  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.5k
3.8k Beiträge 462 Kommentatoren 2.3m Aufrufe 410 Beobachtet
  • S Sneak-L8
    @tombox Ich stehe etwas auf dem Schlauch.
    Ich bekomme etwa jeden zweiten Tag zum Tagesbeginn folgende Meldungen:
    2023-02-24 00:11:37.774 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.webApp" is missing the required property "common.type"
    2023-02-24 00:11:37.805 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.automation" is missing the required property "common.type"
    2023-02-24 00:11:37.855 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.batteryColdWarning" is missing the required property "common.type"
    2023-02-24 00:11:37.875 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.charging" is missing the required property "common.type"
    2023-02-24 00:11:37.887 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.chargingProfiles" is missing the required property "common.type"
    2023-02-24 00:11:37.935 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.chargingStations" is missing the required property "common.type"
    2023-02-24 00:11:37.946 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.climatisation" is missing the required property "common.type"
    2023-02-24 00:11:37.958 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.climatisationTimers" is missing the required property "common.type"
    2023-02-24 00:11:38.006 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.dealerAppointment" is missing the required property "common.type"
    2023-02-24 00:11:38.020 - warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.destinations" is missing the required property "common.type"
    Da es sich um einen Channel handelt und in der Doku grundsätzlich steht, dass common.type optional ist, ist mit nicht klar, warum diese Warnung kommt. Bei einem Channel gibt man common.type nicht an und bei den anderen Stellen im Code ist immer ein Type dabei.
    Oder ist das eher ein Fehler im ioBroker? Dann würde ich den PR machen für das saubere auslesen der ID.-Modelle.
    tombox
    #1697
    @sneak-l8 Keine Ahnung ist das nur bei dir?
    • S Sneak-L8
      Lucky_ESA
      #1698
      @sneak-l8 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
      Es feht im Datenpunkt common.type
      Hier wird wahrscheinlich irgendwann der common von diesem Datenpunkt überschrieben.
      Gruß//Lucky
      • I Offline
        I Offline
        Iobrick
        #1699
        Bei mir gibt es seit 3 Tagen Login-Probleme beim vw-Connect Adapter mit den VW-ID-Modellen ( Failed in receive login url ). Nach etwas Recherche habe ich gefunden, dass sich wohl die VW-Server-Url für die ID-Modelle geändert hat. Die neue Url soll heißen: https://emea.bff.cariad.digital/user-login/v1/authorize
        Ist das bekannt? @tombox: Kannst du das bitte im Adapter anpassen?
        • I Iobrick
          Sneak-L8
          #1700
          @iobrick schau mal die Posts weiter oben an. Problem ist bekannt und von tombox schon längst gelöst :)
          Einfach nur die Version von github installieren.
          I 1 Antwort Letzte Antwort
          • S Sneak-L8
            I Offline
            I Offline
            Iobrick
            #1701
            @sneak-l8 tschuldigung. Vielen Dank für den Hinweis. Hatte ich irgenwie nicht gesehen. Funktioniert wieder 👍
            • tiga3110T Offline
              tiga3110T Offline
              tiga3110
              #1702
              habe einen neuen Cupra Leon. Leider bekomme ich keine Daten mittels Adapter rein. Anbei ein Auszug vom Log. Hat vielleicht irgendjemand eine Idee, warum ich keinen Zugriff habe?
              Mit der verwendeten Mailadresse bin ich Hauptuser und habe auch sonst bereits rechte das Auto mit der Handyapp zu steuern
              • tiga3110T tiga3110
                tombox
                #1703
                @tiga3110
                Hast du als Type seat und seat cupra probiert?
                tiga3110T ? 2 Antworten Letzte Antwort
                • T tombox
                  @tiga3110
                  tiga3110T Offline
                  tiga3110T Offline
                  tiga3110
                  schrieb am zuletzt editiert von tiga3110
                  #1704
                  @tombox Danke, 100 Punkte! anscheinend haut SeatCupra nicht hin. Seat muss gewählt werden. Danke vielmals!!
                  • L Lucky_ESA
                    Gruß//Lucky
                    Sneak-L8
                    #1705
                    @lucky_esa
                    Es ist eigentlich ein Channel und der hat keinen common.type. Oder hab ich Deine Antwort falsch verstanden?
                    In den letzten Tagen ist der Fehler aber auch nocht mehr aufgetreten. Vielleicht kamen die Werte auch unterschiedlich vom VW-Server, so dass das mal ein Knoten und mal ein Feld im JSON war ...
                    L 1 Antwort Letzte Antwort
                      Stenninger
                      #1706
                      ich würde gern den Ladevorgang meines ID4 über den Adapter starten!
                      Dazu stecke ich den ID4 an meine Wallbox und stoppe sofort dann den Ladvorgang wieder.
                      Der ioBroker checkt nun zuverlässig alle möglichen Daten die die Voraussetzung für den automatischen Ladestart darstellen.
                      (Überschuss meiner PV Anlage ist vorhanden, ID is conncted, ID ist readyForCharging, targetSOC ist nicht erreicht, usw)
                      Das funktioniert soweit gut!
                      Jetzt müsste ich für den Ladestart Werte schreiben/setzen:
                      targetSOC=80% (oder höher)
                      maxChargeCurrentAC=reduced (habe nie 11kW Überschuss)
                      Stop/start Battery Charge=wahr
                      Das Schreiben der Werte klappt aber nur sehr sporadisch.
                      Selbst wenn ich das Script auf die bestätigte Änderung der Werte warte lasse werden diese oft wieder auf den alten Wert zurückgesetzt.
                      Hat hier jemand eine Lösung wie man sicher Werte in der API setzen/schreiben kann?
                      Liegt das Problem ggf an den Limitierungen der Zugriffe auf die API?
                      Vielen Dank
                      Stenninger
                      • S Stenninger
                        Vielen Dank
                        Stenninger
                        Sneak-L8
                        #1707
                        @stenninger hm, ich glaube es wäre einfacher, das Laden über die Wallbox zu steuern. Könnte das deine Box? Die Kommunikation mit den VW-Servern du dafür meins Erachtens nicht zuverlässig genug.
                        • S Sneak-L8
                          @lucky_esa
                          Lucky_ESA
                          schrieb am zuletzt editiert von Lucky_ESA
                          #1708
                          @sneak-l8
                          Wenn das eigentlich ein Channel ist dann liegt der Fehler in der json2iob.js. Hier kommt ein JSON mit einem leeren Wert und somit will json2iob.js den Value in den Channel schreiben (wahrscheinlich kommt null).
                          Edit:
                          Beispiel:
                          webApp: ["wert1","wert2"],
                          und es wird dann wahrscheinlich mal so kommen:
                          webApp: null,
                          Gruß//Lucky
                          • S Sneak-L8
                            Stenninger
                            #1709
                            @sneak-l8 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                            ja, zum Teil wird die WB das nach zukünftigen FW-Updates auch können.
                            Was sie aber wohl nie können wird ist den Ladestrom auf null absenken bzw erst starten wenn PV-Überschuss da ist.
                            Die Box wird mit minimal 6A pro Phase laden können. (wie alle WB)
                            Da sie keine Phasenabschaltung kann laufen dann schonmal 4kW in das Auto, ohne daß irgendwelcher Strom von der PV kommt. (reduziert man über das "reduced" Häckchen im VW dann sinds immernoch 2kW)
                            Das ist natürlich keine gute Lösung!
                            Daher wäre es super das Auto direkt steuern zu können.
                            Die API ist ja auch da. Nur scheint diese eben nicht stabil genug zu funktionieren.
                            Schade :-/
                            • stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              #1710
                              Ist beim Skoda Octavia die Fensteröffnung nicht mehr auslesbar, wie viel % geöffnet sind?
                              Finde die nicht unter der ID: vw-connect.0.DEINSkoda.status.data_0x030105FFFF.field_0x0301050004.value
                              Cores: 1 × 8 = 8 cores
                              Threads: 16
                              mit Proxmox
                              LXC Container mit Iobroker
                              • T tombox
                                @tiga3110
                                #1711
                                @tombox Hallo, hm, der Adapter mit 0.61 und 0.62 verbident sich nicht mehr mit dem Gerät oder Dienst. Im Log sehe ich einen Fehler 500 und dann einen ganzen Absatz mit unleserlichen Fehlern.
                                Ich habe ein Passat GTE BJ21. Mit 0.56 ging noch alles. Was könnte ich denn ausprobieren?
                                VG vsa
                                vw-connect.0
                                2023-03-05 18:00:38.690 error 500
                                  VG vsa
                                  vw-connect.0
                                  tombox
                                  #1712
                                  @vsa Geht denn die 60 noch,. Welchen Typ hast du in dein Einstellungen ausgewählt und was sind zb Fehler
                                  • T tombox
                                    #1713
                                    Hallo, danke schon mal für die Antwort.
                                    Ich habe bisher immer VWv2 benutzt, habe es aber auch mit VW vor 2020 ausprobiert. Hier gibt es gleich drei rote Punkte zusehen. Bei VWv2 lediglich einen gelben bei Gerät oder Dienst nicht verbunden, die anderen beiden sind grün.
                                    auffällig ist, dass ich bei jedem Neustart des Adapters eine Datenschutz-Hinweis Mail von VW zugeschickt bekomme.
                                    Wie gesagt, es kommt ein Error 500 und eine weitereZeile mit einem großen Absatz mit recht viel Hyroglyphen(für mich).
                                    V60 hatte ich leider nicht drauf, habe erst vor einigen Tagen mal alle Adapter geupdatet….
                                      tombox
                                      #1714
                                      @vsa log. wäre wichtig und auch mal in der app aus und einloggen
                                      • T tombox
                                        #1715
                                        @tombox Vielen Dank für den Tipp. Das war das Problem: nach dem ausloggen in der App und wieer einloggen kam eine Datenschutzabfrage, die ich erst akzeptieren musste. Danach ging der Adapter plkötlich wieder.
                                        Vg vsa
                                        • G Online
                                          G Online
                                          guitardoc
                                          #1716
                                          bei mir lässt sich der Adapter nicht mehr starten - er bleibt auf gelb stehen. Weiß jemand wie ich den wieder gestartet bekomme? Ich habe oben was gelesen von App neu starten - wie macht man das?
                                          Danke für die Hilfe!
