  4. Node-Red
  5. [Gelöst] Benötige Hilfe mit Node-Red in Verbindung mit homee
node-red
121 Beiträge 3 Kommentatoren 22.8k Aufrufe 4 Beobachtet
  • O Oli
    @mickym
    erstmal danke für deine Antwort, sorry wahrscheinlich ein typischer Anfängerfehler (kopieren, versuchen zu verstehen und versuchen dieses anzupassen).
    Die homeeApi spuckt leider nur zahlen und kryptische Wörter aus, hier mal ein Beispiel eines Heizungsthermostats:
    msg.payload : Object
    object
    node: object
    profile: 3006
    image: "nodeicon_temperature"
    favorite: 0
    order: 6
    protocol: 1
    routing: 0
    state: 1
    state_changed: 1678443567
    added: 1571490280
    history: 0
    cube_type: 1
    note: "%23%20EUROtronic%20Spirit%20Z-Wave%20Plus"
    services: 7
    phonetic_name: "Heizung%20Toilette"
    owner: 1
    security: 0
    attributes: array[15]
    [0 … 9]
    0: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 0
    current_value: 0
    target_value: 0
    last_value: 0
    unit: "text"
    step_value: 1
    editable: 0
    type: 44
    state: 1
    last_changed: 1571490280
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: "4.61"
    1: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 0
    current_value: 0
    target_value: 0
    last_value: 0
    unit: "text"
    step_value: 1
    editable: 0
    type: 45
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: "0.16"
    2: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 1
    current_value: 0
    target_value: 0
    last_value: 0
    unit: ""
    step_value: 1
    editable: 1
    type: 91
    state: 1
    last_changed: 1583340481
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    3: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 100
    current_value: 35
    target_value: 35
    last_value: 37
    unit: "%25"
    step_value: 1
    editable: 0
    type: 18
    state: 1
    last_changed: 1678471005
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    4: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 100
    current_value: 55
    target_value: 55
    last_value: 55
    unit: "%25"
    step_value: 1
    editable: 0
    type: 8
    state: 1
    last_changed: 1678459725
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    options: object
    5: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 4
    current_value: 1
    target_value: 1
    last_value: 1
    unit: ""
    step_value: 1
    editable: 1
    type: 258
    state: 1
    last_changed: 1678428356
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    6: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 180
    current_value: 0
    target_value: 0
    last_value: 0
    unit: "%C2%B0"
    step_value: 180
    editable: 1
    type: 90
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    7: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 30
    current_value: 0
    target_value: 0
    last_value: 0
    unit: "s"
    step_value: 5
    editable: 1
    type: 259
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    8: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 1
    current_value: 1
    target_value: 1
    last_value: 0
    unit: ""
    step_value: 1
    editable: 1
    type: 260
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    9: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 3
    current_value: 2
    target_value: 2
    last_value: 0
    unit: ""
    step_value: 1
    editable: 1
    type: 261
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    [10 … 14]
    10: object
    node_id: 5
    instance: 0
    minimum: -5
    maximum: 5
    current_value: 0
    target_value: 0
    last_value: 0
    unit: "%C2%B0C"
    step_value: 0.1
    editable: 1
    type: 64
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    11: object
    node_id: 5
    instance: 0
    minimum: -50
    maximum: 125
    current_value: 18.93
    target_value: 18.93
    last_value: 18.84
    unit: "%C2%B0C"
    step_value: 1
    editable: 0
    type: 5
    state: 1
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    options: object
    can_observe: array[1]
    0: 5
    history: object
    day: 1
    week: 26
    month: 6
    12: object
    node_id: 5
    instance: 0
    minimum: 8
    maximum: 28
    current_value: 19
    target_value: 19
    last_value: 8
    unit: "%C2%B0C"
    step_value: 0.5
    editable: 1
    type: 6
    state: 1
    last_changed: 1678443559
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    options: object
    0: 6
    automations: array[1]
    0: "step"
    history: object
    day: 35
    week: 5
    month: 1
    stepped: true
    13: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 1
    current_value: 0
    target_value: 0
    last_value: 0
    unit: ""
    step_value: 1
    editable: 0
    type: 69
    state: 1
    last_changed: 1661403111
    changed_by: 1
    changed_by_id: 0
    based_on: 1
    data: ""
    options: object
    history: object
    day: 182
    week: 26
    month: 6
    stepped: true
    14: object
    node_id: 5
    instance: 0
    minimum: 0
    maximum: 1
    current_value: 1
    target_value: 1
    last_value: 0
    unit: ""
    step_value: 1
    editable: 1
    type: 385
    state: 1
    last_changed: 0
    changed_by: 0
    changed_by_id: 0
    based_on: 0
    data: ""
    Made 2 formatting edits on line 33
    Der ursprüngliche Flow liest den Punkt "state" aus, 1 = Verfügbar, 2 = nicht Verfügbar, 12 = wird Aktualisiert, erstellt einen Text und löst eine Pushnachricht in der homee App mit diesem Text aus. Dieses funktioniert auch. Das schreiben in einen Datenpunkt von ioBroker und den Startbutton habe ich zusätzlich noch hinzugefügt.
    Ich fange auch gerne nochmal bei null an, wie würdest du das denn umsetzen?
    mickymM Offline
    mickymM Offline
    mickym
    @oli Wenn Du Daten hier rein kopieren möchtest das man die verwenden kann, dann bitte nicht über kopieren des Textes aus dem Debugfenster sondern in dem Du den Wert direkt aus dem Debugfenster direkt kopierst und hier in Code-Tags einfügst.
    Also immer rechts neben den Wert und dann über Wert kopieren hier in CodeTags einfügen.
    • O Oli
      @mickym
      object
      node: object
      profile: 3006
      favorite: 0
      order: 6
      protocol: 1
      routing: 0
      state: 1
      added: 1571490280
      history: 0
      cube_type: 1
      services: 7
      owner: 1
      security: 0
      [0 … 9]
      0: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 0
      current_value: 0
      target_value: 0
      last_value: 0
      unit: "text"
      step_value: 1
      editable: 0
      type: 44
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: "4.61"
      1: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 0
      current_value: 0
      target_value: 0
      last_value: 0
      unit: "text"
      step_value: 1
      editable: 0
      type: 45
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: "0.16"
      2: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 1
      current_value: 0
      target_value: 0
      last_value: 0
      unit: ""
      step_value: 1
      editable: 1
      type: 91
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      3: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 100
      current_value: 35
      target_value: 35
      last_value: 37
      unit: "%25"
      step_value: 1
      editable: 0
      type: 18
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      4: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 100
      current_value: 55
      target_value: 55
      last_value: 55
      unit: "%25"
      step_value: 1
      editable: 0
      type: 8
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      options: object
      5: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 4
      current_value: 1
      target_value: 1
      last_value: 1
      unit: ""
      step_value: 1
      editable: 1
      type: 258
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      6: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 180
      current_value: 0
      target_value: 0
      last_value: 0
      unit: "%C2%B0"
      step_value: 180
      editable: 1
      type: 90
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      7: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 30
      current_value: 0
      target_value: 0
      last_value: 0
      unit: "s"
      step_value: 5
      editable: 1
      type: 259
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      8: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 1
      current_value: 1
      target_value: 1
      last_value: 0
      unit: ""
      step_value: 1
      editable: 1
      type: 260
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      9: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 3
      current_value: 2
      target_value: 2
      last_value: 0
      unit: ""
      step_value: 1
      editable: 1
      type: 261
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      [10 … 14]
      10: object
      node_id: 5
      instance: 0
      minimum: -5
      maximum: 5
      current_value: 0
      target_value: 0
      last_value: 0
      unit: "%C2%B0C"
      step_value: 0.1
      editable: 1
      type: 64
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      11: object
      node_id: 5
      instance: 0
      minimum: -50
      maximum: 125
      target_value: 18.93
      last_value: 18.84
      unit: "%C2%B0C"
      step_value: 1
      editable: 0
      type: 5
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      options: object
      0: 5
      history: object
      day: 1
      week: 26
      month: 6
      12: object
      node_id: 5
      instance: 0
      minimum: 8
      maximum: 28
      current_value: 19
      target_value: 19
      last_value: 8
      unit: "%C2%B0C"
      step_value: 0.5
      editable: 1
      type: 6
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      options: object
      0: 6
      0: "step"
      history: object
      day: 35
      week: 5
      month: 1
      stepped: true
      13: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 1
      current_value: 0
      target_value: 0
      last_value: 0
      unit: ""
      step_value: 1
      editable: 0
      type: 69
      state: 1
      changed_by: 1
      changed_by_id: 0
      based_on: 1
      data: ""
      options: object
      history: object
      day: 182
      week: 26
      month: 6
      stepped: true
      14: object
      node_id: 5
      instance: 0
      minimum: 0
      maximum: 1
      current_value: 1
      target_value: 1
      last_value: 0
      unit: ""
      step_value: 1
      editable: 1
      type: 385
      state: 1
      last_changed: 0
      changed_by: 0
      changed_by_id: 0
      based_on: 0
      data: ""
      mickymM Offline
      mickymM Offline
      mickym
      @oli sagte in Benötige Hilfe mit Node-Red in Verbindung mit homee:
      Nun da würde ich generell immer mit den Daten anfangen und dann was Du alles erreichen möchtest.
      O 1 Antwort Letzte Antwort
      • mickymM mickym
        O Offline
        O Offline
        Oli
        @mickym
        {"node":{"id":5,"name":"EG%20%2F%20WC%20%2F%20Heizung","profile":3006,"image":"nodeicon_temperature","favorite":0,"order":6,"protocol":1,"routing":0,"state":1,"state_changed":1678443567,"added":1571490280,"history":0,"cube_type":1,"note":"%23%20EUROtronic%20Spirit%20Z-Wave%20Plus","services":7,"phonetic_name":"Heizung%20Toilette","owner":1,"security":0,"attributes":[{"id":74,"node_id":5,"instance":0,"minimum":0,"maximum":0,"current_value":0,"target_value":0,"last_value":0,"unit":"text","step_value":1,"editable":0,"type":44,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"4.61","name":""},{"id":75,"node_id":5,"instance":0,"minimum":0,"maximum":0,"current_value":0,"target_value":0,"last_value":0,"unit":"text","step_value":1,"editable":0,"type":45,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"0.16","name":""},{"id":76,"node_id":5,"instance":0,"minimum":0,"maximum":1,"current_value":0,"target_value":0,"last_value":0,"unit":"","step_value":1,"editable":1,"type":91,"state":1,"last_changed":1583340481,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":77,"node_id":5,"instance":0,"minimum":0,"maximum":100,"current_value":34,"target_value":34,"last_value":35,"unit":"%25","step_value":1,"editable":0,"type":18,"state":1,"last_changed":1678473765,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":78,"node_id":5,"instance":0,"minimum":0,"maximum":100,"current_value":55,"target_value":55,"last_value":55,"unit":"%25","step_value":1,"editable":0,"type":8,"state":1,"last_changed":1678459725,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"history":{"day":182,"week":26,"month":6}}},{"id":79,"node_id":5,"instance":0,"minimum":0,"maximum":4,"current_value":1,"target_value":1,"last_value":1,"unit":"","step_value":1,"editable":1,"type":258,"state":1,"last_changed":1678428356,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":80,"node_id":5,"instance":0,"minimum":0,"maximum":180,"current_value":0,"target_value":0,"last_value":0,"unit":"%C2%B0","step_value":180,"editable":1,"type":90,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":81,"node_id":5,"instance":0,"minimum":0,"maximum":30,"current_value":0,"target_value":0,"last_value":0,"unit":"s","step_value":5,"editable":1,"type":259,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":82,"node_id":5,"instance":0,"minimum":0,"maximum":1,"current_value":1,"target_value":1,"last_value":0,"unit":"","step_value":1,"editable":1,"type":260,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":83,"node_id":5,"instance":0,"minimum":0,"maximum":3,"current_value":2,"target_value":2,"last_value":0,"unit":"","step_value":1,"editable":1,"type":261,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":84,"node_id":5,"instance":0,"minimum":-5,"maximum":5,"current_value":0,"target_value":0,"last_value":0,"unit":"%C2%B0C","step_value":0.1,"editable":1,"type":64,"state":1,"last_changed":1571490280,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":""},{"id":85,"node_id":5,"instance":0,"minimum":-50,"maximum":125,"current_value":19.1,"target_value":19.1,"last_value":19.02,"unit":"%C2%B0C","step_value":1,"editable":0,"type":5,"state":1,"last_changed":1678476525,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"can_observe":[5],"history":{"day":1,"week":26,"month":6}}},{"id":86,"node_id":5,"instance":0,"minimum":8,"maximum":28,"current_value":19,"target_value":19,"last_value":8,"unit":"%C2%B0C","step_value":0.5,"editable":1,"type":6,"state":1,"last_changed":1678443559,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"can_observe":[6],"automations":["step"],"history":{"day":35,"week":5,"month":1,"stepped":true}}},{"id":87,"node_id":5,"instance":0,"minimum":0,"maximum":1,"current_value":0,"target_value":0,"last_value":0,"unit":"","step_value":1,"editable":0,"type":69,"state":1,"last_changed":1661403111,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"history":{"day":182,"week":26,"month":6,"stepped":true}}},{"id":459,"node_id":5,"instance":0,"minimum":0,"maximum":1,"current_value":1,"target_value":1,"last_value":0,"unit":"","step_value":1,"editable":1,"type":385,"state":1,"last_changed":0,"changed_by":0,"changed_by_id":0,"based_on":0,"data":"","name":""}]}}
        Vom Prinzip möchte ich das umsetzten, was der der Flow bis jetzt zum großen Teil auch schon macht:
        1. Alles Geräte nach ihrem Status abfragen
        2. Die Anzahl der Geräte nach dem jeweilen Status zählen
        3. Einen Text mit Namen, Status und Anzahl verfassen
        4. Eine Pushnachricht in der homee App mit dem Text auslösen
        5. Den Text in einen Datenpunkt schreiben.
        6. Die Anzahl der nicht Verfügbaren Geräte in einen Datenpunkt schreiben
        7. Die ganze Aktion zusätzlich mit einem Button starten
        Oliver
        • O Oli
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          Nun wie gesagt . wenn du zufrieden bist - ist ja OK.
          Ich habe mal deine Daten genommen:
          Ist das nun ein Gerät - und was sind die 15 Attribute zu dem Gerät. Sorry kenn mich halt mit homee 0,0 aus.
          • mickymM mickym
            O Offline
            O Offline
            Oli
            @mickym
            ja, dass ist nur 1 Gerät von 46. In den Attributen stehen die einzelnen Werte drin, wie z.B. Temperatur und Batteriestand u.s.w
            Oliver
            • O Oli
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @oli OK . das heisst die Attribute interessieren nicht, sondern es ist nur der Status in der "node" Eigenschaft selbst relevant und nicht die Attribute?
              Kannst Du mir dann auch das komplette Array - oder halt mehrere Geräte mit unterschiedlichem Status genauso zur Verfügung stellen. Wenn das ggf. zu groß ist, dann halt in eine Datei packen.
              • mickymM mickym
                O Offline
                O Offline
                Oli
                @mickym
                homee.txt
                Aber gerne doch, danke für deine Hilfe!!!
                Oliver
                • O Oli
                  @mickym
                  homee.txt
                  mickymM Offline
                  mickymM Offline
                  mickym
                  So hier mal wieder eine Version ohne function Node - mit Spaghetti-Code. ;)
                  Ja ich musste auch erst lernen, wie man JSONATA liest - wir können das gerne genauer anschauen, aber Du musst Dich halt generell mit Objekte und Arrays auseinandersetzen.
                  Ich hab einfach die verschiedenen Filterfunktionen und Möglichkeiten von JSONATA genutzt. Im Prinzip dient dir diese ganzen Debug Nodes, damit du siehst, wie Du selektierst und auf verschiedenene Eigenschaften der Objekte zugreifst.
                  Im Prinzip habe ich alle Geräte nicht nur nach den Status (aktiv, inaktiv, updating) getrennt, sondern dies auch im Flow-Kontext gespeichert, so dass Du zeitlich unabhängig auf diese Informationen zugreifen kannst.
                  Hier eine Inject Node - aber das kann natürlich auch ein trigger Datenpunkt über VIS sein.
                  Ich hab jetzt mal bewusst nicht die Namen, sondern die phonetischen Namen gewählt - aber das dient ja alles nur der Demo.
                  Es wird unten nicht nur mit der template Node gezeigt, wie Du eine Textausgabe erzeugst, sondern ich hab mal HTML Code verwendet.
                  Diese seite wird im iobroker Home Verzeichnis gespeichert. So könnte dann ein Report aussehen:
                  Somit schau ich mal - was ich von Deinem Pflichtenheft erledigt habe:
                  1. Alles Geräte nach ihrem Status abfragen => erledigt
                  2. Die Anzahl der Geräte nach dem jeweilen Status zählen => erledigt
                  3. Einen Text mit Namen, Status und Anzahl verfassen => erledigt - ich habe HTML code erzeugt, aber reiner Text ist ja einfacher
                  4. Eine Pushnachricht in der homee App mit dem Text auslösen => musst Du machen - bzw. halt das von dem bestehenden Flow übernehmen
                  5. Den Text in einen Datenpunkt schreiben. => Nun da brauchst Du ja nur ein iobroker Out Node an die Ausgabe die Du wünschst dranhängen
                  6. Die Anzahl der nicht Verfügbaren Geräte in einen Datenpunkt schreiben => erledigt nur noch iobroker-Out Node dranhängen
                  7. Die ganze Aktion zusätzlich mit einem Button starten => erledigt, trigger mit VIS
                  Hier nun der Flow zum Import und Ausprobieren:
                         "id": "1a49f3e7a72eeb98",
                         "type": "debug",
                         "z": "9c280ddf049b2b4d",
                         "name": "inaktive Geräte",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "payload",
                         "targetType": "msg",
                         "statusVal": "",
                         "statusType": "auto",
                         "x": 1340,
                         "y": 1120,
                         "wires": []
                         "id": "6f4c16eed7166074",
                         "type": "change",
                         "name": "decodeUrlComponents",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload ~> |$.nodes|{\"name\":$decodeUrlComponent(name),\t\"note\":$decodeUrlComponent(note),\t\"phonetic_name\":$decodeUrlComponent(phonetic_name)},\"attributes\"|",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 340,
                         "y": 1180,
                         "wires": [
                                 "5c62dbd7992ee76d"
                         "id": "5c62dbd7992ee76d",
                         "type": "change",
                         "name": "Alle Geräte",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload.nodes",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 550,
                         "y": 1180,
                         "wires": [
                                 "9ed44d883152b608"
                         "id": "99528e0bbb0f2491",
                         "type": "change",
                         "name": "Alle inaktiven Geräte",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload[state = 2]",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "p": "homee.inactive",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1060,
                         "y": 1180,
                         "wires": [
                                 "1a49f3e7a72eeb98",
                                 "79c90e3a205144c8",
                                 "852a4580fa93381d"
                         "id": "139fe3d8efb20402",
                         "type": "change",
                         "name": "Alle aktiven Geräte",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload[state = 1]",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "p": "homee.active",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1050,
                         "y": 940,
                         "wires": [
                                 "f8402a89bc3c1103",
                                 "b1946c337b7d80ef",
                                 "d95e18df200eadee"
                         "id": "f8402a89bc3c1103",
                         "type": "debug",
                         "name": "aktive Geräte",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1270,
                         "y": 900,
                         "wires": []
                         "id": "43f88f1028d1af0a",
                         "type": "change",
                         "name": "Geräte, die aktualisiert werden",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload[state = 12] ",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "p": "homee.updating",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1090,
                         "y": 1440,
                         "wires": [
                                 "ceb8932892417bf3",
                                 "4e3680fd1ba7cc1e",
                                 "21b0ae03da03035d"
                         "id": "ceb8932892417bf3",
                         "type": "debug",
                         "name": "Geräte die aktualisiert werden",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1410,
                         "y": 1380,
                         "wires": []
                         "id": "4e3680fd1ba7cc1e",
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload ? $count(payload) : \"Keine Geräte im Aktualisierungsstatus\"",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1350,
                         "y": 1440,
                         "wires": [
                                 "d629bd7188fa7121"
                         "id": "d629bd7188fa7121",
                         "type": "debug",
                         "name": "Anzahl Geräte im Aktualisierungsstatus",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1600,
                         "y": 1440,
                         "wires": []
                         "id": "79c90e3a205144c8",
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1330,
                         "y": 1180,
                         "wires": [
                                 "6636132bd627fd5a"
                         "id": "6636132bd627fd5a",
                         "type": "debug",
                         "name": "Anzahl inaktive Geräte",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1520,
                         "y": 1180,
                         "wires": []
                         "id": "b1946c337b7d80ef",
                         "type": "change",
                         "name": "Anzahl",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1270,
                         "y": 940,
                         "wires": [
                                 "1871f120aa223a8d"
                         "id": "1871f120aa223a8d",
                         "type": "debug",
                         "name": "Anzahl aktiver Geräte",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1460,
                         "y": 940,
                         "wires": []
                         "id": "d95e18df200eadee",
                         "type": "change",
                         "name": "Namen",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload.phonetic_name",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1260,
                         "y": 1000,
                         "wires": [
                                 "ae2e5ba148bb399a"
                         "id": "ae2e5ba148bb399a",
                         "type": "debug",
                         "name": "Namen aktiver Geräte (Phoenetic Name)",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1540,
                         "y": 1040,
                         "wires": []
                         "id": "852a4580fa93381d",
                         "type": "change",
                         "name": "Namen",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1340,
                         "y": 1240,
                         "wires": [
                                 "43f62f9f3bc5bc3d"
                         "id": "43f62f9f3bc5bc3d",
                         "type": "debug",
                         "name": "Namen inaktiver Geräte (Phoenetic Name)",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1630,
                         "y": 1240,
                         "wires": []
                         "id": "21b0ae03da03035d",
                         "type": "change",
                         "name": "Namen",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1360,
                         "y": 1500,
                         "wires": [
                                 "02eb40a627f4e90d"
                         "id": "02eb40a627f4e90d",
                         "type": "debug",
                         "name": "Namen aktualisierende Geräte (Phoenetic Name)",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1670,
                         "y": 1500,
                         "wires": []
                         "id": "9ed44d883152b608",
                         "type": "change",
                         "name": "Geräte ausschliessen",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload ~> $filter(function($value){$value.id in [-1] != true})",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 760,
                         "y": 1180,
                         "wires": [
                                 "bc383b50669e8145"
                         "id": "8295d28d57fdb5f9",
                         "type": "inject",
                         "name": "Trigger Report",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "",
                         "payloadType": "date",
                         "x": 210,
                         "y": 1620,
                         "wires": [
                                 "bb70522cf511b632"
                         "id": "bb70522cf511b632",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "homee",
                                 "tot": "flow"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "{\t   \"active\" : {\t       \"count\": payload.active ? $count(payload.active): 0,\t       \"names\" :  payload.active ?  $join(payload.active.phonetic_name,\"\\n\") : \"Keine aktiven Geräte vorhanden\"\t   },\t   \"inactive\" : {\t       \"count\": payload.inactive ? $count(payload.inactive): 0,\t        \"names\" :  payload.inactive ?  $join(payload.inactive.phonetic_name,\"\\n\") : \"Keine inaktiven Geräte vorhanden\"\t   },\t   \"updating\" : {\t       \"count\": payload.updating ? $count(payload.inactive): 0,\t        \"names\" :  payload.updating ?  $join(payload.updating.phonetic_name,\"\\n\") : \"Keine Geräte im Aktualisierungsstatus\"\t   },\t   \"summary\" : payload.updating or payload.inactive ? \"Nicht alle Geräte bereit!\" : \"Alle Geräte aktiv\"\t}",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 430,
                         "y": 1680,
                         "wires": [
                                 "886c19b24989ed4d",
                                 "a76c7c09a28be0d6",
                                 "f422b5bcbb03ca87"
                         "id": "886c19b24989ed4d",
                         "type": "template",
                         "name": "",
                         "field": "payload",
                         "fieldType": "msg",
                         "format": "html",
                         "syntax": "mustache",
                         "template": "<!DOCTYPE html>\n<html>\n\n<body>\n<h1>Status der Geräte:</h1>\n\n<h3>aktive Geräte: {{payload.active.count}}\n<pre>{{payload.active.names}}</pre>\n\n<h3>inaktive Geräte: {{payload.inactive.count}}\n<pre>{{payload.inactive.names}}</pre>\n\n<h3>aktualisierende Geräte: {{payload.updating.count}}\n<pre>{{payload.updating.names}}</pre>\n\n<h3>{{payload.summary}}</h3>\n</body>\n</html>",
                         "output": "str",
                         "x": 660,
                         "y": 1680,
                         "wires": [
                                 "e9df565834fa1f46"
                         "id": "ea538b90d2d339e0",
                         "type": "file",
                         "name": "",
                         "filename": "filename",
                         "filenameType": "msg",
                         "appendNewline": false,
                         "createDir": false,
                         "overwriteFile": "true",
                         "encoding": "none",
                         "x": 1080,
                         "y": 1680,
                         "wires": [
                         "id": "e9df565834fa1f46",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "filename",
                                 "pt": "msg",
                                 "to": "/home/iobroker/homee-report.html",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 870,
                         "y": 1680,
                         "wires": [
                                 "ea538b90d2d339e0"
                         "id": "a76c7c09a28be0d6",
                         "type": "switch",
                         "name": "",
                         "property": "payload.summary",
                         "propertyType": "msg",
                         "rules": [
                                 "t": "neq",
                                 "v": "Alle Geräte aktiv",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 650,
                         "y": 1760,
                         "wires": [
                                 "d8673a8fe1b1dfc2"
                         "id": "48226cba37067157",
                         "type": "debug",
                         "name": "Warnung ausgeben - wenn nicht alle Geräte aktiv",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1150,
                         "y": 1760,
                         "wires": []
                         "id": "d8673a8fe1b1dfc2",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload.summary",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 830,
                         "y": 1760,
                         "wires": [
                                 "48226cba37067157"
                         "id": "f99cd78780beb8e7",
                         "type": "ioBroker in",
                         "name": "start",
                         "topic": "0_userdata.0.System.homee.StartGeräteinfo",
                         "payloadType": "value",
                         "onlyack": "",
                         "func": "all",
                         "gap": "",
                         "fireOnStart": "false",
                         "outFormat": "MQTT",
                         "x": 190,
                         "y": 1680,
                         "wires": [
                                 "bb70522cf511b632"
                         "id": "f422b5bcbb03ca87",
                         "type": "change",
                         "name": "Anzahl nicht aktiver Geräte",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload.inactive.count + payload.updating.count",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 720,
                         "y": 1840,
                         "wires": [
                                 "8b40e4fbe4ba993d"
                         "id": "8b40e4fbe4ba993d",
                         "type": "debug",
                         "name": "Nicht aktive Geräte (updating oder inaktiv)",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1060,
                         "y": 1840,
                         "wires": []
                         "id": "bc383b50669e8145",
                         "type": "junction",
                         "x": 880,
                         "y": 1180,
                         "wires": [
                                 "43f88f1028d1af0a",
                                 "99528e0bbb0f2491",
                                 "139fe3d8efb20402"
                  Die Inject Node mit den Daten der 46 Geräte ist in diesem Export nicht enthalten - also den Dateninput musst Du halt liefern. ;)
                  Der Vorteil nicht alles in einer function Node zu verstecken ist halt auch, dass Du individuell Aktionen mit bestimmten Geräten ggf. anschließen kannst.
                  Und zum Schluss - Du hast so einen Flow dann selbst erarbeitet. Ich kann Dich nur ermuntern, das zu Probieren, anstelle im Netz nach fertigen Flows zu suchen. Es kann eine Anregung sein - man muss das Rad nicht neu erfinden. Der Mensch, der den Flow gemacht hat, ist zwar ein sehr fitter Javascript Programmierer (diese template Literals habe ich noch nie benutzt), aber er kapselt viel zu viel in der function Node und beschneidet deshalb die Möglichkeiten eines Flows.
                  • O Offline
                    O Offline
                    Oli
                    @mickym
                    wow, erstmal vielen Dank, dass muss ich mir heute nach dem aufstehen mal etwas genau anschauen, momentan erschlägt es mich erstmal.
                    Da werden bestimmt einige Fragen aufkommen, mit denen ich auf dich zukommen werde ;-)
                    Oliver
                    • mickymM mickym
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1340,
                             "y": 1120,
                             "wires": []
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 340,
                             "y": 1180,
                             "wires": [
                                     "5c62dbd7992ee76d"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 550,
                             "y": 1180,
                             "wires": [
                                     "9ed44d883152b608"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                                     "t": "set",
                                     "pt": "flow",
                                     "to": "payload",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1060,
                             "y": 1180,
                             "wires": [
                                     "1a49f3e7a72eeb98",
                                     "79c90e3a205144c8",
                                     "852a4580fa93381d"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                                     "t": "set",
                                     "pt": "flow",
                                     "to": "payload",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1050,
                             "y": 940,
                             "wires": [
                                     "f8402a89bc3c1103",
                                     "b1946c337b7d80ef",
                                     "d95e18df200eadee"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1270,
                             "y": 900,
                             "wires": []
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                                     "t": "set",
                                     "pt": "flow",
                                     "to": "payload",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1090,
                             "y": 1440,
                             "wires": [
                                     "ceb8932892417bf3",
                                     "4e3680fd1ba7cc1e",
                                     "21b0ae03da03035d"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1410,
                             "y": 1380,
                             "wires": []
                             "type": "change",
                             "name": "Anzahl",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1350,
                             "y": 1440,
                             "wires": [
                                     "d629bd7188fa7121"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1600,
                             "y": 1440,
                             "wires": []
                             "type": "change",
                             "name": "Anzahl",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1330,
                             "y": 1180,
                             "wires": [
                                     "6636132bd627fd5a"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1520,
                             "y": 1180,
                             "wires": []
                             "type": "change",
                             "name": "Anzahl",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1270,
                             "y": 940,
                             "wires": [
                                     "1871f120aa223a8d"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1460,
                             "y": 940,
                             "wires": []
                             "type": "change",
                             "name": "Namen",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1260,
                             "y": 1000,
                             "wires": [
                                     "ae2e5ba148bb399a"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1540,
                             "y": 1040,
                             "wires": []
                             "type": "change",
                             "name": "Namen",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1340,
                             "y": 1240,
                             "wires": [
                                     "43f62f9f3bc5bc3d"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1630,
                             "y": 1240,
                             "wires": []
                             "type": "change",
                             "name": "Namen",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1360,
                             "y": 1500,
                             "wires": [
                                     "02eb40a627f4e90d"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1670,
                             "y": 1500,
                             "wires": []
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 760,
                             "y": 1180,
                             "wires": [
                                     "bc383b50669e8145"
                             "type": "inject",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "",
                             "x": 210,
                             "y": 1620,
                             "wires": [
                                     "bb70522cf511b632"
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "homee",
                                     "tot": "flow"
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 430,
                             "y": 1680,
                             "wires": [
                                     "886c19b24989ed4d",
                                     "a76c7c09a28be0d6",
                                     "f422b5bcbb03ca87"
                             "type": "template",
                             "name": "",
                             "field": "payload",
                             "fieldType": "msg",
                             "format": "html",
                             "output": "str",
                             "x": 660,
                             "y": 1680,
                             "wires": [
                                     "e9df565834fa1f46"
                             "type": "file",
                             "name": "",
                             "createDir": false,
                             "encoding": "none",
                             "x": 1080,
                             "y": 1680,
                             "wires": [
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "filename",
                                     "pt": "msg",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 870,
                             "y": 1680,
                             "wires": [
                                     "ea538b90d2d339e0"
                             "type": "switch",
                             "name": "",
                             "rules": [
                                     "t": "neq",
                                     "vt": "str"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 1,
                             "x": 650,
                             "y": 1760,
                             "wires": [
                                     "d8673a8fe1b1dfc2"
                             "type": "debug",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1150,
                             "y": 1760,
                             "wires": []
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 830,
                             "y": 1760,
                             "wires": [
                                     "48226cba37067157"
                             "name": "start",
                             "onlyack": "",
                             "func": "all",
                             "gap": "",
                             "x": 190,
                             "y": 1680,
                             "wires": [
                                     "bb70522cf511b632"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 720,
                             "y": 1840,
                             "wires": [
                                     "8b40e4fbe4ba993d"
                             "type": "debug",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 1060,
                             "y": 1840,
                             "wires": []
                             "type": "junction",
                             "x": 880,
                             "y": 1180,
                             "wires": [
                                     "43f88f1028d1af0a",
                                     "99528e0bbb0f2491",
                                     "139fe3d8efb20402"
                      O Offline
                      O Offline
                      Oli
                      @mickym
                      habe mir das ganze mal angesehen und versucht durch zu blicken, aber leider funktioniert es nicht.
                      Der Obere Teil sieht wie folgt aus:
                      Bei den Debug-Nodes der einzelnen Geräte kommt immer folgendes:
                      Bei der Debug-Node 5 schreibt er folgendes:
                      {"attribute":{"id":358,"node_id":56,"instance":0,"minimum":0,"maximum":20,"current_value":0.412,"target_value":0.412,"last_value":0.438,"unit":"A","step_value":1,"editable":0,"type":193,"state":1,"last_changed":1678519354,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}}}
                      Aber nach meinem Verständnis, sollte doch eigentlich die "node" abgefragt werden, nicht die "attribute"
                      {"node":{"id":29,"name":"EG%20%2F%20Wohnzimmer%20%2F%20Netatmo","profile":3014,"image":"default","favorite":0,"order":42,"protocol":9,"routing":0,"state":1,"state_changed":1678428037,"added":1607519624,"history":0,"cube_type":8,"note":"","services":5,"phonetic_name":"Klima%20Wohnzimmer","owner":1,"security":0,"attributes":[{"id":253,"node_id":29,"instance":0,"minimum":0,"maximum":50,"current_value":20.6,"target_value":20.6,"last_value":20.5,"unit":"%C2%B0C","step_value":0.5,"editable":0,"type":5,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":254,"node_id":29,"instance":0,"minimum":0,"maximum":100,"current_value":33,"target_value":33,"last_value":34,"unit":"%25","step_value":1,"editable":0,"type":7,"state":1,"last_changed":1678515784,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":255,"node_id":29,"instance":0,"minimum":0,"maximum":5000,"current_value":444,"target_value":444,"last_value":449,"unit":"ppm","step_value":50,"editable":0,"type":20,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":256,"node_id":29,"instance":0,"minimum":35,"maximum":120,"current_value":32,"target_value":32,"last_value":33,"unit":"dB","step_value":1,"editable":0,"type":93,"state":1,"last_changed":1678515183,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":257,"node_id":29,"instance":0,"minimum":260,"maximum":1160,"current_value":1003.7,"target_value":1003.7,"last_value":1003.6,"unit":"mBar","step_value":5,"editable":0,"type":94,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":258,"node_id":29,"instance":0,"minimum":0,"maximum":4,"current_value":4,"target_value":4,"last_value":2,"unit":"n%2Fa","step_value":1,"editable":0,"type":33,"state":1,"last_changed":1677083197,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":""},{"id":475,"node_id":29,"instance":0,"minimum":0,"maximum":1,"current_value":1,"target_value":1,"last_value":0,"unit":"","step_value":1,"editable":1,"type":385,"state":1,"last_changed":0,"changed_by":0,"changed_by_id":0,"based_on":0,"data":"","name":""}]}}
                      Wenn dem so ist, wo kann ich das ändern?
                      Oliver
                      • O Oli
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @oli Nein dem ist nicht so - im Gegenteil die attribute werden entfernt. - Ich denke wir haben ggf. nicht mit der gleichen Datenbasis gearbeitet.
                        Bei mir sind also in dem Input alle 46 Geräte zu sehen.
                        Mit der Change Node - werden im Gegenteil die einzelnen attribute weggenommen.
                        Also haben wir eine unterschiedliche Ausgangsbasis. Kommen denn die Geräte einzeln an? oder insgesamt?
                        Ich habe halt mit der Datenbasis gearbeitet, bei der alle Geräte aufeinmal ankommen. Also im Prinzip mit dem was Du mir in der Datei aus : https://forum.iobroker.net/post/960869 geschickt hast.
                        Deswegen heißt mein Array auch nodes und nicht node. ;)
                        Jetzt ist halt die Frage - kannst Du das auch so machen oder müssen wir die einzelnen Geräte mühsam sammeln? Wenn die Geräte einzeln ankommen - müssen wir den Flow umändern.
                        Also sag mir, ob die Geräte sich da nun einzeln melden oder ob Du die ganze Geräteliste als Input zur Verfügung stellen kannst?
                        Im Prinzip hat der wohl die Nodes global gesammelt, da dies in der 1. Zeile der function Node so steht:
                        const nodes = global.get('homee.nodes');
                        Falls dem so ist, kannst Du mal in Deinem globalen Kontext schauen, ob da die vollständigen Nodeliste drin ist ;) ?
                        Wenn ja dann - ignorieren wir nämlich den Input und setzen die payload am Anfang auf den globalen Kontext.
                        Also schau mal, was ggf. hier in Deinem globalen Kontext drin steht:
                        Du musst rechts auf das Aktualisieren Icon drücken.
                        Falls dem so ist, wie ich vermute, dann ist das was rein kommt in Deinen Flow nur ein trigger - den wir später auch verfeinern können.
                        Du kannst die payload - wie in der function Node auf alle Nodes setzen, wenn Du vorher noch folgende Change Node dran machst:
                        die Change Node muss folgenden Inhalt haben:
                                "id": "4bb866d9e36a197e",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload.nodes",
                                        "pt": "msg",
                                        "to": "homee.nodes",
                                        "tot": "global"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 390,
                                "y": 460,
                                "wires": [
                                        "6f4c16eed7166074"
                        Im Prinzip holen wir dann bei jedem Geräteupdate die vollständige Liste bzw. analysieren diese.
                        Im Prinzip filtert er aus, dass nur diese Ereignisse triggern:
                        if((msg.payload.node && ((msg.payload.node.state === 2)||(msg.payload.node.state === 12)))||msg.payload === true)
                        das müssen wir halt nochmal schauen, ob das Sinn macht. Das bedeutet, dass momentan die Auswertung nur läuft wenn die payload nur true ist oder die payload eine Eigenschaft node hat, deren states 2 oder 12 ist.
                        Ich hoffe ich habe mich verständlich ausgedrückt. - Also setze mal die payload auf den globalen Kontext, mit der Change Node und mit den triggern überlegen wir uns noch.
                        So ich hab das jetzt nochmal simuliert:
                        Wenn bei Dir der globale Kontext so aussieht:
                        Dann sollte jetzt dieser ganze Flow funktionieren, indem Du einfach auf den trigger Knopf drückst oder auch von Deinem anderen Flow triggern lässt:
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1620,
                               "y": 620,
                               "wires": []
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 580,
                               "y": 680,
                               "wires": [
                                       "5c62dbd7992ee76d"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 790,
                               "y": 680,
                               "wires": [
                                       "9ed44d883152b608"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1340,
                               "y": 680,
                               "wires": [
                                       "1a49f3e7a72eeb98",
                                       "79c90e3a205144c8",
                                       "852a4580fa93381d"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1330,
                               "y": 440,
                               "wires": [
                                       "f8402a89bc3c1103",
                                       "b1946c337b7d80ef",
                                       "d95e18df200eadee"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1550,
                               "y": 400,
                               "wires": []
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1370,
                               "y": 940,
                               "wires": [
                                       "ceb8932892417bf3",
                                       "4e3680fd1ba7cc1e",
                                       "21b0ae03da03035d"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1690,
                               "y": 880,
                               "wires": []
                               "type": "change",
                               "name": "Anzahl",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1630,
                               "y": 940,
                               "wires": [
                                       "d629bd7188fa7121"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1880,
                               "y": 940,
                               "wires": []
                               "type": "change",
                               "name": "Anzahl",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1610,
                               "y": 680,
                               "wires": [
                                       "6636132bd627fd5a"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1800,
                               "y": 680,
                               "wires": []
                               "type": "change",
                               "name": "Anzahl",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1550,
                               "y": 440,
                               "wires": [
                                       "1871f120aa223a8d"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1740,
                               "y": 440,
                               "wires": []
                               "type": "change",
                               "name": "Namen",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1540,
                               "y": 500,
                               "wires": [
                                       "ae2e5ba148bb399a"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1820,
                               "y": 540,
                               "wires": []
                               "type": "change",
                               "name": "Namen",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1620,
                               "y": 740,
                               "wires": [
                                       "43f62f9f3bc5bc3d"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1910,
                               "y": 740,
                               "wires": []
                               "type": "change",
                               "name": "Namen",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1640,
                               "y": 1000,
                               "wires": [
                                       "02eb40a627f4e90d"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1950,
                               "y": 1000,
                               "wires": []
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1000,
                               "y": 680,
                               "wires": [
                                       "bc383b50669e8145"
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "",
                               "x": 250,
                               "y": 1140,
                               "wires": [
                                       "bb70522cf511b632"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "homee",
                                       "tot": "flow"
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 470,
                               "y": 1200,
                               "wires": [
                                       "886c19b24989ed4d",
                                       "a76c7c09a28be0d6",
                                       "f422b5bcbb03ca87",
                                       "5ea7fcec46176042"
                               "type": "template",
                               "name": "",
                               "field": "payload",
                               "fieldType": "msg",
                               "format": "html",
                               "output": "str",
                               "x": 700,
                               "y": 1200,
                               "wires": [
                                       "e9df565834fa1f46"
                               "type": "file",
                               "name": "",
                               "createDir": false,
                               "encoding": "none",
                               "x": 1120,
                               "y": 1200,
                               "wires": [
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "filename",
                                       "pt": "msg",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 910,
                               "y": 1200,
                               "wires": [
                                       "ea538b90d2d339e0"
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "neq",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 690,
                               "y": 1280,
                               "wires": [
                                       "d8673a8fe1b1dfc2"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1190,
                               "y": 1280,
                               "wires": []
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 870,
                               "y": 1280,
                               "wires": [
                                       "48226cba37067157"
                               "name": "start",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 230,
                               "y": 1200,
                               "wires": [
                                       "bb70522cf511b632"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 760,
                               "y": 1360,
                               "wires": [
                                       "8b40e4fbe4ba993d"
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1100,
                               "y": 1360,
                               "wires": []
                               "type": "change",
                               "name": "hole alle Geräte",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "homee",
                                       "tot": "global"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 340,
                               "y": 680,
                               "wires": [
                                       "6f4c16eed7166074"
                               "id": "a48d4a225b9f0daa",
                               "type": "inject",
                               "name": "trigger",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "true",
                               "payloadType": "bool",
                               "x": 170,
                               "y": 680,
                               "wires": [
                                       "4bb866d9e36a197e"
                               "id": "5ea7fcec46176042",
                               "type": "debug",
                               "name": "Zusammenfassung",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 730,
                               "y": 1140,
                               "wires": []
                               "type": "junction",
                               "x": 1160,
                               "y": 680,
                               "wires": [
                                       "43f88f1028d1af0a",
                                       "99528e0bbb0f2491",
                                       "139fe3d8efb20402"
                        Wenn Du dann unten den Trigger Report anklickst - dann solltest Du im Debug Fenster folgende Daten erhalten:
                          "active": {
                            "count": 44,
                            "names": "Bewegungsmelder Kirsten\nBewegungsmelder Oliver\nLuftreiniger\nNachtlicht TV\nNachtlicht Kirsten\n\nNachtlicht Oliver\nHeizung Wohnzimmer Balkon\nWaschmaschine\nMultimedia\nRauchmelder Flur Dachgeschoss\nRauchmelder Flur Erdgeschoss\nRauchmelder Flur Keller\nFenster Bad\nBalkontür Esszimmer\nBalkontür Wohnzimmer\nFenster Toilette\nFenster Büro Rechts\nFenster Büro Links\nSchlafzimmer Rauchmelder\nRauchmelder Schlafzimmer Keller\nHeizung Büro\nVitrine Wohnzimmer\nTemperatur Weinkühlschrank\nHeizung Wohnzimmer Links\nSchrank Wohnzimmer\nHeizung Esszimmer\nHeizung Toilette\nWeinschrank Wohnzimmer\nThermostat Wohnzimmer\nComputer\nKühlschrank\nGeschirrspüler\nWassersensor Küche\nHeizung Bad\nKlima Wohnzimmer\nKlima Balkon\nKlima Büro\nKlima Schlafzimmer\nKlimaanlage\nTablet\nStehlampe Wohnzimmer\nBar Wohnzimmer\nTemperatur Kühlschrank"
                          "inactive": {
                            "count": 1,
                            "names": "Licht Glasvitrine Flur"
                          "updating": {
                            "count": 0,
                            "names": "Keine Geräte im Aktualisierungsstatus"
                          "summary": "Nicht alle Geräte bereit!"
                        • mickymM mickym
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "pt": "msg",
                                          "tot": "global"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 390,
                                  "y": 460,
                                  "wires": [
                                          "6f4c16eed7166074"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1620,
                                 "y": 620,
                                 "wires": []
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 580,
                                 "y": 680,
                                 "wires": [
                                         "5c62dbd7992ee76d"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 790,
                                 "y": 680,
                                 "wires": [
                                         "9ed44d883152b608"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "pt": "flow",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1340,
                                 "y": 680,
                                 "wires": [
                                         "1a49f3e7a72eeb98",
                                         "79c90e3a205144c8",
                                         "852a4580fa93381d"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "pt": "flow",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1330,
                                 "y": 440,
                                 "wires": [
                                         "f8402a89bc3c1103",
                                         "b1946c337b7d80ef",
                                         "d95e18df200eadee"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1550,
                                 "y": 400,
                                 "wires": []
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "pt": "flow",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1370,
                                 "y": 940,
                                 "wires": [
                                         "ceb8932892417bf3",
                                         "4e3680fd1ba7cc1e",
                                         "21b0ae03da03035d"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1690,
                                 "y": 880,
                                 "wires": []
                                 "type": "change",
                                 "name": "Anzahl",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1630,
                                 "y": 940,
                                 "wires": [
                                         "d629bd7188fa7121"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1880,
                                 "y": 940,
                                 "wires": []
                                 "type": "change",
                                 "name": "Anzahl",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1610,
                                 "y": 680,
                                 "wires": [
                                         "6636132bd627fd5a"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1800,
                                 "y": 680,
                                 "wires": []
                                 "type": "change",
                                 "name": "Anzahl",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1550,
                                 "y": 440,
                                 "wires": [
                                         "1871f120aa223a8d"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1740,
                                 "y": 440,
                                 "wires": []
                                 "type": "change",
                                 "name": "Namen",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1540,
                                 "y": 500,
                                 "wires": [
                                         "ae2e5ba148bb399a"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1820,
                                 "y": 540,
                                 "wires": []
                                 "type": "change",
                                 "name": "Namen",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1620,
                                 "y": 740,
                                 "wires": [
                                         "43f62f9f3bc5bc3d"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1910,
                                 "y": 740,
                                 "wires": []
                                 "type": "change",
                                 "name": "Namen",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1640,
                                 "y": 1000,
                                 "wires": [
                                         "02eb40a627f4e90d"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1950,
                                 "y": 1000,
                                 "wires": []
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1000,
                                 "y": 680,
                                 "wires": [
                                         "bc383b50669e8145"
                                 "type": "inject",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "",
                                 "x": 250,
                                 "y": 1140,
                                 "wires": [
                                         "bb70522cf511b632"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "homee",
                                         "tot": "flow"
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 470,
                                 "y": 1200,
                                 "wires": [
                                         "886c19b24989ed4d",
                                         "a76c7c09a28be0d6",
                                         "f422b5bcbb03ca87",
                                         "5ea7fcec46176042"
                                 "type": "template",
                                 "name": "",
                                 "field": "payload",
                                 "fieldType": "msg",
                                 "format": "html",
                                 "output": "str",
                                 "x": 700,
                                 "y": 1200,
                                 "wires": [
                                         "e9df565834fa1f46"
                                 "type": "file",
                                 "name": "",
                                 "createDir": false,
                                 "encoding": "none",
                                 "x": 1120,
                                 "y": 1200,
                                 "wires": [
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "filename",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 910,
                                 "y": 1200,
                                 "wires": [
                                         "ea538b90d2d339e0"
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "neq",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 1,
                                 "x": 690,
                                 "y": 1280,
                                 "wires": [
                                         "d8673a8fe1b1dfc2"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1190,
                                 "y": 1280,
                                 "wires": []
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 870,
                                 "y": 1280,
                                 "wires": [
                                         "48226cba37067157"
                                 "name": "start",
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 230,
                                 "y": 1200,
                                 "wires": [
                                         "bb70522cf511b632"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 760,
                                 "y": 1360,
                                 "wires": [
                                         "8b40e4fbe4ba993d"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1100,
                                 "y": 1360,
                                 "wires": []
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "homee",
                                         "tot": "global"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 340,
                                 "y": 680,
                                 "wires": [
                                         "6f4c16eed7166074"
                                 "type": "inject",
                                 "name": "trigger",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "true",
                                 "x": 170,
                                 "y": 680,
                                 "wires": [
                                         "4bb866d9e36a197e"
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 730,
                                 "y": 1140,
                                 "wires": []
                                 "type": "junction",
                                 "x": 1160,
                                 "y": 680,
                                 "wires": [
                                         "43f88f1028d1af0a",
                                         "99528e0bbb0f2491",
                                         "139fe3d8efb20402"
                            "active": {
                              "count": 44,
                            "inactive": {
                              "count": 1,
                            "updating": {
                              "count": 0,
                          O Offline
                          O Offline
                          Oli
                          @mickym
                          sieht bei mir so aus:
                          Oliver
                          • O Oli
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @oli Ok - dann lass mich noch eine kleine Modifikation machen. ;)
                            • O Oli
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @mickym
                              Wobei es jetzt eigentlich bei Dir schon gehen sollte, weil ich Deinen Flow Kontext sehe. ;)
                              so hier nochmal der gesamte Flow:
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1620,
                                     "y": 620,
                                     "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 580,
                                     "y": 680,
                                     "wires": [
                                             "5c62dbd7992ee76d"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 790,
                                     "y": 680,
                                     "wires": [
                                             "9ed44d883152b608"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                             "t": "set",
                                             "pt": "flow",
                                             "to": "payload",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1340,
                                     "y": 680,
                                     "wires": [
                                             "1a49f3e7a72eeb98",
                                             "79c90e3a205144c8",
                                             "852a4580fa93381d"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                             "t": "set",
                                             "pt": "flow",
                                             "to": "payload",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1330,
                                     "y": 440,
                                     "wires": [
                                             "f8402a89bc3c1103",
                                             "b1946c337b7d80ef",
                                             "d95e18df200eadee"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1550,
                                     "y": 400,
                                     "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                             "t": "set",
                                             "pt": "flow",
                                             "to": "payload",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1370,
                                     "y": 940,
                                     "wires": [
                                             "ceb8932892417bf3",
                                             "4e3680fd1ba7cc1e",
                                             "21b0ae03da03035d"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1690,
                                     "y": 880,
                                     "wires": []
                                     "type": "change",
                                     "name": "Anzahl",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1630,
                                     "y": 940,
                                     "wires": [
                                             "d629bd7188fa7121"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1880,
                                     "y": 940,
                                     "wires": []
                                     "type": "change",
                                     "name": "Anzahl",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1610,
                                     "y": 680,
                                     "wires": [
                                             "6636132bd627fd5a"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1800,
                                     "y": 680,
                                     "wires": []
                                     "type": "change",
                                     "name": "Anzahl",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1550,
                                     "y": 440,
                                     "wires": [
                                             "1871f120aa223a8d"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1740,
                                     "y": 440,
                                     "wires": []
                                     "type": "change",
                                     "name": "Namen",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1540,
                                     "y": 500,
                                     "wires": [
                                             "ae2e5ba148bb399a"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1820,
                                     "y": 540,
                                     "wires": []
                                     "type": "change",
                                     "name": "Namen",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1620,
                                     "y": 740,
                                     "wires": [
                                             "43f62f9f3bc5bc3d"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1910,
                                     "y": 740,
                                     "wires": []
                                     "type": "change",
                                     "name": "Namen",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1640,
                                     "y": 1000,
                                     "wires": [
                                             "02eb40a627f4e90d"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1950,
                                     "y": 1000,
                                     "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1000,
                                     "y": 680,
                                     "wires": [
                                             "bc383b50669e8145"
                                     "type": "inject",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "",
                                     "x": 250,
                                     "y": 1140,
                                     "wires": [
                                             "bb70522cf511b632"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "homee",
                                             "tot": "flow"
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 470,
                                     "y": 1200,
                                     "wires": [
                                             "886c19b24989ed4d",
                                             "a76c7c09a28be0d6",
                                             "f422b5bcbb03ca87",
                                             "5ea7fcec46176042"
                                     "type": "template",
                                     "name": "",
                                     "field": "payload",
                                     "fieldType": "msg",
                                     "format": "html",
                                     "output": "str",
                                     "x": 700,
                                     "y": 1200,
                                     "wires": [
                                             "e9df565834fa1f46"
                                     "type": "file",
                                     "name": "",
                                     "createDir": false,
                                     "encoding": "none",
                                     "x": 1120,
                                     "y": 1200,
                                     "wires": [
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "filename",
                                             "pt": "msg",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 910,
                                     "y": 1200,
                                     "wires": [
                                             "ea538b90d2d339e0"
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "neq",
                                             "vt": "str"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 1,
                                     "x": 690,
                                     "y": 1280,
                                     "wires": [
                                             "d8673a8fe1b1dfc2"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1190,
                                     "y": 1280,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 870,
                                     "y": 1280,
                                     "wires": [
                                             "48226cba37067157"
                                     "name": "start",
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 230,
                                     "y": 1200,
                                     "wires": [
                                             "bb70522cf511b632"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 760,
                                     "y": 1360,
                                     "wires": [
                                             "8b40e4fbe4ba993d"
                                     "type": "debug",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1100,
                                     "y": 1360,
                                     "wires": []
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "{}",
                                             "tot": "json"
                                             "t": "set",
                                             "pt": "msg",
                                             "tot": "global"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 340,
                                     "y": 680,
                                     "wires": [
                                             "6f4c16eed7166074"
                                     "type": "inject",
                                     "name": "trigger",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "true",
                                     "x": 170,
                                     "y": 680,
                                     "wires": [
                                             "4bb866d9e36a197e"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 730,
                                     "y": 1140,
                                     "wires": []
                                     "type": "junction",
                                     "x": 1160,
                                     "y": 680,
                                     "wires": [
                                             "43f88f1028d1af0a",
                                             "99528e0bbb0f2491",
                                             "139fe3d8efb20402"
                              Im Wesentlichen holen wir nun nur aus dem globalen Kontext die gesamte Geräteliste:
                              Ist halt immer bissi schwierig, wenn man sich halt mit den Daten die Realität zusammensimulieren muss, aber sollte nun eigentlich passen.
                              Wie gesagt wir müssen uns ggf. halt nur über den Trigger unterhalten. Vielleicht langt es da auch wenn Du mit deinem VIS Datenpunkt triggerst - da die globale Geräteliste ja bereits erstellt wird.
                              • mickymM mickym
                                @mickym
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1620,
                                       "y": 620,
                                       "wires": []
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 580,
                                       "y": 680,
                                       "wires": [
                                               "5c62dbd7992ee76d"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 790,
                                       "y": 680,
                                       "wires": [
                                               "9ed44d883152b608"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                               "t": "set",
                                               "pt": "flow",
                                               "to": "payload",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1340,
                                       "y": 680,
                                       "wires": [
                                               "1a49f3e7a72eeb98",
                                               "79c90e3a205144c8",
                                               "852a4580fa93381d"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                               "t": "set",
                                               "pt": "flow",
                                               "to": "payload",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1330,
                                       "y": 440,
                                       "wires": [
                                               "f8402a89bc3c1103",
                                               "b1946c337b7d80ef",
                                               "d95e18df200eadee"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1550,
                                       "y": 400,
                                       "wires": []
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                               "t": "set",
                                               "pt": "flow",
                                               "to": "payload",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1370,
                                       "y": 940,
                                       "wires": [
                                               "ceb8932892417bf3",
                                               "4e3680fd1ba7cc1e",
                                               "21b0ae03da03035d"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1690,
                                       "y": 880,
                                       "wires": []
                                       "type": "change",
                                       "name": "Anzahl",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1630,
                                       "y": 940,
                                       "wires": [
                                               "d629bd7188fa7121"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1880,
                                       "y": 940,
                                       "wires": []
                                       "type": "change",
                                       "name": "Anzahl",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1610,
                                       "y": 680,
                                       "wires": [
                                               "6636132bd627fd5a"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1800,
                                       "y": 680,
                                       "wires": []
                                       "type": "change",
                                       "name": "Anzahl",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1550,
                                       "y": 440,
                                       "wires": [
                                               "1871f120aa223a8d"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1740,
                                       "y": 440,
                                       "wires": []
                                       "type": "change",
                                       "name": "Namen",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1540,
                                       "y": 500,
                                       "wires": [
                                               "ae2e5ba148bb399a"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1820,
                                       "y": 540,
                                       "wires": []
                                       "type": "change",
                                       "name": "Namen",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1620,
                                       "y": 740,
                                       "wires": [
                                               "43f62f9f3bc5bc3d"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1910,
                                       "y": 740,
                                       "wires": []
                                       "type": "change",
                                       "name": "Namen",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1640,
                                       "y": 1000,
                                       "wires": [
                                               "02eb40a627f4e90d"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1950,
                                       "y": 1000,
                                       "wires": []
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1000,
                                       "y": 680,
                                       "wires": [
                                               "bc383b50669e8145"
                                       "type": "inject",
                                       "props": [
                                               "p": "payload"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "",
                                       "x": 250,
                                       "y": 1140,
                                       "wires": [
                                               "bb70522cf511b632"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "homee",
                                               "tot": "flow"
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 470,
                                       "y": 1200,
                                       "wires": [
                                               "886c19b24989ed4d",
                                               "a76c7c09a28be0d6",
                                               "f422b5bcbb03ca87",
                                               "5ea7fcec46176042"
                                       "type": "template",
                                       "name": "",
                                       "field": "payload",
                                       "fieldType": "msg",
                                       "format": "html",
                                       "output": "str",
                                       "x": 700,
                                       "y": 1200,
                                       "wires": [
                                               "e9df565834fa1f46"
                                       "type": "file",
                                       "name": "",
                                       "createDir": false,
                                       "encoding": "none",
                                       "x": 1120,
                                       "y": 1200,
                                       "wires": [
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "filename",
                                               "pt": "msg",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 910,
                                       "y": 1200,
                                       "wires": [
                                               "ea538b90d2d339e0"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "neq",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 1,
                                       "x": 690,
                                       "y": 1280,
                                       "wires": [
                                               "d8673a8fe1b1dfc2"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1190,
                                       "y": 1280,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 870,
                                       "y": 1280,
                                       "wires": [
                                               "48226cba37067157"
                                       "name": "start",
                                       "onlyack": "",
                                       "func": "all",
                                       "gap": "",
                                       "x": 230,
                                       "y": 1200,
                                       "wires": [
                                               "bb70522cf511b632"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 760,
                                       "y": 1360,
                                       "wires": [
                                               "8b40e4fbe4ba993d"
                                       "type": "debug",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1100,
                                       "y": 1360,
                                       "wires": []
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "{}",
                                               "tot": "json"
                                               "t": "set",
                                               "pt": "msg",
                                               "tot": "global"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 340,
                                       "y": 680,
                                       "wires": [
                                               "6f4c16eed7166074"
                                       "type": "inject",
                                       "name": "trigger",
                                       "props": [
                                               "p": "payload"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "true",
                                       "x": 170,
                                       "y": 680,
                                       "wires": [
                                               "4bb866d9e36a197e"
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 730,
                                       "y": 1140,
                                       "wires": []
                                       "type": "junction",
                                       "x": 1160,
                                       "y": 680,
                                       "wires": [
                                               "43f88f1028d1af0a",
                                               "99528e0bbb0f2491",
                                               "139fe3d8efb20402"
                                O Offline
                                O Offline
                                Oli
                                @mickym
                                super, jetzt funktioniert es :-)
                                Oliver
                                • O Oli
                                  @mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @oli sagte in Benötige Hilfe mit Node-Red in Verbindung mit homee:
                                  @mickym
                                  Sehr gut. Dann probier halt erst mal bissi aus. Ggf. brauchst Du den Report nur wenn Du ihn antriggerst oder keine Ahnung ob der mit jedem Geräteupdate ausgegeben werden muss. Ich würde es nicht als final bezeichnen, aber es ist eine Basis damit Du die Zusammenhänge verstehst und das nun Deinen Bedürfnissen anpassen kannst.
                                  Und wie gesagt: Hänge Dir so viele Debug-Nodes dran, wie Du willst, nur so verstehst Du wie die Befehle funktionieren.
                                  O 1 Antwort Letzte Antwort
                                  • mickymM mickym
                                    @mickym
                                    O Offline
                                    O Offline
                                    Oli
                                    @mickym
                                    den Report bräuchte ich eigentlich nur, wenn sich am Gerätestatus was ändert,
                                    den oberen bräuchte ich ebenfalls nur wenn sich am Gerätestatus was ändert, oder ein neues gerät hinzukommt
                                    ist das möglich?
                                    Oliver
                                    • O Oli
                                      @mickym
                                      ist das möglich?
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @oli Du sollst das ja nicht als finalen Flow betrachten. Momentan kannst Du das mit der trigger Node anstossen. ;)
                                      Das hängt doch von "Dir" ab, was Du triggern lässt und wie Du das ermittelst. ;) Ggf. an der Stelle an der die globale Geräteliste zusammen gezimmert wird.
                                      Der Ersteller des ursprünglichen flows hatte das ja als Bedingung - aber das musst Du beurteilen:
                                      sprich NUR wenn payload eine Eigenschaft node hat oder true ist - und wenn sie eine Eigenschaft node hat - dann nur wenn die Geräte nicht verfügbar sind.
                                      Ob dass das ist, was Du willst - weiss ich nicht, aber dann hättest Du die gleiche Situation wie vorher.
                                      Dazu baust Du für Deine Trigger folgenden Filter davor:
                                             "id": "9c97a2e21b3710d3",
                                             "type": "switch",
                                             "name": "filter trigger",
                                             "property": "(payload.node and (payload.node.state =2 or payload.node.state = 12)) or payload = true",
                                             "propertyType": "jsonata",
                                             "rules": [
                                                     "t": "true"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 1,
                                             "x": 570,
                                             "y": 440,
                                             "wires": [
                                                     "0f17893e37ac0581"
                                      Wie gesagt - das ist der Filter der in der function Node war - wenn es andere Möglichkeiten gibt, dann musst du halt schauen. Ich überlege noch was anderes - aber das ist erst mal das, was bislang Dein jetziger Status mit dem anderen Flow war.
                                      • O Oli
                                        @mickym
                                        ist das möglich?
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @mickym
                                        ist das möglich?
                                        OK - habe ich Dir nun auch gemacht. Also nicht den Filter von dem ursprünglichen Flowersteller nehmen, sondern ich hab jetzt folgendes gebastelt: ;)
                                        • Es wird geprüft, ob es ein Gerät ist
                                        • Wenn ja wird es in die Nachrichteneigenschaft device geschoben
                                        • Dann wird wieder die komplette Geräteliste geholt
                                        • Dann wird das Gerät aus der Geräteliste selektiert und überprüft ob es vorhanden ist bzw. sich der status geändert hat und nur dann fortgesetzt.
                                        Statt der Inject Node ein Gerät - kannst dann wieder mit Deinem anderen Flow verlinken:
                                               "id": "94fbc6ce08554a92",
                                               "type": "inject",
                                               "name": "Ein Gerät",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "{\"node\":{\"id\":29,\"name\":\"EG%20%2F%20Wohnzimmer%20%2F%20Netatmo\",\"profile\":3014,\"image\":\"default\",\"favorite\":0,\"order\":42,\"protocol\":9,\"routing\":0,\"state\":1,\"state_changed\":1678428037,\"added\":1607519624,\"history\":0,\"cube_type\":8,\"note\":\"\",\"services\":5,\"phonetic_name\":\"Klima%20Wohnzimmer\",\"owner\":1,\"security\":0,\"attributes\":[{\"id\":253,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":50,\"current_value\":20.6,\"target_value\":20.6,\"last_value\":20.5,\"unit\":\"%C2%B0C\",\"step_value\":0.5,\"editable\":0,\"type\":5,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":254,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":33,\"target_value\":33,\"last_value\":34,\"unit\":\"%25\",\"step_value\":1,\"editable\":0,\"type\":7,\"state\":1,\"last_changed\":1678515784,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":255,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":5000,\"current_value\":444,\"target_value\":444,\"last_value\":449,\"unit\":\"ppm\",\"step_value\":50,\"editable\":0,\"type\":20,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":256,\"node_id\":29,\"instance\":0,\"minimum\":35,\"maximum\":120,\"current_value\":32,\"target_value\":32,\"last_value\":33,\"unit\":\"dB\",\"step_value\":1,\"editable\":0,\"type\":93,\"state\":1,\"last_changed\":1678515183,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":257,\"node_id\":29,\"instance\":0,\"minimum\":260,\"maximum\":1160,\"current_value\":1003.7,\"target_value\":1003.7,\"last_value\":1003.6,\"unit\":\"mBar\",\"step_value\":5,\"editable\":0,\"type\":94,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":258,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":4,\"target_value\":4,\"last_value\":2,\"unit\":\"n%2Fa\",\"step_value\":1,\"editable\":0,\"type\":33,\"state\":1,\"last_changed\":1677083197,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\"},{\"id\":475,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":1,\"target_value\":1,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":385,\"state\":1,\"last_changed\":0,\"changed_by\":0,\"changed_by_id\":0,\"based_on\":0,\"data\":\"\",\"name\":\"\"}]}}",
                                               "payloadType": "json",
                                               "x": 120,
                                               "y": 800,
                                               "wires": [
                                                       "e565ecbc06eb639f"
                                               "id": "306e283de06793a5",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "move",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "device",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 500,
                                               "y": 800,
                                               "wires": [
                                                       "3fcd14dd3eda98a3"
                                               "id": "3fcd14dd3eda98a3",
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "{}",
                                                       "tot": "json"
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "global"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 720,
                                               "y": 800,
                                               "wires": [
                                                       "3981f0834f60fe3d"
                                               "id": "3981f0834f60fe3d",
                                               "type": "switch",
                                               "name": "Nur wenn Gerätestatus geändert",
                                               "property": "payload.nodes[id=$$.device.node.id].state = device.node.state",
                                               "rules": [
                                                       "t": "false"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 970,
                                               "y": 800,
                                               "wires": [
                                                       "6f4c16eed7166074"
                                               "id": "e565ecbc06eb639f",
                                               "type": "switch",
                                               "name": "verify device",
                                               "property": "payload.node",
                                               "rules": [
                                                       "t": "nnull"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 290,
                                               "y": 800,
                                               "wires": [
                                                       "306e283de06793a5"
                                        Nachdem Du die Zusammenfassung automatisch haben willst kannst Du das mit einer Complete Node erledigen, später würde ich das alles wegschmeissen und mit dem Hauptflow zusammenführen.
                                               "id": "615f1d935afd46f7",
                                               "type": "complete",
                                               "z": "9c280ddf049b2b4d",
                                               "name": "",
                                               "scope": [
                                                   "99528e0bbb0f2491",
                                                   "43f88f1028d1af0a",
                                                   "139fe3d8efb20402"
                                               "uncaught": false,
                                               "x": 230,
                                               "y": 1260,
                                               "wires": [
                                                       "bb70522cf511b632"
                                        Falls in der Complete Node nichts ausgewählt ist dann halt diese 3 Change Nodes auswählen
                                        Wie gesagt final - wenn Du genug rumexperimentiert hast - würde ich das eh zusammenfassen.
                                        und hinten raus - den Report willst Du ja auch ganz anders gestalten.
                                        1. Konsolidierung:
                                               "id": "afaeceb73a81b97a",
                                               "type": "tab",
                                               "label": "Homee 1. Konsoldierung",
                                               "disabled": false,
                                               "info": "",
                                               "env": []
                                               "id": "1f31a8a611e8ae62",
                                               "type": "junction",
                                               "z": "afaeceb73a81b97a",
                                               "x": 1100,
                                               "y": 400,
                                               "wires": [
                                                       "d1362666d0d6498d",
                                                       "e5e4c67350b62fb9",
                                                       "9c0a0c2ec54309c4"
                                               "id": "d6ba83fcbbf8632b",
                                               "type": "junction",
                                               "x": 1560,
                                               "y": 260,
                                               "wires": [
                                                       "4fc32434b1ad9e30"
                                               "id": "ba0d73a9ecf905bb",
                                               "type": "junction",
                                               "x": 1500,
                                               "y": 400,
                                               "wires": [
                                                       "d6ba83fcbbf8632b"
                                               "id": "ccc13bcc415bf46d",
                                               "type": "change",
                                               "name": "decodeUrlComponents",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "payload ~> |$.nodes|{\"name\":$decodeUrlComponent(name),\t\"note\":$decodeUrlComponent(note),\t\"phonetic_name\":$decodeUrlComponent(phonetic_name)},\"attributes\"|",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 520,
                                               "y": 400,
                                               "wires": [
                                                       "c97f121d294f1458"
                                               "id": "c97f121d294f1458",
                                               "type": "change",
                                               "name": "Alle Geräte",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "payload.nodes",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 730,
                                               "y": 400,
                                               "wires": [
                                                       "913391f5d68d5666"
                                               "id": "e5e4c67350b62fb9",
                                               "type": "change",
                                               "name": "Alle inaktiven Geräte",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "payload[state = 2]",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "homee.inactive",
                                                       "pt": "flow",
                                                       "to": "payload",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1320,
                                               "y": 400,
                                               "wires": [
                                                       "ba0d73a9ecf905bb"
                                               "id": "9c0a0c2ec54309c4",
                                               "type": "change",
                                               "name": "Alle aktiven Geräte",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "payload[state = 1]",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "homee.active",
                                                       "pt": "flow",
                                                       "to": "payload",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1330,
                                               "y": 340,
                                               "wires": [
                                                       "ba0d73a9ecf905bb"
                                               "id": "d1362666d0d6498d",
                                               "type": "change",
                                               "name": "Geräte, die aktualisiert werden",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "payload[state = 12] ",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "homee.updating",
                                                       "pt": "flow",
                                                       "to": "payload",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1290,
                                               "y": 460,
                                               "wires": [
                                                       "ba0d73a9ecf905bb"
                                               "id": "913391f5d68d5666",
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 940,
                                               "y": 400,
                                               "wires": [
                                                       "1f31a8a611e8ae62"
                                               "id": "bf00496a9f44421a",
                                               "type": "inject",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "",
                                               "x": 1330,
                                               "y": 200,
                                               "wires": [
                                                       "d6ba83fcbbf8632b"
                                               "id": "ee98fce5a9a9aa0a",
                                               "name": "start",
                                               "onlyack": "",
                                               "func": "all",
                                               "gap": "",
                                               "x": 1350,
                                               "y": 260,
                                               "wires": [
                                                       "d6ba83fcbbf8632b"
                                               "id": "f750a4c387a2be4e",
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "{}",
                                                       "tot": "json"
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "global"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 280,
                                               "y": 400,
                                               "wires": [
                                                       "ccc13bcc415bf46d"
                                               "id": "bc3f5ae2440a7bd8",
                                               "type": "inject",
                                               "name": "trigger",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "true",
                                               "x": 110,
                                               "y": 400,
                                               "wires": [
                                                       "f750a4c387a2be4e"
                                               "id": "cb19c80f141b5ec7",
                                               "type": "inject",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "x": 60,
                                               "y": 520,
                                               "wires": [
                                                       "477f8cdd68a623d6"
                                               "id": "ea25ff19366dbd8b",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "move",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "device",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 440,
                                               "y": 520,
                                               "wires": [
                                                       "13fef03679554dae"
                                               "id": "13fef03679554dae",
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "{}",
                                                       "tot": "json"
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "global"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 660,
                                               "y": 520,
                                               "wires": [
                                                       "3e5a3f328d92cbec"
                                               "id": "3e5a3f328d92cbec",
                                               "type": "switch",
                                               "rules": [
                                                       "t": "false"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 910,
                                               "y": 520,
                                               "wires": [
                                                       "ccc13bcc415bf46d"
                                               "id": "477f8cdd68a623d6",
                                               "type": "switch",
                                               "rules": [
                                                       "t": "nnull"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 230,
                                               "y": 520,
                                               "wires": [
                                                       "ea25ff19366dbd8b"
                                               "id": "4fc32434b1ad9e30",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "homee",
                                                       "tot": "flow"
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1710,
                                               "y": 260,
                                               "wires": [
                                                       "93b337c8b0c958f0",
                                                       "6208fe0589c08c8c",
                                                       "91df4ca35b0811b5",
                                                       "a9b7cfa0138adb7c"
                                               "id": "93b337c8b0c958f0",
                                               "type": "template",
                                               "name": "",
                                               "field": "payload",
                                               "fieldType": "msg",
                                               "format": "html",
                                               "output": "str",
                                               "x": 1940,
                                               "y": 260,
                                               "wires": [
                                                       "bd020f5de81b6984"
                                               "id": "1b3a14e37e06a753",
                                               "type": "file",
                                               "name": "",
                                               "createDir": false,
                                               "encoding": "none",
                                               "x": 2360,
                                               "y": 260,
                                               "wires": [
                                               "id": "bd020f5de81b6984",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "filename",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2150,
                                               "y": 260,
                                               "wires": [
                                                       "1b3a14e37e06a753"
                                               "id": "6208fe0589c08c8c",
                                               "type": "switch",
                                               "name": "",
                                               "rules": [
                                                       "t": "neq",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 1930,
                                               "y": 340,
                                               "wires": [
                                                       "e7ee2a2337e50af1"
                                               "id": "f533e9122ec7d98d",
                                               "type": "debug",
                                               "active": false,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "complete": "payload",
                                               "targetType": "msg",
                                               "statusVal": "",
                                               "statusType": "auto",
                                               "x": 2430,
                                               "y": 340,
                                               "wires": []
                                               "id": "e7ee2a2337e50af1",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2110,
                                               "y": 340,
                                               "wires": [
                                                       "f533e9122ec7d98d"
                                               "id": "91df4ca35b0811b5",
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2000,
                                               "y": 420,
                                               "wires": [
                                                       "49ce4151b0046769"
                                               "id": "49ce4151b0046769",
                                               "type": "debug",
                                               "active": false,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2340,
                                               "y": 420,
                                               "wires": []
                                               "id": "a9b7cfa0138adb7c",
                                               "type": "debug",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1970,
                                               "y": 200,
                                               "wires": []
                                        • mickymM mickym
                                          @mickym
                                          ist das möglich?
                                                 "type": "inject",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 120,
                                                 "y": 800,
                                                 "wires": [
                                                         "e565ecbc06eb639f"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "move",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "device",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 500,
                                                 "y": 800,
                                                 "wires": [
                                                         "3fcd14dd3eda98a3"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "{}",
                                                         "tot": "json"
                                                         "t": "set",
                                                         "pt": "msg",
                                                         "tot": "global"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 720,
                                                 "y": 800,
                                                 "wires": [
                                                         "3981f0834f60fe3d"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 970,
                                                 "y": 800,
                                                 "wires": [
                                                         "6f4c16eed7166074"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "nnull"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 290,
                                                 "y": 800,
                                                 "wires": [
                                                         "306e283de06793a5"
                                                 "type": "complete",
                                                 "name": "",
                                                 "scope": [
                                                     "99528e0bbb0f2491",
                                                     "43f88f1028d1af0a",
                                                     "139fe3d8efb20402"
                                                 "uncaught": false,
                                                 "x": 230,
                                                 "y": 1260,
                                                 "wires": [
                                                         "bb70522cf511b632"
                                          1. Konsolidierung:
                                                 "type": "tab",
                                                 "disabled": false,
                                                 "info": "",
                                                 "env": []
                                                 "type": "junction",
                                                 "x": 1100,
                                                 "y": 400,
                                                 "wires": [
                                                         "d1362666d0d6498d",
                                                         "e5e4c67350b62fb9",
                                                         "9c0a0c2ec54309c4"
                                                 "type": "junction",
                                                 "x": 1560,
                                                 "y": 260,
                                                 "wires": [
                                                         "4fc32434b1ad9e30"
                                                 "type": "junction",
                                                 "x": 1500,
                                                 "y": 400,
                                                 "wires": [
                                                         "d6ba83fcbbf8632b"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 520,
                                                 "y": 400,
                                                 "wires": [
                                                         "c97f121d294f1458"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 730,
                                                 "y": 400,
                                                 "wires": [
                                                         "913391f5d68d5666"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "pt": "flow",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1320,
                                                 "y": 400,
                                                 "wires": [
                                                         "ba0d73a9ecf905bb"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "pt": "flow",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1330,
                                                 "y": 340,
                                                 "wires": [
                                                         "ba0d73a9ecf905bb"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "pt": "flow",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1290,
                                                 "y": 460,
                                                 "wires": [
                                                         "ba0d73a9ecf905bb"
                                                 "type": "change",
                                                 "name": "Geräte ausschliessen",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "payload ~> $filter(function($value){$value.id in [-1] != true})",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 940,
                                                 "y": 400,
                                                 "wires": [
                                                         "1f31a8a611e8ae62"
                                                 "type": "inject",
                                                 "name": "Trigger Report",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "",
                                                 "payloadType": "date",
                                                 "x": 1330,
                                                 "y": 200,
                                                 "wires": [
                                                         "d6ba83fcbbf8632b"
                                                 "type": "ioBroker in",
                                                 "name": "start",
                                                 "topic": "0_userdata.0.System.homee.StartGeräteinfo",
                                                 "payloadType": "value",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "fireOnStart": "false",
                                                 "outFormat": "MQTT",
                                                 "x": 1350,
                                                 "y": 260,
                                                 "wires": [
                                                         "d6ba83fcbbf8632b"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "{}",
                                                         "tot": "json"
                                                         "t": "set",
                                                         "pt": "msg",
                                                         "tot": "global"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 280,
                                                 "y": 400,
                                                 "wires": [
                                                         "ccc13bcc415bf46d"
                                                 "type": "inject",
                                                 "name": "trigger",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "true",
                                                 "x": 110,
                                                 "y": 400,
                                                 "wires": [
                                                         "f750a4c387a2be4e"
                                                 "type": "inject",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 60,
                                                 "y": 520,
                                                 "wires": [
                                                         "477f8cdd68a623d6"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "move",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "device",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 440,
                                                 "y": 520,
                                                 "wires": [
                                                         "13fef03679554dae"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "{}",
                                                         "tot": "json"
                                                         "t": "set",
                                                         "pt": "msg",
                                                         "tot": "global"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 660,
                                                 "y": 520,
                                                 "wires": [
                                                         "3e5a3f328d92cbec"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 910,
                                                 "y": 520,
                                                 "wires": [
                                                         "ccc13bcc415bf46d"
                                                 "type": "switch",
                                                 "propertyType": "msg",
                                                 "rules": [
                                                         "t": "nnull"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 230,
                                                 "y": 520,
                                                 "wires": [
                                                         "ea25ff19366dbd8b"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "homee",
                                                         "tot": "flow"
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "{\t   \"active\" : {\t       \"count\": payload.active ? $count(payload.active): 0,\t       \"names\" :  payload.active ?  $join(payload.active.phonetic_name,\"\\n\") : \"Keine aktiven Geräte vorhanden\"\t   },\t   \"inactive\" : {\t       \"count\": payload.inactive ? $count(payload.inactive): 0,\t        \"names\" :  payload.inactive ?  $join(payload.inactive.phonetic_name,\"\\n\") : \"Keine inaktiven Geräte vorhanden\"\t   },\t   \"updating\" : {\t       \"count\": payload.updating ? $count(payload.inactive): 0,\t        \"names\" :  payload.updating ?  $join(payload.updating.phonetic_name,\"\\n\") : \"Keine Geräte im Aktualisierungsstatus\"\t   },\t   \"summary\" : payload.updating or payload.inactive ? \"Nicht alle Geräte bereit!\" : \"Alle Geräte aktiv\"\t}",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1710,
                                                 "y": 260,
                                                 "wires": [
                                                         "93b337c8b0c958f0",
                                                         "6208fe0589c08c8c",
                                                         "91df4ca35b0811b5",
                                                         "a9b7cfa0138adb7c"
                                                 "type": "template",
                                                 "name": "",
                                                 "field": "payload",
                                                 "fieldType": "msg",
                                                 "format": "html",
                                                 "syntax": "mustache",
                                                 "template": "<!DOCTYPE html>\n<html>\n\n<body>\n<h1>Status der Geräte:</h1>\n\n<h3>aktive Geräte: {{payload.active.count}}\n<pre>{{payload.active.names}}</pre>\n\n<h3>inaktive Geräte: {{payload.inactive.count}}\n<pre>{{payload.inactive.names}}</pre>\n\n<h3>aktualisierende Geräte: {{payload.updating.count}}\n<pre>{{payload.updating.names}}</pre>\n\n<h3>{{payload.summary}}</h3>\n</body>\n</html>",
                                                 "output": "str",
                                                 "x": 1940,
                                                 "y": 260,
                                                 "wires": [
                                                         "bd020f5de81b6984"
                                                 "type": "file",
                                                 "name": "",
                                                 "filename": "filename",
                                                 "filenameType": "msg",
                                                 "appendNewline": false,
                                                 "createDir": false,
                                                 "overwriteFile": "true",
                                                 "encoding": "none",
                                                 "x": 2360,
                                                 "y": 260,
                                                 "wires": [
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "filename",
                                                         "pt": "msg",
                                                         "to": "/home/iobroker/homee-report.html",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2150,
                                                 "y": 260,
                                                 "wires": [
                                                         "1b3a14e37e06a753"
                                                 "type": "switch",
                                                 "name": "",
                                                 "property": "payload.summary",
                                                 "rules": [
                                                         "t": "neq",
                                                         "v": "Alle Geräte aktiv",
                                                         "vt": "str"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 1930,
                                                 "y": 340,
                                                 "wires": [
                                                         "e7ee2a2337e50af1"
                                                 "type": "debug",
                                                 "name": "Warnung ausgeben - wenn nicht alle Geräte aktiv",
                                                 "active": false,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 2430,
                                                 "y": 340,
                                                 "wires": []
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "payload.summary",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2110,
                                                 "y": 340,
                                                 "wires": [
                                                         "f533e9122ec7d98d"
                                                 "type": "change",
                                                 "name": "Anzahl nicht aktiver Geräte",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "payload.inactive.count + payload.updating.count",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2000,
                                                 "y": 420,
                                                 "wires": [
                                                         "49ce4151b0046769"
                                                 "type": "debug",
                                                 "name": "Nicht aktive Geräte (updating oder inaktiv)",
                                                 "active": false,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 2340,
                                                 "y": 420,
                                                 "wires": []
                                                 "type": "debug",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1970,
                                                 "y": 200,
                                                 "wires": []
                                          O Offline
                                          O Offline
                                          Oli
                                          @mickym
                                          oh, oh, dass ging mir jetzt alles zu schnell, also nochmal zum mitschreiben für dumme wie mich.
                                          1. den unteren Teil des ersten Flow kann ich löschen und dafür den neuen Flow Konsolidierung importieren?
                                          2. Muss ich am "Ein Gerät" noch etwas ändern oder nachtragen?
                                          3. habe ich nicht begriffe, was "Ein Gerät" bewirkt?
                                          Oliver
