  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.6k Aufrufe 45 Beobachtet
  • IdleBitI IdleBit
    Das scheint aber nicht die aktuelle Version vom git zu sein.
    Wie bist du vorgegangen?
    Aragon
    #320
    @idlebit
    Instanz entfernt
    Expertenmodus eingeschaltet
    auf die Katze geklickt
    dann von Github geklickt
    Adapter aus Liste ausgesucht und installiert
    Anschließend Adapter installiert
    IdleBitI 1 Antwort Letzte Antwort
    • A Aragon
      @idlebit
      Instanz entfernt
      IdleBitI Offline
      IdleBitI Offline
      IdleBit
      #321
      @aragon Entfernen musst du nichts, aber der Rest passt .. komisch ich prüfe ..
      • IdleBitI IdleBit
        Aragon
        #322
        @idlebit
        Mein Fehler hatte in den Einstellungen unter Repositories auf Beta stehen, umgestellt auf Stable.
        Jetzt siehts anders aus, Instanz bleibt GRÜN.
        zigbee2mqtt.0
        	2023-02-18 14:53:17.474	debug	{"date_code":"20210121","definition":{"description":"Aqara presence detector FP1","exposes":[{"access":5,"description":"Indicates whether the device detected presence","name":"presence","property":"presence","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Temperature of the device","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Number of power outages (since last pairing)","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"description":"Presence events: \"enter\", \"leave\", \"left_enter\", \"right_leave\", \"right_enter\", \"left_leave\", \"approach\", \"away\"","name":"presence_event","property":"presence_event","type":"enum","values":["enter","leave","left_enter","right_leave","right_enter","left_leave","approach","away"]},{"access":7,"description":"Monitoring mode with or without considering right and left sides","name":"monitoring_mode","property":"monitoring_mode","type":"enum","values":["undirected","left_right"]},{"access":7,"description":"The distance at which the sensor detects approaching","name":"approach_distance","property":"approach_distance","type":"enum","values":["far","medium","near"]},{"access":7,"description":"Different sensitivities means different static human body recognition rate and response speed of occupied","name":"motion_sensitivity","property":"motion_sensitivity","type":"enum","values":["low","medium","high"]},{"access":2,"description":"Reset the status of no presence","name":"reset_nopresence_status","property":"reset_nopresence_status","type":"enum","values":[""]},{"access":1,"description":"Most recent region event. Event template is \"region_<REGION_ID>_<EVENT_TYPE>\", where <REGION_ID> is region number (1-10), <EVENT_TYPE> is one of \"enter\", \"leave\", \"occupied\", \"unoccupied\". \"enter\" / \"leave\" events are usually triggered first, followed by \"occupied\" / \"unoccupied\" after a couple of seconds.","name":"action","property":"action","type":"enum","values":["region_*_enter","region_*_leave","region_*_occupied","region_*_unoccupied"]},{"access":2,"description":"Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1},{"access":2,"item_type":{"features":[{"access":2,"name":"x","property":"x","type":"numeric","value_max":4,"value_min":1},{"access":2,"name":"y","property":"y","type":"numeric","value_max":7,"value_min":1}],"name":"zone_position","type":"composite"},"name":"zones","property":"zones","type":"list"}],"name":"region_upsert","property":"region_upsert","type":"composite"},{"access":2,"description":"Region definition to be deleted from the device.","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1}],"name":"region_delete","property":"region_delete","type":"composite"},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"RTCZCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":true,"vendor":"Xiaomi"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","aqaraOpple"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","interview_completed":false,"interviewing":false,"manufacturer":"aqara","model_id":"lumi.motion.ac01","network_address":58871,"power_source":"DC Source","software_build_id":"","supported":true,"type":"EndDevice"}
        zigbee2mqtt.0
        	2023-02-18 14:53:17.473	warn	Cannot 0x54ef4410006492a3 create Device from Exposes!
        zigbee2mqtt.0
        	2023-02-18 14:53:17.464	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        	2023-02-18 14:53:17.463	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        zigbee2mqtt.0
        	2023-02-18 14:53:17.462	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        zigbee2mqtt.0
        	2023-02-18 14:53:17.461	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        zigbee2mqtt.0
        	2023-02-18 14:53:17.460	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        zigbee2mqtt.0
        	2023-02-18 14:53:17.459	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
        zigbee2mqtt.0
        	2023-02-18 14:53:17.445	info	Starting interview of '0x54ef4410006492a3'
        zigbee2mqtt.0
        	2023-02-18 14:53:17.433	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
        zigbee2mqtt.0
        	2023-02-18 14:53:17.428	debug	TypeError: Cannot set properties of undefined (setting 'prop')
        • IdleBitI IdleBit
          @aragon Kannst du mal aus dem Git installieren?
          Jetzt sollte maximal "nur" noch ein Warning auftauchen, und wenn du auf Debug stellst sollte es noch mehr Infos über das Problem kommen...
          Könntest Du mir die mal zu Verfügung stellen?
          @toralt das könnte auch mit deinen Problem zusammenhängen also nen Versuch wert ;)
          toralt
          #323
          @idlebit ich habs jetzt nicht ganz kapiert, habe aber auch 4 x FP1 im Einsatz. Ich habe nun auch mit der Katze via Github nochmal den Treiber installiert.
          Habe eben den 1.30.1 Container gestartet -> Läuft!
          Besten Dank!
          << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
          • A Aragon
            @idlebit
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            zigbee2mqtt.0
            IdleBitI Offline
            IdleBitI Offline
            IdleBit
            #324
            @aragon Konnte den Fehler eingrenzen...
            Dieser neuen State mach mir Probleme weil er eine Objekt in einen Objekt ist und das gab es meines Wissens vorher nicht. da muss ich nun mal grübeln wie ich das umsetzte.
                            "access": 2,
                            "description": "Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).",
                            "features": [
                                    "access": 2,
                                    "name": "region_id",
                                    "property": "region_id",
                                    "type": "numeric",
                                    "value_max": 10,
                                    "value_min": 1
                                    "access": 2,
                                    "item_type": {
                                        "features": [
                                                "access": 2,
                                                "name": "x",
                                                "property": "x",
                                                "type": "numeric",
                                                "value_max": 4,
                                                "value_min": 1
                                                "access": 2,
                                                "name": "y",
                                                "property": "y",
                                                "type": "numeric",
                                                "value_max": 7,
                                                "value_min": 1
                                        "name": "zone_position",
                                        "type": "composite"
                                    "name": "zones",
                                    "property": "zones",
                                    "type": "list"
                            "name": "region_upsert",
                            "property": "region_upsert",
                            "type": "composite"
            A T 2 Antworten Letzte Antwort
            • IdleBitI IdleBit
                              "access": 2,
                              "features": [
                                      "access": 2,
                                      "type": "numeric",
                                      "value_max": 10,
                                      "value_min": 1
                                      "access": 2,
                                      "item_type": {
                                          "features": [
                                                  "access": 2,
                                                  "name": "x",
                                                  "property": "x",
                                                  "type": "numeric",
                                                  "value_max": 4,
                                                  "value_min": 1
                                                  "access": 2,
                                                  "name": "y",
                                                  "property": "y",
                                                  "type": "numeric",
                                                  "value_max": 7,
                                                  "value_min": 1
                                          "type": "composite"
                                      "name": "zones",
                                      "type": "list"
                              "type": "composite"
              Aragon
              #325
              @idlebit Okay vielen Dank für die Info und deine Mühe
              • IdleBitI IdleBit
                                "access": 2,
                                "features": [
                                        "access": 2,
                                        "type": "numeric",
                                        "value_max": 10,
                                        "value_min": 1
                                        "access": 2,
                                        "item_type": {
                                            "features": [
                                                    "access": 2,
                                                    "name": "x",
                                                    "property": "x",
                                                    "type": "numeric",
                                                    "value_max": 4,
                                                    "value_min": 1
                                                    "access": 2,
                                                    "name": "y",
                                                    "property": "y",
                                                    "type": "numeric",
                                                    "value_max": 7,
                                                    "value_min": 1
                                            "type": "composite"
                                        "name": "zones",
                                        "type": "list"
                                "type": "composite"
                toralt
                #326
                @idlebit ok, meine Aqaras FP1 sind jetzt alle 4 weg. Ansonsten scheint alles zu gehen.
                • IdleBitI Offline
                  IdleBitI Offline
                  IdleBit
                  schrieb am zuletzt editiert von IdleBit
                  #327
                  Testet jetzt mal von git, jetzt sollten die wieder angelegt werden allerdings erstmal ohne diesen neuen State.
                  T A 2 Antworten Letzte Antwort
                  • IdleBitI IdleBit
                    toralt
                    #328
                    @idlebit Bester Mann! Sind wieder da!
                    Vielen Dank!
                    • IdleBitI IdleBit
                      Aragon
                      schrieb am zuletzt editiert von Aragon
                      #329
                      @idlebit Ich habe jetzt auch einen Eintrag in den Objekten. Dankeschön
                        meerkat
                        #330
                        Guten Morgen zusammen,
                        Kann mir einer vielleicht sagen, warum mir im ioBroker nicht der state available angezeigt wird. In den z2m Einstellungen habe ich es aktiviert, aber ich erhalte nur false als Wert.
                        Gruß und schönen Sonntag
                        • M meerkat
                          IdleBitI Offline
                          IdleBitI Offline
                          IdleBit
                          #331
                          @meerkat schon mal hier geschaut ob alles in der Config vorhanden ist?
                          https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/blob/main/docs/DE/DE_get-started.md
                          • IdleBitI IdleBit
                            meerkat
                            #332
                            @idlebit ja, bis auf
                            device_options:
                                 legacy: false
                            Habe ich die anderen Sachen auch drin stehen.
                            Availability ist auf true
                            • M meerkat
                              device_options:
                                   legacy: false
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #333
                              @meerkat zeigmal die komplette konfig
                              • arteckA arteck
                                meerkat
                                #334
                                @arteck moin, fehler habe ich gefunden. In der Oberfläche habe ich die Option "Legacy availability payload" deaktiviert und nun erhalte ich die availability
                                • M meerkat
                                  IdleBitI Offline
                                  IdleBitI Offline
                                  IdleBit
                                  #335
                                  @meerkat Ja das steht auch so in der Doku ;)
                                  ioT4dbI 1 Antwort Letzte Antwort
                                  • IdleBitI IdleBit
                                    ioT4dbI Online
                                    ioT4dbI Online
                                    ioT4db
                                    #336
                                    Hallo @idlebit
                                    zuerst einmal meinen Dank für diesen Adapter. Er funktioniert bei mir wunderbar.
                                    Ein Punkt beschäftigt mich jedoch im Moment.
                                    Ich habe eine Art Alive-Skript, was mir Geräte (nicht nur Zigbee) anhand des Zeitstempels überwacht. Wenn der state z.B. Temperatur oder Batterie oder oder (je gerät hab ich das individuell gewählt) nicht innerhalb z.B. 1h aktualisiert wird, meldet es mir das Skript.
                                    Ich hatte zuvor den Zigbee-Adapter verwendet. Dort war es so, dass die Zeitstempel der States von "geändert" und "aktualisiert" so erzeugt werden wie es wohl auch sein sollte.
                                    Beim z2m-Adapter sind jedoch die Zeitstempel für aktualisiert und geändert immer gleich. Ist das so gewollt bzw. könnte man das Verhalten hier noch anpassen?
                                    Ich hoffe ich hab mich nicht zu umständlich ausgedrückt :)
                                    Danke und Grüße
                                    Daniel
                                    • ioT4dbI ioT4db
                                      Hallo @idlebit
                                      Danke und Grüße
                                      Daniel
                                      IdleBitI Offline
                                      IdleBitI Offline
                                      IdleBit
                                      #337
                                      @friesenjung Bei den Adapter werden Datenpunkte nur unter zwei Bedingungen neu gesetzt, die erste wäre wenn sich ein Wert ändert und die zweite ist wenn es sich um ein Event handelt.
                                      Ein Event wird von zigbee2mqtt vorgeben und ist z.B. ein Taster oder der gleichen.
                                      Hier wurde schon mal darüber diskutiert -> https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/issues/119
                                      Die Alive Logik kann man das auch wunderbar anpassen wenn die ein im Default nicht gefällt.
                                      • IdleBitI IdleBit
                                        ioT4dbI Online
                                        ioT4dbI Online
                                        ioT4db
                                        #338
                                        Hi @IdleBit
                                        danke für die Rückmeldung und die Info mit der Availability in z2m. Hatte ich nicht so auf dem Schirm, jedoch nachdem ich mir es angeschaut habe, ist es eher nicht das was ich suche.
                                        Hier kann man nur einen globalen Wert für z.B. batteriebetriebene Sensoren angeben. Da sich die vielen Geräte aber im Verhalten sehr stark voneinander unterscheiden (also wie oft und wann sie Dinge senden bzw. sich melden) ist hier auch sinnvollerweise ein recht hoher Wert angegeben (1500 Min. alsoe etwas länger als ein Tag) den ich auch nicht global ändern möchte.
                                        Es gab hier auch mal den Wunsch den "last_seen-Datenpunkt" zu übertragen: https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/issues/131
                                        Das würde vielleicht schon eher meinen Fall (zugegebenermaßen vielleicht Einzelfall :) ) "lösen" können.
                                        Wenn ich Dich richtig verstanden habe, liegt es aber in erster Linie ja daran, dass z2m nur Werteänderungen und Events weitergibt. richtig?
                                        Also kann der (andere) Zigbee-Adapter den Zeitstempel für aktualisierte Werte (gleicher Wert aber neu gesendet) wohl nur angeben, weil dieser die Payloads der Geräte selber "auswertet" > richtig?
                                        Ich wills nur verstehen :)
                                        Daniel
                                        • ioT4dbI ioT4db
                                          Hi @IdleBit
                                          Daniel
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #339
                                          @friesenjung sagte in Test Adapter zigbee2mqtt:
                                          jo genau so ist es
