  3. Einsteigerfragen
  4. Installation
  5. 2 mal ioBoker installieren unter Proxmox
51 Beiträge 6 Kommentatoren 5.1k Aufrufe 6 Beobachtet
  • W Wolfshunter
    @dp20eic
    oot@proxmox:~# rfkill
    ID TYPE      DEVICE      SOFT      HARD
     1 bluetooth hci0   unblocked unblocked
    root@proxmox:~# bluetoothctl
    Agent registered
    [bluetooth]# help
    Menu main:
    Available commands:
    advertise                                         Advertise Options Submenu
    scan                                              Scan Options Submenu
    gatt                                              Generic Attribute Submenu
    list                                              List available controllers
    show [ctrl]                                       Controller information
    select <ctrl>                                     Select default controller
    devices                                           List available devices
    paired-devices                                    List paired devices
    system-alias <name>                               Set controller alias
    reset-alias                                       Reset controller alias
    power <on/off>                                    Set controller power
    pairable <on/off>                                 Set controller pairable mode
    discoverable <on/off>                             Set controller discoverable mode
    discoverable-timeout [value]                      Set discoverable timeout
    agent <on/off/capability>                         Enable/disable agent with given capability
    default-agent                                     Set agent as the default one
    advertise <on/off/type>                           Enable/disable advertising with given type
    set-alias <alias>                                 Set device alias
    scan <on/off>                                     Scan for devices
    info [dev]                                        Device information
    pair [dev]                                        Pair with device
    cancel-pairing [dev]                              Cancel pairing with device
    trust [dev]                                       Trust device
    untrust [dev]                                     Untrust device
    block [dev]                                       Block device
    unblock [dev]                                     Unblock device
    remove <dev>                                      Remove device
    connect <dev>                                     Connect device
    disconnect [dev]                                  Disconnect device
    menu <name>                                       Select submenu
    version                                           Display version
    quit                                              Quit program
    exit                                              Quit program
    help                                              Display help about this program
    export                                            Print environment variables
    wendy2702W Offline
    wendy2702W Offline
    @wolfshunter Sieht so aus als wenn der Chipsatz nicht erkannt wird da immer noch keine Adresse vom Device ausgegeben wird.
    W 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      W Offline
      W Offline
      Wolfshunter
      @wendy2702
      ist der Stick vielleicht def. oder nicht Linux kompatible
      wendy2702W ? 2 Antworten Letzte Antwort
      • W Wolfshunter
        @wendy2702
        wendy2702W Offline
        wendy2702W Offline
        @wolfshunter Denke eher nicht „kompatibel“ aber wie @dp20eic geschrieben hat solltest du dem Link mal nachgehen den er gepostet hat.
          W Offline
          W Offline
          Wolfshunter
          @wendy2702
          Ok ich werde das mal testen. Und mich dann wieder melden.
          • W Wolfshunter
            ich haabe mal eine Frage. Da es Probleme gibt mit den durchreichen von BT an einen LXC Container
            gibt, überlege ich das ich folgendes mache:
            • Proxmox installieren
            • LXC Container mit ioBroker installieren und konfigurieren
            • ioBroker direkt auf dem Proxmox Server installieren (So das ich BT nutzen kann)
            Dann Multi-Hosting (Cluster) nutzen um so BT unter dem ioBroker nutzen zu können.
            Hat das schon mal jemand gemacht? Würdet Ihr das auch so machen oder sollte man das nicht tun.
            Achja, ich möchte schon den Proxmox nutzen da ich auch überlege noch einen weiteren Client zu
            nutzen für das Nutzen einer IP Cam in Zukunft.
            Solltet ihr noch Infos brauchtén fragt mich. Hoffe das ihr mir hier den einen oder andeen Tip geben könnt.
            da_WoodyD Offline
            da_WoodyD Offline
            @wolfshunter vllt versteh ich dein prob nicht...
            proxmox, ioB in eine VM, andere von mir aus in LXC wenn du dort nichts durchreichen musst.
            • da_WoodyD da_Woody
              wendy2702W Offline
              wendy2702W Offline
              @da_woody ER will einen Bluetooth USB Stick durchreichen.
              Der wird aber aktuell nichtmal unter Proxmox richtig erkannt.
              W da_WoodyD 2 Antworten Letzte Antwort
                W Offline
                W Offline
                Wolfshunter
                @wendy2702
                ich glaube da muß ich aktuell aufgeben. Scheint so das ich den Kernel anpassen soll. Bin nicht so Linux Fit das ich das ohne Probleme hinbekomme.
                Habe mit dmesg folgendes gefunden:
                [  239.145207] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                [  239.145211] usb 1-1.2: Product: Bluetooth Radio
                [  239.145213] usb 1-1.2: Manufacturer: Realtek
                [  239.145215] usb 1-1.2: SerialNumber: 00E04C239987
                [  239.147219] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
                [  239.149017] Bluetooth: hci0: RTL: rom_version status=0 version=1
                [  239.149033] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
                [  239.149132] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761bu_fw.bin failed with error -2
                [  239.149139] Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8761bu_fw.bin not found
                root@proxmox:~#
                wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                  da_WoodyD Offline
                  da_WoodyD Offline
                  @wendy2702 schon verstanden, aber wie kann man auf seine idea kommen?
                  • W Wolfshunter
                    @wendy2702
                    root@proxmox:~#
                    wendy2702W Offline
                    wendy2702W Offline
                    @wolfshunter OK.
                    Muss zugeben das ich den Kernel jetzt unter Proxmox auch nicht neubauen würde. Könnte zu unschönen Nebeneffekten kommen.
                    Kannst noch VM probieren oder für paar € neuen Stick besorgen.
                      @wolfshunter OK.
                      W Offline
                      W Offline
                      Wolfshunter
                      schrieb am zuletzt editiert von Wolfshunter
                      @wendy2702
                      ich hab ja eine VM doch dort sehe ich den erst garnicht.
                      Vielleicht sollte ich mir eine WLAN Karte mit passenden Antennen holen. Das hat beim anderen funktioniert.
                      • W Wolfshunter
                        @wendy2702
                        root@proxmox:~#
                        @wolfshunter
                        Da fehlt die Firmware für den Stick
                        Gibt es meist als Paket in non-free oder so.
                        Paket nennt sich firmware-realtek
                        Aber ob und wie das bei Proxmox geht? Keine Ahnung.
                        • W Wolfshunter
                          @wendy2702
                          da_WoodyD Offline
                          da_WoodyD Offline
                          @wolfshunter eventuell ein config prob in der VM?
                          hast du da USB überhaupt aktiv? hab sowas nicht, aber hier
                          kannst du USB über hinzufürgen einbinden.
                          ? W 2 Antworten Letzte Antwort
                          • W Wolfshunter
                            @wendy2702
                            @wolfshunter
                            Moin,
                            dazu brauchten wir erst einmal die genaue Bezeichnung des Sticks, ich hatte ja oben schon mal eine Seite linux hardware angepinnt, wo es eine Zuordnung gibt, es kann auch ein Problem zwischen Motherboard USB und dem Stick sein.
                            Auch die letzten Seiten sind von 2020, somit sollte es eigentlich 2-3 Jahre später Kernel technisch gelöst sein, es sei denn die Firmen rücken die Informationen nicht für die Linux Kernel Entwickler raus und die haben dann keine Lust Reverse Engineering zu betreiben um jedes Device zu implementieren.
                            Also Du must auch noch mal in die kernel messages schauen
                            # root@pve:~# dmesg | grep -i blue
                            Sollte dort etwas wie kommen, dann fehlt Firmware für diesen Bluetooth Stick
                            bluetooth hci0: Direct firmware load for ... failed with error ...
                            Wie man das dann bei einem RTL8761B-Chip macht, steht im Link.
                            Bernd
                              @da_woody
                              Moin,
                              er ist ja noch nicht so weit, das er in einem LXC Container oder in einer VM den Stick benutzen kann ;)
                              Proxmox erkennt den Stick ja schon nicht mal, da kann er anschließen frickeln wie er will, datt wird so nichts :(
                              Erst in Proxmox sauber einbinden, was bei mancher Hardware unter Linux leider manchmal schwer fällt, da die Firmen nur an KleinWeich Informationen geben und die Freien-, Open Source Entwickler in die Röhre schauen :(
                              Deswegen gilt für mich immer erst auf z.B. Linux-Hardware nachschauen ob die Hardware unterstützt wird, dann kaufen :)
                              Bernd
                                @da_woody
                                Moin,
                                Bernd
                                W Offline
                                W Offline
                                Wolfshunter
                                @dp20eic
                                Ich habe jetzt eine rtl8761bu_fw.bin und eine rtl8761bu_config.bin gefunden, kann ich die einfach in das Firmware Verzeichnich auf dem Proxmox reinkopieren? Ohne mir das System zu zerschießen?
                                • W Wolfshunter
                                  @dp20eic
                                  @wolfshunter
                                  https://wiki.ubuntuusers.de/Howto/Realtek_Bluetooth_5_Adapter_unter_Ubuntu/
                                  Sollte auf Proxmox ähnlich funktionieren.
                                    @wolfshunter
                                    Moin,
                                    ja, genau den Link hatte ich oben auch angepinnt :)
                                    Thomas BraunT W 2 Antworten Letzte Antwort
                                      Moin,
                                      @dp20eic
                                      Ja, den habe ich nur nochmal in voller Länge gepostet. Die Links werden gerne übersehen.
                                        Moin,
                                        W Offline
                                        W Offline
                                        Wolfshunter
                                        @dp20eic
                                        habe nun die beiden Dateien bei mir hier auf dem System. Wollte die gleich auf den Proxmox laden. Muß ich da noch was beachten??
                                          @dp20eic
                                          @thomas-braun sagte in 2 mal ioBoker installieren unter Proxmox:
                                          @dp20eic
                                          Moin,
                                          stimmt :)
                                          Wichtig ist aber immer noch, das es sich auch wirklich bei dem Stick um einen mit diesem Chip handelt. Leider gibt es nicht out of the Box alles unter Proxmox, somit muss man da leider am Grundsystem basteln, was ich ungern unerfahrenen anraten möchte.
                                          Also auf eigene Gefahr:
                                          # apt install lshw
                                          Dann
                                          # lshw | grep "description: Bluetooth wireless interface" -A 8
                                          Unter Produkt sollte die Bezeichnung für den Stick stehen.
                                          @Wolfshunter
                                          Wenn Du das Problem gelöst hast, dann solltest Du rfkill und lshw wieder deinstallieren.
