  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.7k
766 Beiträge 51 Kommentatoren 323.3k Aufrufe 52 Beobachtet
  • D DonToben
    @copystring said in Roborock Adapter tester gesucht:
    @dontoben said in Roborock Adapter tester gesucht:
    @hunter-0 said in Roborock Adapter tester gesucht:
    @dontoben
    Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
    Gleiches Problem mit Node v16.19.0
    Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
    $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
    install copystring/ioBroker.roborock
    NPM version: 6.14.5
    Installing copystring/ioBroker.roborock... (System call)
    > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
    (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
    CXX(target) Release/obj.target/canvas/src/Backends.o
    CXX(target) Release/obj.target/canvas/src/Canvas.o
    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
    CXX(target) Release/obj.target/canvas/src/closure.o
    CXX(target) Release/obj.target/canvas/src/color.o
    CXX(target) Release/obj.target/canvas/src/Image.o
    CXX(target) Release/obj.target/canvas/src/ImageData.o
    CXX(target) Release/obj.target/canvas/src/init.o
    CXX(target) Release/obj.target/canvas/src/register_font.o
    SOLINK_MODULE(target) Release/obj.target/canvas.node
    COPY Release/canvas.node
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
    48 packages are looking for funding run `npm fund` for details
    upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
    Process exited with code 0
    Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
    Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
    Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
    @copystring
    Ja das ist issue 40.
    Ich mache dann heute mit deinen Anweisungen aus issue 40 weiter. Oder soll ich noch etwas anderes installieren?
    copystringC Offline
    copystringC Offline
    copystring
    #233
    @dontoben Siehe github.
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • H Offline
      Hunter 0
      #234
      Da es noch keine neue Version ist, weiß ich nicht ob es ein Issue für Github ist. Main Branch stand jetzt:
      • H Hunter 0
        wendy2702W Offline
        wendy2702W Offline
        #235
        @hunter-0 Bitte vollständiges Log als text in Code Tags </> posten.
        Und vielleicht noch mitteilen was für ein System das ist.
        • wendy2702W Offline
          wendy2702W Offline
          #236
          aktualisieren sich bei euch die Objekte noch?
          Unser Sauger ist eben gefahren und ich kann keine Änderung in den Objekten feststellen.
          Batterie z.B.
          Nach knapp 45 minuten Arbeit unverändert.
          Bisschen was RAM belegt er auch:
          Und im Log passiert zum Adapter nichts mehr.
          Erst nach restart kommen die neuen Werte aber beim RAM hochzählen kann ich zugucken:
          Restart log ohne Debug:
          mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep roborock
          2023-02-02 15:50:38.847  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
          2023-02-02 15:50:38.851  - info: roborock.0 (77838) Got terminate signal TERMINATE_YOURSELF
          2023-02-02 15:50:38.853  - info: roborock.0 (77838) terminating
          2023-02-02 15:50:38.854  - info: roborock.0 (77838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-02-02 15:50:39.007  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
          2023-02-02 15:50:40.012  - info: host.iobroker stopInstance system.adapter.roborock.0 killing pid 77838
          2023-02-02 15:50:40.323  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-02-02 15:50:42.148  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89295
          2023-02-02 15:50:43.974  - info: roborock.0 (89295) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
          2023-02-02 15:50:44.177  - info: roborock.0 (89295) MQTT initialized
          2023-02-02 15:51:23.345  - info: host.iobroker "system.adapter.roborock.0" disabled
          2023-02-02 15:51:23.346  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
          2023-02-02 15:51:23.360  - info: roborock.0 (89295) Got terminate signal TERMINATE_YOURSELF
          2023-02-02 15:51:23.364  - info: roborock.0 (89295) terminating
          2023-02-02 15:51:23.365  - info: roborock.0 (89295) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-02-02 15:51:23.392  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
          2023-02-02 15:51:23.954  - warn: roborock.0 (89295) get state error: Connection is closed.
          2023-02-02 15:51:23.956  - error: roborock.0 (89295) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-02-02 15:51:23.956  - error: roborock.0 (89295) unhandled promise rejection: DB closed
          2023-02-02 15:51:23.956  - error: roborock.0 (89295) Error: DB closed
          2023-02-02 15:51:23.956  - error: roborock.0 (89295) DB closed
          2023-02-02 15:51:24.059  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-02-02 15:52:43.193  - info: host.iobroker "system.adapter.roborock.0" enabled
          2023-02-02 15:52:43.422  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89332
          2023-02-02 15:52:44.603  - info: roborock.0 (89332) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
          2023-02-02 15:52:44.827  - info: roborock.0 (89332) MQTT initialized
          2023-02-02 15:54:25.755  - info: host.iobroker "system.adapter.roborock.0" disabled
          2023-02-02 15:54:25.756  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
          2023-02-02 15:54:25.769  - info: roborock.0 (89332) Got terminate signal TERMINATE_YOURSELF
          2023-02-02 15:54:25.772  - info: roborock.0 (89332) terminating
          2023-02-02 15:54:25.772  - info: roborock.0 (89332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-02-02 15:54:25.800  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
          2023-02-02 15:54:26.440  - warn: roborock.0 (89332) get state error: Connection is closed.
          2023-02-02 15:54:26.441  - error: roborock.0 (89332) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-02-02 15:54:26.441  - error: roborock.0 (89332) unhandled promise rejection: DB closed
          2023-02-02 15:54:26.442  - error: roborock.0 (89332) Error: DB closed
          2023-02-02 15:54:26.442  - error: roborock.0 (89332) DB closed
          2023-02-02 15:54:26.533  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          @copystring : soll ich ein Issue aufmachen?
          Desweiteren, kann man es vielleicht so machen das die Karte nur aktualisiert wird wenn das Kerlchen fährt?
          copystringC 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            Batterie z.B.
            copystringC Offline
            copystringC Offline
            copystring
            schrieb am zuletzt editiert von copystring
            #237
            @wendy2702 Ja bitte ein Issue öffnen. Es scheint so zu sein, dass viel RAM belegt wird wenn unbekannte Befehle oder Statusnachrichten vorliegen. Siehe https://github.com/copystring/ioBroker.roborock/issues/34 und https://github.com/copystring/ioBroker.roborock/issues/49
            Für solche Probleme brauche ich Tester da ich den passenden Saugroboter nicht habe. Hier z.B. den Roborock S7 MaxV (Ultra). Für den Roboter kann https://github.com/copystring/ioBroker.roborock/compare/update_robot_attributes getestet werden.
            • copystringC copystring
              wendy2702W Offline
              wendy2702W Offline
              #238
              @copystring sagte in Roborock Adapter tester gesucht:
              Ich habe mich an das Issue dran gehangen, oder wolltest du zwingend ein neues?
              Für das Map Update neues Issue:
              https://github.com/copystring/ioBroker.roborock/issues/50
                copystringC Offline
                copystringC Offline
                copystring
                #239
                @wendy2702 Ist schon ok so.
                M-A HuebM 1 Antwort Letzte Antwort
                  M-A HuebM Offline
                  M-A HuebM Offline
                  M-A Hueb
                  schrieb am zuletzt editiert von M-A Hueb
                  #240
                  Hab mir jetzt mal Seq installiert, dann kann man besser das Log ziehen.
                  Seq
                  Gibts auch nen Adapter dazu
                  iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                  • M-A HuebM M-A Hueb
                    Seq
                    simplyclever
                    #241
                    @m-a-hueb Die Funktion suche ich auch. Aktuell lade ich den Log runter und (Linux/Mac) führe dann dieses Kommando in einer Shell aus:
                    grep ": roborock" log.txt | sed 's/Name1/Kind1/' | sed 's/Name2/Kind2/' > robolog.txt
                    Das grep filtert die roborock Eintröge aus dem Log, die beiden sed ersetzen die realen Namen meiner Kinder (die Räume sind so benannt) durch KindX..
                    • S simplyclever
                      M-A HuebM Offline
                      M-A HuebM Offline
                      M-A Hueb
                      #242
                      @simplyclever Danke aber bin unter Windows unterwegs. Mit dem Seq Tool ist das recht easy jetzt
                        wendy2702W Offline
                        #243
                        Log in Notepad++ geht auch
                          M-A HuebM Offline
                          M-A HuebM Offline
                          M-A Hueb
                          #244
                          @wendy2702 Wie meinst du?
                            wendy2702W Offline
                            wendy2702W Offline
                            #245
                            @m-a-hueb Das Log kann man auch in Notepad++ öffnen und einfach nach Roborock filtern. bzw. suchen.
                            Dann erhält man auch eine Ausgabe in der nur die Daten vom Roborock Adapter stehen.
                            Könnte dann z.B. so aus sehen mit FTP Plugin rechts auf iobroker und dort direkt das log anklicken. Dann mit STRG+F im Beispiel nach allen "ical.2" einträgen in der offenen Datei gesucht. Ergebnis dann unten.
                            • H Offline
                              Hunter 0
                              #246
                              Das ist der aktuelle Main Branch, soll ich ein Issue auf machen?
                              2023-02-04 15:43:18.241 - info: host.pIOBroker "system.adapter.roborock.0" enabled
                              2023-02-04 15:43:18.283 - info: host.pIOBroker instance system.adapter.roborock.0 started with pid 285887
                              2023-02-04 15:43:18.728 - debug: roborock.0 (285887) Redis Objects: Use Redis connection: 0.0.0.0:9001
                              2023-02-04 15:43:18.745 - debug: roborock.0 (285887) Objects client ready ... initialize now
                              2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create System PubSub Client
                              2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create User PubSub Client
                              2023-02-04 15:43:18.771 - debug: roborock.0 (285887) Objects client initialize lua scripts
                              2023-02-04 15:43:18.774 - debug: roborock.0 (285887) Objects connected to redis: 0.0.0.0:9001
                              2023-02-04 15:43:18.788 - debug: roborock.0 (285887) Redis States: Use Redis connection: 0.0.0.0:9000
                              2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create System PubSub Client
                              2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create User PubSub Client
                              2023-02-04 15:43:18.856 - debug: roborock.0 (285887) States connected to redis: 0.0.0.0:9000
                              2023-02-04 15:43:18.936 - info: roborock.0 (285887) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#681304095ec6fa6391041cb23d70c746ec79c93e) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                              2023-02-04 15:43:19.338 - error: roborock.0 (285887) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2023-02-04 15:43:19.339 - error: roborock.0 (285887) unhandled promise rejection: Cannot set properties of undefined (setting 'Authorization')
                              2023-02-04 15:43:19.339 - error: roborock.0 (285887) TypeError: Cannot set properties of undefined (setting 'Authorization')
                              at /opt/iobroker/node_modules/iobroker.roborock/main.js:133:43
                              at async Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:160:15)
                              2023-02-04 15:43:19.339 - error: roborock.0 (285887) Cannot set properties of undefined (setting 'Authorization')
                              2023-02-04 15:43:19.340 - info: roborock.0 (285887) terminating
                              2023-02-04 15:43:19.341 - warn: roborock.0 (285887) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2023-02-04 15:43:19.881 - error: host.pIOBroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2023-02-04 15:43:19.881 - info: host.pIOBroker Restart adapter system.adapter.roborock.0 because enabled
                              2023-02-04 15:43:19.881 - warn: host.pIOBroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                              • H Hunter 0
                                copystringC Offline
                                copystringC Offline
                                copystring
                                #247
                                @hunter-0 Bitte hier mit einklinken: https://github.com/copystring/ioBroker.roborock/issues/57
                                  Kartensupport ist da.
                                  Die Karte wird als base64 bereitgestellt und kann z.B. über lovelace so verwendet werden:
                                  type: markdown
                                  content: <img src="{roborock.0.Devices.3UGDpwnSbiyhmcbVPLDRJV.map.mapBase64}" />
                                  title: Roborock Map
                                  Die Karte wird jede Sekunde aktualisiert... ich hoffe, dass die Roborockserver da nicht blöd machen. Ist aber bei der App ähnlich oft. Mal schauen was passiert :)
                                  O Offline
                                  O Offline
                                  oxident
                                  #248
                                  Ich hab mal eine blöde Frage zur Kartendarstellung.
                                  Derzeit habe ich sie als einfaches Image-Element im Vis dargestellt. Quelle ist der Datenpunkt der Map.
                                  Das klappt auch super, aber die Skalierung ist natürlich Käse. Da ich versuche, es responsive zu gestalten, dachte ich, ein simples Setzen der Breite auf "calc (100% - 50px)" würde funktionieren. Die Karte bleibt aber viel zu breit.
                                  Die "Strecken"-Eigenschaft vom Image-Widget bringt es zwar auf die richtige Breite, aber natürlich nicht proportional.
                                  Habt ihr einen Tipp für mich?
                                  • J Offline
                                    joerg0085
                                    #249
                                    Hallo zusammen, ich hatte den Adapter letzte Woche "eigentlich" schon am laufen.
                                    Nach dem letzten Update auf die aktuelle GIT Version wird er nur einmal kurz Grün, in der Roborock app bekomme mich auch eine Push Notification dass jemand anderes sich eingeloggt hat.
                                    Ohne Zugangsdaten bleibt der Adapter auch Grün
                                    Könnt ihr was mit der Log Meldung anfangen?
                                    JS NPM ..alles aktuell
                                    • H Offline
                                      Hunter 0
                                      #250
                                      Das wird gerade gefixt. Siehe
                                      https://github.com/copystring/ioBroker.roborock/tree/catch_errors_on_initialization
                                      • H Hunter 0
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #251
                                        @hunter-0 genau. Das sollte dort eigentlich behoben sein. Ich hätte gerne noch mindestens einen zusätzlichen Tester.
                                        • copystringC Offline
                                          copystringC Offline
                                          copystring
                                          #252
                                          Ich bin nicht so kreativ. Vielleicht mag jemand mithelfen eine gute Beschreibung (auf Englisch) für den Adapter zu erstellen.
                                          Aktuell steht dort nur: Describe your project here
