[Aufruf] BLE Adapter testen (v0.6.0)
Ok weitergeschaut dann gibts noch characteristics mit ner uuid und die haben andere Daten …
00:18:08.838 — Characteristic (FF00A502-D020-913C-1234-56D97200A6A6) read: <00000000 00000000 00000000 000000> 00:18:33.014 — Characteristic (FF00A502-D020-913C-1234-56D97200A6A6) read: <00000000 00000000 00000000 000000> 00:18:37.186 — Characteristic (FF00A503-D020-913C-1234-56D97200A6A6) read: <> 00:18:39.760 — Characteristic (FF00A503-D020-913C-1234-56D97200A6A6) read: <> 00:18:41.213 — Disconnected from nearby peripheral Mo0085 with error: The specified device has disconnected from us. 00:18:46.954 — Starting search for nearby peripherals 00:18:47.109 — Discovered nearby peripheral: Mo0085 (RSSI: -95) 00:18:47.495 — Disconnecting from nearby peripheral: Mo0085 00:18:48.352 — Connecting to nearby peripheral: Mo0085 00:18:48.810 — Connected to nearby peripheral: Mo0085 00:18:49.053 — Characteristic (2A25) read: <424c452d 4150504c 49434154 494f4e2d 303031> 00:18:49.131 — Characteristic (2A23) read: <fffe14d5 45784b08=""> 00:18:49.288 — Characteristic (2A27) read: <41303455> 00:18:49.368 — Characteristic (2A26) read: <75456e65 72677920 53444b20 322e302e 302e3431> 00:18:49.578 — Characteristic (2A28) read: <332e302e 302e3030> 00:18:49.735 — Characteristic (2A29) read: <526f626f 6d6f77> 00:18:49.894 — Characteristic (2A50) read: <010a004c 010001> 00:18:50.370 — Stopping search for nearby peripherals 00:18:52.228 — Characteristic (FF00A504-D020-913C-1234-56D97200A6A6) read: <62626262> 00:19:58.252 — Characteristic (FF00A505-D020-913C-1234-56D97200A6A6) read: <61616161> 00:20:02.557 — Characteristic (FF00A506-D020-913C-1234-56D97200A6A6) read: <> 00:20:18.630 — Disconnected from nearby peripheral Mo0085 with error: The specified device has disconnected from us.</fffe14d5> -
Auslesen lassen kannst du die Charakteristiken, d.h. 2A25, 2A23, FF00A502-D020-913C-1234-56D97200A6A6, etc, sofern diese nicht nur bei einer Verbindung bereit stehen, sondern auch per Advertisement gesendet werden. Im Prinzip alle, die die App "nRF Connect" bei ServiceData ausspuckt (siehe vorige Posts).
RSSI kann ich prinzipiell auch mit ausgeben, wenn die von Interesse ist.
weil ich Die Daten ja wohl eh nicht dekodiert bekomme, oder ?! `
Eventuell schon, musste mal googlen ob das schon wer untersucht hat. -
Hm, dann schaue ich mal. Fürchte da kommt ohne connect nichts :-(
Naja dann vllt der RSSI bzw habe wegen "Discovery" an sich und RSSI mal beim radar-Adapter ein Issue als Idee auf gemacht … weil ich den schon einsetze.
Kann man eigentlich mit zwei Bluetooth-"Sticks" (bzw. einmal build in und einmal stick) zwei DInge gleichzeitig machen, Dann müssten die Adapter unterstützen das man irgendwie angeben kann welcher Stick genutzt werden soll ...
Hab auch mal installiert. Scheint zu laufen. Jedenfalls grün und connection = treu und driver State = poweredOn.
Ich meine auch bemerkt zu haben, als ich damals das BT-Script von ruhr am Laufen hatte, dass der Radar Adapter nicht richtig funktionierte. Vielleicht gibt es Probleme wenn mehrere noble wollen. Schauen wir mal. `
Bei mir ist außer dem Info Ordner nichts dazu gekommen. Ich hatte auch mal testweise den Radar Adapter ausgeschaltet und auch den BLE Adapter paar mal neugestartet.BT läuft bei mir auf dem brix. Ich könnte das ganze auch auf dem Raspi3 testen, aber auf dem brix läuft es ja bisher ohne Probleme mit Radar und noble.
Kann man eigentlich mit zwei Bluetooth-"Sticks" (bzw. einmal build in und einmal stick) zwei DInge gleichzeitig machen, Dann müssten die Adapter unterstützen das man irgendwie angeben kann welcher Stick genutzt werden soll … `
EDIT: Device selection kommt heute Abend: https://github.com/AlCalzone/ioBroker.ble/pull/3RSSI-Speichern kommt in der nächsten Version (heute Abend): https://github.com/AlCalzone/ioBroker.ble/pull/1
Connect und so in Kürze.
Hast du in der Config Services angegeben, die gespeichert werden sollen? Und bist du sicher, dass diese auch advertised werden?
Achso! Ich hatte gar nichts eingestellt bisher. Habe jetzt mal "0x180F" eingetragen unter Überwachte Dienste. Da hat er gleich einen meiner G-tags gefunden. -
Hat jemand von euch g-tags damit ausprobiert?
Hab nach diesem link paar services eingetragen,
aber es bleibt sehr mau mit den Objekten. Batterie % wäre toll.
https://www.bluetooth.com/specifications/gatt/services
1146_objekte.jpg -
Die Geräte sollten eigentlich nur angelegt werden, wenn die Services auch tatsächlich gebroadcasted werden. Eventuell hat das mit nem Bug zu tun, den ich vorhin gefixt habe.
Lösch den Adapter nochmal und installiere bitte die neueste Version (geht inzwischen auch über die Liste im Admin => Github-Button).
@Apollon77 Inzwischen kann auch ausgewählt werden, welches Bluetooth-Gerät zum Funken verwendet wird. Unter Linux sollte auch schön benannt sein, welches das ist (UART oder USB).
Lösch den Adapter nochmal und installiere bitte die neueste Version (geht inzwischen auch über die Liste im Admin => Github-Button). `
OK. Jetzt wird rssi und services angezeigt. Beim Einrichten konnte ich nur USB im Adapter auswählen, obwohl kein Gerät am USB hängt, aber scheinbar egal.Was auffällt ist das es sehr schnell hintereinander aktualisiert die Werte… und dann paar Sekunden Pause ist. Also geschätzt nach 30...40 sec wird kurz hintereinander der Wert etwa 5x aktualisiert. Ich könnte mir vorstellen, dass diese 5x Aktualisierungen unnötig an der Batterie ziehen, oder?
Jetzt wird rssi und services angezeigt. `
Die Werte auch?Beim Einrichten konnte ich nur USB im Adapter auswählen, obwohl kein Gerät am USB hängt, aber scheinbar egal. `
Interessant. Ich frage nur ab, was Linux für Geräte kennt. Aber die Benennung ist eigentlich egal. Kann das noch jemand nachvollziehen?Was auffällt ist das es sehr schnell hintereinander aktualisiert die Werte… und dann paar Sekunden Pause ist. Also geschätzt nach 30...40 sec wird kurz hintereinander der Wert etwa 5x aktualisiert. Ich könnte mir vorstellen, dass diese 5x Aktualisierungen unnötig an der Batterie ziehen, oder? `
Meinst du RSSI? Der wird bei mir ca 2-3x pro Sekunde aktualisiert. Dadurch, dass keine aktive Verbindung hergestellt wird, sondern nur auf sowieso gesendete Pakete gelauscht, dürfte das keinen Einfluss haben. Mein Puck.js, der seit mehreren Wochen alle 375ms ein Paket sendet, hat immernoch 95% Batterie.Wenn in einer zukünftigen Version aktiv verbunden wird, gilt es natürlich, hier einen Mittelweg zwischen Aktualität und Batterieverbrauch zu finden.
keine Ahnung welche die g-tags können.
Hast du mal die nRF Connect App ausprobiert um zu schauen was die können? Würde gerne ausschließen dass der Fehler an meinem Code liegt.
Jetzt ja, coole App! :)Nun kenne ich den Batteriestand und den Sendezyklus.
Die 94% habe ich noch nicht hinbekommen unter services angezeigt zu bekommen. Im Adapter, Überwachte Dienste, habe ich eingetragen: 0x2A19, 0x180F, 0x2902, 0x2A04
Äh bei mir sah das anders aus, etwa so wie hier:
http://forum.iobroker.net/viewtopic.php?p=83065#p83065
Nur das was hinter ServiceData steht kann aktuell erfasst werden, weil das freiwillig gesendet wird. `
Ja, hab ich auch. Meine Seite kommt dann, wenn man auf connect klickt. -
ich habe zwar noch keinen Anwendungsfall für den Adapter, aber vielleicht hilft es dir wenn ich mein Installations-Log mit den Meldungen hier reinstelle?!?
host.raspberrypi 2017-09-09 10:29:56.415 info instance system.adapter.ble.0 terminated with code 0 (OK)
ble.0 2017-09-09 10:29:56.350 info terminating
host.raspberrypi 2017-09-09 10:29:56.308 info stopInstance system.adapter.ble.0 killing pid 19372
host.raspberrypi 2017-09-09 10:29:56.307 info stopInstance system.adapter.ble.0
host.raspberrypi 2017-09-09 10:29:56.292 info object change system.adapter.ble.0
ble.0 2017-09-09 10:28:11.527 info {"index":0,"bus":"UART"}
ble.0 2017-09-09 10:28:10.800 info {"index":0,"bus":"UART"}
ble.0 2017-09-09 10:28:09.865 info {"index":0,"bus":"UART"}
ble.0 2017-09-09 10:28:09.782 info {"index":0,"bus":"UART"}
ble.0 2017-09-09 10:28:05.197 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ble, node: v6.11.2
iobroker 2017-09-09 10:28:03.254 info exit 0
iobroker 2017-09-09 10:28:03.222 info host.raspberrypi object system.adapter.ble.0 created
host.raspberrypi 2017-09-09 10:28:03.213 info instance system.adapter.ble.0 started with pid 19372
host.raspberrypi 2017-09-09 10:28:03.184 info object change system.adapter.ble.0
iobroker 2017-09-09 10:28:03.146 info host.raspberrypi object system.adapter.ble.0.alive created
iobroker 2017-09-09 10:28:03.103 info host.raspberrypi object system.adapter.ble.0.connected created
iobroker 2017-09-09 10:28:03.065 info host.raspberrypi object system.adapter.ble.0.memHeapUsed created
iobroker 2017-09-09 10:28:03.025 info host.raspberrypi object system.adapter.ble.0.memHeapTotal created
iobroker 2017-09-09 10:28:02.980 info host.raspberrypi object system.adapter.ble.0.memRss created
iobroker 2017-09-09 10:28:02.938 info host.raspberrypi object system.adapter.ble.0.uptime created
iobroker 2017-09-09 10:28:02.901 info host.raspberrypi object system.adapter.ble.0.inputCount created
iobroker 2017-09-09 10:28:02.865 info host.raspberrypi object system.adapter.ble.0.outputCount created
iobroker 2017-09-09 10:28:02.826 info host.raspberrypi object ble.0.info created
iobroker 2017-09-09 10:28:02.794 info host.raspberrypi object ble.0.info.connection created
iobroker 2017-09-09 10:28:02.760 info host.raspberrypi object ble.0.info.driverState created
iobroker 2017-09-09 10:28:02.738 info host.raspberrypi create instance ble
iobroker 2017-09-09 10:28:02.684 info host.raspberrypi object system.adapter.ble created
iobroker 2017-09-09 10:28:02.536 info upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
iobroker 2017-09-09 10:28:02.448 info upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
iobroker 2017-09-09 10:28:02.342 info upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
iobroker 2017-09-09 10:28:02.315 info got /opt/iobroker/node_modules/iobroker.ble/admin
iobroker 2017-09-09 10:28:02.246 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
iobroker 2017-09-09 10:28:02.246 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.2.0 (node_modules/usb):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.2.0 install:node-pre-gyp install --fallback-to-build
iobroker 2017-09-09 10:28:02.244 info SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: want
iobroker 2017-09-09 10:28:02.240 info WARN optional
iobroker 2017-09-09 10:28:02.238 info npm
iobroker 2017-09-09 10:27:43.500 info ^
iobroker 2017-09-09 10:27:43.500 info Local error = errorConstructor->NewInstance(1, constructorArgs);
iobroker 2017-09-09 10:27:43.500 info ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:275:72: warning: ‘v8::Local v8::Function::NewInstance(int, v8::
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! not ok
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! node-pre-gyp -v v0.6.30
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! node -v v6.11.2
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! System Linux 4.9.44-v7+
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:891:16)
iobroker 2017-09-09 10:27:36.135 info node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
iobroker 2017-09-09 10:27:36.135 info at ChildProcess. (/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at emitTwo (events.js:106:13
iobroker 2017-09-09 10:27:36.133 info ERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.ble/n
iobroker 2017-09-09 10:27:36.129 info node-pre-gyp
iobroker 2017-09-09 10:27:36.117 info node-pre-gyp ERR! build error
iobroker 2017-09-09 10:27:36.108 info gyp ERR! not ok
iobroker 2017-09-09 10:27:36.106 info ERR! node -v v6.11.2gyp ERR! node-gyp -v v3.6.0
iobroker 2017-09-09 10:27:36.102 info gyp
iobroker 2017-09-09 10:27:36.102 info gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
iobroker 2017-09-09 10:27:36.102 info gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.ble/node_modules/u
iobroker 2017-09-09 10:27:36.102 info gyp ERR! System Linux 4.9.44-v7+
iobroker 2017-09-09 10:27:36.102 info ERR! stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
iobroker 2017-09-09 10:27:36.098 info gyp
iobroker 2017-09-09 10:27:36.096 info gyp ERR! stack at emitTwo (events.js:106:13)
iobroker 2017-09-09 10:27:36.093 info ERR! stack Error:makefailed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
iobroker 2017-09-09 10:27:36.092 info gyp
iobroker 2017-09-09 10:27:36.081 info ERR! build error
iobroker 2017-09-09 10:27:36.079 info
iobroker 2017-09-09 10:27:36.073 info gyp
iobroker 2017-09-09 10:27:36.058 info make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
iobroker 2017-09-09 10:27:35.628 info compilation terminated.
iobroker 2017-09-09 10:27:35.626 info ^
iobroker 2017-09-09 10:27:35.626 info ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden #include
iobroker 2017-09-09 10:27:18.862 info ERR! Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.2.0 and node
iobroker 2017-09-09 10:27:18.806 info node-pre-gyp
iobroker 2017-09-09 10:26:39.288 info npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.ble"
iobroker 2017-09-09 10:26:39.279 info host.raspberrypi install adapter ble
iobroker 2017-09-09 10:26:37.227 info add ble -
