    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • T tklein
    wo muss ich das einstellen/hinzufügen?
    export const config: Config = {
        mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_E7F5D8.POWER1, ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: Off  },
        mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_E7F5D8.POWER1', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: Off  },
    Hier reinfügen?
    Sorry bin sonst primär nur in Blockly unterwegs. :-)
    TT-Tom
    #2491
    @tklein Die Icon werden jetzt so konfiguriert.
                ScreensaverEntity: NSPanel_Path + 'Relay.1',
                ScreensaverEntityIconOn: 'lightbulb',                           //Rename
                ScreensaverEntityIconOff: null,
                ScreensaverEntityValue: null,                                   //New
                ScreensaverEntityValueDecimalPlace : 0,                         //New
                ScreensaverEntityValueUnit: null,                               //New
                ScreensaverEntityOffColor: HMIOff
                ScreensaverEntity: 'deconz.0.Sensors.5.open',
                ScreensaverEntityIconOn: 'heat-wave',
                ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                ScreensaverEntityValueDecimalPlace : 1,
                ScreensaverEntityValueUnit: '°',
                ScreensaverEntityOnColor: MSRed,
                ScreensaverEntityOffColor: Yellow
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T tklein
      @tt-tom klasse, besten Dank,
      Was/wo kann ich bei diesem Fehler machen?
      10:18:00.185	warn	javascript.0 (28654) at HandleScreensaverStatusIcons (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:8133:25)
      10:18:00.185	warn	javascript.0 (28654) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:8044:13)
      10:18:00.186	warn	javascript.0 (28654) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:2619:9)
      10:18:00.188	warn	javascript.0 (28654) at HandleScreensaverStatusIcons (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:8155:30)
      10:18:00.189	warn	javascript.0 (28654) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:8044:13)
      10:18:00.189	warn	javascript.0 (28654) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_03_08:2619:9)
      L4rs
      schrieb am zuletzt editiert von L4rs
      #2492
      Moin @tklein, Schau Dir mal die Stelle zur 'bottomScreensaverEntity 4' NsPanelTs_without_Examples, Zeile 693ff. an:
                  // bottomScreensaverEntity 4
                      ScreensaverEntity: '0_userdata.0.wetter.Windrichtung',
                      ScreensaverEntityFactor: 0,
                      ScreensaverEntityDecimalPlaces: 0,
                      ScreensaverEntityIconOn: 'windsock',
                      ScreensaverEntityText: 'Windr.',
                      ScreensaverEntityUnitText: '°',
                      ScreensaverEntityIconColor: White
      Dort wird auf '0_userdata.0.wetter.Windrichtung' zugegriffen - den DP gab es bei mir aber nicht, weshalb ich hier ähnliche Fehler hatte. Vielleicht liegt es bei Dir auch daran?
      Gruß, L4rs
        Sniker
        schrieb am zuletzt editiert von Sniker
        #2493
        kann mir jemand sagen wie ich mein NSpanel aktualisiere. Ich müsst noch einen recht alten stand haben 3.6.0.3. Kann in der Doku nicht wirklich was dazu finden.
        Muss ich dazu Tasmota aktualisieren, nur das Script oder die autoexec?
        • S Sniker
          TT-Tom
          #2494
          @sniker ein paar Seiten zurück war das grade Thema gewesen. @tklein hat/läuft auch grade den Prozess durch. Wenn noch Fragen offen sind hier melden.
          Gruß Tom
          Public Transport
          • ? Offline
            #2495
            Guten Morgen.
            Ich wollte gerade bei meinem Panel die TFT-Firmware aktualisieren. Aber es kommt folgender Fehler:
            00:00:52.808 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF1AFFFFFF1AFFFFFF')]
            00:00:52.955 FLH: Send (High Speed) flash start
            00:00:53.306 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
            Vorher habe ich
            Backlog UrlFetch https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
            ausgeführt
              Guten Morgen.
              Vorher habe ich
              ausgeführt
              TT-Tom
              #2496
              @darkness_08
              Welche Version hast du aktuell installiert?
              Tasmota
              Berry
              TFT
              Gruß Tom
              Public Transport
              • L L4rs
                Gruß, L4rs
                tklein
                #2497
                @l4rs said in SONOFF NSPanel mit Lovelace UI:
                Gruß, L4rs
                @l4rs Hi,
                vielen Dank für den Tip! Es lag daran.
                Habe jetzt eine DP vom Netamo Crawler Adapter genommen. Der gibt die Himmelsrichtungen und nicht die Gradzahl von der Windrichtung aus.
                Mal sehen oben ich eine Funktion finde, die aus Gradangaben eine Windrichtung wie N oder SW macht.
                Thomas
                L 1 Antwort Letzte Antwort
                • T TT-Tom
                  @darkness_08
                  Tasmota
                  Berry
                  TFT
                  #2498
                  @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                  @darkness_08
                  Tasmota
                  Berry
                  TFT
                  Tasmota:
                  12.4.0(nspanel)
                  Berry:
                  TFT:
                  50 / v4.0.3
                  Ich hoffe das waren die richtigen Werte die du brauchst. Jeweils die "currentVersion"
                    @darkness_08
                    Tasmota
                    Berry
                    TFT
                    Tasmota:
                    12.4.0(nspanel)
                    Berry:
                    TFT:
                    50 / v4.0.3
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    Most Active Forum Testing
                    #2499
                    @darkness_08
                    Versuche mal eine von denen:
                    Nextion Upload Proto 1.2 with 921600 Baud (same as FlashNextion):
                    FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.1 with 921600 Baud:
                    FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.2 with 115200 Baud:
                    FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.1 with 115200 Baud:
                    FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.2 with 256000 Baud:
                    FlashNextionAdv4 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.1 with 256000 Baud:
                    FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
                    Nextion Upload Proto 1.1 with 921600 Baud and communication init on 9600 Baud:
                    FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
                    • ArmilarA Armilar
                      @darkness_08
                      #2500
                      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                      Leider kein Erfolg.
                      @darkness_08
                      06:10:45.504 CMD: FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
                      06:10:45.518 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      06:10:45.559 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      06:10:46.730 FLH: Send (High Speed) flash start
                      06:10:47.083 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:15.174 CMD: FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
                      00:00:15.188 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:15.227 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      00:00:16.397 FLH: Send (High Speed) flash start
                      00:00:16.749 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:19.023 CMD: FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
                      00:00:19.036 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:19.075 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      00:00:20.100 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF1AFFFFFF1AFFFFFF')]
                      00:00:20.246 FLH: Send (High Speed) flash start
                      00:00:20.598 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:29.204 CMD: FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
                      00:00:29.217 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:29.240 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      00:00:30.415 FLH: Send (High Speed) flash start
                      00:00:30.862 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:19.069 CMD: FlashNextionAdv4 http://nspanel.pky.eu/lui.tf
                      00:00:19.084 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:19.125 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tf
                      00:00:20.299 FLH: Send (High Speed) flash start
                      00:00:20.746 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:15.294 CMD: FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
                      00:00:15.307 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:15.348 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      00:00:16.519 FLH: Send (High Speed) flash start
                      00:00:16.870 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                      00:00:15.539 CMD: FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
                      00:00:15.552 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                      00:00:15.603 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                      00:00:16.624 FLH: Something has gone wrong flashing display firmware [bytes('8FDEFB')]
                      • T tklein
                        Gruß, L4rs
                        @l4rs Hi,
                        Thomas
                        L4rs
                        #2501
                        @tklein said in SONOFF NSPanel mit Lovelace UI:
                        Du könntest z.B. diese nehmen: 😉
                        function gradeToDirection(grade) {
                          grade = parseFloat(grade);
                          if (isNaN(grade) || grade < 0.0 || grade > 360.0) {
                            return "--";
                          if (grade < 11.25 || grade >= 348.75) {
                            return "N";
                          } else {
                            const directions = {
                              NNO:  22.5,      NO:  45.0,      ONO:  67.5,      O:  90.0,
                              OSO: 112.5,      SO: 135.0,      SSO: 157.5,      S: 180.0,
                              SSW: 202.5,      SW: 225.0,      WSW: 247.5,      W: 270.0,
                              WNW: 292.5,      NW: 315.0,      NNW: 337.5,
                            for (const [key, val] of Object.entries(directions)) {
                              if (grade >= val - 11.25 && grade < val + 11.25) {
                                return key;
                        Gruß, L4rs
                        • T TT-Tom
                          Sniker
                          #2502
                          @tt-tom danke dir. Ich habe es irgendwie hin bekommen. Mein Problem ist halt, das wenn ich zu lang nicht am NS Panel was gemacht habe, da wieder rein zu kommen. Aber eine Anleitung wie man richtig vorgeht bei update, fehlt trotzdem irgendwie.
                            Leider kein Erfolg.
                            @darkness_08
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #2503
                            @darkness_08
                            Hängt dein NSPanel nicht im Internet? Gastzugang oder irgendetwas anderes? Sieht so aus, als käme es an die URL nicht ran.
                            ? 2 Antworten Letzte Antwort
                            • S Sniker
                              TT-Tom
                              #2504
                              @sniker okay, welche Informationen wären für dich hilfreich gewesen? Da du es jetzt geschafft hast, kannst du uns da unterstützen, wo die Stolperstellen sind. Wir nehmen sie dann im Wiki auf. Danke
                              Gruß Tom
                              Public Transport
                              • ArmilarA Armilar
                                @darkness_08
                                #2505
                                @armilar
                                Doch, hat ganz normalen zugriff. Aber irgendwas scheint da jetzt durcheinander zu sein. Der Screensaver startet auch nicht mehr. Ich werde es mal neu bespielen und mal gucken.
                                • ArmilarA Armilar
                                  @darkness_08
                                  #2506
                                  @armilar
                                  Oh, man.Sorrryyyy :)
                                  Hat alles geklappt. Ich hatte dem Panel eine StaticIP zugewiesen aber vergessen den DNS-Server zu hinterlegen. Deshalb konnte die Auflösung nicht klappen.
                                  Jetzt geht es. Tut mir leid für die Verwirrung.
                                  • Dark AngelD Offline
                                    Dark AngelD Offline
                                    Dark Angel
                                    schrieb am zuletzt editiert von Dark Angel
                                    #2507
                                    Hi Leute,
                                    seit geraumer Zeit habe ich das Problem, dass beim betätigen der Hardwarebuttons der Status unter 0_userdata.0.NSPanel.1.Relay.1 nicht aktualisiert wird, was dazu führt, dass weder die Symbole in den oberen Ecken in Screensaver den geänderten Zustand anzeigen, noch der richtige Status im Jarvis angezeigt wird.
                                    Wenn ich die Softwareschalter unter Einstellungen benutze, wird auch der Status unter 0_userdata.0.NSPanel.1.Relay.1 richtig geändert und auch in Jarvis richtig angezeigt. Auch wenn ich über Jarvis die Schalter die Schalter betätige wird der Status unter 0_userdata.0.NSPanel.1.Relay.1 und in den oberen Ecken am Dysplay richtig angezeigt.
                                    In alle Fälle gehen jedoch die Lichter ganz normal an und aus.
                                    Habe die Tage erst das Script auf Version 4.0.4 ( auch TFT 50 und BerryDriver 8 ) aktualisiert, in der Hoffnung, dass es wieder funktionieren wird, aber dem war leider nicht so.
                                    Hat jemand eine Tipp?
                                    • Dark AngelD Dark Angel
                                      Hi Leute,
                                      TT-Tom
                                      #2508
                                      Hi @dark-angel
                                      Tasmota hast du auch auf dem aktuellen Stand?
                                      Wie ist die Konfiguration deiner Button, hast du sie von den Relais entkoppelt?
                                      Schaltest du mit den Relais die Lampen?
                                      Gruß Tom
                                      Public Transport
                                      Dark AngelD 1 Antwort Letzte Antwort
                                        tklein
                                        #2509
                                        wie bekomme ich diesen View weg? Der ist von einer älteren Projektversion bzw. Datei.
                                        Den Screen gibt es in der aktuellen Config gar nicht mehr.
                                        Nach dem Updates (Display,Berry, Tasmota) habe ich nur mit der neuen Projektdatei gearbeitet. Stromlos über Nacht brachte auch keinen Erfolg.
                                        WhatsApp Video 2023-03-11 at 11.06.58.mp4
                                        • T tklein
                                          TT-Tom
                                          #2510
                                          @tklein
                                          zeige bitte mal die Config deiner Pages, es muss eine Page mit der Überschrift / heading "Wohnzimmer" geben. Vielleicht ist diese noch falsch konfiguriert.
                                          gibt es Fehlermeldungen im LOG. ggf. den JavaScript Adapter neu starten.
                                          Gruß Tom
                                          Public Transport
                                          T 2 Antworten Letzte Antwort
