    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
    @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
    @darkness_08
    Welche Version hast du aktuell installiert?
    Tasmota
    Berry
    TFT
    Tasmota:
    12.4.0(nspanel)
    Berry:
    TFT:
    50 / v4.0.3
    Ich hoffe das waren die richtigen Werte die du brauchst. Jeweils die "currentVersion"
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #2499
    @darkness_08
    Versuche mal eine von denen:
    Nextion Upload Proto 1.2 with 921600 Baud (same as FlashNextion):
    FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.1 with 921600 Baud:
    FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.2 with 115200 Baud:
    FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.1 with 115200 Baud:
    FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.2 with 256000 Baud:
    FlashNextionAdv4 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.1 with 256000 Baud:
    FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
    Nextion Upload Proto 1.1 with 921600 Baud and communication init on 9600 Baud:
    FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
    • ArmilarA Armilar
      @darkness_08
      #2500
      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
      Leider kein Erfolg.
      @darkness_08
      06:10:45.504 CMD: FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
      06:10:45.518 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      06:10:45.559 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      06:10:46.730 FLH: Send (High Speed) flash start
      06:10:47.083 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:15.174 CMD: FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
      00:00:15.188 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:15.227 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      00:00:16.397 FLH: Send (High Speed) flash start
      00:00:16.749 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:19.023 CMD: FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
      00:00:19.036 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:19.075 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      00:00:20.100 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF1AFFFFFF1AFFFFFF')]
      00:00:20.246 FLH: Send (High Speed) flash start
      00:00:20.598 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:29.204 CMD: FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
      00:00:29.217 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:29.240 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      00:00:30.415 FLH: Send (High Speed) flash start
      00:00:30.862 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:19.069 CMD: FlashNextionAdv4 http://nspanel.pky.eu/lui.tf
      00:00:19.084 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:19.125 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tf
      00:00:20.299 FLH: Send (High Speed) flash start
      00:00:20.746 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:15.294 CMD: FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
      00:00:15.307 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:15.348 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      00:00:16.519 FLH: Send (High Speed) flash start
      00:00:16.870 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      00:00:15.539 CMD: FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
      00:00:15.552 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
      00:00:15.603 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
      00:00:16.624 FLH: Something has gone wrong flashing display firmware [bytes('8FDEFB')]
      • T tklein
        @l4rs said in SONOFF NSPanel mit Lovelace UI:
        Dort wird auf '0_userdata.0.wetter.Windrichtung' zugegriffen - den DP gab es bei mir aber nicht, weshalb ich hier ähnliche Fehler hatte. Vielleicht liegt es bei Dir auch daran?
        Gruß, L4rs
        @l4rs Hi,
        vielen Dank für den Tip! Es lag daran.
        Habe jetzt eine DP vom Netamo Crawler Adapter genommen. Der gibt die Himmelsrichtungen und nicht die Gradzahl von der Windrichtung aus.
        Mal sehen oben ich eine Funktion finde, die aus Gradangaben eine Windrichtung wie N oder SW macht.
        Thomas
        L4rs
        schrieb am zuletzt editiert von L4rs
        #2501
        @tklein said in SONOFF NSPanel mit Lovelace UI:
        Du könntest z.B. diese nehmen: 😉
        function gradeToDirection(grade) {
          grade = parseFloat(grade);
          if (isNaN(grade) || grade < 0.0 || grade > 360.0) {
            return "--";
          if (grade < 11.25 || grade >= 348.75) {
            return "N";
          } else {
            const directions = {
              NNO:  22.5,      NO:  45.0,      ONO:  67.5,      O:  90.0,
              OSO: 112.5,      SO: 135.0,      SSO: 157.5,      S: 180.0,
              SSW: 202.5,      SW: 225.0,      WSW: 247.5,      W: 270.0,
              WNW: 292.5,      NW: 315.0,      NNW: 337.5,
            for (const [key, val] of Object.entries(directions)) {
              if (grade >= val - 11.25 && grade < val + 11.25) {
                return key;
        Gruß, L4rs
        • T TT-Tom
          @sniker ein paar Seiten zurück war das grade Thema gewesen. @tklein hat/läuft auch grade den Prozess durch. Wenn noch Fragen offen sind hier melden.
          Sniker
          #2502
          @tt-tom danke dir. Ich habe es irgendwie hin bekommen. Mein Problem ist halt, das wenn ich zu lang nicht am NS Panel was gemacht habe, da wieder rein zu kommen. Aber eine Anleitung wie man richtig vorgeht bei update, fehlt trotzdem irgendwie.
            Leider kein Erfolg.
            @darkness_08
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #2503
            @darkness_08
            Hängt dein NSPanel nicht im Internet? Gastzugang oder irgendetwas anderes? Sieht so aus, als käme es an die URL nicht ran.
            ? 2 Antworten Letzte Antwort
            • S Sniker
              TT-Tom
              #2504
              @sniker okay, welche Informationen wären für dich hilfreich gewesen? Da du es jetzt geschafft hast, kannst du uns da unterstützen, wo die Stolperstellen sind. Wir nehmen sie dann im Wiki auf. Danke
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • ArmilarA Armilar
                @darkness_08
                #2505
                @armilar
                Doch, hat ganz normalen zugriff. Aber irgendwas scheint da jetzt durcheinander zu sein. Der Screensaver startet auch nicht mehr. Ich werde es mal neu bespielen und mal gucken.
                • ArmilarA Armilar
                  @darkness_08
                  #2506
                  @armilar
                  Oh, man.Sorrryyyy :)
                  Hat alles geklappt. Ich hatte dem Panel eine StaticIP zugewiesen aber vergessen den DNS-Server zu hinterlegen. Deshalb konnte die Auflösung nicht klappen.
                  Jetzt geht es. Tut mir leid für die Verwirrung.
                  • Dark AngelD Offline
                    Dark AngelD Offline
                    Dark Angel
                    schrieb am zuletzt editiert von Dark Angel
                    #2507
                    Hi Leute,
                    seit geraumer Zeit habe ich das Problem, dass beim betätigen der Hardwarebuttons der Status unter 0_userdata.0.NSPanel.1.Relay.1 nicht aktualisiert wird, was dazu führt, dass weder die Symbole in den oberen Ecken in Screensaver den geänderten Zustand anzeigen, noch der richtige Status im Jarvis angezeigt wird.
                    Wenn ich die Softwareschalter unter Einstellungen benutze, wird auch der Status unter 0_userdata.0.NSPanel.1.Relay.1 richtig geändert und auch in Jarvis richtig angezeigt. Auch wenn ich über Jarvis die Schalter die Schalter betätige wird der Status unter 0_userdata.0.NSPanel.1.Relay.1 und in den oberen Ecken am Dysplay richtig angezeigt.
                    In alle Fälle gehen jedoch die Lichter ganz normal an und aus.
                    Habe die Tage erst das Script auf Version 4.0.4 ( auch TFT 50 und BerryDriver 8 ) aktualisiert, in der Hoffnung, dass es wieder funktionieren wird, aber dem war leider nicht so.
                    Hat jemand eine Tipp?
                    • Dark AngelD Dark Angel
                      Hi Leute,
                      TT-Tom
                      #2508
                      Hi @dark-angel
                      Tasmota hast du auch auf dem aktuellen Stand?
                      Wie ist die Konfiguration deiner Button, hast du sie von den Relais entkoppelt?
                      Schaltest du mit den Relais die Lampen?
                      Gruß Tom
                      Public Transport
                      Dark AngelD 1 Antwort Letzte Antwort
                        tklein
                        #2509
                        wie bekomme ich diesen View weg? Der ist von einer älteren Projektversion bzw. Datei.
                        Den Screen gibt es in der aktuellen Config gar nicht mehr.
                        Nach dem Updates (Display,Berry, Tasmota) habe ich nur mit der neuen Projektdatei gearbeitet. Stromlos über Nacht brachte auch keinen Erfolg.
                        WhatsApp Video 2023-03-11 at 11.06.58.mp4
                        • T tklein
                          TT-Tom
                          #2510
                          @tklein
                          zeige bitte mal die Config deiner Pages, es muss eine Page mit der Überschrift / heading "Wohnzimmer" geben. Vielleicht ist diese noch falsch konfiguriert.
                          gibt es Fehlermeldungen im LOG. ggf. den JavaScript Adapter neu starten.
                          Gruß Tom
                          Public Transport
                          T 2 Antworten Letzte Antwort
                          • T TT-Tom
                            @tklein
                            tklein
                            schrieb am zuletzt editiert von tklein
                            #2511
                            @tt-tom
                            // Eigene Views
                            let WZ_Thermostat = <PageThermo>
                                'type': 'cardThermo',
                                'heading': 'Wohnzimmer Thermostat',
                                'useColor': true,
                                'items': [<PageItem>{
                                            minValue: 50,
                                            maxValue: 300,
                                            stepValue: 5
                            let WP_Thermostat = <PageThermo>
                                'heading': 'Whirlpool Thermostat',
                                'useColor': true,
                                            minValue: 50,
                                            maxValue: 400,
                                            stepValue: 5
                            sowie:
                                pages: [
                             //           Buero_Seite_1,          //Beispiel-Seite
                                        WZ_Thermostat,
                                        WP_Thermostat,
                            //            WLED,                   //Beispiel-Seite
                            //            Radiosender,            //Beispiel-Seite
                            //            SensorGrid,             //Beispiel-Seite
                            //            CardLChartExample,      //Beispiel-Seite
                            //            CardChartExample,       //Beispiel-Seite
                             //           CardPowerExample,       //Beispiel-Seite
                                        //SqueezeboxRPC,        //Beispiel-Seite
                            //            Sonos,                  //Beispiel-Seite
                            //            SpotifyPremium,         //Beispiel-Seite
                             //           Alexa,                  //Beispiel-Seite
                             //           Buero_Seite_2,          //Beispiel-Seite
                             //           Buero_Klimaanlage,      //Beispiel-Seite
                             //           Button_1,               //Beispiel-Seite
                            //            Test_Licht1,            //Beispiel-Seite
                            //            Test_Licht2,            //Beispiel-Seite
                            //            Test_Funktionen,        //Beispiel-Seite
                            //            Fenster_1,              //Beispiel-Seite
                            //            Subpages_1,             //Beispiel-Seite
                            //            Buero_Themostat,        //Beispiel-Seite
                            //            Buero_Alarm,            //Beispiel-Seite
                            	    //Unlock_Service,
                                        NSPanel_Service         //Auto-Alias Service Page
                                subPages: [
                                            Abfall,                                 //Beispiel-Unterseite
                                            WLAN,                                   //Beispiel-Unterseite
                                            NSPanel_Infos,                          //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                                                NSPanel_Sensoren,                   //Auto-Alias Service Page
                                                NSPanel_Hardware,                   //Auto-Alias Service Page
                                            NSPanel_Einstellungen,                  //Auto-Alias Service Page
                                                NSPanel_Screensaver,                //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                                                    NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                                                    NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                                                    NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                                                    NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                                                NSPanel_Relays,                     //Auto-Alias Service Page
                                            NSPanel_Firmware,                       //Auto-Alias Service Page
                                                NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                                                NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                                                NSPanel_FirmwareNextion,            //Auto-Alias Service Page
                             //   button1Page: button1Page,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                             //   button2Page: button2Page    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                                button1Page: null,
                                button2Page: null
                            Log ist leer.
                            • T TT-Tom
                              Hi @dark-angel
                              Dark AngelD Offline
                              Dark AngelD Offline
                              Dark Angel
                              #2512
                              Hi @dark-angel
                              Tasmota ist 12.4.0
                              Mit den Relais schalte ich die mit dem NSPanel verbundenen Lampen.
                              In welchen Schritt werden die Relais entkoppelt?
                              Müssen die entkoppelt werden, damit es „richtig“ funktioniert?
                              Wenn ich so darüber nachdenke… könnte ein Tasmota Update dazu geführt haben, dass es nicht mehr richtig funktioniert?
                              • T TT-Tom
                                @tklein
                                tklein
                                #2513
                                @tt-tom
                                ferner wechseln oben links/recht die Icons jenachdem ob forecat oder übersicht im screensaver ist:
                                • T tklein
                                  @tt-tom
                                  // Eigene Views
                                      'useColor': true,
                                                  minValue: 50,
                                                  maxValue: 300,
                                                  stepValue: 5
                                      'useColor': true,
                                                  minValue: 50,
                                                  maxValue: 400,
                                                  stepValue: 5
                                  sowie:
                                      pages: [
                                              WZ_Thermostat,
                                              WP_Thermostat,
                                  	    //Unlock_Service,
                                      subPages: [
                                      button1Page: null,
                                      button2Page: null
                                  Log ist leer.
                                  TT-Tom
                                  #2514
                                  @tklein
                                  dort ist kein Fehler zu erkennen. Dein Alias für das Thermostat kannst du nochmal zeigen.
                                  Hast du den JavaScript Adapter mal neu gestartet??
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @tklein
                                    tklein
                                    #2515
                                    @tt-tom ja mehrfach.
                                    Das scheint irgendwie noch teilweise im Speicher/Cacher etc zu hängen. Von der alten Datei.
                                    var Startseite_Wohnzimmer: PageEntities =
                                        "type": "cardEntities",
                                        "heading": "Wohnzimmer",
                                        "useColor": true,
                                        "subPage": false,
                                        "parent": undefined,
                                        "items": [
                                            <PageItem>{ navigate: true, id: "Wohnzimmer_Thermostat", onColor: White, name: "Thermostat", icon:"thermostat"},
                                            <PageItem>{ navigate: true, id: "Wohnzimmer_Licht_Overview", onColor: White, name: "Geräte", icon:"devices"},
                                            <PageItem>{ navigate: true, id: "Wohnzimmer_Jalousien", onColor: White, name: "Jalousien", icon:"blinds"},
                                            <PageItem>{ id: "alias.0.System.Status_Heizung_WZ", name: "Heizung", icon: "radiator", icon2:"radiator-off",  offColor: Blue, onColor: MSRed, interpolateColor: true}
                                            //<PageItem>{ navigate: true, id: "AlarmPage", onColor: White, name: "Alarmpanel"}
                                    • T tklein
                                          "useColor": true,
                                          "subPage": false,
                                          "items": [
                                      TT-Tom
                                      #2516
                                      @tklein sagte in SONOFF NSPanel mit Lovelace UI:
                                      Das ist ja auch meine Vermutung gewesen. Wir hatten dieses Phänomen schon ein paar Mal beobachten können, das im Hintergrund die alte Datei mit gelaufen ist.
                                      bitte beide Dateien stoppen, Adapter neu starten. Display sollte dann Connectscreen zeigen. Dann neue Datei starten.
                                      ggf. mal eine neue Instanz erstellen und das Script auf die neue Instanz setzen.
                                      Gruß Tom
                                      Public Transport
                                      • T TT-Tom
                                        tklein
                                        #2517
                                        @tt-tom thx, jetzt klappt es. Juhu. Endlich kann es weitergehen. Da kommen bestimmt noch Fragen :-)
                                        • ArmilarA Armilar
                                          Release v4.0.3
                                          Änderungen in der Config:
                                          aus
                                          export const config: Config = {
                                          wird
                                          export const config = <Config> {
                                          und die firstScreensaverEntity - fourthScreensaverentity existieren nicht mehr. Erstatz dafür ist das Array bottomScreensaverEntity. Die ersten 4 bottomScreensaverEntity werden auch im Standard-Screensaver genutzt.
                                          Des weiteren ist der Erweiterte Screensaver enthalten:
                                          Zur Konfiguration des Screensavers bitte die Wiki berücksichtigen:
                                          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
                                          Für alle User mit kleinen Hackern zuhause gibt es jetzt die cardUnlock:
                                          Siehe auch:
                                          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardunlock-ab-v400
                                          Ansonsen gab es diverse Erweiterungen und Minor-Bugfixes:
                                          • Eine überarbeitete und erweiterte Squeezebox und diverse Optimierungen von @bembelstemmer
                                          • Ein Mode - Fix für die cardThermo und dynamische Icons im Advanced Screensaver (Issue in letzer Sekunde ;-) ) von @Gargano
                                          Kurze Upgrade-Empfehlung:
                                          • Neues TypeScript anlegen und die Version https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/NsPanelTs_without_Examples.ts hineinkopieren
                                          • altes Script deaktivieren (Fallback)
                                          • Konfiguration anhand der Variablen aus dem anderen Script übernehmen (Achtung Config hat einen veränderten Aufbau und kann nicht 1:1 übernommen werden, siehe oben!)
                                          • Erweiterungen für Advanced Screensaver aus Wiki oder NSPanel.ts (Script mit Beispielen) migrieren
                                          • FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.0.3.tft
                                          Hinweis:
                                          • @TT-Tom hat bereits festgestellt, dass es erforderlich sein kann, die vom TS-Script automatisch angelegten 0_userdata.0.NSPanel.X Verzeichnisse und Auto-Aliase zu löschen und neu anlegen zu lassen.
                                          Viel Spaß mit dem neuen Release...
                                          wendy2702W Online
                                          wendy2702W Online
                                          #2518
                                          Release v4.0.3
                                          aus
                                          wird
                                          Siehe auch:
                                          Hinweis:
                                          habe gerade mal mein NSPanel angeschmissen und versucht das Upgrade zu machen.
                                          Zum Schluß das Script aus dem Link genommen und aktiviert.
                                          Hier kommt in regelmäßigen Abständen das im Log:
                                          18:00:04.951	info	javascript.0 (375) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:00:41.436	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: compiling TypeScript source...
                                          18:00:41.857	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: source code did not change, using cached compilation result...
                                          18:00:41.887	error	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: Wetter-Adapter: << weatherAdapterInstance - accuweather.0. >> is not installed. Please Check Adapter!
                                          18:00:41.930	warn	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: mrIcon1ScreensaverEntity data point in the config not available - please adjust
                                          18:00:41.931	warn	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: mrIcon2ScreensaverEntity data point in the config not available - please adjust
                                          18:00:41.931	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: setObjects enabled - create Alias Channels possible
                                          18:00:41.934	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: weather alias for accuweather.0. already exists
                                          18:00:41.938	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:2177:17
                                          18:00:41.939	error	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: schedule(cron=*/null * * * * *): cannot create schedule
                                          18:00:41.949	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: registered 28 subscriptions, 4 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          18:00:42.304	warn	javascript.0 (375) at HandleStartupProcess (script.js.common.NSPanel.NSPANEL_1_4_0_4:3368:41)
                                          18:00:42.304	warn	javascript.0 (375) at HandleMessage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3222:21)
                                          18:00:42.304	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:3160:25)
                                          18:00:42.304	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.304	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.304	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.304	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.304	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:3152:12)
                                          18:00:42.305	warn	javascript.0 (375) at GeneratePageElements (script.js.common.NSPanel.NSPANEL_1_4_0_4:3449:21)
                                          18:00:42.305	warn	javascript.0 (375) at GenerateEntitiesPage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3405:34)
                                          18:00:42.305	warn	javascript.0 (375) at GeneratePage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3289:29)
                                          18:00:42.305	warn	javascript.0 (375) at HandleMessage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3224:21)
                                          18:00:42.305	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:3160:25)
                                          18:00:42.305	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.305	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.305	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.306	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.306	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:3152:12)
                                          18:00:42.396	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1291:26)
                                          18:00:42.396	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.396	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.396	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.397	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.397	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1287:12)
                                          18:00:42.414	warn	javascript.0 (375) at update_tasmota_firmware (script.js.common.NSPanel.NSPANEL_1_4_0_4:3094:13)
                                          18:00:42.414	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1420:25)
                                          18:00:42.414	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.415	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.415	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.415	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.415	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1413:12)
                                          18:00:42.451	warn	javascript.0 (375) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPANEL_1_4_0_4:7674:25)
                                          18:00:42.452	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1649:41)
                                          18:00:42.452	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.452	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.452	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.452	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.452	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1635:32)
                                          18:00:42.452	warn	javascript.0 (375) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPANEL_1_4_0_4:7696:30)
                                          18:00:42.453	warn	javascript.0 (375) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPANEL_1_4_0_4:7736:48)
                                          18:00:42.453	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1649:41)
                                          18:00:42.453	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.453	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.453	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.453	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.453	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1635:32)
                                          18:00:42.453	warn	javascript.0 (375) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPANEL_1_4_0_4:7737:48)
                                          18:00:42.454	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1649:41)
                                          18:00:42.454	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.454	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.454	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.454	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.454	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1635:32)
                                          18:00:42.475	warn	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: error at Trigger PageNavi: Cannot read properties of null (reading 'pagetype')
                                          18:00:42.517	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:1780:42
                                          18:00:42.517	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.517	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.518	warn	javascript.0 (375) at fulfilled (script.js.common.NSPanel.NSPANEL_1_4_0_4:5:58)
                                          18:00:42.756	warn	javascript.0 (375) at GeneratePageElements (script.js.common.NSPanel.NSPANEL_1_4_0_4:3449:21)
                                          18:00:42.756	warn	javascript.0 (375) at GenerateEntitiesPage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3405:34)
                                          18:00:42.757	warn	javascript.0 (375) at GeneratePage (script.js.common.NSPanel.NSPANEL_1_4_0_4:3289:29)
                                          18:00:42.757	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1804:25)
                                          18:00:42.757	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.757	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.757	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.757	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.757	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1797:12)
                                          18:00:42.788	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: Desired TFT Firmware: 50 / v4.0.4
                                          18:00:42.789	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: Installed TFT Firmware: NaN / vundefined
                                          18:00:42.874	warn	javascript.0 (375) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPANEL_1_4_0_4:7737:48)
                                          18:00:42.874	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1673:41)
                                          18:00:42.874	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:00:42.875	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:00:42.875	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:00:42.875	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:00:42.875	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:1659:32)
                                          18:03:49.336	info	javascript.0 (375) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:03:49.410	info	javascript.2 (429) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:03:49.551	info	javascript.1 (139047) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:03:49.728	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: compiling TypeScript source...
                                          18:03:52.816	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: TypeScript compilation successful
                                          18:03:52.876	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: setObjects enabled - create Alias Channels possible
                                          18:03:52.878	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: weather alias for daswetter.0. already exists
                                          18:03:52.886	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: registered 28 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          18:03:53.164	info	javascript.2 (429) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:03:53.375	info	javascript.1 (139047) Stop script script.js.common.NSPanel.NSPANEL_1_4_0_4
                                          18:03:53.793	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: Desired TFT Firmware: 50 / v4.0.4
                                          18:03:53.793	info	javascript.0 (375) script.js.common.NSPanel.NSPANEL_1_4_0_4: Installed TFT Firmware: 50 / v4.0.4
                                          18:04:30.006	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:04:30.006	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:04:30.006	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:04:30.006	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:04:30.007	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:04:30.008	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:04:30.009	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:05:00.009	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:05:00.009	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2170:9)
                                          18:05:00.010	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:05:00.010	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2170:9)
                                          18:04:30.007	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:04:30.007	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:04:30.007	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:04:30.007	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:04:30.007	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:04:30.007	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:04:30.008	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:04:30.008	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:04:30.008	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:04:30.008	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:04:30.008	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:04:30.008	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:04:30.009	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:04:30.009	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:04:30.009	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:04:30.009	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:04:30.009	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:04:30.009	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:06:30.009	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:06:30.009	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:06:30.009	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:06:30.009	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:06:30.010	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:06:30.010	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:06:30.010	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:06:30.010	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:06:30.010	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:06:30.011	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:06:30.011	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:06:30.011	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:06:30.011	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:06:30.011	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:06:30.011	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:06:30.011	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:06:30.012	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:06:30.012	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:06:30.012	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:06:30.012	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:06:30.012	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:06:30.012	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2233:17)
                                          18:06:30.012	warn	javascript.0 (375) at step (script.js.common.NSPanel.NSPANEL_1_4_0_4:33:23)
                                          18:06:30.013	warn	javascript.0 (375) at Object.next (script.js.common.NSPanel.NSPANEL_1_4_0_4:14:53)
                                          18:06:30.013	warn	javascript.0 (375) at script.js.common.NSPanel.NSPANEL_1_4_0_4:8:71
                                          18:06:30.013	warn	javascript.0 (375) at __awaiter (script.js.common.NSPanel.NSPANEL_1_4_0_4:4:12)
                                          18:06:30.013	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2229:12)
                                          18:07:00.009	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:07:00.009	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2170:9)
                                          18:07:00.010	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:07:00.010	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2170:9)
                                          18:07:00.011	warn	javascript.0 (375) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPANEL_1_4_0_4:7504:31)
                                          18:07:00.011	warn	javascript.0 (375) at Object.<anonymous> (script.js.common.NSPanel.NSPANEL_1_4_0_4:2170:9)
                                          Erfordert das Script an dieser Stelle schon irgendeine Config von mir oder sollte das Log fehlerfrei bleiben?
                                          Habe von accuweather auf daswetter umgestellt.
                                          EDIT: Hat sich erledigt. Gerade überlegt und festgestellt das mir leider die Zeit und Motivation fehlt mich weiterhin mit dem Panel und der für mich leider nicht einfachen Konfiguration zu beschäftigen.
                                          Wer also Interesse an einem Quasi neuen Panel hat: https://forum.iobroker.net/topic/63810/sonoff-nspanel-zu-verkaufen
