                                     "wires": [
                                             "8d51d3dcf40934ba"
                                     "type": "switch",
                                     "rules": [
                                             "t": "false"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 1,
                                     "x": 1170,
                                     "y": 3280,
                                     "wires": [
                                             "43da9c222d7086f2"
                                     "type": "switch",
                                     "rules": [
                                             "t": "nnull"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 1,
                                     "x": 490,
                                     "y": 3280,
                                     "wires": [
                                             "dfd67d5090a5ee3c"
                                     "type": "link in",
                                     "name": "",
                                     "links": [
                                         "d87f2174cf715cf2"
                                     "x": 355,
                                     "y": 3280,
                                     "wires": [
                                             "ce392b92472130c0"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "protocols",
                                             "pt": "msg",
                                             "tot": "json"
                                             "t": "set",
                                             "p": "states",
                                             "pt": "msg",
                                             "tot": "json"
                                             "t": "set",
                                             "p": "battery",
                                             "pt": "msg",
                                             "tot": "json"
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1490,
                                     "y": 3180,
                                     "wires": [
                                             "39141a4dea9b6dfe",
                                             "be5b77b1fa74bc57"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1690,
                                     "y": 3180,
                                     "wires": []
                                     "type": "change",
                                     "d": true,
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1690,
                                     "y": 3240,
                                     "wires": [
                                             "f889528021dc2fb8"
                                     "type": "debug",
                                     "d": true,
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1900,
                                     "y": 3240,
                                     "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1510,
                                     "y": 3300,
                                     "wires": [
                                             "87c117cf7391af3e"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1720,
                                     "y": 3300,
                                     "wires": []
                                     "type": "debug",
                                     "name": "all",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1490,
                                     "y": 3120,
                                     "wires": []
                              var batterie = 0;
                                      batterie ++
                              return {
                                  "payload": batterie
                              O Online
                              O Online
                              Oli
                              #72
                              @mickym
                              ich will nur das Ergebnis in einen Datenpunkt schreiben, macht er aber wieder nicht
                              Oliver
                              • O Oli
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #73
                                @oli da hängt doch keine iobroker_out Node dran???
                                O 1 Antwort Letzte Antwort
                                • mickymM mickym
                                  O Online
                                  O Online
                                  Oli
                                  #74
                                  @mickym
                                  das ist schon richtig, aber das Ergebniss stimmt ja auch nicht mit 1
                                  Oliver
                                  • O Oli
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #75
                                    @oli Du hängst die Change Node ja auch nicht an die Tabelle - also das Objekt sondern an die JSON Node. Die enthält nur noch einen String - den man nicht analysieren kann. Insofern ist egal was Du schreibst immer 1 ist da 1 (ein String) - 0 (nämlich nichts) immer 1 ist.
                                    • mickymM mickym
                                      O Online
                                      O Online
                                      Oli
                                      #76
                                      @mickym
                                      habe ich gerade getan, mit dem Ergebnis 0
                                      Oliver
                                      • O Oli
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #77
                                        @oli Keine Ahnung mach halt mal die VIS Tabelle an, um zu sehen ob was ankommt. Bei mir geht das:
                                        Dann kommt halt da unten nichts an bei Dir.
                                        • mickymM mickym
                                          O Online
                                          O Online
                                          Oli
                                          #78
                                          @mickym
                                          Tabelle ist da
                                          Oliver
