  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.6k Aufrufe 45 Beobachtet
  • A Aragon
    @idlebit
    Mein Fehler hatte in den Einstellungen unter Repositories auf Beta stehen, umgestellt auf Stable.
    Jetzt siehts anders aus, Instanz bleibt GRÜN.
    zigbee2mqtt.0
    	2023-02-18 14:53:17.474	debug	{"date_code":"20210121","definition":{"description":"Aqara presence detector FP1","exposes":[{"access":5,"description":"Indicates whether the device detected presence","name":"presence","property":"presence","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Temperature of the device","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Number of power outages (since last pairing)","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"description":"Presence events: \"enter\", \"leave\", \"left_enter\", \"right_leave\", \"right_enter\", \"left_leave\", \"approach\", \"away\"","name":"presence_event","property":"presence_event","type":"enum","values":["enter","leave","left_enter","right_leave","right_enter","left_leave","approach","away"]},{"access":7,"description":"Monitoring mode with or without considering right and left sides","name":"monitoring_mode","property":"monitoring_mode","type":"enum","values":["undirected","left_right"]},{"access":7,"description":"The distance at which the sensor detects approaching","name":"approach_distance","property":"approach_distance","type":"enum","values":["far","medium","near"]},{"access":7,"description":"Different sensitivities means different static human body recognition rate and response speed of occupied","name":"motion_sensitivity","property":"motion_sensitivity","type":"enum","values":["low","medium","high"]},{"access":2,"description":"Reset the status of no presence","name":"reset_nopresence_status","property":"reset_nopresence_status","type":"enum","values":[""]},{"access":1,"description":"Most recent region event. Event template is \"region_<REGION_ID>_<EVENT_TYPE>\", where <REGION_ID> is region number (1-10), <EVENT_TYPE> is one of \"enter\", \"leave\", \"occupied\", \"unoccupied\". \"enter\" / \"leave\" events are usually triggered first, followed by \"occupied\" / \"unoccupied\" after a couple of seconds.","name":"action","property":"action","type":"enum","values":["region_*_enter","region_*_leave","region_*_occupied","region_*_unoccupied"]},{"access":2,"description":"Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1},{"access":2,"item_type":{"features":[{"access":2,"name":"x","property":"x","type":"numeric","value_max":4,"value_min":1},{"access":2,"name":"y","property":"y","type":"numeric","value_max":7,"value_min":1}],"name":"zone_position","type":"composite"},"name":"zones","property":"zones","type":"list"}],"name":"region_upsert","property":"region_upsert","type":"composite"},{"access":2,"description":"Region definition to be deleted from the device.","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1}],"name":"region_delete","property":"region_delete","type":"composite"},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"RTCZCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":true,"vendor":"Xiaomi"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","aqaraOpple"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","interview_completed":false,"interviewing":false,"manufacturer":"aqara","model_id":"lumi.motion.ac01","network_address":58871,"power_source":"DC Source","software_build_id":"","supported":true,"type":"EndDevice"}
    zigbee2mqtt.0
    	2023-02-18 14:53:17.473	warn	Cannot 0x54ef4410006492a3 create Device from Exposes!
    zigbee2mqtt.0
    	2023-02-18 14:53:17.464	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    	2023-02-18 14:53:17.463	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    zigbee2mqtt.0
    	2023-02-18 14:53:17.462	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    zigbee2mqtt.0
    	2023-02-18 14:53:17.461	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    zigbee2mqtt.0
    	2023-02-18 14:53:17.460	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    zigbee2mqtt.0
    	2023-02-18 14:53:17.459	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
    zigbee2mqtt.0
    	2023-02-18 14:53:17.445	info	Starting interview of '0x54ef4410006492a3'
    zigbee2mqtt.0
    	2023-02-18 14:53:17.433	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
    zigbee2mqtt.0
    	2023-02-18 14:53:17.428	debug	TypeError: Cannot set properties of undefined (setting 'prop')
    IdleBitI Offline
    IdleBitI Offline
    IdleBit
    #324
    @aragon Konnte den Fehler eingrenzen...
    Dieser neuen State mach mir Probleme weil er eine Objekt in einen Objekt ist und das gab es meines Wissens vorher nicht. da muss ich nun mal grübeln wie ich das umsetzte.
                    "access": 2,
                    "description": "Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).",
                    "features": [
                            "access": 2,
                            "name": "region_id",
                            "property": "region_id",
                            "type": "numeric",
                            "value_max": 10,
                            "value_min": 1
                            "access": 2,
                            "item_type": {
                                "features": [
                                        "access": 2,
                                        "name": "x",
                                        "property": "x",
                                        "type": "numeric",
                                        "value_max": 4,
                                        "value_min": 1
                                        "access": 2,
                                        "name": "y",
                                        "property": "y",
                                        "type": "numeric",
                                        "value_max": 7,
                                        "value_min": 1
                                "name": "zone_position",
                                "type": "composite"
                            "name": "zones",
                            "property": "zones",
                            "type": "list"
                    "name": "region_upsert",
                    "property": "region_upsert",
                    "type": "composite"
    A T 2 Antworten Letzte Antwort
    • IdleBitI IdleBit
                      "access": 2,
                      "features": [
                              "access": 2,
                              "type": "numeric",
                              "value_max": 10,
                              "value_min": 1
                              "access": 2,
                              "item_type": {
                                  "features": [
                                          "access": 2,
                                          "name": "x",
                                          "property": "x",
                                          "type": "numeric",
                                          "value_max": 4,
                                          "value_min": 1
                                          "access": 2,
                                          "name": "y",
                                          "property": "y",
                                          "type": "numeric",
                                          "value_max": 7,
                                          "value_min": 1
                                  "type": "composite"
                              "name": "zones",
                              "type": "list"
                      "type": "composite"
      Aragon
      #325
      @idlebit Okay vielen Dank für die Info und deine Mühe
      • IdleBitI IdleBit
                        "access": 2,
                        "features": [
                                "access": 2,
                                "type": "numeric",
                                "value_max": 10,
                                "value_min": 1
                                "access": 2,
                                "item_type": {
                                    "features": [
                                            "access": 2,
                                            "name": "x",
                                            "property": "x",
                                            "type": "numeric",
                                            "value_max": 4,
                                            "value_min": 1
                                            "access": 2,
                                            "name": "y",
                                            "property": "y",
                                            "type": "numeric",
                                            "value_max": 7,
                                            "value_min": 1
                                    "type": "composite"
                                "name": "zones",
                                "type": "list"
                        "type": "composite"
        toralt
        #326
        @idlebit ok, meine Aqaras FP1 sind jetzt alle 4 weg. Ansonsten scheint alles zu gehen.
        << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
        • IdleBitI Offline
          IdleBitI Offline
          IdleBit
          schrieb am zuletzt editiert von IdleBit
          #327
          Testet jetzt mal von git, jetzt sollten die wieder angelegt werden allerdings erstmal ohne diesen neuen State.
          T A 2 Antworten Letzte Antwort
          • IdleBitI IdleBit
            toralt
            #328
            @idlebit Bester Mann! Sind wieder da!
            Vielen Dank!
            • IdleBitI IdleBit
              Aragon
              schrieb am zuletzt editiert von Aragon
              #329
              @idlebit Ich habe jetzt auch einen Eintrag in den Objekten. Dankeschön
                meerkat
                #330
                Guten Morgen zusammen,
                Kann mir einer vielleicht sagen, warum mir im ioBroker nicht der state available angezeigt wird. In den z2m Einstellungen habe ich es aktiviert, aber ich erhalte nur false als Wert.
                Gruß und schönen Sonntag
                IdleBitI 1 Antwort Letzte Antwort
                • M meerkat
                  IdleBitI Offline
                  IdleBitI Offline
                  IdleBit
                  #331
                  @meerkat schon mal hier geschaut ob alles in der Config vorhanden ist?
                  https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/blob/main/docs/DE/DE_get-started.md
                  • IdleBitI IdleBit
                    meerkat
                    #332
                    @idlebit ja, bis auf
                    device_options:
                         legacy: false
                    Habe ich die anderen Sachen auch drin stehen.
                    Availability ist auf true
                    • M meerkat
                      device_options:
                           legacy: false
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #333
                      @meerkat zeigmal die komplette konfig
                      • arteckA arteck
                        meerkat
                        #334
                        @arteck moin, fehler habe ich gefunden. In der Oberfläche habe ich die Option "Legacy availability payload" deaktiviert und nun erhalte ich die availability
                        • M meerkat
                          IdleBitI Offline
                          IdleBitI Offline
                          IdleBit
                          #335
                          @meerkat Ja das steht auch so in der Doku ;)
                          ioT4dbI 1 Antwort Letzte Antwort
                          • IdleBitI IdleBit
                            ioT4dbI Online
                            ioT4dbI Online
                            ioT4db
                            #336
                            Hallo @idlebit
                            zuerst einmal meinen Dank für diesen Adapter. Er funktioniert bei mir wunderbar.
                            Ein Punkt beschäftigt mich jedoch im Moment.
                            Ich habe eine Art Alive-Skript, was mir Geräte (nicht nur Zigbee) anhand des Zeitstempels überwacht. Wenn der state z.B. Temperatur oder Batterie oder oder (je gerät hab ich das individuell gewählt) nicht innerhalb z.B. 1h aktualisiert wird, meldet es mir das Skript.
                            Ich hatte zuvor den Zigbee-Adapter verwendet. Dort war es so, dass die Zeitstempel der States von "geändert" und "aktualisiert" so erzeugt werden wie es wohl auch sein sollte.
                            Beim z2m-Adapter sind jedoch die Zeitstempel für aktualisiert und geändert immer gleich. Ist das so gewollt bzw. könnte man das Verhalten hier noch anpassen?
                            Ich hoffe ich hab mich nicht zu umständlich ausgedrückt :)
                            Danke und Grüße
                            Daniel
                            • ioT4dbI ioT4db
                              Hallo @idlebit
                              Danke und Grüße
                              Daniel
                              IdleBitI Offline
                              IdleBitI Offline
                              IdleBit
                              #337
                              @friesenjung Bei den Adapter werden Datenpunkte nur unter zwei Bedingungen neu gesetzt, die erste wäre wenn sich ein Wert ändert und die zweite ist wenn es sich um ein Event handelt.
                              Ein Event wird von zigbee2mqtt vorgeben und ist z.B. ein Taster oder der gleichen.
                              Hier wurde schon mal darüber diskutiert -> https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/issues/119
                              Die Alive Logik kann man das auch wunderbar anpassen wenn die ein im Default nicht gefällt.
                              • IdleBitI IdleBit
                                ioT4dbI Online
                                ioT4dbI Online
                                ioT4db
                                #338
                                Hi @IdleBit
                                danke für die Rückmeldung und die Info mit der Availability in z2m. Hatte ich nicht so auf dem Schirm, jedoch nachdem ich mir es angeschaut habe, ist es eher nicht das was ich suche.
                                Hier kann man nur einen globalen Wert für z.B. batteriebetriebene Sensoren angeben. Da sich die vielen Geräte aber im Verhalten sehr stark voneinander unterscheiden (also wie oft und wann sie Dinge senden bzw. sich melden) ist hier auch sinnvollerweise ein recht hoher Wert angegeben (1500 Min. alsoe etwas länger als ein Tag) den ich auch nicht global ändern möchte.
                                Es gab hier auch mal den Wunsch den "last_seen-Datenpunkt" zu übertragen: https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/issues/131
                                Das würde vielleicht schon eher meinen Fall (zugegebenermaßen vielleicht Einzelfall :) ) "lösen" können.
                                Wenn ich Dich richtig verstanden habe, liegt es aber in erster Linie ja daran, dass z2m nur Werteänderungen und Events weitergibt. richtig?
                                Also kann der (andere) Zigbee-Adapter den Zeitstempel für aktualisierte Werte (gleicher Wert aber neu gesendet) wohl nur angeben, weil dieser die Payloads der Geräte selber "auswertet" > richtig?
                                Ich wills nur verstehen :)
                                Daniel
                                • ioT4dbI ioT4db
                                  Hi @IdleBit
                                  Daniel
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #339
                                  @friesenjung sagte in Test Adapter zigbee2mqtt:
                                  jo genau so ist es
                                  • arteckA arteck
                                    jo genau so ist es
                                    IdleBitI Offline
                                    IdleBitI Offline
                                    IdleBit
                                    #340
                                    @arteck sagte in Test Adapter zigbee2mqtt:
                                    jo genau so ist es
                                    Ne nicht ganz, auch dieser Adapter wertet die Payloads selbst aus.
                                    Bloß ich habe mich dazu entscheiden nicht unsinnig alles in die StatesDB zu knallen, so setzte ich im Adapter nur Werte die sich ändern, außer diese stammen von "Zigbee-Event".
                                    • IdleBitI IdleBit
                                      jo genau so ist es
                                      ioT4dbI Online
                                      ioT4dbI Online
                                      ioT4db
                                      #341
                                      hi @IdleBit
                                      bitte nicht falsch verstehen, ist vielleicht nur ein kläglicher Versuch dich umzustimmen :)
                                      aber ich dachte genau dafür gibt es in ioB die 2 Zeitstempel.
                                      Die Daten sind ja tatsächlich übermittelt worden und wenn es der gleiche Wert ist, dann eben nur aktualisiert.
                                      • ioT4dbI ioT4db
                                        hi @IdleBit
                                        IdleBitI Offline
                                        IdleBitI Offline
                                        IdleBit
                                        #342
                                        @friesenjung Teste mal die aktuelle Git Version, dort habe ich last_seen hinzugefügt .
                                        • IdleBitI IdleBit
                                          ioT4dbI Online
                                          ioT4dbI Online
                                          ioT4db
                                          #343
                                          @idlebit klasse! funktioniert. vielen dank für die rasche umsetzung! :)
