  4. Failed to lock DB file nach Festplatte voll.
    5.5k
82 Beiträge 6 Kommentatoren 11.4k Aufrufe 5 Beobachtet
    @chrisprefect sagte in Failed to lock DB file nach Festplatte voll.:
    Kann das wirklich drei Stunden dauern die paar Adapter zu installieren?
    Möglich.
    Kann man dem LogFile aber entnehmen.
    ChrisPrefectC Offline
    ChrisPrefect
    Siehst du da was? Oder soll ich mal neustarten?
    2023-03-04 16:28:12.321  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:28:12.329  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:28:22.334  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:28:22.335  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:28:22.338  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:28:32.468  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:28:32.469  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:28:32.472  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:28:42.481  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:28:42.481  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:28:42.486  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:28:52.489  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:28:52.489  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:28:52.497  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:02.502  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:02.503  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:02.512  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:12.516  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:12.516  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:12.524  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:22.526  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:22.527  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:22.533  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:32.544  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:32.544  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:32.549  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:42.557  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:42.557  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:42.563  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:29:52.575  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:29:52.575  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:29:52.578  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:00.134  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 5476
    2023-03-04 16:30:01.933  - info: weatherunderground.0 (5476) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:30:02.580  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:02.580  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:02.584  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:12.594  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:12.595  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:12.599  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:22.611  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:22.611  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:22.615  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:30.144  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.234  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.332  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.423  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.510  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.592  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.716  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.810  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:30.898  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.001  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.120  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.210  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.313  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.406  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.494  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.589  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.676  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.770  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:31.855  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.054  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.152  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.242  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.330  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.419  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.522  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.607  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.616  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:32.616  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:32.620  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:32.706  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.806  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.901  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:32.989  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.081  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.175  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.263  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.350  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.440  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:33.525  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:30:35.599  - info: weatherunderground.0 (5476) Terminated (NO_ERROR): Without reason
    2023-03-04 16:30:36.118  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-03-04 16:30:42.622  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:42.622  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:42.627  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:30:52.639  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:30:52.641  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:30:52.648  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:02.658  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:02.659  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:02.668  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:12.669  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:12.669  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:12.676  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:22.677  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:22.677  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:22.681  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:32.683  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:32.684  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:32.689  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:42.706  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:42.706  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:42.713  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:31:52.720  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:31:52.720  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:31:52.725  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:02.725  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:02.726  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:02.742  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:12.749  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:12.749  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:12.755  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:22.756  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:22.756  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:22.764  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:32.773  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:32.773  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:32.777  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:42.779  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:42.779  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:42.783  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:32:52.788  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:32:52.788  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:32:52.792  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:02.793  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:02.793  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:02.800  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:12.806  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:12.807  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:12.812  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:22.819  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:22.820  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:22.827  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:32.830  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:32.831  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:32.834  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:42.848  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:42.848  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:42.853  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:33:52.863  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:33:52.864  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:33:52.871  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:02.882  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:02.882  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:02.886  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:12.887  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:12.888  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:12.897  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:22.899  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:22.900  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:22.904  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:32.982  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:32.983  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:32.987  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:42.991  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:42.992  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:42.997  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:34:53.007  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:34:53.008  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:34:53.014  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:03.041  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:03.042  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:03.048  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:13.049  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:13.050  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:13.055  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:23.056  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:23.057  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:23.061  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:33.063  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:33.064  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:33.070  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:43.087  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:43.087  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:43.090  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:35:53.097  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:35:53.098  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:35:53.101  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:03.102  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:03.102  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:03.109  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:13.127  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:13.127  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:13.130  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:23.143  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:23.144  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:23.149  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:33.151  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:33.151  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:33.155  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:43.157  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:43.157  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:43.163  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:36:53.168  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:36:53.169  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:36:53.174  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:03.178  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:03.178  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:03.184  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:13.194  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:13.195  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:13.202  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:23.207  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:23.208  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:23.212  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:33.222  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:33.222  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:33.228  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:43.242  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:43.243  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:43.253  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:37:53.270  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:37:53.270  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:37:53.274  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:03.296  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:03.297  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:03.300  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:13.301  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:13.301  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:13.304  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:23.326  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:23.327  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:23.330  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:33.335  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:33.335  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:33.343  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:43.352  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:43.352  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:43.356  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:38:53.360  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:38:53.360  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:38:53.365  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:03.365  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:03.366  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:03.374  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:13.376  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:13.377  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:13.380  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:23.390  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:23.390  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:23.394  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:33.406  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:33.407  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:33.413  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:43.423  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:43.424  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:43.427  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:53.434  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
    2023-03-04 16:39:53.434  - info: influxdb.0 (1617) Influx DB Version used: 1.x
    2023-03-04 16:39:53.438  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
    2023-03-04 16:39:54.986  - info: influxdb.0 (1617) Adapter is disabled => stop
    2023-03-04 16:39:55.010  - info: host.iobroker "system.adapter.influxdb.0" disabled
    2023-03-04 16:39:55.012  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
    2023-03-04 16:39:55.211  - info: influxdb.0 (1617) terminating
    2023-03-04 16:39:55.212  - info: influxdb.0 (1617) Terminated (NO_ERROR): Without reason
    2023-03-04 16:39:55.845  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2023-03-04 16:39:55.845  - info: host.iobroker Do not restart adapter system.adapter.influxdb.0 because disabled or deleted
    2023-03-04 16:40:00.044  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 5495
    2023-03-04 16:40:01.749  - info: weatherunderground.0 (5495) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:40:14.793  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:14.882  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:14.967  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.069  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.116  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.203  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.295  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.396  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.482  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.583  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.681  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.775  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.883  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:15.977  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.084  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.172  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.254  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.336  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.419  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.519  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.600  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.684  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.885  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:16.967  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.078  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.163  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.245  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.323  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.411  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.495  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.584  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.713  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.805  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:17.901  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:18.004  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:18.088  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:40:20.153  - info: weatherunderground.0 (5495) Terminated (NO_ERROR): Without reason
    2023-03-04 16:40:20.689  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-03-04 16:50:00.044  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6242
    2023-03-04 16:50:01.851  - info: weatherunderground.0 (6242) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:50:04.521  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:04.614  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:04.704  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:04.791  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:04.846  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:04.950  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.058  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.147  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.228  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.314  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.420  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.526  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.646  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.734  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.819  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:05.919  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.010  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.095  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.193  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.272  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.362  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.459  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.544  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.633  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.733  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.816  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.910  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:06.993  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.091  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.175  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.273  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.358  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.445  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.524  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.616  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:07.701  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 16:50:09.806  - info: weatherunderground.0 (6242) Terminated (NO_ERROR): Without reason
    2023-03-04 16:50:10.326  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-03-04 16:53:23.860  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224 admin
    2023-03-04 16:53:24.423  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
    2023-03-04 16:55:50.169  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
    2023-03-04 16:56:02.481  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224
    2023-03-04 16:56:02.641  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
    2023-03-04 16:56:42.391  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224
    2023-03-04 16:56:52.057  - info: host.iobroker "system.adapter.vis.0" enabled
    2023-03-04 16:56:52.350  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
    2023-03-04 16:56:52.350  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
    2023-03-04 16:56:53.862  - info: host.iobroker iobroker npm-install: host.iobroker Adapter "system.adapter.vis.0" is stopped.
    2023-03-04 16:56:53.883  - info: host.iobroker "system.adapter.vis.0" disabled
    2023-03-04 16:56:54.387  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:56:54.388  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:57:03.858  - info: vis.0 (6294) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:57:03.991  - info: vis.0 (6294) vis license is OK.
    2023-03-04 16:57:04.350  - error: vis.0 (6294) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:57:04.351  - error: vis.0 (6294) unhandled promise rejection: Not exists
    2023-03-04 16:57:04.352  - error: vis.0 (6294) Error: Not exists
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2983:17)
        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
        at processImmediate (node:internal/timers:468:21)
    2023-03-04 16:57:04.352  - error: vis.0 (6294) Not exists
    2023-03-04 16:57:04.868  - info: vis.0 (6294) terminating
    2023-03-04 16:57:04.868  - warn: vis.0 (6294) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:57:06.030  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:57:07.046  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:57:08.048  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
    2023-03-04 16:57:08.049  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
    2023-03-04 16:57:10.144  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:57:10.145  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:57:18.792  - info: vis.0 (6340) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:57:18.920  - info: vis.0 (6340) vis license is OK.
    2023-03-04 16:57:19.262  - error: vis.0 (6340) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:57:19.263  - error: vis.0 (6340) unhandled promise rejection: Not exists
    2023-03-04 16:57:19.264  - error: vis.0 (6340) Error: Not exists
    2023-03-04 16:57:19.265  - error: vis.0 (6340) Not exists
    2023-03-04 16:57:19.777  - info: vis.0 (6340) terminating
    2023-03-04 16:57:19.778  - warn: vis.0 (6340) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:57:21.003  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:57:22.033  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:57:23.034  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
    2023-03-04 16:57:23.035  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
    2023-03-04 16:57:25.145  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:57:25.146  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:57:34.116  - info: vis.0 (6386) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:57:34.248  - info: vis.0 (6386) vis license is OK.
    2023-03-04 16:57:34.597  - error: vis.0 (6386) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:57:34.598  - error: vis.0 (6386) unhandled promise rejection: Not exists
    2023-03-04 16:57:34.600  - error: vis.0 (6386) Error: Not exists
    2023-03-04 16:57:34.600  - error: vis.0 (6386) Not exists
    2023-03-04 16:57:35.106  - info: vis.0 (6386) terminating
    2023-03-04 16:57:35.109  - warn: vis.0 (6386) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:57:36.300  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:57:37.337  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:57:38.342  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
    2023-03-04 16:57:38.343  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
    2023-03-04 16:57:40.519  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:57:40.520  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:57:49.458  - info: vis.0 (6432) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:57:49.596  - info: vis.0 (6432) vis license is OK.
    2023-03-04 16:57:49.928  - error: vis.0 (6432) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:57:49.929  - error: vis.0 (6432) unhandled promise rejection: Not exists
    2023-03-04 16:57:49.930  - error: vis.0 (6432) Error: Not exists
    2023-03-04 16:57:49.931  - error: vis.0 (6432) Not exists
    2023-03-04 16:57:50.442  - info: vis.0 (6432) terminating
    2023-03-04 16:57:50.443  - warn: vis.0 (6432) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:57:51.590  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:57:52.628  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:57:53.636  - error: host.iobroker Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2023-03-04 16:57:55.127  - info: host.iobroker "system.adapter.vis.0" enabled
    2023-03-04 16:57:55.245  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
    2023-03-04 16:57:55.245  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
    2023-03-04 16:57:56.740  - info: host.iobroker iobroker npm-install: host.iobroker Adapter "system.adapter.vis.0" is stopped.
    2023-03-04 16:57:56.758  - info: host.iobroker "system.adapter.vis.0" disabled
    2023-03-04 16:57:57.326  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:57:57.327  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:58:06.797  - info: vis.0 (6478) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:58:06.917  - info: vis.0 (6478) vis license is OK.
    2023-03-04 16:58:07.246  - error: vis.0 (6478) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:58:07.247  - error: vis.0 (6478) unhandled promise rejection: Not exists
    2023-03-04 16:58:07.248  - error: vis.0 (6478) Error: Not exists
    2023-03-04 16:58:07.249  - error: vis.0 (6478) Not exists
    2023-03-04 16:58:07.763  - info: vis.0 (6478) terminating
    2023-03-04 16:58:07.764  - warn: vis.0 (6478) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:58:08.938  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:58:09.960  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:58:10.966  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
    2023-03-04 16:58:10.967  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
    2023-03-04 16:58:12.943  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:58:12.944  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:58:22.092  - info: vis.0 (6524) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:58:22.211  - info: vis.0 (6524) vis license is OK.
    2023-03-04 16:58:22.564  - error: vis.0 (6524) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:58:22.565  - error: vis.0 (6524) unhandled promise rejection: Not exists
    2023-03-04 16:58:22.566  - error: vis.0 (6524) Error: Not exists
    2023-03-04 16:58:22.567  - error: vis.0 (6524) Not exists
    2023-03-04 16:58:23.071  - info: vis.0 (6524) terminating
    2023-03-04 16:58:23.072  - warn: vis.0 (6524) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:58:24.245  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:58:25.265  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:58:26.265  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
    2023-03-04 16:58:26.265  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
    2023-03-04 16:58:28.392  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:58:28.393  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:58:37.480  - info: vis.0 (6572) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:58:37.612  - info: vis.0 (6572) vis license is OK.
    2023-03-04 16:58:37.942  - error: vis.0 (6572) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:58:37.943  - error: vis.0 (6572) unhandled promise rejection: Not exists
    2023-03-04 16:58:37.944  - error: vis.0 (6572) Error: Not exists
    2023-03-04 16:58:37.945  - error: vis.0 (6572) Not exists
    2023-03-04 16:58:38.454  - info: vis.0 (6572) terminating
    2023-03-04 16:58:38.456  - warn: vis.0 (6572) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:58:39.667  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:58:40.689  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:58:41.701  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
    2023-03-04 16:58:41.701  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
    2023-03-04 16:58:43.732  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
    2023-03-04 16:58:43.733  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
    2023-03-04 16:58:52.870  - info: vis.0 (6619) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 16:58:52.999  - info: vis.0 (6619) vis license is OK.
    2023-03-04 16:58:53.369  - error: vis.0 (6619) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-04 16:58:53.369  - error: vis.0 (6619) unhandled promise rejection: Not exists
    2023-03-04 16:58:53.371  - error: vis.0 (6619) Error: Not exists
    2023-03-04 16:58:53.372  - error: vis.0 (6619) Not exists
    2023-03-04 16:58:53.884  - info: vis.0 (6619) terminating
    2023-03-04 16:58:53.884  - warn: vis.0 (6619) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-04 16:58:55.051  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
    2023-03-04 16:58:56.089  - info: host.iobroker iobroker npm-install: exit 25
    2023-03-04 16:58:57.122  - error: host.iobroker Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2023-03-04 17:00:00.042  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6630
    2023-03-04 17:00:01.866  - info: weatherunderground.0 (6630) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 17:00:07.534  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:07.631  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:07.722  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:07.822  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:07.926  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.032  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.124  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.210  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.299  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.386  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.495  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.582  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.699  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.783  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.889  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:08.977  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.072  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.168  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.261  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.353  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.476  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.567  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.676  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.759  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.866  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:09.948  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.033  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.124  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.248  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.348  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.448  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.541  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.627  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.717  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.823  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:10.910  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:00:12.985  - info: weatherunderground.0 (6630) Terminated (NO_ERROR): Without reason
    2023-03-04 17:00:13.505  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-03-04 17:10:00.041  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6647
    2023-03-04 17:10:01.883  - info: weatherunderground.0 (6647) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
    2023-03-04 17:10:32.042  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.130  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.219  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.314  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.422  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.509  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.611  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.706  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.789  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.888  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:32.978  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.077  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.181  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.278  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.367  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.460  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.546  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.636  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.721  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.809  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.906  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:33.992  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.078  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.164  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.262  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.348  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.448  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.539  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.638  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.739  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.830  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:34.917  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:35.001  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:35.081  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:35.165  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:35.248  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-03-04 17:10:37.319  - info: weatherunderground.0 (6647) Terminated (NO_ERROR): Without reason
    2023-03-04 17:10:37.837  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    • David G.D David G.
      @chrisprefect
      Ich kann deinen Frust teilweise nachvollziehen.
      (Manchmal) geht es mir ähnlich.
      Das liegt (zumindest bei mir) daran, dass ich in der Linuxwelt nicht zu Hause bin.
      Habe mir durch den ioBroker nach und nach einiges angeeignet.
      Hier und da, MUSS man einfach ein ordentliches Tutorial lesen, wenn man selber nicht in der Materie ist.
      Das meiste bekommt man auch hier im Forum mit. Lange war zb ein Thread sehr aktuell, wie man auf Bullseye updatet.
      Klar, bei Windows bin ich seit Win7 durch Windows Update bis auf Win11.
      Bei Windows bekomme ich auch mit, wenn es eine neue Version gibt. Überall hat man Windows 11 gelesen.
      Bin auch viel zu spät auf Bullseye. Liegt aber daran, dass ich eben nicht in der Linuxwelt zu Hause bin und nicht auf einschlägigen Websites zu Linux unterwegs bin.
      Linux lässt einem einfach mehr Freiheiten. Mit diesen muss man lernen umzugehen.
      P. S.
      Bei Windows hatte ich schon oft genug Probleme nach einem Hardreset. Oder andere Dinge die ich auf meinem Rpi noch nie hatte.
      ChrisPrefectC Offline
      ChrisPrefect
      @david-g
      Danke! 😊
      Genau, ich bin bei Linux leider auch nicht zu Hause und komme trotz 20 Jahren herumbasteln damit noch immer nicht richtig rein. Nur schon das Chaos mit Root, su, su -, sudoers, sudo usw. ist jedes Mal ein riesen Stolperstein. Und warum es jetzt einen Unterschied machen soll ob man ein root-Passwort setzt oder nicht erschliesst sich mir wirklich nicht. Bis nach der Installation nur mal wieder SSH funktioniert, damit ich Befehle reinkopieren kann, statt sie ins Fenster der VM abtippen zu müssen, dauert ewig.
      Ja, ich google jedes Problem und jede Fehlermeldung und finde dutzende verschiedene Anleitungen, die dann aber alle irgendwie nicht funktionieren. Ich wollte z.B. nur mal Bash wieder auf Englisch einstellen statt auf Deutsch und habe nach der vierten Anleitung, die nur Fehlermeldungen produziert hatte, aufgegeben.
      Eine aktuelle Influxdb2-Anleitung habe ich nicht gefunden. Die offizielle Anleitung für Debian von influxdb selbst stimmt nicht, weil die Quellen fürs Installieren per apt bei Debian fehlen. Aktuell kann ich keinen User anlegen.
      ioBroker ist ja eine geniale Software und ich bin jedem dankbar, der daran weiterentwickelt. Aber für mich als User ist es ein Graus, wenn das System alle paar Monate nicht mehr funktioniert, weil irgendein Update was gebrochen hat (oft sogar absichtlich!) oder weil nach einem Neustart wieder irgendwelche Files korrupt sind. Alle zwei Jahre das OS neu installieren, weil es veraltet ist, sollte auch nicht sein müssen. Das ist eine Appliance. Die muss einfach laufen, egal auf welcher Version sie ist. Die Mikrowelle funktioniert auch mit der ursprünglich installierten Firmware zuverlässig.
      Gibt es für sowas keinen bezahlten Support? Kann ich nicht jemandem 100€ bezahlen, dafür dass er mir ioBroker auf einer VM installiert und das Backup sauber zurückspielt? Das würde mir viel Aufwand ersparen. Weil ich aktuell durch LongCovid einen starken Brainfog habe und jede Konzentration extrem anstrengend ist, wäre sowas auch für meine Gesundheit besser.
      Thomas BraunT David G.D 4 Antworten Letzte Antwort
      • ChrisPrefectC ChrisPrefect
        Siehst du da was? Oder soll ich mal neustarten?
        2023-03-04 16:28:12.321  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:28:12.329  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:28:22.334  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:28:22.335  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:28:22.338  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:28:32.468  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:28:32.469  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:28:32.472  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:28:42.481  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:28:42.481  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:28:42.486  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:28:52.489  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:28:52.489  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:28:52.497  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:02.502  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:02.503  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:02.512  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:12.516  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:12.516  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:12.524  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:22.526  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:22.527  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:22.533  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:32.544  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:32.544  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:32.549  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:42.557  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:42.557  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:42.563  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:29:52.575  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:29:52.575  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:29:52.578  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:00.134  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 5476
        2023-03-04 16:30:01.933  - info: weatherunderground.0 (5476) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:30:02.580  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:02.580  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:02.584  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:12.594  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:12.595  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:12.599  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:22.611  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:22.611  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:22.615  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:30.144  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.234  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.332  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.423  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.510  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.592  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.716  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.810  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:30.898  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.001  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.120  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.210  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.313  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.406  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.494  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.589  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.676  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.770  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:31.855  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.054  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.152  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.242  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.330  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.419  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.522  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.607  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.616  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:32.616  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:32.620  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:32.706  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.806  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.901  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:32.989  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.081  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.175  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.263  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.350  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.440  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:33.525  - info: weatherunderground.0 (5476) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:30:35.599  - info: weatherunderground.0 (5476) Terminated (NO_ERROR): Without reason
        2023-03-04 16:30:36.118  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2023-03-04 16:30:42.622  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:42.622  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:42.627  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:30:52.639  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:30:52.641  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:30:52.648  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:02.658  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:02.659  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:02.668  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:12.669  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:12.669  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:12.676  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:22.677  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:22.677  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:22.681  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:32.683  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:32.684  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:32.689  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:42.706  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:42.706  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:42.713  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:31:52.720  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:31:52.720  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:31:52.725  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:02.725  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:02.726  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:02.742  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:12.749  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:12.749  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:12.755  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:22.756  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:22.756  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:22.764  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:32.773  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:32.773  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:32.777  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:42.779  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:42.779  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:42.783  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:32:52.788  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:32:52.788  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:32:52.792  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:02.793  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:02.793  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:02.800  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:12.806  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:12.807  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:12.812  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:22.819  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:22.820  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:22.827  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:32.830  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:32.831  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:32.834  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:42.848  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:42.848  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:42.853  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:33:52.863  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:33:52.864  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:33:52.871  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:02.882  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:02.882  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:02.886  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:12.887  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:12.888  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:12.897  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:22.899  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:22.900  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:22.904  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:32.982  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:32.983  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:32.987  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:42.991  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:42.992  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:42.997  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:34:53.007  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:34:53.008  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:34:53.014  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:03.041  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:03.042  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:03.048  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:13.049  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:13.050  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:13.055  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:23.056  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:23.057  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:23.061  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:33.063  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:33.064  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:33.070  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:43.087  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:43.087  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:43.090  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:35:53.097  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:35:53.098  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:35:53.101  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:03.102  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:03.102  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:03.109  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:13.127  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:13.127  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:13.130  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:23.143  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:23.144  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:23.149  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:33.151  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:33.151  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:33.155  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:43.157  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:43.157  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:43.163  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:36:53.168  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:36:53.169  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:36:53.174  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:03.178  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:03.178  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:03.184  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:13.194  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:13.195  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:13.202  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:23.207  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:23.208  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:23.212  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:33.222  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:33.222  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:33.228  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:43.242  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:43.243  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:43.253  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:37:53.270  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:37:53.270  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:37:53.274  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:03.296  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:03.297  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:03.300  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:13.301  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:13.301  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:13.304  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:23.326  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:23.327  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:23.330  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:33.335  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:33.335  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:33.343  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:43.352  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:43.352  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:43.356  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:38:53.360  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:38:53.360  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:38:53.365  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:03.365  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:03.366  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:03.374  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:13.376  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:13.377  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:13.380  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:23.390  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:23.390  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:23.394  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:33.406  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:33.407  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:33.413  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:43.423  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:43.424  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:43.427  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:53.434  - info: influxdb.0 (1617) Connecting http://localhost:8086/ ...
        2023-03-04 16:39:53.434  - info: influxdb.0 (1617) Influx DB Version used: 1.x
        2023-03-04 16:39:53.438  - error: influxdb.0 (1617) Error: {"code":"unauthorized","message":"Unauthorized"}
        2023-03-04 16:39:54.986  - info: influxdb.0 (1617) Adapter is disabled => stop
        2023-03-04 16:39:55.010  - info: host.iobroker "system.adapter.influxdb.0" disabled
        2023-03-04 16:39:55.012  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
        2023-03-04 16:39:55.211  - info: influxdb.0 (1617) terminating
        2023-03-04 16:39:55.212  - info: influxdb.0 (1617) Terminated (NO_ERROR): Without reason
        2023-03-04 16:39:55.845  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
        2023-03-04 16:39:55.845  - info: host.iobroker Do not restart adapter system.adapter.influxdb.0 because disabled or deleted
        2023-03-04 16:40:00.044  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 5495
        2023-03-04 16:40:01.749  - info: weatherunderground.0 (5495) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:40:14.793  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:14.882  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:14.967  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.069  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.116  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.203  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.295  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.396  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.482  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.583  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.681  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.775  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.883  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:15.977  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.084  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.172  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.254  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.336  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.419  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.519  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.600  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.684  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.885  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:16.967  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.078  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.163  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.245  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.323  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.411  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.495  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.584  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.713  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.805  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:17.901  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:18.004  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:18.088  - info: weatherunderground.0 (5495) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:40:20.153  - info: weatherunderground.0 (5495) Terminated (NO_ERROR): Without reason
        2023-03-04 16:40:20.689  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2023-03-04 16:50:00.044  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6242
        2023-03-04 16:50:01.851  - info: weatherunderground.0 (6242) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:50:04.521  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:04.614  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:04.704  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:04.791  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:04.846  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:04.950  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.058  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.147  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.228  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.314  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.420  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.526  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.646  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.734  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.819  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:05.919  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.010  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.095  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.193  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.272  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.362  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.459  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.544  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.633  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.733  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.816  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.910  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:06.993  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.091  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.175  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.273  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.358  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.445  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.524  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.616  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:07.701  - info: weatherunderground.0 (6242) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 16:50:09.806  - info: weatherunderground.0 (6242) Terminated (NO_ERROR): Without reason
        2023-03-04 16:50:10.326  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2023-03-04 16:53:23.860  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224 admin
        2023-03-04 16:53:24.423  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
        2023-03-04 16:55:50.169  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
        2023-03-04 16:56:02.481  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224
        2023-03-04 16:56:02.641  - info: admin.0 (913) ==> Connected system.user.admin from ::ffff:192.168.20.224
        2023-03-04 16:56:42.391  - info: admin.0 (913) <== Disconnect system.user.admin from ::ffff:192.168.20.224
        2023-03-04 16:56:52.057  - info: host.iobroker "system.adapter.vis.0" enabled
        2023-03-04 16:56:52.350  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
        2023-03-04 16:56:52.350  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
        2023-03-04 16:56:53.862  - info: host.iobroker iobroker npm-install: host.iobroker Adapter "system.adapter.vis.0" is stopped.
        2023-03-04 16:56:53.883  - info: host.iobroker "system.adapter.vis.0" disabled
        2023-03-04 16:56:54.387  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:56:54.388  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:57:03.858  - info: vis.0 (6294) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:57:03.991  - info: vis.0 (6294) vis license is OK.
        2023-03-04 16:57:04.350  - error: vis.0 (6294) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:57:04.351  - error: vis.0 (6294) unhandled promise rejection: Not exists
        2023-03-04 16:57:04.352  - error: vis.0 (6294) Error: Not exists
            at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2983:17)
            at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
            at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
            at processImmediate (node:internal/timers:468:21)
        2023-03-04 16:57:04.352  - error: vis.0 (6294) Not exists
        2023-03-04 16:57:04.868  - info: vis.0 (6294) terminating
        2023-03-04 16:57:04.868  - warn: vis.0 (6294) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:57:06.030  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:57:07.046  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:57:08.048  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
        2023-03-04 16:57:08.049  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
        2023-03-04 16:57:10.144  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:57:10.145  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:57:18.792  - info: vis.0 (6340) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:57:18.920  - info: vis.0 (6340) vis license is OK.
        2023-03-04 16:57:19.262  - error: vis.0 (6340) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:57:19.263  - error: vis.0 (6340) unhandled promise rejection: Not exists
        2023-03-04 16:57:19.264  - error: vis.0 (6340) Error: Not exists
        2023-03-04 16:57:19.265  - error: vis.0 (6340) Not exists
        2023-03-04 16:57:19.777  - info: vis.0 (6340) terminating
        2023-03-04 16:57:19.778  - warn: vis.0 (6340) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:57:21.003  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:57:22.033  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:57:23.034  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
        2023-03-04 16:57:23.035  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
        2023-03-04 16:57:25.145  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:57:25.146  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:57:34.116  - info: vis.0 (6386) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:57:34.248  - info: vis.0 (6386) vis license is OK.
        2023-03-04 16:57:34.597  - error: vis.0 (6386) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:57:34.598  - error: vis.0 (6386) unhandled promise rejection: Not exists
        2023-03-04 16:57:34.600  - error: vis.0 (6386) Error: Not exists
        2023-03-04 16:57:34.600  - error: vis.0 (6386) Not exists
        2023-03-04 16:57:35.106  - info: vis.0 (6386) terminating
        2023-03-04 16:57:35.109  - warn: vis.0 (6386) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:57:36.300  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:57:37.337  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:57:38.342  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
        2023-03-04 16:57:38.343  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
        2023-03-04 16:57:40.519  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:57:40.520  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:57:49.458  - info: vis.0 (6432) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:57:49.596  - info: vis.0 (6432) vis license is OK.
        2023-03-04 16:57:49.928  - error: vis.0 (6432) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:57:49.929  - error: vis.0 (6432) unhandled promise rejection: Not exists
        2023-03-04 16:57:49.930  - error: vis.0 (6432) Error: Not exists
        2023-03-04 16:57:49.931  - error: vis.0 (6432) Not exists
        2023-03-04 16:57:50.442  - info: vis.0 (6432) terminating
        2023-03-04 16:57:50.443  - warn: vis.0 (6432) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:57:51.590  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:57:52.628  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:57:53.636  - error: host.iobroker Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2023-03-04 16:57:55.127  - info: host.iobroker "system.adapter.vis.0" enabled
        2023-03-04 16:57:55.245  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
        2023-03-04 16:57:55.245  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
        2023-03-04 16:57:56.740  - info: host.iobroker iobroker npm-install: host.iobroker Adapter "system.adapter.vis.0" is stopped.
        2023-03-04 16:57:56.758  - info: host.iobroker "system.adapter.vis.0" disabled
        2023-03-04 16:57:57.326  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:57:57.327  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:58:06.797  - info: vis.0 (6478) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:58:06.917  - info: vis.0 (6478) vis license is OK.
        2023-03-04 16:58:07.246  - error: vis.0 (6478) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:58:07.247  - error: vis.0 (6478) unhandled promise rejection: Not exists
        2023-03-04 16:58:07.248  - error: vis.0 (6478) Error: Not exists
        2023-03-04 16:58:07.249  - error: vis.0 (6478) Not exists
        2023-03-04 16:58:07.763  - info: vis.0 (6478) terminating
        2023-03-04 16:58:07.764  - warn: vis.0 (6478) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:58:08.938  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:58:09.960  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:58:10.966  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
        2023-03-04 16:58:10.967  - info: host.iobroker iobroker install vis@1.4.16 using installedFrom
        2023-03-04 16:58:12.943  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:58:12.944  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:58:22.092  - info: vis.0 (6524) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:58:22.211  - info: vis.0 (6524) vis license is OK.
        2023-03-04 16:58:22.564  - error: vis.0 (6524) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:58:22.565  - error: vis.0 (6524) unhandled promise rejection: Not exists
        2023-03-04 16:58:22.566  - error: vis.0 (6524) Error: Not exists
        2023-03-04 16:58:22.567  - error: vis.0 (6524) Not exists
        2023-03-04 16:58:23.071  - info: vis.0 (6524) terminating
        2023-03-04 16:58:23.072  - warn: vis.0 (6524) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:58:24.245  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:58:25.265  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:58:26.265  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
        2023-03-04 16:58:26.265  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
        2023-03-04 16:58:28.392  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:58:28.393  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:58:37.480  - info: vis.0 (6572) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:58:37.612  - info: vis.0 (6572) vis license is OK.
        2023-03-04 16:58:37.942  - error: vis.0 (6572) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:58:37.943  - error: vis.0 (6572) unhandled promise rejection: Not exists
        2023-03-04 16:58:37.944  - error: vis.0 (6572) Error: Not exists
        2023-03-04 16:58:37.945  - error: vis.0 (6572) Not exists
        2023-03-04 16:58:38.454  - info: vis.0 (6572) terminating
        2023-03-04 16:58:38.456  - warn: vis.0 (6572) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:58:39.667  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:58:40.689  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:58:41.701  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
        2023-03-04 16:58:41.701  - info: host.iobroker iobroker install vis@1.4.16 using installedVersion
        2023-03-04 16:58:43.732  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
        2023-03-04 16:58:43.733  - info: host.iobroker iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
        2023-03-04 16:58:52.870  - info: vis.0 (6619) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 16:58:52.999  - info: vis.0 (6619) vis license is OK.
        2023-03-04 16:58:53.369  - error: vis.0 (6619) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-04 16:58:53.369  - error: vis.0 (6619) unhandled promise rejection: Not exists
        2023-03-04 16:58:53.371  - error: vis.0 (6619) Error: Not exists
        2023-03-04 16:58:53.372  - error: vis.0 (6619) Not exists
        2023-03-04 16:58:53.884  - info: vis.0 (6619) terminating
        2023-03-04 16:58:53.884  - warn: vis.0 (6619) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-04 16:58:55.051  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.vis@1.4.16: 6
        2023-03-04 16:58:56.089  - info: host.iobroker iobroker npm-install: exit 25
        2023-03-04 16:58:57.122  - error: host.iobroker Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2023-03-04 17:00:00.042  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6630
        2023-03-04 17:00:01.866  - info: weatherunderground.0 (6630) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 17:00:07.534  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:07.631  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:07.722  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:07.822  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:07.926  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.032  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.124  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.210  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.299  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.386  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.495  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.582  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.699  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.783  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.889  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:08.977  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.072  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.168  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.261  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.353  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.476  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.567  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.676  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.759  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.866  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:09.948  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.033  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.124  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.248  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.348  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.448  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.541  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.627  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.717  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.823  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:10.910  - info: weatherunderground.0 (6630) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:00:12.985  - info: weatherunderground.0 (6630) Terminated (NO_ERROR): Without reason
        2023-03-04 17:00:13.505  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2023-03-04 17:10:00.041  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 6647
        2023-03-04 17:10:01.883  - info: weatherunderground.0 (6647) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
        2023-03-04 17:10:32.042  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.130  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.219  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.314  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.422  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.509  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.611  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.706  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.789  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.888  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:32.978  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.077  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.181  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.12h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.278  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.13h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.367  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.14h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.460  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.15h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.546  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.16h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.636  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.17h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.721  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.18h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.809  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.19h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.906  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.20h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:33.992  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.078  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.164  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.262  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.348  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.448  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.539  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.638  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.739  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.830  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:34.917  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:35.001  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:35.081  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:35.165  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:35.248  - info: weatherunderground.0 (6647) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2023-03-04 17:10:37.319  - info: weatherunderground.0 (6647) Terminated (NO_ERROR): Without reason
        2023-03-04 17:10:37.837  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        @chrisprefect
        Ich sehe da, dass es mit der Autorisierung an einer influxdb v1 Probleme gibt.
        Hättest du nicht oben geschrieben du seist auf V2 unterwegs?
        ChrisPrefectC 1 Antwort Letzte Antwort
        • ChrisPrefectC ChrisPrefect
          @david-g
          Danke! 😊
          Genau, ich bin bei Linux leider auch nicht zu Hause und komme trotz 20 Jahren herumbasteln damit noch immer nicht richtig rein. Nur schon das Chaos mit Root, su, su -, sudoers, sudo usw. ist jedes Mal ein riesen Stolperstein. Und warum es jetzt einen Unterschied machen soll ob man ein root-Passwort setzt oder nicht erschliesst sich mir wirklich nicht. Bis nach der Installation nur mal wieder SSH funktioniert, damit ich Befehle reinkopieren kann, statt sie ins Fenster der VM abtippen zu müssen, dauert ewig.
          Ja, ich google jedes Problem und jede Fehlermeldung und finde dutzende verschiedene Anleitungen, die dann aber alle irgendwie nicht funktionieren. Ich wollte z.B. nur mal Bash wieder auf Englisch einstellen statt auf Deutsch und habe nach der vierten Anleitung, die nur Fehlermeldungen produziert hatte, aufgegeben.
          Eine aktuelle Influxdb2-Anleitung habe ich nicht gefunden. Die offizielle Anleitung für Debian von influxdb selbst stimmt nicht, weil die Quellen fürs Installieren per apt bei Debian fehlen. Aktuell kann ich keinen User anlegen.
          ioBroker ist ja eine geniale Software und ich bin jedem dankbar, der daran weiterentwickelt. Aber für mich als User ist es ein Graus, wenn das System alle paar Monate nicht mehr funktioniert, weil irgendein Update was gebrochen hat (oft sogar absichtlich!) oder weil nach einem Neustart wieder irgendwelche Files korrupt sind. Alle zwei Jahre das OS neu installieren, weil es veraltet ist, sollte auch nicht sein müssen. Das ist eine Appliance. Die muss einfach laufen, egal auf welcher Version sie ist. Die Mikrowelle funktioniert auch mit der ursprünglich installierten Firmware zuverlässig.
          Gibt es für sowas keinen bezahlten Support? Kann ich nicht jemandem 100€ bezahlen, dafür dass er mir ioBroker auf einer VM installiert und das Backup sauber zurückspielt? Das würde mir viel Aufwand ersparen. Weil ich aktuell durch LongCovid einen starken Brainfog habe und jede Konzentration extrem anstrengend ist, wäre sowas auch für meine Gesundheit besser.
          @chrisprefect sagte in Failed to lock DB file nach Festplatte voll.:
          Äpfel - Birnen...
            @david-g
            Danke! 😊
            Muss es auch nicht. Mit entsprechend Ahnung geht das auch so. Und es gibt ja auch Linux-Geschmacksrichtungen als 'rolling release'. Die empfehle ich aber nicht als Basis für einen Server.
              @david-g
              Danke! 😊
              David G.D Online
              David G.D Online
              David G.
              Sind es bei Debian lts nicht sogar 5 Jahre?
                @david-g
                Danke! 😊
                Was für ein Chaos? Das ist ganz einfach: Als root direkt wird sich nicht angemeldet und alle Befehle die tiefer ins System reingehen werden mit sudo eingeleitet. So einfach ist das.
                  @thomas-braun Kann das wirklich drei Stunden dauern die paar Adapter zu installieren? Auf einem 24 Kern Intel Xeon mit NVMe SSD?
                  Intel Xeon
                  oooh, da scheint es schon öfter Probleme mit gegeben zu haben.
                    @chrisprefect
                    ChrisPrefectC Offline
                    ChrisPrefect
                    @thomas-braun sagte in Failed to lock DB file nach Festplatte voll.:
                    Als ob ich das wüsste :-D Ich habe danach mit apt install influxdb2 installiert. Was muss ich nun tun? Wie kann ich einen User einrichten und die HTTP-Verbindung aktivieren? Ich finde dazu keine Anleitungen.
                    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                      Und woher sollen potentielle Helfer das dann wissen?
                      So kann das nix werden. Du musst schon wissen was da auf deinem System los ist.
                      apt policy influxdb*
                      sagt?
                        ChrisPrefect
                        Haha nein das stimmt eben leider ganz und gar nicht, sonst hätte ich ja keine Probleme gehabt! 😊
                        Sudo ging nicht. auch nicht, als ich als root den user in die sudoers-Liste eingetragen hatte.
                        Ich musste manuel in der sudoers Textdatei den Root-Eintrag kopieren und auf den User abändern, erst dann ging Sudo.
                        Su ging auch nicht, da wurden keine Befehle gefunden, weil anschienend da absichtlich die Pfadvariable nicht gesetzt wird? Erst "su -" mit Bindestrich dahinter ging. Aber sowas findet man ja auch erst nach vielem Googeln. Intiutiv und konsistent ist das sicher nicht.
                        Und wenn Linux so flexibel ist, warum darf ich dann nicht so arbeiten wie ich will? Ich will immer als root arbeiten. Ich will keine extra Sicherheitsschicht. Warum bevormundet mich das System? Warum ist das system nicht so robust und transparent, dass beide Arbeitsweisen funktionieren? Das ist für mich ein grober Designfehler, der das Arbeiten unnötig umständlich und fehleranfällig macht. Das allein hat mich heute wieder eine Stunde gekostet.
                          Dürfte bei influxdb zu finden sein. Die haben da soweit ich es sehe eine umfangreiche Dokumentation.
                            Diese Anleitungen wirst du auch bei ioBroker nicht unbedingt finden.
                            Influx ist eine 3rd Party Software, die an ioBroker angebunden werden kann.
                            ioBroker geht natürlich davon aus, dass du dich damit auskennst, wenn du sie installiert hast.
                              sagt?
                              ChrisPrefect
                              Ich will einfach, dass influxdb wieder läuft. Welche Version ist mir egal. Ich befolge nur Anleitungen die ich durch googeln finde. Auf der offiziellen influxdb-Seite stand was von apt install influxdb2, deshalb habe ich das so ausgeführt (was erst mal natürlich fehl schlug).
                              pi@iobroker:/$ apt policy influxdb*
                              influxdb2-cli:
                                Installiert:           2.6.1
                                Installationskandidat: 2.6.1
                                Versionstabelle:
                               *** 2.6.1 500
                                      500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                   2.6.0 500
                                   2.5.0 500
                                   2.4.0 500
                                   2.3.0 500
                              influxdb-client:
                                Installiert:           (keine)
                                Installationskandidat: 1.6.7~rc0-1+b5
                                Versionstabelle:
                                   1.6.7~rc0-1+b5 500
                                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
                              influxdb-dev:
                                Installationskandidat: (keine)
                                Versionstabelle:
                              influxdb:
                                Installationskandidat: 1.8.10-1
                                Versionstabelle:
                                   1.8.10-1 500
                                   1.6.7~rc0-1+b5 500
                              influxdb2:
                                Installiert:           2.6.1-1
                                Installationskandidat: 2.6.1-1
                                Versionstabelle:
                               *** 2.6.1-1 500
                                   2.6.0-1 500
                                   2.5.1-1 500
                                   2.4.0-1 500
                                   2.3.0-1 500
                                   2.2.0 500
                                @chrisprefect
                                Du frickelst da komplett kopf- und planlos irgendwas herum und wunderst dich, dass das von dir zusammengestümperte Zeug nicht funktioniert?
                                Ich verabschiede mich dann auch an der Stelle, das führt zu nichts.
                                  @chrisprefect
                                  ChrisPrefect
                                  schrieb am zuletzt editiert von ChrisPrefect
                                  @chrisprefect
                                  Natürlich! Ich sage ja ständig, dass ich mich da nicht auskenne! Was soll ich denn sonst machen? Ich bin auf Hilfe angewiesen. Anleitungen habe ich trotz vielem Googeln keine passenden gefunden. Den Rest habe ich so gemacht, wie ich es auf den Anleitungsseiten von ioBroker gefunden habe.
                                  Wie soll ich sonst vorgehen? Ich weiss da nicht weiter.
                                    Das tut es nicht. Du kannst als root arbeiten, wenn die entsprechende Expertise vorhanden wäre. Ist sie aber bei dir ganz offensichtlich nicht. Also agierst du da besser als User herum um pflügst nicht mit root-Rechten dauerhaft über deine Kiste. Dann verfummelt man das ganze auch nicht so wie es hier offenbar immer wieder getan wird.
                                    Mein Linux-System rennt hier rockstable seit Jahren, ich hampel aber auch nicht komplett ahnungslos da drüber.
                                      ChrisPrefect
                                      @thomas-braun Das tue ich ja! Ich befolge ja alle deine Befehle. Aber es funktioniert halt nich! Wenn "sudo" nicht funktioniert, was soll ich denn machen? Das System funktioniert halt einfach nicht. "verfummelt" habe ich sicher nichts, und wenn dann nur, weil das System halt "sauber" einfach nicht funktioniert. Natürlich bringt man so ein Linux rock-solid hin, wenn man genau weiss, was man tut. Aber für alle anderen ist es ein Graus.
                                      Ich bin ja extrem froh um all eure Hilfe. Aber ich bin halt gefrustet, wenn jeder kleine Schritt immer wieder zu neuen Probleme führt.
                                      Also auch eine weitere Stunde später sind die meisten Instanzen noch rot und im Log tut sich nichts. Was nun? 😖
                                      • Thomas BraunT Online
                                        @chrisprefect
                                        In deinem Backup ist offenbar eine influxdb1 drin, das kannst du aber nicht in eine influxdb2 stopfen. Funktioniert nicht, anderes Format. Also influxdb1 installieren.
                                          Das kann ich so nicht stehen lassen!
                                          als ich mit ioBroker v0.x = ccu.io anfing, wusste ich noch nicht mal was e7n Raspberry ist. Ok, von Linux hatte ich schon mal gehört.
                                          Ich habe mich nach und nach dort reingefummelt. und bei mir lief immer alles stabil.
                                          Zwei Dinge habe ich nie gemacht: Jutjub Videos angesehen, und mit Dingen gearbeitet von denen ich das Gefühl hatte sie nicht zu verstehen.
                                          Für letzteres habe ich mich auch nicht gescheut 3x täglich eine neue Installation aufzusetzen...bis ich es verstanden hatte.
