lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • W Wuschl
    @armilar Fehler :-)
    script.js.Ns-Panels.Garage-3_9_0: TypeScript compilation failed:var Flur: PageEntities = { ^ERROR: Type '{ type: "cardEntities"; heading: string; useColor: true; subPage: false; parent: undefined; prev: undefined; next: undefined; home: undefined; items: PageItem[]; }' is missing the following properties from type 'PageEntities': parentIcon, parentIconColor, prevIcon, prevIconColor, and 4 more.var Luftfeuchte: PageEntities = { ^ERROR: Type '{ type: "cardEntities"; heading: string; useColor: true; subPage: false; parent: undefined; prev: undefined; next: undefined; home: undefined; items: PageItem[]; }' is missing the following properties from type 'PageEntities': parentIcon, parentIconColor, prevIcon, prevIconColor, and 4 more.var Küche: PageEntities = { ^ERROR: Type '{ type: "cardEntities"; heading: string; useColor: true; subPage: false; parent: undefined; prev: undefined; next: undefined; home: undefined; items: PageItem[]; }' is missing the following properties from type 'PageEntities': parentIcon, parentIconColor, prevIcon, prevIconColor, and 4 more.var Garagen: PageEntities = { ^ERROR: Type '{ type: "cardEntities"; heading: string; useColor: true; subPage: false; parent: undefined; prev: undefined; next: undefined; home: undefined; items: PageItem[]; }' is missing the following properties from type 'PageEntities': parentIcon, parentIconColor, prevIcon, prevIconColor, and 4 more.var WLAN: PageQR = { ^ERROR: Type '{ type: "cardQR"; heading: string; useColor: true; subPage: false; parent: undefined; prev: undefined; next: undefined; home: undefined; items: PageItem[]; }' is missing the following properties from type 'PageQR': parentIcon, parentIconColor, prevIcon, prevIconColor, and 4 more.
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #1901
    @wuschl
    Da bist du aber nicht wie in der Beschreibung vorgegangen, oder?
    https://forum.iobroker.net/post/937928
    Da dürfte nicht mit Flur, etc. drin sein, wenn das Script zum ersten Mal "ohne" deine Seiten startet.
    W 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @wuschl
      W Offline
      W Offline
      Wuschl
      schrieb am zuletzt editiert von Wuschl
      #1902
      @armilar doch, ich habe es gemacht wie in der Beschreibung. Skript ohne Beispiele und reinkopiert. Achso, ohne Seiten!!!
      • W Wuschl
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #1903
        @wuschl
        Achtung: nicht einfach alles reinkopieren. Nur die Seiten und Farbkonstanten. Die Config nicht! Die ist völlig anders als in der 3.8.3
        Das Script sollte bereits so wie es auf Github ist (mit Ausnahme der Zeilen die ich benannt habe) laufen... Dann erst deine Sachen reinkopieren.
        • ArmilarA Armilar
          @wuschl
          W Offline
          W Offline
          Wuschl
          #1904
          @armilar hab die Config nur angepasst so wie beschrieben. Aber meine Seiten habe ich mit rein kopiert. Die hab ich jetzt gelöscht, dann kommen keine Fehler. Kann ich die Seiten nicht mehr kopieren?
          • W Wuschl
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #1905
            @wuschl
            natürlich kannst du das... kopiere eine nach der anderen rein. Dann sage mir bei welcher Seite es Fehler gibt... Am Besten mit der Seite im Post... Ich vermute, dass du nicht von einer v3.8.3 kommst...
            Dann wären deine Seiten noch nicht wie hier:
            let Beispielseite = <PageEntities>
            • ArmilarA Armilar
              @wuschl
              W Offline
              W Offline
              Wuschl
              #1906
              @armilar
              Nein, komme von der 3.8.1
              Die erste Seite bringt schon Fehler
              • W Wuschl
                @armilar
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #1907
                @wuschl
                Poste mal die Seite "Flur". Ich sende sie korrigiert zurück...
                • ArmilarA Armilar
                  @wuschl
                  W Offline
                  W Offline
                  Wuschl
                  #1908
                  @armilar
                      "type": "cardEntities",
                      "heading": "Flur",
                      "useColor": true,
                      "subPage": false,
                      "parent": undefined,
                      'prev': undefined,        //Neu - bitte in jede Seite einfügen
                      'next': undefined,        //Neu - bitte in jede Seite einfügen
                      'home': undefined,        //Neu - bitte in jede Seite einfügen
                      "items": [
                          <PageItem>{ id: "alias.0.NsPanelGarage.Fernsehen", name: "Fernsehen", interpolateColor: true},
                          <PageItem>{ id: "alias.0.NsPanelGarage.Garage-Bernd", offColor: MSGreen, onColor: MSRed, name: "Garagentor", icon: "garage-variant", icon2: "garage-open-variant"},
                          <PageItem>{ id: "alias.0.NsPanelGarage.Radio_ein", name: "Radio", interpolateColor: true},
                          <PageItem>{ id: "alias.0.NsPanelGarage.Deko-Flur", name: "Flur-Deko", minValueBrightness: 0, maxValueBrightness: 100, interpolateColor: true},
                  • W Wuschl
                    @armilar
                        "heading": "Flur",
                        "useColor": true,
                        "subPage": false,
                        "items": [
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #1909
                    @wuschl
                    oben bis 3.8.1
                        "heading": "Flur",
                        "useColor": true,
                        "subPage": false,
                        "items": [
                    jetzt neue Definition ab 3.8.3
                    var Flur = <PageEntities>    // Hier Änderung bitte vergleichen
                        "heading": "Flur",
                        "useColor": true,
                        "subPage": false,
                        "items": [
                    Alles was undefined ist, wird ebenfalls nicht mehr benötigt. Du kannst dich auch an den Service-Pages orientieren...
                    Bitte kurz einfügen und Bescheid geben...
                    • ArmilarA Armilar
                      @wuschl
                      oben bis 3.8.1
                          "heading": "Flur",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                          "heading": "Flur",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                      W Offline
                      W Offline
                      Wuschl
                      #1910
                      @armilar Danke, funktioniert👍
                      • W Wuschl
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #1911
                        @wuschl
                        Perfekt... nach dem Stil alle Seiten überarbeiten:
                        Steht auch in der Wiki:
                        https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Navigation
                        • ArmilarA Armilar
                          TS-Script Release 3.9.0
                          Achtung Breaking Changes
                          FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.9.0.tft
                          Im oberen Konfigurationsbereich sind diverse Änderungen entstanden. Die einfachste Methode für ein Upgrade ist auf ein TS-Script ohne Beispiele aufzusetzten: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs_without_Examples.ts .
                          • Das vorhandene bereits TS-Script sollte deaktiviert werden, dienst als Fallbacklösung und zum kopieren der Migrationsanteile (vorhandene Seitendefinitionen, etc.):
                          • Benutzer- /Panelspezifische Anpassungen vornehmen
                            • Zeile 213: NEU: bevorzugte Tasmota-Version auswählen
                            • Zeile 217: NSPanel- Pfad anpassen
                            • Zeile 618: MQTT-Pfad anpassen
                            • Zeile 619: MQTT-Pfad anpassen
                            • Zeile 658: MQTT-Pfad anpassen
                            • Zeile 666: MQTT-Pfad anpassen
                          • TS-Script aktivieren und starten (Neue Datenpunkte und Aliase werden erstellt)
                          • Wenn keine Fehler vorhanden sein sollten, dann danach die vorhandenen Seiten-Variablen und benutzerspezifische Farbkonstanten aus dem deaktivierten, bisherigen TS-Script nachziehen (migrieren).
                          • Zum Schluss Anpassungen in den neuen Parametern der Screensaver-Entities im Config-Teil vornehmen.
                          Zu einigen Neuerungen ist die Wiki noch nicht komplett beschrieben und wird noch vervollständigt!
                          EDIT: Sollte es Fragen geben, dann einfach fragen 😊
                          madingM Online
                          madingM Online
                          mading
                          #1912
                          @armilar top danke für 3.9.0 läuft auf Anhieb. Bekommst du eigentlich den Obulus wenn ich über Paypal was spende (https://paypal.me/joBr99)?
                          • madingM mading
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #1913
                            @mading
                            wenn ioBroker drin steht, dann ja ;-)
                              tomsport2022
                              schrieb am zuletzt editiert von tomsport2022
                              #1914
                              @Armilar
                              Gibt es irgendwo eine Doku, wie der Aufbau des Info Feldes für die LCharts sein muss, da ich eine andere DB verwende und auch kein Influx installieren möchte?
                              Dann kann ich mir den String selbst zusammenbauen :)
                              Danke im Voraus und sieht wieder sehr vielversprechend aus, die neue Version!
                              ArmilarA 2 Antworten Letzte Antwort
                              • T tomsport2022
                                @Armilar
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #1915
                                @tomsport2022
                                @ravenst0ne hat die Doku noch um den History-Adapter (unter der Influx-Lösung) erweitert. Sollte ähnlich einer SQL-DB vom Query sein. Die Scripte erzeugen die X-Achse und die Koordinaten des Graphen in "einem" String und sind etwas komplexer als bei der cardChart.
                                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardlchart-line-charts-ab-ts-script-v390
                                Ein Beispielstring sieht so aus:
                                0^20:00+60+120+180+240^00:00+300+360+420+480^04:00+540+600+660+720^08:00+780+840+900+960^12:00+1020+1080+1140+1200^16:00+1260+1320+1380~47:218~107:223~167:220~227:222~287:209~347:204~407:201~467:199~527:197~587:195~707:195~767:197~827:200~887:201~947:207~1007:210~1067:213~1127:213~1187:214~1247:211~1307:215~1367:215~1427:213~1440:214
                                Falls jemand eine andere Datenbank bedient, außer InfluxDB 2 oder History, dann gerne posten. Ich nehme es gerne in die Wiki auf.
                                • T tomsport2022
                                  @Armilar
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #1916
                                  @tomsport2022
                                  Ansonsten und falls es einen für Influx2 interessiert: ;-)
                                  Lässt sich in Teilen auch für andere Dinge (Luftfeuchte, etc.) adaptieren, ist schlank und ressourcenschonend.
                                  Es legt die Datenpunkte in 0_userdata automatisch an.
                                  Das wäre mein JS-Script. Es erzeugt bei jeder Temperaturänderung zu jedem Raum einen Temperatur-String für die cartLChart:
                                  const Debug = false;
                                  const NSPanel_Path = '0_userdata.0.NSPanel.';
                                  const Path = NSPanel_Path + 'Influx2NSPanel.cardLChart.';
                                  let   PathSensor = '';
                                  let SensorName = ['EG.Buero.Temperatur',
                                                    'EG.Gaeste_WC.Temperatur',
                                                    'EG.Wohnzimmer.Temperatur',
                                                    'EG.Hauswirtschaftsraum.Temperatur',
                                                    'EG.Flur_vorne.Temperatur',
                                                    'EG.Flur_hinten.Temperatur',
                                                    'EG.Esszimmer.Temperatur',
                                                    'EG.Kaminzimmer.Temperatur',
                                                    'EG.Badezimmer.Temperatur',
                                                    'EG.Kueche.Temperatur',
                                                    'OG.Schlafzimmer_1.Temperatur',
                                                    'OG.Gaestezimmer.Temperatur',
                                                    'OG.Hobbyraum.Temperatur',
                                                    'Gartenhaus.Temperatur'];
                                  const Sensor = [].concat('deconz.0.Sensors.65.temperature')  // EG.Buero.Temperatur
                                                   .concat('deconz.0.Sensors.10.temperature')  // EG.Gaeste_WC.Temperatur
                                                   .concat('deconz.0.Sensors.73.temperature')  // EG.Wohnzimmer.Temperatur
                                                   .concat('deconz.0.Sensors.62.temperature')  // EG.Hauswirtschaftsraum.Temperatur
                                                   .concat('deconz.0.Sensors.7.temperature')   // EG.Flur_vorne.Temperatur
                                                   .concat('deconz.0.Sensors.14.temperature')  // EG.Flur_hinten.Temperatur
                                                   .concat('deconz.0.Sensors.23.temperature')  // EG.Esszimmer.Temperatur
                                                   .concat('deconz.0.Sensors.41.temperature')  // EG.Kaminzimmer.Temperatur
                                                   .concat('deconz.0.Sensors.52.temperature')  // EG.Badezimmer.Temperatur
                                                   .concat('deconz.0.Sensors.17.temperature')  // EG.Kueche.Temperature
                                                   .concat('deconz.0.Sensors.32.temperature')  // OG.Schlafzimmer_1.Temperatur
                                                   .concat('deconz.0.Sensors.45.temperature')  // OG.Gaestezimmer.Temperatur
                                                   .concat('deconz.0.Sensors.48.temperature')  // OG.Hobbyraum.Temperatur
                                                   .concat('deconz.0.Sensors.58.temperature'); // Gartenhaus.Temperatur
                                  let   triggeredSensor = 0;
                                  const numberOfHoursAgo = 24;
                                  const xAxisTicksEveryM = 60;
                                  const xAxisLabelEveryM = 240;
                                  const InfluxInstance = 'influxdb.0';
                                  // Ab hier keine Ändeungen
                                  let coordinates = '';
                                  on({ id: Sensor, change: 'any' }, async function (obj) {
                                      if (Debug) console.log(obj.id);
                                      if (Debug) console.log(Sensor.indexOf(obj.id));
                                      if (Debug) console.log(SensorName[Sensor.indexOf(obj.id)])
                                      PathSensor = Path + SensorName[Sensor.indexOf(obj.id)]
                                      if (existsObject(PathSensor) == false) {
                                          createState(PathSensor, 0, {
                                              desc: 'Sensor Values [~<time>:<value>]*',
                                              type: 'string',
                                              role: 'value',
                                      let query =[
                                          'from(bucket: "iobroker")',
                                          '|> range(start: -' + numberOfHoursAgo + 'h)',
                                          '|> filter(fn: (r) => r["_measurement"] == "' + obj.id + '")',
                                          '|> filter(fn: (r) => r["_field"] == "value")',
                                          '|> drop(columns: ["from", "ack", "q"])',
                                          '|> aggregateWindow(every: 1h, fn: last, createEmpty: false)',
                                          '|> map(fn: (r) => ({ r with _rtime: int(v: r._time) - int(v: r._start)}))',
                                          '|> yield(name: "_result")'].join('');
                                      if (Debug) console.log('Query: ' + query);
                                      sendTo(InfluxInstance, 'query', query, function (result) {
                                          if (result.error) {
                                              console.error(result.error);
                                          } else {
                                              // show result
                                              if (Debug) console.log(result);
                                              let numResults = result.result.length;
                                              for (let r = 0; r < numResults; r++)
                                                  let list = []
                                                  let numValues = result.result[r].length;
                                                  for (let i = 0; i < numValues; i++)
                                                      let time = Math.round(result.result[r][i]._rtime/1000/1000/1000/60);
                                                      let value = Math.round(result.result[r][i]._value * 10);
                                                      list.push(time + ":" + value);
                                                  coordinates = list.join("~");
                                                  if (Debug) console.log(coordinates);
                                      let timeOut = setTimeout (
                                          function () {
                                              let ticksAndLabelsList = []
                                              let date = new Date();
                                              date.setMinutes(0, 0, 0);
                                              let ts = Math.round(date.getTime() / 1000);
                                              let tsYesterday = ts - (numberOfHoursAgo * 3600);
                                              if (Debug) console.log('Iterate from ' + tsYesterday + ' to ' + ts + ' stepsize=' + (xAxisTicksEveryM * 60));
                                              for (let x = tsYesterday, i = 0; x < ts; x += (xAxisTicksEveryM * 60), i += xAxisTicksEveryM)
                                                  if ((i % xAxisLabelEveryM))
                                                      ticksAndLabelsList.push(i);
                                                  else
                                                      let currentDate = new Date(x * 1000);
                                                      // Hours part from the timestamp
                                                      let hours = '0' + String(currentDate.getHours());
                                                      // Minutes part from the timestamp
                                                      let minutes = '0' + String(currentDate.getMinutes());
                                                      let formattedTime = hours.slice(-2) + ':' + minutes.slice(-2);
                                                      ticksAndLabelsList.push(String(i) + '^' + formattedTime);
                                              if (Debug) console.log('Ticks & Label: ' + ticksAndLabelsList);
                                              if (Debug) console.log('Coordinates: ' + coordinates);
                                              setState(PathSensor, ticksAndLabelsList.join('+') + '~' + coordinates, true);
                                      1500
                                  Ich nutze die Influx 2 übrigens - weil der Index, insbesondere bei Timestamps, um einiges schneller als bei einer MySQL/MariaDB/etc. und natürlich sehr viel schneller als ein Filezugriff mit dem History ist!
                                  EDIT: danach noch einen Alias vom Gerätetyp: Info zu jedem der geschriebenen Raum-Strings erzeugen und als cardLChart anlegen:
                                  let CardLChartExample = <PageChart>
                                      'type': 'cardLChart',
                                      'heading': 'Büro Temperatur',
                                      'useColor': true,
                                      'items': [<PageItem>{
                                                  yAxis: 'Temperatur [°C]',
                                                  yAxisTicks: [100,110,120,130,140,150,160,170,180,190,200,210,220,230,240,250],
                                                  onColor: Yellow
                                  Die Y-Achse wird in diesem Beispiel von 10°C-25°C definiert (kann individuell definiert werden)
                                  Ergebnis: 1 Chart pro Raum
                                  Wie man in dem Chart sieht, sucht sich die cardChart den idealen Y-Achsen-Wertebereich automatisch heraus.
                                  EDIT 2: Die Datenpunkte, die das Script erzeugt sehen so aus:
                                  T W 2 Antworten Letzte Antwort
                                  • ArmilarA Armilar
                                    @tomsport2022
                                                type: 'string',
                                                role: 'value',
                                        let query =[
                                            if (result.error) {
                                            } else {
                                                // show result
                                                    let list = []
                                            function () {
                                                    else
                                        1500
                                        'useColor': true,
                                                    onColor: Yellow
                                    tomsport2022
                                    #1917
                                    @armilar
                                    Vielen Dank für die ausführliche Beschreibung!
                                    • ArmilarA Armilar
                                      @tomsport2022
                                                  type: 'string',
                                                  role: 'value',
                                          let query =[
                                              if (result.error) {
                                              } else {
                                                  // show result
                                                      let list = []
                                              function () {
                                                      else
                                          1500
                                          'useColor': true,
                                                      onColor: Yellow
                                      W Offline
                                      W Offline
                                      Winnipuuh
                                      schrieb am zuletzt editiert von Winnipuuh
                                      #1918
                                      @armilar Hallo,
                                      kann es sein das es mit der Influx 1.8 nicht funktioniert?
                                      Ich erhalte folgende Fehlermeldungen:
                                      Ist der Sensor so richtig eingefügt?
                                      const Sensor = [].concat('mqtt.0.openWB.evu.W'); // Gartenhaus.Temperatur
                                      LG
                                      Winnipuuh
                                      N 1 Antwort Letzte Antwort
                                      • W Winnipuuh
                                        @armilar Hallo,
                                        LG
                                        Winnipuuh
                                        N Offline
                                        N Offline
                                        niiccooo1
                                        schrieb am zuletzt editiert von niiccooo1
                                        #1919
                                        @winnipuuh
                                        Moin,
                                        ich nutze ebenfalls influxDB V1.8. Beim Debug spuckt er jedoch folgendes aus:
                                        31.1.2023, 08:01:00.963	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 1 - NaN - 1
                                        31.1.2023, 08:01:00.963	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 2 - NaN - 1
                                        31.1.2023, 08:01:00.963	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 3 - NaN - 1
                                        31.1.2023, 08:01:00.963	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 4 - NaN - 1
                                        31.1.2023, 08:01:00.964	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 5 - NaN - 1
                                        31.1.2023, 08:01:00.964	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 6 - NaN - 1
                                        31.1.2023, 08:01:00.964	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 7 - NaN - 1
                                        31.1.2023, 08:01:00.965	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 8 - NaN - 1
                                        31.1.2023, 08:01:00.965	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 9 - NaN - 1
                                        31.1.2023, 08:01:00.965	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 10 - NaN - 1
                                        31.1.2023, 08:01:00.965	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 11 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 12 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 13 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 14 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 15 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 16 - NaN - 1
                                        31.1.2023, 08:01:00.966	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 17 - NaN - 1
                                        31.1.2023, 08:01:00.967	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 18 - NaN - 1
                                        31.1.2023, 08:01:00.967	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 19 - NaN - 1
                                        31.1.2023, 08:01:00.967	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 20 - NaN - 1
                                        31.1.2023, 08:01:00.967	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 21 - NaN - 1
                                        31.1.2023, 08:01:00.968	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 22 - NaN - 1
                                        31.1.2023, 08:01:00.968	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 23 - NaN - 1
                                        31.1.2023, 08:01:00.968	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: 24 - NaN - 2
                                        31.1.2023, 08:01:00.968	[info ]: javascript.0 (624) script.js.NSPanels.cardChart_Stromverbrauch: NaN^1:00~NaN~NaN~NaN~NaN^1:00~NaN~NaN~NaN~NaN^1:00~NaN~NaN~NaN~NaN^1:00~NaN~NaN~NaN~NaN^1:00~NaN~NaN~NaN~NaN^1:00~NaN~NaN~NaN
                                        Anscheinend kann sich das Skript keine Werte aus der DB holen.
                                        Sieht das bei dir genauso aus?
                                        Nico
                                        EDIT: Habe das Problem finden können: Das Blockly ist nur für InfluxDB V2.x geeignet, da die Abfrage über FluxQL läuft. Für InfluxDB V1.8 muss die Abfrage in InfluxQL erfolgen.
                                        • N niiccooo1
                                          @winnipuuh
                                          Moin,
                                          Nico
                                          W Offline
                                          W Offline
                                          Winnipuuh
                                          #1920
                                          @niiccooo1 said in SONOFF NSPanel mit Lovelace UI:
                                          Hallo niicooo,
                                          das ist aber schade, da mein Rasp noch auf 32 bit läuft somit kann ich nicht auf Influx2.0 upgraden. Vielleicht kann jemand den code umschreiben für die Influx1.8 :-)
                                          LG
                                          Winnipuuh
