  4. Linux/Debian - Grafana-Repo muss aktualisiert werden
151 Beiträge 23 Kommentatoren 48.5k Aufrufe 22 Beobachtet
  • A australien
    @dp20eic
    ich dacht ich hab es, aber......
    pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    pi@raspberrypi:~ $ ls
    Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
    Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
    pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
    pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
          9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
    uid                      InfluxData Package Signing Key <support@influxdata.com>
    pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
    -bash: $: command not found
    gpg: no valid OpenPGP data found.
    pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
    pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
    Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
    Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
    Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
    Err:7 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
    Fetched 18.8 kB in 2s (9,253 B/s)
    Reading package lists... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    pi@raspberrypi:~ $
    @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
    Moin,
    lies mal im Thread, den @Thomas-Braun verlinkt hat weiter, dann kommst Du auch auf die Lösung :)
    Kleiner Tip,
    # ls -la /etc/apt/sources.list.d/
    Dann
    Bernd
      Moin,
      Kleiner Tip,
      Dann
      Bernd
      australien
      @dp20eic
      DANKE!!!!
      jetzt hab ich es auch :)
      • A australien
        @dp20eic
        das ganze von vorne
        pi@raspberrypi:~ $ cd
        pi@raspberrypi:~ $ pwd
        /home/pi
        Hit:1 https://repos.influxdata.com/debian stable InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
        Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:7 https://deb.nodesource.com/node_17.x bullseye InRelease
        Err:5 https://repos.influxdata.com/debian bullseye InRelease
        Fetched 7,022 B in 2s (3,881 B/s)
        pi@raspberrypi:~ $
        das ganze von vorne
        Moin,
        warum so ungeduldig?
        Erst lesen, dann Nachdenken :)
        Du hast mit Sicherheit mehr Source List Files für influxDB im Verzeichnis, die werden beim apt-get update auch genommen, nur die alten List Files haben keine gültige Signatur mehr.
        Also immer ganz ruhig junger Padawan :)
        Bernd
          das ganze von vorne
          Moin,
          Bernd
          Marty56
          schrieb am zuletzt editiert von Marty56
          Danke an alle.
          Warum muss Linux immer so eine fürchterlichere Frickelei sein?!
          Ich verstehe das nicht.
          Ich habe die Befehle vom ersten Post eingetippt.
          Und bekomme jetzt folgenden Output.
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 http://ftp.debian.org/debian bullseye InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
          Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
          Get:6 https://apt.grafana.com stable InRelease [5984 B]
          Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
          Ign:8 https://apt.tvheadend.org/unstable bullseye InRelease
          Hit:9 https://apt.tvheadend.org/unstable bullseye Release
          Err:4 https://packages.grafana.com/oss/deb stable InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          Get:11 https://apt.grafana.com stable/main amd64 Packages [105 kB]
          Fetched 118 kB in 1s (80.5 kB/s)
          4 packages can be upgraded. Run 'apt list --upgradable' to see them.
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          N: Skipping acquire of configured file 'main/binary-amd64/Packages' as repository 'https://apt.tvheadend.org/unstable bullseye InRelease' doesn't support architecture 'amd64'
          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          apt-key list | grep -i grafana | wc -l
          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
          HW:NUC (16 GB Ram)
          OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
          wendy2702W ? 2 Antworten Letzte Antwort
          • M Marty56
            Danke an alle.
            wendy2702W Offline
            wendy2702W Offline
            @marty56 sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
            Verstehe nicht was daran Frickelei ist. Blos weil du bei WIndows nicht mitbekommst was die auf deinem Rechner veranstalten ist es nicht besser.
            Poste doch bitte mal die vollständige Ausgabe der Eingabe der Befehle aus dem ersten Post.
            • M Marty56
              Danke an alle.
              Moin,
              Zu 1: Das hat nichts mit Linux zu tun, sondern mit der Distribution und den 3rd. Party Software Hersteller, die versuchen zu verhinder, das schlechte Menschen, verseuchte Pakete auf Deinen PC installieren können. Jede Distribution kocht da leider ihr eigenes Süppchen.
              Zu 2. Dann musst Du dir mal ein gutes Buch zu Linux kaufen und lesen, dann wird vieles klar :)
              Zu 3. immer nur Befehle, die ein anderer hier eintippt blindlings zu kopieren und sich dann zu wundern wieso geht das bei mir nicht, ist auch nicht so klug.
              Hatte ich ja schon weiter oben geschrieben, Lesen (Bildet) dann nachdenken, dann handeln.
              Wenn Du auf die Seite von Grafana gehst, steht genau beschrieben was zu tun ist, um die neuen Signaturen in sein System zu bekommen.
              Bernd
                Moin,
                Bernd
                Marty56
                @dp20eic Sehr hilfreich. Leider habe ich überhaupt keinen Bock, Bücher über Linux zu lesen und Frickelkönig zu werden.
                HW:NUC (16 GB Ram)
                ? Thomas BraunT ChaotC 3 Antworten Letzte Antwort
                -4
                • M Marty56
                  Moin,
                  ist doch eine Aussage, kann ich mit leben, ob Du damit leben kannst und ob Du mit dieser Einstellung Hilfe bekommst, kann ich Dir nur wünschen. Ich bin dann mal weg.
                  Bernd
                  • M Marty56
                    Dann lass es bleiben und nerv andere nicht mit deinem Unwillen dich damit zu beschäftigen.
                    Ich z.B. habe überhaupt keinen Bock so triviales Zeug Leuten zu erklären die es nicht wissen wollen. Setz besser ein Windows ein.
                    Das Repo ist nach der obigen Anleitung und mit ein wenig Nachdenken in Nullkommanix richtig umgestellt. Hat gestern bei mir keine 10 Sekunden gedauert. Da war nix 'zu frickeln'.
                    • M Marty56
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      @marty56 Ich verstehe dein Problem nicht.
                      Ich musste mich beim Übergang von win 3.1 auf Win 95 komplett neu damit befassen. Dann kam Win2000 was auch viele Eigenheiten hatte und dann die Umstellung auf Win7. Auch hier musste einiges komplett neu erlernt werden.
                      Warum ist das bei Windows ok, aber bei Linux plötzlich böse?
                      Wenn ich eine Software nutze muss ich mich halt damit beschäftigen damit ich sie richtig einsetzen kann. Das war schon bei PC-DOS so und wird auch bei Win 25 irgendwann so bleiben.
                      Und Frickelkönig? Dann hast du noch nie einen Windows Server bearbeitet.
                      • ? Offline
                        Moin,
                        lasst doch gut sein, es geht hier nur darum Grafana und zwischendurch auch mal influxDB nach der Singnaturänderung wieder ans Laufen zu bringen, alles andere ist vergebene Liebesmüh und bring hier gar nichts :)
                        Bernd
                          Moin,
                          Bernd
                          Marty56
                          @dp20eic ganz meiner Meinung. Sorry, dass ich vom Thema abgewichen bin.
                          HW:NUC (16 GB Ram)
                            @lessthanmore
                            Key löschen. Geht wie oben:
                            sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                            Die /etc/apt/sources.list.d/influxdata.list löschen.
                            Aktuelles Setup für influxdb:
                            wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
                            export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                            echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                            shellyrulestheworld
                            Vielen Dank für deine Beiträge. Hab auch versucht influxdb umzustellen, wie von dir beschrieben.
                            Fetched 7,022 B in 3s (2,530 B/s)
                            klappt aber leider nicht. Hab ich was vergessen?
                            mein vorgehen war folgendes:
                            apt-key list | grep -i influxdb | wc -l
                            sudo rm influxdb.list
                            • S shellyrulestheworld
                              @shellyrulestheworld
                              ls -lA /etc/apt/sources.list.d/
                              sudo apt update
                              sagt? Vollständig posten, nix weg lassen. Auch nicht das login prompt.
                                sudo apt update
                                shellyrulestheworld
                                @thomas-braun said in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                                pi@raspberrypi:~ $ ls -lA /etc/apt/sources.list.d/
                                total 24
                                -rw-r--r-- 1 root root  60 Dec 23 10:10 deconz.list
                                -rw-r--r-- 1 root root  84 Jan 30 14:21 grafana.list
                                -rw-r--r-- 1 root root 101 Jan 30 15:05 influxdb.list
                                -rw-r--r-- 1 root root 208 Dec 23 09:34 nodesource.list
                                -rw-r--r-- 1 root root 398 Jan 11 16:11 ookla_speedtest-cli.list
                                -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
                                Hit:7 https://apt.grafana.com stable InRelease
                                Get:8 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                                Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                Err:8 https://repos.influxdata.com/debian bullseye InRelease
                                Fetched 7,022 B in 2s (3,282 B/s)
                                pi@raspberrypi:~ $
                                  total 24
                                  pi@raspberrypi:~ $
                                  sudo rm /etc/apt/sources.list.d/influxdb.list
                                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                  sudo apt update
                                  sudo apt full-upgrade
                                  S hotspot_2H 2 Antworten Letzte Antwort
                                    sudo apt update
                                    shellyrulestheworld
                                    ein großes Dankeschön, läuft perfekt durch :-)
                                    Ist wirklich ein klasse Support von dir
                                    • darkbluD Offline
                                      darkbluD Offline
                                      darkblu
                                      und wieder eine Anfänger Frage, muss ich hier auch die beiden Schlüssel von influx löschen ?
                                      pi@raspberrypi:~ $ apt-key list
                                      pub   rsa2048 2012-04-01 [SC]
                                            A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
                                      uid        [ unbekannt ] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
                                      sub   rsa2048 2012-04-01 [E]
                                      pub   rsa2048 2012-06-17 [SC]
                                            CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
                                      uid        [ unbekannt ] Raspberry Pi Archive Signing Key
                                      sub   rsa2048 2012-06-17 [E]
                                      pub   rsa4096 2015-09-28 [SC]
                                            05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
                                      uid        [ unbekannt ] InfluxDB Packaging Service <support@influxdb.com>
                                      sub   rsa4096 2015-09-28 [E]
                                      pub   rsa4096 2023-01-18 [SC] [verfällt: 2026-01-17]
                                      uid        [ unbekannt ] InfluxData Package Signing Key <support@influxdata.com>
                                      pi@raspberrypi:~ $
                                      und dann
                                      sudo apt update
                                      ausführen ?
                                      Raspi 4, 4GB für Influxdb 1.8 und Grafana
                                      Raspi 5, 8 GB für ioBroker
                                      Threadnetzwerk per Apple
                                      • darkbluD darkblu
                                        pi@raspberrypi:~ $
                                        und dann
                                        sudo apt update
                                        ausführen ?
                                        @darkblu
                                        Ja, die Schlüssel sollten aus apt-key raus.
                                        Ob du dann das Repo anlegen musst hängt vom jetzigen Setup ab.
                                        darkbluD 1 Antwort Letzte Antwort
                                          @darkblu
                                          darkbluD Offline
                                          darkbluD Offline
                                          darkblu
                                          Wie finde ich denn raus, ob ich das Repo anlegen muss, bzw. welches Setup ich habe ?
                                          Sorry für meine Unwissenheit.
