    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • T TT-Tom
    @darkness_08
    Welche Version hast du aktuell installiert?
    Tasmota
    Berry
    TFT
    #2498
    @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
    @darkness_08
    Tasmota
    Berry
    TFT
    Tasmota:
    12.4.0(nspanel)
    Berry:
    TFT:
    50 / v4.0.3
    Ich hoffe das waren die richtigen Werte die du brauchst. Jeweils die "currentVersion"
      @darkness_08
      Tasmota
      Berry
      TFT
      Tasmota:
      12.4.0(nspanel)
      Berry:
      TFT:
      50 / v4.0.3
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #2499
      @darkness_08
      Versuche mal eine von denen:
      Nextion Upload Proto 1.2 with 921600 Baud (same as FlashNextion):
      FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.1 with 921600 Baud:
      FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.2 with 115200 Baud:
      FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.1 with 115200 Baud:
      FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.2 with 256000 Baud:
      FlashNextionAdv4 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.1 with 256000 Baud:
      FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
      Nextion Upload Proto 1.1 with 921600 Baud and communication init on 9600 Baud:
      FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
      • ArmilarA Armilar
        @darkness_08
        #2500
        @armilar sagte in SONOFF NSPanel mit Lovelace UI:
        Leider kein Erfolg.
        @darkness_08
        06:10:45.504 CMD: FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
        06:10:45.518 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        06:10:45.559 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        06:10:46.730 FLH: Send (High Speed) flash start
        06:10:47.083 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:15.174 CMD: FlashNextionAdv1 http://nspanel.pky.eu/lui.tft
        00:00:15.188 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:15.227 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        00:00:16.397 FLH: Send (High Speed) flash start
        00:00:16.749 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:19.023 CMD: FlashNextionAdv2 http://nspanel.pky.eu/lui.tft
        00:00:19.036 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:19.075 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        00:00:20.100 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF1AFFFFFF1AFFFFFF')]
        00:00:20.246 FLH: Send (High Speed) flash start
        00:00:20.598 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:29.204 CMD: FlashNextionAdv3 http://nspanel.pky.eu/lui.tft
        00:00:29.217 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:29.240 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        00:00:30.415 FLH: Send (High Speed) flash start
        00:00:30.862 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:19.069 CMD: FlashNextionAdv4 http://nspanel.pky.eu/lui.tf
        00:00:19.084 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:19.125 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tf
        00:00:20.299 FLH: Send (High Speed) flash start
        00:00:20.746 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:15.294 CMD: FlashNextionAdv5 http://nspanel.pky.eu/lui.tft
        00:00:15.307 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:15.348 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        00:00:16.519 FLH: Send (High Speed) flash start
        00:00:16.870 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
        00:00:15.539 CMD: FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
        00:00:15.552 MQT: SmartHome/02_Kueche/02-nspanel/stat/RESULT = {"FlashNextionAdv":"Done"}
        00:00:15.603 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
        00:00:16.624 FLH: Something has gone wrong flashing display firmware [bytes('8FDEFB')]
        • T tklein
          @l4rs said in SONOFF NSPanel mit Lovelace UI:
          Dort wird auf '0_userdata.0.wetter.Windrichtung' zugegriffen - den DP gab es bei mir aber nicht, weshalb ich hier ähnliche Fehler hatte. Vielleicht liegt es bei Dir auch daran?
          Gruß, L4rs
          @l4rs Hi,
          vielen Dank für den Tip! Es lag daran.
          Habe jetzt eine DP vom Netamo Crawler Adapter genommen. Der gibt die Himmelsrichtungen und nicht die Gradzahl von der Windrichtung aus.
          Mal sehen oben ich eine Funktion finde, die aus Gradangaben eine Windrichtung wie N oder SW macht.
          Thomas
          L4rs
          schrieb am zuletzt editiert von L4rs
          #2501
          @tklein said in SONOFF NSPanel mit Lovelace UI:
          Du könntest z.B. diese nehmen: 😉
          function gradeToDirection(grade) {
            grade = parseFloat(grade);
            if (isNaN(grade) || grade < 0.0 || grade > 360.0) {
              return "--";
            if (grade < 11.25 || grade >= 348.75) {
              return "N";
            } else {
              const directions = {
                NNO:  22.5,      NO:  45.0,      ONO:  67.5,      O:  90.0,
                OSO: 112.5,      SO: 135.0,      SSO: 157.5,      S: 180.0,
                SSW: 202.5,      SW: 225.0,      WSW: 247.5,      W: 270.0,
                WNW: 292.5,      NW: 315.0,      NNW: 337.5,
              for (const [key, val] of Object.entries(directions)) {
                if (grade >= val - 11.25 && grade < val + 11.25) {
                  return key;
          Gruß, L4rs
          • T TT-Tom
            @sniker ein paar Seiten zurück war das grade Thema gewesen. @tklein hat/läuft auch grade den Prozess durch. Wenn noch Fragen offen sind hier melden.
            Sniker
            #2502
            @tt-tom danke dir. Ich habe es irgendwie hin bekommen. Mein Problem ist halt, das wenn ich zu lang nicht am NS Panel was gemacht habe, da wieder rein zu kommen. Aber eine Anleitung wie man richtig vorgeht bei update, fehlt trotzdem irgendwie.
              Leider kein Erfolg.
              @darkness_08
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #2503
              @darkness_08
              Hängt dein NSPanel nicht im Internet? Gastzugang oder irgendetwas anderes? Sieht so aus, als käme es an die URL nicht ran.
              ? 2 Antworten Letzte Antwort
              • S Sniker
                TT-Tom
                #2504
                @sniker okay, welche Informationen wären für dich hilfreich gewesen? Da du es jetzt geschafft hast, kannst du uns da unterstützen, wo die Stolperstellen sind. Wir nehmen sie dann im Wiki auf. Danke
                Gruß Tom
                Public Transport
                NSPanel Adapter Wiki
                • ArmilarA Armilar
                  @darkness_08
                  #2505
                  @armilar
                  Doch, hat ganz normalen zugriff. Aber irgendwas scheint da jetzt durcheinander zu sein. Der Screensaver startet auch nicht mehr. Ich werde es mal neu bespielen und mal gucken.
                  • ArmilarA Armilar
                    @darkness_08
                    #2506
                    @armilar
                    Oh, man.Sorrryyyy :)
                    Hat alles geklappt. Ich hatte dem Panel eine StaticIP zugewiesen aber vergessen den DNS-Server zu hinterlegen. Deshalb konnte die Auflösung nicht klappen.
                    Jetzt geht es. Tut mir leid für die Verwirrung.
                    • Dark AngelD Offline
                      Dark AngelD Offline
                      Dark Angel
                      schrieb am zuletzt editiert von Dark Angel
                      #2507
                      Hi Leute,
                      seit geraumer Zeit habe ich das Problem, dass beim betätigen der Hardwarebuttons der Status unter 0_userdata.0.NSPanel.1.Relay.1 nicht aktualisiert wird, was dazu führt, dass weder die Symbole in den oberen Ecken in Screensaver den geänderten Zustand anzeigen, noch der richtige Status im Jarvis angezeigt wird.
                      Wenn ich die Softwareschalter unter Einstellungen benutze, wird auch der Status unter 0_userdata.0.NSPanel.1.Relay.1 richtig geändert und auch in Jarvis richtig angezeigt. Auch wenn ich über Jarvis die Schalter die Schalter betätige wird der Status unter 0_userdata.0.NSPanel.1.Relay.1 und in den oberen Ecken am Dysplay richtig angezeigt.
                      In alle Fälle gehen jedoch die Lichter ganz normal an und aus.
                      Habe die Tage erst das Script auf Version 4.0.4 ( auch TFT 50 und BerryDriver 8 ) aktualisiert, in der Hoffnung, dass es wieder funktionieren wird, aber dem war leider nicht so.
                      Hat jemand eine Tipp?
                      • Dark AngelD Dark Angel
                        Hi Leute,
                        TT-Tom
                        #2508
                        Hi @dark-angel
                        Tasmota hast du auch auf dem aktuellen Stand?
                        Wie ist die Konfiguration deiner Button, hast du sie von den Relais entkoppelt?
                        Schaltest du mit den Relais die Lampen?
                        Gruß Tom
                        Public Transport
                        Dark AngelD 1 Antwort Letzte Antwort
                          tklein
                          #2509
                          wie bekomme ich diesen View weg? Der ist von einer älteren Projektversion bzw. Datei.
                          Den Screen gibt es in der aktuellen Config gar nicht mehr.
                          Nach dem Updates (Display,Berry, Tasmota) habe ich nur mit der neuen Projektdatei gearbeitet. Stromlos über Nacht brachte auch keinen Erfolg.
                          WhatsApp Video 2023-03-11 at 11.06.58.mp4
                          • T tklein
                            TT-Tom
                            #2510
                            @tklein
                            zeige bitte mal die Config deiner Pages, es muss eine Page mit der Überschrift / heading "Wohnzimmer" geben. Vielleicht ist diese noch falsch konfiguriert.
                            gibt es Fehlermeldungen im LOG. ggf. den JavaScript Adapter neu starten.
                            Gruß Tom
                            Public Transport
                            T 2 Antworten Letzte Antwort
                            • T TT-Tom
                              @tklein
                              tklein
                              schrieb am zuletzt editiert von tklein
                              #2511
                              @tt-tom
                              // Eigene Views
                              let WZ_Thermostat = <PageThermo>
                                  'type': 'cardThermo',
                                  'heading': 'Wohnzimmer Thermostat',
                                  'useColor': true,
                                  'items': [<PageItem>{
                                              minValue: 50,
                                              maxValue: 300,
                                              stepValue: 5
                              let WP_Thermostat = <PageThermo>
                                  'heading': 'Whirlpool Thermostat',
                                  'useColor': true,
                                              minValue: 50,
                                              maxValue: 400,
                                              stepValue: 5
                              sowie:
                                  pages: [
                               //           Buero_Seite_1,          //Beispiel-Seite
                                          WZ_Thermostat,
                                          WP_Thermostat,
                              //            WLED,                   //Beispiel-Seite
                              //            Radiosender,            //Beispiel-Seite
                              //            SensorGrid,             //Beispiel-Seite
                              //            CardLChartExample,      //Beispiel-Seite
                              //            CardChartExample,       //Beispiel-Seite
                               //           CardPowerExample,       //Beispiel-Seite
                                          //SqueezeboxRPC,        //Beispiel-Seite
                              //            Sonos,                  //Beispiel-Seite
                              //            SpotifyPremium,         //Beispiel-Seite
                               //           Alexa,                  //Beispiel-Seite
                               //           Buero_Seite_2,          //Beispiel-Seite
                               //           Buero_Klimaanlage,      //Beispiel-Seite
                               //           Button_1,               //Beispiel-Seite
                              //            Test_Licht1,            //Beispiel-Seite
                              //            Test_Licht2,            //Beispiel-Seite
                              //            Test_Funktionen,        //Beispiel-Seite
                              //            Fenster_1,              //Beispiel-Seite
                              //            Subpages_1,             //Beispiel-Seite
                              //            Buero_Themostat,        //Beispiel-Seite
                              //            Buero_Alarm,            //Beispiel-Seite
                              	    //Unlock_Service,
                                          NSPanel_Service         //Auto-Alias Service Page
                                  subPages: [
                                              Abfall,                                 //Beispiel-Unterseite
                                              WLAN,                                   //Beispiel-Unterseite
                                              NSPanel_Infos,                          //Auto-Alias Service Page
                                                  NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                                                  NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                                                  NSPanel_Sensoren,                   //Auto-Alias Service Page
                                                  NSPanel_Hardware,                   //Auto-Alias Service Page
                                              NSPanel_Einstellungen,                  //Auto-Alias Service Page
                                                  NSPanel_Screensaver,                //Auto-Alias Service Page
                                                      NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                                                      NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                                                      NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                                                      NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                                                      NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                                                      NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                                                  NSPanel_Relays,                     //Auto-Alias Service Page
                                              NSPanel_Firmware,                       //Auto-Alias Service Page
                                                  NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                                                  NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                                                  NSPanel_FirmwareNextion,            //Auto-Alias Service Page
                               //   button1Page: button1Page,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                               //   button2Page: button2Page    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                                  button1Page: null,
                                  button2Page: null
                              Log ist leer.
                              • T TT-Tom
                                Hi @dark-angel
                                Dark AngelD Offline
                                Dark AngelD Offline
                                Dark Angel
                                #2512
                                Hi @dark-angel
                                Tasmota ist 12.4.0
                                Mit den Relais schalte ich die mit dem NSPanel verbundenen Lampen.
                                In welchen Schritt werden die Relais entkoppelt?
                                Müssen die entkoppelt werden, damit es „richtig“ funktioniert?
                                Wenn ich so darüber nachdenke… könnte ein Tasmota Update dazu geführt haben, dass es nicht mehr richtig funktioniert?
                                • T TT-Tom
                                  @tklein
                                  tklein
                                  #2513
                                  @tt-tom
                                  ferner wechseln oben links/recht die Icons jenachdem ob forecat oder übersicht im screensaver ist:
                                  • T tklein
                                    @tt-tom
                                    // Eigene Views
                                        'useColor': true,
                                                    minValue: 50,
                                                    maxValue: 300,
                                                    stepValue: 5
                                        'useColor': true,
                                                    minValue: 50,
                                                    maxValue: 400,
                                                    stepValue: 5
                                    sowie:
                                        pages: [
                                                WZ_Thermostat,
                                                WP_Thermostat,
                                    	    //Unlock_Service,
                                        subPages: [
                                        button1Page: null,
                                        button2Page: null
                                    Log ist leer.
                                    TT-Tom
                                    #2514
                                    @tklein
                                    dort ist kein Fehler zu erkennen. Dein Alias für das Thermostat kannst du nochmal zeigen.
                                    Hast du den JavaScript Adapter mal neu gestartet??
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @tklein
                                      tklein
                                      #2515
                                      @tt-tom ja mehrfach.
                                      Das scheint irgendwie noch teilweise im Speicher/Cacher etc zu hängen. Von der alten Datei.
                                      var Startseite_Wohnzimmer: PageEntities =
                                          "type": "cardEntities",
                                          "heading": "Wohnzimmer",
                                          "useColor": true,
                                          "subPage": false,
                                          "parent": undefined,
                                          "items": [
                                              <PageItem>{ navigate: true, id: "Wohnzimmer_Thermostat", onColor: White, name: "Thermostat", icon:"thermostat"},
                                              <PageItem>{ navigate: true, id: "Wohnzimmer_Licht_Overview", onColor: White, name: "Geräte", icon:"devices"},
                                              <PageItem>{ navigate: true, id: "Wohnzimmer_Jalousien", onColor: White, name: "Jalousien", icon:"blinds"},
                                              <PageItem>{ id: "alias.0.System.Status_Heizung_WZ", name: "Heizung", icon: "radiator", icon2:"radiator-off",  offColor: Blue, onColor: MSRed, interpolateColor: true}
                                              //<PageItem>{ navigate: true, id: "AlarmPage", onColor: White, name: "Alarmpanel"}
                                      • T tklein
                                            "useColor": true,
                                            "subPage": false,
                                            "items": [
                                        TT-Tom
                                        #2516
                                        @tklein sagte in SONOFF NSPanel mit Lovelace UI:
                                        Das ist ja auch meine Vermutung gewesen. Wir hatten dieses Phänomen schon ein paar Mal beobachten können, das im Hintergrund die alte Datei mit gelaufen ist.
                                        bitte beide Dateien stoppen, Adapter neu starten. Display sollte dann Connectscreen zeigen. Dann neue Datei starten.
                                        ggf. mal eine neue Instanz erstellen und das Script auf die neue Instanz setzen.
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          tklein
                                          #2517
                                          @tt-tom thx, jetzt klappt es. Juhu. Endlich kann es weitergehen. Da kommen bestimmt noch Fragen :-)
