  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.7k
766 Beiträge 51 Kommentatoren 323.3k Aufrufe 52 Beobachtet
  • D DonToben
    @wendy2702
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v16.19.0
    v16.19.0
    8.19.3
    8.19.3
    4.0.24
    pi
    pi adm tty dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    tty
    /home/pi
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:3 https://deb.nodesource.com/node_16.x buster InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           16.19.0-deb-1nodesource1
      Installationskandidat: 16.19.0-deb-1nodesource1
      Versionstabelle:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    pi@raspberrypi:~ $
    Hier der Log vom Adapter:
    2023-01-30 20:21:55.849 - info: host.raspberrypi "system.adapter.roborock.0" enabled
    2023-01-30 20:21:56.290 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5746
    2023-01-30 20:21:59.848 - debug: roborock.0 (5746) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-30 20:21:59.916 - debug: roborock.0 (5746) Objects client ready ... initialize now
    2023-01-30 20:21:59.919 - debug: roborock.0 (5746) Objects create System PubSub Client
    2023-01-30 20:21:59.923 - debug: roborock.0 (5746) Objects create User PubSub Client
    2023-01-30 20:21:59.992 - debug: roborock.0 (5746) Objects client initialize lua scripts
    2023-01-30 20:22:00.013 - debug: roborock.0 (5746) Objects connected to redis: 127.0.0.1:9001
    2023-01-30 20:22:00.055 - debug: roborock.0 (5746) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-30 20:22:00.095 - debug: roborock.0 (5746) States create System PubSub Client
    2023-01-30 20:22:00.097 - debug: roborock.0 (5746) States create User PubSub Client
    2023-01-30 20:22:00.144 - debug: roborock.0 (5746) States connected to redis: 127.0.0.1:9000
    2023-01-30 20:22:00.538 - info: roborock.0 (5746) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-01-30 20:22:00.908 - debug: roborock.0 (5746) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
    2023-01-30 20:22:01.049 - info: roborock.0 (5746) MQTT initialized
    2023-01-30 20:22:01.059 - debug: roborock.0 (5746) Products: object
    2023-01-30 20:22:01.060 - debug: roborock.0 (5746) Products: object
    2023-01-30 20:22:01.063 - debug: roborock.0 (5746) Robot key: roborock.vacuum.a62
    2023-01-30 20:22:02.000 - debug: roborock.0 (5746) Latest data requested
    2023-01-30 20:22:02.003 - debug: roborock.0 (5746) getParameter: get_status
    2023-01-30 20:22:02.009 - debug: roborock.0 (5746) getParameter: get_water_box_custom_mode
    2023-01-30 20:22:02.012 - debug: roborock.0 (5746) getParameter: get_consumable
    2023-01-30 20:22:02.015 - debug: roborock.0 (5746) getParameter: get_network_info
    2023-01-30 20:22:02.018 - debug: roborock.0 (5746) getParameter: get_carpet_mode
    2023-01-30 20:22:02.020 - debug: roborock.0 (5746) getParameter: get_carpet_clean_mode
    2023-01-30 20:22:02.021 - debug: roborock.0 (5746) getParameter: get_fw_features
    2023-01-30 20:22:02.023 - debug: roborock.0 (5746) Firmware features request
    2023-01-30 20:22:02.025 - debug: roborock.0 (5746) getParameter: get_multi_maps_list
    2023-01-30 20:22:02.027 - debug: roborock.0 (5746) getParameter: get_room_mapping
    2023-01-30 20:22:02.028 - debug: roborock.0 (5746) get_room_mapping
    2023-01-30 20:22:02.149 - debug: roborock.0 (5746) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    2023-01-30 20:22:02.151 - debug: roborock.0 (5746) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
    2023-01-30 20:22:02.160 - debug: roborock.0 (5746) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
    2023-01-30 20:22:02.178 - debug: roborock.0 (5746) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    2023-01-30 20:22:02.179 - debug: roborock.0 (5746) get_status: {"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    2023-01-30 20:22:02.184 - debug: roborock.0 (5746) dps debug: {"id":2,"result":{"water_box_mode":203}}
    2023-01-30 20:22:02.234 - debug: roborock.0 (5746) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-61}}
    2023-01-30 20:22:02.239 - debug: roborock.0 (5746) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
    2023-01-30 20:22:02.243 - debug: roborock.0 (5746) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
    2023-01-30 20:22:02.246 - debug: roborock.0 (5746) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
    2023-01-30 20:22:02.247 - debug: roborock.0 (5746) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
    2023-01-30 20:22:02.249 - debug: roborock.0 (5746) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.253 - debug: roborock.0 (5746) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
    2023-01-30 20:22:02.256 - debug: roborock.0 (5746) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.258 - debug: roborock.0 (5746) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.261 - debug: roborock.0 (5746) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
    2023-01-30 20:22:02.264 - debug: roborock.0 (5746) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.267 - debug: roborock.0 (5746) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.269 - debug: roborock.0 (5746) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.272 - debug: roborock.0 (5746) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.274 - debug: roborock.0 (5746) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.277 - debug: roborock.0 (5746) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.278 - debug: roborock.0 (5746) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:02.281 - debug: roborock.0 (5746) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.284 - debug: roborock.0 (5746) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:02.286 - debug: roborock.0 (5746) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.289 - debug: roborock.0 (5746) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
    2023-01-30 20:22:02.364 - debug: roborock.0 (5746) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.366 - debug: roborock.0 (5746) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:02.372 - debug: roborock.0 (5746) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:02.376 - debug: roborock.0 (5746) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:02.378 - debug: roborock.0 (5746) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
    2023-01-30 20:22:02.441 - debug: roborock.0 (5746) dps debug: {"id":11,"result":["ok"]}
    2023-01-30 20:22:03.208 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
    2023-01-30 20:22:03.209 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
    2023-01-30 20:22:03.209 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-01-30 20:22:33.345 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5773
    2023-01-30 20:22:36.103 - debug: roborock.0 (5773) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-30 20:22:36.253 - debug: roborock.0 (5773) Objects client ready ... initialize now
    2023-01-30 20:22:36.257 - debug: roborock.0 (5773) Objects create System PubSub Client
    2023-01-30 20:22:36.259 - debug: roborock.0 (5773) Objects create User PubSub Client
    2023-01-30 20:22:36.338 - debug: roborock.0 (5773) Objects client initialize lua scripts
    2023-01-30 20:22:36.347 - debug: roborock.0 (5773) Objects connected to redis: 127.0.0.1:9001
    2023-01-30 20:22:36.386 - debug: roborock.0 (5773) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-30 20:22:36.413 - debug: roborock.0 (5773) States create System PubSub Client
    2023-01-30 20:22:36.415 - debug: roborock.0 (5773) States create User PubSub Client
    2023-01-30 20:22:36.458 - debug: roborock.0 (5773) States connected to redis: 127.0.0.1:9000
    2023-01-30 20:22:36.753 - info: roborock.0 (5773) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-01-30 20:22:37.022 - debug: roborock.0 (5773) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
    2023-01-30 20:22:37.101 - info: roborock.0 (5773) MQTT initialized
    2023-01-30 20:22:37.109 - debug: roborock.0 (5773) Products: object
    2023-01-30 20:22:37.110 - debug: roborock.0 (5773) Products: object
    2023-01-30 20:22:37.111 - debug: roborock.0 (5773) Robot key: roborock.vacuum.a62
    2023-01-30 20:22:37.938 - debug: roborock.0 (5773) Latest data requested
    2023-01-30 20:22:37.940 - debug: roborock.0 (5773) getParameter: get_status
    2023-01-30 20:22:37.946 - debug: roborock.0 (5773) getParameter: get_water_box_custom_mode
    2023-01-30 20:22:37.948 - debug: roborock.0 (5773) getParameter: get_consumable
    2023-01-30 20:22:37.950 - debug: roborock.0 (5773) getParameter: get_network_info
    2023-01-30 20:22:37.953 - debug: roborock.0 (5773) getParameter: get_carpet_mode
    2023-01-30 20:22:37.955 - debug: roborock.0 (5773) getParameter: get_carpet_clean_mode
    2023-01-30 20:22:37.957 - debug: roborock.0 (5773) getParameter: get_fw_features
    2023-01-30 20:22:37.957 - debug: roborock.0 (5773) Firmware features request
    2023-01-30 20:22:37.959 - debug: roborock.0 (5773) getParameter: get_multi_maps_list
    2023-01-30 20:22:37.961 - debug: roborock.0 (5773) getParameter: get_room_mapping
    2023-01-30 20:22:37.962 - debug: roborock.0 (5773) get_room_mapping
    2023-01-30 20:22:38.133 - debug: roborock.0 (5773) dps debug: {"id":2,"result":{"water_box_mode":203}}
    2023-01-30 20:22:38.140 - debug: roborock.0 (5773) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
    2023-01-30 20:22:38.141 - debug: roborock.0 (5773) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
    2023-01-30 20:22:38.143 - debug: roborock.0 (5773) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-62}}
    2023-01-30 20:22:38.147 - debug: roborock.0 (5773) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
    2023-01-30 20:22:38.148 - debug: roborock.0 (5773) get_status: {"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
    2023-01-30 20:22:38.153 - debug: roborock.0 (5773) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
    2023-01-30 20:22:38.156 - debug: roborock.0 (5773) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
    2023-01-30 20:22:38.173 - debug: roborock.0 (5773) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
    2023-01-30 20:22:38.176 - debug: roborock.0 (5773) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
    2023-01-30 20:22:38.193 - debug: roborock.0 (5773) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    2023-01-30 20:22:38.196 - debug: roborock.0 (5773) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
    2023-01-30 20:22:38.243 - debug: roborock.0 (5773) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.251 - debug: roborock.0 (5773) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.255 - debug: roborock.0 (5773) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.264 - debug: roborock.0 (5773) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.272 - debug: roborock.0 (5773) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:38.274 - debug: roborock.0 (5773) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.277 - debug: roborock.0 (5773) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.282 - debug: roborock.0 (5773) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.285 - debug: roborock.0 (5773) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:38.291 - debug: roborock.0 (5773) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
    2023-01-30 20:22:38.293 - debug: roborock.0 (5773) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.297 - debug: roborock.0 (5773) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.303 - debug: roborock.0 (5773) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
    2023-01-30 20:22:38.304 - debug: roborock.0 (5773) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.310 - debug: roborock.0 (5773) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
    2023-01-30 20:22:38.312 - debug: roborock.0 (5773) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.345 - debug: roborock.0 (5773) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.369 - debug: roborock.0 (5773) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
    2023-01-30 20:22:38.423 - debug: roborock.0 (5773) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
    2023-01-30 20:22:38.425 - debug: roborock.0 (5773) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
    2023-01-30 20:22:38.428 - debug: roborock.0 (5773) dps debug: {"id":11,"result":["ok"]}
    2023-01-30 20:22:40.311 - debug: roborock.0 (5773) dps debug: {"id":32,"result":["ok"]}
    2023-01-30 20:22:41.122 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
    2023-01-30 20:22:41.122 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
    2023-01-30 20:22:41.123 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    wendy2702W Offline
    wendy2702W Offline
    #222
    @dontoben sagte in Roborock Adapter tester gesucht:
    SIGSEGV
    Was ist das fuer ein PI?
    Was sagt:
    free -ht
    sudo apt update
    Als erste Hilfe kannst du mal Instanz und Adapter komplett loeschen. Server neu starten und dann neu installieren.
    • wendy2702W wendy2702
      SIGSEGV
      Was sagt:
      free -ht
      sudo apt update
      DonToben
      schrieb am zuletzt editiert von DonToben
      #223
      @wendy2702
      pi@raspberrypi:~ $ free -ht
                    total        used        free      shared  buff/cache
         available
      Mem:          3,7Gi       606Mi        79Mi       200Mi       3,1Gi
             2,8Gi
      Swap:          99Mi        13Mi        86Mi
      Total:        3,8Gi       619Mi       166Mi
      pi@raspberrypi:~ $ sudo apt update
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 https://deb.nodesource.com/node_16.x buster InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      pi@raspberrypi:~ $
      Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM, WLAN-ac, Bluetooth 5, LAN, 4 x USB, 2 x Micro-HD
      0.0.5 funktionierte noch einwandfrei.
      Deinstallation, Server Neustart und Neuinstallation brachte keine Abhilfe
      • D DonToben
        @wendy2702
           available
               2,8Gi
        pi@raspberrypi:~ $
        wendy2702W Offline
        wendy2702W Offline
        #224
        @dontoben OK. Buster solltest du mal bei Gelegenheit updaten. Bzw. besser was aktuelles neu installieren. Moeglich das es da haengt. Kommt halt drauf an was @copystring alles in seinem Adapter verwendet.
        Sonst wuerde ich einmal wie geschrieben vorgehen.
        EDIT: Hat sich mit deinem Edit ueberschnitten. Immer noch SIGSEGV als error?
          DonToben
          #225
          @wendy2702 said in Roborock Adapter tester gesucht:
          Ja, SIGSEGV kommt noch als Fehler.
          Ich warte jetzt mal, was @copystring sagt. Update des Betriebssystems würde ich nur zur Not machen, da ich das mühselige Neueinrichten vermeiden möchte.
          Hoffentlich ist es nur ein Fehler im Adapter.
          • D DonToben
            wendy2702W Offline
            wendy2702W Offline
            #226
            @dontoben Wieso muehselig bei einem PI?
            Kannst das Betriebssystem auch updaten:
            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye?page=1
            Vorher natuerlich ein Backup machen.
            • copystringC Offline
              copystringC Offline
              copystring
              #227
              SIGSEGV steht für Segmentation fault. Ein Programm stürzt also ab. Dass das von meinen Adapter direkt kommt ist eher unwahrscheinlich. Es wird wohl eher daher kommen, dass entweder eine Bibliothek (vielleicht canvas von npm) abstürzt oder ein RPi nicht damit klar kommt, dass die Karte jede Sekunde neu erstellt wird. Beim meinen Server lief das auch nicht richtig aber es kam nie ein Absturz. Daher hatte ich das bereits auf 2 Sekunden reduziert.
              Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
              https://paypal.me/copystring
              • D DonToben
                @hunter-0 said in Roborock Adapter tester gesucht:
                @dontoben
                Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
                Gleiches Problem mit Node v16.19.0
                Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
                $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
                install copystring/ioBroker.roborock
                NPM version: 6.14.5
                Installing copystring/ioBroker.roborock... (System call)
                > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
                node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
                node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
                (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                (Use `node --trace-deprecation ...` to show where the warning was created)
                make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
                CXX(target) Release/obj.target/canvas/src/Backends.o
                CXX(target) Release/obj.target/canvas/src/Canvas.o
                CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
                CXX(target) Release/obj.target/canvas/src/closure.o
                CXX(target) Release/obj.target/canvas/src/color.o
                CXX(target) Release/obj.target/canvas/src/Image.o
                CXX(target) Release/obj.target/canvas/src/ImageData.o
                CXX(target) Release/obj.target/canvas/src/init.o
                CXX(target) Release/obj.target/canvas/src/register_font.o
                SOLINK_MODULE(target) Release/obj.target/canvas.node
                COPY Release/canvas.node
                make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
                48 packages are looking for funding run `npm fund` for details
                upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
                Process exited with code 0
                copystringC Offline
                copystringC Offline
                copystring
                schrieb am zuletzt editiert von copystring
                #228
                @dontoben said in Roborock Adapter tester gesucht:
                @dontoben
                NPM version: 6.14.5
                Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
                Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
                Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
                • wendy2702W Offline
                  wendy2702W Offline
                  #229
                  @DonToben
                  mal versucht Canvas zu installieren:
                  cd /opt/iobroker/
                  npm install canvas
                    copystringC Offline
                    copystring
                    #230
                    Vergiss was ich gesagt habe. canvas wurde anschließend erfolgreich kompiliert.
                    Der eigentliche Fehler ist bei:
                      wendy2702W Offline
                      #231
                      @copystring sagte in Roborock Adapter tester gesucht:
                      buffer@>=6.0.3
                      Da habe ich ja Glueck gehabt das es die bei mir gibt:
                       npm ls buffer
                      [sudo] password for mi:
                      iobroker.inst@2.0.3 /opt/iobroker
                      +-- iobroker.modbus@5.0.11
                      | `-- crc@4.1.1
                      |   `-- buffer@6.0.3
                      +-- iobroker.mqtt@4.0.7
                      | `-- mqtt-connection@4.1.0
                      |   `-- mqtt-packet@6.10.0
                      |     `-- bl@4.1.0
                      |       `-- buffer@5.7.1
                      +-- iobroker.sayit@1.12.6
                      | `-- aws-sdk@2.1071.0
                      |   `-- buffer@4.9.2
                      `-- iobroker.shelly@6.3.1
                        `-- shelly-iot@1.1.2
                          `-- coap@0.26.0
                            `-- bl@5.1.0
                              `-- buffer@6.0.3 deduped
                      • copystringC copystring
                        @dontoben
                        NPM version: 6.14.5
                        DonToben
                        #232
                        @copystring said in Roborock Adapter tester gesucht:
                        @dontoben
                        NPM version: 6.14.5
                        @copystring
                        Ja das ist issue 40.
                        Ich mache dann heute mit deinen Anweisungen aus issue 40 weiter. Oder soll ich noch etwas anderes installieren?
                        copystringC 1 Antwort Letzte Antwort
                        • D DonToben
                          @dontoben
                          NPM version: 6.14.5
                          @copystring
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #233
                          @dontoben Siehe github.
                          • H Offline
                            Hunter 0
                            #234
                            Da es noch keine neue Version ist, weiß ich nicht ob es ein Issue für Github ist. Main Branch stand jetzt:
                            • H Hunter 0
                              wendy2702W Offline
                              wendy2702W Offline
                              #235
                              @hunter-0 Bitte vollständiges Log als text in Code Tags </> posten.
                              Und vielleicht noch mitteilen was für ein System das ist.
                                wendy2702W Offline
                                #236
                                aktualisieren sich bei euch die Objekte noch?
                                Unser Sauger ist eben gefahren und ich kann keine Änderung in den Objekten feststellen.
                                Batterie z.B.
                                Nach knapp 45 minuten Arbeit unverändert.
                                Bisschen was RAM belegt er auch:
                                Und im Log passiert zum Adapter nichts mehr.
                                Erst nach restart kommen die neuen Werte aber beim RAM hochzählen kann ich zugucken:
                                Restart log ohne Debug:
                                mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep roborock
                                2023-02-02 15:50:38.847  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                2023-02-02 15:50:38.851  - info: roborock.0 (77838) Got terminate signal TERMINATE_YOURSELF
                                2023-02-02 15:50:38.853  - info: roborock.0 (77838) terminating
                                2023-02-02 15:50:38.854  - info: roborock.0 (77838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-02-02 15:50:39.007  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                2023-02-02 15:50:40.012  - info: host.iobroker stopInstance system.adapter.roborock.0 killing pid 77838
                                2023-02-02 15:50:40.323  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-02-02 15:50:42.148  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89295
                                2023-02-02 15:50:43.974  - info: roborock.0 (89295) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                2023-02-02 15:50:44.177  - info: roborock.0 (89295) MQTT initialized
                                2023-02-02 15:51:23.345  - info: host.iobroker "system.adapter.roborock.0" disabled
                                2023-02-02 15:51:23.346  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                2023-02-02 15:51:23.360  - info: roborock.0 (89295) Got terminate signal TERMINATE_YOURSELF
                                2023-02-02 15:51:23.364  - info: roborock.0 (89295) terminating
                                2023-02-02 15:51:23.365  - info: roborock.0 (89295) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-02-02 15:51:23.392  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                2023-02-02 15:51:23.954  - warn: roborock.0 (89295) get state error: Connection is closed.
                                2023-02-02 15:51:23.956  - error: roborock.0 (89295) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-02-02 15:51:23.956  - error: roborock.0 (89295) unhandled promise rejection: DB closed
                                2023-02-02 15:51:23.956  - error: roborock.0 (89295) Error: DB closed
                                2023-02-02 15:51:23.956  - error: roborock.0 (89295) DB closed
                                2023-02-02 15:51:24.059  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-02-02 15:52:43.193  - info: host.iobroker "system.adapter.roborock.0" enabled
                                2023-02-02 15:52:43.422  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89332
                                2023-02-02 15:52:44.603  - info: roborock.0 (89332) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                2023-02-02 15:52:44.827  - info: roborock.0 (89332) MQTT initialized
                                2023-02-02 15:54:25.755  - info: host.iobroker "system.adapter.roborock.0" disabled
                                2023-02-02 15:54:25.756  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                2023-02-02 15:54:25.769  - info: roborock.0 (89332) Got terminate signal TERMINATE_YOURSELF
                                2023-02-02 15:54:25.772  - info: roborock.0 (89332) terminating
                                2023-02-02 15:54:25.772  - info: roborock.0 (89332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-02-02 15:54:25.800  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                2023-02-02 15:54:26.440  - warn: roborock.0 (89332) get state error: Connection is closed.
                                2023-02-02 15:54:26.441  - error: roborock.0 (89332) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-02-02 15:54:26.441  - error: roborock.0 (89332) unhandled promise rejection: DB closed
                                2023-02-02 15:54:26.442  - error: roborock.0 (89332) Error: DB closed
                                2023-02-02 15:54:26.442  - error: roborock.0 (89332) DB closed
                                2023-02-02 15:54:26.533  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                @copystring : soll ich ein Issue aufmachen?
                                Desweiteren, kann man es vielleicht so machen das die Karte nur aktualisiert wird wenn das Kerlchen fährt?
                                  Batterie z.B.
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #237
                                  @wendy2702 Ja bitte ein Issue öffnen. Es scheint so zu sein, dass viel RAM belegt wird wenn unbekannte Befehle oder Statusnachrichten vorliegen. Siehe https://github.com/copystring/ioBroker.roborock/issues/34 und https://github.com/copystring/ioBroker.roborock/issues/49
                                  Für solche Probleme brauche ich Tester da ich den passenden Saugroboter nicht habe. Hier z.B. den Roborock S7 MaxV (Ultra). Für den Roboter kann https://github.com/copystring/ioBroker.roborock/compare/update_robot_attributes getestet werden.
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #238
                                    Ich habe mich an das Issue dran gehangen, oder wolltest du zwingend ein neues?
                                    Für das Map Update neues Issue:
                                    https://github.com/copystring/ioBroker.roborock/issues/50
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #239
                                      @wendy2702 Ist schon ok so.
                                      M-A HuebM 1 Antwort Letzte Antwort
                                        M-A HuebM Offline
                                        M-A HuebM Offline
                                        M-A Hueb
                                        schrieb am zuletzt editiert von M-A Hueb
                                        #240
                                        Hab mir jetzt mal Seq installiert, dann kann man besser das Log ziehen.
                                        Seq
                                        Gibts auch nen Adapter dazu
                                        iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                                        • M-A HuebM M-A Hueb
                                          Seq
                                          simplyclever
                                          #241
                                          @m-a-hueb Die Funktion suche ich auch. Aktuell lade ich den Log runter und (Linux/Mac) führe dann dieses Kommando in einer Shell aus:
                                          grep ": roborock" log.txt | sed 's/Name1/Kind1/' | sed 's/Name2/Kind2/' > robolog.txt
                                          Das grep filtert die roborock Eintröge aus dem Log, die beiden sed ersetzen die realen Namen meiner Kinder (die Räume sind so benannt) durch KindX..
