  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.7k
766 Beiträge 51 Kommentatoren 323.4k Aufrufe 52 Beobachtet
  • D DonToben
    @hunter-0 said in Roborock Adapter tester gesucht:
    @dontoben
    Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
    Gleiches Problem mit Node v16.19.0
    Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
    $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
    install copystring/ioBroker.roborock
    NPM version: 6.14.5
    Installing copystring/ioBroker.roborock... (System call)
    > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
    (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
    CXX(target) Release/obj.target/canvas/src/Backends.o
    CXX(target) Release/obj.target/canvas/src/Canvas.o
    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
    CXX(target) Release/obj.target/canvas/src/closure.o
    CXX(target) Release/obj.target/canvas/src/color.o
    CXX(target) Release/obj.target/canvas/src/Image.o
    CXX(target) Release/obj.target/canvas/src/ImageData.o
    CXX(target) Release/obj.target/canvas/src/init.o
    CXX(target) Release/obj.target/canvas/src/register_font.o
    SOLINK_MODULE(target) Release/obj.target/canvas.node
    COPY Release/canvas.node
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
    48 packages are looking for funding run `npm fund` for details
    upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
    Process exited with code 0
    copystringC Offline
    copystringC Offline
    copystring
    schrieb am zuletzt editiert von copystring
    #228
    @dontoben said in Roborock Adapter tester gesucht:
    @dontoben
    NPM version: 6.14.5
    Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
    Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
    Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • wendy2702W Offline
      wendy2702W Offline
      #229
      @DonToben
      mal versucht Canvas zu installieren:
      cd /opt/iobroker/
      npm install canvas
      • copystringC Offline
        copystringC Offline
        copystring
        #230
        Vergiss was ich gesagt habe. canvas wurde anschließend erfolgreich kompiliert.
        Der eigentliche Fehler ist bei:
          wendy2702W Offline
          #231
          @copystring sagte in Roborock Adapter tester gesucht:
          buffer@>=6.0.3
          Da habe ich ja Glueck gehabt das es die bei mir gibt:
           npm ls buffer
          [sudo] password for mi:
          iobroker.inst@2.0.3 /opt/iobroker
          +-- iobroker.modbus@5.0.11
          | `-- crc@4.1.1
          |   `-- buffer@6.0.3
          +-- iobroker.mqtt@4.0.7
          | `-- mqtt-connection@4.1.0
          |   `-- mqtt-packet@6.10.0
          |     `-- bl@4.1.0
          |       `-- buffer@5.7.1
          +-- iobroker.sayit@1.12.6
          | `-- aws-sdk@2.1071.0
          |   `-- buffer@4.9.2
          `-- iobroker.shelly@6.3.1
            `-- shelly-iot@1.1.2
              `-- coap@0.26.0
                `-- bl@5.1.0
                  `-- buffer@6.0.3 deduped
          • copystringC copystring
            @dontoben
            NPM version: 6.14.5
            DonToben
            schrieb am zuletzt editiert von DonToben
            #232
            @copystring said in Roborock Adapter tester gesucht:
            @dontoben
            NPM version: 6.14.5
            @copystring
            Ja das ist issue 40.
            Ich mache dann heute mit deinen Anweisungen aus issue 40 weiter. Oder soll ich noch etwas anderes installieren?
            copystringC 1 Antwort Letzte Antwort
            • D DonToben
              @dontoben
              NPM version: 6.14.5
              @copystring
              copystringC Offline
              copystringC Offline
              copystring
              #233
              @dontoben Siehe github.
              • H Offline
                Hunter 0
                #234
                Da es noch keine neue Version ist, weiß ich nicht ob es ein Issue für Github ist. Main Branch stand jetzt:
                • H Hunter 0
                  wendy2702W Offline
                  wendy2702W Offline
                  #235
                  @hunter-0 Bitte vollständiges Log als text in Code Tags </> posten.
                  Und vielleicht noch mitteilen was für ein System das ist.
                    wendy2702W Offline
                    #236
                    aktualisieren sich bei euch die Objekte noch?
                    Unser Sauger ist eben gefahren und ich kann keine Änderung in den Objekten feststellen.
                    Batterie z.B.
                    Nach knapp 45 minuten Arbeit unverändert.
                    Bisschen was RAM belegt er auch:
                    Und im Log passiert zum Adapter nichts mehr.
                    Erst nach restart kommen die neuen Werte aber beim RAM hochzählen kann ich zugucken:
                    Restart log ohne Debug:
                    mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep roborock
                    2023-02-02 15:50:38.847  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                    2023-02-02 15:50:38.851  - info: roborock.0 (77838) Got terminate signal TERMINATE_YOURSELF
                    2023-02-02 15:50:38.853  - info: roborock.0 (77838) terminating
                    2023-02-02 15:50:38.854  - info: roborock.0 (77838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-02-02 15:50:39.007  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                    2023-02-02 15:50:40.012  - info: host.iobroker stopInstance system.adapter.roborock.0 killing pid 77838
                    2023-02-02 15:50:40.323  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-02-02 15:50:42.148  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89295
                    2023-02-02 15:50:43.974  - info: roborock.0 (89295) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                    2023-02-02 15:50:44.177  - info: roborock.0 (89295) MQTT initialized
                    2023-02-02 15:51:23.345  - info: host.iobroker "system.adapter.roborock.0" disabled
                    2023-02-02 15:51:23.346  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                    2023-02-02 15:51:23.360  - info: roborock.0 (89295) Got terminate signal TERMINATE_YOURSELF
                    2023-02-02 15:51:23.364  - info: roborock.0 (89295) terminating
                    2023-02-02 15:51:23.365  - info: roborock.0 (89295) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-02-02 15:51:23.392  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                    2023-02-02 15:51:23.954  - warn: roborock.0 (89295) get state error: Connection is closed.
                    2023-02-02 15:51:23.956  - error: roborock.0 (89295) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-02-02 15:51:23.956  - error: roborock.0 (89295) unhandled promise rejection: DB closed
                    2023-02-02 15:51:23.956  - error: roborock.0 (89295) Error: DB closed
                    2023-02-02 15:51:23.956  - error: roborock.0 (89295) DB closed
                    2023-02-02 15:51:24.059  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-02-02 15:52:43.193  - info: host.iobroker "system.adapter.roborock.0" enabled
                    2023-02-02 15:52:43.422  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89332
                    2023-02-02 15:52:44.603  - info: roborock.0 (89332) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                    2023-02-02 15:52:44.827  - info: roborock.0 (89332) MQTT initialized
                    2023-02-02 15:54:25.755  - info: host.iobroker "system.adapter.roborock.0" disabled
                    2023-02-02 15:54:25.756  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                    2023-02-02 15:54:25.769  - info: roborock.0 (89332) Got terminate signal TERMINATE_YOURSELF
                    2023-02-02 15:54:25.772  - info: roborock.0 (89332) terminating
                    2023-02-02 15:54:25.772  - info: roborock.0 (89332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-02-02 15:54:25.800  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                    2023-02-02 15:54:26.440  - warn: roborock.0 (89332) get state error: Connection is closed.
                    2023-02-02 15:54:26.441  - error: roborock.0 (89332) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-02-02 15:54:26.441  - error: roborock.0 (89332) unhandled promise rejection: DB closed
                    2023-02-02 15:54:26.442  - error: roborock.0 (89332) Error: DB closed
                    2023-02-02 15:54:26.442  - error: roborock.0 (89332) DB closed
                    2023-02-02 15:54:26.533  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    @copystring : soll ich ein Issue aufmachen?
                    Desweiteren, kann man es vielleicht so machen das die Karte nur aktualisiert wird wenn das Kerlchen fährt?
                    • wendy2702W wendy2702
                      Batterie z.B.
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #237
                      @wendy2702 Ja bitte ein Issue öffnen. Es scheint so zu sein, dass viel RAM belegt wird wenn unbekannte Befehle oder Statusnachrichten vorliegen. Siehe https://github.com/copystring/ioBroker.roborock/issues/34 und https://github.com/copystring/ioBroker.roborock/issues/49
                      Für solche Probleme brauche ich Tester da ich den passenden Saugroboter nicht habe. Hier z.B. den Roborock S7 MaxV (Ultra). Für den Roboter kann https://github.com/copystring/ioBroker.roborock/compare/update_robot_attributes getestet werden.
                        wendy2702W Offline
                        wendy2702W Offline
                        #238
                        Ich habe mich an das Issue dran gehangen, oder wolltest du zwingend ein neues?
                        Für das Map Update neues Issue:
                        https://github.com/copystring/ioBroker.roborock/issues/50
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #239
                          @wendy2702 Ist schon ok so.
                          M-A HuebM 1 Antwort Letzte Antwort
                            M-A HuebM Offline
                            M-A HuebM Offline
                            M-A Hueb
                            schrieb am zuletzt editiert von M-A Hueb
                            #240
                            Hab mir jetzt mal Seq installiert, dann kann man besser das Log ziehen.
                            Seq
                            Gibts auch nen Adapter dazu
                            iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                            • M-A HuebM M-A Hueb
                              Seq
                              simplyclever
                              #241
                              @m-a-hueb Die Funktion suche ich auch. Aktuell lade ich den Log runter und (Linux/Mac) führe dann dieses Kommando in einer Shell aus:
                              grep ": roborock" log.txt | sed 's/Name1/Kind1/' | sed 's/Name2/Kind2/' > robolog.txt
                              Das grep filtert die roborock Eintröge aus dem Log, die beiden sed ersetzen die realen Namen meiner Kinder (die Räume sind so benannt) durch KindX..
                              • S simplyclever
                                M-A HuebM Offline
                                M-A HuebM Offline
                                M-A Hueb
                                #242
                                @simplyclever Danke aber bin unter Windows unterwegs. Mit dem Seq Tool ist das recht easy jetzt
                                  wendy2702W Offline
                                  #243
                                  Log in Notepad++ geht auch
                                    M-A HuebM Offline
                                    M-A HuebM Offline
                                    M-A Hueb
                                    #244
                                    @wendy2702 Wie meinst du?
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      #245
                                      @m-a-hueb Das Log kann man auch in Notepad++ öffnen und einfach nach Roborock filtern. bzw. suchen.
                                      Dann erhält man auch eine Ausgabe in der nur die Daten vom Roborock Adapter stehen.
                                      Könnte dann z.B. so aus sehen mit FTP Plugin rechts auf iobroker und dort direkt das log anklicken. Dann mit STRG+F im Beispiel nach allen "ical.2" einträgen in der offenen Datei gesucht. Ergebnis dann unten.
                                      • H Offline
                                        Hunter 0
                                        #246
                                        Das ist der aktuelle Main Branch, soll ich ein Issue auf machen?
                                        2023-02-04 15:43:18.241 - info: host.pIOBroker "system.adapter.roborock.0" enabled
                                        2023-02-04 15:43:18.283 - info: host.pIOBroker instance system.adapter.roborock.0 started with pid 285887
                                        2023-02-04 15:43:18.728 - debug: roborock.0 (285887) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                        2023-02-04 15:43:18.745 - debug: roborock.0 (285887) Objects client ready ... initialize now
                                        2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create System PubSub Client
                                        2023-02-04 15:43:18.746 - debug: roborock.0 (285887) Objects create User PubSub Client
                                        2023-02-04 15:43:18.771 - debug: roborock.0 (285887) Objects client initialize lua scripts
                                        2023-02-04 15:43:18.774 - debug: roborock.0 (285887) Objects connected to redis: 0.0.0.0:9001
                                        2023-02-04 15:43:18.788 - debug: roborock.0 (285887) Redis States: Use Redis connection: 0.0.0.0:9000
                                        2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create System PubSub Client
                                        2023-02-04 15:43:18.797 - debug: roborock.0 (285887) States create User PubSub Client
                                        2023-02-04 15:43:18.856 - debug: roborock.0 (285887) States connected to redis: 0.0.0.0:9000
                                        2023-02-04 15:43:18.936 - info: roborock.0 (285887) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#681304095ec6fa6391041cb23d70c746ec79c93e) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                        2023-02-04 15:43:19.338 - error: roborock.0 (285887) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2023-02-04 15:43:19.339 - error: roborock.0 (285887) unhandled promise rejection: Cannot set properties of undefined (setting 'Authorization')
                                        2023-02-04 15:43:19.339 - error: roborock.0 (285887) TypeError: Cannot set properties of undefined (setting 'Authorization')
                                        at /opt/iobroker/node_modules/iobroker.roborock/main.js:133:43
                                        at async Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:160:15)
                                        2023-02-04 15:43:19.339 - error: roborock.0 (285887) Cannot set properties of undefined (setting 'Authorization')
                                        2023-02-04 15:43:19.340 - info: roborock.0 (285887) terminating
                                        2023-02-04 15:43:19.341 - warn: roborock.0 (285887) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2023-02-04 15:43:19.881 - error: host.pIOBroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2023-02-04 15:43:19.881 - info: host.pIOBroker Restart adapter system.adapter.roborock.0 because enabled
                                        2023-02-04 15:43:19.881 - warn: host.pIOBroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                                        • H Hunter 0
                                          copystringC Offline
                                          copystringC Offline
                                          copystring
                                          #247
                                          @hunter-0 Bitte hier mit einklinken: https://github.com/copystring/ioBroker.roborock/issues/57
